Node coordinate data.
+ Collaboration diagram for Node coordinate data.:
Functions
int mhdf_haveNodes (mhdf_FileHandle file_handle, mhdf_Status *status)
hid_t mhdf_createNodeCoords (mhdf_FileHandle file_handle, int dimension, long num_nodes, long *first_node_id_out, mhdf_Status *status)
 Create new table for node coordinate data.
hid_t mhdf_openNodeCoords (mhdf_FileHandle file_handle, long *num_nodes_out, int *dimension_out, long *first_node_id_out, mhdf_Status *status)
 Open table containing node coordinate data.
hid_t mhdf_openNodeCoordsSimple (mhdf_FileHandle file_handle, mhdf_Status *status)
void mhdf_writeNodeCoords (hid_t data_handle, long offset, long count, const double *coords, mhdf_Status *status)
 Write node coordinate data.
void mhdf_writeNodeCoordsWithOpt (hid_t data_handle, long offset, long count, const double *coords, hid_t write_prop, mhdf_Status *status)
void mhdf_writeNodeCoord (hid_t data_handle, long offset, long count, int dimension, const double *coords, mhdf_Status *status)
void mhdf_writeNodeCoordWithOpt (hid_t data_handle, long offset, long count, int dimension, const double *coords, hid_t write_prop, mhdf_Status *status)
void mhdf_readNodeCoords (hid_t data_handle, long offset, long count, double *coordinates, mhdf_Status *status)
 Read node coordinate data.
void mhdf_readNodeCoordsWithOpt (hid_t data_handle, long offset, long count, double *coordinates, hid_t read_prop, mhdf_Status *status)
void mhdf_readNodeCoord (hid_t data_handle, long offset, long count, int dimension, double *coords, mhdf_Status *status)
void mhdf_readNodeCoordWithOpt (hid_t data_handle, long offset, long count, int dimension, double *coords, hid_t read_prop, mhdf_Status *status)
Function Documentation
hid_t mhdf_createNodeCoords ( mhdf_FileHandle  file_handle,
int  dimension,
long  num_nodes,
long *  first_node_id_out,
mhdf_Status *  status
Parameters:
file_handleThe file.
dimensionNumber of coordinate values per node.
num_nodesThe number of nodes the table will contain.
first_node_id_outNodes are assigned IDs sequentially in the order they occur in the table, where the ID of the first node in the table is this passed-back value.
statusPassed back status of API call.
Returns:
An HDF5 handle to the coordinate table.
Definition at line 72 of file nodes.c.
References API_BEGIN, API_END_H, struct_FileHandle::hdf_handle, struct_FileHandle::max_id, mhdf_check_valid_file(), mhdf_create_scalar_attrib(), mhdf_create_table(), mhdf_setFail(), mhdf_setOkay(), mhdf_write_max_id(), NODE_COORD_PATH, struct_FileHandle::open_handle_count, and START_ID_ATTRIB.
Referenced by moab::WriteHDF5Parallel::create_node_table(), and moab::WriteHDF5::serial_create_file().
    FileHandle* file_ptr = (FileHandle*)file_handle;
    hid_t table_id;
    hsize_t dims[2];
    long first_id;
    API_BEGIN;
    if( !mhdf_check_valid_file( file_ptr, status ) ) return -1;
    if( dimension < 1 )
        mhdf_setFail( status, "Invalid argument: dimension = %d.", dimension );
        return -1;
    dims[0]  = (hsize_t)num_nodes;
    dims[1]  = (hsize_t)dimension;
    table_id = mhdf_create_table( file_ptr->hdf_handle, NODE_COORD_PATH, H5T_NATIVE_DOUBLE, 2, dims, status );
    if( table_id < 0 ) return -1;
    first_id = file_ptr->max_id + 1;
    if( !mhdf_create_scalar_attrib( table_id, START_ID_ATTRIB, H5T_NATIVE_LONG, &first_id, status ) )
        H5Dclose( table_id );
        return -1;
    *first_id_out = first_id;
    file_ptr->max_id += num_nodes;
    if( !mhdf_write_max_id( file_ptr, status ) )
        return -1;
    file_ptr->open_handle_count++;
    mhdf_setOkay( status );
    API_END_H( 1 );
    return table_id;
int mhdf_haveNodes ( mhdf_FileHandle  file,
MOAB, a Mesh-Oriented datABase, is a software component for creating, storing and accessing finite element mesh data.
Copyright 2004 Sandia Corporation. Under the terms of Contract DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government retains certain rights in this software.
This library is free software; you can redistribute it and/or modify it under the terms of the GNU Lesser General Public License as published by the Free Software Foundation; either version 2.1 of the License, or (at your option) any later version.
Definition at line 26 of file nodes.c.
References API_BEGIN, API_END, struct_FileHandle::hdf_handle, mhdf_check_valid_file(), mhdf_is_in_group(), mhdf_setFail(), mhdf_setOkay(), NODE_COORD_NAME, NODE_GROUP, NODE_GROUP_NAME, and ROOT_GROUP.
Referenced by mhdf_getFileSummary().
    FileHandle* file_ptr = (FileHandle*)file;
    hid_t root_id, node_id;
    int result;
    API_BEGIN;
#if defined( H5Gopen_vers ) && H5Gopen_vers > 1
    root_id = H5Gopen2( file_ptr->hdf_handle, ROOT_GROUP, H5P_DEFAULT );
#else
    root_id = H5Gopen( file_ptr->hdf_handle, ROOT_GROUP );
#endif
    if( root_id < 0 )
        mhdf_setFail( status, "H5Gopen( \"%s\" ) failed.", ROOT_GROUP );
        return -1;
    result = mhdf_is_in_group( root_id, NODE_GROUP_NAME, status );
    if( result < 1 )
        H5Gclose( root_id );
        return result;
    node_id = H5Gopen2( root_id, NODE_GROUP_NAME, H5P_DEFAULT );
#else
    node_id = H5Gopen( root_id, NODE_GROUP_NAME );
#endif
    if( node_id < 0 )
        mhdf_setFail( status, "H5Gopen( \"%s\" ) failed.", NODE_GROUP );
        return -1;
    result = mhdf_is_in_group( node_id, NODE_COORD_NAME, status );
    if( result >= 0 ) mhdf_setOkay( status );
    H5Gclose( node_id );
    API_END;
    return result;
hid_t mhdf_openNodeCoords ( mhdf_FileHandle  file_handle,
long *  num_nodes_out,
int *  dimension_out,
Parameters:
dimension_outNumber of coordinate values per node.
num_nodes_outThe number of nodes the table contains.
Returns:
Definition at line 118 of file nodes.c.
References API_BEGIN, API_END_H, struct_FileHandle::hdf_handle, mhdf_check_valid_file(), mhdf_open_table2(), mhdf_setOkay(), NODE_COORD_PATH, and struct_FileHandle::open_handle_count.
Referenced by main(), mhdf_getFileSummary(), and moab::WriteHDF5::write_nodes().
    hid_t table_id;
    hsize_t dims[2];
    API_BEGIN;
    table_id = mhdf_open_table2( file_ptr->hdf_handle, NODE_COORD_PATH, 2, dims, first_id_out, status );
    *num_nodes_out = dims[0];
    *dimension_out = dims[1];
    API_END_H( 1 );
    return table_id;
hid_t mhdf_openNodeCoordsSimple ( mhdf_FileHandle  file_handle,
Definition at line 142 of file nodes.c.
References API_BEGIN, API_END_H, struct_FileHandle::hdf_handle, mhdf_check_valid_file(), mhdf_open_table_simple(), mhdf_setOkay(), NODE_COORD_PATH, and struct_FileHandle::open_handle_count.
Referenced by moab::ReadHDF5::read_nodes().
    hid_t table_id;
    API_BEGIN;
    table_id = mhdf_open_table_simple( file_ptr->hdf_handle, NODE_COORD_PATH, status );
    API_END_H( 1 );
    return table_id;
void mhdf_readNodeCoord ( hid_t  data_handle,
long  offset,
long  count,
int  dimension,
double *  coords,
Read a single coordinate value (e.g. the 'x' coordinate) for a block of nodes.
Parameters:
data_handleHandle returned from mhdf_createNodeCoords or mhdf_openNodeCoords.
offsetTable row (node index) at which to start reading.
countNumber of rows (number of nodes) to read.
dimensionThe coordinate to read (0->x, 1->y, ...)
coordsBuffer in which to write node coordinate data.
Definition at line 219 of file nodes.c.
References API_BEGIN, API_END, and mhdf_read_column().
    API_BEGIN;
    mhdf_read_column( table_id, dimension, offset, count, H5T_NATIVE_DOUBLE, coords, H5P_DEFAULT, status );
    API_END;
void mhdf_readNodeCoords ( hid_t  data_handle,
long  offset,
long  count,
double *  coordinates,
Read interleaved coordinate data for a block of nodes
Parameters:
coordinatesBuffer in which to write node coordinate data.
Definition at line 177 of file nodes.c.
References API_BEGIN, API_END, and mhdf_read_data().
Referenced by main().
    API_BEGIN;
    mhdf_read_data( table_id, offset, count, H5T_NATIVE_DOUBLE, coords, H5P_DEFAULT, status );
    API_END;
void mhdf_readNodeCoordsWithOpt ( hid_t  data_handle,
long  offset,
long  count,
hid_t  read_prop,
Definition at line 183 of file nodes.c.
    API_BEGIN;
    mhdf_read_data( table_id, offset, count, H5T_NATIVE_DOUBLE, coords, prop, status );
    API_END;
void mhdf_readNodeCoordWithOpt ( hid_t  data_handle,
long  offset,
long  count,
int  dimension,
double *  coords,
hid_t  read_prop,
Definition at line 225 of file nodes.c.
    API_BEGIN;
    mhdf_read_column( table_id, dimension, offset, count, H5T_NATIVE_DOUBLE, coords, prop, status );
    API_END;
void mhdf_writeNodeCoord ( hid_t  data_handle,
long  offset,
long  count,
int  dimension,
const double *  coords,
Write a single coordinate value (e.g. the 'x' coordinate) for a block of nodes.
Parameters:
offsetTable row (node index) at which to start writing.
countNumber of rows (number of nodes) to write.
dimensionThe coordinate to write (0->x, 1->y, ...)
coordsCoordinate list.
Definition at line 195 of file nodes.c.
References API_BEGIN, API_END, and mhdf_write_column().
    API_BEGIN;
    mhdf_write_column( table_id, dimension, offset, count, H5T_NATIVE_DOUBLE, coords, H5P_DEFAULT, status );
    API_END;
void mhdf_writeNodeCoords ( hid_t  data_handle,
long  offset,
long  count,
Write interleaved coordinate data for a block of nodes
Parameters:
coordsInterleaved node coordinate data.
Definition at line 159 of file nodes.c.
References API_BEGIN, API_END, and mhdf_write_data().
    API_BEGIN;
    mhdf_write_data( table_id, offset, count, H5T_NATIVE_DOUBLE, coords, H5P_DEFAULT, status );
    API_END;
void mhdf_writeNodeCoordsWithOpt ( hid_t  data_handle,
long  offset,
long  count,
hid_t  write_prop,
Definition at line 165 of file nodes.c.
Referenced by moab::WriteHDF5::write_nodes().
    API_BEGIN;
    mhdf_write_data( table_id, offset, count, H5T_NATIVE_DOUBLE, coords, prop, status );
    API_END;
void mhdf_writeNodeCoordWithOpt ( hid_t  data_handle,
long  offset,
long  count,
int  dimension,
hid_t  write_prop,
Definition at line 206 of file nodes.c.
    API_BEGIN;
    mhdf_write_column( table_id, dimension, offset, count, H5T_NATIVE_DOUBLE, coords, prop, status );
    API_END;
