MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "moab/Defines.h"#include "moab/Core.hpp"#include "ReadWriteExoII.hpp"#include "moab/_MBSet.hpp"#include <iostream>
Include dependency graph for test_exo.cpp:Go to the source code of this file.
Functions | |
| std::ostream & | operator<< (std::ostream &out, const std::vector< int > &v) |
| int | main (int argc, char *argv[]) |
| int main | ( | int | argc, |
| char * | argv[] | ||
Definition at line 31 of file test_exo.cpp.
References ErrorCode.
// check for file name on command line
if( 2 != argc )
std::cout << "Usage: " << argv[0] << " <exoII_file_name>" << std::endl;
return 1;
Core mdb;
ReadWriteExoII reader( &mdb );
ErrorCode result = reader.load_file( argv[1], NULL );
std::cout << "Result of reading file = " << ( MB_FAILURE == result ? "FAILURE." : "SUCCESS." ) << std::endl;
// print some data about the mesh
int num_nodes = mdb.total_num_nodes();
int num_elements = mdb.total_num_elements();
std::cout << "Total number of nodes, elements read = " << num_nodes << ", " << num_elements << std::endl;
// get the nodeset meshsets and blocks
std::vector< MB_MBSet* > blocks, nodesets, sidesets;
std::vector< int > block_ids, nodeset_ids, sideset_ids;
const std::set< MB_MBSet* >& gms = MB_MBSet::GlobalMBSets();
std::set< MB_MBSet* >::const_iterator this_it = gms.begin(), end_it = MB_MBSet::GlobalMBSets().end();
MB_MBSet* this_meshset;
int bc_tag;
for( ; this_it != end_it; ++this_it )
// get the next set
this_meshset = *this_it;
bc_tag = reader.get_block_id( this_meshset );
if( -1 != bc_tag )
blocks.push_back( this_meshset );
block_ids.push_back( bc_tag );
// same for nodeset tag
bc_tag = reader.get_nodeset_id( this_meshset );
if( -1 != bc_tag )
nodesets.push_back( this_meshset );
nodeset_ids.push_back( bc_tag );
// same for sideset tag
bc_tag = reader.get_sideset_id( this_meshset );
if( -1 != bc_tag )
sidesets.push_back( this_meshset );
sideset_ids.push_back( bc_tag );
// std::vector<int>::iterator set_it;
std::cout << "Block numbers read: " << std::endl;
if( !blocks.empty() )
std::cout << block_ids << std::endl;
else
std::cout << "(no blocks)" << std::endl;
std::cout << "Nodeset numbers read: " << std::endl;
if( !nodesets.empty() )
std::cout << nodeset_ids << std::endl;
else
std::cout << "(no nodesets)" << std::endl;
std::cout << "Sideset numbers read: " << std::endl;
if( !sidesets.empty() )
std::cout << sideset_ids << std::endl;
else
std::cout << "(no sidesets)" << std::endl;
| std::ostream& operator<< | ( | std::ostream & | out, |
| const std::vector< int > & | v | ||
Definition at line 25 of file test_exo.cpp.
std::copy( v.begin(), v.end(), std::ostream_iterator< int >( std::cout, " " ) );
return out;
