MOAB: Mesh Oriented datABase
(version 5.4.1)
#include <iostream>#include <cassert>#include <ctime>#include <vector>#include "moab/Core.hpp"#include "moab/Range.hpp"#include "moab/MeshTopoUtil.hpp"#include "moab/HalfFacetRep.hpp"#include "../TestUtil.hpp"#include "moab/CpuTimer.hpp"
Include dependency graph for adj_mem_time_test.cpp:Go to the source code of this file.
Classes | |
| struct | query_time |
| struct | mesh_mem |
Functions | |
| void | handle_error_code (ErrorCode rv, int &number_failed, int &number_successful) |
| ErrorCode | adj_perf (const char *filename) |
| int | main (int argc, char *argv[]) |
Variables | |
| int | number_tests_successful = 0 |
| int | number_tests_failed = 0 |
Definition at line 91 of file adj_mem_time_test.cpp.
References mesh_mem::adjacency_storage, mesh_mem::amortized_adjacency_storage, mesh_mem::amortized_entity_storage, mesh_mem::amortized_tag_storage, mesh_mem::amortized_total_storage, moab::Range::begin(), query_time::cell_to_cells_avg, query_time::cell_to_cells_total, query_time::cell_to_edges_avg, query_time::cell_to_edges_total, query_time::cell_to_faces_avg, query_time::cell_to_faces_total, CHECK_ERR, moab::Range::clear(), query_time::ds_construction, query_time::edge_to_cells_avg, query_time::edge_to_cells_total, query_time::edge_to_edges_avg, query_time::edge_to_edges_total, query_time::edge_to_faces_avg, query_time::edge_to_faces_total, moab::Range::end(), mesh_mem::entity_storage, moab::error(), ErrorCode, moab::Interface::estimated_memory_use(), query_time::face_to_cells_avg, query_time::face_to_cells_total, query_time::face_to_edges_avg, query_time::face_to_edges_total, query_time::face_to_faces_avg, query_time::face_to_faces_total, moab::Interface::get_adjacencies(), moab::MeshTopoUtil::get_bridge_adjacencies(), moab::Interface::get_entities_by_dimension(), moab::Interface::load_file(), MB_SUCCESS, MPI_COMM_WORLD, read_options, moab::Range::size(), mesh_mem::tag_storage, moab::CpuTimer::time_elapsed(), mesh_mem::total_storage, query_time::vertex_to_cells_avg, query_time::vertex_to_cells_total, query_time::vertex_to_edges_avg, query_time::vertex_to_edges_total, query_time::vertex_to_faces_avg, and query_time::vertex_to_faces_total.
Referenced by main().
ErrorCode error;
Core moab;
Interface* mbImpl = &moab;
MeshTopoUtil mtu( mbImpl );
struct query_time qtime;
struct mesh_mem qmem;
#ifdef MOAB_HAVE_MPI
int procs = 1;
MPI_Comm_size( MPI_COMM_WORLD, &procs );
if( procs > 1 )
read_options = "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS";
error = mbImpl->load_file( filename, 0, read_options.c_str() );CHECK_ERR( error );
else if( procs == 1 )
#endif
error = mbImpl->load_file( filename );CHECK_ERR( error );
#endif
// Storage Costs before any call to adjacencies
unsigned long long sTotS, sTAS, sES, sAES, sAS, sAAS, sTS, sATS;
sTotS = sTAS = sES = sAES = sAS = sAAS = sTS = sATS = 0;
mbImpl->estimated_memory_use( NULL, 0, &sTotS, &sTAS, &sES, &sAES, &sAS, &sAAS, NULL, 0, &sTS, &sATS );
qmem.total_storage[0] = sTotS;
qmem.amortized_total_storage[0] = sTAS;
qmem.entity_storage[0] = sES;
qmem.amortized_entity_storage[0] = sAES;
qmem.adjacency_storage[0] = sAS;
qmem.amortized_adjacency_storage[0] = sAAS;
qmem.tag_storage[0] = sTS;
qmem.amortized_tag_storage[0] = sATS;
// Create ranges for handles of explicit elements of the mixed mesh
Range verts, edges, faces, cells;
error = mbImpl->get_entities_by_dimension( 0, 0, verts );
error = mbImpl->get_entities_by_dimension( 0, 1, edges );
error = mbImpl->get_entities_by_dimension( 0, 2, faces );
error = mbImpl->get_entities_by_dimension( 0, 3, cells );
int nverts = verts.size();
int nedges = edges.size();
int nfaces = faces.size();
int ncells = cells.size();
std::cout << "MESH SIZE :: "
<< "NV = " << nverts << ", NE = " << nedges << ", NF = " << nfaces << ", NC = " << ncells << std::endl;
CpuTimer* mt = new CpuTimer;
double time_start, time_avg, time_total;
// Perform queries
std::vector< EntityHandle > adjents;
Range ngbents;
// This call should create all the necessary ahf maps or adjacency lists
time_start = mt->time_elapsed();
error = mbImpl->get_adjacencies( &*verts.begin(), 1, 1, false, adjents );
time_total = mt->time_elapsed() - time_start;
qtime.ds_construction = time_total;
// 1D Queries
std::cout << "1D QUERIES Start" << std::endl;
// IQ1: For every vertex, obtain incident edges
for( Range::iterator i = verts.begin(); i != verts.end(); ++i )
adjents.clear();
error = mbImpl->get_adjacencies( &*i, 1, 1, false, adjents );
time_avg = time_total / (double)verts.size();
qtime.vertex_to_edges_total = time_total;
qtime.vertex_to_edges_avg = time_avg;
// NQ1: For every edge, obtain neighbor edges
#ifdef MOAB_HAVE_AHF
for( Range::iterator i = edges.begin(); i != edges.end(); ++i )
adjents.clear();
time_avg = time_total / (double)edges.size();
#else
error = mtu.get_bridge_adjacencies( *edges.begin(), 0, 1, ngbents );
ngbents.clear();
error = mtu.get_bridge_adjacencies( *i, 0, 1, ngbents );
#endif
qtime.edge_to_edges_total = time_total;
qtime.edge_to_edges_avg = time_avg;
std::cout << "1D QUERIES End" << std::endl;
// 2D Queries
std::cout << "2D QUERIES Start" << std::endl;
// IQ21: For every vertex, obtain incident faces
adjents.clear();
error = mbImpl->get_adjacencies( &*i, 1, 2, false, adjents );
qtime.vertex_to_faces_total = time_total;
qtime.vertex_to_faces_avg = time_avg;
// IQ22: For every edge, obtain incident faces
adjents.clear();
qtime.edge_to_faces_total = time_total;
qtime.edge_to_faces_avg = time_avg;
// NQ2: For every face, obtain neighbor faces
for( Range::iterator i = faces.begin(); i != faces.end(); ++i )
adjents.clear();
time_avg = time_total / (double)faces.size();
#else
error = mtu.get_bridge_adjacencies( *faces.begin(), 1, 2, ngbents );
ngbents.clear();
error = mtu.get_bridge_adjacencies( *i, 1, 2, ngbents );
#endif
qtime.face_to_faces_total = time_total;
qtime.face_to_faces_avg = time_avg;
// DQ2: For every face, obtain its edges
adjents.clear();
qtime.face_to_edges_total = time_total;
qtime.face_to_edges_avg = time_avg;
std::cout << "2D QUERIES End" << std::endl;
// 3D Queries
std::cout << "3D QUERIES Start " << std::endl;
// IQ31: For every vertex, obtain incident cells
adjents.clear();
error = mbImpl->get_adjacencies( &*i, 1, 3, false, adjents );
qtime.vertex_to_cells_total = time_total;
qtime.vertex_to_cells_avg = time_avg;
// IQ 32: For every edge, obtain incident cells
adjents.clear();
qtime.edge_to_cells_total = time_total;
qtime.edge_to_cells_avg = time_avg;
// IQ32: For every face, obtain incident cells
adjents.clear();
qtime.face_to_cells_total = time_total;
qtime.face_to_cells_avg = time_avg;
// NQ3: For every cell, obtain neighbor cells
for( Range::iterator i = cells.begin(); i != cells.end(); ++i )
adjents.clear();
time_avg = time_total / (double)cells.size();
#else
error = mtu.get_bridge_adjacencies( *cells.begin(), 2, 3, ngbents );
ngbents.clear();
error = mtu.get_bridge_adjacencies( *i, 2, 3, ngbents );
#endif
qtime.cell_to_cells_total = time_total;
qtime.cell_to_cells_avg = time_avg;
// DQ31: For every cell, obtain its edges
adjents.clear();
qtime.cell_to_edges_total = time_total;
qtime.cell_to_edges_avg = time_avg;
// DQ32: For every cell, obtain its faces
adjents.clear();
qtime.cell_to_faces_total = time_total;
qtime.cell_to_faces_avg = time_avg;
std::cout << "3D QUERIES End" << std::endl;
// Storage Costs after calling ahf deinitialize
unsigned long long eTotS, eTAS, eES, eAES, eAS, eAAS, eTS, eATS;
eTotS = eTAS = eES = eAES = eAS = eAAS = eTS = eATS = 0;
mbImpl->estimated_memory_use( NULL, 0, &eTotS, &eTAS, &eES, &eAES, &eAS, &eAAS, NULL, 0, &eTS, &eATS );
qmem.total_storage[1] = eTotS;
qmem.amortized_total_storage[1] = eTAS;
qmem.entity_storage[1] = eES;
qmem.amortized_entity_storage[1] = eAES;
qmem.adjacency_storage[1] = eAS;
qmem.amortized_adjacency_storage[1] = eAAS;
qmem.tag_storage[1] = eTS;
qmem.amortized_tag_storage[1] = eATS;
// Print times
std::cout << std::endl;
std::cout << " Data Structure Construction Time = " << qtime.ds_construction << " Secs" << std::endl;
std::cout << "Query times in Seconds" << std::endl;
std::cout << "QUERY: Vertex -> Edges :: MOAB_AHF: Average time = " << qtime.vertex_to_edges_avg;
std::cout << ", Total time = " << qtime.vertex_to_edges_total << std::endl;
#else
std::cout << "QUERY: Vertex -> Edges :: MOAB: Average time = " << qtime.vertex_to_edges_avg;
#endif
std::cout << "QUERY: Edge -> Edges :: MOAB_AHF: Average time = " << qtime.edge_to_edges_avg;
std::cout << ", Total time = " << qtime.edge_to_edges_total << std::endl;
#else
std::cout << "QUERY: Edge -> Edges :: MOAB: Average time = " << qtime.edge_to_edges_avg;
#endif
std::cout << "QUERY: Vertex -> Faces :: MOAB_AHF: Average time = " << qtime.vertex_to_faces_avg;
std::cout << ", Total time = " << qtime.vertex_to_faces_total << std::endl;
#else
std::cout << "QUERY: Vertex -> Faces :: MOAB: Average time = " << qtime.vertex_to_faces_avg;
#endif
std::cout << "QUERY: Edge -> Faces :: MOAB_AHF: Average time = " << qtime.edge_to_faces_avg;
std::cout << ", Total time = " << qtime.edge_to_faces_total << std::endl;
#else
std::cout << "QUERY: Edge -> Faces :: MOAB: Average time = " << qtime.edge_to_faces_avg;
#endif
std::cout << "QUERY: Face -> Faces :: MOAB_AHF: Average time = " << qtime.face_to_faces_avg;
std::cout << ", Total time = " << qtime.face_to_faces_total << std::endl;
#else
std::cout << "QUERY: Face -> Faces :: MOAB: Average time = " << qtime.face_to_faces_avg;
#endif
std::cout << "QUERY: Face -> Edges :: MOAB_AHF: Average time = " << qtime.face_to_edges_avg;
std::cout << ", Total time = " << qtime.face_to_edges_total << std::endl;
#else
std::cout << "QUERY: Face -> Edges :: MOAB: Average time = " << qtime.face_to_edges_avg;
#endif
std::cout << "QUERY: Vertex -> Cells :: MOAB_AHF: Average time = " << qtime.vertex_to_cells_avg;
std::cout << ", Total time = " << qtime.vertex_to_cells_total << std::endl;
#else
std::cout << "QUERY: Vertex -> Cells :: MOAB: Average time = " << qtime.vertex_to_cells_avg;
#endif
std::cout << "QUERY: Edge -> Cells :: MOAB_AHF: Average time = " << qtime.edge_to_cells_avg;
std::cout << ", Total time = " << qtime.edge_to_cells_total << std::endl;
#else
std::cout << "QUERY: Edge -> Cells :: MOAB: Average time = " << qtime.edge_to_cells_avg;
#endif
std::cout << "QUERY: Face -> Cells :: MOAB_AHF: Average time = " << qtime.face_to_cells_avg;
std::cout << ", Total time = " << qtime.face_to_cells_total << std::endl;
#else
std::cout << "QUERY: Face -> Cells :: MOAB: Average time = " << qtime.face_to_cells_avg;
#endif
std::cout << "QUERY: Cell -> Cells :: MOAB_AHF: Average time = " << qtime.cell_to_cells_avg;
std::cout << ", Total time = " << qtime.cell_to_cells_total << std::endl;
#else
std::cout << "QUERY: Cell -> Cells :: MOAB: Average time = " << qtime.cell_to_cells_avg;
#endif
std::cout << "QUERY: Cell -> Edges :: MOAB_AHF: Average time = " << qtime.cell_to_edges_avg;
std::cout << ", Total time = " << qtime.cell_to_edges_total << std::endl;
#else
std::cout << "QUERY: Cell -> Edges :: MOAB: Average time = " << qtime.cell_to_edges_avg;
#endif
std::cout << "QUERY: Cell -> Faces :: MOAB_AHF: Average time = " << qtime.cell_to_faces_avg;
std::cout << ", Total time = " << qtime.cell_to_faces_total << std::endl;
#else
std::cout << "QUERY: Cell -> Faces :: MOAB: Average time = " << qtime.cell_to_faces_avg;
#endif
// Print Storage
for( int i = 0; i < 2; i++ )
if( i == 0 )
std::cout << "STORAGE BEFORE CALLING ADJACENCIES" << std::endl;
else
std::cout << "STORAGE AFTER CALLING ADJACENCIES" << std::endl;
std::cout << "Total storage = " << qmem.total_storage[i] << std::endl;
std::cout << "Total amortized storage = " << qmem.amortized_total_storage[i] << std::endl;
std::cout << "Entity storage = " << qmem.entity_storage[i] << std::endl;
std::cout << "Amortized entity storage = " << qmem.amortized_entity_storage[i] << std::endl;
std::cout << "Adjacency storage = " << qmem.adjacency_storage[i] << std::endl;
std::cout << "Amortized adjacency storage = " << qmem.amortized_adjacency_storage[i] << std::endl;
std::cout << "Tag storage = " << qmem.tag_storage[i] << std::endl;
std::cout << "Amortized tag storage = " << qmem.amortized_tag_storage[i] << std::endl;
double total_time = qtime.vertex_to_edges_total + qtime.edge_to_edges_total + qtime.vertex_to_faces_total +
qtime.edge_to_faces_total + qtime.face_to_faces_total + qtime.face_to_edges_total +
qtime.vertex_to_cells_total + qtime.edge_to_cells_total + qtime.face_to_cells_total +
qtime.cell_to_cells_total + qtime.cell_to_edges_total + qtime.cell_to_faces_total;
// Print values in a line to aid data copying later
std::cout << qtime.ds_construction << " " << total_time << " " << qmem.entity_storage[1] << " "
<< qmem.adjacency_storage[1] << " " << qtime.vertex_to_edges_avg << " " << qtime.edge_to_edges_avg
<< " " << qtime.vertex_to_faces_avg << " " << qtime.edge_to_faces_avg << " " << qtime.face_to_faces_avg
<< " " << qtime.face_to_edges_avg << " " << qtime.vertex_to_cells_avg << " " << qtime.edge_to_cells_avg
<< " " << qtime.face_to_cells_avg << " " << qtime.cell_to_cells_avg << " " << qtime.cell_to_edges_avg
<< " " << qtime.cell_to_faces_avg << std::endl;
delete mt;
return MB_SUCCESS;
| void handle_error_code | ( | ErrorCode | rv, |
| int & | number_failed, | ||
| int & | number_successful | ||
Definition at line 71 of file adj_mem_time_test.cpp.
References MB_SUCCESS, MPI_COMM_WORLD, and rank.
if( rv == MB_SUCCESS )
int rank = 0;
MPI_Comm_rank( MPI_COMM_WORLD, &rank );
if( rank == 0 ) std::cout << "Success";
#else
#endif
number_successful++;
else
std::cout << "Failure";
number_failed++;
| int main | ( | int | argc, |
| char * | argv[] | ||
Definition at line 553 of file adj_mem_time_test.cpp.
References adj_perf(), ErrorCode, filename, handle_error_code(), MPI_COMM_WORLD, number_tests_failed, number_tests_successful, and rank.
MPI_Init( &argc, &argv );
int nprocs, rank;
MPI_Comm_size( MPI_COMM_WORLD, &nprocs );
#endif
std::string filename;
#ifdef MOAB_HAVE_HDF5
filename = TestDir + "unittest/32hex_ef.h5m";
#else
filename = TestDir + "unittest/hexes_mixed.vtk";
#endif
if( argc == 1 )
if( rank == 0 ) std::cout << "Using default input file:" << filename << std::endl;
#else
#endif
else if( argc == 2 )
filename = argv[1];
else
std::cerr << "Usage: " << argv[0] << " [filename]" << std::endl;
return 1;
ErrorCode result;
if( rank == 0 ) std::cout << " para_adj_perf: ";
#else
std::cout << "adj_perf:";
#endif
result = adj_perf( filename.c_str() );
handle_error_code( result, number_tests_failed, number_tests_successful );
std::cout << "\n";
MPI_Finalize();
#endif
return number_tests_failed;
| int number_tests_failed = 0 |
Definition at line 28 of file adj_mem_time_test.cpp.
| int number_tests_successful = 0 |
Definition at line 27 of file adj_mem_time_test.cpp.
