MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "moab/Core.hpp"#include "moab/Range.hpp"#include "TestUtil.hpp"#include <iostream>#include <cassert>#include <ctime>
Include dependency graph for adj_time.cpp:Go to the source code of this file.
Functions | |
| int | main () |
Variables | |
| static const std::string | default_input_file = "unittest/64bricks_512hex.h5m" |
| int main | ( | ) |
Definition at line 12 of file adj_time.cpp.
References moab::Range::begin(), default_input_file, moab::Range::empty(), moab::Range::end(), ErrorCode, moab::Interface::get_adjacencies(), moab::Interface::get_entities_by_dimension(), moab::Interface::load_file(), mb, MB_SUCCESS, moab::Range::size(), and moab::Interface::UNION.
ErrorCode rval;
Core moab;
Interface& mb = moab;
// load test file
rval = mb.load_file( default_input_file.c_str() );
if( MB_SUCCESS != rval )
std::cerr << default_input_file << ": failed to load file." << std::endl;
return 1;
// get all region elements
Range vols;
rval = mb.get_entities_by_dimension( 0, 3, vols );
if( MB_SUCCESS != rval ) return 2;
if( vols.empty() ) return 1;
// create internal face elements
Range faces;
rval = mb.get_adjacencies( vols, 2, true, faces, Interface::UNION );
assert( faces.size() > vols.size() );
// time query of all adjacent volumes
std::vector< EntityHandle > adj;
clock_t t_0 = clock();
for( Range::iterator i = faces.begin(); i != faces.end(); ++i )
adj.clear();
rval = mb.get_adjacencies( &*i, 1, 3, false, adj );
assert( adj.size() == 1 || adj.size() == 2 );
clock_t t_up = clock() - t_0;
std::cout << "Querying of volumes for " << faces.size() << " faces: " << t_up / (double)CLOCKS_PER_SEC << " seconds"
<< std::endl;
// time downward adjacency query from volumes to faces
t_0 = clock();
for( Range::iterator i = vols.begin(); i != vols.end(); ++i )
adj.clear();
rval = mb.get_adjacencies( &*i, 1, 1, false, adj );
assert( adj.size() > 3 );
clock_t t_down = clock() - t_0;
std::cout << "Querying of faces for " << vols.size() << " volumes: " << t_down / (double)CLOCKS_PER_SEC
<< " seconds" << std::endl;
return 0;
const std::string default_input_file = "unittest/64bricks_512hex.h5m" [static] |
Definition at line 10 of file adj_time.cpp.
Referenced by main().
