MOAB: Mesh Oriented datABase
(version 5.4.1)
Include dependency graph for addPCdata.cpp:Go to the source code of this file.
Functions | |
| int | main (int argc, char *argv[]) |
| int main | ( | int | argc, |
| char * | argv[] | ||
Definition at line 28 of file addPCdata.cpp.
References ProgOptions::addOpt(), moab::Range::begin(), moab::Range::end(), ErrorCode, moab::Core::get_entities_by_dimension(), moab::Core::load_file(), mb, MB_CHK_SET_ERR, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_DOUBLE, MB_TYPE_INTEGER, outfile, ProgOptions::parseCommandLine(), ProgOptions::printHelp(), moab::Range::size(), moab::Core::tag_get_bytes(), moab::Core::tag_get_data(), moab::Core::tag_get_data_type(), moab::Core::tag_get_handle(), moab::Core::tag_get_length(), moab::Core::tag_set_data(), and moab::Core::write_file().
ProgOptions opts;
std::string inputfile, outfile( "out.h5m" ), sourcefile, variable_name;
int dual_mesh = 0;
opts.addOpt< std::string >( "input,i", "input mesh filename", &inputfile );
opts.addOpt< std::string >( "source,s", "h5m file aligned with the mesh input file", &sourcefile );
opts.addOpt< std::string >( "output,o", "output mesh filename", &outfile );
opts.addOpt< std::string >( "var,v", "variable to extract and add to output file", &variable_name );
opts.addOpt< int >( "pentagon,p", "switch for dual mesh ", &dual_mesh );
opts.parseCommandLine( argc, argv );
std::cout << "input file: " << inputfile << "\n";
std::cout << "source file: " << sourcefile << "\n";
std::cout << "variable to copy: " << variable_name << "\n";
std::cout << "output file: " << outfile << "\n";
if( inputfile.empty() )
opts.printHelp();
return 0;
ErrorCode rval;
Core* mb = new Core();
rval = mb->load_file( inputfile.c_str() );MB_CHK_SET_ERR( rval, "can't load input file" );
Core* mb2 = new Core();
rval = mb2->load_file( sourcefile.c_str() );MB_CHK_SET_ERR( rval, "can't load source file" );
Tag sourceTag;
rval = mb2->tag_get_handle( variable_name.c_str(), sourceTag );MB_CHK_SET_ERR( rval, "can't get tag from file" );
int sizeTag = 0;
rval = mb2->tag_get_length( sourceTag, sizeTag );MB_CHK_SET_ERR( rval, "can't get size of tag " );
DataType type;
rval = mb2->tag_get_data_type( sourceTag, type );MB_CHK_SET_ERR( rval, "can't get type of tag " );
int sizeInBytes = 0;
rval = mb2->tag_get_bytes( sourceTag, sizeInBytes );MB_CHK_SET_ERR( rval, "can't get size in bytes of tag " );
Tag newTag;
* ErrorCode tag_get_handle( const char* name,
int size,
DataType type,
Tag& tag_handle,
unsigned flags = 0,
const void* default_value = 0 )
void* defVal;
int defInt = -100000;
double defDouble = -1.e10;
if( type == MB_TYPE_INTEGER )
defVal = (void*)( &defInt );
else if( type == MB_TYPE_DOUBLE )
defVal = (void*)( &defDouble );
rval = mb->tag_get_handle( variable_name.c_str(), sizeTag, type, newTag, MB_TAG_DENSE | MB_TAG_CREAT, defVal );MB_CHK_SET_ERR( rval, "can't create new tag " );
// get vertices on ini mesh; get global id on ini mesh
// get global id on source mesh
Tag gid;
Tag gid2;
rval = mb->tag_get_handle( "GLOBAL_ID", gid );MB_CHK_SET_ERR( rval, "can't get GLOBAL_ID tag on ini mesh " );
rval = mb2->tag_get_handle( "GLOBAL_ID", gid2 );MB_CHK_SET_ERR( rval, "can't get GLOBAL_ID tag on source mesh " );
// get vertices on ini mesh; build
Range iniVerts;
rval = mb->get_entities_by_dimension( 0, 0, iniVerts );MB_CHK_SET_ERR( rval, "can't get verts on initial mesh " );
if( 0 != dual_mesh )
// verts will be polygons
rval = mb->get_entities_by_dimension( 0, 2, iniVerts );MB_CHK_SET_ERR( rval, "can't get polygons on initial mesh " );
std::vector< int > gids;
gids.resize( iniVerts.size() );
rval = mb->tag_get_data( gid, iniVerts, &( gids[0] ) );MB_CHK_SET_ERR( rval, "can't get gid on initial verts " );
// build now the map
std::map< int, EntityHandle > fromGidToEh;
int i = 0;
for( Range::iterator vit = iniVerts.begin(); vit != iniVerts.end(); vit++, i++ )
fromGidToEh[gids[i]] = *vit;
// now get the source verts, and tags, and set it on new mesh
char* valTag = new char[sizeInBytes];
std::cout << " size of tag in bytes:" << sizeInBytes << "\n";
Range sourceVerts;
rval = mb2->get_entities_by_dimension( 0, 0, sourceVerts );MB_CHK_SET_ERR( rval, "can't get verts on source mesh " );
for( Range::iterator sit = sourceVerts.begin(); sit != sourceVerts.end(); sit++ )
int globalId = 0;
EntityHandle sourceHandle = *sit;
rval = mb2->tag_get_data( gid2, &sourceHandle, 1, &globalId );MB_CHK_SET_ERR( rval, "can't get id on source mesh " );
// iniVert could be a polygon, actually
EntityHandle iniVert = fromGidToEh[globalId];
// find the value of source tag
rval = mb2->tag_get_data( sourceTag, &sourceHandle, 1, (void*)valTag );MB_CHK_SET_ERR( rval, "can't get value on source tag " );
rval = mb->tag_set_data( newTag, &iniVert, 1, (void*)valTag );MB_CHK_SET_ERR( rval, "can't set value on initial mesh, new tag " );
// save file
rval = mb->write_file( outfile.c_str() );MB_CHK_SET_ERR( rval, "can't write file" );
delete[] valTag;
delete mb;
delete mb2;
return 0;
