MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "mhdf.h"#include <stdlib.h>#include <stdio.h>#include <string.h>#include <sys/stat.h>#include <H5Tpublic.h>
Include dependency graph for validate.c:Go to the source code of this file.
Functions | |
| static int | check_valid_file_ids (struct mhdf_FileDesc *desc) |
| static int | check_file_contains_holes (const char *filename) |
| static int | check_valid_connectivity (mhdf_FileHandle file, struct mhdf_FileDesc *desc) |
| static int | check_valid_adjacencies (mhdf_FileHandle file, struct mhdf_FileDesc *desc) |
| static int | check_valid_sets (mhdf_FileHandle file, struct mhdf_FileDesc *desc) |
| static int | check_valid_tags (mhdf_FileHandle file, struct mhdf_FileDesc *desc) |
| static const char * | desc_name (struct mhdf_FileDesc *desc, struct mhdf_EntDesc *grp) |
| static int | id_contained (long file_id, const long *ranges, int num_range) |
| static int | ids_contained (const long *ids, int num_ids, const long *ranges, int num_ranges) |
| static int | ranges_contained (const long *id_ranges, int num_id_ranges, const long *ranges, int num_ranges) |
| static int | string_contained (const char *str, const char *const *const list) |
| static int | contains_duplicates (long *array, long n) |
| static int | ranges_contain_duplicates (long *ranges, long nranges) |
| static long * | all_id_ranges (struct mhdf_FileDesc *desc, int include_null, int *num_ranges_out) |
| static long * | get_dim_ranges (struct mhdf_FileDesc *desc, int dim, int *num_ranges_out) |
| static int | merge_ranges (long *ranges, int nranges) |
| static int | check_valid_end_indices (const long *indices, long num_idx, int min_len, long start_id, long max_value, const char *typestr, const char *name) |
| static int | check_valid_elem_conn (int idx, mhdf_FileHandle file, struct mhdf_FileDesc *desc, int conn_dim) |
| static int | check_valid_poly_conn (int idx, mhdf_FileHandle file, struct mhdf_FileDesc *desc, int conn_dim) |
| static int | check_valid_tag (int tag_idx, mhdf_FileHandle file, struct mhdf_FileDesc *desc) |
| static int | check_valid_var_len_tag (int tag_idx, mhdf_FileHandle file, struct mhdf_FileDesc *desc) |
| static int | check_valid_adj_list (long start_id, long count, const long *data, long data_len, const long *valid_ranges, long num_valid_ranges, const char *name) |
| static int | check_valid_parents_children (long start_id, long count, hid_t meta_handle, hid_t data_handle, long data_len, int parents) |
| static int | check_valid_set_contents (struct mhdf_FileDesc *desc, long start_id, long count, hid_t meta_handle, hid_t data_handle, long data_len) |
| static int | lcomp (const void *p1, const void *p2) |
| static int | dcomp (const void *p1, const void *p2) |
| int | main (int argc, char *argv[]) |
Variables | |
| int | verbose = 0 |
| program-wide verbose output flag | |
| static long * all_id_ranges | ( | struct mhdf_FileDesc * | desc, |
| int | include_null, | ||
| int * | num_ranges_out | ||
| ) | [static] |
Definition at line 907 of file validate.c.
References mhdf_EntDesc::count, mhdf_ElemDesc::desc, mhdf_FileDesc::elems, merge_ranges(), mhdf_FileDesc::nodes, mhdf_FileDesc::num_elem_desc, mhdf_FileDesc::sets, and mhdf_EntDesc::start_id.
Referenced by check_valid_set_contents(), check_valid_tag(), and check_valid_var_len_tag().
int i, num_ranges = 0;
struct mhdf_EntDesc* group;
long* ranges = malloc( 2 * sizeof( long ) * ( desc->num_elem_desc + 2 + !!include_null ) );
if( include_null )
num_ranges = 1;
ranges[0] = 0;
ranges[1] = 1;
for( i = -1; i <= desc->num_elem_desc; ++i )
if( i == -1 )
group = &desc->nodes;
else if( i == desc->num_elem_desc )
group = &desc->sets;
else
group = &desc->elems[i].desc;
if( num_ranges && ranges[2 * num_ranges - 2] + ranges[2 * num_ranges - 1] == group->start_id )
ranges[2 * num_ranges - 1] += group->count;
else
ranges[2 * num_ranges] = group->start_id;
ranges[2 * num_ranges + 1] = group->count;
++num_ranges;
*num_ranges_out = merge_ranges( ranges, num_ranges );
return ranges;
| int check_file_contains_holes | ( | const char * | filename | ) | [static] |
Definition at line 231 of file validate.c.
Referenced by main().
#ifndef _WIN32
const int blocksize = 512;
#endif
int errorcode;
struct stat buf;
errorcode = stat( filename, &buf );
if( errorcode )
perror( filename );
return 1;
#ifndef _WIN32 /*Does not have st_blocks*/
if( buf.st_size / blocksize > buf.st_blocks + 1 )
printf( "File \"%s\" contains holes. This indicates that portions of the file were never "
"written.\n",
filename );
return 1;
#endif
return 0;
| static int check_valid_adj_list | ( | long | start_id, |
| long | count, | ||
| const long * | data, | ||
| long | data_len, | ||
| const long * | valid_ranges, | ||
| long | num_valid_ranges, | ||
| const char * | name | ||
| ) | [static] |
Definition at line 637 of file validate.c.
References ids_contained(), and verbose.
Referenced by check_valid_adjacencies().
long i, n, id, invalid_id = 0, invalid_vals = 0;
const long* iter = data;
const long* const end = data + data_len;
int result = 0;
for( i = 0; iter != end; ++i )
id = *iter;
++iter;
if( iter == end )
printf( "Entry %ld in %s adjacency data (ID %ld) is truncated by the end of the "
"adjacency list.\n",
i, name, id );
result = 1;
break;
if( id < start_id || ( id - start_id ) >= count )
if( verbose )
printf( "Entry %ld in %s adjacency data has ID %ld outside of group range [%ld,%ld].\n", i, name, id,
start_id, start_id + count - 1 );
++invalid_id;
n = *iter;
++iter;
if( n < 1 )
printf( "Entry %ld in %s adjacency data (ID %ld) has %ld adjacency entries.\n", i, name, id, n );
result = 1;
if( n < 0 ) break; /* data is corrupt. don't proceed further */
if( iter + n > end )
i, name, id );
result = 1;
break;
if( !ids_contained( iter, n, valid_ranges, num_valid_ranges ) )
if( verbose )
printf( "Entry %ld in %s adjacency data (ID %ld) has invalid IDs in its adjacency "
"list.\n",
i, name, id );
++invalid_vals;
iter += n;
if( invalid_id )
printf( "%ld entries in %s adjacency data were for entities not in %s\n", invalid_id, name, name );
result = 1;
if( invalid_vals )
printf( "%ld entries in %s adjacency data contained invalid adjacent entity ids\n", invalid_id, name );
result = 1;
return result;
| int check_valid_adjacencies | ( | mhdf_FileHandle | file, |
| struct mhdf_FileDesc * | desc | ||
| ) | [static] |
Definition at line 584 of file validate.c.
References buffer, check_valid_adj_list(), mhdf_EntDesc::count, mhdf_ElemDesc::desc, mhdf_FileDesc::elems, mhdf_ElemDesc::handle, mhdf_ElemDesc::have_adj, mhdf_closeData(), mhdf_isError(), mhdf_message(), mhdf_openAdjacency(), mhdf_readAdjacency(), mhdf_FileDesc::num_elem_desc, and mhdf_EntDesc::start_id.
const int num_ranges = desc->num_elem_desc;
long *ranges, *buffer;
int i;
int invalid = 0;
long count;
hid_t handle;
mhdf_Status status;
/* Build list of ID ranges for all elements. Consider any element ID to be a valid
* thing to be adjacent to. So we disallow adjacency to nodes, sets, or undefined IDs */
ranges = malloc( sizeof( long ) * 2 * num_ranges );
for( i = 0; i < num_ranges; ++i )
ranges[2 * i] = desc->elems[i].desc.start_id;
ranges[2 * i + 1] = desc->elems[i].desc.count;
if( !desc->elems[i].have_adj ) continue;
handle = mhdf_openAdjacency( file, desc->elems[i].handle, &count, &status );
if( mhdf_isError( &status ) )
fprintf( stderr, "Internal error openening adjacency list for %s: %s\n", desc->elems[i].handle,
mhdf_message( &status ) );
free( ranges );
return 1;
buffer = malloc( sizeof( long ) * count );
mhdf_readAdjacency( handle, 0, count, H5T_NATIVE_LONG, buffer, &status );
fprintf( stderr, "Internal error reading adjacency list for %s: %s\n", desc->elems[i].handle,
free( ranges );
mhdf_closeData( file, handle, &status );
return 1;
invalid += check_valid_adj_list( desc->elems[i].desc.start_id, desc->elems[i].desc.count, buffer, count, ranges,
num_ranges, desc->elems[i].handle );
free( buffer );
free( ranges );
return invalid;
| int check_valid_connectivity | ( | mhdf_FileHandle | file, |
| ) | [static] |
Definition at line 259 of file validate.c.
References check_valid_elem_conn(), check_valid_poly_conn(), mhdf_ElemDesc::desc, dim, mhdf_FileDesc::elems, mhdf_POLYHEDRON_TYPE_NAME, mhdf_FileDesc::num_elem_desc, mhdf_ElemDesc::type, and mhdf_EntDesc::vals_per_ent.
int idx, dim, result = 0;
for( idx = 0; idx < desc->num_elem_desc; ++idx )
if( !strcmp( desc->elems[idx].type, mhdf_POLYHEDRON_TYPE_NAME ) )
dim = 2;
else
dim = 0;
if( desc->elems[idx].desc.vals_per_ent == -1 )
result += check_valid_poly_conn( idx, file, desc, dim );
else
result += check_valid_elem_conn( idx, file, desc, dim );
return result;
| int check_valid_elem_conn | ( | int | idx, |
| mhdf_FileHandle | file, | ||
| struct mhdf_FileDesc * | desc, | ||
| int | conn_dim | ||
| ) | [static] |
Definition at line 379 of file validate.c.
References buffer, mhdf_EntDesc::count, mhdf_ElemDesc::desc, mhdf_FileDesc::elems, get_dim_ranges(), mhdf_ElemDesc::handle, ids_contained(), mhdf_closeData(), mhdf_isError(), mhdf_message(), mhdf_openConnectivitySimple(), mhdf_readConnectivity(), mhdf_EntDesc::start_id, mhdf_EntDesc::vals_per_ent, and verbose.
Referenced by check_valid_connectivity().
long *ranges, *buffer, *iter;
int num_ranges;
long i, invalid = 0;
hid_t handle;
mhdf_Status status;
const long count = desc->elems[idx].desc.count;
const long len = desc->elems[idx].desc.vals_per_ent;
ranges = get_dim_ranges( desc, conn_dim, &num_ranges );
handle = mhdf_openConnectivitySimple( file, desc->elems[idx].handle, &status );
fprintf( stderr, "Internal error opening connectivity for %s: %s\n", desc->elems[idx].handle,
free( ranges );
return 1;
buffer = malloc( sizeof( long ) * count * len );
mhdf_readConnectivity( handle, 0, count, H5T_NATIVE_LONG, buffer, &status );
fprintf( stderr, "Internal error reading connectivity for %s: %s\n", desc->elems[idx].handle,
free( ranges );
free( buffer );
return 1;
iter = buffer;
for( i = 0; i < count; ++i, iter += len )
if( !ids_contained( iter, len, ranges, num_ranges ) )
if( verbose )
printf( "Invalid connectivity for element %ld (ID %ld) in %s\n", i, i + desc->elems[idx].desc.start_id,
desc->elems[idx].handle );
++invalid;
free( buffer );
free( ranges );
if( invalid )
printf( "%ld elements with invalid connectivity in %s\n", invalid, desc->elems[idx].handle );
return 1;
return 0;
| static int check_valid_end_indices | ( | const long * | indices, |
| long | num_idx, | ||
| int | min_len, | ||
| long | start_id, | ||
| long | max_value, | ||
| const char * | typestr, | ||
| ) | [static] |
Definition at line 434 of file validate.c.
References verbose.
Referenced by check_valid_parents_children(), check_valid_poly_conn(), check_valid_set_contents(), and check_valid_var_len_tag().
long i, invalid = 0, prev = -1;
if( num_idx == 0 )
printf( "WARNING: Empty index list for %s %s\n", name, typestr );
return 0;
for( i = 0; i < num_idx; ++i )
if( indices[i] < prev )
if( verbose )
if( start_id > 0 )
printf( "Invalid end index %ld for %s %ld (ID %ld). Prev index is %ld\n", indices[i], name, i,
i + start_id, prev );
else
printf( "Invalid end index %ld for entry %ld in %s %s. Prev index is %ld\n", indices[i], i, name,
typestr, prev );
++invalid;
else if( indices[i] - prev < min_len )
if( verbose )
if( start_id > 0 )
printf( "%s %ld (ID %ld) has only %ld values\n", name, i, start_id, indices[i] - prev );
else
printf( "Entry %ld in %s %s has only %ld values\n", i, name, typestr, indices[i] - prev );
++invalid;
else if( indices[i] >= max_value )
if( verbose )
if( start_id > 0 )
printf( "%s %ld (ID %ld) end index exceeds upper bound of %ld\n", name, i, start_id, max_value );
else
printf( "Entry %ld in %s %s end index exceeds uppper bound of %ld\n", i, name, typestr, max_value );
++invalid;
prev = indices[i];
if( invalid )
printf( "%ld invalid end indices for %s %s\n", invalid, typestr, name );
return invalid;
| int check_valid_file_ids | ( | struct mhdf_FileDesc * | desc | ) | [static] |
Definition at line 195 of file validate.c.
References mhdf_EntDesc::count, dcomp(), mhdf_ElemDesc::desc, desc_name(), mhdf_FileDesc::elems, mhdf_FileDesc::nodes, mhdf_FileDesc::num_elem_desc, mhdf_FileDesc::sets, and mhdf_EntDesc::start_id.
const int ngrp = 2 + desc->num_elem_desc;
int i, err = 0;
struct mhdf_EntDesc** sorted = malloc( ngrp * sizeof( struct mhdf_EntDesc* ) );
for( i = 0; i < desc->num_elem_desc; ++i )
sorted[i] = &desc->elems[i].desc;
sorted[i++] = &desc->nodes;
sorted[i] = &desc->sets;
qsort( sorted, ngrp, sizeof( struct mhdf_EntDesc* ), &dcomp );
for( i = 0; i < ngrp; ++i )
if( sorted[i]->count < 0 )
printf( "Group \"%s\" has negative count!\n", desc_name( desc, sorted[i] ) );
++err;
if( sorted[i]->count && sorted[i]->start_id == 0 )
printf( "Group \"%s\" contains NULL ID!\n", desc_name( desc, sorted[i] ) );
++err;
if( i > 0 && sorted[i - 1]->start_id + sorted[i - 1]->count > sorted[i]->start_id )
printf( "Conflicting group IDs for \"%s\" [%ld,%ld] and \"%s\" [%ld,%ld]\n",
desc_name( desc, sorted[i - 1] ), sorted[i - 1]->start_id,
sorted[i - 1]->start_id + sorted[i - 1]->count - 1, desc_name( desc, sorted[i] ),
sorted[i]->start_id, sorted[i]->start_id + sorted[i]->count - 1 );
++err;
free( sorted );
return err;
| static int check_valid_parents_children | ( | long | start_id, |
| long | count, | ||
| hid_t | meta_handle, | ||
| hid_t | data_handle, | ||
| int | parents | ||
| ) | [static] |
Definition at line 796 of file validate.c.
References check_valid_end_indices(), contains_duplicates(), ids_contained(), mhdf_isError(), mhdf_message(), mhdf_readSetChildEndIndices(), mhdf_readSetParentEndIndices(), mhdf_readSetParentsChildren(), and verbose.
Referenced by check_valid_sets().
mhdf_Status status;
long *indices, *contents;
const char parstr[] = "Parent";
const char cldstr[] = "Child";
const char* name = parents ? parstr : cldstr;
long i, prev, start, n;
long invalid = 0, invalid_dup = 0;
long range[2];
int result = 0;
range[0] = start_id;
range[1] = count;
indices = malloc( sizeof( long ) * count );
if( parents )
mhdf_readSetParentEndIndices( meta_handle, 0, count, H5T_NATIVE_LONG, indices, &status );
else
mhdf_readSetChildEndIndices( meta_handle, 0, count, H5T_NATIVE_LONG, indices, &status );
fprintf( stderr, "Internal error reading set %s end indices: %s\n", name, mhdf_message( &status ) );
free( indices );
return 1;
if( check_valid_end_indices( indices, count, 0, start_id, data_len, "Set", name ) )
free( indices );
return 1;
contents = malloc( sizeof( long ) * data_len );
mhdf_readSetParentsChildren( data_handle, 0, data_len, H5T_NATIVE_LONG, contents, &status );
fprintf( stderr, "Internal error reading set %s IDs: %s\n", name, mhdf_message( &status ) );
free( indices );
free( contents );
return 1;
prev = -1;
for( i = 0; i < count; ++i )
start = prev + 1;
n = indices[i] - prev;
prev = indices[i];
if( !ids_contained( contents + start, n, range, 1 ) )
if( verbose ) printf( "Set %ld (ID %ld) has invalid %s IDs.\n", i, start_id + i, name );
++invalid;
else if( contains_duplicates( contents + start, n ) )
if( verbose ) printf( "Set %ld (ID %ld) %s list contains duplicate IDs.\n", i, start_id + i, name );
++invalid_dup;
free( indices );
free( contents );
if( invalid )
printf( "%ld sets had invalid %s lists.\n", invalid, name );
result = 1;
if( invalid_dup )
printf( "%ld sets had duplicate handles in %s lists.\n", invalid_dup, name );
result = 1;
return result;
| int check_valid_poly_conn | ( | int | idx, |
| int | conn_dim | ||
| ) | [static] |
Definition at line 498 of file validate.c.
References buffer, check_valid_end_indices(), mhdf_FileDesc::elems, get_dim_ranges(), mhdf_ElemDesc::handle, ids_contained(), mhdf_closeData(), mhdf_isError(), mhdf_message(), mhdf_openPolyConnectivity(), mhdf_POLYHEDRON_TYPE_NAME, mhdf_readPolyConnIDs(), mhdf_readPolyConnIndices(), mhdf_ElemDesc::type, and verbose.
long *ranges, *buffer, *indices, *iter;
int num_ranges;
long i, invalid, num_poly, num_conn, first_id, prev, len;
hid_t handles[2];
mhdf_Status status;
int min_conn_len;
if( !strcmp( mhdf_POLYHEDRON_TYPE_NAME, desc->elems[idx].type ) )
min_conn_len = 4;
else
min_conn_len = 3;
mhdf_openPolyConnectivity( file, desc->elems[idx].handle, &num_poly, &num_conn, &first_id, handles, &status );
return 1;
indices = malloc( sizeof( long ) * num_poly );
mhdf_readPolyConnIndices( handles[0], 0, num_poly, H5T_NATIVE_LONG, indices, &status );
fprintf( stderr, "Internal error reading poly indices for %s: %s\n", desc->elems[idx].handle,
free( indices );
mhdf_closeData( file, handles[0], &status );
mhdf_closeData( file, handles[1], &status );
return 1;
invalid = check_valid_end_indices( indices, num_poly, min_conn_len, first_id, num_conn, "Connectivity",
if( invalid )
free( indices );
return 1;
buffer = malloc( sizeof( long ) * num_conn );
mhdf_readPolyConnIDs( handles[1], 0, num_conn, H5T_NATIVE_LONG, buffer, &status );
free( ranges );
free( indices );
free( buffer );
return 1;
prev = -1;
iter = buffer;
for( i = 0; i < num_poly; ++i )
len = indices[i] - prev;
prev = indices[i];
if( verbose )
printf( "Invalid connectivity for element %ld (ID %ld) in %s\n", i, i + first_id,
++invalid;
iter += len;
free( indices );
free( buffer );
free( ranges );
if( invalid )
return 1;
return 0;
| static int check_valid_set_contents | ( | struct mhdf_FileDesc * | desc, |
| long | count, | ||
| long | data_len | ||
| ) | [static] |
Definition at line 943 of file validate.c.
References all_id_ranges(), check_valid_end_indices(), contains_duplicates(), mhdf_EntDesc::count, ids_contained(), mhdf_isError(), mhdf_message(), mhdf_readSetContentEndIndices(), mhdf_readSetData(), mhdf_readSetFlags(), mhdf_SET_ORDER_BIT, mhdf_SET_RANGE_BIT, ranges_contain_duplicates(), ranges_contained(), and verbose.
mhdf_Status status;
short* flags;
long invalid_len = 0, invalid_handle = 0, invalid_dup = 0;
long* ranges;
int num_ranges;
int tmpresult;
mhdf_readSetContentEndIndices( meta_handle, 0, count, H5T_NATIVE_LONG, indices, &status );
fprintf( stderr, "Internal error reading set content end indices: %s\n", mhdf_message( &status ) );
free( indices );
return 1;
if( check_valid_end_indices( indices, count, 0, start_id, data_len, "Set", "Content" ) )
free( indices );
return 1;
ranges = all_id_ranges( desc, 0, &num_ranges );
flags = malloc( sizeof( short ) * count );
mhdf_readSetFlags( meta_handle, 0, count, H5T_NATIVE_SHORT, flags, &status );
fprintf( stderr, "Internal error reading set flags: %s\n", mhdf_message( &status ) );
free( indices );
free( flags );
free( ranges );
return 1;
mhdf_readSetData( data_handle, 0, data_len, H5T_NATIVE_LONG, contents, &status );
fprintf( stderr, "Internal error reading set content IDs: %s\n", mhdf_message( &status ) );
free( indices );
free( contents );
free( flags );
free( ranges );
return 1;
prev = -1;
start = prev + 1;
prev = indices[i];
if( flags[i] & mhdf_SET_RANGE_BIT )
if( n % 2 )
if( verbose )
printf( "Set %ld (ID %ld) is marked as range-compressed but has odd number of "
"content values.\n",
i + 1, start_id + i );
++invalid_len;
continue;
tmpresult = ranges_contained( contents + start, n / 2, ranges, num_ranges );
else
tmpresult = ids_contained( contents + start, n, ranges, num_ranges );
if( !tmpresult )
if( verbose ) printf( "Set %ld (ID %ld) has invalid content IDs.\n", i + 1, start_id + i );
++invalid_handle;
continue;
if( flags[i] & mhdf_SET_ORDER_BIT ) continue;
tmpresult = ranges_contain_duplicates( contents + start, n / 2 );
else
tmpresult = contains_duplicates( contents + start, n );
if( tmpresult )
if( verbose )
printf( "Set %ld (ID %ld) is not ordered but contains duplicate handles.\n", i + 1, start_id + i );
++invalid_dup;
free( indices );
free( contents );
free( flags );
free( ranges );
tmpresult = 0;
if( invalid_len )
printf( "%ld ranged sets had invalid (odd) content list lengths.\n", invalid_len );
tmpresult = 1;
if( invalid_handle )
printf( "%ld sets had invalid IDs in their content lists.\n", invalid_handle );
tmpresult = 1;
if( invalid_dup )
printf( "%ld unordered sets had duplicate IDs in their content lists.\n", invalid_dup );
tmpresult = 1;
return tmpresult;
| int check_valid_sets | ( | mhdf_FileHandle | file, |
| ) | [static] |
Definition at line 714 of file validate.c.
References check_valid_parents_children(), check_valid_set_contents(), mhdf_EntDesc::count, mhdf_FileDesc::have_set_children, mhdf_FileDesc::have_set_contents, mhdf_FileDesc::have_set_parents, mhdf_closeData(), mhdf_isError(), mhdf_message(), mhdf_openSetChildren(), mhdf_openSetData(), mhdf_openSetMeta(), mhdf_openSetParents(), and mhdf_FileDesc::sets.
long count, start_id, data_len;
mhdf_Status status;
hid_t meta, handle;
int result = 0;
if( desc->sets.count == 0 ) return 0;
meta = mhdf_openSetMeta( file, &count, &start_id, &status );
fprintf( stderr, "Internal error opening set description table: %s\n", mhdf_message( &status ) );
return 1;
if( desc->have_set_contents )
handle = mhdf_openSetData( file, &data_len, &status );
fprintf( stderr, "Internal error opening set contents table: %s\n", mhdf_message( &status ) );
else
result += check_valid_set_contents( desc, start_id, count, meta, handle, data_len );
if( desc->have_set_children )
handle = mhdf_openSetChildren( file, &data_len, &status );
fprintf( stderr, "Internal error opening set child table: %s\n", mhdf_message( &status ) );
mhdf_closeData( file, meta, &status );
else
result += check_valid_parents_children( start_id, count, meta, handle, data_len, 0 );
if( desc->have_set_parents )
handle = mhdf_openSetParents( file, &data_len, &status );
else
result += check_valid_parents_children( start_id, count, meta, handle, data_len, 1 );
return result;
| static int check_valid_tag | ( | int | tag_idx, |
| ) | [static] |
Definition at line 1082 of file validate.c.
References all_id_ranges(), contains_duplicates(), mhdf_EntDesc::count, mhdf_TagDesc::default_value, mhdf_TagDesc::dense_elem_indices, mhdf_ElemDesc::desc, mhdf_FileDesc::elems, mhdf_TagDesc::global_value, mhdf_ElemDesc::handle, mhdf_TagDesc::have_sparse, ids_contained(), mhdf_closeData(), mhdf_ENTITY_ID, mhdf_isError(), mhdf_message(), mhdf_node_type_handle(), mhdf_openDenseTagData(), mhdf_openSparseTagData(), mhdf_readSparseTagEntities(), mhdf_readTagValues(), mhdf_set_type_handle(), mhdf_TagDesc::name, mhdf_FileDesc::nodes, mhdf_TagDesc::num_dense_indices, mhdf_FileDesc::sets, size, mhdf_TagDesc::size, mhdf_EntDesc::start_id, mhdf_FileDesc::tags, and mhdf_TagDesc::type.
Referenced by check_valid_tags().
long *ids = 0, count, junk;
long* ranges;
int nranges;
hid_t handles[3];
mhdf_Status status;
const struct mhdf_TagDesc* tag = &( desc->tags[tag_idx] );
int i, result = 0;
long srange[2] = { 0, 0 };
const char* name;
hid_t h5type;
hsize_t size;
if( tag->have_sparse )
mhdf_openSparseTagData( file, tag->name, &count, &junk, handles, &status );
fprintf( stderr, "Internal error opening sparse data for tag \"%s\": %s\n", tag->name,
return 1;
ids = malloc( sizeof( long ) * count );
mhdf_readSparseTagEntities( handles[0], 0, count, H5T_NATIVE_LONG, ids, &status );
fprintf( stderr, "Internal error reading sparse entities for tag \"%s\": %s\n", tag->name,
free( ids );
return 1;
ranges = all_id_ranges( desc, 0, &nranges );
if( !ids_contained( ids, count, ranges, nranges ) )
++result;
printf( "Sparse data for tag \"%s\" has values for invalid IDs\n", tag->name );
else if( contains_duplicates( ids, count ) )
++result;
printf( "Sparse data for tag \"%s\" has duplicate values for one or more entities\n", tag->name );
free( ranges );
for( i = 0; i < tag->num_dense_indices; ++i )
if( tag->dense_elem_indices[i] == -2 )
name = mhdf_set_type_handle();
else if( tag->dense_elem_indices[i] == -1 )
name = mhdf_node_type_handle();
else
name = desc->elems[tag->dense_elem_indices[i]].handle;
group = &desc->elems[tag->dense_elem_indices[i]].desc;
srange[0] = group->start_id;
srange[1] = group->count;
if( ids_contained( ids, count, srange, 2 ) )
++result;
printf( "Tag \"%s\" has both sparse values and dense values for one or more "
"entities in \"%s\"\n",
tag->name, name );
free( ids );
if( tag->type != mhdf_ENTITY_ID )
if( tag->have_sparse ) mhdf_closeData( file, handles[1], &status );
return result;
ranges = all_id_ranges( desc, 1, &nranges );
if( tag->default_value && !ids_contained( tag->default_value, tag->size, ranges, nranges ) )
++result;
printf( "Handle tag \"%s\" has invalid ID(s) in its default value.\n", tag->name );
if( tag->global_value && !ids_contained( tag->global_value, tag->size, ranges, nranges ) )
++result;
printf( "Handle tag \"%s\" has invalid ID(s) in its global/mesh value.\n", tag->name );
h5type = H5T_NATIVE_LONG;
if( tag->size > 1 )
size = tag->size;
#if defined( H5Tarray_create_vers ) && H5Tarray_create_vers > 1
h5type = H5Tarray_create( H5T_NATIVE_LONG, 1, &size );
#else
h5type = H5Tarray_create( H5T_NATIVE_LONG, 1, &size, NULL );
#endif
ids = malloc( tag->size * count * sizeof( long ) );
mhdf_readTagValues( handles[1], 0, count, h5type, ids, &status );
fprintf( stderr, "Internal error reading sparse values for handle tag \"%s\": %s\n", tag->name,
free( ids );
free( ranges );
if( tag->size > 1 ) H5Tclose( h5type );
return 1;
if( !ids_contained( ids, tag->size * count, ranges, nranges ) )
++result;
printf( "Sparse data for one or more entities with handle tag \"%s\" has invalid ID(s).\n", tag->name );
free( ids );
/*group = &desc->sets;*/
/*group = &desc->nodes;*/
else
/*group = &desc->elems[ tag->dense_elem_indices[i] ].desc;*/
handles[0] = mhdf_openDenseTagData( file, tag->name, name, &count, &status );
fprintf( stderr, "Internal dense values for handle tag \"%s\" on \"%s\": %s\n", tag->name, name,
++result;
continue;
mhdf_readTagValues( handles[0], 0, count, h5type, ids, &status );
fprintf( stderr, "Internal error reading dense values for handle tag \"%s\" on \"%s\": %s\n", tag->name,
free( ids );
++result;
continue;
++result;
printf( "Dense data on \"%s\" for handle tag \"%s\" has invalid ID(s) for one or more "
"entities.\n",
name, tag->name );
free( ids );
return result;
| int check_valid_tags | ( | mhdf_FileHandle | file, |
| ) | [static] |
Definition at line 1069 of file validate.c.
References check_valid_tag(), check_valid_var_len_tag(), mhdf_FileDesc::num_tag_desc, mhdf_TagDesc::size, and mhdf_FileDesc::tags.
int i, result = 0;
for( i = 0; i < desc->num_tag_desc; ++i )
if( desc->tags[i].size < 0 )
result += check_valid_var_len_tag( i, file, desc );
else
result += check_valid_tag( i, file, desc );
return result;
| static int check_valid_var_len_tag | ( | int | tag_idx, |
| ) | [static] |
Definition at line 1273 of file validate.c.
References all_id_ranges(), check_valid_end_indices(), contains_duplicates(), mhdf_EntDesc::count, mhdf_TagDesc::default_value, mhdf_TagDesc::default_value_size, mhdf_TagDesc::global_value, mhdf_TagDesc::global_value_size, mhdf_TagDesc::have_sparse, ids_contained(), mhdf_closeData(), mhdf_ENTITY_ID, mhdf_isError(), mhdf_message(), mhdf_openSparseTagData(), mhdf_readSparseTagEntities(), mhdf_readSparseTagIndices(), mhdf_readTagValues(), mhdf_TagDesc::name, mhdf_TagDesc::num_dense_indices, mhdf_TagDesc::size, mhdf_FileDesc::tags, and mhdf_TagDesc::type.
long *ids = 0, count, num_val;
long* ranges;
int nranges;
hid_t handles[3];
mhdf_Status status;
int result = 0;
if( tag->num_dense_indices != 0 )
printf( "Dense data for tag \"%s\" not allowed for variable-length tags\n", tag->name );
++result;
mhdf_openSparseTagData( file, tag->name, &count, &num_val, handles, &status );
return 1;
mhdf_closeData( file, handles[2], &status );
free( ids );
return 1;
++result;
++result;
free( ranges );
mhdf_readSparseTagIndices( handles[2], 0, count, H5T_NATIVE_LONG, ids, &status );
fprintf( stderr, "Internal error reading indices for variable length tag \"%s\": %s\n", tag->name,
free( ids );
return 1;
if( check_valid_end_indices( ids, count, 1, 0, num_val, "Variable-length tag", tag->name ) ) ++result;
free( ids );
return result;
if( tag->default_value && !ids_contained( tag->default_value, tag->default_value_size, ranges, nranges ) )
++result;
if( tag->global_value && !ids_contained( tag->global_value, tag->global_value_size, ranges, nranges ) )
++result;
ids = malloc( num_val * sizeof( long ) );
mhdf_readTagValues( handles[1], 0, num_val, H5T_NATIVE_LONG, ids, &status );
fprintf( stderr, "Internal error reading values for variable-length handle tag \"%s\": %s\n", tag->name,
free( ids );
free( ranges );
return 1;
++result;
printf( "Data for one or more entities with variable-length handle tag \"%s\" has "
"invalid ID(s).\n",
tag->name );
free( ids );
return result;
| static int contains_duplicates | ( | long * | array, |
| long | n | ||
| ) | [static] |
Definition at line 778 of file validate.c.
References lcomp().
Referenced by check_valid_parents_children(), check_valid_set_contents(), check_valid_tag(), and check_valid_var_len_tag().
long i;
qsort( array, n, sizeof( long ), &lcomp );
for( i = 1; i < n; ++i )
if( array[i - 1] == array[i] ) return 1;
return 0;
| static int dcomp | ( | const void * | p1, |
| const void * | p2 | ||
| ) | [static] |
Definition at line 127 of file validate.c.
References lcomp(), and mhdf_EntDesc::start_id.
Referenced by check_valid_file_ids().
const struct mhdf_EntDesc* d1 = *(const struct mhdf_EntDesc**)( p1 );
const struct mhdf_EntDesc* d2 = *(const struct mhdf_EntDesc**)( p2 );
return lcomp( &d1->start_id, &d2->start_id );
| static const char * desc_name | ( | struct mhdf_FileDesc * | desc, |
| struct mhdf_EntDesc * | grp | ||
| ) | [static] |
Definition at line 182 of file validate.c.
References mhdf_ElemDesc::desc, mhdf_ElemDesc::handle, mhdf_FileDesc::nodes, and mhdf_FileDesc::sets.
struct mhdf_ElemDesc junk, *elem;
const size_t diff = (char*)&junk.desc - (char*)&junk;
static const char nodes[] = "Vertices";
static const char sets[] = "Sets";
if( grp == &desc->nodes ) return nodes;
if( grp == &desc->sets ) return sets;
elem = (struct mhdf_ElemDesc*)( (char*)grp - diff );
return elem->handle;
| static long * get_dim_ranges | ( | struct mhdf_FileDesc * | desc, |
| int | dim, | ||
| ) | [static] |
Definition at line 329 of file validate.c.
References mhdf_EntDesc::count, mhdf_ElemDesc::desc, mhdf_FileDesc::elems, mdhf_HEX_TYPE_NAME, mdhf_KNIFE_TYPE_NAME, merge_ranges(), mhdf_EDGE_TYPE_NAME, mhdf_POLYGON_TYPE_NAME, mhdf_POLYHEDRON_TYPE_NAME, mhdf_PRISM_TYPE_NAME, mhdf_PYRAMID_TYPE_NAME, mhdf_QUAD_TYPE_NAME, mhdf_SEPTAHEDRON_TYPE_NAME, mhdf_TET_TYPE_NAME, mhdf_TRI_TYPE_NAME, mhdf_FileDesc::nodes, mhdf_FileDesc::num_elem_desc, mhdf_EntDesc::start_id, string_contained(), and mhdf_ElemDesc::type.
Referenced by check_valid_elem_conn(), and check_valid_poly_conn().
long* ranges = 0;
int i, j;
const char* const types1D[] = { mhdf_EDGE_TYPE_NAME, 0 };
const char* const types2D[] = { mhdf_TRI_TYPE_NAME, mhdf_QUAD_TYPE_NAME, mhdf_POLYGON_TYPE_NAME, 0 };
const char* const types3D[] = { mhdf_TET_TYPE_NAME, mhdf_PYRAMID_TYPE_NAME,
mhdf_PRISM_TYPE_NAME, mdhf_KNIFE_TYPE_NAME,
mdhf_HEX_TYPE_NAME, mhdf_POLYHEDRON_TYPE_NAME,
mhdf_SEPTAHEDRON_TYPE_NAME, 0 };
char const* const* typelist;
switch( dim )
case 0:
*num_ranges_out = 1;
ranges = malloc( 2 * sizeof( long ) );
ranges[0] = desc->nodes.start_id;
ranges[1] = desc->nodes.count;
return ranges;
case 1:
typelist = types1D;
break;
case 2:
typelist = types2D;
break;
case 3:
typelist = types3D;
break;
default:
fprintf( stderr, "Internal error at %s:%d: request for entities of dimesion %d\n", __FILE__, __LINE__,
dim );
abort();
*num_ranges_out = 0;
if( string_contained( desc->elems[i].type, typelist ) ) ++*num_ranges_out;
ranges = malloc( *num_ranges_out * 2 * sizeof( long ) );
for( i = 0, j = 0; i < desc->num_elem_desc; ++i )
ranges[j++] = desc->elems[i].desc.start_id;
ranges[j++] = desc->elems[i].desc.count;
*num_ranges_out = merge_ranges( ranges, *num_ranges_out );
return ranges;
| static int id_contained | ( | long | file_id, |
| const long * | ranges, | ||
| int | num_range | ||
| ) | [static] |
Definition at line 279 of file validate.c.
Referenced by ids_contained().
const long* end = ranges + 2 * num_range;
for( ; ranges != end; ranges += 2 )
if( file_id >= ranges[0] && ( file_id - ranges[0] ) < ranges[1] ) return 1;
return 0;
| static int ids_contained | ( | const long * | ids, |
| int | num_ids, | ||
| int | num_ranges | ||
| ) | [static] |
Definition at line 289 of file validate.c.
References id_contained().
Referenced by check_valid_adj_list(), check_valid_elem_conn(), check_valid_parents_children(), check_valid_poly_conn(), check_valid_set_contents(), check_valid_tag(), and check_valid_var_len_tag().
int i;
for( i = 0; i < num_ids; ++i )
if( !id_contained( ids[i], ranges, num_ranges ) ) return 0;
return 1;
| static int lcomp | ( | const void * | p1, |
| ) | [static] |
Definition at line 119 of file validate.c.
Referenced by contains_duplicates(), dcomp(), merge_ranges(), and ranges_contain_duplicates().
long l1 = *(const long*)p1;
long l2 = *(const long*)p2;
return l1 < l2 ? -1 : l1 > l2 ? 1 : 0;
| int main | ( | int | argc, |
| char * | argv[] | ||
Definition at line 136 of file validate.c.
References check_file_contains_holes(), check_valid_adjacencies(), check_valid_connectivity(), check_valid_file_ids(), check_valid_sets(), check_valid_tags(), mhdf_EntDesc::count, mhdf_closeFile(), mhdf_getFileSummary(), mhdf_isError(), mhdf_message(), mhdf_openFile(), mhdf_FileDesc::nodes, mhdf_FileDesc::num_elem_desc, and verbose.
int result = 0;
mhdf_FileHandle file;
mhdf_Status status;
unsigned long max_id;
struct mhdf_FileDesc* desc;
if( argc < 2 || argc > 3 )
fprintf( stderr, "Usage: %s <filename> <verbose_option> \n", argv[0] );
return 1;
file = mhdf_openFile( argv[1], 0, &max_id, -1, &status );
fprintf( stderr, "%s: %s\n", argv[1], mhdf_message( &status ) );
return 1;
if( argc == 3 )
verbose = atoi( argv[2] );
desc = mhdf_getFileSummary( file, H5T_NATIVE_LONG, &status, 0 ); /*no extra set info*/
return 1;
if( desc->nodes.count < 1 ) puts( "WARNING: file contains no vertices." );
if( desc->num_elem_desc < 1 ) puts( "WARNING: file contains no elements." );
result += check_valid_file_ids( desc );
result += check_file_contains_holes( argv[1] );
result += check_valid_connectivity( file, desc );
result += check_valid_adjacencies( file, desc );
result += check_valid_sets( file, desc );
result += check_valid_tags( file, desc );
free( desc );
mhdf_closeFile( file, &status );
return result;
| static int merge_ranges | ( | long * | ranges, |
| int | nranges | ||
| ) | [static] |
Definition at line 880 of file validate.c.
References lcomp().
Referenced by all_id_ranges(), and get_dim_ranges().
long i, n;
if( nranges < 1 ) return 0;
/* merge adjacent */
qsort( ranges, nranges, 2 * sizeof( long ), &lcomp );
n = 1;
for( i = 1; i < nranges; ++i )
if( ranges[2 * n - 2] + ranges[2 * n - 1] == ranges[2 * i] )
ranges[2 * n - 1] += ranges[2 * i + 1]; /*compact the range*/
else
/* do not compact, just copy, and increase number of ranges*/
ranges[2 * n] = ranges[2 * i];
ranges[2 * n + 1] = ranges[2 * i + 1];
++n;
return n;
| static int ranges_contain_duplicates | ( | long * | ranges, |
| long | nranges | ||
| ) | [static] |
Definition at line 787 of file validate.c.
References lcomp().
Referenced by check_valid_set_contents().
long i;
qsort( ranges, nranges, 2 * sizeof( long ), &lcomp ); /* sort by first value in each pair */
if( ranges[2 * i - 2] + ranges[2 * i - 1] > ranges[2 * i] ) return 1;
return 0;
| static int ranges_contained | ( | const long * | id_ranges, |
| int | num_id_ranges, | ||
| ) | [static] |
Definition at line 297 of file validate.c.
int i;
long start, count, avail;
const long* end = ranges + 2 * num_ranges;
const long* iter;
for( i = 0; i < num_id_ranges; ++i )
start = id_ranges[2 * i];
count = id_ranges[2 * i + 1];
while( count > 0 )
for( iter = ranges; iter != end; iter += 2 )
if( start >= iter[0] && ( start - iter[0] ) < iter[1] ) break;
if( iter == end ) return 0;
avail = iter[1] - ( start - iter[0] );
count -= avail;
start += avail;
return 1;
| static int string_contained | ( | const char * | str, |
| const char *const *const | list | ||
| ) | [static] |
Definition at line 322 of file validate.c.
Referenced by get_dim_ranges().
for( ; *list; ++list )
if( !strcmp( str, *list ) ) return 1;
return 0;
| int verbose = 0 |
Definition at line 134 of file validate.c.
Referenced by check_valid_adj_list(), check_valid_elem_conn(), check_valid_end_indices(), check_valid_parents_children(), check_valid_poly_conn(), check_valid_set_contents(), main(), merge_input_surfs(), obbstat_write(), obbvis_create(), and replace_surface().
