MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "moab/Core.hpp"#include "moab/Interface.hpp"#include <iostream>#include <cmath>#include "moab/IntxMesh/IntxUtils.hpp"#include <cassert>
Include dependency graph for proj1.cpp:Go to the source code of this file.
Functions | |
| int | main (int argc, char **argv) |
Variables | |
| double | radius = 1. |
| int main | ( | int | argc, |
| char ** | argv | ||
Definition at line 19 of file proj1.cpp.
References moab::Interface::add_entities(), moab::Range::begin(), moab::Interface::coords_iterate(), moab::Interface::create_meshset(), moab::Interface::delete_entities(), moab::Range::empty(), moab::Range::end(), ErrorCode, moab::Interface::get_entities_by_dimension(), moab::Interface::get_entities_by_type_and_tag(), moab::CartVect::length(), moab::Interface::load_mesh(), mb, MB_SUCCESS, MBENTITYSET, MESHSET_SET, output, radius, moab::Range::size(), moab::Interface::tag_delete(), moab::Interface::tag_get_handle(), moab::Interface::UNION, moab::Interface::write_file(), and moab::Interface::write_mesh().
bool delete_partition_sets = false;
if( argc < 3 ) return 1;
int index = 1;
char* input_mesh1 = argv[1];
char* output = argv[2];
while( index < argc )
if( !strcmp( argv[index], "-R" ) ) // this is for radius to project
radius = atof( argv[++index] );
if( !strcmp( argv[index], "-DS" ) ) // delete partition sets
delete_partition_sets = true;
if( !strcmp( argv[index], "-h" ) )
std::cout << " usage: proj1 <input> <output> -R <value> -DS (delete partition sets)\n";
return 1;
index++;
Core moab;
Interface& mb = moab;
ErrorCode rval = mb.load_mesh( input_mesh1 );
std::cout << " -R " << radius << " input: " << input_mesh1 << " output: " << output << "\n";
Range verts;
rval = mb.get_entities_by_dimension( 0, 0, verts );
if( MB_SUCCESS != rval ) return 1;
double *x_ptr, *y_ptr, *z_ptr;
int count;
rval = mb.coords_iterate( verts.begin(), verts.end(), x_ptr, y_ptr, z_ptr, count );
assert( count == (int)verts.size() ); // should end up with just one contiguous chunk of vertices
for( int v = 0; v < count; v++ )
// EntityHandle v = verts[v];
CartVect pos( x_ptr[v], y_ptr[v], z_ptr[v] );
pos = pos / pos.length();
pos = radius * pos;
x_ptr[v] = pos[0];
y_ptr[v] = pos[1];
z_ptr[v] = pos[2];
Range edges;
rval = mb.get_entities_by_dimension( 0, 1, edges );
// write edges to a new set, and after that, write the set, delete the edges and the set
EntityHandle sf1;
rval = mb.create_meshset( MESHSET_SET, sf1 );
rval = mb.add_entities( sf1, edges );
rval = mb.write_mesh( "edgesOnly.h5m", &sf1, 1 );
rval = mb.delete_entities( &sf1, 1 );
mb.delete_entities( edges );
mb.write_file( output );
if( delete_partition_sets )
Tag par_tag;
rval = mb.tag_get_handle( "PARALLEL_PARTITION", par_tag );
if( MB_SUCCESS == rval )
Range par_sets;
rval =
mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &par_tag, NULL, 1, par_sets, moab::Interface::UNION );
if( !par_sets.empty() ) mb.delete_entities( par_sets );
mb.tag_delete( par_tag );
return 0;
