cub2h5m.cpp File Reference
#include "moab/GeomQueryTool.hpp"
#include "moab/GeomTopoTool.hpp"
#include "InitCGMA.hpp"
#include "CGMApp.hpp"
#include "moab/CN.hpp"
#include "moab/Core.hpp"
#include "moab/CartVect.hpp"
#include "moab/FileOptions.hpp"
#include "moab/Skinner.hpp"
#include "quads_to_tris.hpp"
#include <limits>
#include <cstdlib>
#include <sstream>
#include <ctime>
+ Include dependency graph for cub2h5m.cpp:
Defines
#define GF_CUBIT_FILE_TYPE   "CUBIT"
#define GF_STEP_FILE_TYPE   "STEP"
#define GF_IGES_FILE_TYPE   "IGES"
#define GF_ACIS_TXT_FILE_TYPE   "ACIS_SAT"
#define GF_ACIS_BIN_FILE_TYPE   "ACIS_SAB"
#define GF_OCC_BREP_FILE_TYPE   "OCC"
Functions
void tokenize (const std::string &str, std::vector< std::string > &tokens, const char *delimiters)
ErrorCode get_group_names (Interface *MBI, const EntityHandle group_set, const Tag nameTag, std::vector< std::string > &grp_names)
ErrorCode summarize_cell_volume_change (Interface *MBI, const EntityHandle cgm_file_set, const Tag categoryTag, const Tag dimTag, const Tag sizeTag, const Tag nameTag, const Tag idTag, const bool conserve_mass, const bool debug)
ErrorCode remove_empty_cgm_surfs_and_vols (Interface *MBI, const EntityHandle cgm_file_set, const Tag idTag, const Tag dimTag, const bool)
ErrorCode build_new_surface (Interface *MBI, EntityHandle &new_surf, const EntityHandle forward_parent_vol, const EntityHandle reverse_parent_vol, const int new_surf_id, const Tag dimTag, const Tag idTag, const Tag categoryTag, const Tag senseTag)
ErrorCode orient_faces_outward (Interface *MBI, const Range &faces, const bool)
void plot_histogram (const std::string &title, const std::string &x_axis_label, const std::string &y_axis_label, const int n_bins, const double data[], const int n_data)
void generate_plots (const double orig[], const double defo[], const int n_elems, const std::string &time_step)
static double tet_volume (const CartVect &v0, const CartVect &v1, const CartVect &v2, const CartVect &v3)
double measure (Interface *MBI, const EntityHandle element)
ErrorCode get_signed_volume (Interface *MBI, const EntityHandle surf_set, const CartVect &offset, double &signed_volume)
ErrorCode fix_surface_senses (Interface *MBI, const EntityHandle cgm_file_set, const EntityHandle cub_file_set, const Tag idTag, const Tag dimTag, const Tag senseTag, const bool debug)
ErrorCode replace_faceted_cgm_surfs (Interface *MBI, const EntityHandle cgm_file_set, const EntityHandle cub_file_set, const Tag idTag, const Tag dimTag, const bool debug)
ErrorCode add_dead_elems_to_impl_compl (Interface *MBI, const EntityHandle cgm_file_set, const EntityHandle cub_file_set, const Tag idTag, const Tag dimTag, const Tag categoryTag, const Tag senseTag, const bool debug)
const char * get_geom_file_type (const char *filename)
const char * get_geom_fptr_type (FILE *file)
int is_cubit_file (FILE *file)
int is_step_file (FILE *file)
int is_iges_file (FILE *file)
int is_acis_txt_file (FILE *file)
int is_acis_bin_file (FILE *file)
int is_occ_brep_file (FILE *file)
int main (int argc, char *argv[])
Variables
double DEFAULT_DISTANCE = 0.001
double DEFAULT_LEN = 0.0
int DEFAULT_NORM = 5
Define Documentation
Definition at line 20 of file cub2h5m.cpp.
Referenced by get_geom_fptr_type().
Definition at line 19 of file cub2h5m.cpp.
Definition at line 16 of file cub2h5m.cpp.
Definition at line 18 of file cub2h5m.cpp.
Definition at line 21 of file cub2h5m.cpp.
Definition at line 17 of file cub2h5m.cpp.
Function Documentation
ErrorCode add_dead_elems_to_impl_compl ( Interface *  MBI,
const Tag  idTag,
const Tag  dimTag,
const Tag  senseTag,
const bool  debug
Definition at line 860 of file cub2h5m.cpp.
References moab::Interface::add_entities(), moab::Range::begin(), build_new_surface(), moab::Range::empty(), moab::Range::end(), ErrorCode, moab::Skinner::find_skin(), moab::Range::front(), moab::Interface::get_child_meshsets(), moab::Interface::get_entities_by_type(), moab::Interface::get_entities_by_type_and_tag(), idTag, moab::intersect(), MB_INVALID_SIZE, MB_SUCCESS, MBENTITYSET, MBHEX, MBQUAD, orient_faces_outward(), moab::Interface::remove_entities(), moab::Range::size(), moab::subtract(), and moab::Interface::tag_get_data().
Referenced by main().
    // Get the cgm surfaces
    ErrorCode result;
    const int two               = 2;
    const void* const two_val[] = { &two };
    Range cgm_surfs;
    result = MBI->get_entities_by_type_and_tag( cgm_file_set, MBENTITYSET, &dimTag, two_val, 1, cgm_surfs );
    if( MB_SUCCESS != result ) return result;
    // Get the maximum surface id. This is so that new surfaces do not have
    // duplicate ids.
    int max_surf_id = -1;
    for( Range::const_iterator i = cgm_surfs.begin(); i != cgm_surfs.end(); ++i )
        int surf_id;
        result = MBI->tag_get_data( idTag, &( *i ), 1, &surf_id );
        if( max_surf_id < surf_id ) max_surf_id = surf_id;
    std::cout << "  Maximum surface id=" << max_surf_id << std::endl;
    // For each cgm volume, does a cub volume with the same id exist?
    const int three               = 3;
    const void* const three_val[] = { &three };
    Range cgm_vols;
    result = MBI->get_entities_by_type_and_tag( cgm_file_set, MBENTITYSET, &dimTag, three_val, 1, cgm_vols );
    // get the corresponding cub volume
    for( Range::iterator i = cgm_vols.begin(); i != cgm_vols.end(); ++i )
        int vol_id;
        result = MBI->tag_get_data( idTag, &( *i ), 1, &vol_id );
        assert( MB_SUCCESS == result );
        std::cout << "  Volume " << vol_id;
        // Find the meshed vol set with the same id
        Range cub_vol;
        const Tag tags[]             = { idTag, dimTag };
        const void* const tag_vals[] = { &vol_id, &three };
        result = MBI->get_entities_by_type_and_tag( cub_file_set, MBENTITYSET, tags, tag_vals, 2, cub_vol );
        if( 1 != cub_vol.size() )
            std::cout << ": no meshed representation found" << std::endl;
            continue;
        else
            std::cout << std::endl;
        // get the mesh elements of the volume.
        Range elems;
        result = MBI->get_entities_by_type( cub_vol.front(), MBHEX, elems );
        if( debug ) std::cout << "    found " << elems.size() << " hex elems" << std::endl;
        // skin the volumes
        Skinner tool( MBI );
        Range skin_faces;
        result = tool.find_skin( 0, elems, 2, skin_faces, true );
        // Reconcile the difference between faces of the cub file surfaces and skin
        // faces of the 3D mesh. The difference exists because dead elements have been
        // removed. Faces are divided into:
        //   cub_faces    (in) - the faces in the cub file surface
        //   skin_faces   (in) - the faces of the 3D mesh elements
        //   common_faces (out)- the faces common to both the cub file surface and 3D mesh
        //                       they are still adjacent to this volume
        //   old_faces    (out)- the faces of the cub surface not on the 3D mesh skin
        //                       they are no longer adjacent to this vol
        //   new_faces    (out)- the faces of the 3D mesh skin not on the cub surface
        //                       they are now adjacent to this volume
        // get cub child surfaces.
        Range cub_surfs;
        result = MBI->get_child_meshsets( cub_vol.front(), cub_surfs );
        for( Range::iterator j = cub_surfs.begin(); j != cub_surfs.end(); ++j )
            int surf_id;
            result = MBI->tag_get_data( idTag, &( *j ), 1, &surf_id );
            // get the quads on each surface
            Range cub_faces;
            result = MBI->get_entities_by_type( *j, MBQUAD, cub_faces );
            // Meshed volumes must have meshed surfaces
            if( cub_faces.empty() )
                std::cout << "    Surface " << surf_id << ": contains no meshed faces" << std::endl;
                // return MB_ENTITY_NOT_FOUND;
            // get the faces common to both the skin and this surface
            Range common_faces = intersect( cub_faces, skin_faces );
            // find the surface faces not on the skin - these are old and need removed
            Range old_faces = subtract( cub_faces, common_faces );
            result          = MBI->remove_entities( *j, old_faces );
            // remove the common faces from the skin faces
            skin_faces = subtract( skin_faces, common_faces );
            // If no old faces exist we are done
            if( old_faces.empty() ) continue;
            std::cout << "    Surface " << surf_id << ": " << old_faces.size() << " old faces removed" << std::endl;
            // Place the old faces in a new surface, because they may still be adjacent
            // to 3D mesh in another volume. Get the parent vols of the surface.
            Range cgm_surf;
            const Tag tags2[]             = { idTag, dimTag };
            const void* const tag_vals2[] = { &surf_id, &two };
            result = MBI->get_entities_by_type_and_tag( cgm_file_set, MBENTITYSET, tags2, tag_vals2, 2, cgm_surf );
            if( 1 != cgm_surf.size() )
                std::cout << "invalid size" << std::endl;
                return MB_INVALID_SIZE;
            EntityHandle cgm_vols2[2], cub_vols[2];
            result = MBI->tag_get_data( senseTag, cgm_surf, &cgm_vols2 );
            result = MBI->tag_get_data( senseTag, &( *j ), 1, &cub_vols );
            // for the new surf, replace the current volume with the impl compl vol.
            // This is because the faces that no longer exist will become adjacent to
            // the impl compl
            if( *i == cgm_vols2[0] )
                cgm_vols2[0] = 0;
                cub_vols[0]  = 0;
            if( *i == cgm_vols2[1] )
                cgm_vols2[1] = 0;
                cub_vols[1]  = 0;
            // If both sides of the surface are the impl comp, do not create the surface.
            if( 0 == cgm_vols2[0] && 0 == cgm_vols2[1] )
                std::cout << "    New surface was not created for old faces because both parents "
                             "are impl_compl volume "
                          << std::endl;
                continue;
            // build the new surface.
            EntityHandle new_cgm_surf, new_cub_surf;
            ++max_surf_id;
            result = build_new_surface( MBI, new_cgm_surf, cgm_vols2[0], cgm_vols2[1], max_surf_id, dimTag, idTag,
                                        categoryTag, senseTag );
            result = build_new_surface( MBI, new_cub_surf, cub_vols[0], cub_vols[1], max_surf_id, dimTag, idTag,
            // add the new surface to the file set and populate it with the old faces
            result = MBI->add_entities( cgm_file_set, &new_cgm_surf, 1 );
            result = MBI->add_entities( cub_file_set, &new_cub_surf, 1 );
            result = MBI->add_entities( new_cub_surf, old_faces );
            std::cout << "    Surface " << max_surf_id << ": created for " << old_faces.size() << " old faces"
                      << std::endl;
        // the remaining skin faces are newly exposed faces
        Range new_faces = skin_faces;
        // new skin faces must be assigned to a surface
        if( new_faces.empty() ) continue;
        std::cout << "    Surface " << max_surf_id + 1 << ": created for " << new_faces.size() << " new faces"
                  << std::endl;
        // Ensure that faces are oriented outwards
        result = orient_faces_outward( MBI, new_faces, debug );
        // Create the new surface.
        ++max_surf_id;
        result = build_new_surface( MBI, new_cgm_surf, *i, 0, max_surf_id, dimTag, idTag, categoryTag, senseTag );
        result = build_new_surface( MBI, new_cub_surf, cub_vol.front(), 0, max_surf_id, dimTag, idTag, categoryTag,
                                    senseTag );
        // Insert the new surf into file sets and populate it with faces.
        result = MBI->add_entities( new_cub_surf, new_faces );
    return MB_SUCCESS;
ErrorCode build_new_surface ( Interface *  MBI,
EntityHandle &  new_surf,
const Tag  dimTag,
const Tag  idTag,
const Tag  senseTag
Definition at line 300 of file cub2h5m.cpp.
References moab::Interface::add_parent_child(), CATEGORY_TAG_SIZE, moab::Interface::create_meshset(), ErrorCode, moab::geom_category, MB_SUCCESS, and moab::Interface::tag_set_data().
Referenced by add_dead_elems_to_impl_compl().
    ErrorCode result;
    result = MBI->create_meshset( 0, new_surf );
    if( 0 != forward_parent_vol )
        result = MBI->add_parent_child( forward_parent_vol, new_surf );
    if( 0 != reverse_parent_vol )
        result = MBI->add_parent_child( reverse_parent_vol, new_surf );
    const int two = 2;
    result        = MBI->tag_set_data( dimTag, &new_surf, 1, &two );
    result = MBI->tag_set_data( idTag, &new_surf, 1, &new_surf_id );
    const char geom_category[CATEGORY_TAG_SIZE] = { "Surface\0" };
    result                                      = MBI->tag_set_data( categoryTag, &new_surf, 1, &geom_category );
    EntityHandle vols[2] = { forward_parent_vol, reverse_parent_vol };
    result               = MBI->tag_set_data( senseTag, &new_surf, 1, vols );
    return MB_SUCCESS;
ErrorCode fix_surface_senses ( Interface *  MBI,
const Tag  idTag,
const Tag  dimTag,
const Tag  senseTag,
const bool  debug
Definition at line 694 of file cub2h5m.cpp.
References moab::Interface::add_entities(), moab::Range::begin(), moab::Range::end(), ErrorCode, moab::Range::front(), moab::Interface::get_entities_by_type(), moab::Interface::get_entities_by_type_and_tag(), get_signed_volume(), idTag, make_tris_from_quads(), MB_SUCCESS, MBENTITYSET, MBQUAD, moab::Range::size(), moab::Interface::tag_get_data(), and moab::Interface::tag_set_data().
    ErrorCode result;
    const int two               = 2;
    Range cgm_surfs;
    for( Range::iterator i = cgm_surfs.begin(); i != cgm_surfs.end(); ++i )
        int surf_id;
        // Find the meshed surface set with the same id
        Range cub_surf;
        const void* const tag_vals[] = { &surf_id, &two };
        result = MBI->get_entities_by_type_and_tag( cub_file_set, MBENTITYSET, tags, tag_vals, 2, cub_surf );
        if( 1 != cub_surf.size() )
            std::cout << "  Surface " << surf_id << ": no meshed representation found, using CAD representation instead"
                      << std::endl;
            continue;
        // Get tris that represent the quads of the cub surf
        Range quads;
        result = MBI->get_entities_by_type( cub_surf.front(), MBQUAD, quads );
        Range cub_tris;
        result = make_tris_from_quads( MBI, quads, cub_tris );
        // Add the tris to the same surface meshset as the quads are inside.
        result = MBI->add_entities( cub_surf.front(), cub_tris );
        // get the signed volume for each surface representation. Keep trying until
        // The signed volumes are much greater than numerical precision. Planar
        // surfaces will have a signed volume of zero if the plane goes through the
        // origin, unless we apply an offset.
        const int n_attempts        = 100;
        const int max_random        = 10;
        const double min_signed_vol = 0.1;
        double cgm_signed_vol, cub_signed_vol;
        for( int j = 0; j < n_attempts; ++j )
            cgm_signed_vol = 0;
            cub_signed_vol = 0;
            CartVect offset( std::rand() % max_random, std::rand() % max_random, std::rand() % max_random );
            result = get_signed_volume( MBI, *i, offset, cgm_signed_vol );
            result = get_signed_volume( MBI, cub_surf.front(), offset, cub_signed_vol );
            if( debug )
                std::cout << "  surf_id=" << surf_id << " cgm_signed_vol=" << cgm_signed_vol
                          << " cub_signed_vol=" << cub_signed_vol << std::endl;
            if( fabs( cgm_signed_vol ) > min_signed_vol && fabs( cub_signed_vol ) > min_signed_vol ) break;
            if( n_attempts == j + 1 )
                std::cout << "error: signed volume could not be calculated unambiguously" << std::endl;
                return MB_FAILURE;
        // If the sign is different, reverse the cgm senses so that both
        // representations have the same signed volume.
        if( ( cgm_signed_vol < 0 && cub_signed_vol > 0 ) || ( cgm_signed_vol > 0 && cub_signed_vol < 0 ) )
            EntityHandle cgm_surf_volumes[2], reversed_cgm_surf_volumes[2];
            result = MBI->tag_get_data( senseTag, &( *i ), 1, cgm_surf_volumes );
            reversed_cgm_surf_volumes[0] = cgm_surf_volumes[1];
            reversed_cgm_surf_volumes[1] = cgm_surf_volumes[0];
            result = MBI->tag_set_data( senseTag, &( *i ), 1, reversed_cgm_surf_volumes );
    return MB_SUCCESS;
void generate_plots ( const double  orig[],
const int  n_elems,
const std::string &  time_step
Definition at line 570 of file cub2h5m.cpp.
References plot_histogram().
    // find volume ratio then max and min
    double* ratio = new double[n_elems];
    for( int i = 0; i < n_elems; ++i )
        ratio[i] = ( defo[i] - orig[i] ) / orig[i];
    plot_histogram( "Predeformed Element Volume", "Num_Elems", "Volume [cc]", 10, orig, n_elems );
    std::string title = "Element Volume Change Ratio at Time Step " + time_step;
    plot_histogram( title, "Num_Elems", "Volume Ratio", 10, ratio, n_elems );
    delete[] ratio;
const char * get_geom_file_type ( const char *  filename)
Definition at line 1440 of file cub2h5m.cpp.
References get_geom_fptr_type().
    FILE* file;
    const char* result = 0;
    file = fopen( name, "r" );
    if( file )
        result = get_geom_fptr_type( file );
        fclose( file );
    return result;
const char * get_geom_fptr_type ( FILE *  file)
Definition at line 1455 of file cub2h5m.cpp.
References GF_ACIS_BIN_FILE_TYPE, GF_ACIS_TXT_FILE_TYPE, GF_CUBIT_FILE_TYPE, GF_IGES_FILE_TYPE, GF_OCC_BREP_FILE_TYPE, GF_STEP_FILE_TYPE, is_acis_bin_file(), is_acis_txt_file(), is_cubit_file(), is_iges_file(), is_occ_brep_file(), and is_step_file().
Referenced by get_geom_file_type().
    static const char* CUBIT_NAME = GF_CUBIT_FILE_TYPE;
    static const char* STEP_NAME  = GF_STEP_FILE_TYPE;
    static const char* IGES_NAME  = GF_IGES_FILE_TYPE;
    static const char* SAT_NAME   = GF_ACIS_TXT_FILE_TYPE;
    static const char* SAB_NAME   = GF_ACIS_BIN_FILE_TYPE;
    static const char* BREP_NAME  = GF_OCC_BREP_FILE_TYPE;
    if( is_cubit_file( file ) )
        return CUBIT_NAME;
    else if( is_step_file( file ) )
        return STEP_NAME;
    else if( is_iges_file( file ) )
        return IGES_NAME;
    else if( is_acis_bin_file( file ) )
        return SAB_NAME;
    else if( is_acis_txt_file( file ) )
        return SAT_NAME;
    else if( is_occ_brep_file( file ) )
        return BREP_NAME;
    else
        return 0;
ErrorCode get_group_names ( Interface *  MBI,
const Tag  nameTag,
std::vector< std::string > &  grp_names
Definition at line 41 of file cub2h5m.cpp.
References ErrorCode, MB_SUCCESS, MB_TAG_NOT_FOUND, NAME_TAG_SIZE, and moab::Interface::tag_get_data().
Referenced by summarize_cell_volume_change().
    // get names
    char name0[NAME_TAG_SIZE];
    std::fill( name0, name0 + NAME_TAG_SIZE, '\0' );
    ErrorCode result = MBI->tag_get_data( nameTag, &group_set, 1, &name0 );
    if( MB_SUCCESS != result && MB_TAG_NOT_FOUND != result ) return MB_FAILURE;
    if( MB_TAG_NOT_FOUND != result ) grp_names.push_back( std::string( name0 ) );
    return MB_SUCCESS;
ErrorCode get_signed_volume ( Interface *  MBI,
const CartVect &  offset,
double &  signed_volume
Definition at line 653 of file cub2h5m.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::Interface::get_entities_by_type(), MB_INVALID_SIZE, MB_SUCCESS, and MBTRI.
Referenced by fix_surface_senses().
    ErrorCode rval;
    Range tris;
    rval = MBI->get_entities_by_type( surf_set, MBTRI, tris );
    if( MB_SUCCESS != rval ) return rval;
    signed_volume = 0.0;
    const EntityHandle* conn;
    int len;
    CartVect coords[3];
    for( Range::iterator j = tris.begin(); j != tris.end(); ++j )
        rval = MBI->get_connectivity( *j, conn, len, true );
        if( 3 != len ) return MB_INVALID_SIZE;
        rval = MBI->get_coords( conn, 3, coords[0].array() );
        // Apply offset to avoid calculating 0 for cases when the origin is in the
        // plane of the surface.
        for( unsigned int k = 0; k < 3; ++k )
            coords[k][0] += offset[0];
            coords[k][1] += offset[1];
            coords[k][2] += offset[2];
        coords[1] -= coords[0];
        coords[2] -= coords[0];
        signed_volume += ( coords[0] % ( coords[1] * coords[2] ) );
    return MB_SUCCESS;
int is_acis_bin_file ( FILE *  file)
Definition at line 1498 of file cub2h5m.cpp.
References buffer.
    char buffer[15];
    return !fseek( file, 0, SEEK_SET ) && fread( buffer, 15, 1, file ) && !memcmp( buffer, "ACIS BinaryFile", 9 );
int is_acis_txt_file ( FILE *  file)
Definition at line 1504 of file cub2h5m.cpp.
References buffer, and length().
    char buffer[5];
    int version, length;
    if( fseek( file, 0, SEEK_SET ) || 2 != fscanf( file, "%d %*d %*d %*d %d ", &version, &length ) ) return 0;
    if( version < 1 || version > 0xFFFF ) return 0;
    // Skip application name
    if( fseek( file, length, SEEK_CUR ) ) return 0;
    // Read length of version string followed by first 5 characters
    if( 2 != fscanf( file, "%d %4s", &length, buffer ) ) return 0;
    return !strcmp( buffer, "ACIS" );
int is_cubit_file ( FILE *  file)
Definition at line 1480 of file cub2h5m.cpp.
References buffer.
    unsigned char buffer[4];
    return !fseek( file, 0, SEEK_SET ) && fread( buffer, 4, 1, file ) && !memcmp( buffer, "CUBE", 4 );
int is_iges_file ( FILE *  file)
Definition at line 1492 of file cub2h5m.cpp.
References buffer.
    unsigned char buffer[10];
    return !fseek( file, 72, SEEK_SET ) && fread( buffer, 10, 1, file ) && !memcmp( buffer, "S      1\r\n", 10 );
int is_occ_brep_file ( FILE *  file)
Definition at line 1522 of file cub2h5m.cpp.
References buffer.
    unsigned char buffer[6];
    return !fseek( file, 0, SEEK_SET ) && fread( buffer, 6, 1, file ) && !memcmp( buffer, "DBRep_", 6 );
int is_step_file ( FILE *  file)
Definition at line 1486 of file cub2h5m.cpp.
References buffer.
    unsigned char buffer[9];
    return !fseek( file, 0, SEEK_SET ) && fread( buffer, 9, 1, file ) && !memcmp( buffer, "ISO-10303", 9 );
int main ( int  argc,
char *  argv[]
Definition at line 1129 of file cub2h5m.cpp.
References add_dead_elems_to_impl_compl(), moab::Range::begin(), CATEGORY_TAG_NAME, CATEGORY_TAG_SIZE, moab::Core::create_meshset(), moab::debug, moab::Range::end(), ErrorCode, fix_surface_senses(), generate_plots(), GEOM_DIMENSION_TAG_NAME, moab::Core::get_entities_by_dimension(), moab::Core::get_entities_by_type_and_tag(), get_geom_file_type(), moab::Core::get_last_error(), moab::Core::globalId_tag(), idTag, moab::Core::load_file(), MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TAG_SPARSE, MB_TYPE_DOUBLE, MB_TYPE_HANDLE, MB_TYPE_INTEGER, MB_TYPE_OPAQUE, MBENTITYSET, moab::measure(), moab::GeomQueryTool::measure_volume(), MESHSET_TRACK_OWNER, NAME_TAG_NAME, NAME_TAG_SIZE, nameTag, remove_empty_cgm_surfs_and_vols(), replace_faceted_cgm_surfs(), moab::Core::set_meshset_options(), size, moab::Range::size(), start_time, summarize_cell_volume_change(), moab::Core::tag_get_handle(), moab::Core::tag_set_data(), and moab::Core::write_mesh().
    clock_t start_time = clock();
    const bool debug      = false;
    const char* file_type = NULL;
    const char* cub_name  = 0;
    const char* exo_name  = 0;
    const char* out_name  = 0;
    const char* time_step = 0;
    const char* sat_name  = 0;
    double dist_tol = 0.001, len_tol = 0.0;
    int norm_tol = 5;
    if( 6 != argc && 9 != argc )
        std::cerr << "To read meshed geometry for MOAB:" << std::endl;
        std::cerr << "$> <cub_file.cub> <acis_file.sat> <facet_tol> <output_file.h5m> conserve_mass<bool>" << std::endl;
        std::cerr << "To read meshed geometry for MOAB and update node coordinates:" << std::endl;
        std::cerr << "$> <cub_file.cub> <acis_file.sat> <facet_tol> <output_file.h5m> "
                     "<deformed_exo_file.e> time_step<int> check_vol_change<bool> conserve_mass<bool>"
                  << std::endl;
        exit( 4 );
    // check filenames for proper suffix
    std::string temp;
    cub_name = argv[1];
    temp.assign( cub_name );
    if( std::string::npos == temp.find( ".cub" ) )
        std::cerr << "cub_file does not have correct suffix" << std::endl;
        return 1;
    sat_name = argv[2];  // needed because the cub file's embedded sat file does not have groups
    temp.assign( sat_name );
    if( std::string::npos == temp.find( ".sat" ) )
        std::cerr << "sat_file does not have correct suffix" << std::endl;
        return 1;
    out_name = argv[4];
    temp.assign( out_name );
    if( std::string::npos == temp.find( ".h5m" ) )
        std::cerr << "out_file does not have correct suffix" << std::endl;
        return 1;
    // get the facet tolerance
    dist_tol = atof( argv[3] );
    if( 0 > dist_tol || 1 < dist_tol )
        std::cout << "error: facet_tolerance=" << dist_tol << std::endl;
        return 1;
    // Should the nodes be updated?
    bool update_coords = false;
    if( 9 == argc )
        exo_name = argv[5];
        temp.assign( exo_name );
        if( std::string::npos == temp.find( ".e" ) )
            std::cerr << "e_file does not have correct suffix" << std::endl;
            return 1;
        time_step     = argv[6];
        update_coords = true;
    // Should the volume change be determined?
    bool determine_volume_change = false;
    if( 9 == argc )
        temp.assign( argv[7] );
        if( std::string::npos != temp.find( "true" ) ) determine_volume_change = true;
    // Should densities be changed to conserve mass?
    bool conserve_mass = false;
    if( 9 == argc )
        temp.assign( argv[8] );
        if( std::string::npos != temp.find( "true" ) ) conserve_mass = true;
    else if( 6 == argc )
        temp.assign( argv[5] );
    // Get CGM file type
    if( !file_type )
        file_type = get_geom_file_type( cub_name );
        if( !file_type )
            std::cerr << cub_name << " : unknown file type, try '-t'" << std::endl;
            exit( 1 );
    // Read the mesh from the cub file with Tqcdfr
    Core* MBI = new Core();
    ErrorCode result;
    EntityHandle cub_file_set;
    result = MBI->create_meshset( 0, cub_file_set );
    // Do not ignore the Cubit file version. In testing, a cub file from Cubit12
    // did not work.
    // char cub_options[256] = "120";
    // char cub_options[256] = "IGNORE_VERSION";
    // result = MBI->load_file(cub_name, &cub_file_set, cub_options, NULL, 0, 0);
    result = MBI->load_file( cub_name, &cub_file_set, 0, NULL, 0, 0 );
        std::cout << "error: problem reading cub file" << std::endl;
        return result;
    std::cout << "Mesh file read." << std::endl;
    // Read the ACIS file with ReadCGM
    char cgm_options[256];
    std::cout << "  facet tolerance=" << dist_tol << std::endl;
    sprintf( cgm_options,
             "CGM_ATTRIBS=yes;FACET_DISTANCE_TOLERANCE=%g;FACET_NORMAL_TOLERANCE=%d;MAX_FACET_EDGE_"
             "LENGTH=%g;",
             dist_tol, norm_tol, len_tol );
    EntityHandle cgm_file_set;
    result = MBI->create_meshset( 0, cgm_file_set );
    result = MBI->load_file( sat_name, &cgm_file_set, cgm_options, NULL, 0, 0 );
        std::cout << "error: problem reading sat file" << std::endl;
        return result;
    std::cout << "CAD file read." << std::endl;
    // Create tags
    Tag dimTag, idTag, categoryTag, senseTag, sizeTag, nameTag;
    result = MBI->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, dimTag, MB_TAG_SPARSE | MB_TAG_CREAT );
    idTag  = MBI->globalId_tag();
    result = MBI->tag_get_handle( CATEGORY_TAG_NAME, CATEGORY_TAG_SIZE, MB_TYPE_OPAQUE, categoryTag,
    result = MBI->tag_get_handle( "GEOM_SENSE_2", 2, MB_TYPE_HANDLE, senseTag, MB_TAG_SPARSE | MB_TAG_CREAT );
    result = MBI->tag_get_handle( "GEOM_SIZE", 1, MB_TYPE_DOUBLE, sizeTag, MB_TAG_DENSE | MB_TAG_CREAT );
    result = MBI->tag_get_handle( NAME_TAG_NAME, NAME_TAG_SIZE, MB_TYPE_OPAQUE, nameTag, MB_TAG_SPARSE | MB_TAG_CREAT );
    // Create triangles from the quads of the cub surface sets and add them to the
    // cub surface sets. Get the signed volume of each surface for both cgm and
    // cub representations. Change the sense of the cgm representation to match
    // the cub representation.
    result = fix_surface_senses( MBI, cgm_file_set, cub_file_set, idTag, dimTag, senseTag, debug );
    std::cout << "Fixed CAD surface senses to match meshed surface senses." << std::endl;
    // Get the 3D elements in the cub file and measure their volume.
    Range orig_elems;
    std::vector< double > orig_size;
    if( determine_volume_change )
        result = MBI->get_entities_by_dimension( 0, 3, orig_elems );
        orig_size.resize( orig_elems.size() );
        for( unsigned int i = 0; i < orig_elems.size(); ++i )
            orig_size[i] = measure( MBI, orig_elems[i] );
    // Before updating the nodes and removing dead elements, force the cub volume
    // sets to track ownership so that dead elements will be deleted from the sets.
    Range cub_vols;
    result = MBI->get_entities_by_type_and_tag( cub_file_set, MBENTITYSET, &dimTag, three_val, 1, cub_vols );
    for( Range::const_iterator i = cub_vols.begin(); i != cub_vols.end(); ++i )
        result = MBI->set_meshset_options( *i, MESHSET_TRACK_OWNER );
    // Tag volume sets with the undeformed size of each volume.
    Range vol_sets;
    result = MBI->get_entities_by_type_and_tag( cgm_file_set, MBENTITYSET, &dimTag, three_val, 1, vol_sets );
    moab::GeomTopoTool gtt  = moab::GeomTopoTool( MBI, false );
    moab::GeomQueryTool gqt = moab::GeomQueryTool( &gtt );
    for( Range::const_iterator i = vol_sets.begin(); i != vol_sets.end(); ++i )
        double size;
        result = gqt.measure_volume( *i, size );
        result = MBI->tag_set_data( sizeTag, &( *i ), 1, &size );
    // Update the coordinates if needed. Do not do this before checking surface
    // sense, because the coordinate update could deform the surfaces too much
    // to make an accurate comparison.
    // The cub node ids are unique because cgm vertex ids are tagged on the vertex
    // meshset and not the vertex itself.
    // result = MBI->delete_entities( &cub_file_set, 1 );
    // if(MB_SUCCESS != result) return result;
    // Assume dead elements exist until I think of something better.
    bool dead_elements_exist = true;
    if( update_coords )
        // ReadNCDF my_ex_reader(MBI);
        char exo_options[120] = "tdata=coord,";
        strcat( exo_options, time_step );
        strcat( exo_options, ",set" );
        // FileOptions exo_opts(exo_options)  ;
        // opts = "tdata=coord, 100, sum, temp.exo";
        // result =  my_ex_reader.load_file(exo_name, cgm_file_set, exo_opts, NULL, 0 , 0);
        // result =  my_ex_reader.load_file(exo_name, cub_file_set, exo_opts, NULL, 0 , 0);
        // result = my_ex_reader.load_file(exo_name, &cub_file_set, exo_opts, NULL, 0 , 0);
        MBI->load_file( exo_name, &cub_file_set, exo_options );
            std::string last_error;
            MBI->get_last_error( last_error );
            std::cout << "coordinate update failed, " << last_error << std::endl;
            return result;
        std::cout << "Updated mesh nodes with deformed coordinates from exodus file." << std::endl;
        // Dead elements have been removed by the deformation. Get the elements that
        // still exist.
        Range defo_elems;
        result = MBI->get_entities_by_dimension( 0, 3, defo_elems );
        // Determine the volume of the elements now that a deformation has been
        // applied. Condense the original array by removing dead elements.
        double* orig_size_condensed = new double[defo_elems.size()];
        double* defo_size_condensed = new double[defo_elems.size()];
        int j                       = 0;
            if( orig_elems[i] == defo_elems[j] )
                orig_size_condensed[j] = orig_size[i];
                defo_size_condensed[j] = measure( MBI, defo_elems[j] );
                ++j;
        generate_plots( orig_size_condensed, defo_size_condensed, defo_elems.size(), std::string( time_step ) );
        delete[] orig_size_condensed;  // can't use the same delete[] for both
        delete[] defo_size_condensed;
    // Deal with dead elements. For now, add them to the impl_compl volume.
    // Extra surfaces are created to do this.
    if( update_coords && dead_elements_exist )
        result = add_dead_elems_to_impl_compl( MBI, cgm_file_set, cub_file_set, idTag, dimTag, categoryTag, senseTag,
                                               debug );
        std::cout << "Placed dead elements in implicit complement volume and added required surfaces." << std::endl;
    // The quads in the cub_file_set have been updated for dead elements. For each
    // cgm_surf, if there exists a cub_surf with the same id, replace the cgm tris
    // with cub_tris (created from the quads). Note the a surface that is not
    // meshed (in cub file) will not be effected.
    result = replace_faceted_cgm_surfs( MBI, cgm_file_set, cub_file_set, idTag, dimTag, debug );
    std::cout << "Replaced faceted CAD surfaces with meshed surfaces of triangles." << std::endl;
    result = remove_empty_cgm_surfs_and_vols( MBI, cgm_file_set, idTag, dimTag, debug );
    std::cout << "Removed surfaces and volumes that no longer have any triangles." << std::endl;
    // For each material, sum the volume. If the coordinates were updated for
    // deformation, summarize the volume change.
    result = summarize_cell_volume_change( MBI, cgm_file_set, categoryTag, dimTag, sizeTag, nameTag, idTag,
                                           conserve_mass, debug );
    std::cout << "Summarized the volume change of each material, with respect to the solid model." << std::endl;
    result = MBI->write_mesh( out_name, &cgm_file_set, 1 );
        std::cout << "write mesh failed" << std::endl;
        return result;
    std::cout << "Saved output file for mesh-based analysis." << std::endl;
    clock_t end_time = clock();
    std::cout << "  " << (double)( end_time - start_time ) / CLOCKS_PER_SEC << " seconds" << std::endl;
    return 0;
double measure ( Interface *  MBI,
Definition at line 591 of file cub2h5m.cpp.
References ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), length(), MB_SUCCESS, MBEDGE, MBHEX, MBPOLYGON, MBPRISM, MBPYRAMID, MBQUAD, MBTET, MBTRI, moab::sum(), tet_volume(), and moab::Interface::type_from_handle().
    EntityType type = MBI->type_from_handle( element );
    int num_vertices;
    ErrorCode result = MBI->get_connectivity( element, conn, num_vertices );
    std::vector< CartVect > coords( num_vertices );
    result = MBI->get_coords( conn, num_vertices, coords[0].array() );
    switch( type )
        case MBEDGE:
            return ( coords[0] - coords[1] ).length();
        case MBTRI:
            return 0.5 * ( ( coords[1] - coords[0] ) * ( coords[2] - coords[0] ) ).length();
        case MBQUAD:
            num_vertices = 4;
        case MBPOLYGON: {
            CartVect mid( 0, 0, 0 );
            for( int i = 0; i < num_vertices; ++i )
                mid += coords[i];
            mid /= num_vertices;
            double sum = 0.0;
                int j = ( i + 1 ) % num_vertices;
                sum += ( ( mid - coords[i] ) * ( mid - coords[j] ) ).length();
            return 0.5 * sum;
        case MBTET:
            return tet_volume( coords[0], coords[1], coords[2], coords[3] );
        case MBPYRAMID:
            return tet_volume( coords[0], coords[1], coords[2], coords[4] ) +
                   tet_volume( coords[0], coords[2], coords[3], coords[4] );
        case MBPRISM:
            return tet_volume( coords[0], coords[1], coords[2], coords[5] ) +
                   tet_volume( coords[3], coords[5], coords[4], coords[0] ) +
                   tet_volume( coords[1], coords[4], coords[5], coords[0] );
        case MBHEX:
            return tet_volume( coords[0], coords[1], coords[3], coords[4] ) +
                   tet_volume( coords[7], coords[3], coords[6], coords[4] ) +
                   tet_volume( coords[4], coords[5], coords[1], coords[6] ) +
                   tet_volume( coords[1], coords[6], coords[3], coords[4] ) +
                   tet_volume( coords[2], coords[6], coords[3], coords[1] );
        default:
            return 0.0;
ErrorCode orient_faces_outward ( Interface *  MBI,
const Range &  faces,
const bool
Definition at line 341 of file cub2h5m.cpp.
References moab::Range::begin(), moab::CN::Dimension(), moab::Range::end(), ErrorCode, moab::Range::front(), moab::Interface::get_adjacencies(), moab::Interface::get_connectivity(), MB_INVALID_SIZE, MB_SUCCESS, moab::Interface::set_connectivity(), moab::CN::SideNumber(), moab::Range::size(), and moab::Interface::type_from_handle().
    ErrorCode result;
    for( Range::const_iterator i = faces.begin(); i != faces.end(); ++i )
        Range adj_elem;
        result = MBI->get_adjacencies( &( *i ), 1, 3, false, adj_elem );
        if( 1 != adj_elem.size() ) return MB_INVALID_SIZE;
        // get connectivity for element and face
        const EntityHandle* elem_conn;
        int elem_n_nodes;
        result = MBI->get_connectivity( adj_elem.front(), elem_conn, elem_n_nodes );
        const EntityHandle* face_conn;
        int face_n_nodes;
        result = MBI->get_connectivity( *i, face_conn, face_n_nodes );
        // Get the sense of the face wrt the element
        EntityType elem_type = MBI->type_from_handle( adj_elem.front() );
        EntityType face_type = MBI->type_from_handle( *i );
        int face_num, offset;
        int sense          = 0;
        const int face_dim = CN::Dimension( face_type );
        int rval = CN::SideNumber( elem_type, elem_conn, face_conn, face_n_nodes, face_dim, face_num, sense, offset );
        if( 0 != rval ) return MB_FAILURE;
        // If the face is not oriented outward wrt the element, reverse it
        if( -1 == sense )
            EntityHandle new_face_conn[4] = { face_conn[3], face_conn[2], face_conn[1], face_conn[0] };
            result                        = MBI->set_connectivity( *i, new_face_conn, 4 );
    return MB_SUCCESS;
void plot_histogram ( const std::string &  title,
const std::string &  x_axis_label,
const std::string &  y_axis_label,
const int  n_bins,
const int  n_data
Definition at line 500 of file cub2h5m.cpp.
Referenced by generate_plots().
    // find max and min
    double min = std::numeric_limits< double >::max();
    double max = -std::numeric_limits< double >::max();
    for( int i = 0; i < n_data; ++i )
        if( min > data[i] ) min = data[i];
        if( max < data[i] ) max = data[i];
    // make bins for histogram
    double bin_width = ( max - min ) / n_bins;
    std::vector< int > bins( n_bins );
    for( int i = 0; i < n_bins; ++i )
        bins[i] = 0;
    // fill the bins
        double diff = data[i] - min;
        int bin     = diff / bin_width;
        if( 9 < bin ) bin = 9;  // cheap fix for numerical precision error
        if( 0 > bin ) bin = 0;  // cheap fix for numerical precision error
        ++bins[bin];
    // create bars
    int max_bin = 0;
        if( max_bin < bins[i] ) max_bin = bins[i];
    int bar_height;
    int max_bar_chars = 72;
    std::vector< std::string > bars( n_bins );
        bar_height = ( max_bar_chars * bins[i] ) / max_bin;
        for( int j = 0; j < bar_height; ++j )
            bars[i] += "*";
    // print histogram header
    std::cout << "                                 " << title << std::endl;
    // print results
    std::cout.width( 15 );
    std::cout << min << std::endl;
        std::cout << min + ( ( i + 1 ) * bin_width );
        std::cout.width( max_bar_chars );
        std::cout << bars[i] << bins[i] << std::endl;
    // print histogram footer
    std::cout << y_axis_label;
    std::cout << " " << x_axis_label << std::endl;
ErrorCode remove_empty_cgm_surfs_and_vols ( Interface *  MBI,
const Tag  idTag,
const Tag  dimTag,
const bool
Definition at line 188 of file cub2h5m.cpp.
References moab::Range::begin(), moab::Interface::contains_entities(), moab::Interface::delete_entities(), moab::Range::end(), ErrorCode, moab::Interface::get_child_meshsets(), moab::Interface::get_entities_by_type(), moab::Interface::get_entities_by_type_and_tag(), moab::Interface::get_number_entities_by_type(), moab::Interface::get_parent_meshsets(), MB_SUCCESS, MBENTITYSET, MBTRI, moab::Interface::num_child_meshsets(), moab::Interface::remove_entities(), moab::Interface::remove_parent_child(), and moab::Interface::tag_get_data().
    ErrorCode result;
    const int two               = 2;
    Range cgm_surfs;
        int n_tris;
        result = MBI->get_number_entities_by_type( *i, MBTRI, n_tris );
        if( 0 == n_tris )
            int surf_id;
            Range parent_vols;
            result = MBI->get_parent_meshsets( *i, parent_vols );
            for( Range::iterator j = parent_vols.begin(); j != parent_vols.end(); ++j )
                result = MBI->remove_parent_child( *j, *i );
            Range child_curves;
            result = MBI->get_child_meshsets( *i, child_curves );
            for( Range::iterator j = child_curves.begin(); j != child_curves.end(); ++j )
                result = MBI->remove_parent_child( *i, *j );
            result = MBI->remove_entities( cgm_file_set, &( *i ), 1 );
            // Is the set contained anywhere else? If the surface is in a CUBIT group,
            // such as "unmerged_surfs" it will cause write_mesh to fail. This should
            // be a MOAB bug.
            Range all_sets;
            result = MBI->get_entities_by_type( 0, MBENTITYSET, all_sets );
            for( Range::iterator j = all_sets.begin(); j != all_sets.end(); ++j )
                if( MBI->contains_entities( *j, &( *i ), 1 ) )
                    result = MBI->remove_entities( *j, &( *i ), 1 );
            result = MBI->delete_entities( &( *i ), 1 );
            std::cout << "  Surface " << surf_id << ": removed because all of its mesh faces have been removed"
                      << std::endl;
    // get all volumes
    Range cgm_vols;
        // get the volume's number of surfaces
        int n_surfs;
        result = MBI->num_child_meshsets( *i, &n_surfs );
        // if no surfaces remain, remove the volume
        if( 0 == n_surfs )
            int vol_id;
            // be a MOAB bug.
            Range all_sets;
            std::cout << "  Volume " << vol_id << ": removed because all of its surfaces have been removed"
                      << std::endl;
    return MB_SUCCESS;
ErrorCode replace_faceted_cgm_surfs ( Interface *  MBI,
const Tag  idTag,
const Tag  dimTag,
const bool  debug
Definition at line 791 of file cub2h5m.cpp.
References moab::Interface::add_entities(), moab::Range::begin(), moab::Interface::delete_entities(), moab::Range::end(), ErrorCode, moab::Range::front(), moab::Interface::get_entities_by_type(), moab::Interface::get_entities_by_type_and_tag(), idTag, make_tris_from_quads(), MB_SUCCESS, MBENTITYSET, MBQUAD, MBTRI, moab::Interface::remove_entities(), moab::Range::size(), and moab::Interface::tag_get_data().
    ErrorCode result;
    const int two               = 2;
    Range cgm_surfs;
        int surf_id;
        if( debug ) std::cout << "surf_id=" << surf_id << std::endl;
        Range cub_surf;
                      << std::endl;
            continue;
        Range quads;
        Range cub_tris;
        // Remove the tris from the cgm surf. Don't forget to remove them from the
        // cgm_file_set because it is not TRACKING.
        Range cgm_tris;
        result = MBI->get_entities_by_type( *i, MBTRI, cgm_tris );
        result = MBI->remove_entities( *i, cgm_tris );
        result = MBI->remove_entities( cgm_file_set, cgm_tris );
        result = MBI->delete_entities( cgm_tris );
        // Add the cub_tris to the cgm_surf
        result = MBI->add_entities( *i, cub_tris );
    return MB_SUCCESS;
ErrorCode summarize_cell_volume_change ( Interface *  MBI,
const Tag  dimTag,
const Tag  sizeTag,
const Tag  nameTag,
const Tag  idTag,
const bool  debug
Definition at line 59 of file cub2h5m.cpp.
References moab::Interface::add_entities(), moab::Range::begin(), CATEGORY_TAG_SIZE, moab::Interface::create_meshset(), moab::Range::end(), ErrorCode, moab::Interface::get_entities_by_type_and_tag(), get_group_names(), MB_SUCCESS, MBENTITYSET, moab::GeomQueryTool::measure_volume(), MESHSET_SET, moab::Interface::remove_entities(), moab::Interface::tag_get_data(), moab::Interface::tag_set_data(), and tokenize().
    // get groups
    ErrorCode rval;
    const char group_category[CATEGORY_TAG_SIZE] = { "Group\0" };
    const void* const group_val[]                = { &group_category };
    Range groups;
    rval = MBI->get_entities_by_type_and_tag( 0, MBENTITYSET, &categoryTag, group_val, 1, groups );
    // Get the maximum group id. This is so that new groups do not have
    // duplicate ids.
    int max_grp_id = -1;
    for( Range::const_iterator i = groups.begin(); i != groups.end(); ++i )
        int grp_id;
        rval = MBI->tag_get_data( idTag, &( *i ), 1, &grp_id );
        if( max_grp_id < grp_id ) max_grp_id = grp_id;
    if( conserve_mass )
        std::cout << "  Altering group densities to conserve mass for each volume." << std::endl;
        std::cout << "    maximum group id=" << max_grp_id << std::endl;
        // get group names
        std::vector< std::string > grp_names;
        rval = get_group_names( MBI, *i, nameTag, grp_names );
        if( MB_SUCCESS != rval ) return MB_FAILURE;
        // determine if it is a material group
        bool material_grp = false;
        int mat_id        = -1;
        double rho        = 0;
        for( std::vector< std::string >::const_iterator j = grp_names.begin(); j != grp_names.end(); ++j )
            if( std::string::npos != ( *j ).find( "mat" ) && std::string::npos != ( *j ).find( "rho" ) )
                material_grp = true;
                std::cout << "  material group: " << *j << std::endl;
                // get the density and material id
                std::vector< std::string > tokens;
                tokenize( *j, tokens, "_" );
                mat_id = atoi( tokens[1].c_str() );
                rho    = atof( tokens[3].c_str() );
        if( !material_grp ) continue;
        // get the volume sets of the material group
        Range vols;
        rval = MBI->get_entities_by_type_and_tag( *i, MBENTITYSET, &dimTag, three_val, 1, vols );
        // for each volume, sum predeformed and deformed volume
        double orig_grp_volume = 0, defo_grp_volume = 0;
        for( Range::const_iterator j = vols.begin(); j != vols.end(); ++j )
            double defo_size = 0, orig_size = 0;
            rval = gqt.measure_volume( *j, defo_size );
            defo_grp_volume += defo_size;
            rval = MBI->tag_get_data( sizeTag, &( *j ), 1, &orig_size );
            orig_grp_volume += orig_size;
            // calculate a new density to conserve mass through the deformation
            if( !conserve_mass ) continue;
            double new_rho = rho * orig_size / defo_size;
            // create a group for the volume with modified density
            EntityHandle new_grp;
            rval = MBI->create_meshset( MESHSET_SET, new_grp );
            std::stringstream new_name_ss;
            new_name_ss << "mat_" << mat_id << "_rho_" << new_rho << "\0";
            std::string new_name;
            new_name_ss >> new_name;
            rval = MBI->tag_set_data( nameTag, &new_grp, 1, new_name.c_str() );
            max_grp_id++;
            rval = MBI->tag_set_data( idTag, &new_grp, 1, &max_grp_id );
            const char group_category2[CATEGORY_TAG_SIZE] = "Group\0";
            rval = MBI->tag_set_data( categoryTag, &new_grp, 1, group_category2 );
            // add the volume to the new group
            rval = MBI->add_entities( new_grp, &( *j ), 1 );
            // add the new grp to the cgm_file_set
            rval = MBI->add_entities( cgm_file_set, &new_grp, 1 );
            // remove the volume from the old group
            rval = MBI->remove_entities( *i, &( *j ), 1 );
            if( debug ) std::cout << "    new group: " << new_name << " id=" << max_grp_id << std::endl;
        std::cout << "    orig_volume=" << orig_grp_volume << " defo_volume=" << defo_grp_volume
                  << " defo/orig=" << defo_grp_volume / orig_grp_volume << std::endl;
    return MB_SUCCESS;
static double tet_volume ( const CartVect &  v0,
const CartVect &  v1,
const CartVect &  v2,
const CartVect &  v3
) [inline, static]
Definition at line 585 of file cub2h5m.cpp.
Referenced by measure().
    return 1. / 6. * ( ( ( v1 - v0 ) * ( v2 - v0 ) ) % ( v3 - v0 ) );
void tokenize ( const std::string &  str,
std::vector< std::string > &  tokens,
const char *  delimiters
Definition at line 25 of file cub2h5m.cpp.
    std::string::size_type last = str.find_first_not_of( delimiters, 0 );
    std::string::size_type pos  = str.find_first_of( delimiters, last );
    if( std::string::npos == pos )
        tokens.push_back( str );
    else
        while( std::string::npos != pos && std::string::npos != last )
            tokens.push_back( str.substr( last, pos - last ) );
            last = str.find_first_not_of( delimiters, pos );
            if( std::string::npos == pos ) pos = str.size();
Variable Documentation
Definition at line 1103 of file cub2h5m.cpp.
Definition at line 1104 of file cub2h5m.cpp.
Definition at line 1105 of file cub2h5m.cpp.
Referenced by moab::ReadCGM::set_options().
