MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "moab/Core.hpp"#include "moab/AdaptiveKDTree.hpp"#include "moab/CartVect.hpp"#include "moab/GeomUtil.hpp"#include "moab/Range.hpp"#include "TestUtil.hpp"#include <iostream>#include <algorithm>#include <sstream>
Include dependency graph for adaptive_kd_tree_tests.cpp:Go to the source code of this file.
| #define CHECK_RAY_XSECTS | ( | PT, | |
| DIR, | |||
| T_IN, | |||
| T_OUT | |||
do \ { \ CHECK( iter.intersect_ray( ( PT ), ( DIR ), t_in, t_out ) ); \ CHECK_REAL_EQUAL( ( T_IN ), t_in, 1e-6 ); \ CHECK_REAL_EQUAL( ( T_OUT ), t_out, 1e-6 ); \ } while( false )
Definition at line 1060 of file adaptive_kd_tree_tests.cpp.
Referenced by test_leaf_intersects_ray().
| bool box_equal | ( | const AdaptiveKDTreeIter & | iter, |
| double | x_min, | ||
| double | y_min, | ||
| double | z_min, | ||
| double | x_max, | ||
| double | y_max, | ||
| double | z_max | ||
Definition at line 19 of file adaptive_kd_tree_tests.cpp.
References moab::AdaptiveKDTreeIter::box_max(), and moab::AdaptiveKDTreeIter::box_min().
Referenced by create_simple_2d_tree(), leaf_iterator_test(), and test_tree_merge_nodes().
| void build_triangle_box_large | ( | Interface * | moab, |
| Range & | tris | ||
Definition at line 67 of file adaptive_kd_tree_tests.cpp.
References build_triangles().
Referenced by test_build_tree_bisect_triangles(), test_closest_triangle(), and test_sphere_intersect_triangles().
const double coords[] = { // corners
-3, -3, -3, 3, -3, -3, 3, 3, -3, -3, 3, -3, -3, -3, 3, 3, -3, 3, 3, 3, 3, -3, 3, 3,
// edges
-1, -3, -3, 1, -3, -3, 3, -1, -3, 3, 1, -3, 1, 3, -3, -1, 3, -3, -3, 1, -3, -3, -1, -3,
-1, -3, 3, 1, -3, 3, 3, -1, 3, 3, 1, 3, 1, 3, 3, -1, 3, 3, -3, 1, 3, -3, -1, 3,
-3, -3, -1, -3, -3, 1, 3, -3, -1, 3, -3, 1, 3, 3, -1, 3, 3, 1, -3, 3, -1, -3, 3, 1,
// faces
-1, -3, -1, 1, -3, -1, 1, -3, 1, -1, -3, 1,
3, -1, -1, 3, 1, -1, 3, 1, 1, 3, -1, 1,
1, 3, -1, -1, 3, -1, -1, 3, 1, 1, 3, 1,
-3, 1, -1, -3, -1, -1, -3, -1, 1, -3, 1, 1,
-1, -1, -3, 1, -1, -3, 1, 1, -3, -1, 1, -3,
-1, -1, 3, 1, -1, 3, 1, 1, 3, -1, 1, 3 };
const unsigned conn[] = {
// face 0
0, 8, 24, 8, 32, 24, 8, 33, 32, 8, 9, 33, 9, 1, 33, 1, 26, 33, 24, 35, 25, 24, 32, 35, 32, 33, 35, 33, 34, 35,
33, 27, 34, 33, 26, 27, 35, 4, 25, 35, 16, 4, 35, 17, 16, 35, 34, 17, 27, 17, 34, 27, 5, 17,
// face 1
36, 26, 1, 36, 1, 10, 36, 10, 11, 36, 11, 37, 11, 28, 37, 11, 2, 28, 36, 27, 26, 36, 39, 27, 36, 38, 39, 36, 37,
38, 37, 28, 38, 28, 29, 38, 18, 5, 27, 18, 27, 39, 18, 39, 38, 18, 38, 19, 6, 19, 38, 6, 38, 29,
// face 2
12, 28, 2, 12, 40, 28, 12, 41, 40, 12, 13, 41, 3, 41, 13, 3, 30, 41, 43, 29, 28, 43, 28, 40, 43, 40, 41, 43, 41,
42, 41, 31, 42, 41, 30, 31, 43, 6, 29, 43, 20, 6, 43, 21, 20, 43, 42, 21, 21, 42, 31, 21, 31, 7,
// face 3
44, 30, 3, 44, 3, 14, 44, 14, 15, 44, 15, 45, 15, 24, 45, 15, 0, 24, 44, 31, 30, 44, 47, 31, 44, 46, 47, 44, 45,
46, 46, 45, 24, 46, 24, 25, 31, 22, 7, 31, 47, 22, 46, 22, 47, 46, 23, 22, 46, 4, 23, 46, 25, 4,
// face 4
8, 15, 0, 8, 48, 15, 8, 49, 48, 8, 9, 49, 1, 49, 9, 1, 10, 49, 51, 14, 15, 51, 15, 48, 51, 48, 49, 51, 49, 50,
11, 50, 49, 11, 49, 10, 51, 3, 14, 51, 13, 3, 51, 12, 13, 51, 50, 12, 11, 12, 50, 11, 2, 12,
// face 5
4, 52, 16, 4, 23, 52, 22, 52, 23, 22, 55, 52, 22, 21, 55, 22, 7, 21, 17, 16, 52, 17, 52, 53, 54, 53, 52, 54, 52,
55, 54, 55, 21, 54, 21, 20, 18, 5, 17, 18, 17, 53, 18, 53, 54, 18, 54, 19, 6, 19, 54, 6, 54, 20 };
build_triangles( moab, tris, 56, coords, 108, conn );
| void build_triangle_box_small | ( | Interface * | moab, |
| Range & | tris | ||
Definition at line 54 of file adaptive_kd_tree_tests.cpp.
Referenced by test_build_tree_bisect_triangles(), test_closest_triangle(), test_ray_intersect_triangles(), and test_sphere_intersect_triangles().
const double coords[] = { -1, -1, -1, 1, -1, -1, 1, 1, -1, -1, 1, -1, -1, -1, 1, 1, -1, 1, 1, 1, 1, -1, 1, 1 };
const unsigned conn[] = { 0, 1, 5, 0, 5, 4, 2, 6, 7, 2, 7, 3, 1, 2, 6, 1, 6, 5,
0, 3, 4, 3, 7, 4, 0, 1, 3, 1, 2, 3, 4, 5, 6, 4, 6, 7 };
build_triangles( moab, tris, 8, coords, 12, conn );
| void build_triangle_octahedron | ( | Interface * | moab, |
| Range & | tris | ||
Definition at line 115 of file adaptive_kd_tree_tests.cpp.
Referenced by test_build_tree_bisect_triangles().
const double coords[] = { 1, 0, 0, 0, 1, 0, -1, 0, 0, 0, -1, 0, 0, 0, 1, 0, 0, -1 };
const unsigned conn[] = { 0, 1, 4, 1, 2, 4, 2, 3, 4, 3, 0, 4, 1, 0, 5, 2, 1, 5, 3, 2, 5, 0, 3, 5 };
build_triangles( moab, tris, 6, coords, 8, conn );
| void build_triangles | ( | Interface * | moab, |
| Range & | tris, | ||
| int | num_vert, | ||
| const double * | coords, | ||
| int | num_tri, | ||
| const unsigned * | conn | ||
Definition at line 31 of file adaptive_kd_tree_tests.cpp.
References moab::Interface::create_element(), moab::Interface::create_vertex(), moab::Range::insert(), and MBTRI.
Referenced by build_triangle_box_large(), build_triangle_box_small(), and build_triangle_octahedron().
std::vector< EntityHandle > verts( num_vert );
for( int i = 0; i < num_vert; ++i )
moab->create_vertex( coords + 3 * i, verts[i] );
EntityHandle tri, tri_verts[3];
for( int i = 0; i < num_tri; ++i )
tri_verts[0] = verts[conn[3 * i]];
tri_verts[1] = verts[conn[3 * i + 1]];
tri_verts[2] = verts[conn[3 * i + 2]];
moab->create_element( MBTRI, tri_verts, 3, tri );
tris.insert( tri );
| void check_common_vertex | ( | Interface * | moab, |
| const EntityHandle * | tris, | ||
| unsigned | num_tri, | ||
| CartVect | point | ||
Definition at line 161 of file adaptive_kd_tree_tests.cpp.
References CHECK, ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), MB_SUCCESS, MBTRI, tri_coords(), and moab::Interface::type_from_handle().
Referenced by test_closest_triangle(), and test_sphere_intersect_triangles().
for( unsigned i = 0; i < num_tri; ++i )
CHECK( MBTRI == moab->type_from_handle( tris[i] ) );
ErrorCode rval;
CartVect tri_coords[3];
const EntityHandle* conn;
int conn_len;
rval = moab->get_connectivity( tris[0], conn, conn_len );
CHECK( MB_SUCCESS == rval );
rval = moab->get_coords( conn, 3, tri_coords[0].array() );
tri_coords[0] -= point;
tri_coords[1] -= point;
tri_coords[2] -= point;
EntityHandle vertex = 0;
if( tri_coords[0] % tri_coords[0] < 1e-6 )
vertex = conn[0];
else if( tri_coords[1] % tri_coords[1] < 1e-6 )
vertex = conn[1];
else if( tri_coords[2] % tri_coords[2] < 1e-6 )
vertex = conn[2];
else
CHECK( false );
for( unsigned j = 1; j < num_tri; ++j )
rval = moab->get_connectivity( tris[j], conn, conn_len );
CHECK( conn[0] == vertex || conn[1] == vertex || conn[2] == vertex );
| void check_point_in_triangles | ( | Interface * | moab, |
| unsigned | num_tris, | ||
Definition at line 194 of file adaptive_kd_tree_tests.cpp.
References CHECK, moab::GeomUtil::closest_location_on_tri(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), MB_SUCCESS, MBTRI, tri_coords(), and moab::Interface::type_from_handle().
Referenced by test_closest_triangle(), and test_ray_intersect_triangles().
ErrorCode rval;
CartVect tri_coords[3], tript;
int conn_len;
for( unsigned i = 0; i < num_tris; ++i )
rval = moab->get_connectivity( tris[i], conn, conn_len );
GeomUtil::closest_location_on_tri( point, tri_coords, tript );
tript -= point;
CHECK( fabs( tript[0] ) < 1e-6 );
CHECK( fabs( tript[1] ) < 1e-6 );
CHECK( fabs( tript[2] ) < 1e-6 );
| void create_simple_2d_tree | ( | AdaptiveKDTree & | tool, |
| EntityHandle & | root, | ||
| EntityHandle | leaves[9] = 0 |
Definition at line 238 of file adaptive_kd_tree_tests.cpp.
References box_equal(), CHECK, moab::AdaptiveKDTree::Plane::coord, moab::Tree::create_root(), ErrorCode, moab::AdaptiveKDTree::get_tree_iterator(), moab::AdaptiveKDTreeIter::handle(), MB_ENTITY_NOT_FOUND, MB_SUCCESS, moab::AdaptiveKDTree::Plane::norm, moab::AdaptiveKDTree::split_leaf(), moab::AdaptiveKDTreeIter::step(), moab::AdaptiveKDTree::X, and moab::AdaptiveKDTree::Y.
Referenced by leaf_iterator_test(), test_leaf_sibling(), test_leaf_volume(), and test_tree_merge_nodes().
ErrorCode rval;
AdaptiveKDTree::Plane plane;
// create a single-node tree
double min[3] = { -5, -4, -1 };
double max[3] = { 5, 4, 1 };
rval = tool.create_root( min, max, root );
// get iterator for tree
AdaptiveKDTreeIter iter;
rval = tool.get_tree_iterator( root, iter );
CHECK( box_equal( iter, -5, -4, -1, 5, 4, 1 ) );
// split plane (1)
plane.norm = AdaptiveKDTree::Y;
plane.coord = 0.0;
rval = tool.split_leaf( iter, plane );
CHECK( box_equal( iter, -5, -4, -1, 5, 0, 1 ) );
// split plane (2)
plane.norm = AdaptiveKDTree::X;
plane.coord = -1.0;
CHECK( box_equal( iter, -5, -4, -1, -1, 0, 1 ) );
// split plane (3), leaf [1]
plane.coord = -2.0;
CHECK( box_equal( iter, -5, -4, -1, -1, -2, 1 ) );
if( leaves ) leaves[1] = iter.handle();
// leaf [2]
rval = iter.step();
CHECK( box_equal( iter, -5, -2, -1, -1, 0, 1 ) );
if( leaves ) leaves[2] = iter.handle();
// non-leaf right of split plane (2)
rval = iter.step();
CHECK( box_equal( iter, -1, -4, -1, 5, 0, 1 ) );
// split plane (4) and leaf [3]
plane.coord = 4.0;
CHECK( box_equal( iter, -1, -4, -1, 4, 0, 1 ) );
if( leaves ) leaves[3] = iter.handle();
// leaf [4]
rval = iter.step();
CHECK( box_equal( iter, 4, -4, -1, 5, 0, 1 ) );
if( leaves ) leaves[4] = iter.handle();
// non-leaf above split plane (1)
rval = iter.step();
CHECK( box_equal( iter, -5, 0, -1, 5, 4, 1 ) );
// split plane (5)
plane.coord = 0.0;
CHECK( box_equal( iter, -5, 0, -1, 0, 4, 1 ) );
// split plane (6) and leaf [5]
plane.coord = -3.0;
CHECK( box_equal( iter, -5, 0, -1, -3, 4, 1 ) );
if( leaves ) leaves[5] = iter.handle();
// leaf [6];
rval = iter.step();
CHECK( box_equal( iter, -3, 0, -1, 0, 4, 1 ) );
if( leaves ) leaves[6] = iter.handle();
// non-leaf right of split plane (5)
rval = iter.step();
CHECK( box_equal( iter, 0, 0, -1, 5, 4, 1 ) );
// split plane (7) and leaf [7]
plane.coord = 3.0;
CHECK( box_equal( iter, 0, 0, -1, 5, 3, 1 ) );
if( leaves ) leaves[7] = iter.handle();
// leaf [8];
rval = iter.step();
CHECK( box_equal( iter, 0, 3, -1, 5, 4, 1 ) );
if( leaves ) leaves[8] = iter.handle();
// the end
rval = iter.step();
CHECK( MB_ENTITY_NOT_FOUND == rval );
| void leaf_iterator_test | ( | ) |
Definition at line 352 of file adaptive_kd_tree_tests.cpp.
References box_equal(), CHECK, moab::Tree::create_root(), create_simple_2d_tree(), ErrorCode, moab::AdaptiveKDTreeIter::get_neighbors(), moab::AdaptiveKDTree::get_tree_iterator(), moab::AdaptiveKDTreeIter::handle(), mb, MB_ENTITY_NOT_FOUND, MB_SUCCESS, moab::AdaptiveKDTree::reset_tree(), moab::AdaptiveKDTreeIter::step(), swap(), moab::AdaptiveKDTree::X, moab::AdaptiveKDTree::Y, and moab::AdaptiveKDTree::Z.
Referenced by main().
ErrorCode rval;
Core moab;
Interface* mb = &moab;
AdaptiveKDTree tool( mb );
EntityHandle root;
double min[3] = { -3, -2, -1 };
double max[3] = { 1, 2, 3 };
CHECK( box_equal( iter, -3, -2, -1, 1, 2, 3 ) );
// check that steping the iterator fails correctly.
rval = iter.step();
rval = iter.step();
CHECK( MB_SUCCESS != rval );
rval = tool.reset_tree();
root = 0;
// construct a simple 2D tree for remaining tests
EntityHandle leaves[9];
create_simple_2d_tree( tool, root, leaves );
/**** Now traverse tree again, and check neighbors of each leaf *****/
std::vector< AdaptiveKDTreeIter > list;
// leaf [1]
CHECK( iter.handle() == leaves[1] );
list.clear();
rval = iter.get_neighbors( AdaptiveKDTree::X, true, list );
CHECK( list.empty() );
list.clear();
rval = iter.get_neighbors( AdaptiveKDTree::X, false, list );
CHECK( list.size() == 1 );
// should be leaf [3]
CHECK( box_equal( list.front(), -1, -4, -1, 4, 0, 1 ) );
CHECK( list.front().handle() == leaves[3] );
list.clear();
rval = iter.get_neighbors( AdaptiveKDTree::Y, true, list );
list.clear();
rval = iter.get_neighbors( AdaptiveKDTree::Y, false, list );
// should be leaf [2]
CHECK( box_equal( list.front(), -5, -2, -1, -1, 0, 1 ) );
CHECK( list.front().handle() == leaves[2] );
list.clear();
rval = iter.get_neighbors( AdaptiveKDTree::Z, true, list );
list.clear();
rval = iter.get_neighbors( AdaptiveKDTree::Z, false, list );
// leaf [2]
rval = iter.step();
CHECK( iter.handle() == leaves[2] );
list.clear();
list.clear();
list.clear();
// should be leaf [1]
CHECK( box_equal( list.front(), -5, -4, -1, -1, -2, 1 ) );
CHECK( list.front().handle() == leaves[1] );
list.clear();
CHECK( list.size() == 2 );
// should be leaf [5] and leaf[6]
if( list[0].handle() == leaves[6] ) std::swap( list[0], list[1] );
CHECK( list[0].handle() == leaves[5] );
CHECK( list[1].handle() == leaves[6] );
CHECK( box_equal( list[0], -5, 0, -1, -3, 4, 1 ) );
CHECK( box_equal( list[1], -3, 0, -1, 0, 4, 1 ) );
list.clear();
list.clear();
// leaf [3]
rval = iter.step();
CHECK( iter.handle() == leaves[3] );
// leaf [4]
rval = iter.step();
CHECK( iter.handle() == leaves[4] );
// leaf [5]
rval = iter.step();
CHECK( iter.handle() == leaves[5] );
// leaf [6]
rval = iter.step();
CHECK( iter.handle() == leaves[6] );
// leaf [7]
rval = iter.step();
CHECK( iter.handle() == leaves[7] );
// leaf [8]
rval = iter.step();
CHECK( iter.handle() == leaves[8] );
| int main | ( | ) |
Definition at line 1131 of file adaptive_kd_tree_tests.cpp.
References error_count, moab::fail(), leaf_iterator_test(), RUN_TEST, test_build_tree_bisect_triangles(), test_closest_triangle(), test_leaf_intersects_plane(), test_leaf_intersects_ray(), test_leaf_sibling(), test_leaf_volume(), test_ray_intersect_triangles(), test_sphere_intersect_triangles(), and test_tree_merge_nodes().
#ifdef MOAB_HAVE_MPI
int fail = MPI_Init( 0, 0 );
if( fail ) return fail;
#endif
int error_count = 0;
error_count += RUN_TEST( leaf_iterator_test );
error_count += RUN_TEST( test_build_tree_bisect_triangles );
error_count += RUN_TEST( test_closest_triangle );
error_count += RUN_TEST( test_sphere_intersect_triangles );
error_count += RUN_TEST( test_ray_intersect_triangles );
error_count += RUN_TEST( test_tree_merge_nodes );
error_count += RUN_TEST( test_leaf_volume );
error_count += RUN_TEST( test_leaf_sibling );
error_count += RUN_TEST( test_leaf_intersects_plane );
error_count += RUN_TEST( test_leaf_intersects_ray );
fail = MPI_Finalize();
#endif
return error_count;
| void test_build_tree_bisect_triangles | ( | ) |
Definition at line 552 of file adaptive_kd_tree_tests.cpp.
References moab::AdaptiveKDTree::build_tree(), build_triangle_box_large(), build_triangle_box_small(), build_triangle_octahedron(), CHECK, moab::Range::clear(), moab::Core::delete_mesh(), ErrorCode, MB_SUCCESS, moab::AdaptiveKDTree::reset_tree(), and test_valid_tree().
Core moab;
AdaptiveKDTree tool( &moab );
Range box_tris;
std::ostringstream options;
options << "MAX_PER_LEAF=1;SPLITS_PER_DIR=1;PLANE_SET=0;";
FileOptions opts( options.str().c_str() );
EntityHandle root;
ErrorCode rval;
moab.delete_mesh();
box_tris.clear();
build_triangle_box_small( &moab, box_tris );
rval = tool.build_tree( box_tris, &root, &opts );
test_valid_tree( &tool, root, opts, box_tris );
tool.reset_tree();
moab.delete_mesh();
box_tris.clear();
build_triangle_octahedron( &moab, box_tris );
tool.reset_tree();
moab.delete_mesh();
box_tris.clear();
build_triangle_box_large( &moab, box_tris );
tool.reset_tree();
options << "MAX_DEPTH=2;";
opts = FileOptions( options.str().c_str() );
tool.reset_tree();
| void test_closest_triangle | ( | ) |
Definition at line 597 of file adaptive_kd_tree_tests.cpp.
References moab::CartVect::array(), moab::AdaptiveKDTree::build_tree(), build_triangle_box_large(), build_triangle_box_small(), CHECK, check_common_vertex(), check_point_in_triangles(), moab::Range::clear(), moab::AdaptiveKDTree::closest_triangle(), moab::Core::delete_mesh(), ErrorCode, MB_SUCCESS, moab::Tree::moab(), moab::AdaptiveKDTree::reset_tree(), and test_valid_tree().
Core moab;
Range box_tris;
EntityHandle root;
ErrorCode rval;
EntityHandle tri;
moab.delete_mesh();
box_tris.clear();
// test closest to each corner of the box.
for( unsigned i = 0; i < 8; ++i )
int x = i & 1 ? 1 : -1;
int y = i & 2 ? 1 : -1;
int z = i & 4 ? 1 : -1;
double coords[] = { 2.0 * x, 2.0 * y, 2.0 * z };
CartVect point;
rval = tool.closest_triangle( root, coords, point.array(), tri );
// check result position
CHECK( fabs( x - point[0] ) < 1e-6 );
CHECK( fabs( y - point[1] ) < 1e-6 );
CHECK( fabs( z - point[2] ) < 1e-6 );
// check point is at triangle vertex
check_common_vertex( tool.moab(), &tri, 1, point );
// test location on each face
const CartVect facepts[] = { CartVect( -1.0, 0.5, 0.5 ), CartVect( 1.0, 0.5, 0.5 ), CartVect( 0.5, -1.0, 0.5 ),
CartVect( 0.5, 1.0, 0.5 ), CartVect( 0.5, 0.5, -1.0 ), CartVect( 0.5, 0.5, 1.0 ) };
for( unsigned i = 0; i < 6; ++i )
CartVect point;
rval = tool.closest_triangle( root, facepts[i].array(), point.array(), tri );
const CartVect diff = facepts[i] - point;
CHECK( fabs( diff[0] ) < 1e-6 );
CHECK( fabs( diff[1] ) < 1e-6 );
CHECK( fabs( diff[2] ) < 1e-6 );
// check that point is contained within triangle
check_point_in_triangles( tool.moab(), &tri, 1, point );
// test a location really far from the tree
const double far[] = { 0.75, 0.75, 200 };
CartVect point;
rval = tool.closest_triangle( root, far, point.array(), tri );
CHECK( fabs( point[0] - 0.75 ) < 1e-6 );
CHECK( fabs( point[1] - 0.75 ) < 1e-6 );
CHECK( fabs( point[2] - 1.00 ) < 1e-6 );
// now do it all again with a lot more triangles
tool.reset_tree();
moab.delete_mesh();
box_tris.clear();
double coords[] = { 4.0 * x, 4.0 * y, 4.0 * z };
CartVect point;
CHECK( fabs( 3.0 * x - point[0] ) < 1e-6 );
CHECK( fabs( 3.0 * y - point[1] ) < 1e-6 );
CHECK( fabs( 3.0 * z - point[2] ) < 1e-6 );
const CartVect facepts2[] = { CartVect( -3.0, 0.5, 0.5 ), CartVect( 3.0, 0.5, 0.5 ), CartVect( 0.5, -3.0, 0.5 ),
CartVect( 0.5, 3.0, 0.5 ), CartVect( 0.5, 0.5, -3.0 ), CartVect( 0.5, 0.5, 3.0 ) };
CartVect point;
rval = tool.closest_triangle( root, facepts2[i].array(), point.array(), tri );
const CartVect diff = facepts2[i] - point;
const double far[] = { 2.75, 2.75, 200 };
CartVect point;
CHECK( fabs( point[0] - 2.75 ) < 1e-6 );
CHECK( fabs( point[1] - 2.75 ) < 1e-6 );
CHECK( fabs( point[2] - 3.00 ) < 1e-6 );
| void test_leaf_intersects_plane | ( | ) |
Definition at line 1006 of file adaptive_kd_tree_tests.cpp.
References CHECK, CHECK_ERR, moab::Tree::create_root(), ErrorCode, moab::AdaptiveKDTree::get_tree_iterator(), moab::AdaptiveKDTreeIter::intersects(), moab::AdaptiveKDTree::X, moab::AdaptiveKDTree::Y, and moab::AdaptiveKDTree::Z.
ErrorCode rval;
Core moab;
EntityHandle root;
const double min[3] = { -5, -4, -1 };
const double max[3] = { 1, 2, 3 };
rval = tool.create_root( min, max, root );CHECK_ERR( rval );
rval = tool.get_tree_iterator( root, iter );CHECK_ERR( rval );
AdaptiveKDTree::Plane x1 = { min[0] - 1, AdaptiveKDTree::X };
CHECK( !iter.intersects( x1 ) );
AdaptiveKDTree::Plane x2 = { min[0], AdaptiveKDTree::X };
CHECK( iter.intersects( x2 ) );
AdaptiveKDTree::Plane x3 = { min[0] + 1, AdaptiveKDTree::X };
CHECK( iter.intersects( x3 ) );
AdaptiveKDTree::Plane x4 = { max[0] - 1, AdaptiveKDTree::X };
CHECK( iter.intersects( x4 ) );
AdaptiveKDTree::Plane x5 = { max[0], AdaptiveKDTree::X };
CHECK( iter.intersects( x5 ) );
AdaptiveKDTree::Plane x6 = { max[0] + 1, AdaptiveKDTree::X };
CHECK( !iter.intersects( x6 ) );
AdaptiveKDTree::Plane y1 = { min[1] - 1, AdaptiveKDTree::Y };
CHECK( !iter.intersects( y1 ) );
AdaptiveKDTree::Plane y2 = { min[1], AdaptiveKDTree::Y };
CHECK( iter.intersects( y2 ) );
AdaptiveKDTree::Plane y3 = { min[1] + 1, AdaptiveKDTree::Y };
CHECK( iter.intersects( y3 ) );
AdaptiveKDTree::Plane y4 = { max[1] - 1, AdaptiveKDTree::Y };
CHECK( iter.intersects( y4 ) );
AdaptiveKDTree::Plane y5 = { max[1], AdaptiveKDTree::Y };
CHECK( iter.intersects( y5 ) );
AdaptiveKDTree::Plane y6 = { max[1] + 1, AdaptiveKDTree::Y };
CHECK( !iter.intersects( y6 ) );
AdaptiveKDTree::Plane z1 = { min[2] - 1, AdaptiveKDTree::Z };
CHECK( !iter.intersects( z1 ) );
AdaptiveKDTree::Plane z2 = { min[2], AdaptiveKDTree::Z };
CHECK( iter.intersects( z2 ) );
AdaptiveKDTree::Plane z3 = { min[2] + 1, AdaptiveKDTree::Z };
CHECK( iter.intersects( z3 ) );
AdaptiveKDTree::Plane z4 = { max[2] - 1, AdaptiveKDTree::Z };
CHECK( iter.intersects( z4 ) );
AdaptiveKDTree::Plane z5 = { max[2], AdaptiveKDTree::Z };
CHECK( iter.intersects( z5 ) );
AdaptiveKDTree::Plane z6 = { max[2] + 1, AdaptiveKDTree::Z };
CHECK( !iter.intersects( z6 ) );
| void test_leaf_intersects_ray | ( | ) |
Definition at line 1068 of file adaptive_kd_tree_tests.cpp.
References CHECK, CHECK_ERR, CHECK_RAY_XSECTS, moab::Tree::create_root(), ErrorCode, moab::AdaptiveKDTree::get_tree_iterator(), and moab::AdaptiveKDTreeIter::intersect_ray().
ErrorCode rval;
Core moab;
double t_in, t_out;
EntityHandle root;
// start with point inside box
const double pt1[] = { 0, 0, 0 };
const double dir1[] = { 0.1, 0.1, 0.1 };
CHECK_RAY_XSECTS( pt1, dir1, 0, 10 );
const double dir2[] = { 5, 5, 5 };
CHECK_RAY_XSECTS( pt1, dir2, 0, 0.2 );
const double pxdir[] = { 1, 0, 0 };
CHECK_RAY_XSECTS( pt1, pxdir, 0, 1 );
const double nxdir[] = { -1, 0, 0 };
CHECK_RAY_XSECTS( pt1, nxdir, 0, 5 );
const double pydir[] = { 0, 1, 0 };
CHECK_RAY_XSECTS( pt1, pydir, 0, 2 );
const double nydir[] = { 0, -1, 0 };
CHECK_RAY_XSECTS( pt1, nydir, 0, 4 );
const double pzdir[] = { 0, 0, 1 };
CHECK_RAY_XSECTS( pt1, pzdir, 0, 3 );
const double nzdir[] = { 0, 0, -1 };
CHECK_RAY_XSECTS( pt1, nzdir, 0, 1 );
// point below box
const double pt2[] = { 0, 0, -2 };
CHECK_RAY_XSECTS( pt2, dir1, 10, 10 );
CHECK_RAY_XSECTS( pt2, dir2, 0.2, 0.2 );
CHECK( !iter.intersect_ray( pt2, pxdir, t_in, t_out ) );
CHECK( !iter.intersect_ray( pt2, nxdir, t_in, t_out ) );
CHECK( !iter.intersect_ray( pt2, pydir, t_in, t_out ) );
CHECK( !iter.intersect_ray( pt2, nydir, t_in, t_out ) );
CHECK_RAY_XSECTS( pt2, pzdir, 1, 5 );
CHECK( !iter.intersect_ray( pt2, nzdir, t_in, t_out ) );
// point right of box
const double pt3[] = { 3, 0, 0 };
CHECK( !iter.intersect_ray( pt3, dir1, t_in, t_out ) );
CHECK( !iter.intersect_ray( pt3, dir2, t_in, t_out ) );
CHECK( !iter.intersect_ray( pt3, pxdir, t_in, t_out ) );
CHECK_RAY_XSECTS( pt3, nxdir, 2, 8 );
CHECK( !iter.intersect_ray( pt3, pydir, t_in, t_out ) );
CHECK( !iter.intersect_ray( pt3, nydir, t_in, t_out ) );
CHECK( !iter.intersect_ray( pt3, pzdir, t_in, t_out ) );
CHECK( !iter.intersect_ray( pt3, nzdir, t_in, t_out ) );
// a few more complex test cases
const double dira[] = { -3, 0, 3 };
CHECK_RAY_XSECTS( pt3, dira, 2. / 3., 1.0 );
const double dirb[] = { -2, 0, 3.1 };
CHECK( !iter.intersect_ray( pt3, dirb, t_in, t_out ) );
| void test_leaf_sibling | ( | ) |
Definition at line 953 of file adaptive_kd_tree_tests.cpp.
References CHECK, CHECK_EQUAL, CHECK_ERR, create_simple_2d_tree(), ErrorCode, moab::AdaptiveKDTree::get_tree_iterator(), moab::AdaptiveKDTreeIter::handle(), moab::AdaptiveKDTreeIter::is_sibling(), moab::AdaptiveKDTreeIter::sibling_is_forward(), and moab::AdaptiveKDTreeIter::step().
ErrorCode rval;
Core moab;
EntityHandle root;
create_simple_2d_tree( tool, root );
AdaptiveKDTreeIter iter1, iter2;
rval = tool.get_tree_iterator( root, iter1 );CHECK_ERR( rval );
rval = tool.get_tree_iterator( root, iter2 );CHECK_ERR( rval );
// iter1 == 1, iter2 == 1
CHECK( !iter1.is_sibling( iter1 ) );
CHECK( !iter1.is_sibling( iter1.handle() ) );
CHECK( !iter1.is_sibling( iter2 ) );
CHECK( iter1.sibling_is_forward() );
// iter1 == 1, iter2 == 2
rval = iter2.step();CHECK_ERR( rval );
CHECK( iter1.is_sibling( iter2 ) );
CHECK( iter1.is_sibling( iter2.handle() ) );
CHECK( iter2.is_sibling( iter1 ) );
CHECK( iter2.is_sibling( iter1.handle() ) );
CHECK( !iter2.sibling_is_forward() );
// iter1 == 1, iter2 == 3
CHECK( !iter1.is_sibling( iter2.handle() ) );
CHECK( !iter2.is_sibling( iter1 ) );
CHECK( !iter2.is_sibling( iter1.handle() ) );
CHECK( iter2.sibling_is_forward() );
// iter1 == 2, iter2 == 3
rval = iter1.step();CHECK_ERR( rval );
CHECK( !iter1.sibling_is_forward() );
// iter1 == 4, iter2 == 3
CHECK_EQUAL( iter1.handle(), iter2.handle() );
| void test_leaf_volume | ( | ) |
Definition at line 926 of file adaptive_kd_tree_tests.cpp.
References CHECK_ERR, CHECK_REAL_EQUAL, create_simple_2d_tree(), ErrorCode, moab::AdaptiveKDTree::get_tree_iterator(), moab::AdaptiveKDTreeIter::step(), and moab::AdaptiveKDTreeIter::volume().
Referenced by main(), test_leaf_volume_box(), and test_leaf_volume_gen().
Core moab;
EntityHandle root;
ErrorCode rval = tool.get_tree_iterator( root, iter );CHECK_ERR( rval );
CHECK_REAL_EQUAL( 16.0, iter.volume(), 1e-12 ); // 1
CHECK_ERR( iter.step() );
CHECK_REAL_EQUAL( 16.0, iter.volume(), 1e-12 ); // 2
CHECK_REAL_EQUAL( 40.0, iter.volume(), 1e-12 ); // 3
CHECK_REAL_EQUAL( 8.0, iter.volume(), 1e-12 ); // 4
CHECK_REAL_EQUAL( 16.0, iter.volume(), 1e-12 ); // 5
CHECK_REAL_EQUAL( 24.0, iter.volume(), 1e-12 ); // 6
CHECK_REAL_EQUAL( 30.0, iter.volume(), 1e-12 ); // 7
CHECK_REAL_EQUAL( 10.0, iter.volume(), 1e-12 ); // 8
| void test_ray_intersect_triangles | ( | ) |
Definition at line 790 of file adaptive_kd_tree_tests.cpp.
References moab::CartVect::array(), moab::AdaptiveKDTree::build_tree(), build_triangle_box_small(), CHECK, check_point_in_triangles(), moab::Range::clear(), moab::Core::delete_mesh(), ErrorCode, MB_SUCCESS, moab::AdaptiveKDTree::ray_intersect_triangles(), and test_valid_tree().
Core moab;
Range box_tris;
EntityHandle root;
ErrorCode rval;
std::vector< EntityHandle > tris;
std::vector< double > dists;
moab.delete_mesh();
box_tris.clear();
// test ray through box parallel to X axis
CartVect dir( 1, 0, 0 );
CartVect pt( -2, 0.75, 0.75 );
tris.clear();
dists.clear();
rval = tool.ray_intersect_triangles( root, 1e-6, dir.array(), pt.array(), tris, dists );
CHECK( tris.size() == 3 );
CHECK( dists.size() == tris.size() );
for( unsigned i = 0; i < dists.size(); ++i )
CHECK( fabs( dists[i] - 1 ) < 1e-6 || fabs( dists[i] - 3 ) < 1e-6 );
CartVect tript = pt + dists[i] * dir;
check_point_in_triangles( &moab, &tris[i], 1, tript );
// test ray through box parallel to X axis, closest tri only
tris.clear();
dists.clear();
rval = tool.ray_intersect_triangles( root, 1e-6, dir.array(), pt.array(), tris, dists, 1 );
CHECK( tris.size() == 1 );
CHECK( fabs( dists[0] - 1 ) < 1e-6 );
check_point_in_triangles( &moab, &tris[0], 1, pt + dists[0] * dir );
// test ray ending within box, parallel to X axis
tris.clear();
dists.clear();
rval = tool.ray_intersect_triangles( root, 1e-6, dir.array(), pt.array(), tris, dists, 0, 2.0 );
// test ray starting within box parallel to X axis
tris.clear();
dists.clear();
pt = CartVect( 0, .75, .75 );
CHECK( tris.size() == 2 );
CHECK( fabs( dists[i] - 1 ) < 1e-6 );
// test skew ray through box
dir = CartVect( 0.5 * sqrt( 2.0 ), 0.5 * sqrt( 2.0 ), 0.0 );
pt = CartVect( 0, -1.5, 0 );
tris.clear();
dists.clear();
if( dists[0] < dists[1] )
CHECK( fabs( dists[0] - 0.5 * sqrt( 2.0 ) ) < 1e-6 );
CHECK( fabs( dists[1] - sqrt( 2.0 ) ) < 1e-6 );
check_point_in_triangles( &moab, &tris[1], 1, pt + dists[1] * dir );
// test ray through box parallel to -Y axis
dir = CartVect( 0, -1, 0 );
pt = CartVect( 0, 2, 0 );
tris.clear();
dists.clear();
CHECK( tris.size() == 4 );
// test ray through box parallel to Z axis
dir = CartVect( 0, 0, 1 );
pt = CartVect( 0, 0, -2 );
tris.clear();
dists.clear();
// test ray through box parallel to Z axis, limit 2 first 2 intersections
tris.clear();
dists.clear();
rval = tool.ray_intersect_triangles( root, 1e-6, dir.array(), pt.array(), tris, dists, 2 );
| void test_sphere_intersect_triangles | ( | ) |
Definition at line 724 of file adaptive_kd_tree_tests.cpp.
References moab::AdaptiveKDTree::build_tree(), build_triangle_box_large(), build_triangle_box_small(), center(), CHECK, check_common_vertex(), moab::Range::clear(), moab::Core::delete_mesh(), ErrorCode, MB_SUCCESS, moab::Tree::moab(), moab::AdaptiveKDTree::reset_tree(), moab::AdaptiveKDTree::sphere_intersect_triangles(), and test_valid_tree().
Core moab;
Range box_tris;
EntityHandle root;
ErrorCode rval;
std::vector< EntityHandle > triangles;
moab.delete_mesh();
box_tris.clear();
double x = i & 1 ? 1 : -1;
double y = i & 2 ? 1 : -1;
double z = i & 4 ? 1 : -1;
double center[] = { x, y, z };
triangles.clear();
rval = tool.sphere_intersect_triangles( root, center, 0.26, triangles );
// expect 3 to 6 triangles, depending on the corner
CHECK( triangles.size() >= 3 );
CHECK( triangles.size() <= 6 );
// check point is at the same vertex for each triangle
check_common_vertex( tool.moab(), &triangles[0], triangles.size(), CartVect( center ) );
tool.reset_tree();
moab.delete_mesh();
box_tris.clear();
double center[] = { 3.0 * x, 3.0 * y, 3.0 * z };
triangles.clear();
| void test_tree_merge_nodes | ( | ) |
Definition at line 518 of file adaptive_kd_tree_tests.cpp.
References box_equal(), CHECK, create_simple_2d_tree(), ErrorCode, moab::AdaptiveKDTree::get_tree_iterator(), moab::AdaptiveKDTreeIter::handle(), mb, MB_SUCCESS, moab::AdaptiveKDTree::merge_leaf(), and moab::AdaptiveKDTreeIter::step().
// build simple tree for tests
ErrorCode rval;
Core moab;
EntityHandle root;
// merge leaves 1 and 2
rval = tool.merge_leaf( iter );
// merge leaf 1,2 with 3,4 (implicity merges 3 and 4)
// make sure iterator remains valid
rval = iter.step();
// leaf 5
| void test_valid_tree | ( | AdaptiveKDTree * | tool, |
| EntityHandle | root, | ||
| FileOptions & | options, | ||
| const Range & | expected_tris | ||
Definition at line 123 of file adaptive_kd_tree_tests.cpp.
References moab::AdaptiveKDTreeIter::box_max(), moab::AdaptiveKDTreeIter::box_min(), moab::GeomUtil::box_tri_overlap(), CHECK, moab::AdaptiveKDTreeIter::depth(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::Interface::get_entities_by_type(), moab::Tree::get_max_depth(), moab::FileOptions::get_real_option(), moab::AdaptiveKDTree::get_tree_iterator(), moab::AdaptiveKDTreeIter::handle(), MB_ENTITY_NOT_FOUND, MB_SUCCESS, MBTRI, moab::Range::merge(), moab::Tree::moab(), and moab::AdaptiveKDTreeIter::step().
Range all_tris;
ErrorCode rval;
CHECK( MB_SUCCESS == tool->get_tree_iterator( root, iter ) );
do
double dep;
rval = options.get_real_option( "MAX_DEPTH", dep );
CHECK( MB_ENTITY_NOT_FOUND == rval || iter.depth() <= tool->get_max_depth() );
Range tris;
CHECK( tool->moab()->get_entities_by_type( iter.handle(), MBTRI, tris ) == MB_SUCCESS );
// CHECK( !tris.empty() );
all_tris.merge( tris );
const CartVect min( iter.box_min() ), max( iter.box_max() );
const CartVect cen( 0.5 * ( min + max ) ), hdim( 0.5 * ( max - min ) );
for( Range::iterator i = tris.begin(); i != tris.end(); ++i )
EntityHandle tri = *i;
int conn_len;
CHECK( tool->moab()->get_connectivity( tri, conn, conn_len ) == MB_SUCCESS );
CHECK( conn_len == 3 );
CartVect coords[3];
CHECK( tool->moab()->get_coords( conn, 3, coords[0].array() ) == MB_SUCCESS );
CHECK( GeomUtil::box_tri_overlap( coords, cen, hdim ) );
} while( MB_SUCCESS == ( rval = iter.step() ) );
CHECK( expected_tris == all_tris );
