MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "moab/Core.hpp" 00002 #include "moab/LloydSmoother.hpp" 00003 #include "moab/CartVect.hpp" 00004 #include "TestUtil.hpp" 00005 00006 std::string filename = TestDir + "unittest/surfrandomtris-4part.h5m"; 00007 00008 using namespace moab; 00009 00010 int main( int argc, char** argv ) 00011 { 00012 if( argc > 1 ) filename = std::string( argv[1] ); 00013 Core mb; 00014 ErrorCode rval = mb.load_file( filename.c_str() );CHECK_ERR( rval ); 00015 00016 Range elems; 00017 rval = mb.get_entities_by_dimension( 0, 3, elems );CHECK_ERR( rval ); 00018 if( elems.empty() ) 00019 { 00020 rval = mb.get_entities_by_dimension( 0, 2, elems );CHECK_ERR( rval ); 00021 } 00022 if( elems.empty() ) 00023 { 00024 std::cout << "Mesh must have faces or regions for this test." << std::endl;CHECK_ERR( MB_FAILURE ); 00025 } 00026 00027 // get the vertex positions and set on an intermediate tag, to test smoothing for 00028 // a tag instead of for coords 00029 Tag ctag; 00030 rval = mb.tag_get_handle( "vcentroid", 3, MB_TYPE_DOUBLE, ctag, MB_TAG_CREAT | MB_TAG_DENSE );CHECK_ERR( rval ); 00031 Range verts; 00032 rval = mb.get_entities_by_dimension( 0, 0, verts );CHECK_ERR( rval ); 00033 std::vector< double > coords( 3 * verts.size() ); 00034 rval = mb.get_coords( verts, &coords[0] );CHECK_ERR( rval ); 00035 rval = mb.tag_set_data( ctag, verts, &coords[0] );CHECK_ERR( rval ); 00036 00037 LloydSmoother ll( &mb, NULL, elems, ctag ); 00038 ll.report_its( 10 ); 00039 rval = ll.perform_smooth();CHECK_ERR( rval ); 00040 std::cout << "Mesh smoothed in " << ll.num_its() << " iterations." << std::endl; 00041 00042 // now, set vertex coords to almost their converged positions, then re-smooth; should take fewer 00043 // iterations 00044 std::vector< double > new_coords( 3 * verts.size() ); 00045 rval = mb.tag_get_data( ctag, verts, &new_coords[0] );CHECK_ERR( rval ); 00046 unsigned int i; 00047 Range::iterator vit; 00048 for( vit = verts.begin(), i = 0; vit != verts.end(); ++vit, i += 3 ) 00049 { 00050 CartVect old_pos( &coords[i] ), new_pos( &new_coords[i] ); 00051 CartVect almost_pos = old_pos + .99 * ( new_pos - old_pos ); 00052 almost_pos.get( &new_coords[i] ); 00053 } 00054 rval = mb.set_coords( verts, &new_coords[0] );CHECK_ERR( rval ); 00055 00056 LloydSmoother ll2( &mb, NULL, elems ); 00057 ll2.report_its( 10 ); 00058 rval = ll2.perform_smooth();CHECK_ERR( rval ); 00059 std::cout << "Mesh smoothed in " << ll2.num_its() << " iterations." << std::endl; 00060 }
