MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "mhdf.h" 00002 #include "util.h" 00003 #include "status.h" 00004 #include <assert.h> 00005 #include <stdlib.h> 00006 #include <string.h> 00007 #include <H5Tpublic.h> 00008 #include <H5Dpublic.h> 00009 #include <H5Ppublic.h> 00010 00011 static struct mhdf_FileDesc* alloc_file_desc( mhdf_Status* status ); 00012 static void* realloc_data( struct mhdf_FileDesc** data, size_t append_bytes, mhdf_Status* status, int alignment ); 00013 static char buffer[512]; 00014 00015 static struct mhdf_FileDesc* alloc_file_desc( mhdf_Status* status ) 00016 { 00017 struct mhdf_FileDesc* result; 00018 /* allocate a little short of a page */ 00019 result = (struct mhdf_FileDesc*)mhdf_malloc( 4000, status ); 00020 if( mhdf_isError( status ) ) return 0; 00021 00022 memset( result, 0, sizeof( struct mhdf_FileDesc ) ); 00023 result->total_size = 4000; 00024 result->offset = ( (unsigned char*)result ) + sizeof( struct mhdf_FileDesc ); 00025 return result; 00026 } 00027 00028 static void* realloc_data( struct mhdf_FileDesc** data, size_t append_bytes, mhdf_Status* status, int alignment) 00029 { 00030 void* result_ptr; 00031 struct mhdf_FileDesc* const input_ptr = *data; 00032 unsigned char* mem_ptr = (unsigned char*)input_ptr; 00033 00034 size_t new_size, occupied_size = input_ptr->offset - mem_ptr; 00035 00036 int append_bytes_padded = append_bytes + alignment - 1; 00037 /* if the end of the allocated space is before the end of the required space */ 00038 if( mem_ptr + input_ptr->total_size < input_ptr->offset + append_bytes_padded ) 00039 { 00040 if( append_bytes_padded < input_ptr->total_size ) 00041 new_size = 2 * input_ptr->total_size; 00042 else 00043 new_size = input_ptr->total_size + append_bytes_padded; 00044 *data = (struct mhdf_FileDesc*)mhdf_realloc( *data, new_size, status ); 00045 if( mhdf_isError( status ) ) return 0; 00046 00047 /* if realloc moved us to a different location in memory, 00048 * we need to update all of the internal pointers to 00049 * new locations relative to the start of the struct */ 00050 if( *data != input_ptr ) 00051 { 00052 mhdf_fixFileDesc( *data, input_ptr ); 00053 mem_ptr = (unsigned char*)( *data ); 00054 ( *data )->offset = mem_ptr + occupied_size; 00055 } 00056 ( *data )->total_size = new_size; 00057 } 00058 00059 result_ptr = ( *data )->offset; 00060 /* need to make this return pointer aligned */ 00061 uintptr_t addr = (uintptr_t)(( *data )->offset); 00062 int pad = addr%alignment; 00063 if (pad > 0) 00064 { 00065 ( *data )->offset += (alignment-pad); 00066 result_ptr = ( *data )->offset; 00067 } 00068 /*printf("new address %p \n", result_ptr);*/ 00069 ( *data )->offset += append_bytes; 00070 return result_ptr; 00071 } 00072 00073 #define FIX_OFFSET( TYPE, FIELD ) \ 00074 if( copy_ptr->FIELD != NULL ) \ 00075 copy_ptr->FIELD = (TYPE)( ( (char*)( copy_ptr->FIELD ) - (char*)orig_addr ) + (char*)copy_ptr ) 00076 00077 void mhdf_fixFileDesc( struct mhdf_FileDesc* copy_ptr, const struct mhdf_FileDesc* orig_addr ) 00078 { 00079 int i; 00080 00081 API_BEGIN; 00082 FIX_OFFSET( int*, nodes.dense_tag_indices ); 00083 FIX_OFFSET( int*, sets.dense_tag_indices ); 00084 FIX_OFFSET( struct mhdf_ElemDesc*, elems ); 00085 FIX_OFFSET( struct mhdf_TagDesc*, tags ); 00086 00087 FIX_OFFSET( int*, numEntSets ); 00088 FIX_OFFSET( int**, defTagsEntSets ); 00089 FIX_OFFSET( int**, defTagsVals ); 00090 00091 for( i = 0; i < 5; i++ ) 00092 { 00093 if( copy_ptr->defTagsEntSets ) FIX_OFFSET( int*, defTagsEntSets[i] ); 00094 if( copy_ptr->defTagsVals ) FIX_OFFSET( int*, defTagsVals[i] ); 00095 } 00096 00097 if( copy_ptr->elems != NULL ) 00098 { 00099 for( i = 0; i < copy_ptr->num_elem_desc; ++i ) 00100 { 00101 FIX_OFFSET( const char*, elems[i].handle ); 00102 FIX_OFFSET( const char*, elems[i].type ); 00103 FIX_OFFSET( int*, elems[i].desc.dense_tag_indices ); 00104 } 00105 } 00106 00107 if( copy_ptr->tags != NULL ) 00108 { 00109 for( i = 0; i < copy_ptr->num_tag_desc; ++i ) 00110 { 00111 FIX_OFFSET( const char*, tags[i].name ); 00112 FIX_OFFSET( void*, tags[i].default_value ); 00113 FIX_OFFSET( void*, tags[i].global_value ); 00114 FIX_OFFSET( int*, tags[i].dense_elem_indices ); 00115 } 00116 } 00117 API_END; 00118 } 00119 00120 static struct mhdf_FileDesc* get_elem_desc( mhdf_FileHandle file_handle, 00121 struct mhdf_FileDesc* result, 00122 const char* elem_handle, 00123 int idx, 00124 mhdf_Status* status ) 00125 { 00126 hid_t id_pair[2]; 00127 int poly; 00128 void* ptr; 00129 long junk; 00130 00131 ptr = realloc_data( &result, strlen( elem_handle ) + 1, status, sizeof(char) ); 00132 if( !ptr ) return NULL; 00133 strcpy( ptr, elem_handle ); 00134 result->elems[idx].handle = ptr; 00135 00136 mhdf_getElemTypeName( file_handle, elem_handle, buffer, sizeof( buffer ), status ); 00137 if( mhdf_isError( status ) ) 00138 { 00139 free( result ); 00140 return NULL; 00141 } 00142 00143 ptr = realloc_data( &result, strlen( buffer ) + 1, status, sizeof(char) ); 00144 if( !ptr ) return NULL; 00145 strcpy( ptr, buffer ); 00146 result->elems[idx].type = ptr; 00147 00148 poly = mhdf_isPolyElement( file_handle, elem_handle, status ); 00149 if( mhdf_isError( status ) ) 00150 { 00151 free( result ); 00152 return NULL; 00153 } 00154 00155 if( !poly ) 00156 { 00157 id_pair[0] = mhdf_openConnectivity( file_handle, elem_handle, &result->elems[idx].desc.vals_per_ent, 00158 &result->elems[idx].desc.count, &result->elems[idx].desc.start_id, status ); 00159 if( id_pair[0] < 0 ) 00160 { 00161 free( result ); 00162 return NULL; 00163 } 00164 mhdf_closeData( file_handle, id_pair[0], status ); 00165 } 00166 else 00167 { 00168 result->elems[idx].desc.vals_per_ent = -1; 00169 mhdf_openPolyConnectivity( file_handle, elem_handle, &result->elems[idx].desc.count, &junk, 00170 &result->elems[idx].desc.start_id, id_pair, status ); 00171 if( id_pair[0] < 0 ) 00172 { 00173 free( result ); 00174 return NULL; 00175 } 00176 mhdf_closeData( file_handle, id_pair[0], status ); 00177 mhdf_closeData( file_handle, id_pair[1], status ); 00178 } 00179 00180 result->elems[idx].desc.dense_tag_indices = NULL; 00181 result->elems[idx].desc.num_dense_tags = 0; 00182 result->elems[idx].have_adj = mhdf_haveAdjacency( file_handle, result->elems[idx].handle, status ); 00183 if( mhdf_isError( status ) ) 00184 { 00185 free( result ); 00186 return 0; 00187 } 00188 00189 return result; 00190 } 00191 00192 static unsigned get_file_id_size( hid_t file_id_type, mhdf_Status* status ) 00193 { 00194 if( H5Tget_class( file_id_type ) != H5T_INTEGER ) 00195 { 00196 mhdf_setFail( status, "Invalid handle or type class for file ID type." ); 00197 return 0; 00198 } 00199 00200 return H5Tget_size( file_id_type ); 00201 } 00202 00203 static struct mhdf_FileDesc* get_tag_desc( mhdf_FileHandle file_handle, 00204 struct mhdf_FileDesc* result, 00205 const char* name, 00206 int idx, 00207 hid_t type, 00208 mhdf_Status* status ) 00209 { 00210 void* ptr; 00211 int have_default, have_global; 00212 int valsize, size, close_type = 0; 00213 hsize_t array_len; 00214 00215 ptr = realloc_data( &result, strlen( name ) + 1, status, sizeof(char) ); 00216 if( NULL == ptr ) return NULL; 00217 strcpy( ptr, name ); 00218 result->tags[idx].name = ptr; 00219 00220 mhdf_getTagInfo( file_handle, name, &result->tags[idx].type, &result->tags[idx].size, &result->tags[idx].storage, 00221 &have_default, &have_global, &result->tags[idx].have_sparse, status ); 00222 if( mhdf_isError( status ) ) 00223 { 00224 free( result ); 00225 return NULL; 00226 } 00227 00228 /* For variable length tags, have_default and have_global will 00229 contain the size of the respective values. For fixed-length 00230 tags, they are either zero or one. Simplify later code by 00231 making them contain the size for both cases. */ 00232 valsize = result->tags[idx].size; 00233 if( result->tags[idx].size >= 0 ) 00234 { 00235 if( have_default ) have_default = valsize; 00236 if( have_global ) have_global = valsize; 00237 } 00238 00239 result->tags[idx].default_value = NULL; 00240 result->tags[idx].default_value_size = have_default; 00241 result->tags[idx].global_value = NULL; 00242 result->tags[idx].global_value_size = have_global; 00243 00244 switch( result->tags[idx].type ) 00245 { 00246 case mhdf_OPAQUE: 00247 type = 0; 00248 break; 00249 case mhdf_BOOLEAN: 00250 type = H5T_NATIVE_UCHAR; 00251 break; 00252 case mhdf_INTEGER: 00253 type = H5T_NATIVE_INT; 00254 have_default *= sizeof( int ); 00255 have_global *= sizeof( int ); 00256 valsize *= sizeof( int ); 00257 break; 00258 case mhdf_FLOAT: 00259 type = H5T_NATIVE_DOUBLE; 00260 have_default *= sizeof( double ); 00261 have_global *= sizeof( double ); 00262 valsize *= sizeof( double ); 00263 break; 00264 case mhdf_BITFIELD: 00265 have_default = ( have_default + 7 ) / 8; 00266 have_global = ( have_global + 7 ) / 8; 00267 valsize = ( valsize + 7 ) / 8; 00268 switch( valsize ) 00269 { 00270 case 1: 00271 type = H5Tcopy( H5T_NATIVE_B8 ); 00272 break; 00273 case 2: 00274 type = H5Tcopy( H5T_NATIVE_B16 ); 00275 break; 00276 case 3: 00277 case 4: 00278 valsize += 4 - valsize; // to avoid fallthrough warning 00279 type = H5Tcopy( H5T_NATIVE_B32 ); 00280 break; 00281 case 5: 00282 case 6: 00283 case 7: 00284 case 8: 00285 valsize += 8 - valsize; // to avoid fallthrough warning 00286 type = H5Tcopy( H5T_NATIVE_B64 ); 00287 break; 00288 default: 00289 free( result ); 00290 mhdf_setFail( status, "Cannot create a bit tag larger than 64-bits. %d bits requested.\n", 00291 (int)valsize ); 00292 return NULL; 00293 } 00294 close_type = 1; 00295 break; 00296 case mhdf_ENTITY_ID: 00297 if( 0 == type ) type = H5T_NATIVE_ULONG; 00298 size = get_file_id_size( type, status ); 00299 if( !size ) 00300 { 00301 free( result ); 00302 return NULL; 00303 } 00304 have_default *= size; 00305 have_global *= size; 00306 valsize *= size; 00307 break; 00308 default: 00309 mhdf_setFail( status, "Unknown mhdf_TagDataType value (%d) for tag (\"%s\")", (int)result->tags[idx].type, 00310 name ); 00311 free( result ); 00312 return NULL; 00313 } 00314 result->tags[idx].bytes = valsize; 00315 00316 if( result->tags[idx].type != mhdf_OPAQUE && result->tags[idx].type != mhdf_BITFIELD && result->tags[idx].size > 1 ) 00317 { 00318 close_type = 1; 00319 array_len = result->tags[idx].size; 00320 #if defined( H5Tarray_create_vers ) && H5Tarray_create_vers > 1 00321 type = H5Tarray_create2( type, 1, &array_len ); 00322 #else 00323 type = H5Tarray_create( type, 1, &array_len, 0 ); 00324 #endif 00325 if( type < 0 ) 00326 { 00327 mhdf_setFail( status, "H5Tarray_create failed for tag (\"%s\")", name ); 00328 free( result ); 00329 return NULL; 00330 } 00331 } 00332 00333 if( have_default || have_global ) 00334 { 00335 if( have_default ) 00336 { 00337 ptr = realloc_data( &result, have_default, status, sizeof(int) ); 00338 if( NULL == ptr ) 00339 { 00340 if( close_type ) 00341 { 00342 H5Tclose( type ); 00343 } 00344 return NULL; 00345 } 00346 result->tags[idx].default_value = ptr; 00347 } 00348 if( have_global ) 00349 { 00350 ptr = realloc_data( &result, have_global, status, sizeof(int) ); 00351 if( NULL == ptr ) 00352 { 00353 if( close_type ) 00354 { 00355 H5Tclose( type ); 00356 } 00357 return NULL; 00358 } 00359 result->tags[idx].global_value = ptr; 00360 } 00361 mhdf_getTagValues( file_handle, name, type, result->tags[idx].default_value, result->tags[idx].global_value, 00362 status ); 00363 if( close_type ) 00364 { 00365 H5Tclose( type ); 00366 } 00367 if( mhdf_isError( status ) ) 00368 { 00369 free( result ); 00370 return NULL; 00371 } 00372 } 00373 00374 return result; 00375 } 00376 00377 static void free_string_list( char** list, int count ) 00378 { 00379 int i; 00380 for( i = 0; i < count; ++i ) 00381 free( list[i] ); 00382 free( list ); 00383 } 00384 00385 struct mhdf_FileDesc* mhdf_getFileSummary( mhdf_FileHandle file_handle, 00386 hid_t file_id_type, 00387 mhdf_Status* status, 00388 int extraSetInfo ) 00389 { 00390 struct mhdf_FileDesc* result; 00391 hid_t table_id; 00392 int i, i1, numtags, j, k, size, *indices, have, num_tag_names = 0; 00393 unsigned int ui; 00394 void* ptr; 00395 char **elem_handles = 0, **tag_names = 0; 00396 unsigned char *array, *matrix; 00397 const char* pname[5] = { "PARALLEL_PARTITION", "MATERIAL_SET", "NEUMANN_SET", "DIRICHLET_SET", "GEOM_DIMENSION" }; 00398 00399 long* id_list; 00400 struct mhdf_TagDesc* tag_desc; 00401 long int nval, junk; 00402 hid_t table[3]; 00403 hid_t data_type; 00404 00405 API_BEGIN; 00406 00407 mhdf_setOkay( status ); 00408 result = alloc_file_desc( status ); 00409 if( NULL == result ) return NULL; 00410 00411 /* get node info */ 00412 have = mhdf_haveNodes( file_handle, status ); 00413 if( mhdf_isError( status ) ) 00414 { 00415 free( result ); 00416 return NULL; 00417 } 00418 if( have ) 00419 { 00420 table_id = mhdf_openNodeCoords( file_handle, &result->nodes.count, &result->nodes.vals_per_ent, 00421 &result->nodes.start_id, status ); 00422 if( table_id < 0 ) 00423 { 00424 free( result ); 00425 return NULL; 00426 } 00427 mhdf_closeData( file_handle, table_id, status ); 00428 } 00429 else 00430 { 00431 result->nodes.count = 0; 00432 result->nodes.vals_per_ent = 0; 00433 result->nodes.start_id = 0; 00434 } 00435 00436 /* get set info */ 00437 result->sets.vals_per_ent = -1; 00438 have = mhdf_haveSets( file_handle, &result->have_set_contents, &result->have_set_children, 00439 &result->have_set_parents, status ); 00440 if( mhdf_isError( status ) ) 00441 { 00442 free( result ); 00443 return NULL; 00444 } 00445 if( have ) 00446 { 00447 table_id = mhdf_openSetMeta( file_handle, &result->sets.count, &result->sets.start_id, status ); 00448 if( table_id < 0 ) 00449 { 00450 free( result ); 00451 return NULL; 00452 } 00453 mhdf_closeData( file_handle, table_id, status ); 00454 } 00455 else 00456 { 00457 result->sets.count = 0; 00458 result->sets.start_id = 0; 00459 } 00460 00461 /* get element list */ 00462 elem_handles = mhdf_getElemHandles( file_handle, &ui, status ); 00463 if( elem_handles == NULL ) 00464 { 00465 free( result ); 00466 return NULL; 00467 } 00468 result->num_elem_desc = ui; 00469 00470 /* allocate array of element descriptors */ 00471 size = result->num_elem_desc * sizeof( struct mhdf_ElemDesc ); 00472 ptr = realloc_data( &result, size, status, sizeof( char* ) ); 00473 if( NULL == ptr ) 00474 { 00475 free( elem_handles ); 00476 return NULL; 00477 } 00478 memset( ptr, 0, size ); 00479 result->elems = ptr; 00480 00481 /* Initialize each element descriptor */ 00482 for( i = 0; i < result->num_elem_desc; ++i ) 00483 { 00484 result = get_elem_desc( file_handle, result, elem_handles[i], i, status ); 00485 if( NULL == result ) 00486 { 00487 free( elem_handles ); 00488 return NULL; 00489 } 00490 } 00491 00492 /* get tag list */ 00493 tag_names = mhdf_getTagNames( file_handle, &num_tag_names, status ); 00494 if( mhdf_isError( status ) ) 00495 { 00496 free( elem_handles ); 00497 free( result ); 00498 return NULL; 00499 } 00500 00501 /* allocate array of tag descriptors */ 00502 size = num_tag_names * sizeof( struct mhdf_TagDesc ); 00503 ptr = realloc_data( &result, size, status, sizeof( char* ) ); 00504 if( NULL == ptr ) 00505 { 00506 free( elem_handles ); 00507 free_string_list( tag_names, result->num_tag_desc ); 00508 return NULL; 00509 } 00510 memset( ptr, 0, size ); 00511 result->tags = ptr; 00512 result->num_tag_desc = num_tag_names; 00513 memset( result->tags, 0, size ); 00514 00515 /* Initialize each tag descriptor */ 00516 for( i = 0; i < result->num_tag_desc; ++i ) 00517 { 00518 result = get_tag_desc( file_handle, result, tag_names[i], i, file_id_type, status ); 00519 if( NULL == result ) 00520 { 00521 free( elem_handles ); 00522 free_string_list( tag_names, num_tag_names ); 00523 return NULL; 00524 } 00525 } 00526 00527 /* Determine which dense tags are present */ 00528 00529 size = ( 2 + result->num_elem_desc ) * result->num_tag_desc; 00530 array = mhdf_malloc( size, status ); 00531 if( NULL == array ) 00532 { 00533 free( elem_handles ); 00534 free_string_list( tag_names, num_tag_names ); 00535 free( result ); 00536 return NULL; 00537 } 00538 memset( array, 0, size ); 00539 matrix = array + ( 2 * result->num_tag_desc ); 00540 00541 for( j = 0; j < result->num_tag_desc; ++j ) 00542 { 00543 if( mhdf_haveDenseTag( file_handle, tag_names[j], mhdf_node_type_handle(), status ) ) 00544 matrix[-1 * result->num_tag_desc + j] = 1; 00545 if( mhdf_haveDenseTag( file_handle, tag_names[j], mhdf_set_type_handle(), status ) ) 00546 matrix[-2 * result->num_tag_desc + j] = 1; 00547 for( i = 0; i < result->num_elem_desc; ++i ) 00548 if( mhdf_haveDenseTag( file_handle, tag_names[j], elem_handles[i], status ) ) 00549 matrix[i * result->num_tag_desc + j] = 1; 00550 } 00551 free( elem_handles ); 00552 free_string_list( tag_names, result->num_tag_desc ); 00553 00554 /* Populate dense tag lists for element types */ 00555 for( i = -2; i < result->num_elem_desc; ++i ) 00556 { 00557 size = 0; 00558 for( j = 0; j < result->num_tag_desc; ++j ) 00559 size += matrix[i * result->num_tag_desc + j]; 00560 if( !size ) 00561 { 00562 indices = NULL; 00563 } 00564 else 00565 { 00566 indices = realloc_data( &result, size * sizeof( int ), status, sizeof( int ) ); 00567 if( NULL == indices ) 00568 { 00569 free( array ); 00570 return NULL; 00571 } 00572 00573 k = 0; 00574 for( j = 0; j < result->num_tag_desc; ++j ) 00575 if( matrix[i * result->num_tag_desc + j] ) indices[k++] = j; 00576 assert( k == size ); 00577 } 00578 00579 if( i == -2 ) 00580 { 00581 result->sets.dense_tag_indices = indices; 00582 result->sets.num_dense_tags = size; 00583 } 00584 else if( i == -1 ) 00585 { 00586 result->nodes.dense_tag_indices = indices; 00587 result->nodes.num_dense_tags = size; 00588 } 00589 else 00590 { 00591 result->elems[i].desc.dense_tag_indices = indices; 00592 result->elems[i].desc.num_dense_tags = size; 00593 } 00594 } 00595 00596 /* Populate dense tag lists for each tag */ 00597 for( j = 0; j < result->num_tag_desc; ++j ) 00598 { 00599 size = 0; 00600 for( i = -2; i < result->num_elem_desc; ++i ) 00601 size += matrix[i * result->num_tag_desc + j]; 00602 if( !size ) 00603 { 00604 indices = 0; 00605 } 00606 else 00607 { 00608 indices = realloc_data( &result, size * sizeof( int ), status, sizeof( int ) ); 00609 if( NULL == ptr ) 00610 { 00611 free( array ); 00612 return NULL; 00613 } 00614 00615 k = 0; 00616 for( i = -2; i < result->num_elem_desc; ++i ) 00617 if( matrix[i * result->num_tag_desc + j] ) indices[k++] = i; 00618 assert( k == size ); 00619 } 00620 00621 result->tags[j].num_dense_indices = size; 00622 result->tags[j].dense_elem_indices = indices; 00623 } 00624 00625 if( extraSetInfo ) 00626 { 00627 /* open the table for parallel partitions, material sets, neumann sets, 00628 * dirichlet sets 00629 * to determine number of parts, etc 00630 * this is needed for iMOAB and VisIt plugin */ 00631 const int NPRIMARY_SETS = 5; 00632 ptr = realloc_data( &result, NPRIMARY_SETS * sizeof( int ), status, sizeof( int ) ); 00633 if( NULL == ptr || mhdf_isError( status ) ) 00634 { 00635 free( array ); 00636 return NULL; 00637 } 00638 result->numEntSets = ptr; 00639 for( i = 0; i < NPRIMARY_SETS; ++i ) 00640 result->numEntSets[i] = 0; 00641 00642 ptr = realloc_data( &result, NPRIMARY_SETS * sizeof( int* ), status, sizeof( int* ) ); 00643 if( NULL == ptr || mhdf_isError( status ) ) 00644 { 00645 free( array ); 00646 return NULL; 00647 } 00648 result->defTagsEntSets = ptr; 00649 00650 ptr = realloc_data( &result, NPRIMARY_SETS * sizeof( int* ), status, sizeof( int* ) ); 00651 if( NULL == ptr || mhdf_isError( status ) ) 00652 { 00653 free( array ); 00654 return NULL; 00655 } 00656 result->defTagsVals = ptr; 00657 numtags = result->num_tag_desc; 00658 00659 for( i = 0; i < numtags; i++ ) 00660 { 00661 tag_desc = &( result->tags[i] ); 00662 for( k = 0; k < NPRIMARY_SETS; k++ ) /* number of default tags to consider */ 00663 { 00664 if( strcmp( pname[k], tag_desc->name ) == 0 ) 00665 { 00666 if( tag_desc->have_sparse ) 00667 { 00668 mhdf_openSparseTagData( file_handle, pname[k], &nval, &junk, table, status ); 00669 if( mhdf_isError( status ) ) 00670 { 00671 free( array ); 00672 return NULL; 00673 } 00674 /* for sparse tags, read */ 00675 result->numEntSets[k] = nval; 00676 if( nval <= 0 ) continue; /* do not do anything */ 00677 00678 ptr = realloc_data( &result, nval * sizeof( int ), status, sizeof( int ) ); 00679 if( NULL == ptr || mhdf_isError( status ) ) 00680 { 00681 free( array ); 00682 return NULL; 00683 } 00684 memset( ptr, 0, nval * sizeof( int ) ); 00685 result->defTagsEntSets[k] = ptr; 00686 tag_desc = &( result->tags[i] ); 00687 00688 ptr = realloc_data( &result, nval * sizeof( int ), status, sizeof( int ) ); 00689 if( NULL == ptr || mhdf_isError( status ) ) 00690 { 00691 free( array ); 00692 return NULL; 00693 } 00694 memset( ptr, 0, nval * sizeof( int ) ); 00695 result->defTagsVals[k] = ptr; 00696 tag_desc = &( result->tags[i] ); /* this is because the tag might point to 00697 something else*/ 00698 00699 /* make room for the long array type 00700 is it long or something else? */ 00701 id_list = mhdf_malloc( nval * sizeof( long ), status ); 00702 /* fill the id with values, then convert to int type (-set start) 00703 00704 mhdf_read_data( table_id, offset, count, int_type, id_list, H5P_DEFAULT, 00705 status );*/ 00706 00707 data_type = H5Dget_type( table[0] ); 00708 00709 mhdf_read_data( table[0], 0, nval, data_type, id_list, H5P_DEFAULT, status ); 00710 if( mhdf_isError( status ) ) 00711 { 00712 free( array ); 00713 return NULL; 00714 } 00715 H5Tclose( data_type ); 00716 00717 for( i1 = 0; i1 < nval; i1++ ) 00718 result->defTagsEntSets[k][i1] = (int)( id_list[i1] - result->sets.start_id + 1 ); 00719 /* now read values, integer type */ 00720 data_type = H5Dget_type( table[1] ); 00721 mhdf_read_data( table[1], 0, nval, data_type, result->defTagsVals[k], H5P_DEFAULT, status ); 00722 if( mhdf_isError( status ) ) 00723 { 00724 free( array ); 00725 return NULL; 00726 } 00727 H5Tclose( data_type ); 00728 mhdf_closeData( file_handle, table[0], status ); 00729 if( mhdf_isError( status ) ) 00730 { 00731 free( array ); 00732 return NULL; 00733 } 00734 mhdf_closeData( file_handle, table[1], status ); 00735 if( mhdf_isError( status ) ) 00736 { 00737 free( array ); 00738 return NULL; 00739 } 00740 free( id_list ); 00741 } 00742 else if( 0 == k || 1 == k ) 00743 { /* parallel partition or material sets should still work if dense 00744 could be dense tags on sets */ 00745 if( !mhdf_haveDenseTag( file_handle, pname[k], mhdf_set_type_handle(), status ) ) continue; 00746 table[0] = 00747 mhdf_openDenseTagData( file_handle, pname[k], mhdf_set_type_handle(), &nval, status ); 00748 if( mhdf_isError( status ) ) 00749 { 00750 continue; /* do not error out if not a dense tag either */ 00751 } 00752 result->numEntSets[k] = nval; 00753 if( nval <= 0 ) continue; /* do not do anything */ 00754 00755 /* 00756 * if dense parallel partition or material set, we know what to expect 00757 */ 00758 result->numEntSets[k] = nval; /* k could be 0 or 1 */ 00759 if( nval <= 0 ) continue; /* do not do anything */ 00760 00761 ptr = realloc_data( &result, nval * sizeof( int ), status, sizeof( int ) ); 00762 if( NULL == ptr || mhdf_isError( status ) ) 00763 { 00764 free( array ); 00765 return NULL; 00766 } 00767 memset( ptr, 0, nval * sizeof( int ) ); 00768 result->defTagsEntSets[k] = ptr; 00769 tag_desc = &( result->tags[i] ); 00770 00771 ptr = realloc_data( &result, nval * sizeof( int ), status, sizeof( int ) ); 00772 if( NULL == ptr || mhdf_isError( status ) ) 00773 { 00774 free( array ); 00775 return NULL; 00776 } 00777 memset( ptr, 0, nval * sizeof( int ) ); 00778 result->defTagsVals[k] = ptr; 00779 tag_desc = &( result->tags[i] ); /* this is because the tag might point to 00780 something else*/ 00781 00782 for( i1 = 0; i1 < nval; i1++ ) 00783 { 00784 result->defTagsEntSets[k][i1] = i1 + 1; 00785 /*result -> defTagsVals[k][i1] = i1; we know how the partition looks 00786 * like */ 00787 } 00788 /* fill in the data with the dense tag values 00789 because dense, sets will be in order 00790 00791 we know it has to be integer */ 00792 mhdf_readTagValues( table[0], 0, nval, H5T_NATIVE_INT, result->defTagsVals[k], status ); 00793 if( mhdf_isError( status ) ) 00794 { 00795 free( array ); 00796 return NULL; 00797 } 00798 mhdf_closeData( file_handle, table[0], status ); 00799 if( mhdf_isError( status ) ) 00800 { 00801 free( array ); 00802 return NULL; 00803 } 00804 } 00805 } 00806 } 00807 } 00808 } 00809 /* Compact memory and return */ 00810 free( array ); 00811 result->total_size = result->offset - (unsigned char*)result; 00812 00813 API_END; 00814 return result; 00815 }
