MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "TestUtil.hpp"#include "moab/Core.hpp"#include "moab/Range.hpp"#include "moab/FileOptions.hpp"
Include dependency graph for ccmio_test.cpp:Go to the source code of this file.
Defines | |
| #define | IS_BUILDING_MB |
Functions | |
| void | test_read () |
| void | test_write () |
| int | main () |
Variables | |
| std::string | cubfile = "unittest/io/singlecyl.cub" |
| std::string | ccmgfiler = "unittest/io/singlecyl.ccmg" |
| std::string | ccmgfilew = "singlecyl_tmp.ccmg" |
| #define IS_BUILDING_MB |
Definition at line 3 of file ccmio_test.cpp.
| int main | ( | ) |
Definition at line 16 of file ccmio_test.cpp.
References RUN_TEST, test_read(), and test_write().
int result = 0;
result += RUN_TEST( test_write );
result += RUN_TEST( test_read );
return result;
| void test_read | ( | ) |
| void test_write | ( | ) |
Definition at line 26 of file ccmio_test.cpp.
References ccmgfilew, CHECK_ERR, cubfile, ErrorCode, moab::Interface::load_file(), mb, MB_SUCCESS, and moab::Interface::write_file().
Referenced by main().
ErrorCode rval;
Core moab;
Interface& mb = moab;
rval = mb.load_file( cubfile.c_str() );
if( MB_SUCCESS != rval ) std::cerr << "Trouble reading file " << cubfile << std::endl;CHECK_ERR( rval );
rval = mb.write_file( ccmgfilew.c_str() );
if( MB_SUCCESS != rval ) std::cerr << "Trouble writing file " << ccmgfilew << std::endl;CHECK_ERR( rval );
| std::string ccmgfiler = "unittest/io/singlecyl.ccmg" |
Definition at line 10 of file ccmio_test.cpp.
Referenced by test_read().
| std::string ccmgfilew = "singlecyl_tmp.ccmg" |
Definition at line 11 of file ccmio_test.cpp.
Referenced by test_write().
| std::string cubfile = "unittest/io/singlecyl.cub" |
Definition at line 9 of file ccmio_test.cpp.
