MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "moab/Core.hpp"#include "moab/CartVect.hpp"#include "moab/Range.hpp"#include "moab/verdict/VerdictWrapper.hpp"#include <iostream>#include <iomanip>#include <cstdio>#include "TestUtil.hpp"
Include dependency graph for verdict_test.cpp:Go to the source code of this file.
Classes | |
| struct | test_case |
Defines | |
| #define | MAX_NODES_PER_ELEMENT 27 |
| #define | MAX_TESTS_PER_ELEMENT 20 |
| #define | VERDICT_SIGNIFICANT_FIG 15 |
| #define | MAX_STR_LEN 30 |
Functions | |
| void | verdict_test1 () |
| void | verdict_unit_tests () |
| int | main (int argc, char *argv[]) |
Variables | |
| std::string | filename = "unittest/mbtest1.vtk" |
| #define MAX_NODES_PER_ELEMENT 27 |
Definition at line 83 of file verdict_test.cpp.
Referenced by moab::ReadIDEAS::create_elements(), moab::ParallelComm::print_buffer(), moab::ParallelComm::unpack_entities(), and moab::WriteCCMIO::write_cells_and_faces().
| #define MAX_STR_LEN 30 |
Referenced by verdict_unit_tests().
| #define MAX_TESTS_PER_ELEMENT 20 |
Definition at line 84 of file verdict_test.cpp.
| #define VERDICT_SIGNIFICANT_FIG 15 |
Definition at line 89 of file verdict_test.cpp.
| int main | ( | int | argc, |
| char * | argv[] | ||
Definition at line 17 of file verdict_test.cpp.
References filename, RUN_TEST, verdict_test1(), and verdict_unit_tests().
if( argc > 1 )
if( argc > 1 ) filename = std::string( argv[1] );
int result = 0;
result += RUN_TEST( verdict_test1 );
result += RUN_TEST( verdict_unit_tests );
return result;
| void verdict_test1 | ( | ) |
Definition at line 29 of file verdict_test.cpp.
References moab::VerdictWrapper::all_quality_measures(), moab::Range::begin(), CHECK_ERR, moab::Range::end(), entities, ErrorCode, filename, moab::Interface::get_entities_by_handle(), moab::Interface::id_from_handle(), moab::Interface::list_entity(), moab::Interface::load_mesh(), mb, MB_NOT_IMPLEMENTED, moab::MB_QUALITY_COUNT, MB_SUCCESS, MBHEX, MBVERTEX, moab::VerdictWrapper::quality_measure(), moab::VerdictWrapper::quality_name(), moab::VerdictWrapper::set_size(), moab::TYPE_FROM_HANDLE(), and moab::Interface::type_from_handle().
Referenced by main().
ErrorCode rval;
Core moab_core;
Interface* mb = &moab_core;
rval = mb->load_mesh( filename.c_str() );CHECK_ERR( rval );
Range entities;
rval = mb->get_entities_by_handle( 0, entities ); // all entities from the model
CHECK_ERR( rval );
VerdictWrapper vw( mb );
// for size methods/quality, we need a size, to compute relative sizes and stuff
rval = vw.set_size( 1.0 );CHECK_ERR( rval );
for( Range::iterator eit = entities.begin(); eit != entities.end(); ++eit )
EntityHandle eh = *eit;
EntityType etype = TYPE_FROM_HANDLE( eh );
if( etype == MBVERTEX || etype > MBHEX ) continue;
for( int quality = 0; quality < MB_QUALITY_COUNT; quality++ )
QualityType q = (QualityType)quality;
double qm;
rval = vw.quality_measure( eh, q, qm );
if( MB_NOT_IMPLEMENTED == rval ) continue;
if( MB_FAILURE == rval )
std::cerr << " failure for entity " << mb->list_entity( eh ) << " quality " << vw.quality_name( q )
<< "\n";
if( MB_SUCCESS == rval )
std::cout << "Entity type " << (EntityType)mb->type_from_handle( eh )
<< " id:" << mb->id_from_handle( eh ) << " quality:" << vw.quality_name( q ) << " : " << qm
<< "\n";
// now compute all qualities for each entity handle
std::map< QualityType, double > qualities;
rval = vw.all_quality_measures( eh, qualities );
mb->list_entity( eh );
for( std::map< QualityType, double >::iterator mit = qualities.begin(); mit != qualities.end(); ++mit )
std::cout << " " << vw.quality_name( mit->first ) << " " << mit->second << " \n";
return;
| void verdict_unit_tests | ( | ) |
Definition at line 107 of file verdict_test.cpp.
References test_case::answer, ErrorCode, test_case::function, iface, MAX_STR_LEN, moab::MB_AREA, moab::MB_ASPECT_RATIO, moab::MB_CONDITION, moab::MB_DIAGONAL, moab::MB_DIMENSION, moab::MB_DISTORTION, moab::MB_JACOBIAN, moab::MB_LENGTH, moab::MB_MAXIMUM_ANGLE, moab::MB_MINIMUM_ANGLE, moab::MB_RELATIVE_SIZE_SQUARED, moab::MB_SCALED_JACOBIAN, MB_SET_ERR_RET, moab::MB_SHAPE, moab::MB_SHAPE_AND_SIZE, moab::MB_SHEAR, moab::MB_SHEAR_AND_SIZE, moab::MB_SKEW, moab::MB_STRETCH, MB_SUCCESS, moab::MB_TAPER, moab::MB_UNDEFINED_QUALITY, moab::MB_VOLUME, moab::MB_WARPAGE, MBEDGE, MBHEX, MBMAXTYPE, MBPRISM, MBQUAD, MBTET, MBTRI, moab::VerdictWrapper::quality_measure(), moab::QualityType_ToString(), test_case::testname, moab::tolerance, and VERDICT_SIGNIFICANT_FIG.
// all test cases go here
test_case testcases[] = {
{ "edge calc 1",
MBEDGE,
{ MB_LENGTH, MB_UNDEFINED_QUALITY },
2,
{ 0.0, 0.0, 0.0, 1.0, 1.0, 1.0 },
{ 1.732050807568877, 0.0 } },
{ "edge calc 2",
MBEDGE,
2,
{ 0.0, 0.0, 0.0, 1.0, 0.0, 0.0 },
{ 1.0, 0.0 } },
{ "edge calc 3",
MBEDGE,
2,
{ 0.0, 0.0, 0.0, 0.0, 0.0, 0.0 },
{ 0.0, 0.0 } },
{ "simple wedge",
MBPRISM,
{ MB_VOLUME, MB_UNDEFINED_QUALITY },
6,
{ 0.0, 0.0, 0.0, -1.0, 1.0, 0.0, -1.0, 0.0, 0.0, 0.0, 0.0, 1.0, -1.0, 1.0, 1.0, -1.0, 0.0, 1.0 },
{ 0.5, 0.0 } },
{ "singularity wedge",
MBPRISM,
6,
{ 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0 },
{ 0.0, 0.0 } },
{ "simple tri",
MBTRI,
{ MB_AREA, MB_MINIMUM_ANGLE, MB_MAXIMUM_ANGLE, MB_CONDITION, MB_SCALED_JACOBIAN, MB_SHAPE,
MB_RELATIVE_SIZE_SQUARED, MB_SHAPE_AND_SIZE, MB_DISTORTION, MB_UNDEFINED_QUALITY },
3,
0.0,
0.0,
0.0,
5,
0.0,
0.0,
2.5,
4.330127,
0.0,
{ 10.825317499999997, 5.999999989158383329e+01, 6.000000021683238316e+01, 1.000000000000000000e+00,
9.999999989075266660e-01, 1.000000000000000000e+00, 8.533333407912848181e-03, 8.533333407912848181e-03,
1.000000000000000000e+00, 0.0 } },
"singular tri",
MBTRI,
{ v_tri_area, v_tri_aspect_ratio, v_tri_condition,
v_tri_distortion, v_tri_minimum_angle, v_tri_maximum_angle,
v_tri_relative_size_squared, v_tri_shape, v_tri_shape_and_size,
3,
{0,0,0},
{0.5,0.8660254037,0},
{1,0,0}
{ 123, 1234, 1234, 1234, 1234, 1234, 1234, 1234, 1234,0}
"simple quad",
MBQUAD,
{ v_quad_skew, MB_UNDEFINED_QUALITY},
4,
{0,0,0},
{1,0,0},
{1,7,0},
{0,7,0 }
{ 1.3333333333333333333, 0 }
{ "simple quad",
MBQUAD,
{ MB_ASPECT_RATIO, MB_SKEW, MB_TAPER, MB_WARPAGE, MB_AREA, MB_STRETCH, MB_MAXIMUM_ANGLE, MB_MINIMUM_ANGLE,
MB_CONDITION, MB_JACOBIAN, MB_SCALED_JACOBIAN, MB_SHEAR, MB_SHAPE, MB_RELATIVE_SIZE_SQUARED,
MB_SHAPE_AND_SIZE, MB_SHEAR_AND_SIZE, MB_DISTORTION, MB_UNDEFINED_QUALITY },
4,
2.0, 0.0, 0.0, // 1
1.0, 1.0, 2.0, // 2
0.0, 1.0, 0.0, // 3
0.0, 0.0, 0.0, // 0
{ 1.429964171762364344e+00, 9.245003270420482089e-02, 7.453559924999298980e-01, 7.999999999999998432e-03,
2.692582403567252314e+00, 5.773502691896258421e-01, 9.000000000000000000e+01, 5.678908923910092454e+01,
2.307927774486215888e+00, 1.114172029062311164e+00, 5.570860145311555822e-01, 5.570860145311555822e-01,
4.332891224131210084e-01, 9.999999999999995559e-01, 4.332891224131208419e-01, 5.570860145311553602e-01,
5.626795729450876360e-01, 0.0 } },
{ "tet test",
MBTET,
{ /*MB_SHEAR,*/ MB_VOLUME, MB_CONDITION, MB_JACOBIAN, MB_SHAPE, MB_RELATIVE_SIZE_SQUARED, MB_SHAPE_AND_SIZE,
4,
-5.0,
-5.0,
-5.0,
-5.0,
5.0,
-5.0,
-5.0,
-5.0,
5.0,
5.0,
-5.0,
-5.0,
{ 1.666666666666666572e+02, 1.224744871391589385e+00, 1.000000000000000000e+03, 8.399473665965818681e-01,
3.599999999998462557e-05, 3.023810519746403209e-05, 1.000000000000000000e+00, 0.0 } },
{ "hex test",
MBHEX,
{ /*MB_ASPECT_RATIO,*/ MB_SKEW, MB_TAPER, MB_VOLUME, MB_STRETCH, MB_DIAGONAL, MB_DIMENSION, MB_CONDITION,
MB_JACOBIAN, MB_SCALED_JACOBIAN, MB_SHEAR, MB_SHAPE, MB_RELATIVE_SIZE_SQUARED, MB_SHEAR_AND_SIZE,
8,
-0.2, -0.7, -0.3, // 1
-0.7, 0.4, -0.6, // 2
-0.5, 0.5, 0.3, // 3
-0.3, -0.5, 0.5, // 0
0.5, -0.8, -0.2, // 5
0.4, 0.4, -0.6, // 6
0.2, 0.5, 0.2, // 7
0.5, -0.3, 0.8 // 4
{ 2.458897037399689067e-01, 1.784576525620624188e-01, 8.130624999999999103e-01, 6.209702997008308412e-01,
6.896219298787312768e-01, 5.245942005845132261e-01, 1.273059825673506174e+00, 4.769999999999999241e-01,
7.778495101180593618e-01, 7.778495101180593618e-01, 7.897852810190353345e-01, 6.738357656250002492e-01,
5.241428201914338780e-01, 5.321855695148176579e-01, 5.847977114834492784e-01, 0.0 } },
// keep this one last
// { 0, {MB_UNDEFINED_QUALITY} , 0, {{0}} , {0} } };
{ 0, MBMAXTYPE, { MB_UNDEFINED_QUALITY }, 0, { 0.0, 0.0 }, { 0.0, 0.0 } }
int i;
int j = 0;
double answer_from_lib;
double tolerance;
// double norm_answer_from_lib;
char exponent[MAX_STR_LEN];
char* base_ptr;
int base;
bool passed = true; // have all the tests performed so far passed?
cout.setf( ios::scientific, ios::floatfield );
cout.precision( VERDICT_SIGNIFICANT_FIG + 3 );
ErrorCode merr;
Interface* iface = new Core();
VerdictWrapper* vw = new VerdictWrapper( iface );
EntityHandle dummy = 0;
// loop through each test
for( i = 0; testcases[i].testname != 0; i++ )
cout << endl
<< "[" << i << "]: "
<< "Test case: " << testcases[i].testname << endl;
for( j = 0; testcases[i].function[j] != MB_UNDEFINED_QUALITY; j++ )
answer_from_lib =
(testcases[i].function[j])
(testcases[i].num_nodes, testcases[i].coords);
cout << "\t #" << j + 1 << " TESTING :: " << QualityType_ToString( testcases[i].function[j] ) << endl;
merr = vw->quality_measure( dummy, testcases[i].function[j], answer_from_lib, testcases[i].num_nodes,
testcases[i].etype, testcases[i].coords );
if( MB_SUCCESS != merr )
delete vw;
delete iface;
MB_SET_ERR_RET( "Failed to compute the quality for an element" );
sprintf( exponent, "%e", testcases[i].answer[j] );
base_ptr = strstr( exponent, "e" );
base_ptr = &base_ptr[1];
base = atoi( base_ptr );
tolerance = pow( 10.0, -VERDICT_SIGNIFICANT_FIG ) * pow( 10.0, base );
if( fabs( answer_from_lib - testcases[i].answer[j] ) > tolerance )
cout << "\t #" << j + 1 << " FAILED :: " << QualityType_ToString( testcases[i].function[j] ) << endl;
cout << "\t\t calculated ( " << answer_from_lib << " ) and "
<< "expected ( " << testcases[i].answer[j] << ") " << endl;
passed = false;
else
cout << "\t #" << j + 1 << " PASSED :: " << QualityType_ToString( testcases[i].function[j] ) << endl;
delete vw;
delete iface;
std::cout << endl << "All tests passed ? " << ( passed ? 1 : 0 ) << endl;
return;
| std::string filename = "unittest/mbtest1.vtk" |
Definition at line 10 of file verdict_test.cpp.
