MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 //------------------------------------------------------------------------- 00017 // Filename : ReadHDF5.cpp 00018 // 00019 // Purpose : HDF5 Writer 00020 // 00021 // Creator : Jason Kraftcheck 00022 // 00023 // Creation Date : 04/18/04 00024 //------------------------------------------------------------------------- 00025 00026 #include <cassert> 00027 #include "moab/MOABConfig.h" 00028 /* Include our MPI header before any HDF5 because otherwise 00029 it will get included indirectly by HDF5 */ 00030 #ifdef MOAB_HAVE_MPI 00031 #include "moab_mpi.h" 00032 #include "moab/ParallelComm.hpp" 00033 #endif 00034 #include <H5Tpublic.h> 00035 #include <H5Ppublic.h> 00036 #include <H5Epublic.h> 00037 #include "moab/Interface.hpp" 00038 #include "Internals.hpp" 00039 #include "MBTagConventions.hpp" 00040 #include "ReadHDF5.hpp" 00041 #include "moab/CN.hpp" 00042 #include "moab/FileOptions.hpp" 00043 #include "moab/CpuTimer.hpp" 00044 #ifdef MOAB_HAVE_HDF5_PARALLEL 00045 #include <H5FDmpi.h> 00046 #include <H5FDmpio.h> 00047 #endif 00048 //#include "WriteHDF5.hpp" 00049 00050 #include <cstdlib> 00051 #include <cstring> 00052 #include <limits> 00053 #include <functional> 00054 #include <iostream> 00055 00056 #include "IODebugTrack.hpp" 00057 #include "ReadHDF5Dataset.hpp" 00058 #include "ReadHDF5VarLen.hpp" 00059 #include "moab_mpe.h" 00060 00061 namespace moab 00062 { 00063 00064 /* If true, coordinates are read in blocked format (all X values before 00065 * Y values before Z values.) If undefined, then all coordinates for a 00066 * given vertex are read at the same time. 00067 */ 00068 const bool DEFAULT_BLOCKED_COORDINATE_IO = false; 00069 00070 /* If true, file is opened first by root node only to read summary, 00071 * file is the closed and the summary is broadcast to all nodes, after 00072 * which all nodes open file in parallel to read data. If undefined, 00073 * file is opened once in parallel and all nodes read summary data. 00074 */ 00075 const bool DEFAULT_BCAST_SUMMARY = true; 00076 00077 /* If true and all processors are to read the same block of data, 00078 * read it on one and broadcast to others rather than using collective 00079 * io 00080 */ 00081 const bool DEFAULT_BCAST_DUPLICATE_READS = true; 00082 00083 #define READ_HDF5_BUFFER_SIZE ( 128 * 1024 * 1024 ) 00084 00085 #define assert_range( PTR, CNT ) \ 00086 assert( ( PTR ) >= (void*)dataBuffer ); \ 00087 assert( ( ( PTR ) + ( CNT ) ) <= (void*)( dataBuffer + bufferSize ) ); 00088 00089 // Call \c error function during HDF5 library errors to make 00090 // it easier to trap such errors in the debugger. This function 00091 // gets registered with the HDF5 library as a callback. It 00092 // works the same as the default (H5Eprint), except that it 00093 // also calls the \c error function as a no-op. 00094 #if defined( H5E_auto_t_vers ) && H5E_auto_t_vers > 1 00095 static herr_t handle_hdf5_error( hid_t stack, void* data ) 00096 { 00097 ReadHDF5::HDF5ErrorHandler* h = reinterpret_cast< ReadHDF5::HDF5ErrorHandler* >( data ); 00098 herr_t result = 0; 00099 if( h->func ) result = ( *h->func )( stack, h->data );MB_CHK_ERR_CONT( MB_FAILURE ); 00100 return result; 00101 } 00102 #else 00103 static herr_t handle_hdf5_error( void* data ) 00104 { 00105 ReadHDF5::HDF5ErrorHandler* h = reinterpret_cast< ReadHDF5::HDF5ErrorHandler* >( data ); 00106 herr_t result = 0; 00107 if( h->func ) result = ( *h->func )( h->data );MB_CHK_ERR_CONT( MB_FAILURE ); 00108 return result; 00109 } 00110 #endif 00111 00112 static void copy_sorted_file_ids( const EntityHandle* sorted_ids, long num_ids, Range& results ) 00113 { 00114 Range::iterator hint = results.begin(); 00115 long i = 0; 00116 while( i < num_ids ) 00117 { 00118 EntityHandle start = sorted_ids[i]; 00119 for( ++i; i < num_ids && sorted_ids[i] == 1 + sorted_ids[i - 1]; ++i ) 00120 ; 00121 hint = results.insert( hint, start, sorted_ids[i - 1] ); 00122 } 00123 } 00124 00125 static void intersect( const mhdf_EntDesc& group, const Range& range, Range& result ) 00126 { 00127 Range::const_iterator s, e; 00128 s = Range::lower_bound( range.begin(), range.end(), group.start_id ); 00129 e = Range::lower_bound( s, range.end(), group.start_id + group.count ); 00130 result.merge( s, e ); 00131 } 00132 00133 #define debug_barrier() debug_barrier_line( __LINE__ ) 00134 void ReadHDF5::debug_barrier_line( int lineno ) 00135 { 00136 #ifdef MOAB_HAVE_MPI 00137 if( mpiComm ) 00138 { 00139 const unsigned threshold = 2; 00140 static unsigned long count = 0; 00141 if( dbgOut.get_verbosity() >= threshold ) 00142 { 00143 dbgOut.printf( threshold, "*********** Debug Barrier %lu (@%d)***********\n", ++count, lineno ); 00144 MPI_Barrier( *mpiComm ); 00145 } 00146 } 00147 #else 00148 if( lineno ) 00149 { 00150 } 00151 #endif 00152 } 00153 00154 class CheckOpenReadHDF5Handles 00155 { 00156 int fileline; 00157 mhdf_FileHandle handle; 00158 int enter_count; 00159 00160 public: 00161 CheckOpenReadHDF5Handles( mhdf_FileHandle file, int line ) 00162 : fileline( line ), handle( file ), enter_count( mhdf_countOpenHandles( file ) ) 00163 { 00164 } 00165 ~CheckOpenReadHDF5Handles() 00166 { 00167 int new_count = mhdf_countOpenHandles( handle ); 00168 if( new_count != enter_count ) 00169 { 00170 std::cout << "Leaked HDF5 object handle in function at " << __FILE__ << ":" << fileline << std::endl 00171 << "Open at entrance: " << enter_count << std::endl 00172 << "Open at exit: " << new_count << std::endl; 00173 } 00174 } 00175 }; 00176 00177 #ifdef NDEBUG 00178 #define CHECK_OPEN_HANDLES 00179 #else 00180 #define CHECK_OPEN_HANDLES CheckOpenReadHDF5Handles check_open_handles_( filePtr, __LINE__ ) 00181 #endif 00182 00183 ReaderIface* ReadHDF5::factory( Interface* iface ) 00184 { 00185 return new ReadHDF5( iface ); 00186 } 00187 00188 ReadHDF5::ReadHDF5( Interface* iface ) 00189 : bufferSize( READ_HDF5_BUFFER_SIZE ), dataBuffer( NULL ), iFace( iface ), filePtr( 0 ), fileInfo( NULL ), 00190 readUtil( NULL ), handleType( 0 ), indepIO( H5P_DEFAULT ), collIO( H5P_DEFAULT ), myPcomm( NULL ), 00191 debugTrack( false ), dbgOut( stderr ), nativeParallel( false ), mpiComm( NULL ), 00192 blockedCoordinateIO( DEFAULT_BLOCKED_COORDINATE_IO ), bcastSummary( DEFAULT_BCAST_SUMMARY ), 00193 bcastDuplicateReads( DEFAULT_BCAST_DUPLICATE_READS ), setMeta( 0 ), timer( NULL ), cputime( false ) 00194 { 00195 } 00196 00197 ErrorCode ReadHDF5::init() 00198 { 00199 ErrorCode rval; 00200 00201 if( readUtil ) return MB_SUCCESS; 00202 00203 indepIO = collIO = H5P_DEFAULT; 00204 // WriteHDF5::register_known_tag_types(iFace); 00205 00206 handleType = H5Tcopy( H5T_NATIVE_ULONG ); 00207 if( handleType < 0 ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 00208 00209 if( H5Tset_size( handleType, sizeof( EntityHandle ) ) < 0 ) 00210 { 00211 H5Tclose( handleType ); 00212 MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 00213 } 00214 00215 rval = iFace->query_interface( readUtil ); 00216 if( MB_SUCCESS != rval ) 00217 { 00218 H5Tclose( handleType ); 00219 MB_SET_ERR( rval, "ReadHDF5 Failure" ); 00220 } 00221 00222 idMap.clear(); 00223 fileInfo = 0; 00224 debugTrack = false; 00225 myPcomm = 0; 00226 00227 return MB_SUCCESS; 00228 } 00229 00230 ReadHDF5::~ReadHDF5() 00231 { 00232 if( !readUtil ) // init() failed. 00233 return; 00234 00235 delete[] setMeta; 00236 setMeta = 0; 00237 iFace->release_interface( readUtil ); 00238 H5Tclose( handleType ); 00239 } 00240 00241 ErrorCode ReadHDF5::set_up_read( const char* filename, const FileOptions& opts ) 00242 { 00243 ErrorCode rval; 00244 mhdf_Status status; 00245 indepIO = collIO = H5P_DEFAULT; 00246 mpiComm = 0; 00247 00248 if( MB_SUCCESS != init() ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 00249 00250 #if defined( H5Eget_auto_vers ) && H5Eget_auto_vers > 1 00251 herr_t err = H5Eget_auto( H5E_DEFAULT, &errorHandler.func, &errorHandler.data ); 00252 #else 00253 herr_t err = H5Eget_auto( &errorHandler.func, &errorHandler.data ); 00254 #endif 00255 if( err < 0 ) 00256 { 00257 errorHandler.func = 0; 00258 errorHandler.data = 0; 00259 } 00260 else 00261 { 00262 #if defined( H5Eset_auto_vers ) && H5Eset_auto_vers > 1 00263 err = H5Eset_auto( H5E_DEFAULT, &handle_hdf5_error, &errorHandler ); 00264 #else 00265 err = H5Eset_auto( &handle_hdf5_error, &errorHandler ); 00266 #endif 00267 if( err < 0 ) 00268 { 00269 errorHandler.func = 0; 00270 errorHandler.data = 0; 00271 } 00272 } 00273 00274 // Set up debug output 00275 int tmpval; 00276 if( MB_SUCCESS == opts.get_int_option( "DEBUG_IO", 1, tmpval ) ) 00277 { 00278 dbgOut.set_verbosity( tmpval ); 00279 dbgOut.set_prefix( "H5M " ); 00280 } 00281 dbgOut.limit_output_to_first_N_procs( 32 ); 00282 00283 // Enable some extra checks for reads. Note: amongst other things this 00284 // will print errors if the entire file is not read, so if doing a 00285 // partial read that is not a parallel read, this should be disabled. 00286 debugTrack = ( MB_SUCCESS == opts.get_null_option( "DEBUG_BINIO" ) ); 00287 00288 opts.get_toggle_option( "BLOCKED_COORDINATE_IO", DEFAULT_BLOCKED_COORDINATE_IO, blockedCoordinateIO ); 00289 opts.get_toggle_option( "BCAST_SUMMARY", DEFAULT_BCAST_SUMMARY, bcastSummary ); 00290 opts.get_toggle_option( "BCAST_DUPLICATE_READS", DEFAULT_BCAST_DUPLICATE_READS, bcastDuplicateReads ); 00291 00292 // Handle parallel options 00293 bool use_mpio = ( MB_SUCCESS == opts.get_null_option( "USE_MPIO" ) ); 00294 rval = opts.match_option( "PARALLEL", "READ_PART" ); 00295 bool parallel = ( rval != MB_ENTITY_NOT_FOUND ); 00296 nativeParallel = ( rval == MB_SUCCESS ); 00297 if( use_mpio && !parallel ) 00298 { 00299 MB_SET_ERR( MB_NOT_IMPLEMENTED, "'USE_MPIO' option specified w/out 'PARALLEL' option" ); 00300 } 00301 00302 // This option is intended for testing purposes only, and thus 00303 // is not documented anywhere. Decreasing the buffer size can 00304 // expose bugs that would otherwise only be seen when reading 00305 // very large files. 00306 rval = opts.get_int_option( "BUFFER_SIZE", bufferSize ); 00307 if( MB_SUCCESS != rval ) 00308 { 00309 bufferSize = READ_HDF5_BUFFER_SIZE; 00310 } 00311 else if( bufferSize < (int)std::max( sizeof( EntityHandle ), sizeof( void* ) ) ) 00312 { 00313 MB_CHK_ERR( MB_INVALID_SIZE ); 00314 } 00315 00316 dataBuffer = (char*)malloc( bufferSize ); 00317 if( !dataBuffer ) MB_CHK_ERR( MB_MEMORY_ALLOCATION_FAILED ); 00318 00319 if( use_mpio || nativeParallel ) 00320 { 00321 00322 #ifndef MOAB_HAVE_HDF5_PARALLEL 00323 free( dataBuffer ); 00324 dataBuffer = NULL; 00325 MB_SET_ERR( MB_NOT_IMPLEMENTED, "MOAB not configured with parallel HDF5 support" ); 00326 #else 00327 MPI_Info info = MPI_INFO_NULL; 00328 std::string cb_size; 00329 rval = opts.get_str_option( "CB_BUFFER_SIZE", cb_size ); 00330 if( MB_SUCCESS == rval ) 00331 { 00332 MPI_Info_create( &info ); 00333 MPI_Info_set( info, const_cast< char* >( "cb_buffer_size" ), const_cast< char* >( cb_size.c_str() ) ); 00334 } 00335 00336 int pcomm_no = 0; 00337 rval = opts.get_int_option( "PARALLEL_COMM", pcomm_no ); 00338 if( rval == MB_TYPE_OUT_OF_RANGE ) 00339 { 00340 MB_SET_ERR( rval, "Invalid value for PARALLEL_COMM option" ); 00341 } 00342 myPcomm = ParallelComm::get_pcomm( iFace, pcomm_no ); 00343 if( 0 == myPcomm ) 00344 { 00345 myPcomm = new ParallelComm( iFace, MPI_COMM_WORLD ); 00346 } 00347 const int rank = myPcomm->proc_config().proc_rank(); 00348 dbgOut.set_rank( rank ); 00349 dbgOut.limit_output_to_first_N_procs( 32 ); 00350 mpiComm = new MPI_Comm( myPcomm->proc_config().proc_comm() ); 00351 00352 #ifndef H5_MPI_COMPLEX_DERIVED_DATATYPE_WORKS 00353 dbgOut.print( 1, "H5_MPI_COMPLEX_DERIVED_DATATYPE_WORKS is not defined\n" ); 00354 #endif 00355 00356 // Open the file in serial on root to read summary 00357 dbgOut.tprint( 1, "Getting file summary\n" ); 00358 fileInfo = 0; 00359 00360 hid_t file_prop; 00361 if( bcastSummary ) 00362 { 00363 unsigned long size = 0; 00364 if( rank == 0 ) 00365 { 00366 file_prop = H5Pcreate( H5P_FILE_ACCESS ); 00367 err = H5Pset_fapl_mpio( file_prop, MPI_COMM_SELF, MPI_INFO_NULL ); 00368 assert( file_prop >= 0 ); 00369 assert( err >= 0 ); 00370 filePtr = mhdf_openFileWithOpt( filename, 0, NULL, handleType, file_prop, &status ); 00371 H5Pclose( file_prop ); 00372 00373 if( filePtr ) 00374 { 00375 fileInfo = mhdf_getFileSummary( filePtr, handleType, &status, 00376 0 ); // no extra set info 00377 if( !is_error( status ) ) 00378 { 00379 size = fileInfo->total_size; 00380 fileInfo->offset = (unsigned char*)fileInfo; 00381 } 00382 } 00383 mhdf_closeFile( filePtr, &status ); 00384 if( fileInfo && mhdf_isError( &status ) ) 00385 { 00386 free( fileInfo ); 00387 fileInfo = NULL; 00388 } 00389 } 00390 00391 dbgOut.tprint( 1, "Communicating file summary\n" ); 00392 int mpi_err = MPI_Bcast( &size, 1, MPI_UNSIGNED_LONG, 0, myPcomm->proc_config().proc_comm() ); 00393 if( mpi_err || !size ) return MB_FAILURE; 00394 00395 if( rank != 0 ) fileInfo = reinterpret_cast< mhdf_FileDesc* >( malloc( size ) ); 00396 00397 MPI_Bcast( fileInfo, size, MPI_BYTE, 0, myPcomm->proc_config().proc_comm() ); 00398 00399 if( rank != 0 ) mhdf_fixFileDesc( fileInfo, reinterpret_cast< mhdf_FileDesc* >( fileInfo->offset ) ); 00400 } 00401 00402 file_prop = H5Pcreate( H5P_FILE_ACCESS ); 00403 err = H5Pset_fapl_mpio( file_prop, myPcomm->proc_config().proc_comm(), info ); 00404 assert( file_prop >= 0 ); 00405 assert( err >= 0 ); 00406 00407 collIO = H5Pcreate( H5P_DATASET_XFER ); 00408 assert( collIO > 0 ); 00409 err = H5Pset_dxpl_mpio( collIO, H5FD_MPIO_COLLECTIVE ); 00410 assert( err >= 0 ); 00411 indepIO = nativeParallel ? H5P_DEFAULT : collIO; 00412 00413 // Re-open file in parallel 00414 dbgOut.tprintf( 1, "Opening \"%s\" for parallel IO\n", filename ); 00415 filePtr = mhdf_openFileWithOpt( filename, 0, NULL, handleType, file_prop, &status ); 00416 00417 H5Pclose( file_prop ); 00418 if( !filePtr ) 00419 { 00420 free( dataBuffer ); 00421 dataBuffer = NULL; 00422 H5Pclose( indepIO ); 00423 if( collIO != indepIO ) H5Pclose( collIO ); 00424 collIO = indepIO = H5P_DEFAULT; 00425 MB_SET_ERR( MB_FAILURE, mhdf_message( &status ) ); 00426 } 00427 00428 if( !bcastSummary ) 00429 { 00430 fileInfo = mhdf_getFileSummary( filePtr, handleType, &status, 0 ); 00431 if( is_error( status ) ) 00432 { 00433 free( dataBuffer ); 00434 dataBuffer = NULL; 00435 mhdf_closeFile( filePtr, &status ); 00436 MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 00437 } 00438 } 00439 #endif // HDF5_PARALLEL 00440 } 00441 else 00442 { 00443 // Open the file 00444 filePtr = mhdf_openFile( filename, 0, NULL, handleType, &status ); 00445 if( !filePtr ) 00446 { 00447 free( dataBuffer ); 00448 dataBuffer = NULL; 00449 MB_SET_ERR( MB_FAILURE, mhdf_message( &status ) ); 00450 } 00451 00452 // Get file info 00453 fileInfo = mhdf_getFileSummary( filePtr, handleType, &status, 0 ); 00454 if( is_error( status ) ) 00455 { 00456 free( dataBuffer ); 00457 dataBuffer = NULL; 00458 mhdf_closeFile( filePtr, &status ); 00459 MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 00460 } 00461 } 00462 00463 ReadHDF5Dataset::default_hyperslab_selection_limit(); 00464 int hslimit; 00465 rval = opts.get_int_option( "HYPERSLAB_SELECT_LIMIT", hslimit ); 00466 if( MB_SUCCESS == rval && hslimit > 0 ) 00467 ReadHDF5Dataset::set_hyperslab_selection_limit( hslimit ); 00468 else 00469 ReadHDF5Dataset::default_hyperslab_selection_limit(); 00470 if( MB_SUCCESS != opts.get_null_option( "HYPERSLAB_OR" ) && 00471 ( MB_SUCCESS == opts.get_null_option( "HYPERSLAB_APPEND" ) || HDF5_can_append_hyperslabs() ) ) 00472 { 00473 ReadHDF5Dataset::append_hyperslabs(); 00474 if( MB_SUCCESS != opts.get_int_option( "HYPERSLAB_SELECT_LIMIT", hslimit ) ) 00475 ReadHDF5Dataset::set_hyperslab_selection_limit( std::numeric_limits< int >::max() ); 00476 dbgOut.print( 1, "Using H5S_APPEND for hyperslab selection\n" ); 00477 } 00478 00479 return MB_SUCCESS; 00480 } 00481 00482 ErrorCode ReadHDF5::clean_up_read( const FileOptions& ) 00483 { 00484 HDF5ErrorHandler handler; 00485 #if defined( H5Eget_auto_vers ) && H5Eget_auto_vers > 1 00486 herr_t err = H5Eget_auto( H5E_DEFAULT, &handler.func, &handler.data ); 00487 #else 00488 herr_t err = H5Eget_auto( &handler.func, &handler.data ); 00489 #endif 00490 if( err >= 0 && handler.func == &handle_hdf5_error ) 00491 { 00492 assert( handler.data == &errorHandler ); 00493 #if defined( H5Eget_auto_vers ) && H5Eget_auto_vers > 1 00494 H5Eset_auto( H5E_DEFAULT, errorHandler.func, errorHandler.data ); 00495 #else 00496 H5Eset_auto( errorHandler.func, errorHandler.data ); 00497 #endif 00498 } 00499 00500 free( dataBuffer ); 00501 dataBuffer = NULL; 00502 free( fileInfo ); 00503 fileInfo = NULL; 00504 delete mpiComm; 00505 mpiComm = 0; 00506 00507 if( indepIO != H5P_DEFAULT ) H5Pclose( indepIO ); 00508 if( collIO != indepIO ) H5Pclose( collIO ); 00509 collIO = indepIO = H5P_DEFAULT; 00510 00511 delete[] setMeta; 00512 setMeta = 0; 00513 00514 mhdf_Status status; 00515 mhdf_closeFile( filePtr, &status ); 00516 filePtr = 0; 00517 return is_error( status ) ? MB_FAILURE : MB_SUCCESS; 00518 } 00519 00520 ErrorCode ReadHDF5::load_file( const char* filename, 00521 const EntityHandle* file_set, 00522 const FileOptions& opts, 00523 const ReaderIface::SubsetList* subset_list, 00524 const Tag* file_id_tag ) 00525 { 00526 ErrorCode rval; 00527 00528 rval = set_up_read( filename, opts ); 00529 if( MB_SUCCESS != rval ) 00530 { 00531 clean_up_read( opts ); 00532 return rval; 00533 } 00534 // See if we need to report times 00535 00536 rval = opts.get_null_option( "CPUTIME" ); 00537 if( MB_SUCCESS == rval ) 00538 { 00539 cputime = true; 00540 timer = new CpuTimer; 00541 for( int i = 0; i < NUM_TIMES; i++ ) 00542 _times[i] = 0; 00543 } 00544 00545 // We read the entire set description table regardless of partial 00546 // or complete reads or serial vs parallel reads 00547 rval = read_all_set_meta(); 00548 00549 if( cputime ) _times[SET_META_TIME] = timer->time_elapsed(); 00550 if( subset_list && MB_SUCCESS == rval ) 00551 rval = load_file_partial( subset_list->tag_list, subset_list->tag_list_length, subset_list->num_parts, 00552 subset_list->part_number, opts ); 00553 else 00554 rval = load_file_impl( opts ); 00555 00556 if( MB_SUCCESS == rval && file_id_tag ) 00557 { 00558 dbgOut.tprint( 1, "Storing file IDs in tag\n" ); 00559 rval = store_file_ids( *file_id_tag ); 00560 } 00561 ErrorCode rval3 = opts.get_null_option( "STORE_SETS_FILEIDS" ); 00562 if( MB_SUCCESS == rval3 ) 00563 { 00564 rval = store_sets_file_ids(); 00565 if( MB_SUCCESS != rval ) return rval; 00566 } 00567 00568 if( cputime ) _times[STORE_FILE_IDS_TIME] = timer->time_elapsed(); 00569 00570 if( MB_SUCCESS == rval && 0 != file_set ) 00571 { 00572 dbgOut.tprint( 1, "Reading QA records\n" ); 00573 rval = read_qa( *file_set ); 00574 } 00575 00576 if( cputime ) _times[READ_QA_TIME] = timer->time_elapsed(); 00577 dbgOut.tprint( 1, "Cleaning up\n" ); 00578 ErrorCode rval2 = clean_up_read( opts ); 00579 if( rval == MB_SUCCESS && rval2 != MB_SUCCESS ) rval = rval2; 00580 00581 if( MB_SUCCESS == rval ) 00582 dbgOut.tprint( 1, "Read finished.\n" ); 00583 else 00584 { 00585 std::string msg; 00586 iFace->get_last_error( msg ); 00587 dbgOut.tprintf( 1, "READ FAILED (ERROR CODE %s): %s\n", ErrorCodeStr[rval], msg.c_str() ); 00588 } 00589 00590 if( cputime ) 00591 { 00592 _times[TOTAL_TIME] = timer->time_since_birth(); 00593 print_times(); 00594 delete timer; 00595 } 00596 if( H5P_DEFAULT != collIO ) H5Pclose( collIO ); 00597 if( H5P_DEFAULT != indepIO ) H5Pclose( indepIO ); 00598 collIO = indepIO = H5P_DEFAULT; 00599 00600 return rval; 00601 } 00602 00603 ErrorCode ReadHDF5::load_file_impl( const FileOptions& ) 00604 { 00605 ErrorCode rval; 00606 mhdf_Status status; 00607 int i; 00608 00609 CHECK_OPEN_HANDLES; 00610 00611 dbgOut.tprint( 1, "Reading all nodes...\n" ); 00612 Range ids; 00613 if( fileInfo->nodes.count ) 00614 { 00615 ids.insert( fileInfo->nodes.start_id, fileInfo->nodes.start_id + fileInfo->nodes.count - 1 ); 00616 rval = read_nodes( ids ); 00617 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 00618 } 00619 00620 dbgOut.tprint( 1, "Reading all element connectivity...\n" ); 00621 std::vector< int > polyhedra; // Need to do these last so that faces are loaded 00622 for( i = 0; i < fileInfo->num_elem_desc; ++i ) 00623 { 00624 if( CN::EntityTypeFromName( fileInfo->elems[i].type ) == MBPOLYHEDRON ) 00625 { 00626 polyhedra.push_back( i ); 00627 continue; 00628 } 00629 00630 rval = read_elems( i ); 00631 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 00632 } 00633 for( std::vector< int >::iterator it = polyhedra.begin(); it != polyhedra.end(); ++it ) 00634 { 00635 rval = read_elems( *it ); 00636 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 00637 } 00638 00639 dbgOut.tprint( 1, "Reading all sets...\n" ); 00640 ids.clear(); 00641 if( fileInfo->sets.count ) 00642 { 00643 ids.insert( fileInfo->sets.start_id, fileInfo->sets.start_id + fileInfo->sets.count - 1 ); 00644 rval = read_sets( ids ); 00645 if( rval != MB_SUCCESS ) 00646 { 00647 MB_SET_ERR( rval, "ReadHDF5 Failure" ); 00648 } 00649 } 00650 00651 dbgOut.tprint( 1, "Reading all adjacencies...\n" ); 00652 for( i = 0; i < fileInfo->num_elem_desc; ++i ) 00653 { 00654 if( !fileInfo->elems[i].have_adj ) continue; 00655 00656 long table_len; 00657 hid_t table = mhdf_openAdjacency( filePtr, fileInfo->elems[i].handle, &table_len, &status ); 00658 if( is_error( status ) ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 00659 00660 rval = read_adjacencies( table, table_len ); 00661 mhdf_closeData( filePtr, table, &status ); 00662 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 00663 if( is_error( status ) ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 00664 } 00665 00666 dbgOut.tprint( 1, "Reading all tags...\n" ); 00667 for( i = 0; i < fileInfo->num_tag_desc; ++i ) 00668 { 00669 rval = read_tag( i ); 00670 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 00671 } 00672 00673 dbgOut.tprint( 1, "Core read finished. Cleaning up...\n" ); 00674 return MB_SUCCESS; 00675 } 00676 00677 ErrorCode ReadHDF5::find_int_tag( const char* name, int& index ) 00678 { 00679 for( index = 0; index < fileInfo->num_tag_desc; ++index ) 00680 if( !strcmp( name, fileInfo->tags[index].name ) ) break; 00681 00682 if( index == fileInfo->num_tag_desc ) 00683 { 00684 MB_SET_ERR( MB_TAG_NOT_FOUND, "File does not contain subset tag '" << name << "'" ); 00685 } 00686 00687 if( fileInfo->tags[index].type != mhdf_INTEGER || fileInfo->tags[index].size != 1 ) 00688 { 00689 MB_SET_ERR( MB_TAG_NOT_FOUND, "Tag ' " << name << "' does not contain single integer value" ); 00690 } 00691 00692 return MB_SUCCESS; 00693 } 00694 00695 ErrorCode ReadHDF5::get_subset_ids( const ReaderIface::IDTag* subset_list, int subset_list_length, Range& file_ids ) 00696 { 00697 ErrorCode rval; 00698 00699 for( int i = 0; i < subset_list_length; ++i ) 00700 { 00701 int tag_index; 00702 rval = find_int_tag( subset_list[i].tag_name, tag_index ); 00703 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 00704 00705 Range tmp_file_ids; 00706 if( !subset_list[i].num_tag_values ) 00707 { 00708 rval = get_tagged_entities( tag_index, tmp_file_ids ); 00709 } 00710 else 00711 { 00712 std::vector< int > ids( subset_list[i].tag_values, 00713 subset_list[i].tag_values + subset_list[i].num_tag_values ); 00714 std::sort( ids.begin(), ids.end() ); 00715 rval = search_tag_values( tag_index, ids, tmp_file_ids ); 00716 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 00717 } 00718 00719 if( tmp_file_ids.empty() ) MB_CHK_ERR( MB_ENTITY_NOT_FOUND ); 00720 00721 if( i == 0 ) 00722 file_ids.swap( tmp_file_ids ); 00723 else 00724 file_ids = intersect( tmp_file_ids, file_ids ); 00725 } 00726 00727 return MB_SUCCESS; 00728 } 00729 00730 ErrorCode ReadHDF5::get_partition( Range& tmp_file_ids, int num_parts, int part_number ) 00731 { 00732 CHECK_OPEN_HANDLES; 00733 00734 // Check that the tag only identified sets 00735 if( (unsigned long)fileInfo->sets.start_id > tmp_file_ids.front() ) 00736 { 00737 dbgOut.print( 2, "Ignoring non-set entities with partition set tag\n" ); 00738 tmp_file_ids.erase( tmp_file_ids.begin(), tmp_file_ids.lower_bound( (EntityHandle)fileInfo->sets.start_id ) ); 00739 } 00740 unsigned long set_end = (unsigned long)fileInfo->sets.start_id + fileInfo->sets.count; 00741 if( tmp_file_ids.back() >= set_end ) 00742 { 00743 dbgOut.print( 2, "Ignoring non-set entities with partition set tag\n" ); 00744 tmp_file_ids.erase( tmp_file_ids.upper_bound( (EntityHandle)set_end ), tmp_file_ids.end() ); 00745 } 00746 00747 Range::iterator s = tmp_file_ids.begin(); 00748 size_t num_per_proc = tmp_file_ids.size() / num_parts; 00749 size_t num_extra = tmp_file_ids.size() % num_parts; 00750 Range::iterator e; 00751 if( part_number < (long)num_extra ) 00752 { 00753 s += ( num_per_proc + 1 ) * part_number; 00754 e = s; 00755 e += ( num_per_proc + 1 ); 00756 } 00757 else 00758 { 00759 s += num_per_proc * part_number + num_extra; 00760 e = s; 00761 e += num_per_proc; 00762 } 00763 tmp_file_ids.erase( e, tmp_file_ids.end() ); 00764 tmp_file_ids.erase( tmp_file_ids.begin(), s ); 00765 00766 return MB_SUCCESS; 00767 } 00768 00769 ErrorCode ReadHDF5::load_file_partial( const ReaderIface::IDTag* subset_list, 00770 int subset_list_length, 00771 int num_parts, 00772 int part_number, 00773 const FileOptions& opts ) 00774 { 00775 mhdf_Status status; 00776 00777 static MPEState mpe_event( "ReadHDF5", "yellow" ); 00778 00779 mpe_event.start( "gather parts" ); 00780 00781 CHECK_OPEN_HANDLES; 00782 00783 for( int i = 0; i < subset_list_length; ++i ) 00784 { 00785 dbgOut.printf( 2, "Select by \"%s\" with num_tag_values = %d\n", subset_list[i].tag_name, 00786 subset_list[i].num_tag_values ); 00787 if( subset_list[i].num_tag_values ) 00788 { 00789 assert( 0 != subset_list[i].tag_values ); 00790 dbgOut.printf( 2, " \"%s\" values = { %d", subset_list[i].tag_name, subset_list[i].tag_values[0] ); 00791 for( int j = 1; j < subset_list[i].num_tag_values; ++j ) 00792 dbgOut.printf( 2, ", %d", subset_list[i].tag_values[j] ); 00793 dbgOut.printf( 2, " }\n" ); 00794 } 00795 } 00796 if( num_parts ) dbgOut.printf( 2, "Partition with num_parts = %d and part_number = %d\n", num_parts, part_number ); 00797 00798 dbgOut.tprint( 1, "RETRIEVING TAGGED ENTITIES\n" ); 00799 00800 Range file_ids; 00801 ErrorCode rval = get_subset_ids( subset_list, subset_list_length, file_ids ); 00802 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 00803 00804 if( cputime ) _times[SUBSET_IDS_TIME] = timer->time_elapsed(); 00805 00806 if( num_parts ) 00807 { 00808 /*if (num_parts>(int)file_ids.size()) 00809 { 00810 MB_SET_ERR(MB_FAILURE, "Only " << file_ids.size() << " parts to distribute to " << 00811 num_parts << " processes."); 00812 }*/ 00813 rval = get_partition( file_ids, num_parts, part_number ); 00814 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 00815 } 00816 00817 if( cputime ) _times[GET_PARTITION_TIME] = timer->time_elapsed(); 00818 00819 dbgOut.print_ints( 4, "Set file IDs for partial read: ", file_ids ); 00820 mpe_event.end(); 00821 mpe_event.start( "gather related sets" ); 00822 dbgOut.tprint( 1, "GATHERING ADDITIONAL ENTITIES\n" ); 00823 00824 enum RecusiveSetMode 00825 { 00826 RSM_NONE, 00827 RSM_SETS, 00828 RSM_CONTENTS 00829 }; 00830 const char* const set_opts[] = { "NONE", "SETS", "CONTENTS", NULL }; 00831 int child_mode; 00832 rval = opts.match_option( "CHILDREN", set_opts, child_mode ); 00833 if( MB_ENTITY_NOT_FOUND == rval ) 00834 child_mode = RSM_CONTENTS; 00835 else if( MB_SUCCESS != rval ) 00836 { 00837 MB_SET_ERR( rval, "Invalid value for 'CHILDREN' option" ); 00838 } 00839 int content_mode; 00840 rval = opts.match_option( "SETS", set_opts, content_mode ); 00841 if( MB_ENTITY_NOT_FOUND == rval ) 00842 content_mode = RSM_CONTENTS; 00843 else if( MB_SUCCESS != rval ) 00844 { 00845 MB_SET_ERR( rval, "Invalid value for 'SETS' option" ); 00846 } 00847 00848 // If we want the contents of contained/child sets, 00849 // search for them now (before gathering the non-set contents 00850 // of the sets.) 00851 Range sets; 00852 intersect( fileInfo->sets, file_ids, sets ); 00853 if( content_mode == RSM_CONTENTS || child_mode == RSM_CONTENTS ) 00854 { 00855 dbgOut.tprint( 1, " doing read_set_ids_recursive\n" ); 00856 rval = read_set_ids_recursive( sets, content_mode == RSM_CONTENTS, child_mode == RSM_CONTENTS ); 00857 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 00858 } 00859 00860 if( cputime ) _times[GET_SET_IDS_TIME] = timer->time_elapsed(); 00861 debug_barrier(); 00862 00863 // Get elements and vertices contained in sets 00864 dbgOut.tprint( 1, " doing get_set_contents\n" ); 00865 rval = get_set_contents( sets, file_ids ); 00866 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 00867 00868 if( cputime ) _times[GET_SET_CONTENTS_TIME] = timer->time_elapsed(); 00869 00870 dbgOut.print_ints( 5, "File IDs for partial read: ", file_ids ); 00871 debug_barrier(); 00872 mpe_event.end(); 00873 dbgOut.tprint( 1, "GATHERING NODE IDS\n" ); 00874 00875 // Figure out the maximum dimension of entity to be read 00876 int max_dim = 0; 00877 for( int i = 0; i < fileInfo->num_elem_desc; ++i ) 00878 { 00879 EntityType type = CN::EntityTypeFromName( fileInfo->elems[i].type ); 00880 if( type <= MBVERTEX || type >= MBENTITYSET ) 00881 { 00882 assert( false ); // For debug code die for unknown element types 00883 continue; // For release code, skip unknown element types 00884 } 00885 int dim = CN::Dimension( type ); 00886 if( dim > max_dim ) 00887 { 00888 Range subset; 00889 intersect( fileInfo->elems[i].desc, file_ids, subset ); 00890 if( !subset.empty() ) max_dim = dim; 00891 } 00892 } 00893 #ifdef MOAB_HAVE_MPI 00894 if( nativeParallel ) 00895 { 00896 int send = max_dim; 00897 MPI_Allreduce( &send, &max_dim, 1, MPI_INT, MPI_MAX, *mpiComm ); 00898 } 00899 #endif 00900 00901 // If input contained any polyhedra, then need to get faces 00902 // of the polyhedra before the next loop because we need to 00903 // read said faces in that loop. 00904 for( int i = 0; i < fileInfo->num_elem_desc; ++i ) 00905 { 00906 EntityType type = CN::EntityTypeFromName( fileInfo->elems[i].type ); 00907 if( type != MBPOLYHEDRON ) continue; 00908 00909 debug_barrier(); 00910 dbgOut.print( 2, " Getting polyhedra faces\n" ); 00911 mpe_event.start( "reading connectivity for ", fileInfo->elems[i].handle ); 00912 00913 Range polyhedra; 00914 intersect( fileInfo->elems[i].desc, file_ids, polyhedra ); 00915 rval = read_elems( i, polyhedra, &file_ids ); 00916 mpe_event.end( rval ); 00917 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 00918 } 00919 00920 if( cputime ) _times[GET_POLYHEDRA_TIME] = timer->time_elapsed(); 00921 // Get node file ids for all elements 00922 Range nodes; 00923 intersect( fileInfo->nodes, file_ids, nodes ); 00924 for( int i = 0; i < fileInfo->num_elem_desc; ++i ) 00925 { 00926 EntityType type = CN::EntityTypeFromName( fileInfo->elems[i].type ); 00927 if( type <= MBVERTEX || type >= MBENTITYSET ) 00928 { 00929 assert( false ); // For debug code die for unknown element types 00930 continue; // For release code, skip unknown element types 00931 } 00932 if( MBPOLYHEDRON == type ) continue; 00933 00934 debug_barrier(); 00935 dbgOut.printf( 2, " Getting element node IDs for: %s\n", fileInfo->elems[i].handle ); 00936 00937 Range subset; 00938 intersect( fileInfo->elems[i].desc, file_ids, subset ); 00939 mpe_event.start( "reading connectivity for ", fileInfo->elems[i].handle ); 00940 00941 // If dimension is max_dim, then we can create the elements now 00942 // so we don't have to read the table again later (connectivity 00943 // will be fixed up after nodes are created when update_connectivity()) 00944 // is called. For elements of a smaller dimension, we just build 00945 // the node ID range now because a) we'll have to read the whole 00946 // connectivity table again later, and b) we don't want to worry 00947 // about accidentally creating multiple copies of the same element. 00948 if( CN::Dimension( type ) == max_dim ) 00949 rval = read_elems( i, subset, &nodes ); 00950 else 00951 rval = read_elems( i, subset, nodes ); 00952 mpe_event.end( rval ); 00953 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 00954 } 00955 if( cputime ) _times[GET_ELEMENTS_TIME] = timer->time_elapsed(); 00956 debug_barrier(); 00957 mpe_event.start( "read coords" ); 00958 dbgOut.tprintf( 1, "READING NODE COORDINATES (%lu nodes in %lu selects)\n", (unsigned long)nodes.size(), 00959 (unsigned long)nodes.psize() ); 00960 00961 // Read node coordinates and create vertices in MOAB 00962 // NOTE: This populates the RangeMap with node file ids, 00963 // which is expected by read_node_adj_elems. 00964 rval = read_nodes( nodes ); 00965 mpe_event.end( rval ); 00966 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 00967 00968 if( cputime ) _times[GET_NODES_TIME] = timer->time_elapsed(); 00969 00970 debug_barrier(); 00971 dbgOut.tprint( 1, "READING ELEMENTS\n" ); 00972 00973 // Decide if we need to read additional elements 00974 enum SideMode 00975 { 00976 SM_EXPLICIT, 00977 SM_NODES, 00978 SM_SIDES 00979 }; 00980 int side_mode; 00981 const char* const options[] = { "EXPLICIT", "NODES", "SIDES", 0 }; 00982 rval = opts.match_option( "ELEMENTS", options, side_mode ); 00983 if( MB_ENTITY_NOT_FOUND == rval ) 00984 { 00985 // If only nodes were specified, then default to "NODES", otherwise 00986 // default to "SIDES". 00987 if( 0 == max_dim ) 00988 side_mode = SM_NODES; 00989 else 00990 side_mode = SM_SIDES; 00991 } 00992 else if( MB_SUCCESS != rval ) 00993 { 00994 MB_SET_ERR( rval, "Invalid value for 'ELEMENTS' option" ); 00995 } 00996 00997 if( side_mode == SM_SIDES /*ELEMENTS=SIDES*/ && max_dim == 0 /*node-based*/ ) 00998 { 00999 // Read elements until we find something. Once we find something, 01000 // read only elements of the same dimension. NOTE: loop termination 01001 // criterion changes on both sides (max_dim can be changed in loop 01002 // body). 01003 for( int dim = 3; dim >= max_dim; --dim ) 01004 { 01005 for( int i = 0; i < fileInfo->num_elem_desc; ++i ) 01006 { 01007 EntityType type = CN::EntityTypeFromName( fileInfo->elems[i].type ); 01008 if( CN::Dimension( type ) == dim ) 01009 { 01010 debug_barrier(); 01011 dbgOut.tprintf( 2, " Reading node-adjacent elements for: %s\n", fileInfo->elems[i].handle ); 01012 mpe_event.start( "reading connectivity for ", fileInfo->elems[i].handle ); 01013 Range ents; 01014 rval = read_node_adj_elems( fileInfo->elems[i] ); 01015 mpe_event.end( rval ); 01016 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 01017 if( !ents.empty() ) max_dim = 3; 01018 } 01019 } 01020 } 01021 } 01022 01023 if( cputime ) _times[GET_NODEADJ_TIME] = timer->time_elapsed(); 01024 Range side_entities; 01025 if( side_mode != SM_EXPLICIT /*ELEMENTS=NODES || ELEMENTS=SIDES*/ ) 01026 { 01027 if( 0 == max_dim ) max_dim = 4; 01028 // Now read any additional elements for which we've already read all 01029 // of the nodes. 01030 for( int dim = max_dim - 1; dim > 0; --dim ) 01031 { 01032 for( int i = 0; i < fileInfo->num_elem_desc; ++i ) 01033 { 01034 EntityType type = CN::EntityTypeFromName( fileInfo->elems[i].type ); 01035 if( CN::Dimension( type ) == dim ) 01036 { 01037 debug_barrier(); 01038 dbgOut.tprintf( 2, " Reading node-adjacent elements for: %s\n", fileInfo->elems[i].handle ); 01039 mpe_event.start( "reading connectivity for ", fileInfo->elems[i].handle ); 01040 rval = read_node_adj_elems( fileInfo->elems[i], &side_entities ); 01041 mpe_event.end( rval ); 01042 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 01043 } 01044 } 01045 } 01046 } 01047 01048 // We need to do this here for polyhedra to be handled correctly. 01049 // We have to wait until the faces are read in the above code block, 01050 // but need to create the connectivity before doing update_connectivity, 01051 // which might otherwise delete polyhedra faces. 01052 if( cputime ) _times[GET_SIDEELEM_TIME] = timer->time_elapsed(); 01053 01054 debug_barrier(); 01055 dbgOut.tprint( 1, "UPDATING CONNECTIVITY ARRAYS FOR READ ELEMENTS\n" ); 01056 mpe_event.start( "updating connectivity for elements read before vertices" ); 01057 rval = update_connectivity(); 01058 mpe_event.end(); 01059 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 01060 01061 if( cputime ) _times[UPDATECONN_TIME] = timer->time_elapsed(); 01062 01063 dbgOut.tprint( 1, "READING ADJACENCIES\n" ); 01064 for( int i = 0; i < fileInfo->num_elem_desc; ++i ) 01065 { 01066 if (fileInfo->elems[i].have_adj /*&& 01067 idMap.intersects(fileInfo->elems[i].desc.start_id, fileInfo->elems[i].desc.count) */) 01068 { 01069 mpe_event.start( "reading adjacencies for ", fileInfo->elems[i].handle ); 01070 long len; 01071 hid_t th = mhdf_openAdjacency( filePtr, fileInfo->elems[i].handle, &len, &status ); 01072 if( is_error( status ) ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 01073 01074 rval = read_adjacencies( th, len ); 01075 mhdf_closeData( filePtr, th, &status ); 01076 mpe_event.end( rval ); 01077 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 01078 } 01079 } 01080 01081 if( cputime ) _times[ADJACENCY_TIME] = timer->time_elapsed(); 01082 01083 // If doing ELEMENTS=SIDES then we need to delete any entities 01084 // that we read that aren't actually sides (e.g. an interior face 01085 // that connects two disjoint portions of the part). Both 01086 // update_connectivity and reading of any explicit adjacencies must 01087 // happen before this. 01088 if( side_mode == SM_SIDES ) 01089 { 01090 debug_barrier(); 01091 mpe_event.start( "cleaning up non-side lower-dim elements" ); 01092 dbgOut.tprint( 1, "CHECKING FOR AND DELETING NON-SIDE ELEMENTS\n" ); 01093 rval = delete_non_side_elements( side_entities ); 01094 mpe_event.end( rval ); 01095 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 01096 } 01097 01098 if( cputime ) _times[DELETE_NON_SIDEELEM_TIME] = timer->time_elapsed(); 01099 01100 debug_barrier(); 01101 dbgOut.tprint( 1, "READING SETS\n" ); 01102 01103 // If reading contained/child sets but not their contents then find 01104 // them now. If we were also reading their contents we would 01105 // have found them already. 01106 if( content_mode == RSM_SETS || child_mode == RSM_SETS ) 01107 { 01108 dbgOut.tprint( 1, " doing read_set_ids_recursive\n" ); 01109 mpe_event.start( "finding recursively contained sets" ); 01110 rval = read_set_ids_recursive( sets, content_mode == RSM_SETS, child_mode == RSM_SETS ); 01111 mpe_event.end( rval ); 01112 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 01113 } 01114 01115 if( cputime ) _times[READ_SET_IDS_RECURS_TIME] = timer->time_elapsed(); 01116 01117 dbgOut.tprint( 1, " doing find_sets_containing\n" ); 01118 mpe_event.start( "finding sets containing any read entities" ); 01119 01120 // Decide whether to read set-containing parents 01121 bool read_set_containing_parents = true; 01122 std::string tmp_opt; 01123 rval = opts.get_option( "NO_SET_CONTAINING_PARENTS", tmp_opt ); 01124 if( MB_SUCCESS == rval ) read_set_containing_parents = false; 01125 01126 // Append file IDs of sets containing any of the nodes or elements 01127 // we've read up to this point. 01128 rval = find_sets_containing( sets, read_set_containing_parents ); 01129 mpe_event.end( rval ); 01130 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 01131 01132 if( cputime ) _times[FIND_SETS_CONTAINING_TIME] = timer->time_elapsed(); 01133 01134 // Now actually read all set data and instantiate sets in MOAB. 01135 // Get any contained sets out of file_ids. 01136 mpe_event.start( "reading set contents/parents/children" ); 01137 EntityHandle first_set = fileInfo->sets.start_id; 01138 sets.merge( file_ids.lower_bound( first_set ), file_ids.lower_bound( first_set + fileInfo->sets.count ) ); 01139 dbgOut.tprint( 1, " doing read_sets\n" ); 01140 rval = read_sets( sets ); 01141 mpe_event.end( rval ); 01142 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 01143 01144 if( cputime ) _times[READ_SETS_TIME] = timer->time_elapsed(); 01145 01146 dbgOut.tprint( 1, "READING TAGS\n" ); 01147 01148 for( int i = 0; i < fileInfo->num_tag_desc; ++i ) 01149 { 01150 mpe_event.start( "reading tag: ", fileInfo->tags[i].name ); 01151 rval = read_tag( i ); 01152 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 01153 } 01154 01155 if( cputime ) _times[READ_TAGS_TIME] = timer->time_elapsed(); 01156 01157 dbgOut.tprint( 1, "PARTIAL READ COMPLETE.\n" ); 01158 01159 return MB_SUCCESS; 01160 } 01161 01162 ErrorCode ReadHDF5::search_tag_values( int tag_index, 01163 const std::vector< int >& sorted_values, 01164 Range& file_ids, 01165 bool sets_only ) 01166 { 01167 ErrorCode rval; 01168 mhdf_Status status; 01169 std::vector< EntityHandle >::iterator iter; 01170 const mhdf_TagDesc& tag = fileInfo->tags[tag_index]; 01171 long size; 01172 long start_id; 01173 01174 CHECK_OPEN_HANDLES; 01175 01176 debug_barrier(); 01177 01178 // Do dense data 01179 01180 hid_t table; 01181 const char* name; 01182 std::vector< EntityHandle > indices; 01183 // These are probably in order of dimension, so iterate 01184 // in reverse order to make Range insertions more efficient. 01185 std::vector< int > grp_indices( tag.dense_elem_indices, tag.dense_elem_indices + tag.num_dense_indices ); 01186 for( std::vector< int >::reverse_iterator i = grp_indices.rbegin(); i != grp_indices.rend(); ++i ) 01187 { 01188 int idx = *i; 01189 if( idx == -2 ) 01190 { 01191 name = mhdf_set_type_handle(); 01192 start_id = fileInfo->sets.start_id; 01193 } 01194 else if( sets_only ) 01195 { 01196 continue; 01197 } 01198 else if( idx == -1 ) 01199 { 01200 name = mhdf_node_type_handle(); 01201 start_id = fileInfo->nodes.start_id; 01202 } 01203 else 01204 { 01205 if( idx < 0 || idx >= fileInfo->num_elem_desc ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 01206 name = fileInfo->elems[idx].handle; 01207 start_id = fileInfo->elems[idx].desc.start_id; 01208 } 01209 table = mhdf_openDenseTagData( filePtr, tag.name, name, &size, &status ); 01210 if( is_error( status ) ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 01211 rval = search_tag_values( table, size, sorted_values, indices ); 01212 mhdf_closeData( filePtr, table, &status ); 01213 if( MB_SUCCESS != rval || is_error( status ) ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 01214 // Convert from table indices to file IDs and add to result list 01215 std::sort( indices.begin(), indices.end(), std::greater< EntityHandle >() ); 01216 std::transform( indices.begin(), indices.end(), range_inserter( file_ids ), 01217 // std::bind1st(std::plus<long>(), start_id)); 01218 std::bind( std::plus< long >(), start_id, std::placeholders::_1 ) ); 01219 indices.clear(); 01220 } 01221 01222 if( !tag.have_sparse ) return MB_SUCCESS; 01223 01224 // Do sparse data 01225 01226 hid_t tables[2]; 01227 long junk; // Redundant value for non-variable-length tags 01228 mhdf_openSparseTagData( filePtr, tag.name, &size, &junk, tables, &status ); 01229 if( is_error( status ) ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 01230 rval = search_tag_values( tables[1], size, sorted_values, indices ); 01231 mhdf_closeData( filePtr, tables[1], &status ); 01232 if( MB_SUCCESS != rval || is_error( status ) ) 01233 { 01234 mhdf_closeData( filePtr, tables[0], &status ); 01235 MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 01236 } 01237 // Convert to ranges 01238 std::sort( indices.begin(), indices.end() ); 01239 std::vector< EntityHandle > ranges; 01240 iter = indices.begin(); 01241 while( iter != indices.end() ) 01242 { 01243 ranges.push_back( *iter ); 01244 EntityHandle last = *iter; 01245 for( ++iter; iter != indices.end() && ( last + 1 ) == *iter; ++iter, ++last ) 01246 ; 01247 ranges.push_back( last ); 01248 } 01249 // Read file ids 01250 iter = ranges.begin(); 01251 unsigned long offset = 0; 01252 while( iter != ranges.end() ) 01253 { 01254 long begin = *iter; 01255 ++iter; 01256 long end = *iter; 01257 ++iter; 01258 mhdf_readSparseTagEntitiesWithOpt( tables[0], begin, end - begin + 1, handleType, &indices[offset], indepIO, 01259 &status ); 01260 if( is_error( status ) ) 01261 { 01262 mhdf_closeData( filePtr, tables[0], &status ); 01263 MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 01264 } 01265 offset += end - begin + 1; 01266 } 01267 mhdf_closeData( filePtr, tables[0], &status ); 01268 if( is_error( status ) ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 01269 assert( offset == indices.size() ); 01270 std::sort( indices.begin(), indices.end() ); 01271 01272 if( sets_only ) 01273 { 01274 iter = std::lower_bound( indices.begin(), indices.end(), 01275 (EntityHandle)( fileInfo->sets.start_id + fileInfo->sets.count ) ); 01276 indices.erase( iter, indices.end() ); 01277 iter = std::lower_bound( indices.begin(), indices.end(), fileInfo->sets.start_id ); 01278 indices.erase( indices.begin(), iter ); 01279 } 01280 copy_sorted_file_ids( &indices[0], indices.size(), file_ids ); 01281 01282 return MB_SUCCESS; 01283 } 01284 01285 ErrorCode ReadHDF5::get_tagged_entities( int tag_index, Range& file_ids ) 01286 { 01287 const mhdf_TagDesc& tag = fileInfo->tags[tag_index]; 01288 01289 CHECK_OPEN_HANDLES; 01290 01291 // Do dense data 01292 Range::iterator hint = file_ids.begin(); 01293 for( int i = 0; i < tag.num_dense_indices; ++i ) 01294 { 01295 int idx = tag.dense_elem_indices[i]; 01296 mhdf_EntDesc* ents; 01297 if( idx == -2 ) 01298 ents = &fileInfo->sets; 01299 else if( idx == -1 ) 01300 ents = &fileInfo->nodes; 01301 else 01302 { 01303 if( idx < 0 || idx >= fileInfo->num_elem_desc ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 01304 ents = &( fileInfo->elems[idx].desc ); 01305 } 01306 01307 EntityHandle h = (EntityHandle)ents->start_id; 01308 hint = file_ids.insert( hint, h, h + ents->count - 1 ); 01309 } 01310 01311 if( !tag.have_sparse ) return MB_SUCCESS; 01312 01313 // Do sparse data 01314 01315 mhdf_Status status; 01316 hid_t tables[2]; 01317 long size, junk; 01318 mhdf_openSparseTagData( filePtr, tag.name, &size, &junk, tables, &status ); 01319 if( is_error( status ) ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 01320 mhdf_closeData( filePtr, tables[1], &status ); 01321 if( is_error( status ) ) 01322 { 01323 mhdf_closeData( filePtr, tables[0], &status ); 01324 MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 01325 } 01326 01327 hid_t file_type = H5Dget_type( tables[0] ); 01328 if( file_type < 0 ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 01329 01330 hint = file_ids.begin(); 01331 EntityHandle* buffer = reinterpret_cast< EntityHandle* >( dataBuffer ); 01332 const long buffer_size = bufferSize / std::max( sizeof( EntityHandle ), H5Tget_size( file_type ) ); 01333 long remaining = size, offset = 0; 01334 while( remaining ) 01335 { 01336 long count = std::min( buffer_size, remaining ); 01337 assert_range( buffer, count ); 01338 mhdf_readSparseTagEntitiesWithOpt( *tables, offset, count, file_type, buffer, collIO, &status ); 01339 if( is_error( status ) ) 01340 { 01341 H5Tclose( file_type ); 01342 mhdf_closeData( filePtr, *tables, &status ); 01343 MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 01344 } 01345 H5Tconvert( file_type, handleType, count, buffer, NULL, H5P_DEFAULT ); 01346 01347 std::sort( buffer, buffer + count ); 01348 for( long i = 0; i < count; ++i ) 01349 hint = file_ids.insert( hint, buffer[i], buffer[i] ); 01350 01351 remaining -= count; 01352 offset += count; 01353 } 01354 01355 H5Tclose( file_type ); 01356 mhdf_closeData( filePtr, *tables, &status ); 01357 if( is_error( status ) ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 01358 01359 return MB_SUCCESS; 01360 } 01361 01362 ErrorCode ReadHDF5::search_tag_values( hid_t tag_table, 01363 unsigned long table_size, 01364 const std::vector< int >& sorted_values, 01365 std::vector< EntityHandle >& value_indices ) 01366 { 01367 debug_barrier(); 01368 01369 CHECK_OPEN_HANDLES; 01370 01371 mhdf_Status status; 01372 size_t chunk_size = bufferSize / sizeof( int ); 01373 int* buffer = reinterpret_cast< int* >( dataBuffer ); 01374 size_t remaining = table_size, offset = 0; 01375 while( remaining ) 01376 { 01377 // Get a block of tag values 01378 size_t count = std::min( chunk_size, remaining ); 01379 assert_range( buffer, count ); 01380 mhdf_readTagValuesWithOpt( tag_table, offset, count, H5T_NATIVE_INT, buffer, collIO, &status ); 01381 if( is_error( status ) ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 01382 01383 // Search tag values 01384 for( size_t i = 0; i < count; ++i ) 01385 if( std::binary_search( sorted_values.begin(), sorted_values.end(), (int)buffer[i] ) ) 01386 value_indices.push_back( i + offset ); 01387 01388 offset += count; 01389 remaining -= count; 01390 } 01391 01392 return MB_SUCCESS; 01393 } 01394 01395 ErrorCode ReadHDF5::read_nodes( const Range& node_file_ids ) 01396 { 01397 ErrorCode rval; 01398 mhdf_Status status; 01399 const int dim = fileInfo->nodes.vals_per_ent; 01400 Range range; 01401 01402 CHECK_OPEN_HANDLES; 01403 01404 if( node_file_ids.empty() && !nativeParallel ) return MB_SUCCESS; 01405 01406 int cdim; 01407 rval = iFace->get_dimension( cdim ); 01408 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 01409 01410 if( cdim < dim ) 01411 { 01412 rval = iFace->set_dimension( dim ); 01413 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 01414 } 01415 01416 hid_t data_id = mhdf_openNodeCoordsSimple( filePtr, &status ); 01417 if( is_error( status ) ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 01418 01419 EntityHandle handle; 01420 std::vector< double* > arrays( dim ); 01421 const size_t num_nodes = node_file_ids.size(); 01422 if( num_nodes > 0 ) 01423 { 01424 rval = readUtil->get_node_coords( dim, (int)num_nodes, 0, handle, arrays ); 01425 if( MB_SUCCESS != rval ) 01426 { 01427 mhdf_closeData( filePtr, data_id, &status ); 01428 MB_SET_ERR( rval, "ReadHDF5 Failure" ); 01429 } 01430 } 01431 01432 if( blockedCoordinateIO ) 01433 { 01434 try 01435 { 01436 for( int d = 0; d < dim; ++d ) 01437 { 01438 ReadHDF5Dataset reader( "blocked coords", data_id, nativeParallel, mpiComm, false ); 01439 reader.set_column( d ); 01440 reader.set_file_ids( node_file_ids, fileInfo->nodes.start_id, num_nodes, H5T_NATIVE_DOUBLE ); 01441 dbgOut.printf( 3, "Reading %lu chunks for coordinate dimension %d\n", reader.get_read_count(), d ); 01442 // Should normally only have one read call, unless sparse nature 01443 // of file_ids caused reader to do something strange 01444 size_t count, offset = 0; 01445 int nn = 0; 01446 while( !reader.done() ) 01447 { 01448 dbgOut.printf( 3, "Reading chunk %d for dimension %d\n", ++nn, d ); 01449 reader.read( arrays[d] + offset, count ); 01450 offset += count; 01451 } 01452 if( offset != num_nodes ) 01453 { 01454 mhdf_closeData( filePtr, data_id, &status ); 01455 assert( false ); 01456 return MB_FAILURE; 01457 } 01458 } 01459 } 01460 catch( ReadHDF5Dataset::Exception ) 01461 { 01462 mhdf_closeData( filePtr, data_id, &status ); 01463 MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 01464 } 01465 } 01466 else 01467 { // !blockedCoordinateIO 01468 double* buffer = (double*)dataBuffer; 01469 long chunk_size = bufferSize / ( 3 * sizeof( double ) ); 01470 long coffset = 0; 01471 int nn = 0; 01472 try 01473 { 01474 ReadHDF5Dataset reader( "interleaved coords", data_id, nativeParallel, mpiComm, false ); 01475 reader.set_file_ids( node_file_ids, fileInfo->nodes.start_id, chunk_size, H5T_NATIVE_DOUBLE ); 01476 dbgOut.printf( 3, "Reading %lu chunks for coordinate coordinates\n", reader.get_read_count() ); 01477 while( !reader.done() ) 01478 { 01479 dbgOut.tprintf( 3, "Reading chunk %d of node coords\n", ++nn ); 01480 01481 size_t count; 01482 reader.read( buffer, count ); 01483 01484 for( size_t i = 0; i < count; ++i ) 01485 for( int d = 0; d < dim; ++d ) 01486 arrays[d][coffset + i] = buffer[dim * i + d]; 01487 coffset += count; 01488 } 01489 } 01490 catch( ReadHDF5Dataset::Exception ) 01491 { 01492 mhdf_closeData( filePtr, data_id, &status ); 01493 MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 01494 } 01495 } 01496 01497 dbgOut.print( 3, "Closing node coordinate table\n" ); 01498 mhdf_closeData( filePtr, data_id, &status ); 01499 for( int d = dim; d < cdim; ++d ) 01500 memset( arrays[d], 0, num_nodes * sizeof( double ) ); 01501 01502 dbgOut.printf( 3, "Updating ID to handle map for %lu nodes\n", (unsigned long)node_file_ids.size() ); 01503 return insert_in_id_map( node_file_ids, handle ); 01504 } 01505 01506 ErrorCode ReadHDF5::read_elems( int i ) 01507 { 01508 Range ids; 01509 ids.insert( fileInfo->elems[i].desc.start_id, 01510 fileInfo->elems[i].desc.start_id + fileInfo->elems[i].desc.count - 1 ); 01511 return read_elems( i, ids ); 01512 } 01513 01514 ErrorCode ReadHDF5::read_elems( int i, const Range& file_ids, Range* node_ids ) 01515 { 01516 if( fileInfo->elems[i].desc.vals_per_ent < 0 ) 01517 { 01518 if( node_ids != 0 ) // Not implemented for version 3 format of poly data 01519 MB_CHK_ERR( MB_TYPE_OUT_OF_RANGE ); 01520 return read_poly( fileInfo->elems[i], file_ids ); 01521 } 01522 else 01523 return read_elems( fileInfo->elems[i], file_ids, node_ids ); 01524 } 01525 01526 ErrorCode ReadHDF5::read_elems( const mhdf_ElemDesc& elems, const Range& file_ids, Range* node_ids ) 01527 { 01528 CHECK_OPEN_HANDLES; 01529 01530 debug_barrier(); 01531 dbgOut.tprintf( 1, "READING %s CONNECTIVITY (%lu elems in %lu selects)\n", elems.handle, 01532 (unsigned long)file_ids.size(), (unsigned long)file_ids.psize() ); 01533 01534 ErrorCode rval = MB_SUCCESS; 01535 mhdf_Status status; 01536 01537 EntityType type = CN::EntityTypeFromName( elems.type ); 01538 if( type == MBMAXTYPE ) 01539 { 01540 MB_SET_ERR( MB_FAILURE, "Unknown element type: \"" << elems.type << "\"" ); 01541 } 01542 01543 const int nodes_per_elem = elems.desc.vals_per_ent; 01544 const size_t count = file_ids.size(); 01545 hid_t data_id = mhdf_openConnectivitySimple( filePtr, elems.handle, &status ); 01546 if( is_error( status ) ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 01547 01548 EntityHandle handle; 01549 EntityHandle* array = 0; 01550 if( count > 0 ) rval = readUtil->get_element_connect( count, nodes_per_elem, type, 0, handle, array ); 01551 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 01552 01553 try 01554 { 01555 EntityHandle* buffer = reinterpret_cast< EntityHandle* >( dataBuffer ); 01556 const size_t buffer_size = bufferSize / ( sizeof( EntityHandle ) * nodes_per_elem ); 01557 ReadHDF5Dataset reader( elems.handle, data_id, nativeParallel, mpiComm ); 01558 reader.set_file_ids( file_ids, elems.desc.start_id, buffer_size, handleType ); 01559 dbgOut.printf( 3, "Reading connectivity in %lu chunks for element group \"%s\"\n", reader.get_read_count(), 01560 elems.handle ); 01561 EntityHandle* iter = array; 01562 int nn = 0; 01563 while( !reader.done() ) 01564 { 01565 dbgOut.printf( 3, "Reading chunk %d for \"%s\"\n", ++nn, elems.handle ); 01566 01567 size_t num_read; 01568 reader.read( buffer, num_read ); 01569 iter = std::copy( buffer, buffer + num_read * nodes_per_elem, iter ); 01570 01571 if( node_ids ) 01572 { 01573 std::sort( buffer, buffer + num_read * nodes_per_elem ); 01574 num_read = std::unique( buffer, buffer + num_read * nodes_per_elem ) - buffer; 01575 copy_sorted_file_ids( buffer, num_read, *node_ids ); 01576 } 01577 } 01578 assert( iter - array == (ptrdiff_t)count * nodes_per_elem ); 01579 } 01580 catch( ReadHDF5Dataset::Exception ) 01581 { 01582 MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 01583 } 01584 01585 if( !node_ids ) 01586 { 01587 rval = convert_id_to_handle( array, count * nodes_per_elem ); 01588 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 01589 01590 rval = readUtil->update_adjacencies( handle, count, nodes_per_elem, array ); 01591 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 01592 } 01593 else 01594 { 01595 IDConnectivity t; 01596 t.handle = handle; 01597 t.count = count; 01598 t.nodes_per_elem = nodes_per_elem; 01599 t.array = array; 01600 idConnectivityList.push_back( t ); 01601 } 01602 01603 return insert_in_id_map( file_ids, handle ); 01604 } 01605 01606 ErrorCode ReadHDF5::update_connectivity() 01607 { 01608 ErrorCode rval; 01609 std::vector< IDConnectivity >::iterator i; 01610 for( i = idConnectivityList.begin(); i != idConnectivityList.end(); ++i ) 01611 { 01612 rval = convert_id_to_handle( i->array, i->count * i->nodes_per_elem ); 01613 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 01614 01615 rval = readUtil->update_adjacencies( i->handle, i->count, i->nodes_per_elem, i->array ); 01616 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 01617 } 01618 idConnectivityList.clear(); 01619 01620 return MB_SUCCESS; 01621 } 01622 01623 ErrorCode ReadHDF5::read_node_adj_elems( const mhdf_ElemDesc& group, Range* handles_out ) 01624 { 01625 mhdf_Status status; 01626 ErrorCode rval; 01627 01628 CHECK_OPEN_HANDLES; 01629 01630 hid_t table = mhdf_openConnectivitySimple( filePtr, group.handle, &status ); 01631 if( is_error( status ) ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 01632 01633 rval = read_node_adj_elems( group, table, handles_out ); 01634 01635 mhdf_closeData( filePtr, table, &status ); 01636 if( MB_SUCCESS == rval && is_error( status ) ) MB_SET_ERR_RET_VAL( "ReadHDF5 Failure", MB_FAILURE ); 01637 01638 return rval; 01639 } 01640 01641 ErrorCode ReadHDF5::read_node_adj_elems( const mhdf_ElemDesc& group, hid_t table_handle, Range* handles_out ) 01642 { 01643 CHECK_OPEN_HANDLES; 01644 01645 debug_barrier(); 01646 01647 mhdf_Status status; 01648 ErrorCode rval; 01649 IODebugTrack debug_track( debugTrack, std::string( group.handle ) ); 01650 01651 // Copy data to local variables (makes other code clearer) 01652 const int node_per_elem = group.desc.vals_per_ent; 01653 long start_id = group.desc.start_id; 01654 long remaining = group.desc.count; 01655 const EntityType type = CN::EntityTypeFromName( group.type ); 01656 01657 // Figure out how many elements we can read in each pass 01658 long* const buffer = reinterpret_cast< long* >( dataBuffer ); 01659 const long buffer_size = bufferSize / ( node_per_elem * sizeof( buffer[0] ) ); 01660 // Read all element connectivity in buffer_size blocks 01661 long offset = 0; 01662 dbgOut.printf( 3, "Reading node-adjacent elements from \"%s\" in %ld chunks\n", group.handle, 01663 ( remaining + buffer_size - 1 ) / buffer_size ); 01664 int nn = 0; 01665 Range::iterator hint; 01666 if( handles_out ) hint = handles_out->begin(); 01667 while( remaining ) 01668 { 01669 dbgOut.printf( 3, "Reading chunk %d of connectivity data for \"%s\"\n", ++nn, group.handle ); 01670 01671 // Read a block of connectivity data 01672 const long count = std::min( remaining, buffer_size ); 01673 debug_track.record_io( offset, count ); 01674 assert_range( buffer, count * node_per_elem ); 01675 mhdf_readConnectivityWithOpt( table_handle, offset, count, H5T_NATIVE_LONG, buffer, collIO, &status ); 01676 if( is_error( status ) ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 01677 offset += count; 01678 remaining -= count; 01679 01680 // Count the number of elements in the block that we want, 01681 // zero connectivity for other elements 01682 long num_elem = 0; 01683 long* iter = buffer; 01684 for( long i = 0; i < count; ++i ) 01685 { 01686 for( int j = 0; j < node_per_elem; ++j ) 01687 { 01688 iter[j] = (long)idMap.find( iter[j] ); 01689 if( !iter[j] ) 01690 { 01691 iter[0] = 0; 01692 break; 01693 } 01694 } 01695 if( iter[0] ) ++num_elem; 01696 iter += node_per_elem; 01697 } 01698 01699 if( !num_elem ) 01700 { 01701 start_id += count; 01702 continue; 01703 } 01704 01705 // Create elements 01706 EntityHandle handle; 01707 EntityHandle* array; 01708 rval = readUtil->get_element_connect( (int)num_elem, node_per_elem, type, 0, handle, array ); 01709 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 01710 01711 // Copy all non-zero connectivity values 01712 iter = buffer; 01713 EntityHandle* iter2 = array; 01714 EntityHandle h = handle; 01715 for( long i = 0; i < count; ++i ) 01716 { 01717 if( !*iter ) 01718 { 01719 iter += node_per_elem; 01720 continue; 01721 } 01722 if( !idMap.insert( start_id + i, h++, 1 ).second ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 01723 01724 long* const end = iter + node_per_elem; 01725 for( ; iter != end; ++iter, ++iter2 ) 01726 *iter2 = (EntityHandle)*iter; 01727 } 01728 assert( iter2 - array == num_elem * node_per_elem ); 01729 start_id += count; 01730 01731 rval = readUtil->update_adjacencies( handle, num_elem, node_per_elem, array ); 01732 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 01733 if( handles_out ) hint = handles_out->insert( hint, handle, handle + num_elem - 1 ); 01734 } 01735 01736 debug_track.all_reduce(); 01737 return MB_SUCCESS; 01738 } 01739 01740 ErrorCode ReadHDF5::read_elems( int i, const Range& elems_in, Range& nodes ) 01741 { 01742 CHECK_OPEN_HANDLES; 01743 01744 debug_barrier(); 01745 dbgOut.tprintf( 1, "READING %s CONNECTIVITY (%lu elems in %lu selects)\n", fileInfo->elems[i].handle, 01746 (unsigned long)elems_in.size(), (unsigned long)elems_in.psize() ); 01747 01748 EntityHandle* const buffer = reinterpret_cast< EntityHandle* >( dataBuffer ); 01749 const int node_per_elem = fileInfo->elems[i].desc.vals_per_ent; 01750 const size_t buffer_size = bufferSize / ( node_per_elem * sizeof( EntityHandle ) ); 01751 01752 if( elems_in.empty() ) return MB_SUCCESS; 01753 01754 assert( (long)elems_in.front() >= fileInfo->elems[i].desc.start_id ); 01755 assert( (long)elems_in.back() - fileInfo->elems[i].desc.start_id < fileInfo->elems[i].desc.count ); 01756 01757 // We don't support version 3 style poly element data 01758 if( fileInfo->elems[i].desc.vals_per_ent <= 0 ) MB_CHK_ERR( MB_TYPE_OUT_OF_RANGE ); 01759 01760 mhdf_Status status; 01761 hid_t table = mhdf_openConnectivitySimple( filePtr, fileInfo->elems[i].handle, &status ); 01762 if( is_error( status ) ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 01763 01764 try 01765 { 01766 ReadHDF5Dataset reader( fileInfo->elems[i].handle, table, nativeParallel, mpiComm ); 01767 reader.set_file_ids( elems_in, fileInfo->elems[i].desc.start_id, buffer_size, handleType ); 01768 dbgOut.printf( 3, "Reading node list in %lu chunks for \"%s\"\n", reader.get_read_count(), 01769 fileInfo->elems[i].handle ); 01770 int nn = 0; 01771 while( !reader.done() ) 01772 { 01773 dbgOut.printf( 3, "Reading chunk %d of \"%s\" connectivity\n", ++nn, fileInfo->elems[i].handle ); 01774 size_t num_read; 01775 reader.read( buffer, num_read ); 01776 std::sort( buffer, buffer + num_read * node_per_elem ); 01777 num_read = std::unique( buffer, buffer + num_read * node_per_elem ) - buffer; 01778 copy_sorted_file_ids( buffer, num_read, nodes ); 01779 } 01780 } 01781 catch( ReadHDF5Dataset::Exception ) 01782 { 01783 MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 01784 } 01785 01786 return MB_SUCCESS; 01787 } 01788 01789 ErrorCode ReadHDF5::read_poly( const mhdf_ElemDesc& elems, const Range& file_ids ) 01790 { 01791 class PolyReader : public ReadHDF5VarLen 01792 { 01793 private: 01794 const EntityType type; 01795 ReadHDF5* readHDF5; 01796 01797 public: 01798 PolyReader( EntityType elem_type, void* buffer, size_t buffer_size, ReadHDF5* owner, DebugOutput& dbg ) 01799 : ReadHDF5VarLen( dbg, buffer, buffer_size ), type( elem_type ), readHDF5( owner ) 01800 { 01801 } 01802 virtual ~PolyReader() {} 01803 ErrorCode store_data( EntityHandle file_id, void* data, long len, bool ) 01804 { 01805 size_t valid; 01806 EntityHandle* conn = reinterpret_cast< EntityHandle* >( data ); 01807 readHDF5->convert_id_to_handle( conn, len, valid ); 01808 if( valid != (size_t)len ) MB_CHK_ERR( MB_ENTITY_NOT_FOUND ); 01809 EntityHandle handle; 01810 ErrorCode rval = readHDF5->moab()->create_element( type, conn, len, handle ); 01811 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 01812 01813 rval = readHDF5->insert_in_id_map( file_id, handle ); 01814 return rval; 01815 } 01816 }; 01817 01818 CHECK_OPEN_HANDLES; 01819 01820 debug_barrier(); 01821 01822 EntityType type = CN::EntityTypeFromName( elems.type ); 01823 if( type == MBMAXTYPE ) 01824 { 01825 MB_SET_ERR( MB_FAILURE, "Unknown element type: \"" << elems.type << "\"" ); 01826 } 01827 01828 hid_t handles[2]; 01829 mhdf_Status status; 01830 long num_poly, num_conn, first_id; 01831 mhdf_openPolyConnectivity( filePtr, elems.handle, &num_poly, &num_conn, &first_id, handles, &status ); 01832 if( is_error( status ) ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 01833 01834 std::string nm( elems.handle ); 01835 ReadHDF5Dataset offset_reader( ( nm + " offsets" ).c_str(), handles[0], nativeParallel, mpiComm, true ); 01836 ReadHDF5Dataset connect_reader( ( nm + " data" ).c_str(), handles[1], nativeParallel, mpiComm, true ); 01837 01838 PolyReader tool( type, dataBuffer, bufferSize, this, dbgOut ); 01839 return tool.read( offset_reader, connect_reader, file_ids, first_id, handleType ); 01840 } 01841 01842 ErrorCode ReadHDF5::delete_non_side_elements( const Range& side_ents ) 01843 { 01844 ErrorCode rval; 01845 01846 // Build list of entities that we need to find the sides of 01847 Range explicit_ents; 01848 Range::iterator hint = explicit_ents.begin(); 01849 for( IDMap::iterator i = idMap.begin(); i != idMap.end(); ++i ) 01850 { 01851 EntityHandle start = i->value; 01852 EntityHandle end = i->value + i->count - 1; 01853 EntityType type = TYPE_FROM_HANDLE( start ); 01854 assert( type == TYPE_FROM_HANDLE( end ) ); // Otherwise handle space entirely full!! 01855 if( type != MBVERTEX && type != MBENTITYSET ) hint = explicit_ents.insert( hint, start, end ); 01856 } 01857 explicit_ents = subtract( explicit_ents, side_ents ); 01858 01859 // Figure out which entities we want to delete 01860 Range dead_ents( side_ents ); 01861 Range::iterator ds, de, es; 01862 ds = dead_ents.lower_bound( CN::TypeDimensionMap[1].first ); 01863 de = dead_ents.lower_bound( CN::TypeDimensionMap[2].first, ds ); 01864 if( ds != de ) 01865 { 01866 // Get subset of explicit ents of dimension greater than 1 01867 es = explicit_ents.lower_bound( CN::TypeDimensionMap[2].first ); 01868 Range subset, adj; 01869 subset.insert( es, explicit_ents.end() ); 01870 rval = iFace->get_adjacencies( subset, 1, false, adj, Interface::UNION ); 01871 if( MB_SUCCESS != rval ) return rval; 01872 dead_ents = subtract( dead_ents, adj ); 01873 } 01874 ds = dead_ents.lower_bound( CN::TypeDimensionMap[2].first ); 01875 de = dead_ents.lower_bound( CN::TypeDimensionMap[3].first, ds ); 01876 assert( de == dead_ents.end() ); 01877 if( ds != de ) 01878 { 01879 // Get subset of explicit ents of dimension 3 01880 es = explicit_ents.lower_bound( CN::TypeDimensionMap[3].first ); 01881 Range subset, adj; 01882 subset.insert( es, explicit_ents.end() ); 01883 rval = iFace->get_adjacencies( subset, 2, false, adj, Interface::UNION ); 01884 if( MB_SUCCESS != rval ) return rval; 01885 dead_ents = subtract( dead_ents, adj ); 01886 } 01887 01888 // Now delete anything remaining in dead_ents 01889 dbgOut.printf( 2, "Deleting %lu elements\n", (unsigned long)dead_ents.size() ); 01890 dbgOut.print( 4, "\tDead entities: ", dead_ents ); 01891 rval = iFace->delete_entities( dead_ents ); 01892 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 01893 01894 // Remove dead entities from ID map 01895 while( !dead_ents.empty() ) 01896 { 01897 EntityHandle start = dead_ents.front(); 01898 EntityID count = dead_ents.const_pair_begin()->second - start + 1; 01899 IDMap::iterator rit; 01900 for( rit = idMap.begin(); rit != idMap.end(); ++rit ) 01901 if( rit->value <= start && (EntityID)( start - rit->value ) < rit->count ) break; 01902 if( rit == idMap.end() ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 01903 01904 EntityID offset = start - rit->value; 01905 EntityID avail = rit->count - offset; 01906 if( avail < count ) count = avail; 01907 01908 dead_ents.erase( dead_ents.begin(), dead_ents.begin() + count ); 01909 idMap.erase( rit->begin + offset, count ); 01910 } 01911 01912 return MB_SUCCESS; 01913 } 01914 01915 ErrorCode ReadHDF5::read_sets( const Range& file_ids ) 01916 { 01917 CHECK_OPEN_HANDLES; 01918 01919 debug_barrier(); 01920 01921 mhdf_Status status; 01922 ErrorCode rval; 01923 01924 const size_t num_sets = fileInfo->sets.count; 01925 if( !num_sets ) // If no sets at all! 01926 return MB_SUCCESS; 01927 01928 // Create sets 01929 std::vector< unsigned > flags( file_ids.size() ); 01930 Range::iterator si = file_ids.begin(); 01931 for( size_t i = 0; i < flags.size(); ++i, ++si ) 01932 flags[i] = setMeta[*si - fileInfo->sets.start_id][3] & ~(long)mhdf_SET_RANGE_BIT; 01933 EntityHandle start_handle; 01934 // the files ids could be empty, for empty partitions 01935 if( !file_ids.empty() ) 01936 { 01937 rval = readUtil->create_entity_sets( flags.size(), &flags[0], 0, start_handle ); 01938 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 01939 rval = insert_in_id_map( file_ids, start_handle ); 01940 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 01941 } 01942 01943 // Read contents 01944 if( fileInfo->have_set_contents ) 01945 { 01946 long len = 0; 01947 hid_t handle = mhdf_openSetData( filePtr, &len, &status ); 01948 if( is_error( status ) ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 01949 01950 ReadHDF5Dataset dat( "set contents", handle, nativeParallel, mpiComm, true ); 01951 rval = read_set_data( file_ids, start_handle, dat, CONTENT ); 01952 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 01953 } 01954 01955 // Read set child lists 01956 if( fileInfo->have_set_children ) 01957 { 01958 long len = 0; 01959 hid_t handle = mhdf_openSetChildren( filePtr, &len, &status ); 01960 if( is_error( status ) ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 01961 01962 ReadHDF5Dataset dat( "set children", handle, nativeParallel, mpiComm, true ); 01963 rval = read_set_data( file_ids, start_handle, dat, CHILD ); 01964 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 01965 } 01966 01967 // Read set parent lists 01968 if( fileInfo->have_set_parents ) 01969 { 01970 long len = 0; 01971 hid_t handle = mhdf_openSetParents( filePtr, &len, &status ); 01972 if( is_error( status ) ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 01973 01974 ReadHDF5Dataset dat( "set parents", handle, nativeParallel, mpiComm, true ); 01975 rval = read_set_data( file_ids, start_handle, dat, PARENT ); 01976 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 01977 } 01978 01979 return MB_SUCCESS; 01980 } 01981 01982 ErrorCode ReadHDF5::read_all_set_meta() 01983 { 01984 CHECK_OPEN_HANDLES; 01985 01986 assert( !setMeta ); 01987 const long num_sets = fileInfo->sets.count; 01988 if( !num_sets ) return MB_SUCCESS; 01989 01990 mhdf_Status status; 01991 hid_t handle = mhdf_openSetMetaSimple( filePtr, &status ); 01992 if( is_error( status ) ) 01993 { 01994 MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 01995 } 01996 01997 // Allocate extra space if we need it for data conversion 01998 hid_t meta_type = H5Dget_type( handle ); 01999 size_t size = H5Tget_size( meta_type ); 02000 if( size > sizeof( long ) ) 02001 setMeta = new long[( num_sets * size + ( sizeof( long ) - 1 ) ) / sizeof( long )][4]; 02002 else 02003 setMeta = new long[num_sets][4]; 02004 02005 // Set some parameters based on whether or not each proc reads the 02006 // table or only the root reads it and bcasts it to the others 02007 int rank = 0; 02008 bool bcast = false; 02009 hid_t ioprop = H5P_DEFAULT; 02010 #ifdef MOAB_HAVE_MPI 02011 MPI_Comm comm = 0; 02012 if( nativeParallel ) 02013 { 02014 rank = myPcomm->proc_config().proc_rank(); 02015 comm = myPcomm->proc_config().proc_comm(); 02016 bcast = bcastDuplicateReads; 02017 if( !bcast ) ioprop = collIO; 02018 } 02019 #endif 02020 02021 if( !bcast || 0 == rank ) 02022 { 02023 mhdf_readSetMetaWithOpt( handle, 0, num_sets, meta_type, setMeta, ioprop, &status ); 02024 if( is_error( status ) ) 02025 { 02026 H5Tclose( meta_type ); 02027 mhdf_closeData( filePtr, handle, &status ); 02028 MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 02029 } 02030 02031 H5Tconvert( meta_type, H5T_NATIVE_LONG, num_sets * 4, setMeta, 0, H5P_DEFAULT ); 02032 } 02033 mhdf_closeData( filePtr, handle, &status ); 02034 if( is_error( status ) ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 02035 H5Tclose( meta_type ); 02036 02037 if( bcast ) 02038 { 02039 #ifdef MOAB_HAVE_MPI 02040 int ierr = MPI_Bcast( (void*)setMeta, num_sets * 4, MPI_LONG, 0, comm ); 02041 if( MPI_SUCCESS != ierr ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 02042 #else 02043 assert( rank == 0 ); // If not MPI, then only one proc 02044 #endif 02045 } 02046 02047 return MB_SUCCESS; 02048 } 02049 02050 ErrorCode ReadHDF5::read_set_ids_recursive( Range& sets_in_out, bool contained_sets, bool child_sets ) 02051 { 02052 CHECK_OPEN_HANDLES; 02053 mhdf_Status status; 02054 02055 if( !fileInfo->have_set_children ) child_sets = false; 02056 if( !fileInfo->have_set_contents ) contained_sets = false; 02057 if( !child_sets && !contained_sets ) return MB_SUCCESS; 02058 02059 // Open data tables 02060 if( fileInfo->sets.count == 0 ) 02061 { 02062 assert( sets_in_out.empty() ); 02063 return MB_SUCCESS; 02064 } 02065 02066 if( !contained_sets && !child_sets ) return MB_SUCCESS; 02067 02068 ReadHDF5Dataset cont( "set contents", false, mpiComm ); 02069 ReadHDF5Dataset child( "set children", false, mpiComm ); 02070 02071 if( contained_sets ) 02072 { 02073 long content_len = 0; 02074 hid_t content_handle = mhdf_openSetData( filePtr, &content_len, &status ); 02075 if( is_error( status ) ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 02076 try 02077 { 02078 cont.init( content_handle, true ); 02079 } 02080 catch( ReadHDF5Dataset::Exception ) 02081 { 02082 MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 02083 } 02084 } 02085 02086 if( child_sets ) 02087 { 02088 long child_len = 0; 02089 hid_t child_handle = mhdf_openSetChildren( filePtr, &child_len, &status ); 02090 if( is_error( status ) ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 02091 try 02092 { 02093 child.init( child_handle, true ); 02094 } 02095 catch( ReadHDF5Dataset::Exception ) 02096 { 02097 MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 02098 } 02099 } 02100 02101 ErrorCode rval = MB_SUCCESS; 02102 Range children, new_children( sets_in_out ); 02103 int iteration_count = 0; 02104 do 02105 { 02106 ++iteration_count; 02107 dbgOut.tprintf( 2, "Iteration %d of read_set_ids_recursive\n", iteration_count ); 02108 children.clear(); 02109 if( child_sets ) 02110 { 02111 rval = read_set_data( new_children, 0, child, CHILD, &children ); 02112 if( MB_SUCCESS != rval ) break; 02113 } 02114 if( contained_sets ) 02115 { 02116 rval = read_set_data( new_children, 0, cont, CONTENT, &children ); 02117 // Remove any non-set values 02118 Range::iterator it = children.lower_bound( fileInfo->sets.start_id ); 02119 children.erase( children.begin(), it ); 02120 it = children.lower_bound( fileInfo->sets.start_id + fileInfo->sets.count ); 02121 children.erase( it, children.end() ); 02122 if( MB_SUCCESS != rval ) break; 02123 } 02124 new_children = subtract( children, sets_in_out ); 02125 dbgOut.print_ints( 2, "Adding additional contained/child sets", new_children ); 02126 sets_in_out.merge( new_children ); 02127 } while( !new_children.empty() ); 02128 02129 return MB_SUCCESS; 02130 } 02131 02132 ErrorCode ReadHDF5::find_sets_containing( Range& sets_out, bool read_set_containing_parents ) 02133 { 02134 ErrorCode rval; 02135 mhdf_Status status; 02136 02137 CHECK_OPEN_HANDLES; 02138 02139 if( !fileInfo->have_set_contents ) return MB_SUCCESS; 02140 assert( fileInfo->sets.count ); 02141 02142 // Open data tables 02143 long content_len = 0; 02144 hid_t content_handle = mhdf_openSetData( filePtr, &content_len, &status ); 02145 if( is_error( status ) ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 02146 02147 hid_t data_type = H5Dget_type( content_handle ); 02148 02149 rval = find_sets_containing( content_handle, data_type, content_len, read_set_containing_parents, sets_out ); 02150 02151 H5Tclose( data_type ); 02152 02153 mhdf_closeData( filePtr, content_handle, &status ); 02154 if( MB_SUCCESS == rval && is_error( status ) ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 02155 02156 return rval; 02157 } 02158 02159 static bool set_map_intersect( bool ranged, 02160 const long* contents, 02161 int content_len, 02162 const RangeMap< long, EntityHandle >& id_map ) 02163 { 02164 if( ranged ) 02165 { 02166 if( !content_len || id_map.empty() ) return false; 02167 02168 const long* j = contents; 02169 const long* const end = contents + content_len; 02170 assert( content_len % 2 == 0 ); 02171 while( j != end ) 02172 { 02173 long start = *( j++ ); 02174 long count = *( j++ ); 02175 if( id_map.intersects( start, count ) ) return true; 02176 } 02177 } 02178 else 02179 { 02180 const long* const end = contents + content_len; 02181 for( const long* i = contents; i != end; ++i ) 02182 if( id_map.exists( *i ) ) return true; 02183 } 02184 02185 return false; 02186 } 02187 02188 struct SetContOffComp 02189 { 02190 bool operator()( const long a1[4], const long a2[4] ) 02191 { 02192 return a1[ReadHDF5::CONTENT] < a2[0]; 02193 } 02194 }; 02195 02196 ErrorCode ReadHDF5::find_sets_containing( hid_t contents_handle, 02197 hid_t content_type, 02198 long contents_len, 02199 bool read_set_containing_parents, 02200 Range& file_ids ) 02201 { 02202 CHECK_OPEN_HANDLES; 02203 02204 // Scan all set contents data 02205 02206 const size_t content_size = H5Tget_size( content_type ); 02207 const long num_sets = fileInfo->sets.count; 02208 dbgOut.printf( 2, "Searching contents of %ld\n", num_sets ); 02209 mhdf_Status status; 02210 02211 int rank = 0; 02212 bool bcast = false; 02213 #ifdef MOAB_HAVE_MPI 02214 MPI_Comm comm = 0; 02215 if( nativeParallel ) 02216 { 02217 rank = myPcomm->proc_config().proc_rank(); 02218 comm = myPcomm->proc_config().proc_comm(); 02219 bcast = bcastDuplicateReads; 02220 } 02221 #endif 02222 02223 // Check offsets so that we don't read past end of table or 02224 // walk off end of array. 02225 long prev = -1; 02226 for( long i = 0; i < num_sets; ++i ) 02227 { 02228 if( setMeta[i][CONTENT] < prev ) 02229 { 02230 std::cerr << "Invalid data in set contents offsets at position " << i << ": index " << setMeta[i][CONTENT] 02231 << " is less than previous index " << prev << std::endl; 02232 std::cerr.flush(); 02233 MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 02234 } 02235 prev = setMeta[i][CONTENT]; 02236 } 02237 if( setMeta[num_sets - 1][CONTENT] >= contents_len ) 02238 { 02239 std::cerr << "Maximum set content index " << setMeta[num_sets - 1][CONTENT] 02240 << " exceeds contents table length of " << contents_len << std::endl; 02241 std::cerr.flush(); 02242 MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 02243 } 02244 02245 // Set up buffer for reading set contents 02246 long* const content_buffer = (long*)dataBuffer; 02247 const long content_len = bufferSize / std::max( content_size, sizeof( long ) ); 02248 02249 // Scan set table 02250 Range::iterator hint = file_ids.begin(); 02251 Range tmp_range; 02252 long prev_idx = -1; 02253 int mm = 0; 02254 long sets_offset = 0; 02255 long temp_content[4]; 02256 while( sets_offset < num_sets ) 02257 { 02258 temp_content[0] = content_len + prev_idx; 02259 long sets_count = 02260 std::lower_bound( setMeta + sets_offset, setMeta + num_sets, temp_content, SetContOffComp() ) - setMeta - 02261 sets_offset; 02262 assert( sets_count >= 0 && sets_offset + sets_count <= num_sets ); 02263 if( !sets_count ) 02264 { // Contents of single set don't fit in buffer 02265 long content_remaining = setMeta[sets_offset][CONTENT] - prev_idx; 02266 long content_offset = prev_idx + 1; 02267 while( content_remaining ) 02268 { 02269 long content_count = content_len < content_remaining ? 2 * ( content_len / 2 ) : content_remaining; 02270 assert_range( content_buffer, content_count ); 02271 dbgOut.printf( 3, "Reading chunk %d (%ld values) from set contents table\n", ++mm, content_count ); 02272 if( !bcast || 0 == rank ) 02273 { 02274 if( !bcast ) 02275 mhdf_readSetDataWithOpt( contents_handle, content_offset, content_count, content_type, 02276 content_buffer, collIO, &status ); 02277 else 02278 mhdf_readSetData( contents_handle, content_offset, content_count, content_type, content_buffer, 02279 &status ); 02280 if( is_error( status ) ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 02281 02282 H5Tconvert( content_type, H5T_NATIVE_LONG, content_count, content_buffer, 0, H5P_DEFAULT ); 02283 } 02284 if( bcast ) 02285 { 02286 #ifdef MOAB_HAVE_MPI 02287 int ierr = MPI_Bcast( content_buffer, content_count, MPI_LONG, 0, comm ); 02288 if( MPI_SUCCESS != ierr ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 02289 #else 02290 assert( rank == 0 ); // If not MPI, then only one proc 02291 #endif 02292 } 02293 02294 if( read_set_containing_parents ) 02295 { 02296 tmp_range.clear(); 02297 if( setMeta[sets_offset][3] & mhdf_SET_RANGE_BIT ) 02298 tmp_range.insert( *content_buffer, *( content_buffer + 1 ) ); 02299 else 02300 std::copy( content_buffer, content_buffer + content_count, range_inserter( tmp_range ) ); 02301 tmp_range = intersect( tmp_range, file_ids ); 02302 } 02303 02304 if( !tmp_range.empty() || set_map_intersect( setMeta[sets_offset][3] & mhdf_SET_RANGE_BIT, 02305 content_buffer, content_count, idMap ) ) 02306 { 02307 long id = fileInfo->sets.start_id + sets_offset; 02308 hint = file_ids.insert( hint, id, id ); 02309 if( !nativeParallel ) // Don't stop if doing READ_PART because we need to read 02310 // collectively 02311 break; 02312 } 02313 content_remaining -= content_count; 02314 content_offset += content_count; 02315 } 02316 prev_idx = setMeta[sets_offset][CONTENT]; 02317 sets_count = 1; 02318 } 02319 else if( long read_num = setMeta[sets_offset + sets_count - 1][CONTENT] - prev_idx ) 02320 { 02321 assert( sets_count > 0 ); 02322 assert_range( content_buffer, read_num ); 02323 dbgOut.printf( 3, "Reading chunk %d (%ld values) from set contents table\n", ++mm, read_num ); 02324 if( !bcast || 0 == rank ) 02325 { 02326 if( !bcast ) 02327 mhdf_readSetDataWithOpt( contents_handle, prev_idx + 1, read_num, content_type, content_buffer, 02328 collIO, &status ); 02329 else 02330 mhdf_readSetData( contents_handle, prev_idx + 1, read_num, content_type, content_buffer, &status ); 02331 if( is_error( status ) ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 02332 02333 H5Tconvert( content_type, H5T_NATIVE_LONG, read_num, content_buffer, 0, H5P_DEFAULT ); 02334 } 02335 if( bcast ) 02336 { 02337 #ifdef MOAB_HAVE_MPI 02338 int ierr = MPI_Bcast( content_buffer, read_num, MPI_LONG, 0, comm ); 02339 if( MPI_SUCCESS != ierr ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 02340 #else 02341 assert( rank == 0 ); // If not MPI, then only one proc 02342 #endif 02343 } 02344 02345 long* buff_iter = content_buffer; 02346 for( long i = 0; i < sets_count; ++i ) 02347 { 02348 long set_size = setMeta[i + sets_offset][CONTENT] - prev_idx; 02349 prev_idx += set_size; 02350 02351 // Check whether contents include set already being loaded 02352 if( read_set_containing_parents ) 02353 { 02354 tmp_range.clear(); 02355 if( setMeta[sets_offset + i][3] & mhdf_SET_RANGE_BIT ) 02356 { 02357 // put in tmp_range the contents on the set 02358 // file_ids contain at this points only other sets 02359 const long* j = buff_iter; 02360 const long* const end = buff_iter + set_size; 02361 assert( set_size % 2 == 0 ); 02362 while( j != end ) 02363 { 02364 long start = *( j++ ); 02365 long count = *( j++ ); 02366 tmp_range.insert( start, start + count - 1 ); 02367 } 02368 } 02369 else 02370 std::copy( buff_iter, buff_iter + set_size, range_inserter( tmp_range ) ); 02371 tmp_range = intersect( tmp_range, file_ids ); 02372 } 02373 02374 if( !tmp_range.empty() || 02375 set_map_intersect( setMeta[sets_offset + i][3] & mhdf_SET_RANGE_BIT, buff_iter, set_size, idMap ) ) 02376 { 02377 long id = fileInfo->sets.start_id + sets_offset + i; 02378 hint = file_ids.insert( hint, id, id ); 02379 } 02380 buff_iter += set_size; 02381 } 02382 } 02383 02384 sets_offset += sets_count; 02385 } 02386 02387 return MB_SUCCESS; 02388 } 02389 02390 static Range::iterator copy_set_contents( Range::iterator hint, 02391 int ranged, 02392 EntityHandle* contents, 02393 long length, 02394 Range& results ) 02395 { 02396 if( ranged ) 02397 { 02398 assert( length % 2 == 0 ); 02399 for( long i = 0; i < length; i += 2 ) 02400 hint = results.insert( hint, contents[i], contents[i] + contents[i + 1] - 1 ); 02401 } 02402 else 02403 { 02404 std::sort( contents, contents + length ); 02405 for( long i = 0; i < length; ++i ) 02406 hint = results.insert( hint, contents[i] ); 02407 } 02408 return hint; 02409 } 02410 02411 ErrorCode ReadHDF5::read_set_data( const Range& set_file_ids, 02412 EntityHandle start_handle, 02413 ReadHDF5Dataset& data, 02414 SetMode mode, 02415 Range* file_ids_out ) 02416 { 02417 ErrorCode rval; 02418 Range::const_pair_iterator pi; 02419 Range::iterator out_hint; 02420 if( file_ids_out ) out_hint = file_ids_out->begin(); 02421 02422 // Construct range of offsets into data table at which to read 02423 // Note: all offsets are incremented by TWEAK because Range cannot 02424 // store zeros. 02425 const long TWEAK = 1; 02426 Range data_offsets; 02427 Range::iterator hint = data_offsets.begin(); 02428 pi = set_file_ids.const_pair_begin(); 02429 if( (long)pi->first == fileInfo->sets.start_id ) 02430 { 02431 long second = pi->second - fileInfo->sets.start_id; 02432 if( setMeta[second][mode] >= 0 ) hint = data_offsets.insert( hint, TWEAK, setMeta[second][mode] + TWEAK ); 02433 ++pi; 02434 } 02435 for( ; pi != set_file_ids.const_pair_end(); ++pi ) 02436 { 02437 long first = pi->first - fileInfo->sets.start_id; 02438 long second = pi->second - fileInfo->sets.start_id; 02439 long idx1 = setMeta[first - 1][mode] + 1; 02440 long idx2 = setMeta[second][mode]; 02441 if( idx2 >= idx1 ) hint = data_offsets.insert( hint, idx1 + TWEAK, idx2 + TWEAK ); 02442 } 02443 try 02444 { 02445 data.set_file_ids( data_offsets, TWEAK, bufferSize / sizeof( EntityHandle ), handleType ); 02446 } 02447 catch( ReadHDF5Dataset::Exception ) 02448 { 02449 return MB_FAILURE; 02450 } 02451 02452 // We need to increment this for each processed set because 02453 // the sets were created in the order of the ids in file_ids. 02454 EntityHandle h = start_handle; 02455 02456 const long ranged_flag = ( mode == CONTENT ) ? mhdf_SET_RANGE_BIT : 0; 02457 02458 std::vector< EntityHandle > partial; // For when we read only part of the contents of a set/entity 02459 Range::const_iterator fileid_iter = set_file_ids.begin(); 02460 EntityHandle* buffer = reinterpret_cast< EntityHandle* >( dataBuffer ); 02461 size_t count, offset; 02462 02463 int nn = 0; 02464 /* 02465 #ifdef MOAB_HAVE_MPI 02466 if (nativeParallel && mode==CONTENT && myPcomm->proc_config().proc_size()>1 && 02467 data_offsets.empty()) 02468 { 02469 MB_SET_ERR_CONT( "ReadHDF5 Failure: Attempt reading an empty dataset on proc " << 02470 myPcomm->proc_config().proc_rank()); 02471 MPI_Abort(myPcomm->proc_config().proc_comm(), 1); 02472 } 02473 #endif 02474 */ 02475 if( ( 1 >= set_file_ids.size() ) && ( data.done() ) && moab::ReadHDF5::CONTENT == mode ) 02476 // do at least one null read, it is needed in parallel 02477 data.null_read(); 02478 02479 while( !data.done() ) 02480 { 02481 dbgOut.printf( 3, "Reading chunk %d of %s\n", ++nn, data.get_debug_desc() ); 02482 try 02483 { 02484 data.read( buffer, count ); 02485 } 02486 catch( ReadHDF5Dataset::Exception ) 02487 { 02488 return MB_FAILURE; 02489 } 02490 02491 // Assert not appropriate here - I might have treated all my file ids, but maybe 02492 // another proc hasn't; for me, count will be zero, so I won't do anything, but 02493 // I still need to go through the motions to make the read work 02494 02495 // Handle 'special' case where we read some, but not all 02496 // of the data for an entity during the last iteration. 02497 offset = 0; 02498 if( !partial.empty() ) 02499 { // Didn't read all of previous entity 02500 assert( fileid_iter != set_file_ids.end() ); 02501 size_t num_prev = partial.size(); 02502 size_t idx = *fileid_iter - fileInfo->sets.start_id; 02503 size_t len = idx ? setMeta[idx][mode] - setMeta[idx - 1][mode] : setMeta[idx][mode] + 1; 02504 offset = len - num_prev; 02505 if( offset > count ) 02506 { // Still don't have all 02507 partial.insert( partial.end(), buffer, buffer + count ); 02508 continue; 02509 } 02510 02511 partial.insert( partial.end(), buffer, buffer + offset ); 02512 if( file_ids_out ) 02513 { 02514 out_hint = copy_set_contents( out_hint, setMeta[idx][3] & ranged_flag, &partial[0], partial.size(), 02515 *file_ids_out ); 02516 } 02517 else 02518 { 02519 switch( mode ) 02520 { 02521 size_t valid; 02522 case CONTENT: 02523 if( setMeta[idx][3] & ranged_flag ) 02524 { 02525 if( len % 2 ) MB_CHK_ERR( MB_INDEX_OUT_OF_RANGE ); 02526 Range range; 02527 convert_range_to_handle( &partial[0], len / 2, range ); 02528 rval = moab()->add_entities( h, range ); 02529 } 02530 else 02531 { 02532 convert_id_to_handle( &partial[0], len, valid ); 02533 rval = moab()->add_entities( h, &partial[0], valid ); 02534 } 02535 break; 02536 case CHILD: 02537 convert_id_to_handle( &partial[0], len, valid ); 02538 rval = moab()->add_child_meshsets( h, &partial[0], valid ); 02539 break; 02540 case PARENT: 02541 convert_id_to_handle( &partial[0], len, valid ); 02542 rval = moab()->add_parent_meshsets( h, &partial[0], valid ); 02543 break; 02544 default: 02545 break; 02546 } 02547 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 02548 } 02549 02550 ++fileid_iter; 02551 ++h; 02552 partial.clear(); 02553 } 02554 02555 // Process contents for all entities for which we 02556 // have read the complete list 02557 while( offset < count ) 02558 { 02559 assert( fileid_iter != set_file_ids.end() ); 02560 size_t idx = *fileid_iter - fileInfo->sets.start_id; 02561 size_t len = idx ? setMeta[idx][mode] - setMeta[idx - 1][mode] : setMeta[idx][mode] + 1; 02562 // If we did not read all of the final entity, 02563 // store what we did read to be processed in the 02564 // next iteration 02565 if( offset + len > count ) 02566 { 02567 partial.insert( partial.end(), buffer + offset, buffer + count ); 02568 break; 02569 } 02570 02571 if( file_ids_out ) 02572 { 02573 out_hint = 02574 copy_set_contents( out_hint, setMeta[idx][3] & ranged_flag, buffer + offset, len, *file_ids_out ); 02575 } 02576 else 02577 { 02578 switch( mode ) 02579 { 02580 size_t valid; 02581 case CONTENT: 02582 if( setMeta[idx][3] & ranged_flag ) 02583 { 02584 if( len % 2 ) MB_CHK_ERR( MB_INDEX_OUT_OF_RANGE ); 02585 Range range; 02586 convert_range_to_handle( buffer + offset, len / 2, range ); 02587 rval = moab()->add_entities( h, range ); 02588 } 02589 else 02590 { 02591 convert_id_to_handle( buffer + offset, len, valid ); 02592 rval = moab()->add_entities( h, buffer + offset, valid ); 02593 } 02594 break; 02595 case CHILD: 02596 convert_id_to_handle( buffer + offset, len, valid ); 02597 rval = moab()->add_child_meshsets( h, buffer + offset, valid ); 02598 break; 02599 case PARENT: 02600 convert_id_to_handle( buffer + offset, len, valid ); 02601 rval = moab()->add_parent_meshsets( h, buffer + offset, valid ); 02602 break; 02603 default: 02604 break; 02605 } 02606 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 02607 } 02608 02609 ++fileid_iter; 02610 ++h; 02611 offset += len; 02612 } 02613 } 02614 02615 return MB_SUCCESS; 02616 } 02617 02618 ErrorCode ReadHDF5::get_set_contents( const Range& sets, Range& file_ids ) 02619 { 02620 CHECK_OPEN_HANDLES; 02621 02622 if( !fileInfo->have_set_contents ) return MB_SUCCESS; 02623 dbgOut.tprint( 2, "Reading set contained file IDs\n" ); 02624 try 02625 { 02626 mhdf_Status status; 02627 long content_len; 02628 hid_t contents = mhdf_openSetData( filePtr, &content_len, &status ); 02629 if( is_error( status ) ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 02630 ReadHDF5Dataset data( "set contents", contents, nativeParallel, mpiComm, true ); 02631 02632 return read_set_data( sets, 0, data, CONTENT, &file_ids ); 02633 } 02634 catch( ReadHDF5Dataset::Exception ) 02635 { 02636 MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 02637 } 02638 } 02639 02640 ErrorCode ReadHDF5::read_adjacencies( hid_t table, long table_len ) 02641 { 02642 CHECK_OPEN_HANDLES; 02643 02644 ErrorCode rval; 02645 mhdf_Status status; 02646 02647 debug_barrier(); 02648 02649 hid_t read_type = H5Dget_type( table ); 02650 if( read_type < 0 ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 02651 const bool convert = !H5Tequal( read_type, handleType ); 02652 02653 EntityHandle* buffer = (EntityHandle*)dataBuffer; 02654 size_t chunk_size = bufferSize / H5Tget_size( read_type ); 02655 size_t remaining = table_len; 02656 size_t left_over = 0; 02657 size_t offset = 0; 02658 dbgOut.printf( 3, "Reading adjacency list in %lu chunks\n", 02659 (unsigned long)( remaining + chunk_size - 1 ) / chunk_size ); 02660 int nn = 0; 02661 while( remaining ) 02662 { 02663 dbgOut.printf( 3, "Reading chunk %d of adjacency list\n", ++nn ); 02664 02665 size_t count = std::min( chunk_size, remaining ); 02666 count -= left_over; 02667 remaining -= count; 02668 02669 assert_range( buffer + left_over, count ); 02670 mhdf_readAdjacencyWithOpt( table, offset, count, read_type, buffer + left_over, collIO, &status ); 02671 if( is_error( status ) ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 02672 02673 if( convert ) 02674 { 02675 herr_t err = H5Tconvert( read_type, handleType, count, buffer + left_over, 0, H5P_DEFAULT ); 02676 if( err < 0 ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 02677 } 02678 02679 EntityHandle* iter = buffer; 02680 EntityHandle* end = buffer + count + left_over; 02681 while( end - iter >= 3 ) 02682 { 02683 EntityHandle h = idMap.find( *iter++ ); 02684 EntityHandle count2 = *iter++; 02685 if( !h ) 02686 { 02687 iter += count2; 02688 continue; 02689 } 02690 02691 if( count2 < 1 ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 02692 02693 if( end < count2 + iter ) 02694 { 02695 iter -= 2; 02696 break; 02697 } 02698 02699 size_t valid; 02700 convert_id_to_handle( iter, count2, valid, idMap ); 02701 rval = iFace->add_adjacencies( h, iter, valid, false ); 02702 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 02703 02704 iter += count2; 02705 } 02706 02707 left_over = end - iter; 02708 assert_range( (char*)buffer, left_over ); 02709 assert_range( (char*)iter, left_over ); 02710 memmove( buffer, iter, left_over ); 02711 } 02712 02713 assert( !left_over ); // Unexpected truncation of data 02714 02715 return MB_SUCCESS; 02716 } 02717 02718 ErrorCode ReadHDF5::read_tag( int tag_index ) 02719 { 02720 CHECK_OPEN_HANDLES; 02721 02722 dbgOut.tprintf( 2, "Reading tag \"%s\"\n", fileInfo->tags[tag_index].name ); 02723 02724 debug_barrier(); 02725 02726 ErrorCode rval; 02727 mhdf_Status status; 02728 Tag tag = 0; 02729 hid_t read_type = -1; 02730 bool table_type; 02731 rval = create_tag( fileInfo->tags[tag_index], tag, read_type ); 02732 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 02733 02734 if( fileInfo->tags[tag_index].have_sparse ) 02735 { 02736 hid_t handles[3]; 02737 long num_ent, num_val; 02738 mhdf_openSparseTagData( filePtr, fileInfo->tags[tag_index].name, &num_ent, &num_val, handles, &status ); 02739 if( is_error( status ) ) 02740 { 02741 if( read_type ) H5Tclose( read_type ); 02742 MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 02743 } 02744 02745 table_type = false; 02746 if( read_type == 0 ) 02747 { 02748 read_type = H5Dget_type( handles[1] ); 02749 if( read_type == 0 ) 02750 { 02751 mhdf_closeData( filePtr, handles[0], &status ); 02752 mhdf_closeData( filePtr, handles[0], &status ); 02753 if( fileInfo->tags[tag_index].size <= 0 ) mhdf_closeData( filePtr, handles[2], &status ); 02754 MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 02755 } 02756 table_type = true; 02757 } 02758 02759 if( fileInfo->tags[tag_index].size > 0 ) 02760 { 02761 dbgOut.printf( 2, "Reading sparse data for tag \"%s\"\n", fileInfo->tags[tag_index].name ); 02762 rval = read_sparse_tag( tag, read_type, handles[0], handles[1], num_ent ); 02763 } 02764 else 02765 { 02766 dbgOut.printf( 2, "Reading var-len sparse data for tag \"%s\"\n", fileInfo->tags[tag_index].name ); 02767 rval = read_var_len_tag( tag, read_type, handles[0], handles[1], handles[2], num_ent, num_val ); 02768 } 02769 02770 if( table_type ) 02771 { 02772 H5Tclose( read_type ); 02773 read_type = 0; 02774 } 02775 02776 mhdf_closeData( filePtr, handles[0], &status ); 02777 if( MB_SUCCESS == rval && is_error( status ) ) rval = MB_FAILURE; 02778 mhdf_closeData( filePtr, handles[1], &status ); 02779 if( MB_SUCCESS == rval && is_error( status ) ) rval = MB_FAILURE; 02780 if( fileInfo->tags[tag_index].size <= 0 ) 02781 { 02782 mhdf_closeData( filePtr, handles[2], &status ); 02783 if( MB_SUCCESS == rval && is_error( status ) ) rval = MB_FAILURE; 02784 } 02785 if( MB_SUCCESS != rval ) 02786 { 02787 if( read_type ) H5Tclose( read_type ); 02788 MB_SET_ERR( rval, "ReadHDF5 Failure" ); 02789 } 02790 } 02791 02792 for( int j = 0; j < fileInfo->tags[tag_index].num_dense_indices; ++j ) 02793 { 02794 long count; 02795 const char* name = 0; 02796 mhdf_EntDesc* desc; 02797 int elem_idx = fileInfo->tags[tag_index].dense_elem_indices[j]; 02798 if( elem_idx == -2 ) 02799 { 02800 desc = &fileInfo->sets; 02801 name = mhdf_set_type_handle(); 02802 } 02803 else if( elem_idx == -1 ) 02804 { 02805 desc = &fileInfo->nodes; 02806 name = mhdf_node_type_handle(); 02807 } 02808 else if( elem_idx >= 0 && elem_idx < fileInfo->num_elem_desc ) 02809 { 02810 desc = &fileInfo->elems[elem_idx].desc; 02811 name = fileInfo->elems[elem_idx].handle; 02812 } 02813 else 02814 { 02815 MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 02816 } 02817 02818 dbgOut.printf( 2, "Read dense data block for tag \"%s\" on \"%s\"\n", fileInfo->tags[tag_index].name, name ); 02819 02820 hid_t handle = mhdf_openDenseTagData( filePtr, fileInfo->tags[tag_index].name, name, &count, &status ); 02821 if( is_error( status ) ) 02822 { 02823 rval = MB_FAILURE; // rval = error(MB_FAILURE); 02824 break; 02825 } 02826 02827 if( count > desc->count ) 02828 { 02829 mhdf_closeData( filePtr, handle, &status ); 02830 MB_SET_ERR( MB_FAILURE, 02831 "Invalid data length for dense tag data: " << name << "/" << fileInfo->tags[tag_index].name ); 02832 } 02833 02834 table_type = false; 02835 if( read_type == 0 ) 02836 { 02837 read_type = H5Dget_type( handle ); 02838 if( read_type == 0 ) 02839 { 02840 mhdf_closeData( filePtr, handle, &status ); 02841 MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 02842 } 02843 table_type = true; 02844 } 02845 02846 rval = read_dense_tag( tag, name, read_type, handle, desc->start_id, count ); 02847 02848 if( table_type ) 02849 { 02850 H5Tclose( read_type ); 02851 read_type = 0; 02852 } 02853 02854 mhdf_closeData( filePtr, handle, &status ); 02855 if( MB_SUCCESS != rval ) break; 02856 if( is_error( status ) ) 02857 { 02858 rval = MB_FAILURE; 02859 break; 02860 } 02861 } 02862 02863 if( read_type ) H5Tclose( read_type ); 02864 return rval; 02865 } 02866 02867 ErrorCode ReadHDF5::create_tag( const mhdf_TagDesc& info, Tag& handle, hid_t& hdf_type ) 02868 { 02869 CHECK_OPEN_HANDLES; 02870 02871 ErrorCode rval; 02872 mhdf_Status status; 02873 TagType storage; 02874 DataType mb_type; 02875 bool re_read_default = false; 02876 02877 switch( info.storage ) 02878 { 02879 case mhdf_DENSE_TYPE: 02880 storage = MB_TAG_DENSE; 02881 break; 02882 case mhdf_SPARSE_TYPE: 02883 storage = MB_TAG_SPARSE; 02884 break; 02885 case mhdf_BIT_TYPE: 02886 storage = MB_TAG_BIT; 02887 break; 02888 case mhdf_MESH_TYPE: 02889 storage = MB_TAG_MESH; 02890 break; 02891 default: 02892 MB_SET_ERR( MB_FAILURE, "Invalid storage type for tag '" << info.name << "': " << info.storage ); 02893 } 02894 02895 // Type-specific stuff 02896 if( info.type == mhdf_BITFIELD ) 02897 { 02898 if( info.size < 1 || info.size > 8 ) 02899 { 02900 MB_SET_ERR( MB_FAILURE, "Invalid bit tag: class is MB_TAG_BIT, num bits = " << info.size ); 02901 } 02902 hdf_type = H5Tcopy( H5T_NATIVE_B8 ); 02903 mb_type = MB_TYPE_BIT; 02904 if( hdf_type < 0 ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 02905 } 02906 else if( info.type == mhdf_OPAQUE ) 02907 { 02908 mb_type = MB_TYPE_OPAQUE; 02909 02910 // Check for user-provided type 02911 Tag type_handle; 02912 std::string tag_type_name = "__hdf5_tag_type_"; 02913 tag_type_name += info.name; 02914 rval = iFace->tag_get_handle( tag_type_name.c_str(), sizeof( hid_t ), MB_TYPE_OPAQUE, type_handle ); 02915 if( MB_SUCCESS == rval ) 02916 { 02917 EntityHandle root = 0; 02918 rval = iFace->tag_get_data( type_handle, &root, 1, &hdf_type ); 02919 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 02920 hdf_type = H5Tcopy( hdf_type ); 02921 re_read_default = true; 02922 } 02923 else if( MB_TAG_NOT_FOUND == rval ) 02924 { 02925 hdf_type = 0; 02926 } 02927 else 02928 MB_SET_ERR( rval, "ReadHDF5 Failure" ); 02929 02930 if( hdf_type < 0 ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 02931 } 02932 else 02933 { 02934 switch( info.type ) 02935 { 02936 case mhdf_INTEGER: 02937 hdf_type = H5T_NATIVE_INT; 02938 mb_type = MB_TYPE_INTEGER; 02939 break; 02940 case mhdf_FLOAT: 02941 hdf_type = H5T_NATIVE_DOUBLE; 02942 mb_type = MB_TYPE_DOUBLE; 02943 break; 02944 case mhdf_BOOLEAN: 02945 hdf_type = H5T_NATIVE_UINT; 02946 mb_type = MB_TYPE_INTEGER; 02947 break; 02948 case mhdf_ENTITY_ID: 02949 hdf_type = handleType; 02950 mb_type = MB_TYPE_HANDLE; 02951 break; 02952 default: 02953 MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 02954 } 02955 02956 if( info.size > 1 ) 02957 { // Array 02958 hsize_t tmpsize = info.size; 02959 #if defined( H5Tarray_create_vers ) && H5Tarray_create_vers > 1 02960 hdf_type = H5Tarray_create2( hdf_type, 1, &tmpsize ); 02961 #else 02962 hdf_type = H5Tarray_create( hdf_type, 1, &tmpsize, NULL ); 02963 #endif 02964 } 02965 else 02966 { 02967 hdf_type = H5Tcopy( hdf_type ); 02968 } 02969 if( hdf_type < 0 ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 02970 } 02971 02972 // If default or global/mesh value in file, read it. 02973 if( info.default_value || info.global_value ) 02974 { 02975 if( re_read_default ) 02976 { 02977 mhdf_getTagValues( filePtr, info.name, hdf_type, info.default_value, info.global_value, &status ); 02978 if( mhdf_isError( &status ) ) 02979 { 02980 if( hdf_type ) H5Tclose( hdf_type ); 02981 MB_SET_ERR( MB_FAILURE, mhdf_message( &status ) ); 02982 } 02983 } 02984 02985 if( MB_TYPE_HANDLE == mb_type ) 02986 { 02987 if( info.default_value ) 02988 { 02989 rval = convert_id_to_handle( (EntityHandle*)info.default_value, info.default_value_size ); 02990 if( MB_SUCCESS != rval ) 02991 { 02992 if( hdf_type ) H5Tclose( hdf_type ); 02993 MB_SET_ERR( rval, "ReadHDF5 Failure" ); 02994 } 02995 } 02996 if( info.global_value ) 02997 { 02998 rval = convert_id_to_handle( (EntityHandle*)info.global_value, info.global_value_size ); 02999 if( MB_SUCCESS != rval ) 03000 { 03001 if( hdf_type ) H5Tclose( hdf_type ); 03002 MB_SET_ERR( rval, "ReadHDF5 Failure" ); 03003 } 03004 } 03005 } 03006 } 03007 03008 // Get tag handle, creating if necessary 03009 if( info.size < 0 ) 03010 rval = iFace->tag_get_handle( info.name, info.default_value_size, mb_type, handle, 03011 storage | MB_TAG_CREAT | MB_TAG_VARLEN | MB_TAG_DFTOK, info.default_value ); 03012 else 03013 rval = iFace->tag_get_handle( info.name, info.size, mb_type, handle, storage | MB_TAG_CREAT | MB_TAG_DFTOK, 03014 info.default_value ); 03015 if( MB_SUCCESS != rval ) 03016 { 03017 if( hdf_type ) H5Tclose( hdf_type ); 03018 MB_SET_ERR( MB_FAILURE, "Tag type in file does not match type in database for \"" << info.name << "\"" ); 03019 } 03020 03021 if( info.global_value ) 03022 { 03023 EntityHandle root = 0; 03024 if( info.size > 0 ) 03025 { // Fixed-length tag 03026 rval = iFace->tag_set_data( handle, &root, 1, info.global_value ); 03027 } 03028 else 03029 { 03030 int tag_size = info.global_value_size; 03031 rval = iFace->tag_set_by_ptr( handle, &root, 1, &info.global_value, &tag_size ); 03032 } 03033 if( MB_SUCCESS != rval ) 03034 { 03035 if( hdf_type ) H5Tclose( hdf_type ); 03036 MB_SET_ERR( rval, "ReadHDF5 Failure" ); 03037 } 03038 } 03039 03040 return MB_SUCCESS; 03041 } 03042 03043 ErrorCode ReadHDF5::read_dense_tag( Tag tag_handle, 03044 const char* ent_name, 03045 hid_t hdf_read_type, 03046 hid_t data, 03047 long start_id, 03048 long num_values ) 03049 { 03050 CHECK_OPEN_HANDLES; 03051 03052 ErrorCode rval; 03053 DataType mb_type; 03054 03055 rval = iFace->tag_get_data_type( tag_handle, mb_type ); 03056 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 03057 03058 int read_size; 03059 rval = iFace->tag_get_bytes( tag_handle, read_size ); 03060 if( MB_SUCCESS != rval ) // Wrong function for variable-length tags 03061 MB_SET_ERR( rval, "ReadHDF5 Failure" ); 03062 // if (MB_TYPE_BIT == mb_type) 03063 // read_size = (read_size + 7) / 8; // Convert bits to bytes, plus 7 for ceiling 03064 03065 if( hdf_read_type ) 03066 { // If not opaque 03067 hsize_t hdf_size = H5Tget_size( hdf_read_type ); 03068 if( hdf_size != (hsize_t)read_size ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 03069 } 03070 03071 // Get actual entities read from file 03072 Range file_ids, handles; 03073 Range::iterator f_ins = file_ids.begin(), h_ins = handles.begin(); 03074 IDMap::iterator l, u; 03075 l = idMap.lower_bound( start_id ); 03076 u = idMap.lower_bound( start_id + num_values - 1 ); 03077 if( l != idMap.end() && start_id + num_values > l->begin ) 03078 { 03079 if( l == u ) 03080 { 03081 size_t beg = std::max( start_id, l->begin ); 03082 size_t end = std::min( start_id + num_values, u->begin + u->count ) - 1; 03083 f_ins = file_ids.insert( f_ins, beg, end ); 03084 h_ins = handles.insert( h_ins, l->value + ( beg - l->begin ), l->value + ( end - l->begin ) ); 03085 } 03086 else 03087 { 03088 size_t beg = std::max( start_id, l->begin ); 03089 f_ins = file_ids.insert( f_ins, beg, l->begin + l->count - 1 ); 03090 h_ins = handles.insert( h_ins, l->value + ( beg - l->begin ), l->value + l->count - 1 ); 03091 for( ++l; l != u; ++l ) 03092 { 03093 f_ins = file_ids.insert( f_ins, l->begin, l->begin + l->count - 1 ); 03094 h_ins = handles.insert( h_ins, l->value, l->value + l->count - 1 ); 03095 } 03096 if( u != idMap.end() && u->begin < start_id + num_values ) 03097 { 03098 size_t end = std::min( start_id + num_values, u->begin + u->count - 1 ); 03099 f_ins = file_ids.insert( f_ins, u->begin, end ); 03100 h_ins = handles.insert( h_ins, u->value, u->value + end - u->begin ); 03101 } 03102 } 03103 } 03104 03105 // Given that all of the entities for this dense tag data should 03106 // have been created as a single contiguous block, the resulting 03107 // MOAB handle range should be contiguous. 03108 // THE ABOVE IS NOT NECESSARILY TRUE. SOMETIMES LOWER-DIMENSION 03109 // ENTS ARE READ AND THEN DELETED FOR PARTIAL READS. 03110 // assert(handles.empty() || handles.size() == (handles.back() - handles.front() + 1)); 03111 03112 std::string tn( "<error>" ); 03113 iFace->tag_get_name( tag_handle, tn ); 03114 tn += " data for "; 03115 tn += ent_name; 03116 try 03117 { 03118 h_ins = handles.begin(); 03119 ReadHDF5Dataset reader( tn.c_str(), data, nativeParallel, mpiComm, false ); 03120 long buffer_size = bufferSize / read_size; 03121 reader.set_file_ids( file_ids, start_id, buffer_size, hdf_read_type ); 03122 dbgOut.printf( 3, "Reading dense data for tag \"%s\" and group \"%s\" in %lu chunks\n", tn.c_str(), ent_name, 03123 reader.get_read_count() ); 03124 int nn = 0; 03125 while( !reader.done() ) 03126 { 03127 dbgOut.printf( 3, "Reading chunk %d of \"%s\" data\n", ++nn, tn.c_str() ); 03128 03129 size_t count; 03130 reader.read( dataBuffer, count ); 03131 03132 if( MB_TYPE_HANDLE == mb_type ) 03133 { 03134 rval = convert_id_to_handle( (EntityHandle*)dataBuffer, count * read_size / sizeof( EntityHandle ) ); 03135 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 03136 } 03137 03138 Range ents; 03139 Range::iterator end = h_ins; 03140 end += count; 03141 ents.insert( h_ins, end ); 03142 h_ins = end; 03143 03144 rval = iFace->tag_set_data( tag_handle, ents, dataBuffer ); 03145 if( MB_SUCCESS != rval ) 03146 { 03147 dbgOut.printf( 1, "Internal error setting data for tag \"%s\"\n", tn.c_str() ); 03148 MB_SET_ERR( rval, "ReadHDF5 Failure" ); 03149 } 03150 } 03151 } 03152 catch( ReadHDF5Dataset::Exception ) 03153 { 03154 dbgOut.printf( 1, "Internal error reading dense data for tag \"%s\"\n", tn.c_str() ); 03155 MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 03156 } 03157 03158 return MB_SUCCESS; 03159 } 03160 03161 // Read entire ID table and for those file IDs corresponding 03162 // to entities that we have read from the file add both the 03163 // offset into the offset range and the handle into the handle 03164 // range. If handles are not ordered, switch to using a vector. 03165 ErrorCode ReadHDF5::read_sparse_tag_indices( const char* name, 03166 hid_t id_table, 03167 EntityHandle start_offset, // Can't put zero in a Range 03168 Range& offset_range, 03169 Range& handle_range, 03170 std::vector< EntityHandle >& handle_vect ) 03171 { 03172 CHECK_OPEN_HANDLES; 03173 03174 offset_range.clear(); 03175 handle_range.clear(); 03176 handle_vect.clear(); 03177 03178 ErrorCode rval; 03179 Range::iterator handle_hint = handle_range.begin(); 03180 Range::iterator offset_hint = offset_range.begin(); 03181 03182 EntityHandle* idbuf = (EntityHandle*)dataBuffer; 03183 size_t idbuf_size = bufferSize / sizeof( EntityHandle ); 03184 03185 std::string tn( name ); 03186 tn += " indices"; 03187 03188 assert( start_offset > 0 ); // Can't put zero in a Range 03189 try 03190 { 03191 ReadHDF5Dataset id_reader( tn.c_str(), id_table, nativeParallel, mpiComm, false ); 03192 id_reader.set_all_file_ids( idbuf_size, handleType ); 03193 size_t offset = start_offset; 03194 dbgOut.printf( 3, "Reading file ids for sparse tag \"%s\" in %lu chunks\n", name, id_reader.get_read_count() ); 03195 int nn = 0; 03196 while( !id_reader.done() ) 03197 { 03198 dbgOut.printf( 3, "Reading chunk %d of \"%s\" IDs\n", ++nn, name ); 03199 size_t count; 03200 id_reader.read( idbuf, count ); 03201 03202 rval = convert_id_to_handle( idbuf, count ); 03203 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 03204 03205 // idbuf will now contain zero-valued handles for those 03206 // tag values that correspond to entities we are not reading 03207 // from the file. 03208 for( size_t i = 0; i < count; ++i ) 03209 { 03210 if( idbuf[i] ) 03211 { 03212 offset_hint = offset_range.insert( offset_hint, offset + i ); 03213 if( !handle_vect.empty() ) 03214 { 03215 handle_vect.push_back( idbuf[i] ); 03216 } 03217 else if( handle_range.empty() || idbuf[i] > handle_range.back() ) 03218 { 03219 handle_hint = handle_range.insert( handle_hint, idbuf[i] ); 03220 } 03221 else 03222 { 03223 handle_vect.resize( handle_range.size() ); 03224 std::copy( handle_range.begin(), handle_range.end(), handle_vect.begin() ); 03225 handle_range.clear(); 03226 handle_vect.push_back( idbuf[i] ); 03227 dbgOut.print( 2, "Switching to unordered list for tag handle list\n" ); 03228 } 03229 } 03230 } 03231 03232 offset += count; 03233 } 03234 } 03235 catch( ReadHDF5Dataset::Exception ) 03236 { 03237 MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 03238 } 03239 03240 return MB_SUCCESS; 03241 } 03242 03243 ErrorCode ReadHDF5::read_sparse_tag( Tag tag_handle, 03244 hid_t hdf_read_type, 03245 hid_t id_table, 03246 hid_t value_table, 03247 long /*num_values*/ ) 03248 { 03249 CHECK_OPEN_HANDLES; 03250 03251 // Read entire ID table and for those file IDs corresponding 03252 // to entities that we have read from the file add both the 03253 // offset into the offset range and the handle into the handle 03254 // range. If handles are not ordered, switch to using a vector. 03255 const EntityHandle base_offset = 1; // Can't put zero in a Range 03256 std::vector< EntityHandle > handle_vect; 03257 Range handle_range, offset_range; 03258 std::string tn( "<error>" ); 03259 iFace->tag_get_name( tag_handle, tn ); 03260 ErrorCode rval = 03261 read_sparse_tag_indices( tn.c_str(), id_table, base_offset, offset_range, handle_range, handle_vect ); 03262 if( MB_SUCCESS != rval ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 03263 03264 DataType mbtype; 03265 rval = iFace->tag_get_data_type( tag_handle, mbtype ); 03266 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 03267 03268 int read_size; 03269 rval = iFace->tag_get_bytes( tag_handle, read_size ); 03270 if( MB_SUCCESS != rval ) // Wrong function for variable-length tags 03271 MB_SET_ERR( rval, "ReadHDF5 Failure" ); 03272 // if (MB_TYPE_BIT == mbtype) 03273 // read_size = (read_size + 7) / 8; // Convert bits to bytes, plus 7 for ceiling 03274 03275 if( hdf_read_type ) 03276 { // If not opaque 03277 hsize_t hdf_size = H5Tget_size( hdf_read_type ); 03278 if( hdf_size != (hsize_t)read_size ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 03279 } 03280 03281 const int handles_per_tag = read_size / sizeof( EntityHandle ); 03282 03283 // Now read data values 03284 size_t chunk_size = bufferSize / read_size; 03285 try 03286 { 03287 ReadHDF5Dataset val_reader( ( tn + " values" ).c_str(), value_table, nativeParallel, mpiComm, false ); 03288 val_reader.set_file_ids( offset_range, base_offset, chunk_size, hdf_read_type ); 03289 dbgOut.printf( 3, "Reading sparse values for tag \"%s\" in %lu chunks\n", tn.c_str(), 03290 val_reader.get_read_count() ); 03291 int nn = 0; 03292 size_t offset = 0; 03293 while( !val_reader.done() ) 03294 { 03295 dbgOut.printf( 3, "Reading chunk %d of \"%s\" values\n", ++nn, tn.c_str() ); 03296 size_t count; 03297 val_reader.read( dataBuffer, count ); 03298 if( MB_TYPE_HANDLE == mbtype ) 03299 { 03300 rval = convert_id_to_handle( (EntityHandle*)dataBuffer, count * handles_per_tag ); 03301 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 03302 } 03303 03304 if( !handle_vect.empty() ) 03305 { 03306 rval = iFace->tag_set_data( tag_handle, &handle_vect[offset], count, dataBuffer ); 03307 offset += count; 03308 } 03309 else 03310 { 03311 Range r; 03312 r.merge( handle_range.begin(), handle_range.begin() + count ); 03313 handle_range.erase( handle_range.begin(), handle_range.begin() + count ); 03314 rval = iFace->tag_set_data( tag_handle, r, dataBuffer ); 03315 } 03316 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 03317 } 03318 } 03319 catch( ReadHDF5Dataset::Exception ) 03320 { 03321 MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 03322 } 03323 03324 return MB_SUCCESS; 03325 } 03326 03327 ErrorCode ReadHDF5::read_var_len_tag( Tag tag_handle, 03328 hid_t hdf_read_type, 03329 hid_t ent_table, 03330 hid_t val_table, 03331 hid_t off_table, 03332 long /*num_entities*/, 03333 long /*num_values*/ ) 03334 { 03335 CHECK_OPEN_HANDLES; 03336 03337 ErrorCode rval; 03338 DataType mbtype; 03339 03340 rval = iFace->tag_get_data_type( tag_handle, mbtype ); 03341 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 03342 03343 // Can't do variable-length bit tags 03344 if( MB_TYPE_BIT == mbtype ) MB_CHK_ERR( MB_VARIABLE_DATA_LENGTH ); 03345 03346 // If here, MOAB tag must be variable-length 03347 int mbsize; 03348 if( MB_VARIABLE_DATA_LENGTH != iFace->tag_get_bytes( tag_handle, mbsize ) ) 03349 { 03350 assert( false );MB_CHK_ERR( MB_VARIABLE_DATA_LENGTH ); 03351 } 03352 03353 int read_size; 03354 if( hdf_read_type ) 03355 { 03356 hsize_t hdf_size = H5Tget_size( hdf_read_type ); 03357 if( hdf_size < 1 ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 03358 read_size = hdf_size; 03359 } 03360 else 03361 { 03362 // Opaque 03363 read_size = 1; 03364 } 03365 03366 std::string tn( "<error>" ); 03367 iFace->tag_get_name( tag_handle, tn ); 03368 03369 // Read entire ID table and for those file IDs corresponding 03370 // to entities that we have read from the file add both the 03371 // offset into the offset range and the handle into the handle 03372 // range. If handles are not ordered, switch to using a vector. 03373 const EntityHandle base_offset = 1; // Can't put zero in a Range 03374 std::vector< EntityHandle > handle_vect; 03375 Range handle_range, offset_range; 03376 rval = read_sparse_tag_indices( tn.c_str(), ent_table, base_offset, offset_range, handle_range, handle_vect ); 03377 03378 // This code only works if the id_table is an ordered list. 03379 // This assumption was also true for the previous iteration 03380 // of this code, but wasn't checked. MOAB's file writer 03381 // always writes an ordered list for id_table. 03382 if( !handle_vect.empty() ) 03383 { 03384 MB_SET_ERR( MB_FAILURE, "Unordered file ids for variable length tag not supported" ); 03385 } 03386 03387 class VTReader : public ReadHDF5VarLen 03388 { 03389 Tag tagHandle; 03390 bool isHandle; 03391 size_t readSize; 03392 ReadHDF5* readHDF5; 03393 03394 public: 03395 ErrorCode store_data( EntityHandle file_id, void* data, long count, bool ) 03396 { 03397 ErrorCode rval1; 03398 if( isHandle ) 03399 { 03400 if( readSize != sizeof( EntityHandle ) ) MB_CHK_SET_ERR( MB_FAILURE, "Invalid read size" ); 03401 rval1 = readHDF5->convert_id_to_handle( (EntityHandle*)data, count );MB_CHK_ERR( rval1 ); 03402 } 03403 int n = count; 03404 return readHDF5->moab()->tag_set_by_ptr( tagHandle, &file_id, 1, &data, &n ); 03405 } 03406 VTReader( DebugOutput& debug_output, 03407 void* buffer, 03408 size_t buffer_size, 03409 Tag tag, 03410 bool is_handle_tag, 03411 size_t read_size1, 03412 ReadHDF5* owner ) 03413 : ReadHDF5VarLen( debug_output, buffer, buffer_size ), tagHandle( tag ), isHandle( is_handle_tag ), 03414 readSize( read_size1 ), readHDF5( owner ) 03415 { 03416 } 03417 }; 03418 03419 VTReader tool( dbgOut, dataBuffer, bufferSize, tag_handle, MB_TYPE_HANDLE == mbtype, read_size, this ); 03420 try 03421 { 03422 // Read offsets into value table. 03423 std::vector< unsigned > counts; 03424 Range offsets; 03425 ReadHDF5Dataset off_reader( ( tn + " offsets" ).c_str(), off_table, nativeParallel, mpiComm, false ); 03426 rval = tool.read_offsets( off_reader, offset_range, base_offset, base_offset, offsets, counts ); 03427 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 03428 03429 // Read tag values 03430 Range empty; 03431 ReadHDF5Dataset val_reader( ( tn + " values" ).c_str(), val_table, nativeParallel, mpiComm, false ); 03432 rval = tool.read_data( val_reader, offsets, base_offset, hdf_read_type, handle_range, counts, empty ); 03433 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 03434 } 03435 catch( ReadHDF5Dataset::Exception ) 03436 { 03437 MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 03438 } 03439 03440 return MB_SUCCESS; 03441 } 03442 03443 ErrorCode ReadHDF5::convert_id_to_handle( EntityHandle* array, size_t size ) 03444 { 03445 convert_id_to_handle( array, size, idMap ); 03446 return MB_SUCCESS; 03447 } 03448 03449 void ReadHDF5::convert_id_to_handle( EntityHandle* array, size_t size, const RangeMap< long, EntityHandle >& id_map ) 03450 { 03451 for( EntityHandle* const end = array + size; array != end; ++array ) 03452 *array = id_map.find( *array ); 03453 } 03454 03455 void ReadHDF5::convert_id_to_handle( EntityHandle* array, 03456 size_t size, 03457 size_t& new_size, 03458 const RangeMap< long, EntityHandle >& id_map ) 03459 { 03460 RangeMap< long, EntityHandle >::const_iterator it; 03461 new_size = 0; 03462 for( size_t i = 0; i < size; ++i ) 03463 { 03464 it = id_map.lower_bound( array[i] ); 03465 if( it != id_map.end() && it->begin <= (long)array[i] ) 03466 array[new_size++] = it->value + ( array[i] - it->begin ); 03467 } 03468 } 03469 03470 void ReadHDF5::convert_range_to_handle( const EntityHandle* ranges, 03471 size_t num_ranges, 03472 const RangeMap< long, EntityHandle >& id_map, 03473 Range& merge ) 03474 { 03475 RangeMap< long, EntityHandle >::iterator it = id_map.begin(); 03476 Range::iterator hint = merge.begin(); 03477 for( size_t i = 0; i < num_ranges; ++i ) 03478 { 03479 long id = ranges[2 * i]; 03480 const long end = id + ranges[2 * i + 1]; 03481 // We assume that 'ranges' is sorted, but check just in case it isn't. 03482 if( it == id_map.end() || it->begin > id ) it = id_map.begin(); 03483 it = id_map.lower_bound( it, id_map.end(), id ); 03484 if( it == id_map.end() ) continue; 03485 if( id < it->begin ) id = it->begin; 03486 while( id < end ) 03487 { 03488 if( id < it->begin ) id = it->begin; 03489 const long off = id - it->begin; 03490 long count = std::min( it->count - off, end - id ); 03491 // It is possible that this new subrange is starting after the end 03492 // It will result in negative count, which does not make sense 03493 // We are done with this range, go to the next one 03494 if( count <= 0 ) break; 03495 hint = merge.insert( hint, it->value + off, it->value + off + count - 1 ); 03496 id += count; 03497 if( id < end ) 03498 { 03499 if( ++it == id_map.end() ) break; 03500 if( it->begin > end ) break; 03501 } 03502 } 03503 } 03504 } 03505 03506 ErrorCode ReadHDF5::convert_range_to_handle( const EntityHandle* array, size_t num_ranges, Range& range ) 03507 { 03508 convert_range_to_handle( array, num_ranges, idMap, range ); 03509 return MB_SUCCESS; 03510 } 03511 03512 ErrorCode ReadHDF5::insert_in_id_map( const Range& file_ids, EntityHandle start_id ) 03513 { 03514 IDMap tmp_map; 03515 bool merge = !idMap.empty() && !file_ids.empty() && idMap.back().begin > (long)file_ids.front(); 03516 IDMap& map = merge ? tmp_map : idMap; 03517 Range::const_pair_iterator p; 03518 for( p = file_ids.const_pair_begin(); p != file_ids.const_pair_end(); ++p ) 03519 { 03520 size_t count = p->second - p->first + 1; 03521 if( !map.insert( p->first, start_id, count ).second ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 03522 start_id += count; 03523 } 03524 if( merge && !idMap.merge( tmp_map ) ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 03525 03526 return MB_SUCCESS; 03527 } 03528 03529 ErrorCode ReadHDF5::insert_in_id_map( long file_id, EntityHandle handle ) 03530 { 03531 if( !idMap.insert( file_id, handle, 1 ).second ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 03532 return MB_SUCCESS; 03533 } 03534 03535 ErrorCode ReadHDF5::read_qa( EntityHandle ) 03536 { 03537 CHECK_OPEN_HANDLES; 03538 03539 mhdf_Status status; 03540 // std::vector<std::string> qa_list; 03541 03542 int qa_len; 03543 char** qa = mhdf_readHistory( filePtr, &qa_len, &status ); 03544 if( mhdf_isError( &status ) ) 03545 { 03546 MB_SET_ERR( MB_FAILURE, mhdf_message( &status ) ); 03547 } 03548 // qa_list.resize(qa_len); 03549 for( int i = 0; i < qa_len; i++ ) 03550 { 03551 // qa_list[i] = qa[i]; 03552 free( qa[i] ); 03553 } 03554 free( qa ); 03555 03556 /** FIX ME - how to put QA list on set?? */ 03557 03558 return MB_SUCCESS; 03559 } 03560 03561 ErrorCode ReadHDF5::store_file_ids( Tag tag ) 03562 { 03563 CHECK_OPEN_HANDLES; 03564 03565 // typedef int tag_type; 03566 typedef long tag_type; 03567 // change it to be able to read much bigger files (long is 64 bits ...) 03568 03569 tag_type* buffer = reinterpret_cast< tag_type* >( dataBuffer ); 03570 const long buffer_size = bufferSize / sizeof( tag_type ); 03571 for( IDMap::iterator i = idMap.begin(); i != idMap.end(); ++i ) 03572 { 03573 IDMap::Range range = *i; 03574 03575 // Make sure the values will fit in the tag type 03576 IDMap::key_type rv = range.begin + ( range.count - 1 ); 03577 tag_type tv = (tag_type)rv; 03578 if( (IDMap::key_type)tv != rv ) 03579 { 03580 assert( false ); 03581 return MB_INDEX_OUT_OF_RANGE; 03582 } 03583 03584 while( range.count ) 03585 { 03586 long count = buffer_size < range.count ? buffer_size : range.count; 03587 03588 Range handles; 03589 handles.insert( range.value, range.value + count - 1 ); 03590 range.value += count; 03591 range.count -= count; 03592 for( long j = 0; j < count; ++j ) 03593 buffer[j] = (tag_type)range.begin++; 03594 03595 ErrorCode rval = iFace->tag_set_data( tag, handles, buffer ); 03596 if( MB_SUCCESS != rval ) return rval; 03597 } 03598 } 03599 03600 return MB_SUCCESS; 03601 } 03602 03603 ErrorCode ReadHDF5::store_sets_file_ids() 03604 { 03605 CHECK_OPEN_HANDLES; 03606 03607 // create a tag that will not be saved, but it will be 03608 // used by visit plugin to match the sets and their file ids 03609 // it is the same type as the tag defined in ReadParallelcpp, for file id 03610 Tag setFileIdTag; 03611 long default_val = 0; 03612 ErrorCode rval = iFace->tag_get_handle( "__FILE_ID_FOR_SETS", sizeof( long ), MB_TYPE_OPAQUE, setFileIdTag, 03613 ( MB_TAG_DENSE | MB_TAG_CREAT ), &default_val ); 03614 03615 if( MB_SUCCESS != rval || 0 == setFileIdTag ) return rval; 03616 // typedef int tag_type; 03617 typedef long tag_type; 03618 // change it to be able to read much bigger files (long is 64 bits ...) 03619 03620 tag_type* buffer = reinterpret_cast< tag_type* >( dataBuffer ); 03621 const long buffer_size = bufferSize / sizeof( tag_type ); 03622 for( IDMap::iterator i = idMap.begin(); i != idMap.end(); ++i ) 03623 { 03624 IDMap::Range range = *i; 03625 EntityType htype = iFace->type_from_handle( range.value ); 03626 if( MBENTITYSET != htype ) continue; 03627 // work only with entity sets 03628 // Make sure the values will fit in the tag type 03629 IDMap::key_type rv = range.begin + ( range.count - 1 ); 03630 tag_type tv = (tag_type)rv; 03631 if( (IDMap::key_type)tv != rv ) 03632 { 03633 assert( false ); 03634 return MB_INDEX_OUT_OF_RANGE; 03635 } 03636 03637 while( range.count ) 03638 { 03639 long count = buffer_size < range.count ? buffer_size : range.count; 03640 03641 Range handles; 03642 handles.insert( range.value, range.value + count - 1 ); 03643 range.value += count; 03644 range.count -= count; 03645 for( long j = 0; j < count; ++j ) 03646 buffer[j] = (tag_type)range.begin++; 03647 03648 rval = iFace->tag_set_data( setFileIdTag, handles, buffer ); 03649 if( MB_SUCCESS != rval ) return rval; 03650 } 03651 } 03652 return MB_SUCCESS; 03653 } 03654 03655 ErrorCode ReadHDF5::read_tag_values( const char* file_name, 03656 const char* tag_name, 03657 const FileOptions& opts, 03658 std::vector< int >& tag_values_out, 03659 const SubsetList* subset_list ) 03660 { 03661 ErrorCode rval; 03662 03663 rval = set_up_read( file_name, opts ); 03664 if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" ); 03665 03666 int tag_index; 03667 rval = find_int_tag( tag_name, tag_index ); 03668 if( MB_SUCCESS != rval ) 03669 { 03670 clean_up_read( opts ); 03671 MB_SET_ERR( rval, "ReadHDF5 Failure" ); 03672 } 03673 03674 if( subset_list ) 03675 { 03676 Range file_ids; 03677 rval = get_subset_ids( subset_list->tag_list, subset_list->tag_list_length, file_ids ); 03678 if( MB_SUCCESS != rval ) 03679 { 03680 clean_up_read( opts ); 03681 MB_SET_ERR( rval, "ReadHDF5 Failure" ); 03682 } 03683 03684 rval = read_tag_values_partial( tag_index, file_ids, tag_values_out ); 03685 if( MB_SUCCESS != rval ) 03686 { 03687 clean_up_read( opts ); 03688 MB_SET_ERR( rval, "ReadHDF5 Failure" ); 03689 } 03690 } 03691 else 03692 { 03693 rval = read_tag_values_all( tag_index, tag_values_out ); 03694 if( MB_SUCCESS != rval ) 03695 { 03696 clean_up_read( opts ); 03697 MB_SET_ERR( rval, "ReadHDF5 Failure" ); 03698 } 03699 } 03700 03701 return clean_up_read( opts ); 03702 } 03703 03704 ErrorCode ReadHDF5::read_tag_values_partial( int tag_index, const Range& file_ids, std::vector< int >& tag_values ) 03705 { 03706 CHECK_OPEN_HANDLES; 03707 03708 mhdf_Status status; 03709 const mhdf_TagDesc& tag = fileInfo->tags[tag_index]; 03710 long num_ent, num_val; 03711 size_t count; 03712 std::string tn( tag.name ); 03713 03714 // Read sparse values 03715 if( tag.have_sparse ) 03716 { 03717 hid_t handles[3]; 03718 mhdf_openSparseTagData( filePtr, tag.name, &num_ent, &num_val, handles, &status ); 03719 if( mhdf_isError( &status ) ) 03720 { 03721 MB_SET_ERR( MB_FAILURE, mhdf_message( &status ) ); 03722 } 03723 03724 try 03725 { 03726 // Read all entity handles and fill 'offsets' with ranges of 03727 // offsets into the data table for entities that we want. 03728 Range offsets; 03729 long* buffer = reinterpret_cast< long* >( dataBuffer ); 03730 const long buffer_size = bufferSize / sizeof( long ); 03731 ReadHDF5Dataset ids( ( tn + " ids" ).c_str(), handles[0], nativeParallel, mpiComm ); 03732 ids.set_all_file_ids( buffer_size, H5T_NATIVE_LONG ); 03733 size_t offset = 0; 03734 dbgOut.printf( 3, "Reading sparse IDs for tag \"%s\" in %lu chunks\n", tag.name, ids.get_read_count() ); 03735 int nn = 0; 03736 while( !ids.done() ) 03737 { 03738 dbgOut.printf( 3, "Reading chunk %d of IDs for \"%s\"\n", ++nn, tag.name ); 03739 ids.read( buffer, count ); 03740 03741 std::sort( buffer, buffer + count ); 03742 Range::iterator ins = offsets.begin(); 03743 Range::const_iterator i = file_ids.begin(); 03744 for( size_t j = 0; j < count; ++j ) 03745 { 03746 while( i != file_ids.end() && (long)*i < buffer[j] ) 03747 ++i; 03748 if( i == file_ids.end() ) break; 03749 if( (long)*i == buffer[j] ) 03750 { 03751 ins = offsets.insert( ins, j + offset, j + offset ); 03752 } 03753 } 03754 03755 offset += count; 03756 } 03757 03758 tag_values.clear(); 03759 tag_values.reserve( offsets.size() ); 03760 const size_t data_buffer_size = bufferSize / sizeof( int ); 03761 int* data_buffer = reinterpret_cast< int* >( dataBuffer ); 03762 ReadHDF5Dataset vals( ( tn + " sparse vals" ).c_str(), handles[1], nativeParallel, mpiComm ); 03763 vals.set_file_ids( offsets, 0, data_buffer_size, H5T_NATIVE_INT ); 03764 dbgOut.printf( 3, "Reading sparse values for tag \"%s\" in %lu chunks\n", tag.name, vals.get_read_count() ); 03765 nn = 0; 03766 // Should normally only have one read call, unless sparse nature 03767 // of file_ids caused reader to do something strange 03768 while( !vals.done() ) 03769 { 03770 dbgOut.printf( 3, "Reading chunk %d of values for \"%s\"\n", ++nn, tag.name ); 03771 vals.read( data_buffer, count ); 03772 tag_values.insert( tag_values.end(), data_buffer, data_buffer + count ); 03773 } 03774 } 03775 catch( ReadHDF5Dataset::Exception ) 03776 { 03777 MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 03778 } 03779 } 03780 03781 std::sort( tag_values.begin(), tag_values.end() ); 03782 tag_values.erase( std::unique( tag_values.begin(), tag_values.end() ), tag_values.end() ); 03783 03784 // Read dense values 03785 std::vector< int > prev_data, curr_data; 03786 for( int i = 0; i < tag.num_dense_indices; ++i ) 03787 { 03788 int grp = tag.dense_elem_indices[i]; 03789 const char* gname = 0; 03790 mhdf_EntDesc* desc = 0; 03791 if( grp == -1 ) 03792 { 03793 gname = mhdf_node_type_handle(); 03794 desc = &fileInfo->nodes; 03795 } 03796 else if( grp == -2 ) 03797 { 03798 gname = mhdf_set_type_handle(); 03799 desc = &fileInfo->sets; 03800 } 03801 else 03802 { 03803 assert( grp >= 0 && grp < fileInfo->num_elem_desc ); 03804 gname = fileInfo->elems[grp].handle; 03805 desc = &fileInfo->elems[grp].desc; 03806 } 03807 03808 Range::iterator s = file_ids.lower_bound( (EntityHandle)( desc->start_id ) ); 03809 Range::iterator e = Range::lower_bound( s, file_ids.end(), (EntityHandle)( desc->start_id ) + desc->count ); 03810 Range subset; 03811 subset.merge( s, e ); 03812 03813 hid_t handle = mhdf_openDenseTagData( filePtr, tag.name, gname, &num_val, &status ); 03814 if( mhdf_isError( &status ) ) 03815 { 03816 MB_SET_ERR( MB_FAILURE, mhdf_message( &status ) ); 03817 } 03818 03819 try 03820 { 03821 curr_data.clear(); 03822 tag_values.reserve( subset.size() ); 03823 const size_t data_buffer_size = bufferSize / sizeof( int ); 03824 int* data_buffer = reinterpret_cast< int* >( dataBuffer ); 03825 03826 ReadHDF5Dataset reader( ( tn + " dense vals" ).c_str(), handle, nativeParallel, mpiComm ); 03827 reader.set_file_ids( subset, desc->start_id, data_buffer_size, H5T_NATIVE_INT ); 03828 dbgOut.printf( 3, "Reading dense data for tag \"%s\" and group \"%s\" in %lu chunks\n", tag.name, 03829 fileInfo->elems[grp].handle, reader.get_read_count() ); 03830 int nn = 0; 03831 // Should normally only have one read call, unless sparse nature 03832 // of file_ids caused reader to do something strange 03833 while( !reader.done() ) 03834 { 03835 dbgOut.printf( 3, "Reading chunk %d of \"%s\"/\"%s\"\n", ++nn, tag.name, fileInfo->elems[grp].handle ); 03836 reader.read( data_buffer, count ); 03837 curr_data.insert( curr_data.end(), data_buffer, data_buffer + count ); 03838 } 03839 } 03840 catch( ReadHDF5Dataset::Exception ) 03841 { 03842 MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 03843 } 03844 03845 std::sort( curr_data.begin(), curr_data.end() ); 03846 curr_data.erase( std::unique( curr_data.begin(), curr_data.end() ), curr_data.end() ); 03847 prev_data.clear(); 03848 tag_values.swap( prev_data ); 03849 std::set_union( prev_data.begin(), prev_data.end(), curr_data.begin(), curr_data.end(), 03850 std::back_inserter( tag_values ) ); 03851 } 03852 03853 return MB_SUCCESS; 03854 } 03855 03856 ErrorCode ReadHDF5::read_tag_values_all( int tag_index, std::vector< int >& tag_values ) 03857 { 03858 CHECK_OPEN_HANDLES; 03859 03860 mhdf_Status status; 03861 const mhdf_TagDesc& tag = fileInfo->tags[tag_index]; 03862 long junk, num_val; 03863 03864 // Read sparse values 03865 if( tag.have_sparse ) 03866 { 03867 hid_t handles[3]; 03868 mhdf_openSparseTagData( filePtr, tag.name, &junk, &num_val, handles, &status ); 03869 if( mhdf_isError( &status ) ) 03870 { 03871 MB_SET_ERR( MB_FAILURE, mhdf_message( &status ) ); 03872 } 03873 03874 mhdf_closeData( filePtr, handles[0], &status ); 03875 if( mhdf_isError( &status ) ) 03876 { 03877 MB_SET_ERR_CONT( mhdf_message( &status ) ); 03878 mhdf_closeData( filePtr, handles[1], &status ); 03879 MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 03880 } 03881 03882 hid_t file_type = H5Dget_type( handles[1] ); 03883 tag_values.resize( num_val ); 03884 mhdf_readTagValuesWithOpt( handles[1], 0, num_val, file_type, &tag_values[0], collIO, &status ); 03885 if( mhdf_isError( &status ) ) 03886 { 03887 MB_SET_ERR_CONT( mhdf_message( &status ) ); 03888 H5Tclose( file_type ); 03889 mhdf_closeData( filePtr, handles[1], &status ); 03890 MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 03891 } 03892 H5Tconvert( file_type, H5T_NATIVE_INT, num_val, &tag_values[0], 0, H5P_DEFAULT ); 03893 H5Tclose( file_type ); 03894 03895 mhdf_closeData( filePtr, handles[1], &status ); 03896 if( mhdf_isError( &status ) ) 03897 { 03898 MB_SET_ERR( MB_FAILURE, mhdf_message( &status ) ); 03899 } 03900 } 03901 03902 std::sort( tag_values.begin(), tag_values.end() ); 03903 tag_values.erase( std::unique( tag_values.begin(), tag_values.end() ), tag_values.end() ); 03904 03905 // Read dense values 03906 std::vector< int > prev_data, curr_data; 03907 for( int i = 0; i < tag.num_dense_indices; ++i ) 03908 { 03909 int grp = tag.dense_elem_indices[i]; 03910 const char* gname = 0; 03911 if( grp == -1 ) 03912 gname = mhdf_node_type_handle(); 03913 else if( grp == -2 ) 03914 gname = mhdf_set_type_handle(); 03915 else 03916 gname = fileInfo->elems[grp].handle; 03917 hid_t handle = mhdf_openDenseTagData( filePtr, tag.name, gname, &num_val, &status ); 03918 if( mhdf_isError( &status ) ) 03919 { 03920 MB_SET_ERR( MB_FAILURE, mhdf_message( &status ) ); 03921 } 03922 03923 hid_t file_type = H5Dget_type( handle ); 03924 curr_data.resize( num_val ); 03925 mhdf_readTagValuesWithOpt( handle, 0, num_val, file_type, &curr_data[0], collIO, &status ); 03926 if( mhdf_isError( &status ) ) 03927 { 03928 MB_SET_ERR_CONT( mhdf_message( &status ) ); 03929 H5Tclose( file_type ); 03930 mhdf_closeData( filePtr, handle, &status ); 03931 MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" ); 03932 } 03933 03934 H5Tconvert( file_type, H5T_NATIVE_INT, num_val, &curr_data[0], 0, H5P_DEFAULT ); 03935 H5Tclose( file_type ); 03936 mhdf_closeData( filePtr, handle, &status ); 03937 if( mhdf_isError( &status ) ) 03938 { 03939 MB_SET_ERR( MB_FAILURE, mhdf_message( &status ) ); 03940 } 03941 03942 std::sort( curr_data.begin(), curr_data.end() ); 03943 curr_data.erase( std::unique( curr_data.begin(), curr_data.end() ), curr_data.end() ); 03944 03945 prev_data.clear(); 03946 tag_values.swap( prev_data ); 03947 std::set_union( prev_data.begin(), prev_data.end(), curr_data.begin(), curr_data.end(), 03948 std::back_inserter( tag_values ) ); 03949 } 03950 03951 return MB_SUCCESS; 03952 } 03953 void ReadHDF5::print_times() 03954 { 03955 #ifdef MOAB_HAVE_MPI 03956 if( !myPcomm ) 03957 { 03958 double recv[NUM_TIMES]; 03959 MPI_Reduce( (void*)_times, recv, NUM_TIMES, MPI_DOUBLE, MPI_MAX, 0, myPcomm->proc_config().proc_comm() ); 03960 for( int i = 0; i < NUM_TIMES; i++ ) 03961 _times[i] = recv[i]; // just get the max from all of them 03962 } 03963 if( 0 == myPcomm->proc_config().proc_rank() ) 03964 { 03965 #endif 03966 03967 std::cout << "ReadHDF5: " << _times[TOTAL_TIME] << std::endl 03968 << " get set meta " << _times[SET_META_TIME] << std::endl 03969 << " partial subsets " << _times[SUBSET_IDS_TIME] << std::endl 03970 << " partition time " << _times[GET_PARTITION_TIME] << std::endl 03971 << " get set ids " << _times[GET_SET_IDS_TIME] << std::endl 03972 << " set contents " << _times[GET_SET_CONTENTS_TIME] << std::endl 03973 << " polyhedra " << _times[GET_POLYHEDRA_TIME] << std::endl 03974 << " elements " << _times[GET_ELEMENTS_TIME] << std::endl 03975 << " nodes " << _times[GET_NODES_TIME] << std::endl 03976 << " node adjacency " << _times[GET_NODEADJ_TIME] << std::endl 03977 << " side elements " << _times[GET_SIDEELEM_TIME] << std::endl 03978 << " update connectivity " << _times[UPDATECONN_TIME] << std::endl 03979 << " adjacency " << _times[ADJACENCY_TIME] << std::endl 03980 << " delete non_adj " << _times[DELETE_NON_SIDEELEM_TIME] << std::endl 03981 << " recursive sets " << _times[READ_SET_IDS_RECURS_TIME] << std::endl 03982 << " find contain_sets " << _times[FIND_SETS_CONTAINING_TIME] << std::endl 03983 << " read sets " << _times[READ_SETS_TIME] << std::endl 03984 << " read tags " << _times[READ_TAGS_TIME] << std::endl 03985 << " store file ids " << _times[STORE_FILE_IDS_TIME] << std::endl 03986 << " read qa records " << _times[READ_QA_TIME] << std::endl; 03987 03988 #ifdef MOAB_HAVE_MPI 03989 } 03990 #endif 03991 } 03992 03993 } // namespace moab
