MOAB: Mesh Oriented datABase
(version 5.4.1)
Include dependency graph for AddFieldtoPG2.cpp:Go to the source code of this file.
Functions | |
| int | main (int argc, char *argv[]) |
| int main | ( | int | argc, |
| char * | argv[] | ||
Definition at line 8 of file AddFieldtoPG2.cpp.
References ProgOptions::addOpt(), moab::Core::create_meshset(), ErrorCode, moab::Core::get_entities_by_dimension(), moab::Core::globalId_tag(), moab::Core::load_file(), mb, MB_CHK_SET_ERR, MESHSET_SET, outfile, ProgOptions::parseCommandLine(), ProgOptions::printHelp(), moab::Range::size(), moab::Core::tag_get_data(), moab::Core::tag_get_handle(), moab::Core::tag_set_data(), and moab::Core::write_file().
ProgOptions opts;
std::string inputfile, outfile( "out.h5m" ), physgridfile, variable_name;
opts.addOpt< std::string >( "input,i", "input mesh filename", &inputfile );
opts.addOpt< std::string >( "output,o", "output mesh filename", &outfile );
opts.addOpt< std::string >( "phys,p", "phys grid solution filename", &physgridfile );
opts.addOpt< std::string >( "var,v", "variable to extract and add to output file", &variable_name );
opts.parseCommandLine( argc, argv );
if( inputfile.empty() )
opts.printHelp();
return 0;
ErrorCode rval;
Core* mb = new Core();
EntityHandle fset1, fset2;
rval = mb->create_meshset( MESHSET_SET, fset1 );MB_CHK_SET_ERR( rval, "can't create mesh set" );
rval = mb->load_file( inputfile.c_str(), &fset1 );MB_CHK_SET_ERR( rval, "can't load input file" );
cout << " opened " << inputfile << " with initial h5m data.\n";
rval = mb->create_meshset( MESHSET_SET, fset2 );MB_CHK_SET_ERR( rval, "can't create mesh set" );
rval = mb->load_file( physgridfile.c_str(), &fset2 );MB_CHK_SET_ERR( rval, "can't load phys grid file" );
Tag tagv;
rval = mb->tag_get_handle( variable_name.c_str(), tagv );MB_CHK_SET_ERR( rval, "can't get tag handle" );
Tag gitag = mb->globalId_tag();
Range verts; // from phys grid
rval = mb->get_entities_by_dimension( fset2, 0, verts );MB_CHK_SET_ERR( rval, "can't get vertices" );
std::vector< int > gids;
gids.resize( verts.size() );
rval = mb->tag_get_data( gitag, verts, &gids[0] );MB_CHK_SET_ERR( rval, "can't get gi tag values" );
std::vector< double > valsTag;
valsTag.resize( verts.size() );
rval = mb->tag_get_data( tagv, verts, &valsTag[0] );MB_CHK_SET_ERR( rval, "can't get tag vals" );
Range cells;
rval = mb->get_entities_by_dimension( fset1, 2, cells );MB_CHK_SET_ERR( rval, "can't get cells" );
std::map< int, double > valsByID;
for( int i = 0; i < (int)gids.size(); i++ )
valsByID[gids[i]] = valsTag[i];
// set now cells values
std::vector< int > cellsIds;
cellsIds.resize( cells.size() );
rval = mb->tag_get_data( gitag, cells, &cellsIds[0] );MB_CHK_SET_ERR( rval, "can't get cells ids" );
for( int i = 0; i < (int)cells.size(); i++ )
valsTag[i] = valsByID[cellsIds[i]];
rval = mb->tag_set_data( tagv, cells, &valsTag[0] );MB_CHK_SET_ERR( rval, "can't set cells tags" );
rval = mb->write_file( outfile.c_str(), 0, 0, &fset1, 1 );MB_CHK_SET_ERR( rval, "can't write file" );
return 0;
