MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /* 00002 * IntxUtils.hpp 00003 * 00004 * Created on: Oct 3, 2012 00005 */ 00006 00007 #ifndef INTXUTILS_HPP_ 00008 #define INTXUTILS_HPP_ 00009 00010 #include "moab/CartVect.hpp" 00011 #include "moab/Core.hpp" 00012 00013 namespace moab 00014 { 00015 00016 class IntxUtils 00017 { 00018 public: 00019 // vec utilities that could be common between quads on a plane or sphere 00020 static inline double dist2( double* a, double* b ) 00021 { 00022 double abx = b[0] - a[0], aby = b[1] - a[1]; 00023 return sqrt( abx * abx + aby * aby ); 00024 } 00025 00026 static inline double area2D( double* a, double* b, double* c ) 00027 { 00028 // (b-a)x(c-a) / 2 00029 return ( ( b[0] - a[0] ) * ( c[1] - a[1] ) - ( b[1] - a[1] ) * ( c[0] - a[0] ) ) / 2; 00030 } 00031 00032 static int borderPointsOfXinY2( double* X, int nX, double* Y, int nY, double* P, int* side, double epsilon_area ); 00033 00034 static int SortAndRemoveDoubles2( double* P, int& nP, double epsilon ); 00035 // the marks will show what edges of blue intersect the red 00036 00037 static ErrorCode EdgeIntersections2( double* blue, 00038 int nsBlue, 00039 double* red, 00040 int nsRed, 00041 int* markb, 00042 int* markr, 00043 double* points, 00044 int& nPoints ); 00045 00046 // special one, for intersection between rll (constant latitude) and cs quads 00047 static ErrorCode EdgeIntxRllCs( double* blue, 00048 CartVect* bluec, 00049 int* blueEdgeType, 00050 int nsBlue, 00051 double* red, 00052 CartVect* redc, 00053 int nsRed, 00054 int* markb, 00055 int* markr, 00056 int plane, 00057 double Radius, 00058 double* points, 00059 int& nPoints ); 00060 00061 // vec utils related to gnomonic projection on a sphere 00062 // vec utils 00063 /* 00064 * 00065 * position on a sphere of radius R 00066 * if plane specified, use it; if not, return the plane, and the point in the plane 00067 * there are 6 planes, numbered 1 to 6 00068 * plane 1: x=R, plane 2: y=R, 3: x=-R, 4: y=-R, 5: z=-R, 6: z=R 00069 * 00070 * projection on the plane will preserve the orientation, such that a triangle, quad pointing 00071 * outside the sphere will have a positive orientation in the projection plane 00072 * this is similar logic to 00073 * /cesm1_0_4/models/atm/cam/src/dynamics/homme/share/coordinate_systems_mod.F90 method: 00074 * function cart2face(cart3D) result(face_no) 00075 */ 00076 static void decide_gnomonic_plane( const CartVect& pos, int& oPlane ); 00077 00078 // point on a sphere is projected on one of six planes, decided earlier 00079 00080 static ErrorCode gnomonic_projection( const CartVect& pos, double R, int plane, double& c1, double& c2 ); 00081 00082 // given the position on plane (one out of 6), find out the position on sphere 00083 static ErrorCode reverse_gnomonic_projection( const double& c1, 00084 const double& c2, 00085 double R, 00086 int plane, 00087 CartVect& pos ); 00088 00089 // given a mesh on the sphere, project all centers in 6 gnomonic planes, or project mesh too 00090 static void gnomonic_unroll( double& c1, double& c2, double R, int plane ); 00091 00092 // given a mesh on the sphere, project all centers in 6 gnomonic planes, or project mesh too 00093 static ErrorCode global_gnomonic_projection( Interface* mb, 00094 EntityHandle inSet, 00095 double R, 00096 bool centers_only, 00097 EntityHandle& outSet ); 00098 00099 static void transform_coordinates( double* avg_position, int projection_type ); 00100 /* 00101 * other methods to convert from spherical coord to cartesian, and back 00102 * A spherical coordinate triple is (R, lon, lat) 00103 * should we store it as a CartVect? probably not ... 00104 * /cesm1_0_4/models/atm/cam/src/dynamics/homme/share/coordinate_systems_mod.F90 00105 * 00106 enforce three facts: 00107 ! ========================================================== 00108 ! enforce three facts: 00109 ! 00110 ! 1) lon at poles is defined to be zero 00111 ! 00112 ! 2) Grid points must be separated by about .01 Meter (on earth) 00113 ! from pole to be considered "not the pole". 00114 ! 00115 ! 3) range of lon is { 0<= lon < 2*pi } 00116 ! 00117 ! 4) range of lat is from -pi/2 to pi/2; -pi/2 or pi/2 are the poles, so there the lon is 0 00118 ! 00119 ! ========================================================== 00120 */ 00121 struct SphereCoords 00122 { 00123 double R, lon, lat; 00124 }; 00125 00126 static SphereCoords cart_to_spherical( CartVect& ); 00127 00128 static CartVect spherical_to_cart( SphereCoords& ); 00129 00130 /* 00131 * create a mesh used mainly for visualization for now, with nodes corresponding to 00132 * GL points, a so-called refined mesh, with NP nodes in each direction. 00133 * input: a range of quads (coarse), and a desired order (NP is the number of points), so it 00134 * is order + 1 00135 * 00136 * output: a set with refined elements; with proper input, it should be pretty 00137 * similar to a Homme mesh read with ReadNC 00138 */ 00139 // ErrorCode SpectralVisuMesh(Interface * mb, Range & input, int NP, EntityHandle & outputSet, 00140 // double tolerance); 00141 00142 /* 00143 * given an entity set, get all nodes and project them on a sphere with given radius 00144 */ 00145 static ErrorCode ScaleToRadius( Interface* mb, EntityHandle set, double R ); 00146 00147 static double distance_on_great_circle( CartVect& p1, CartVect& p2 ); 00148 00149 // break the nonconvex quads into triangles; remove the quad from the set? yes. 00150 // maybe radius is not needed; 00151 // 00152 static ErrorCode enforce_convexity( Interface* mb, EntityHandle set, int rank = 0 ); 00153 00154 // this could be larger than PI, because of orientation; useful for non-convex polygons 00155 static double oriented_spherical_angle( double* A, double* B, double* C ); 00156 00157 // looking at quad connectivity, collapse to triangle if 2 nodes equal 00158 // then delete the old quad 00159 static ErrorCode fix_degenerate_quads( Interface* mb, EntityHandle set ); 00160 00161 // distance along a great circle on a sphere of radius 1 00162 static double distance_on_sphere( double la1, double te1, double la2, double te2 ); 00163 00164 /* End Analytical functions */ 00165 00166 /* 00167 * given 2 arcs AB and CD, compute the unique intersection point, if it exists 00168 * in between 00169 */ 00170 static ErrorCode intersect_great_circle_arcs( double* A, double* B, double* C, double* D, double R, double* E ); 00171 /* 00172 * given 2 arcs AB and CD, compute the intersection points, if it exists 00173 * AB is a great circle arc 00174 * CD is a constant latitude arc 00175 */ 00176 static ErrorCode intersect_great_circle_arc_with_clat_arc( double* A, 00177 double* B, 00178 double* C, 00179 double* D, 00180 double R, 00181 double* E, 00182 int& np ); 00183 00184 // ErrorCode set_edge_type_flag(Interface * mb, EntityHandle sf1); 00185 00186 static int borderPointsOfCSinRLL( CartVect* redc, 00187 double* red2dc, 00188 int nsRed, 00189 CartVect* bluec, 00190 int nsBlue, 00191 int* blueEdgeType, 00192 double* P, 00193 int* side, 00194 double epsil ); 00195 00196 // used only by homme 00197 static ErrorCode deep_copy_set_with_quads( Interface* mb, EntityHandle source_set, EntityHandle dest_set ); 00198 00199 // used to 'repair' scrip-like meshes 00200 static ErrorCode remove_duplicate_vertices( Interface* mb, 00201 EntityHandle file_set, 00202 double merge_tol, 00203 std::vector< Tag >& tagList ); 00204 00205 static ErrorCode remove_padded_vertices( Interface* mb, EntityHandle file_set, std::vector< Tag >& tagList ); 00206 }; 00207 00208 class IntxAreaUtils 00209 { 00210 public: 00211 enum AreaMethod 00212 { 00213 lHuiller = 0, 00214 Girard = 1, 00215 GaussQuadrature = 2 00216 }; 00217 00218 IntxAreaUtils( AreaMethod p_eAreaMethod = lHuiller ) : m_eAreaMethod( p_eAreaMethod ) {} 00219 00220 ~IntxAreaUtils() {} 00221 00222 /* 00223 * utilities to compute area of a polygon on which all edges are arcs of great circles on a 00224 * sphere 00225 */ 00226 /* 00227 * this will compute the spherical angle ABC, when A, B, C are on a sphere of radius R 00228 * the radius will not be needed, usually, just for verification the points are indeed on that 00229 * sphere the center of the sphere is at origin (0,0,0) this angle can be used in Girard's 00230 * theorem to compute the area of a spherical polygon 00231 */ 00232 double spherical_angle( double* A, double* B, double* C, double Radius ); 00233 00234 double area_spherical_triangle( double* A, double* B, double* C, double Radius ); 00235 00236 double area_spherical_polygon( double* A, int N, double Radius, int* sign = NULL ); 00237 00238 double area_spherical_element( Interface* mb, EntityHandle elem, double R ); 00239 00240 double area_on_sphere( Interface* mb, EntityHandle set, double R ); 00241 00242 ErrorCode positive_orientation( Interface* mb, EntityHandle set, double R ); 00243 00244 private: 00245 /* lHuiller method for computing area on a spherical triangle */ 00246 double area_spherical_triangle_lHuiller( double* ptA, double* ptB, double* ptC, double Radius ); 00247 00248 /* lHuiller method for computing area on a spherical polygon */ 00249 double area_spherical_polygon_lHuiller( double* A, int N, double Radius, int* sign = NULL ); 00250 00251 /* Girard method for computing area on a spherical triangle with spherical excess */ 00252 double area_spherical_triangle_girard( double* A, double* B, double* C, double Radius ); 00253 00254 /* Girard method for computing area on a spherical polygon with spherical excess */ 00255 double area_spherical_polygon_girard( double* A, int N, double Radius ); 00256 00257 #ifdef MOAB_HAVE_TEMPESTREMAP 00258 /* Gauss-quadrature based integration method for computing area on a spherical triangle */ 00259 double area_spherical_triangle_GQ( double* ptA, double* ptB, double* ptC, double Radius ); 00260 00261 /* Gauss-quadrature based integration method for computing area on a spherical polygon element 00262 */ 00263 double area_spherical_polygon_GQ( double* A, int N, double Radius ); 00264 #endif 00265 00266 private: 00267 /* data */ 00268 AreaMethod m_eAreaMethod; 00269 }; 00270 00271 } // namespace moab 00272 #endif /* INTXUTILS_HPP_ */
