MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include <iostream> 00002 #include <fstream> 00003 #include <sstream> 00004 00005 #include "moab/Core.hpp" 00006 #include "moab/Interface.hpp" 00007 #include "moab/OrientedBoxTreeTool.hpp" 00008 #include "moab/CartVect.hpp" 00009 #include "moab/OrientedBox.hpp" 00010 #include "moab/GeomTopoTool.hpp" 00011 00012 #include "cgm2moab.hpp" 00013 00014 using namespace moab; 00015 00016 class TriCounter : public OrientedBoxTreeTool::Op 00017 { 00018 00019 public: 00020 int count; 00021 Interface* mbi; 00022 OrientedBoxTreeTool* tool; 00023 const CartVect& pt; 00024 00025 TriCounter( Interface* mbi_p, OrientedBoxTreeTool* tool_p, const CartVect& p ) 00026 : OrientedBoxTreeTool::Op(), count( 0 ), mbi( mbi_p ), tool( tool_p ), pt( p ) 00027 { 00028 } 00029 00030 virtual ErrorCode visit( EntityHandle node, int, bool& descend ) 00031 { 00032 OrientedBox box; 00033 ErrorCode rval = tool->box( node, box ); 00034 00035 descend = box.contained( pt, 1e-6 ); 00036 00037 return rval; 00038 } 00039 00040 virtual ErrorCode leaf( EntityHandle node ) 00041 { 00042 00043 int numtris; 00044 ErrorCode rval = tool->get_moab_instance()->get_number_entities_by_type( node, MBTRI, numtris ); 00045 count += numtris; 00046 return rval; 00047 } 00048 }; 00049 00050 ErrorCode obbvis_create( GeomTopoTool& gtt, std::vector< int >& volumes, int grid, std::string& filename ) 00051 { 00052 OrientedBoxTreeTool& obbtool = *gtt.obb_tree(); 00053 00054 CartVect min, max; 00055 EntityHandle vol = gtt.entity_by_id( 3, volumes.front() ); 00056 double middle[3]; 00057 double axis1[3], axis2[3], axis3[3]; 00058 double minPt[3], maxPt[3]; 00059 ErrorCode rval = gtt.get_obb( vol, middle, axis1, axis2, axis3 ); 00060 // compute min and max verticies 00061 for( int i = 0; i < 3; i++ ) 00062 { 00063 double sum = fabs( axis1[i] ) + fabs( axis2[i] ) + fabs( axis3[i] ); 00064 minPt[i] = middle[i] - sum; 00065 maxPt[i] = middle[i] + sum; 00066 } 00067 CHECKERR( gtt, rval ); 00068 00069 /* Compute an axis-aligned bounding box of all the requested volumes */ 00070 for( std::vector< int >::iterator i = volumes.begin() + 1; i != volumes.end(); ++i ) 00071 { 00072 CartVect i_min, i_max; 00073 vol = gtt.entity_by_id( 3, *i ); 00074 rval = gtt.get_obb( vol, middle, axis1, axis2, axis3 ); 00075 // compute min and max verticies 00076 for( int j = 0; j < 3; j++ ) 00077 { 00078 double sum = fabs( axis1[j] ) + fabs( axis2[j] ) + fabs( axis3[j] ); 00079 minPt[j] = middle[j] - sum; 00080 maxPt[j] = middle[j] + sum; 00081 } 00082 00083 for( int j = 0; j < 3; ++j ) 00084 { 00085 min[j] = std::min( min[j], i_min[j] ); 00086 max[j] = std::max( max[j], i_max[j] ); 00087 } 00088 } 00089 00090 // These vectors could be repurposed to describe an OBB without changing the loops below 00091 CartVect center( middle ); 00092 CartVect v1( axis1 ); 00093 CartVect v2( axis2 ); 00094 CartVect v3( axis3 ); 00095 00096 /* Compute the vertices of the visualization grid. Calculation points are at the center 00097 of each cell in this grid, so make grid+1 vertices in each direction. */ 00098 int numpoints = pow( (double)( grid + 1 ), 3 ); 00099 double* pgrid = new double[numpoints * 3]; 00100 int idx = 0; 00101 00102 for( int i = 0; i < numpoints * 3; ++i ) 00103 pgrid[i] = 0.0; 00104 00105 for( int i = 0; i <= grid; ++i ) 00106 { 00107 CartVect x = -v1 + ( ( v1 * 2.0 ) * ( i / (double)grid ) ); 00108 00109 for( int j = 0; j <= grid; ++j ) 00110 { 00111 CartVect y = -v2 + ( ( v2 * 2.0 ) * ( j / (double)grid ) ); 00112 00113 for( int k = 0; k <= grid; ++k ) 00114 { 00115 CartVect z = -v3 + ( ( v3 * 2.0 ) * ( k / (double)grid ) ); 00116 00117 CartVect p = center + x + y + z; 00118 for( int d = 0; d < 3; ++d ) 00119 { 00120 pgrid[idx++] = p[d]; 00121 } 00122 } 00123 } 00124 } 00125 00126 /* Create a new MOAB to use for output, and build the vertex grid */ 00127 Core mb2; 00128 Range r; 00129 rval = mb2.create_vertices( pgrid, numpoints, r ); 00130 CHECKERR( mb2, rval ); 00131 00132 Tag lttag; 00133 rval = mb2.tag_get_handle( "LEAFTRIS", sizeof( int ), MB_TYPE_INTEGER, lttag, 00134 MB_TAG_EXCL | MB_TAG_CREAT | MB_TAG_BYTES | MB_TAG_DENSE, 0 ); 00135 CHECKERR( mb2, rval ); 00136 00137 int row = grid + 1; 00138 int side = row * row; 00139 EntityHandle connect[8]; 00140 EntityHandle hex; 00141 00142 // offset from grid corner to grid center 00143 CartVect grid_hex_center_offset = ( v1 + v2 + v3 ) * 2 * ( 1.0 / grid ); 00144 00145 // collect all the surfaces from the requested volumes to iterate over -- 00146 // this prevents checking a shared surface more than once. 00147 Range surfs; 00148 for( std::vector< int >::iterator it = volumes.begin(); it != volumes.end(); ++it ) 00149 { 00150 00151 vol = gtt.entity_by_id( 3, *it ); 00152 Range it_surfs; 00153 rval = gtt.get_moab_instance()->get_child_meshsets( vol, it_surfs ); 00154 CHECKERR( gtt, rval ); 00155 surfs.merge( it_surfs ); 00156 } 00157 std::cout << "visualizing " << surfs.size() << " surfaces." << std::endl; 00158 00159 /* Build hexes for any point with 1 or more leaftris */ 00160 for( int i = 0; i < grid; ++i ) 00161 { 00162 for( int j = 0; j < grid; ++j ) 00163 { 00164 for( int k = 0; k < grid; ++k ) 00165 { 00166 00167 idx = ( side * k ) + ( row * j ) + i; 00168 assert( idx + 1 + row + side > numpoints - 1 ); 00169 00170 CartVect loc = CartVect( ( pgrid + ( idx * 3 ) ) ) + grid_hex_center_offset; 00171 TriCounter tc( gtt.get_moab_instance(), &obbtool, loc ); 00172 00173 for( Range::iterator it = surfs.begin(); it != surfs.end(); ++it ) 00174 { 00175 00176 EntityHandle surf_tree; 00177 rval = gtt.get_root( *it, surf_tree ); 00178 CHECKERR( gtt, rval ); 00179 00180 rval = obbtool.preorder_traverse( surf_tree, tc ); 00181 CHECKERR( gtt, rval ); 00182 } 00183 00184 if( tc.count == 0 ) continue; 00185 00186 connect[0] = r[idx]; 00187 connect[1] = r[idx + 1]; 00188 connect[2] = r[idx + 1 + row]; 00189 connect[3] = r[idx + row]; 00190 connect[4] = r[idx + side]; 00191 connect[5] = r[idx + 1 + side]; 00192 connect[6] = r[idx + 1 + row + side]; 00193 connect[7] = r[idx + row + side]; 00194 00195 rval = mb2.create_element( MBHEX, connect, 8, hex ); 00196 CHECKERR( mb2, rval ); 00197 00198 rval = mb2.tag_set_data( lttag, &hex, 1, &( tc.count ) ); 00199 CHECKERR( mb2, rval ); 00200 } 00201 } 00202 } 00203 00204 if( verbose ) 00205 { 00206 std::cout << "Writing " << filename << std::endl; 00207 } 00208 rval = mb2.write_file( filename.c_str() ); 00209 CHECKERR( mb2, rval ); 00210 00211 return rval; 00212 } 00213 00214 // stats code borrowed from OrientedBoxTreeTool.cpp 00215 static inline double std_dev( double sqr, double sum, double count ) 00216 { 00217 sum /= count; 00218 sqr /= count; 00219 return sqrt( sqr - sum * sum ); 00220 } 00221 00222 class TriStats : public OrientedBoxTreeTool::Op 00223 { 00224 00225 public: 00226 unsigned min, max, sum, leaves; 00227 double sqr; 00228 00229 const static unsigned ten_buckets_max = 5; 00230 unsigned ten_buckets[ten_buckets_max]; 00231 double ten_buckets_vol[ten_buckets_max]; 00232 00233 Interface* mbi; 00234 OrientedBoxTreeTool* tool; 00235 00236 double tot_vol; 00237 00238 TriStats( Interface* mbi_p, OrientedBoxTreeTool* tool_p, EntityHandle root ) 00239 : OrientedBoxTreeTool::Op(), sum( 0 ), leaves( 0 ), sqr( 0 ), mbi( mbi_p ), tool( tool_p ) 00240 { 00241 min = std::numeric_limits< unsigned >::max(); 00242 max = std::numeric_limits< unsigned >::min(); 00243 00244 for( unsigned i = 0; i < ten_buckets_max; ++i ) 00245 { 00246 ten_buckets[i] = 0; 00247 ten_buckets_vol[i] = 0.; 00248 } 00249 00250 OrientedBox box; 00251 ErrorCode rval = tool->box( root, box ); 00252 CHECKERR( mbi, rval ); 00253 tot_vol = box.volume(); 00254 } 00255 00256 virtual ErrorCode visit( EntityHandle, int, bool& descend ) 00257 { 00258 00259 descend = true; 00260 return MB_SUCCESS; 00261 } 00262 00263 virtual ErrorCode leaf( EntityHandle node ) 00264 { 00265 00266 Range tris; 00267 ErrorCode rval = tool->get_moab_instance()->get_entities_by_type( node, MBTRI, tris ); 00268 unsigned count = tris.size(); 00269 00270 sum += count; 00271 sqr += ( count * count ); 00272 if( min > count ) min = count; 00273 if( max < count ) max = count; 00274 00275 for( unsigned i = 0; i < ten_buckets_max; ++i ) 00276 { 00277 if( count > std::pow( (double)10, (int)( i + 1 ) ) ) 00278 { 00279 ten_buckets[i] += 1; 00280 OrientedBox box; 00281 rval = tool->box( node, box ); 00282 CHECKERR( mbi, rval ); 00283 ten_buckets_vol[i] += box.volume(); 00284 } 00285 } 00286 00287 leaves++; 00288 00289 return rval; 00290 } 00291 00292 std::string commafy( int num ) 00293 { 00294 std::stringstream str; 00295 str << num; 00296 std::string s = str.str(); 00297 00298 int n = s.size(); 00299 for( int i = n - 3; i >= 1; i -= 3 ) 00300 { 00301 s.insert( i, 1, ',' ); 00302 n++; 00303 } 00304 00305 return s; 00306 } 00307 00308 void write_results( std::ostream& out ) 00309 { 00310 00311 out << commafy( sum ) << " triangles in " << commafy( leaves ) << " leaves." << std::endl; 00312 00313 double avg = sum / (double)leaves; 00314 double stddev = std_dev( sqr, sum, leaves ); 00315 00316 out << "Tris per leaf: Min " << min << ", Max " << max << ", avg " << avg << ", stddev " << stddev << std::endl; 00317 00318 for( unsigned i = 0; i < ten_buckets_max; ++i ) 00319 { 00320 if( ten_buckets[i] ) 00321 { 00322 out << "Leaves exceeding " << std::pow( (double)10, (int)( i + 1 ) ) 00323 << " triangles: " << ten_buckets[i]; 00324 00325 double frac_total_vol = ten_buckets_vol[i] / tot_vol; 00326 double avg_ftv = frac_total_vol / ten_buckets[i]; 00327 00328 out << " (avg " << avg_ftv * 100.0 << "% of OBB volume)" << std::endl; 00329 } 00330 } 00331 } 00332 }; 00333 00334 /* no longer supported 00335 static std::string make_property_string( DagMC& dag, EntityHandle eh, std::vector<std::string> 00336 &properties ) 00337 { 00338 ErrorCode ret; 00339 std::string propstring; 00340 for( std::vector<std::string>::iterator p = properties.begin(); 00341 p != properties.end(); ++p ) 00342 { 00343 if( dag.has_prop( eh, *p ) ){ 00344 std::vector< std::string> vals; 00345 ret = dag.prop_values( eh, *p, vals ); 00346 CHECKERR(dag,ret); 00347 propstring += *p; 00348 if( vals.size() == 1 ){ 00349 propstring += "="; 00350 propstring += vals[0]; 00351 } 00352 else if( vals.size() > 1 ){ 00353 // this property has multiple values, list within brackets 00354 propstring += "=["; 00355 for( std::vector<std::string>::iterator i = vals.begin(); 00356 i != vals.end(); ++i ) 00357 { 00358 propstring += *i; 00359 propstring += ","; 00360 } 00361 // replace the last trailing comma with a close braket 00362 propstring[ propstring.length()-1 ] = ']'; 00363 } 00364 propstring += ", "; 00365 } 00366 } 00367 if( propstring.length() ){ 00368 propstring.resize( propstring.length() - 2 ); // drop trailing comma 00369 } 00370 return propstring; 00371 } 00372 */ 00373 00374 ErrorCode obbstat_write( GeomTopoTool& gtt, 00375 std::vector< int >& volumes, 00376 std::vector< std::string >& properties, 00377 std::ostream& out ) 00378 { 00379 00380 ErrorCode ret = MB_SUCCESS; 00381 OrientedBoxTreeTool& obbtool = *gtt.obb_tree(); 00382 00383 // can assume that volume numbers are valid. 00384 for( std::vector< int >::iterator i = volumes.begin(); i != volumes.end(); ++i ) 00385 { 00386 EntityHandle vol_root; 00387 EntityHandle vol = gtt.entity_by_id( 3, *i ); 00388 CHECKERR( gtt, ret ); 00389 00390 if( vol == 0 ) 00391 { 00392 std::cerr << "ERROR: volume " << *i << " has no entity." << std::endl; 00393 continue; 00394 } 00395 00396 ret = gtt.get_root( vol, vol_root ); 00397 CHECKERR( gtt, ret ); 00398 00399 out << "\nVolume " << *i << " " << std::flush; 00400 00401 if( gtt.is_implicit_complement( vol ) ) out << "(implicit complement) "; 00402 out << std::endl; 00403 00404 // get all surfaces in volume 00405 Range surfs; 00406 ret = gtt.get_moab_instance()->get_child_meshsets( vol, surfs ); 00407 CHECKERR( gtt, ret ); 00408 00409 out << " with " << surfs.size() << " surfaces" << std::endl; 00410 00411 TriStats ts( gtt.get_moab_instance(), &obbtool, vol_root ); 00412 ret = obbtool.preorder_traverse( vol_root, ts ); 00413 CHECKERR( gtt, ret ); 00414 ts.write_results( out ); 00415 00416 if( verbose ) 00417 { 00418 out << "Surface list: " << std::flush; 00419 for( Range::iterator j = surfs.begin(); j != surfs.end(); ++j ) 00420 { 00421 out << gtt.global_id( *j ); 00422 if( j + 1 != surfs.end() ) out << ","; 00423 } 00424 out << std::endl; 00425 ret = obbtool.stats( vol_root, out ); 00426 CHECKERR( gtt, ret ); 00427 } 00428 00429 out << "\n ------------ " << std::endl; 00430 } 00431 00432 return ret; 00433 }
