MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "moab/ProgOptions.hpp" 00002 #include "moab/Core.hpp" 00003 #include <iostream> 00004 00005 using namespace moab; 00006 using namespace std; 00007 00008 int main( int argc, char* argv[] ) 00009 { 00010 00011 ProgOptions opts; 00012 00013 std::string inputfile, outfile( "out.h5m" ), physgridfile, variable_name; 00014 00015 opts.addOpt< std::string >( "input,i", "input mesh filename", &inputfile ); 00016 opts.addOpt< std::string >( "output,o", "output mesh filename", &outfile ); 00017 opts.addOpt< std::string >( "phys,p", "phys grid solution filename", &physgridfile ); 00018 opts.addOpt< std::string >( "var,v", "variable to extract and add to output file", &variable_name ); 00019 00020 opts.parseCommandLine( argc, argv ); 00021 00022 if( inputfile.empty() ) 00023 { 00024 opts.printHelp(); 00025 return 0; 00026 } 00027 ErrorCode rval; 00028 Core* mb = new Core(); 00029 00030 EntityHandle fset1, fset2; 00031 rval = mb->create_meshset( MESHSET_SET, fset1 );MB_CHK_SET_ERR( rval, "can't create mesh set" ); 00032 rval = mb->load_file( inputfile.c_str(), &fset1 );MB_CHK_SET_ERR( rval, "can't load input file" ); 00033 00034 cout << " opened " << inputfile << " with initial h5m data.\n"; 00035 00036 rval = mb->create_meshset( MESHSET_SET, fset2 );MB_CHK_SET_ERR( rval, "can't create mesh set" ); 00037 rval = mb->load_file( physgridfile.c_str(), &fset2 );MB_CHK_SET_ERR( rval, "can't load phys grid file" ); 00038 00039 Tag tagv; 00040 rval = mb->tag_get_handle( variable_name.c_str(), tagv );MB_CHK_SET_ERR( rval, "can't get tag handle" ); 00041 00042 Tag gitag = mb->globalId_tag(); 00043 00044 Range verts; // from phys grid 00045 rval = mb->get_entities_by_dimension( fset2, 0, verts );MB_CHK_SET_ERR( rval, "can't get vertices" ); 00046 std::vector< int > gids; 00047 gids.resize( verts.size() ); 00048 rval = mb->tag_get_data( gitag, verts, &gids[0] );MB_CHK_SET_ERR( rval, "can't get gi tag values" ); 00049 std::vector< double > valsTag; 00050 valsTag.resize( verts.size() ); 00051 rval = mb->tag_get_data( tagv, verts, &valsTag[0] );MB_CHK_SET_ERR( rval, "can't get tag vals" ); 00052 Range cells; 00053 00054 rval = mb->get_entities_by_dimension( fset1, 2, cells );MB_CHK_SET_ERR( rval, "can't get cells" ); 00055 00056 std::map< int, double > valsByID; 00057 for( int i = 0; i < (int)gids.size(); i++ ) 00058 valsByID[gids[i]] = valsTag[i]; 00059 00060 // set now cells values 00061 std::vector< int > cellsIds; 00062 cellsIds.resize( cells.size() ); 00063 rval = mb->tag_get_data( gitag, cells, &cellsIds[0] );MB_CHK_SET_ERR( rval, "can't get cells ids" ); 00064 for( int i = 0; i < (int)cells.size(); i++ ) 00065 { 00066 valsTag[i] = valsByID[cellsIds[i]]; 00067 } 00068 rval = mb->tag_set_data( tagv, cells, &valsTag[0] );MB_CHK_SET_ERR( rval, "can't set cells tags" ); 00069 00070 rval = mb->write_file( outfile.c_str(), 0, 0, &fset1, 1 );MB_CHK_SET_ERR( rval, "can't write file" ); 00071 00072 return 0; 00073 }
