MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "moab/Core.hpp"#include "moab/LloydSmoother.hpp"#include "moab/CartVect.hpp"#include "TestUtil.hpp"
Include dependency graph for lloyd_smoother_test.cpp:Go to the source code of this file.
Functions | |
| int | main (int argc, char **argv) |
Variables | |
| std::string | filename = "unittest/surfrandomtris-4part.h5m" |
| int main | ( | int | argc, |
| char ** | argv | ||
Definition at line 10 of file lloyd_smoother_test.cpp.
References moab::Range::begin(), CHECK_ERR, moab::Range::empty(), moab::Range::end(), ErrorCode, filename, moab::CartVect::get(), moab::Core::get_coords(), moab::Core::get_entities_by_dimension(), moab::Core::load_file(), mb, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_DOUBLE, moab::LloydSmoother::num_its(), moab::LloydSmoother::perform_smooth(), moab::LloydSmoother::report_its(), moab::Core::set_coords(), moab::Range::size(), moab::Core::tag_get_data(), moab::Core::tag_get_handle(), and moab::Core::tag_set_data().
if( argc > 1 ) filename = std::string( argv[1] );
Core mb;
ErrorCode rval = mb.load_file( filename.c_str() );CHECK_ERR( rval );
Range elems;
rval = mb.get_entities_by_dimension( 0, 3, elems );CHECK_ERR( rval );
if( elems.empty() )
rval = mb.get_entities_by_dimension( 0, 2, elems );CHECK_ERR( rval );
if( elems.empty() )
std::cout << "Mesh must have faces or regions for this test." << std::endl;CHECK_ERR( MB_FAILURE );
// get the vertex positions and set on an intermediate tag, to test smoothing for
// a tag instead of for coords
Tag ctag;
rval = mb.tag_get_handle( "vcentroid", 3, MB_TYPE_DOUBLE, ctag, MB_TAG_CREAT | MB_TAG_DENSE );CHECK_ERR( rval );
Range verts;
rval = mb.get_entities_by_dimension( 0, 0, verts );CHECK_ERR( rval );
std::vector< double > coords( 3 * verts.size() );
rval = mb.get_coords( verts, &coords[0] );CHECK_ERR( rval );
rval = mb.tag_set_data( ctag, verts, &coords[0] );CHECK_ERR( rval );
LloydSmoother ll( &mb, NULL, elems, ctag );
ll.report_its( 10 );
rval = ll.perform_smooth();CHECK_ERR( rval );
std::cout << "Mesh smoothed in " << ll.num_its() << " iterations." << std::endl;
// now, set vertex coords to almost their converged positions, then re-smooth; should take fewer
// iterations
std::vector< double > new_coords( 3 * verts.size() );
rval = mb.tag_get_data( ctag, verts, &new_coords[0] );CHECK_ERR( rval );
unsigned int i;
Range::iterator vit;
for( vit = verts.begin(), i = 0; vit != verts.end(); ++vit, i += 3 )
CartVect old_pos( &coords[i] ), new_pos( &new_coords[i] );
CartVect almost_pos = old_pos + .99 * ( new_pos - old_pos );
almost_pos.get( &new_coords[i] );
rval = mb.set_coords( verts, &new_coords[0] );CHECK_ERR( rval );
LloydSmoother ll2( &mb, NULL, elems );
ll2.report_its( 10 );
rval = ll2.perform_smooth();CHECK_ERR( rval );
std::cout << "Mesh smoothed in " << ll2.num_its() << " iterations." << std::endl;
| std::string filename = "unittest/surfrandomtris-4part.h5m" |
Definition at line 6 of file lloyd_smoother_test.cpp.
