MOAB: Mesh Oriented datABase
(version 5.4.1)
Collaboration diagram for Set flag bits:Defines | |
| #define | mhdf_SET_OWNER_BIT 0x1 |
| Make entities in set aware of owning set (MOAB-specific?) | |
| #define | mhdf_SET_UNIQUE_BIT 0x2 |
| Set cannot contain duplicates. | |
| #define | mhdf_SET_ORDER_BIT 0x4 |
| Set order is preserved. | |
| #define | mhdf_SET_RANGE_BIT 0x8 |
| The bit specifying set storage format. | |
| #define mhdf_SET_ORDER_BIT 0x4 |
Definition at line 1188 of file mhdf.h.
Referenced by check_valid_set_contents().
| #define mhdf_SET_OWNER_BIT 0x1 |
| #define mhdf_SET_RANGE_BIT 0x8 |
If this bit is set, then the contents of a set (not the children) is written as set of ranges, where each range is of the form {global start id, count}. For such a range, the set contains the count entities with sequential global IDs beginning with the specified start ID. If this bit is not set in the set flags, the contents of the set are stored as a simple list of global IDs.
Definition at line 1199 of file mhdf.h.
Referenced by check_valid_set_contents(), moab::WriteHDF5Parallel::communicate_shared_set_data(), dump_set_contents(), moab::ReadHDF5::find_sets_containing(), moab::WriteHDF5Parallel::pack_set(), moab::ReadHDF5::read_set_data(), moab::ReadHDF5::read_sets(), moab::WriteHDF5Parallel::unpack_set(), and moab::WriteHDF5::write_sets().
| #define mhdf_SET_UNIQUE_BIT 0x2 |
