moab::ReadHDF5 Class Reference
Read mesh from MOAB HDF5 (.h5m) file. More...
#include <ReadHDF5.hpp>
+ Inheritance diagram for moab::ReadHDF5:
+ Collaboration diagram for moab::ReadHDF5:
Classes
struct  HDF5ErrorHandler
 Store old HDF5 error handling function. More...
struct  IDConnectivity
Public Types
enum  SetMode { CONTENT = 0, CHILD = 1, PARENT = 2 }
typedef int Comm
Public Member Functions
 ReadHDF5 (Interface *iface)
virtual ~ReadHDF5 ()
ErrorCode load_file (const char *file_name, const EntityHandle *file_set, const FileOptions &opts, const SubsetList *subset_list=0, const Tag *file_id_tag=0)
ErrorCode read_tag_values (const char *file_name, const char *tag_name, const FileOptions &opts, std::vector< int > &tag_values_out, const SubsetList *subset_list=0)
 Read tag values from a file.
Interface * moab () const
ErrorCode convert_id_to_handle (EntityHandle *in_out_array, size_t array_length)
void convert_id_to_handle (EntityHandle *in_out_array, size_t array_length, size_t &array_length_out) const
ErrorCode convert_range_to_handle (const EntityHandle *ranges, size_t num_ranges, Range &merge)
ErrorCode insert_in_id_map (const Range &file_ids, EntityHandle start_id)
ErrorCode insert_in_id_map (long file_id, EntityHandle handle)
Static Public Member Functions
static ReaderIface * factory (Interface *)
static void convert_id_to_handle (EntityHandle *in_out_array, size_t array_length, const RangeMap< long, EntityHandle > &id_map)
static void convert_id_to_handle (EntityHandle *in_out_array, size_t array_length, size_t &array_length_out, const RangeMap< long, EntityHandle > &id_map)
static void convert_range_to_handle (const EntityHandle *ranges, size_t num_ranges, const RangeMap< long, EntityHandle > &id_map, Range &merge)
Protected Types
enum  ReadTimingValues {
  TOTAL_TIME = 0, SET_META_TIME, SUBSET_IDS_TIME, GET_PARTITION_TIME,
  GET_SET_IDS_TIME, GET_SET_CONTENTS_TIME, GET_POLYHEDRA_TIME, GET_ELEMENTS_TIME,
  GET_NODES_TIME, GET_NODEADJ_TIME, GET_SIDEELEM_TIME, UPDATECONN_TIME,
  ADJACENCY_TIME, DELETE_NON_SIDEELEM_TIME, READ_SET_IDS_RECURS_TIME, FIND_SETS_CONTAINING_TIME,
  READ_SETS_TIME, READ_TAGS_TIME, STORE_FILE_IDS_TIME, READ_QA_TIME,
  NUM_TIMES
Protected Member Functions
ErrorCode load_file_impl (const FileOptions &opts)
ErrorCode load_file_partial (const ReaderIface::IDTag *subset_list, int subset_list_length, int num_parts, int part_number, const FileOptions &opts)
ErrorCode read_tag_values_all (int tag_index, std::vector< int > &results)
ErrorCode read_tag_values_partial (int tag_index, const Range &file_ids, std::vector< int > &results)
void print_times ()
Private Types
typedef RangeMap< long,
EntityHandle >
IDMap
 Map from File ID to MOAB handle.
Private Member Functions
ErrorCode init ()
int is_error (mhdf_Status &status)
ErrorCode read_all_set_meta ()
ErrorCode set_up_read (const char *file_name, const FileOptions &opts)
ErrorCode clean_up_read (const FileOptions &opts)
ErrorCode get_subset_ids (const ReaderIface::IDTag *subset_list, int subset_list_length, Range &file_ids_out)
ErrorCode get_partition (Range &tmp_file_ids, int num_parts, int part_number)
 Remove all but the specified fraction of sets from the passed range.
ErrorCode read_nodes (const Range &node_file_ids)
ErrorCode read_elems (int index)
ErrorCode read_elems (int index, const Range &file_ids, Range *node_ids=0)
ErrorCode read_elems (const mhdf_ElemDesc &elems, const Range &file_ids, Range *node_ids=0)
ErrorCode update_connectivity ()
ErrorCode read_elems (int index, const Range &element_file_ids, Range &node_file_ids)
ErrorCode read_node_adj_elems (const mhdf_ElemDesc &group, Range *read_entities=0)
ErrorCode read_node_adj_elems (const mhdf_ElemDesc &group, hid_t connectivity_handle, Range *read_entities=0)
ErrorCode read_poly (const mhdf_ElemDesc &elems, const Range &file_ids)
 Read poly(gons|hedra)
ErrorCode delete_non_side_elements (const Range &side_ents)
ErrorCode read_sets (const Range &set_file_ids)
 Read sets.
ErrorCode read_adjacencies (hid_t adjacency_table, long table_length)
ErrorCode read_tag (int index)
 Create tag and read all data.
ErrorCode create_tag (const mhdf_TagDesc &info, Tag &handle, hid_t &type)
 Create new tag or verify type matches existing tag.
ErrorCode read_dense_tag (Tag tag_handle, const char *ent_name, hid_t hdf_read_type, hid_t data_table, long start_id, long count)
 Read dense tag for all entities.
ErrorCode read_sparse_tag (Tag tag_handle, hid_t hdf_read_type, hid_t ent_table, hid_t val_table, long num_entities)
 Read sparse tag for all entities.
ErrorCode read_var_len_tag (Tag tag_handle, hid_t hdf_read_type, hid_t ent_table, hid_t val_table, hid_t off_table, long num_entities, long num_values)
 Read variable-length tag for all entities.
ErrorCode read_sparse_tag_indices (const char *name, hid_t id_table, EntityHandle start_offset, Range &offset_range, Range &handle_range, std::vector< EntityHandle > &handle_vect)
 Read index table for sparse tag.
ErrorCode read_qa (EntityHandle file_set)
ErrorCode search_tag_values (int tag_index, const std::vector< int > &sorted_values, Range &file_ids_out, bool sets_only=false)
 Search for entities with specified tag values.
ErrorCode get_tagged_entities (int tag_index, Range &file_ids_out)
 Search for entities with specified tag.
ErrorCode search_tag_values (hid_t tag_table, unsigned long table_size, const std::vector< int > &sorted_values, std::vector< EntityHandle > &value_indices)
 Search a table of tag data for a specified set of values.
ErrorCode get_set_contents (const Range &sets, Range &file_ids)
 Get the file IDs for nodes and elements contained in sets.
ErrorCode read_set_ids_recursive (Range &sets_in_out, bool containted_sets, bool child_sets)
ErrorCode find_sets_containing (Range &sets_out, bool read_set_containing_parents)
ErrorCode read_sets_partial (const Range &sets_in)
 Read sets from file into MOAB for partial read of file.
ErrorCode find_sets_containing (hid_t content_handle, hid_t content_type, long content_len, bool read_set_containing_parents, Range &file_ids)
ErrorCode read_set_data (const Range &set_file_ids, EntityHandle set_start_handle, ReadHDF5Dataset &set_data_set, SetMode which_data, Range *file_ids_out=0)
ErrorCode store_file_ids (Tag tag)
 Store file IDS in tag values.
ErrorCode store_sets_file_ids ()
 Store sets file IDS in a custom tag.
ErrorCode find_int_tag (const char *name, int &index_out)
 Find index in mhdf_FileDesc* fileInfo for specified tag name.
void debug_barrier_line (int lineno)
Private Attributes
int bufferSize
 The size of the data buffer (dataBuffer).
char * dataBuffer
 A memory buffer to use for all I/O operations.
Interface * iFace
 Interface pointer passed to constructor.
mhdf_FileHandle filePtr
 The file handle from the mhdf library.
mhdf_FileDesc * fileInfo
 File summary.
IDMap idMap
ReadUtilIface * readUtil
 Cache pointer to read util.
hid_t handleType
 The type of an EntityHandle.
std::vector< IDConnectivity > idConnectivityList
hid_t indepIO
hid_t collIO
ParallelComm * myPcomm
bool debugTrack
DebugOutput dbgOut
 Debug output. Verbosity controlled with DEBUG_FORMAT option.
bool nativeParallel
 Doing true parallel read (PARALLEL=READ_PART)
Comm * mpiComm
 MPI_Comm value (unused if !nativeParallel)
bool blockedCoordinateIO
bool bcastSummary
bool bcastDuplicateReads
HDF5ErrorHandler errorHandler
long(* setMeta )[4]
double _times [NUM_TIMES]
CpuTimer * timer
bool cputime
Detailed Description
Author:
Jason Kraftcheck
Date:
18 April 2004
Definition at line 46 of file ReadHDF5.hpp.
Member Typedef Documentation
typedef int moab::ReadHDF5::Comm
Definition at line 52 of file ReadHDF5.hpp.
typedef RangeMap< long, EntityHandle > moab::ReadHDF5::IDMap [private]
Definition at line 153 of file ReadHDF5.hpp.
Member Enumeration Documentation
Enumerator:
TOTAL_TIME
SET_META_TIME
SUBSET_IDS_TIME
GET_PARTITION_TIME
GET_SET_IDS_TIME
GET_POLYHEDRA_TIME
GET_ELEMENTS_TIME
GET_NODES_TIME
GET_NODEADJ_TIME
GET_SIDEELEM_TIME
UPDATECONN_TIME
ADJACENCY_TIME
READ_SETS_TIME
READ_TAGS_TIME
STORE_FILE_IDS_TIME
READ_QA_TIME
NUM_TIMES
Definition at line 101 of file ReadHDF5.hpp.
Enumerator:
CONTENT
CHILD
PARENT
Definition at line 451 of file ReadHDF5.hpp.
        CONTENT = 0,
        CHILD   = 1,
        PARENT  = 2
Definition at line 188 of file ReadHDF5.cpp.
Referenced by factory().
    : bufferSize( READ_HDF5_BUFFER_SIZE ), dataBuffer( NULL ), iFace( iface ), filePtr( 0 ), fileInfo( NULL ),
      readUtil( NULL ), handleType( 0 ), indepIO( H5P_DEFAULT ), collIO( H5P_DEFAULT ), myPcomm( NULL ),
      debugTrack( false ), dbgOut( stderr ), nativeParallel( false ), mpiComm( NULL ),
      blockedCoordinateIO( DEFAULT_BLOCKED_COORDINATE_IO ), bcastSummary( DEFAULT_BCAST_SUMMARY ),
      bcastDuplicateReads( DEFAULT_BCAST_DUPLICATE_READS ), setMeta( 0 ), timer( NULL ), cputime( false )
Definition at line 230 of file ReadHDF5.cpp.
References handleType, iFace, readUtil, moab::Interface::release_interface(), and setMeta.
    if( !readUtil )  // init() failed.
        return;
    delete[] setMeta;
    setMeta = 0;
    iFace->release_interface( readUtil );
    H5Tclose( handleType );
Member Function Documentation
Definition at line 482 of file ReadHDF5.cpp.
References collIO, moab::ReadHDF5::HDF5ErrorHandler::data, dataBuffer, errorHandler, fileInfo, filePtr, moab::ReadHDF5::HDF5ErrorHandler::func, moab::handle_hdf5_error(), indepIO, is_error(), MB_SUCCESS, mhdf_closeFile(), mpiComm, and setMeta.
Referenced by load_file(), and read_tag_values().
    HDF5ErrorHandler handler;
#if defined( H5Eget_auto_vers ) && H5Eget_auto_vers > 1
    herr_t err = H5Eget_auto( H5E_DEFAULT, &handler.func, &handler.data );
#else
    herr_t err = H5Eget_auto( &handler.func, &handler.data );
#endif
    if( err >= 0 && handler.func == &handle_hdf5_error )
        assert( handler.data == &errorHandler );
        H5Eset_auto( H5E_DEFAULT, errorHandler.func, errorHandler.data );
#else
        H5Eset_auto( errorHandler.func, errorHandler.data );
#endif
    free( dataBuffer );
    dataBuffer = NULL;
    free( fileInfo );
    fileInfo = NULL;
    delete mpiComm;
    mpiComm = 0;
    if( indepIO != H5P_DEFAULT ) H5Pclose( indepIO );
    if( collIO != indepIO ) H5Pclose( collIO );
    collIO = indepIO = H5P_DEFAULT;
    delete[] setMeta;
    setMeta = 0;
    mhdf_Status status;
    mhdf_closeFile( filePtr, &status );
    filePtr = 0;
    return is_error( status ) ? MB_FAILURE : MB_SUCCESS;
void moab::ReadHDF5::convert_id_to_handle ( EntityHandle *  in_out_array,
size_t &  array_length_out
) const [inline]
Definition at line 345 of file ReadHDF5.hpp.
References convert_id_to_handle(), and idMap.
        return convert_id_to_handle( in_out_array, array_length, array_length_out, idMap );
const RangeMap< long, EntityHandle > &  id_map
) [static]
Definition at line 3449 of file ReadHDF5.cpp.
References moab::RangeMap< KeyType, ValType, NullVal >::find().
    for( EntityHandle* const end = array + size; array != end; ++array )
        *array = id_map.find( *array );
size_t &  array_length_out,
) [static]
Definition at line 3455 of file ReadHDF5.cpp.
References moab::RangeMap< KeyType, ValType, NullVal >::begin(), moab::RangeMap< KeyType, ValType, NullVal >::end(), moab::RangeMap< KeyType, ValType, NullVal >::lower_bound(), and size.
    RangeMap< long, EntityHandle >::const_iterator it;
    new_size = 0;
    for( size_t i = 0; i < size; ++i )
        it = id_map.lower_bound( array[i] );
        if( it != id_map.end() && it->begin <= (long)array[i] )
            array[new_size++] = it->value + ( array[i] - it->begin );
ErrorCode moab::ReadHDF5::convert_range_to_handle ( const EntityHandle *  ranges,
size_t  num_ranges,
Range &  merge
Definition at line 3506 of file ReadHDF5.cpp.
References idMap, and MB_SUCCESS.
Referenced by read_set_data().
    convert_range_to_handle( array, num_ranges, idMap, range );
    return MB_SUCCESS;
void moab::ReadHDF5::convert_range_to_handle ( const EntityHandle *  ranges,
size_t  num_ranges,
const RangeMap< long, EntityHandle > &  id_map,
Range &  merge
) [static]
Definition at line 3470 of file ReadHDF5.cpp.
References moab::RangeMap< KeyType, ValType, NullVal >::begin(), moab::Range::begin(), moab::RangeMap< KeyType, ValType, NullVal >::end(), moab::Range::insert(), and moab::RangeMap< KeyType, ValType, NullVal >::lower_bound().
    RangeMap< long, EntityHandle >::iterator it = id_map.begin();
    Range::iterator hint                        = merge.begin();
    for( size_t i = 0; i < num_ranges; ++i )
        long id        = ranges[2 * i];
        const long end = id + ranges[2 * i + 1];
        // We assume that 'ranges' is sorted, but check just in case it isn't.
        if( it == id_map.end() || it->begin > id ) it = id_map.begin();
        it = id_map.lower_bound( it, id_map.end(), id );
        if( it == id_map.end() ) continue;
        if( id < it->begin ) id = it->begin;
        while( id < end )
            const long off = id - it->begin;
            long count     = std::min( it->count - off, end - id );
            // It is possible that this new subrange is starting after the end
            // It will result in negative count, which does not make sense
            // We are done with this range, go to the next one
            if( count <= 0 ) break;
            hint = merge.insert( hint, it->value + off, it->value + off + count - 1 );
            id += count;
            if( id < end )
                if( ++it == id_map.end() ) break;
                if( it->begin > end ) break;
ErrorCode moab::ReadHDF5::create_tag ( const mhdf_TagDesc &  info,
Tag &  handle,
hid_t &  type
) [private]
Definition at line 2867 of file ReadHDF5.cpp.
References CHECK_OPEN_HANDLES, convert_id_to_handle(), mhdf_TagDesc::default_value, mhdf_TagDesc::default_value_size, ErrorCode, filePtr, mhdf_TagDesc::global_value, mhdf_TagDesc::global_value_size, handleType, iFace, MB_SET_ERR, MB_SUCCESS, MB_TAG_BIT, MB_TAG_CREAT, MB_TAG_DENSE, MB_TAG_MESH, MB_TAG_NOT_FOUND, MB_TAG_SPARSE, MB_TAG_VARLEN, MB_TYPE_BIT, MB_TYPE_DOUBLE, MB_TYPE_HANDLE, MB_TYPE_INTEGER, MB_TYPE_OPAQUE, mhdf_BIT_TYPE, mhdf_BITFIELD, mhdf_BOOLEAN, mhdf_DENSE_TYPE, mhdf_ENTITY_ID, mhdf_FLOAT, mhdf_getTagValues(), mhdf_INTEGER, mhdf_isError(), mhdf_MESH_TYPE, mhdf_message(), mhdf_OPAQUE, mhdf_SPARSE_TYPE, mhdf_TagDesc::name, mhdf_TagDesc::size, mhdf_TagDesc::storage, moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_by_ptr(), moab::Interface::tag_set_data(), tag_type_name(), TagType, and mhdf_TagDesc::type.
Referenced by read_tag().
    CHECK_OPEN_HANDLES;
    ErrorCode rval;
    mhdf_Status status;
    TagType storage;
    DataType mb_type;
    bool re_read_default = false;
    switch( info.storage )
        case mhdf_DENSE_TYPE:
            storage = MB_TAG_DENSE;
            break;
        case mhdf_SPARSE_TYPE:
            storage = MB_TAG_SPARSE;
            break;
        case mhdf_BIT_TYPE:
            storage = MB_TAG_BIT;
            break;
        case mhdf_MESH_TYPE:
            storage = MB_TAG_MESH;
            break;
        default:
            MB_SET_ERR( MB_FAILURE, "Invalid storage type for tag '" << info.name << "': " << info.storage );
    // Type-specific stuff
    if( info.type == mhdf_BITFIELD )
        if( info.size < 1 || info.size > 8 )
            MB_SET_ERR( MB_FAILURE, "Invalid bit tag: class is MB_TAG_BIT, num bits = " << info.size );
        hdf_type = H5Tcopy( H5T_NATIVE_B8 );
        mb_type  = MB_TYPE_BIT;
        if( hdf_type < 0 ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" );
    else if( info.type == mhdf_OPAQUE )
        mb_type = MB_TYPE_OPAQUE;
        // Check for user-provided type
        Tag type_handle;
        std::string tag_type_name = "__hdf5_tag_type_";
        tag_type_name += info.name;
        rval = iFace->tag_get_handle( tag_type_name.c_str(), sizeof( hid_t ), MB_TYPE_OPAQUE, type_handle );
        if( MB_SUCCESS == rval )
            EntityHandle root = 0;
            rval              = iFace->tag_get_data( type_handle, &root, 1, &hdf_type );
            if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" );
            hdf_type        = H5Tcopy( hdf_type );
            re_read_default = true;
        else if( MB_TAG_NOT_FOUND == rval )
            hdf_type = 0;
        else
    else
        switch( info.type )
            case mhdf_INTEGER:
                hdf_type = H5T_NATIVE_INT;
                mb_type  = MB_TYPE_INTEGER;
                break;
            case mhdf_FLOAT:
                hdf_type = H5T_NATIVE_DOUBLE;
                mb_type  = MB_TYPE_DOUBLE;
                break;
            case mhdf_BOOLEAN:
                hdf_type = H5T_NATIVE_UINT;
                break;
            case mhdf_ENTITY_ID:
                hdf_type = handleType;
                mb_type  = MB_TYPE_HANDLE;
                break;
            default:
        if( info.size > 1 )
        {  // Array
            hsize_t tmpsize = info.size;
#if defined( H5Tarray_create_vers ) && H5Tarray_create_vers > 1
            hdf_type = H5Tarray_create2( hdf_type, 1, &tmpsize );
#else
            hdf_type = H5Tarray_create( hdf_type, 1, &tmpsize, NULL );
#endif
        else
    // If default or global/mesh value in file, read it.
    if( info.default_value || info.global_value )
        if( re_read_default )
            mhdf_getTagValues( filePtr, info.name, hdf_type, info.default_value, info.global_value, &status );
            if( mhdf_isError( &status ) )
                if( hdf_type ) H5Tclose( hdf_type );
                MB_SET_ERR( MB_FAILURE, mhdf_message( &status ) );
        if( MB_TYPE_HANDLE == mb_type )
            if( info.default_value )
                rval = convert_id_to_handle( (EntityHandle*)info.default_value, info.default_value_size );
            if( info.global_value )
                rval = convert_id_to_handle( (EntityHandle*)info.global_value, info.global_value_size );
    // Get tag handle, creating if necessary
    if( info.size < 0 )
        rval = iFace->tag_get_handle( info.name, info.default_value_size, mb_type, handle,
                                      storage | MB_TAG_CREAT | MB_TAG_VARLEN | MB_TAG_DFTOK, info.default_value );
    else
        rval = iFace->tag_get_handle( info.name, info.size, mb_type, handle, storage | MB_TAG_CREAT | MB_TAG_DFTOK,
        MB_SET_ERR( MB_FAILURE, "Tag type in file does not match type in database for \"" << info.name << "\"" );
        if( info.size > 0 )
        {  // Fixed-length tag
            rval = iFace->tag_set_data( handle, &root, 1, info.global_value );
        else
            int tag_size = info.global_value_size;
            rval         = iFace->tag_set_by_ptr( handle, &root, 1, &info.global_value, &tag_size );
    return MB_SUCCESS;
void moab::ReadHDF5::debug_barrier_line ( int  lineno) [private]
Definition at line 134 of file ReadHDF5.cpp.
References dbgOut, moab::DebugOutput::get_verbosity(), mpiComm, and moab::DebugOutput::printf().
#ifdef MOAB_HAVE_MPI
    if( mpiComm )
        const unsigned threshold   = 2;
        static unsigned long count = 0;
        if( dbgOut.get_verbosity() >= threshold )
            dbgOut.printf( threshold, "*********** Debug Barrier %lu (@%d)***********\n", ++count, lineno );
            MPI_Barrier( *mpiComm );
#else
    if( lineno )
#endif
ErrorCode moab::ReadHDF5::delete_non_side_elements ( const Range &  side_ents) [private]
Clean up elements that were a) read because we had read all of the nodes and b) weren't actually sides of the top-dimension elements we were trying to read.
Definition at line 1842 of file ReadHDF5.cpp.
References moab::RangeMap< KeyType, ValType, NullVal >::begin(), moab::Range::begin(), moab::Range::const_pair_begin(), dbgOut, moab::Interface::delete_entities(), moab::Range::empty(), moab::RangeMap< KeyType, ValType, NullVal >::end(), moab::Range::end(), moab::RangeMap< KeyType, ValType, NullVal >::erase(), moab::Range::erase(), ErrorCode, moab::GeomUtil::first(), moab::Range::front(), moab::Interface::get_adjacencies(), idMap, iFace, moab::Range::insert(), moab::Range::lower_bound(), MB_SET_ERR, MB_SUCCESS, MBENTITYSET, MBVERTEX, moab::DebugOutput::print(), moab::DebugOutput::printf(), moab::Range::size(), moab::subtract(), moab::TYPE_FROM_HANDLE(), moab::CN::TypeDimensionMap, and moab::Interface::UNION.
Referenced by load_file_partial().
    ErrorCode rval;
    // Build list of entities that we need to find the sides of
    Range explicit_ents;
    Range::iterator hint = explicit_ents.begin();
    for( IDMap::iterator i = idMap.begin(); i != idMap.end(); ++i )
        EntityHandle start = i->value;
        EntityHandle end   = i->value + i->count - 1;
        EntityType type    = TYPE_FROM_HANDLE( start );
        assert( type == TYPE_FROM_HANDLE( end ) );  // Otherwise handle space entirely full!!
        if( type != MBVERTEX && type != MBENTITYSET ) hint = explicit_ents.insert( hint, start, end );
    explicit_ents = subtract( explicit_ents, side_ents );
    // Figure out which entities we want to delete
    Range dead_ents( side_ents );
    Range::iterator ds, de, es;
    ds = dead_ents.lower_bound( CN::TypeDimensionMap[1].first );
    de = dead_ents.lower_bound( CN::TypeDimensionMap[2].first, ds );
    if( ds != de )
        // Get subset of explicit ents of dimension greater than 1
        es = explicit_ents.lower_bound( CN::TypeDimensionMap[2].first );
        Range subset, adj;
        subset.insert( es, explicit_ents.end() );
        rval = iFace->get_adjacencies( subset, 1, false, adj, Interface::UNION );
        if( MB_SUCCESS != rval ) return rval;
        dead_ents = subtract( dead_ents, adj );
    ds = dead_ents.lower_bound( CN::TypeDimensionMap[2].first );
    de = dead_ents.lower_bound( CN::TypeDimensionMap[3].first, ds );
    assert( de == dead_ents.end() );
    if( ds != de )
        // Get subset of explicit ents of dimension 3
        es = explicit_ents.lower_bound( CN::TypeDimensionMap[3].first );
        Range subset, adj;
        rval = iFace->get_adjacencies( subset, 2, false, adj, Interface::UNION );
    // Now delete anything remaining in dead_ents
    dbgOut.printf( 2, "Deleting %lu elements\n", (unsigned long)dead_ents.size() );
    dbgOut.print( 4, "\tDead entities: ", dead_ents );
    rval = iFace->delete_entities( dead_ents );
    // Remove dead entities from ID map
    while( !dead_ents.empty() )
        EntityHandle start = dead_ents.front();
        EntityID count     = dead_ents.const_pair_begin()->second - start + 1;
        IDMap::iterator rit;
        for( rit = idMap.begin(); rit != idMap.end(); ++rit )
            if( rit->value <= start && (EntityID)( start - rit->value ) < rit->count ) break;
        if( rit == idMap.end() ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" );
        EntityID offset = start - rit->value;
        EntityID avail  = rit->count - offset;
        if( avail < count ) count = avail;
        dead_ents.erase( dead_ents.begin(), dead_ents.begin() + count );
        idMap.erase( rit->begin + offset, count );
    return MB_SUCCESS;
Definition at line 183 of file ReadHDF5.cpp.
References ReadHDF5().
Referenced by moab::ReaderWriterSet::ReaderWriterSet().
    return new ReadHDF5( iface );
ErrorCode moab::ReadHDF5::find_int_tag ( const char *  name,
int &  index_out
) [private]
Given a tag name, find its index in fileInfo and verify that each tag value is a single integer.
Definition at line 677 of file ReadHDF5.cpp.
References fileInfo, MB_SET_ERR, MB_SUCCESS, MB_TAG_NOT_FOUND, mhdf_INTEGER, mhdf_TagDesc::name, mhdf_FileDesc::num_tag_desc, mhdf_TagDesc::size, mhdf_FileDesc::tags, and mhdf_TagDesc::type.
Referenced by get_subset_ids(), and read_tag_values().
    for( index = 0; index < fileInfo->num_tag_desc; ++index )
        if( !strcmp( name, fileInfo->tags[index].name ) ) break;
    if( index == fileInfo->num_tag_desc )
        MB_SET_ERR( MB_TAG_NOT_FOUND, "File does not contain subset tag '" << name << "'" );
    if( fileInfo->tags[index].type != mhdf_INTEGER || fileInfo->tags[index].size != 1 )
        MB_SET_ERR( MB_TAG_NOT_FOUND, "Tag ' " << name << "' does not contain single integer value" );
    return MB_SUCCESS;
ErrorCode moab::ReadHDF5::find_sets_containing ( Range &  sets_out,
) [private]
Find all sets containing one or more entities read from the file and added to idMap
Definition at line 2132 of file ReadHDF5.cpp.
References CHECK_OPEN_HANDLES, mhdf_EntDesc::count, ErrorCode, fileInfo, filePtr, mhdf_FileDesc::have_set_contents, is_error(), MB_SET_ERR, MB_SUCCESS, mhdf_closeData(), mhdf_openSetData(), and mhdf_FileDesc::sets.
    ErrorCode rval;
    mhdf_Status status;
    CHECK_OPEN_HANDLES;
    if( !fileInfo->have_set_contents ) return MB_SUCCESS;
    assert( fileInfo->sets.count );
    // Open data tables
    long content_len     = 0;
    hid_t content_handle = mhdf_openSetData( filePtr, &content_len, &status );
    if( is_error( status ) ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" );
    hid_t data_type = H5Dget_type( content_handle );
    rval = find_sets_containing( content_handle, data_type, content_len, read_set_containing_parents, sets_out );
    H5Tclose( data_type );
    mhdf_closeData( filePtr, content_handle, &status );
    if( MB_SUCCESS == rval && is_error( status ) ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" );
    return rval;
ErrorCode moab::ReadHDF5::find_sets_containing ( hid_t  content_handle,
hid_t  content_type,
long  content_len,
Range &  file_ids
) [private]
Find file IDs of sets containing any entities in the passed id_map
Definition at line 2196 of file ReadHDF5.cpp.
References assert_range, bcastDuplicateReads, moab::Range::begin(), bufferSize, CHECK_OPEN_HANDLES, moab::Range::clear(), collIO, CONTENT, mhdf_EntDesc::count, dataBuffer, dbgOut, moab::Range::empty(), fileInfo, idMap, ierr, moab::Range::insert(), moab::intersect(), is_error(), MB_SET_ERR, MB_SUCCESS, mhdf_readSetData(), mhdf_readSetDataWithOpt(), mhdf_SET_RANGE_BIT, myPcomm, nativeParallel, moab::DebugOutput::printf(), moab::ProcConfig::proc_comm(), moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), rank, moab::set_map_intersect(), setMeta, mhdf_FileDesc::sets, and mhdf_EntDesc::start_id.
    CHECK_OPEN_HANDLES;
    // Scan all set contents data
    const size_t content_size = H5Tget_size( content_type );
    const long num_sets       = fileInfo->sets.count;
    dbgOut.printf( 2, "Searching contents of %ld\n", num_sets );
    mhdf_Status status;
    int rank   = 0;
    bool bcast = false;
    MPI_Comm comm = 0;
    if( nativeParallel )
        rank  = myPcomm->proc_config().proc_rank();
        comm  = myPcomm->proc_config().proc_comm();
        bcast = bcastDuplicateReads;
#endif
    // Check offsets so that we don't read past end of table or
    // walk off end of array.
    long prev = -1;
    for( long i = 0; i < num_sets; ++i )
        if( setMeta[i][CONTENT] < prev )
            std::cerr << "Invalid data in set contents offsets at position " << i << ": index " << setMeta[i][CONTENT]
                      << " is less than previous index " << prev << std::endl;
            std::cerr.flush();
        prev = setMeta[i][CONTENT];
    if( setMeta[num_sets - 1][CONTENT] >= contents_len )
        std::cerr << "Maximum set content index " << setMeta[num_sets - 1][CONTENT]
                  << " exceeds contents table length of " << contents_len << std::endl;
        std::cerr.flush();
    // Set up buffer for reading set contents
    long* const content_buffer = (long*)dataBuffer;
    const long content_len     = bufferSize / std::max( content_size, sizeof( long ) );
    // Scan set table
    Range::iterator hint = file_ids.begin();
    Range tmp_range;
    long prev_idx    = -1;
    int mm           = 0;
    long sets_offset = 0;
    long temp_content[4];
    while( sets_offset < num_sets )
        temp_content[0] = content_len + prev_idx;
        long sets_count =
            std::lower_bound( setMeta + sets_offset, setMeta + num_sets, temp_content, SetContOffComp() ) - setMeta -
            sets_offset;
        assert( sets_count >= 0 && sets_offset + sets_count <= num_sets );
        if( !sets_count )
        {  // Contents of single set don't fit in buffer
            long content_remaining = setMeta[sets_offset][CONTENT] - prev_idx;
            long content_offset    = prev_idx + 1;
            while( content_remaining )
                long content_count = content_len < content_remaining ? 2 * ( content_len / 2 ) : content_remaining;
                assert_range( content_buffer, content_count );
                dbgOut.printf( 3, "Reading chunk %d (%ld values) from set contents table\n", ++mm, content_count );
                if( !bcast || 0 == rank )
                    if( !bcast )
                        mhdf_readSetDataWithOpt( contents_handle, content_offset, content_count, content_type,
                                                 content_buffer, collIO, &status );
                    else
                        mhdf_readSetData( contents_handle, content_offset, content_count, content_type, content_buffer,
                                          &status );
                    H5Tconvert( content_type, H5T_NATIVE_LONG, content_count, content_buffer, 0, H5P_DEFAULT );
                if( bcast )
                    int ierr = MPI_Bcast( content_buffer, content_count, MPI_LONG, 0, comm );
                    if( MPI_SUCCESS != ierr ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" );
#else
                    assert( rank == 0 );  // If not MPI, then only one proc
#endif
                if( read_set_containing_parents )
                    tmp_range.clear();
                    if( setMeta[sets_offset][3] & mhdf_SET_RANGE_BIT )
                        tmp_range.insert( *content_buffer, *( content_buffer + 1 ) );
                    else
                        std::copy( content_buffer, content_buffer + content_count, range_inserter( tmp_range ) );
                    tmp_range = intersect( tmp_range, file_ids );
                if( !tmp_range.empty() || set_map_intersect( setMeta[sets_offset][3] & mhdf_SET_RANGE_BIT,
                                                             content_buffer, content_count, idMap ) )
                    long id = fileInfo->sets.start_id + sets_offset;
                    hint    = file_ids.insert( hint, id, id );
                    if( !nativeParallel )  // Don't stop if doing READ_PART because we need to read
                                           // collectively
                        break;
                content_remaining -= content_count;
                content_offset += content_count;
            prev_idx   = setMeta[sets_offset][CONTENT];
            sets_count = 1;
        else if( long read_num = setMeta[sets_offset + sets_count - 1][CONTENT] - prev_idx )
            assert( sets_count > 0 );
            assert_range( content_buffer, read_num );
            dbgOut.printf( 3, "Reading chunk %d (%ld values) from set contents table\n", ++mm, read_num );
                if( !bcast )
                    mhdf_readSetDataWithOpt( contents_handle, prev_idx + 1, read_num, content_type, content_buffer,
                                             collIO, &status );
                else
                    mhdf_readSetData( contents_handle, prev_idx + 1, read_num, content_type, content_buffer, &status );
                H5Tconvert( content_type, H5T_NATIVE_LONG, read_num, content_buffer, 0, H5P_DEFAULT );
            if( bcast )
                int ierr = MPI_Bcast( content_buffer, read_num, MPI_LONG, 0, comm );
#else
#endif
            long* buff_iter = content_buffer;
            for( long i = 0; i < sets_count; ++i )
                long set_size = setMeta[i + sets_offset][CONTENT] - prev_idx;
                prev_idx += set_size;
                // Check whether contents include set already being loaded
                    tmp_range.clear();
                    if( setMeta[sets_offset + i][3] & mhdf_SET_RANGE_BIT )
                        // put in tmp_range the contents on the set
                        // file_ids contain at this points only other sets
                        const long* j         = buff_iter;
                        const long* const end = buff_iter + set_size;
                        assert( set_size % 2 == 0 );
                        while( j != end )
                            long start = *( j++ );
                            long count = *( j++ );
                            tmp_range.insert( start, start + count - 1 );
                    else
                        std::copy( buff_iter, buff_iter + set_size, range_inserter( tmp_range ) );
                    set_map_intersect( setMeta[sets_offset + i][3] & mhdf_SET_RANGE_BIT, buff_iter, set_size, idMap ) )
                    long id = fileInfo->sets.start_id + sets_offset + i;
                buff_iter += set_size;
        sets_offset += sets_count;
    return MB_SUCCESS;
ErrorCode moab::ReadHDF5::get_partition ( Range &  tmp_file_ids,
int  num_parts,
int  part_number
) [private]
Select a subset of the gathered set of file ids to read in based on communicator size and rank.
Parameters:
tmp_file_idsAs input: sets to be read on all procs. As output: sets to read on this proc.
num_partscommunicator size
part_numbercommunicator rank
Definition at line 730 of file ReadHDF5.cpp.
References moab::Range::back(), moab::Range::begin(), CHECK_OPEN_HANDLES, mhdf_EntDesc::count, dbgOut, moab::Range::end(), moab::Range::erase(), fileInfo, moab::Range::front(), moab::Range::lower_bound(), MB_SUCCESS, moab::DebugOutput::print(), mhdf_FileDesc::sets, moab::Range::size(), mhdf_EntDesc::start_id, and moab::Range::upper_bound().
    CHECK_OPEN_HANDLES;
    // Check that the tag only identified sets
    if( (unsigned long)fileInfo->sets.start_id > tmp_file_ids.front() )
        dbgOut.print( 2, "Ignoring non-set entities with partition set tag\n" );
        tmp_file_ids.erase( tmp_file_ids.begin(), tmp_file_ids.lower_bound( (EntityHandle)fileInfo->sets.start_id ) );
    unsigned long set_end = (unsigned long)fileInfo->sets.start_id + fileInfo->sets.count;
    if( tmp_file_ids.back() >= set_end )
        tmp_file_ids.erase( tmp_file_ids.upper_bound( (EntityHandle)set_end ), tmp_file_ids.end() );
    Range::iterator s   = tmp_file_ids.begin();
    size_t num_per_proc = tmp_file_ids.size() / num_parts;
    size_t num_extra    = tmp_file_ids.size() % num_parts;
    Range::iterator e;
    if( part_number < (long)num_extra )
        s += ( num_per_proc + 1 ) * part_number;
        e = s;
        e += ( num_per_proc + 1 );
    else
        s += num_per_proc * part_number + num_extra;
        e = s;
        e += num_per_proc;
    tmp_file_ids.erase( e, tmp_file_ids.end() );
    tmp_file_ids.erase( tmp_file_ids.begin(), s );
    return MB_SUCCESS;
ErrorCode moab::ReadHDF5::get_set_contents ( const Range &  sets,
Range &  file_ids
) [private]
Read the contents for the specified sets and return the file IDs of all nodes and elements contained within those sets.
Parameters:
setsContainer of file IDs designating entity sets.
file_idsOutput: File IDs of entities contained in sets.
Definition at line 2618 of file ReadHDF5.cpp.
References CHECK_OPEN_HANDLES, CONTENT, dbgOut, fileInfo, filePtr, mhdf_FileDesc::have_set_contents, is_error(), MB_SET_ERR, MB_SUCCESS, mhdf_openSetData(), mpiComm, nativeParallel, read_set_data(), and moab::DebugOutput::tprint().
    CHECK_OPEN_HANDLES;
    dbgOut.tprint( 2, "Reading set contained file IDs\n" );
    try
        mhdf_Status status;
        long content_len;
        hid_t contents = mhdf_openSetData( filePtr, &content_len, &status );
        ReadHDF5Dataset data( "set contents", contents, nativeParallel, mpiComm, true );
        return read_set_data( sets, 0, data, CONTENT, &file_ids );
    catch( ReadHDF5Dataset::Exception )
ErrorCode moab::ReadHDF5::get_subset_ids ( const ReaderIface::IDTag *  subset_list,
Range &  file_ids_out
) [private]
Given a list of tags and values, get the file ids for the corresponding entities in the file.
Definition at line 695 of file ReadHDF5.cpp.
References moab::Range::empty(), ErrorCode, find_int_tag(), get_tagged_entities(), moab::intersect(), MB_CHK_ERR, MB_ENTITY_NOT_FOUND, MB_SET_ERR, MB_SUCCESS, search_tag_values(), and moab::Range::swap().
Referenced by load_file_partial(), and read_tag_values().
    ErrorCode rval;
    for( int i = 0; i < subset_list_length; ++i )
        int tag_index;
        rval = find_int_tag( subset_list[i].tag_name, tag_index );
        Range tmp_file_ids;
        if( !subset_list[i].num_tag_values )
            rval = get_tagged_entities( tag_index, tmp_file_ids );
        else
            std::vector< int > ids( subset_list[i].tag_values,
                                    subset_list[i].tag_values + subset_list[i].num_tag_values );
            std::sort( ids.begin(), ids.end() );
            rval = search_tag_values( tag_index, ids, tmp_file_ids );
        if( tmp_file_ids.empty() ) MB_CHK_ERR( MB_ENTITY_NOT_FOUND );
        if( i == 0 )
            file_ids.swap( tmp_file_ids );
        else
            file_ids = intersect( tmp_file_ids, file_ids );
    return MB_SUCCESS;
ErrorCode moab::ReadHDF5::get_tagged_entities ( int  tag_index,
) [private]
For parallel reads, this function does collective IO.
Parameters:
tag_indexIndex into info->tags specifying which tag to search.
file_ids_outFile IDs for entities with specified tag values.
Definition at line 1285 of file ReadHDF5.cpp.
References assert_range, moab::Range::begin(), buffer, bufferSize, CHECK_OPEN_HANDLES, collIO, mhdf_EntDesc::count, dataBuffer, mhdf_TagDesc::dense_elem_indices, mhdf_ElemDesc::desc, mhdf_FileDesc::elems, fileInfo, filePtr, handleType, mhdf_TagDesc::have_sparse, moab::Range::insert(), is_error(), MB_SET_ERR, MB_SUCCESS, mhdf_closeData(), mhdf_openSparseTagData(), mhdf_readSparseTagEntitiesWithOpt(), mhdf_TagDesc::name, mhdf_FileDesc::nodes, mhdf_TagDesc::num_dense_indices, mhdf_FileDesc::num_elem_desc, mhdf_FileDesc::sets, size, mhdf_EntDesc::start_id, and mhdf_FileDesc::tags.
Referenced by get_subset_ids().
    const mhdf_TagDesc& tag = fileInfo->tags[tag_index];
    CHECK_OPEN_HANDLES;
    // Do dense data
    for( int i = 0; i < tag.num_dense_indices; ++i )
        int idx = tag.dense_elem_indices[i];
        mhdf_EntDesc* ents;
        if( idx == -2 )
            ents = &fileInfo->sets;
        else if( idx == -1 )
            ents = &fileInfo->nodes;
        else
            if( idx < 0 || idx >= fileInfo->num_elem_desc ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" );
            ents = &( fileInfo->elems[idx].desc );
        EntityHandle h = (EntityHandle)ents->start_id;
        hint           = file_ids.insert( hint, h, h + ents->count - 1 );
    if( !tag.have_sparse ) return MB_SUCCESS;
    // Do sparse data
    mhdf_Status status;
    hid_t tables[2];
    long size, junk;
    mhdf_openSparseTagData( filePtr, tag.name, &size, &junk, tables, &status );
    mhdf_closeData( filePtr, tables[1], &status );
        mhdf_closeData( filePtr, tables[0], &status );
    hid_t file_type = H5Dget_type( tables[0] );
    if( file_type < 0 ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" );
    EntityHandle* buffer   = reinterpret_cast< EntityHandle* >( dataBuffer );
    const long buffer_size = bufferSize / std::max( sizeof( EntityHandle ), H5Tget_size( file_type ) );
    long remaining = size, offset = 0;
    while( remaining )
        long count = std::min( buffer_size, remaining );
        assert_range( buffer, count );
        mhdf_readSparseTagEntitiesWithOpt( *tables, offset, count, file_type, buffer, collIO, &status );
            H5Tclose( file_type );
            mhdf_closeData( filePtr, *tables, &status );
        H5Tconvert( file_type, handleType, count, buffer, NULL, H5P_DEFAULT );
        std::sort( buffer, buffer + count );
        for( long i = 0; i < count; ++i )
            hint = file_ids.insert( hint, buffer[i], buffer[i] );
        remaining -= count;
        offset += count;
    return MB_SUCCESS;
Definition at line 197 of file ReadHDF5.cpp.
References moab::RangeMap< KeyType, ValType, NullVal >::clear(), collIO, debugTrack, ErrorCode, fileInfo, handleType, idMap, iFace, indepIO, MB_SET_ERR, MB_SUCCESS, myPcomm, moab::Interface::query_interface(), and readUtil.
Referenced by set_up_read().
    ErrorCode rval;
    if( readUtil ) return MB_SUCCESS;
    indepIO = collIO = H5P_DEFAULT;
    // WriteHDF5::register_known_tag_types(iFace);
    handleType = H5Tcopy( H5T_NATIVE_ULONG );
    if( handleType < 0 ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" );
    if( H5Tset_size( handleType, sizeof( EntityHandle ) ) < 0 )
    rval = iFace->query_interface( readUtil );
    idMap.clear();
    fileInfo   = 0;
    debugTrack = false;
    myPcomm    = 0;
    return MB_SUCCESS;
ErrorCode moab::ReadHDF5::insert_in_id_map ( const Range &  file_ids,
Definition at line 3512 of file ReadHDF5.cpp.
References moab::RangeMap< KeyType, ValType, NullVal >::back(), moab::Range::begin(), moab::Range::const_pair_begin(), moab::Range::const_pair_end(), moab::RangeMap< KeyType, ValType, NullVal >::empty(), moab::Range::empty(), moab::Range::front(), idMap, moab::RangeMap< KeyType, ValType, NullVal >::insert(), MB_SET_ERR, MB_SUCCESS, and moab::RangeMap< KeyType, ValType, NullVal >::merge().
Referenced by read_elems(), read_nodes(), and read_sets().
    IDMap tmp_map;
    bool merge = !idMap.empty() && !file_ids.empty() && idMap.back().begin > (long)file_ids.front();
    IDMap& map = merge ? tmp_map : idMap;
    Range::const_pair_iterator p;
    for( p = file_ids.const_pair_begin(); p != file_ids.const_pair_end(); ++p )
        size_t count = p->second - p->first + 1;
        if( !map.insert( p->first, start_id, count ).second ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" );
        start_id += count;
    if( merge && !idMap.merge( tmp_map ) ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" );
    return MB_SUCCESS;
Definition at line 3529 of file ReadHDF5.cpp.
References idMap, moab::RangeMap< KeyType, ValType, NullVal >::insert(), MB_SET_ERR, and MB_SUCCESS.
    if( !idMap.insert( file_id, handle, 1 ).second ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" );
    return MB_SUCCESS;
ErrorCode moab::ReadHDF5::load_file ( const char *  file_name,
const EntityHandle *  file_set,
const FileOptions &  opts,
const SubsetList *  subset_list = 0,
const Tag *  file_id_tag = 0
) [virtual]
Export specified meshsets to file
Parameters:
filenameThe filename to export. Must end in .mhdf
export_setsArray of handles to sets to export, or NULL to export all.
export_set_countLength of export_sets array.
Implements moab::ReaderIface.
Definition at line 520 of file ReadHDF5.cpp.
References _times, clean_up_read(), collIO, cputime, dbgOut, ErrorCode, moab::Interface::get_last_error(), moab::FileOptions::get_null_option(), iFace, indepIO, load_file_impl(), load_file_partial(), MB_SUCCESS, moab::ReaderIface::SubsetList::num_parts, NUM_TIMES, moab::ReaderIface::SubsetList::part_number, print_times(), read_all_set_meta(), read_qa(), READ_QA_TIME, SET_META_TIME, set_up_read(), store_file_ids(), STORE_FILE_IDS_TIME, store_sets_file_ids(), moab::ReaderIface::SubsetList::tag_list, moab::ReaderIface::SubsetList::tag_list_length, moab::CpuTimer::time_elapsed(), moab::CpuTimer::time_since_birth(), timer, TOTAL_TIME, moab::DebugOutput::tprint(), and moab::DebugOutput::tprintf().
    ErrorCode rval;
    rval = set_up_read( filename, opts );
        clean_up_read( opts );
        return rval;
    // See if we need to report times
    rval = opts.get_null_option( "CPUTIME" );
        cputime = true;
        timer   = new CpuTimer;
        for( int i = 0; i < NUM_TIMES; i++ )
            _times[i] = 0;
    // We read the entire set description table regardless of partial
    // or complete reads or serial vs parallel reads
    rval = read_all_set_meta();
    if( cputime ) _times[SET_META_TIME] = timer->time_elapsed();
    if( subset_list && MB_SUCCESS == rval )
        rval = load_file_partial( subset_list->tag_list, subset_list->tag_list_length, subset_list->num_parts,
                                  subset_list->part_number, opts );
    else
        rval = load_file_impl( opts );
    if( MB_SUCCESS == rval && file_id_tag )
        dbgOut.tprint( 1, "Storing file IDs in tag\n" );
        rval = store_file_ids( *file_id_tag );
    ErrorCode rval3 = opts.get_null_option( "STORE_SETS_FILEIDS" );
    if( MB_SUCCESS == rval3 )
        rval = store_sets_file_ids();
    if( cputime ) _times[STORE_FILE_IDS_TIME] = timer->time_elapsed();
    if( MB_SUCCESS == rval && 0 != file_set )
        dbgOut.tprint( 1, "Reading QA records\n" );
        rval = read_qa( *file_set );
    if( cputime ) _times[READ_QA_TIME] = timer->time_elapsed();
    dbgOut.tprint( 1, "Cleaning up\n" );
    ErrorCode rval2 = clean_up_read( opts );
    if( rval == MB_SUCCESS && rval2 != MB_SUCCESS ) rval = rval2;
        dbgOut.tprint( 1, "Read finished.\n" );
    else
        std::string msg;
        iFace->get_last_error( msg );
        dbgOut.tprintf( 1, "READ FAILED (ERROR CODE %s): %s\n", ErrorCodeStr[rval], msg.c_str() );
    if( cputime )
        _times[TOTAL_TIME] = timer->time_since_birth();
        print_times();
        delete timer;
    if( H5P_DEFAULT != collIO ) H5Pclose( collIO );
    if( H5P_DEFAULT != indepIO ) H5Pclose( indepIO );
    return rval;
ErrorCode moab::ReadHDF5::load_file_impl ( const FileOptions &  opts) [protected]
Definition at line 603 of file ReadHDF5.cpp.
References CHECK_OPEN_HANDLES, moab::Range::clear(), mhdf_EntDesc::count, dbgOut, mhdf_FileDesc::elems, moab::CN::EntityTypeFromName(), ErrorCode, fileInfo, filePtr, mhdf_ElemDesc::handle, mhdf_ElemDesc::have_adj, moab::Range::insert(), is_error(), MB_SET_ERR, MB_SUCCESS, MBPOLYHEDRON, mhdf_closeData(), mhdf_openAdjacency(), mhdf_FileDesc::nodes, mhdf_FileDesc::num_elem_desc, mhdf_FileDesc::num_tag_desc, read_adjacencies(), read_elems(), read_nodes(), read_sets(), read_tag(), mhdf_FileDesc::sets, mhdf_EntDesc::start_id, moab::DebugOutput::tprint(), and mhdf_ElemDesc::type.
Referenced by load_file().
    ErrorCode rval;
    mhdf_Status status;
    int i;
    CHECK_OPEN_HANDLES;
    dbgOut.tprint( 1, "Reading all nodes...\n" );
    Range ids;
    if( fileInfo->nodes.count )
        ids.insert( fileInfo->nodes.start_id, fileInfo->nodes.start_id + fileInfo->nodes.count - 1 );
        rval = read_nodes( ids );
    dbgOut.tprint( 1, "Reading all element connectivity...\n" );
    std::vector< int > polyhedra;  // Need to do these last so that faces are loaded
    for( i = 0; i < fileInfo->num_elem_desc; ++i )
        if( CN::EntityTypeFromName( fileInfo->elems[i].type ) == MBPOLYHEDRON )
            polyhedra.push_back( i );
            continue;
        rval = read_elems( i );
    for( std::vector< int >::iterator it = polyhedra.begin(); it != polyhedra.end(); ++it )
        rval = read_elems( *it );
    dbgOut.tprint( 1, "Reading all sets...\n" );
    ids.clear();
    if( fileInfo->sets.count )
        ids.insert( fileInfo->sets.start_id, fileInfo->sets.start_id + fileInfo->sets.count - 1 );
        rval = read_sets( ids );
        if( rval != MB_SUCCESS )
    dbgOut.tprint( 1, "Reading all adjacencies...\n" );
        if( !fileInfo->elems[i].have_adj ) continue;
        long table_len;
        hid_t table = mhdf_openAdjacency( filePtr, fileInfo->elems[i].handle, &table_len, &status );
        rval = read_adjacencies( table, table_len );
        mhdf_closeData( filePtr, table, &status );
    dbgOut.tprint( 1, "Reading all tags...\n" );
    for( i = 0; i < fileInfo->num_tag_desc; ++i )
        rval = read_tag( i );
    dbgOut.tprint( 1, "Core read finished.  Cleaning up...\n" );
    return MB_SUCCESS;
ErrorCode moab::ReadHDF5::load_file_partial ( const ReaderIface::IDTag *  subset_list,
int  num_parts,
int  part_number,
) [protected]
Definition at line 769 of file ReadHDF5.cpp.
References _times, ADJACENCY_TIME, CHECK_OPEN_HANDLES, mhdf_EntDesc::count, cputime, dbgOut, debug_barrier, delete_non_side_elements(), DELETE_NON_SIDEELEM_TIME, mhdf_ElemDesc::desc, dim, moab::CN::Dimension(), mhdf_FileDesc::elems, moab::Range::empty(), moab::CN::EntityTypeFromName(), ErrorCode, fileInfo, filePtr, find_sets_containing(), FIND_SETS_CONTAINING_TIME, GET_ELEMENTS_TIME, GET_NODEADJ_TIME, GET_NODES_TIME, moab::FileOptions::get_option(), get_partition(), GET_PARTITION_TIME, GET_POLYHEDRA_TIME, get_set_contents(), GET_SET_CONTENTS_TIME, GET_SET_IDS_TIME, GET_SIDEELEM_TIME, get_subset_ids(), mhdf_ElemDesc::handle, mhdf_ElemDesc::have_adj, moab::intersect(), is_error(), moab::Range::lower_bound(), moab::FileOptions::match_option(), MB_ENTITY_NOT_FOUND, MB_SET_ERR, MB_SUCCESS, MBENTITYSET, MBPOLYHEDRON, moab::Range::merge(), mhdf_closeData(), mhdf_openAdjacency(), mpiComm, mhdf_TagDesc::name, nativeParallel, mhdf_FileDesc::nodes, mhdf_FileDesc::num_elem_desc, mhdf_FileDesc::num_tag_desc, moab::ReaderIface::IDTag::num_tag_values, moab::DebugOutput::print(), moab::DebugOutput::print_ints(), moab::DebugOutput::printf(), moab::Range::psize(), read_adjacencies(), read_elems(), read_node_adj_elems(), read_nodes(), READ_SET_IDS_RECURS_TIME, read_set_ids_recursive(), read_sets(), READ_SETS_TIME, read_tag(), READ_TAGS_TIME, mhdf_FileDesc::sets, moab::Range::size(), mhdf_EntDesc::start_id, SUBSET_IDS_TIME, moab::ReaderIface::IDTag::tag_values, mhdf_FileDesc::tags, moab::CpuTimer::time_elapsed(), timer, moab::DebugOutput::tprint(), moab::DebugOutput::tprintf(), mhdf_ElemDesc::type, update_connectivity(), and UPDATECONN_TIME.
    mhdf_Status status;
    static MPEState mpe_event( "ReadHDF5", "yellow" );
    mpe_event.start( "gather parts" );
    CHECK_OPEN_HANDLES;
        dbgOut.printf( 2, "Select by \"%s\" with num_tag_values = %d\n", subset_list[i].tag_name,
        if( subset_list[i].num_tag_values )
            assert( 0 != subset_list[i].tag_values );
            dbgOut.printf( 2, "  \"%s\" values = { %d", subset_list[i].tag_name, subset_list[i].tag_values[0] );
            for( int j = 1; j < subset_list[i].num_tag_values; ++j )
                dbgOut.printf( 2, ", %d", subset_list[i].tag_values[j] );
            dbgOut.printf( 2, " }\n" );
    if( num_parts ) dbgOut.printf( 2, "Partition with num_parts = %d and part_number = %d\n", num_parts, part_number );
    dbgOut.tprint( 1, "RETRIEVING TAGGED ENTITIES\n" );
    Range file_ids;
    ErrorCode rval = get_subset_ids( subset_list, subset_list_length, file_ids );
    if( cputime ) _times[SUBSET_IDS_TIME] = timer->time_elapsed();
    if( num_parts )
        /*if (num_parts>(int)file_ids.size())
          MB_SET_ERR(MB_FAILURE, "Only " << file_ids.size() << " parts to distribute to " <<
        num_parts << " processes.");
        rval = get_partition( file_ids, num_parts, part_number );
    if( cputime ) _times[GET_PARTITION_TIME] = timer->time_elapsed();
    dbgOut.print_ints( 4, "Set file IDs for partial read: ", file_ids );
    mpe_event.end();
    mpe_event.start( "gather related sets" );
    dbgOut.tprint( 1, "GATHERING ADDITIONAL ENTITIES\n" );
    enum RecusiveSetMode
        RSM_NONE,
        RSM_SETS,
        RSM_CONTENTS
    const char* const set_opts[] = { "NONE", "SETS", "CONTENTS", NULL };
    int child_mode;
    rval = opts.match_option( "CHILDREN", set_opts, child_mode );
    if( MB_ENTITY_NOT_FOUND == rval )
        child_mode = RSM_CONTENTS;
    else if( MB_SUCCESS != rval )
        MB_SET_ERR( rval, "Invalid value for 'CHILDREN' option" );
    int content_mode;
    rval = opts.match_option( "SETS", set_opts, content_mode );
        content_mode = RSM_CONTENTS;
        MB_SET_ERR( rval, "Invalid value for 'SETS' option" );
    // If we want the contents of contained/child sets,
    // search for them now (before gathering the non-set contents
    // of the sets.)
    Range sets;
    intersect( fileInfo->sets, file_ids, sets );
    if( content_mode == RSM_CONTENTS || child_mode == RSM_CONTENTS )
        dbgOut.tprint( 1, "  doing read_set_ids_recursive\n" );
        rval = read_set_ids_recursive( sets, content_mode == RSM_CONTENTS, child_mode == RSM_CONTENTS );
    if( cputime ) _times[GET_SET_IDS_TIME] = timer->time_elapsed();
    debug_barrier();
    // Get elements and vertices contained in sets
    dbgOut.tprint( 1, "  doing get_set_contents\n" );
    rval = get_set_contents( sets, file_ids );
    if( cputime ) _times[GET_SET_CONTENTS_TIME] = timer->time_elapsed();
    dbgOut.print_ints( 5, "File IDs for partial read: ", file_ids );
    debug_barrier();
    mpe_event.end();
    dbgOut.tprint( 1, "GATHERING NODE IDS\n" );
    // Figure out the maximum dimension of entity to be read
    int max_dim = 0;
    for( int i = 0; i < fileInfo->num_elem_desc; ++i )
        EntityType type = CN::EntityTypeFromName( fileInfo->elems[i].type );
        if( type <= MBVERTEX || type >= MBENTITYSET )
            assert( false );  // For debug code die for unknown element types
            continue;         // For release code, skip unknown element types
        int dim = CN::Dimension( type );
        if( dim > max_dim )
            Range subset;
            intersect( fileInfo->elems[i].desc, file_ids, subset );
            if( !subset.empty() ) max_dim = dim;
        int send = max_dim;
        MPI_Allreduce( &send, &max_dim, 1, MPI_INT, MPI_MAX, *mpiComm );
#endif
    // If input contained any polyhedra, then need to get faces
    // of the polyhedra before the next loop because we need to
    // read said faces in that loop.
        if( type != MBPOLYHEDRON ) continue;
        debug_barrier();
        dbgOut.print( 2, "    Getting polyhedra faces\n" );
        mpe_event.start( "reading connectivity for ", fileInfo->elems[i].handle );
        Range polyhedra;
        intersect( fileInfo->elems[i].desc, file_ids, polyhedra );
        rval = read_elems( i, polyhedra, &file_ids );
        mpe_event.end( rval );
    if( cputime ) _times[GET_POLYHEDRA_TIME] = timer->time_elapsed();
    // Get node file ids for all elements
    Range nodes;
    intersect( fileInfo->nodes, file_ids, nodes );
        if( MBPOLYHEDRON == type ) continue;
        debug_barrier();
        dbgOut.printf( 2, "    Getting element node IDs for: %s\n", fileInfo->elems[i].handle );
        Range subset;
        // If dimension is max_dim, then we can create the elements now
        // so we don't have to read the table again later (connectivity
        // will be fixed up after nodes are created when update_connectivity())
        // is called.  For elements of a smaller dimension, we just build
        // the node ID range now because a) we'll have to read the whole
        // connectivity table again later, and b) we don't want to worry
        // about accidentally creating multiple copies of the same element.
        if( CN::Dimension( type ) == max_dim )
            rval = read_elems( i, subset, &nodes );
        else
            rval = read_elems( i, subset, nodes );
    if( cputime ) _times[GET_ELEMENTS_TIME] = timer->time_elapsed();
    debug_barrier();
    mpe_event.start( "read coords" );
    dbgOut.tprintf( 1, "READING NODE COORDINATES (%lu nodes in %lu selects)\n", (unsigned long)nodes.size(),
                    (unsigned long)nodes.psize() );
    // Read node coordinates and create vertices in MOAB
    // NOTE: This populates the RangeMap with node file ids,
    //       which is expected by read_node_adj_elems.
    rval = read_nodes( nodes );
    if( cputime ) _times[GET_NODES_TIME] = timer->time_elapsed();
    debug_barrier();
    dbgOut.tprint( 1, "READING ELEMENTS\n" );
    // Decide if we need to read additional elements
    enum SideMode
        SM_EXPLICIT,
        SM_NODES,
        SM_SIDES
    int side_mode;
    const char* const options[] = { "EXPLICIT", "NODES", "SIDES", 0 };
    rval                        = opts.match_option( "ELEMENTS", options, side_mode );
        // If only nodes were specified, then default to "NODES", otherwise
        // default to "SIDES".
        if( 0 == max_dim )
            side_mode = SM_NODES;
        else
            side_mode = SM_SIDES;
        MB_SET_ERR( rval, "Invalid value for 'ELEMENTS' option" );
    if( side_mode == SM_SIDES /*ELEMENTS=SIDES*/ && max_dim == 0 /*node-based*/ )
        // Read elements until we find something. Once we find something,
        // read only elements of the same dimension. NOTE: loop termination
        // criterion changes on both sides (max_dim can be changed in loop
        // body).
        for( int dim = 3; dim >= max_dim; --dim )
                if( CN::Dimension( type ) == dim )
                    debug_barrier();
                    dbgOut.tprintf( 2, "    Reading node-adjacent elements for: %s\n", fileInfo->elems[i].handle );
                    Range ents;
                    rval = read_node_adj_elems( fileInfo->elems[i] );
                    if( !ents.empty() ) max_dim = 3;
    if( cputime ) _times[GET_NODEADJ_TIME] = timer->time_elapsed();
    Range side_entities;
    if( side_mode != SM_EXPLICIT /*ELEMENTS=NODES || ELEMENTS=SIDES*/ )
        if( 0 == max_dim ) max_dim = 4;
        // Now read any additional elements for which we've already read all
        // of the nodes.
        for( int dim = max_dim - 1; dim > 0; --dim )
                    debug_barrier();
                    rval = read_node_adj_elems( fileInfo->elems[i], &side_entities );
    // We need to do this here for polyhedra to be handled correctly.
    // We have to wait until the faces are read in the above code block,
    // but need to create the connectivity before doing update_connectivity,
    // which might otherwise delete polyhedra faces.
    if( cputime ) _times[GET_SIDEELEM_TIME] = timer->time_elapsed();
    debug_barrier();
    dbgOut.tprint( 1, "UPDATING CONNECTIVITY ARRAYS FOR READ ELEMENTS\n" );
    mpe_event.start( "updating connectivity for elements read before vertices" );
    rval = update_connectivity();
    mpe_event.end();
    if( cputime ) _times[UPDATECONN_TIME] = timer->time_elapsed();
    dbgOut.tprint( 1, "READING ADJACENCIES\n" );
        if (fileInfo->elems[i].have_adj  /*&&
        idMap.intersects(fileInfo->elems[i].desc.start_id, fileInfo->elems[i].desc.count) */)
            mpe_event.start( "reading adjacencies for ", fileInfo->elems[i].handle );
            long len;
            hid_t th = mhdf_openAdjacency( filePtr, fileInfo->elems[i].handle, &len, &status );
            rval = read_adjacencies( th, len );
            mhdf_closeData( filePtr, th, &status );
    if( cputime ) _times[ADJACENCY_TIME] = timer->time_elapsed();
    // If doing ELEMENTS=SIDES then we need to delete any entities
    // that we read that aren't actually sides (e.g. an interior face
    // that connects two disjoint portions of the part). Both
    // update_connectivity and reading of any explicit adjacencies must
    // happen before this.
    if( side_mode == SM_SIDES )
        debug_barrier();
        mpe_event.start( "cleaning up non-side lower-dim elements" );
        dbgOut.tprint( 1, "CHECKING FOR AND DELETING NON-SIDE ELEMENTS\n" );
        rval = delete_non_side_elements( side_entities );
    if( cputime ) _times[DELETE_NON_SIDEELEM_TIME] = timer->time_elapsed();
    debug_barrier();
    dbgOut.tprint( 1, "READING SETS\n" );
    // If reading contained/child sets but not their contents then find
    // them now. If we were also reading their contents we would
    // have found them already.
    if( content_mode == RSM_SETS || child_mode == RSM_SETS )
        mpe_event.start( "finding recursively contained sets" );
        rval = read_set_ids_recursive( sets, content_mode == RSM_SETS, child_mode == RSM_SETS );
    if( cputime ) _times[READ_SET_IDS_RECURS_TIME] = timer->time_elapsed();
    dbgOut.tprint( 1, "  doing find_sets_containing\n" );
    mpe_event.start( "finding sets containing any read entities" );
    // Decide whether to read set-containing parents
    bool read_set_containing_parents = true;
    std::string tmp_opt;
    rval = opts.get_option( "NO_SET_CONTAINING_PARENTS", tmp_opt );
    if( MB_SUCCESS == rval ) read_set_containing_parents = false;
    // Append file IDs of sets containing any of the nodes or elements
    // we've read up to this point.
    rval = find_sets_containing( sets, read_set_containing_parents );
    if( cputime ) _times[FIND_SETS_CONTAINING_TIME] = timer->time_elapsed();
    // Now actually read all set data and instantiate sets in MOAB.
    // Get any contained sets out of file_ids.
    mpe_event.start( "reading set contents/parents/children" );
    EntityHandle first_set = fileInfo->sets.start_id;
    sets.merge( file_ids.lower_bound( first_set ), file_ids.lower_bound( first_set + fileInfo->sets.count ) );
    dbgOut.tprint( 1, "  doing read_sets\n" );
    rval = read_sets( sets );
    if( cputime ) _times[READ_SETS_TIME] = timer->time_elapsed();
    dbgOut.tprint( 1, "READING TAGS\n" );
    for( int i = 0; i < fileInfo->num_tag_desc; ++i )
        mpe_event.start( "reading tag: ", fileInfo->tags[i].name );
    if( cputime ) _times[READ_TAGS_TIME] = timer->time_elapsed();
    dbgOut.tprint( 1, "PARTIAL READ COMPLETE.\n" );
    return MB_SUCCESS;
Interface* moab::ReadHDF5::moab ( ) const [inline]
Definition at line 77 of file ReadHDF5.hpp.
References iFace.
        return iFace;
void moab::ReadHDF5::print_times ( ) [protected]
Definition at line 3953 of file ReadHDF5.cpp.
References _times, ADJACENCY_TIME, DELETE_NON_SIDEELEM_TIME, FIND_SETS_CONTAINING_TIME, GET_ELEMENTS_TIME, GET_NODEADJ_TIME, GET_NODES_TIME, GET_PARTITION_TIME, GET_POLYHEDRA_TIME, GET_SET_CONTENTS_TIME, GET_SET_IDS_TIME, GET_SIDEELEM_TIME, myPcomm, NUM_TIMES, moab::ProcConfig::proc_comm(), moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), READ_QA_TIME, READ_SET_IDS_RECURS_TIME, READ_SETS_TIME, READ_TAGS_TIME, SET_META_TIME, STORE_FILE_IDS_TIME, SUBSET_IDS_TIME, TOTAL_TIME, and UPDATECONN_TIME.
    if( !myPcomm )
        double recv[NUM_TIMES];
        MPI_Reduce( (void*)_times, recv, NUM_TIMES, MPI_DOUBLE, MPI_MAX, 0, myPcomm->proc_config().proc_comm() );
            _times[i] = recv[i];  // just get the max from all of them
    if( 0 == myPcomm->proc_config().proc_rank() )
#endif
        std::cout << "ReadHDF5:             " << _times[TOTAL_TIME] << std::endl
                  << "  get set meta        " << _times[SET_META_TIME] << std::endl
                  << "  partial subsets     " << _times[SUBSET_IDS_TIME] << std::endl
                  << "  partition time      " << _times[GET_PARTITION_TIME] << std::endl
                  << "  get set ids         " << _times[GET_SET_IDS_TIME] << std::endl
                  << "  set contents        " << _times[GET_SET_CONTENTS_TIME] << std::endl
                  << "  polyhedra           " << _times[GET_POLYHEDRA_TIME] << std::endl
                  << "  elements            " << _times[GET_ELEMENTS_TIME] << std::endl
                  << "  nodes               " << _times[GET_NODES_TIME] << std::endl
                  << "  node adjacency      " << _times[GET_NODEADJ_TIME] << std::endl
                  << "  side elements       " << _times[GET_SIDEELEM_TIME] << std::endl
                  << "  update connectivity " << _times[UPDATECONN_TIME] << std::endl
                  << "  adjacency           " << _times[ADJACENCY_TIME] << std::endl
                  << "  delete non_adj      " << _times[DELETE_NON_SIDEELEM_TIME] << std::endl
                  << "  recursive sets      " << _times[READ_SET_IDS_RECURS_TIME] << std::endl
                  << "  find contain_sets   " << _times[FIND_SETS_CONTAINING_TIME] << std::endl
                  << "  read sets           " << _times[READ_SETS_TIME] << std::endl
                  << "  read tags           " << _times[READ_TAGS_TIME] << std::endl
                  << "  store file ids      " << _times[STORE_FILE_IDS_TIME] << std::endl
                  << "  read qa records     " << _times[READ_QA_TIME] << std::endl;
#endif
ErrorCode moab::ReadHDF5::read_adjacencies ( hid_t  adjacency_table,
long  table_length
) [private]
Definition at line 2640 of file ReadHDF5.cpp.
References moab::Interface::add_adjacencies(), assert_range, buffer, bufferSize, CHECK_OPEN_HANDLES, collIO, convert_id_to_handle(), dataBuffer, dbgOut, debug_barrier, ErrorCode, moab::RangeMap< KeyType, ValType, NullVal >::find(), handleType, idMap, iFace, is_error(), MB_SET_ERR, MB_SUCCESS, mhdf_readAdjacencyWithOpt(), and moab::DebugOutput::printf().
Referenced by load_file_impl(), and load_file_partial().
    CHECK_OPEN_HANDLES;
    ErrorCode rval;
    mhdf_Status status;
    debug_barrier();
    hid_t read_type = H5Dget_type( table );
    if( read_type < 0 ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" );
    const bool convert = !H5Tequal( read_type, handleType );
    EntityHandle* buffer = (EntityHandle*)dataBuffer;
    size_t chunk_size    = bufferSize / H5Tget_size( read_type );
    size_t remaining     = table_len;
    size_t left_over     = 0;
    size_t offset        = 0;
    dbgOut.printf( 3, "Reading adjacency list in %lu chunks\n",
                   (unsigned long)( remaining + chunk_size - 1 ) / chunk_size );
    int nn = 0;
    while( remaining )
        dbgOut.printf( 3, "Reading chunk %d of adjacency list\n", ++nn );
        size_t count = std::min( chunk_size, remaining );
        count -= left_over;
        remaining -= count;
        assert_range( buffer + left_over, count );
        mhdf_readAdjacencyWithOpt( table, offset, count, read_type, buffer + left_over, collIO, &status );
        if( convert )
            herr_t err = H5Tconvert( read_type, handleType, count, buffer + left_over, 0, H5P_DEFAULT );
            if( err < 0 ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" );
        EntityHandle* iter = buffer;
        EntityHandle* end  = buffer + count + left_over;
        while( end - iter >= 3 )
            EntityHandle h      = idMap.find( *iter++ );
            EntityHandle count2 = *iter++;
            if( !h )
                iter += count2;
                continue;
            if( count2 < 1 ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" );
            if( end < count2 + iter )
                iter -= 2;
                break;
            size_t valid;
            convert_id_to_handle( iter, count2, valid, idMap );
            rval = iFace->add_adjacencies( h, iter, valid, false );
            iter += count2;
        left_over = end - iter;
        assert_range( (char*)buffer, left_over );
        assert_range( (char*)iter, left_over );
        memmove( buffer, iter, left_over );
    assert( !left_over );  // Unexpected truncation of data
    return MB_SUCCESS;
Definition at line 1982 of file ReadHDF5.cpp.
References bcastDuplicateReads, CHECK_OPEN_HANDLES, collIO, mhdf_EntDesc::count, fileInfo, filePtr, ierr, is_error(), MB_SET_ERR, MB_SUCCESS, mhdf_closeData(), mhdf_openSetMetaSimple(), mhdf_readSetMetaWithOpt(), myPcomm, nativeParallel, moab::ProcConfig::proc_comm(), moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), rank, setMeta, mhdf_FileDesc::sets, and size.
    CHECK_OPEN_HANDLES;
    assert( !setMeta );
    if( !num_sets ) return MB_SUCCESS;
    mhdf_Status status;
    hid_t handle = mhdf_openSetMetaSimple( filePtr, &status );
    // Allocate extra space if we need it for data conversion
    hid_t meta_type = H5Dget_type( handle );
    size_t size     = H5Tget_size( meta_type );
    if( size > sizeof( long ) )
        setMeta = new long[( num_sets * size + ( sizeof( long ) - 1 ) ) / sizeof( long )][4];
    else
        setMeta = new long[num_sets][4];
    // Set some parameters based on whether or not each proc reads the
    // table or only the root reads it and bcasts it to the others
    int rank     = 0;
    bool bcast   = false;
    hid_t ioprop = H5P_DEFAULT;
    MPI_Comm comm = 0;
        if( !bcast ) ioprop = collIO;
#endif
        mhdf_readSetMetaWithOpt( handle, 0, num_sets, meta_type, setMeta, ioprop, &status );
            H5Tclose( meta_type );
            mhdf_closeData( filePtr, handle, &status );
        H5Tconvert( meta_type, H5T_NATIVE_LONG, num_sets * 4, setMeta, 0, H5P_DEFAULT );
    if( bcast )
        int ierr = MPI_Bcast( (void*)setMeta, num_sets * 4, MPI_LONG, 0, comm );
#else
#endif
    return MB_SUCCESS;
ErrorCode moab::ReadHDF5::read_dense_tag ( Tag  tag_handle,
const char *  ent_name,
hid_t  data_table,
long  start_id,
long  count
) [private]
Definition at line 3043 of file ReadHDF5.cpp.
References moab::Range::begin(), bufferSize, CHECK_OPEN_HANDLES, convert_id_to_handle(), dataBuffer, dbgOut, moab::RangeMap< KeyType, ValType, NullVal >::end(), ErrorCode, idMap, iFace, moab::Range::insert(), moab::RangeMap< KeyType, ValType, NullVal >::lower_bound(), MB_SET_ERR, MB_SUCCESS, MB_TYPE_HANDLE, mpiComm, nativeParallel, moab::DebugOutput::printf(), moab::Interface::tag_get_bytes(), moab::Interface::tag_get_data_type(), moab::Interface::tag_get_name(), and moab::Interface::tag_set_data().
    CHECK_OPEN_HANDLES;
    ErrorCode rval;
    DataType mb_type;
    rval = iFace->tag_get_data_type( tag_handle, mb_type );
    int read_size;
    rval = iFace->tag_get_bytes( tag_handle, read_size );
    if( MB_SUCCESS != rval )  // Wrong function for variable-length tags
    // if (MB_TYPE_BIT == mb_type)
    // read_size = (read_size + 7) / 8; // Convert bits to bytes, plus 7 for ceiling
    if( hdf_read_type )
    {  // If not opaque
        hsize_t hdf_size = H5Tget_size( hdf_read_type );
        if( hdf_size != (hsize_t)read_size ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" );
    // Get actual entities read from file
    Range file_ids, handles;
    Range::iterator f_ins = file_ids.begin(), h_ins = handles.begin();
    IDMap::iterator l, u;
    l = idMap.lower_bound( start_id );
    u = idMap.lower_bound( start_id + num_values - 1 );
    if( l != idMap.end() && start_id + num_values > l->begin )
        if( l == u )
            size_t beg = std::max( start_id, l->begin );
            size_t end = std::min( start_id + num_values, u->begin + u->count ) - 1;
            f_ins      = file_ids.insert( f_ins, beg, end );
            h_ins      = handles.insert( h_ins, l->value + ( beg - l->begin ), l->value + ( end - l->begin ) );
        else
            f_ins      = file_ids.insert( f_ins, beg, l->begin + l->count - 1 );
            h_ins      = handles.insert( h_ins, l->value + ( beg - l->begin ), l->value + l->count - 1 );
            for( ++l; l != u; ++l )
                f_ins = file_ids.insert( f_ins, l->begin, l->begin + l->count - 1 );
                h_ins = handles.insert( h_ins, l->value, l->value + l->count - 1 );
            if( u != idMap.end() && u->begin < start_id + num_values )
                size_t end = std::min( start_id + num_values, u->begin + u->count - 1 );
                f_ins      = file_ids.insert( f_ins, u->begin, end );
                h_ins      = handles.insert( h_ins, u->value, u->value + end - u->begin );
    // Given that all of the entities for this dense tag data should
    // have been created as a single contiguous block, the resulting
    // MOAB handle range should be contiguous.
    // THE ABOVE IS NOT NECESSARILY TRUE. SOMETIMES LOWER-DIMENSION
    // ENTS ARE READ AND THEN DELETED FOR PARTIAL READS.
    // assert(handles.empty() || handles.size() == (handles.back() - handles.front() + 1));
    std::string tn( "<error>" );
    iFace->tag_get_name( tag_handle, tn );
    tn += " data for ";
    tn += ent_name;
    try
        ReadHDF5Dataset reader( tn.c_str(), data, nativeParallel, mpiComm, false );
        long buffer_size = bufferSize / read_size;
        reader.set_file_ids( file_ids, start_id, buffer_size, hdf_read_type );
        dbgOut.printf( 3, "Reading dense data for tag \"%s\" and group \"%s\" in %lu chunks\n", tn.c_str(), ent_name,
                       reader.get_read_count() );
        int nn = 0;
        while( !reader.done() )
            dbgOut.printf( 3, "Reading chunk %d of \"%s\" data\n", ++nn, tn.c_str() );
            size_t count;
            reader.read( dataBuffer, count );
                rval = convert_id_to_handle( (EntityHandle*)dataBuffer, count * read_size / sizeof( EntityHandle ) );
            Range ents;
            Range::iterator end = h_ins;
            end += count;
            ents.insert( h_ins, end );
            h_ins = end;
            rval = iFace->tag_set_data( tag_handle, ents, dataBuffer );
                dbgOut.printf( 1, "Internal error setting data for tag \"%s\"\n", tn.c_str() );
        dbgOut.printf( 1, "Internal error reading dense data for tag \"%s\"\n", tn.c_str() );
    return MB_SUCCESS;
ErrorCode moab::ReadHDF5::read_elems ( int  index,
Range *  node_ids = 0
) [private]
Definition at line 1514 of file ReadHDF5.cpp.
References mhdf_ElemDesc::desc, mhdf_FileDesc::elems, fileInfo, MB_CHK_ERR, MB_TYPE_OUT_OF_RANGE, read_elems(), read_poly(), and mhdf_EntDesc::vals_per_ent.
    if( fileInfo->elems[i].desc.vals_per_ent < 0 )
        if( node_ids != 0 )  // Not implemented for version 3 format of poly data
            MB_CHK_ERR( MB_TYPE_OUT_OF_RANGE );
        return read_poly( fileInfo->elems[i], file_ids );
    else
        return read_elems( fileInfo->elems[i], file_ids, node_ids );
ErrorCode moab::ReadHDF5::read_elems ( const mhdf_ElemDesc &  elems,
) [private]
Read element connectivity.
Parameters:
node_idsIf this is non-null, the union of the connectivity list for all elements is passed back as FILE IDS in this range AND the connectivity list is left in the form of file IDs (NOT NODE HANDLES).
Definition at line 1526 of file ReadHDF5.cpp.
References moab::ReadHDF5::IDConnectivity::array, buffer, bufferSize, CHECK_OPEN_HANDLES, convert_id_to_handle(), moab::copy_sorted_file_ids(), moab::ReadHDF5::IDConnectivity::count, dataBuffer, dbgOut, debug_barrier, mhdf_ElemDesc::desc, moab::ReadHDF5Dataset::done(), moab::CN::EntityTypeFromName(), ErrorCode, filePtr, moab::ReadUtilIface::get_element_connect(), moab::ReadHDF5Dataset::get_read_count(), moab::ReadHDF5::IDConnectivity::handle, mhdf_ElemDesc::handle, handleType, idConnectivityList, insert_in_id_map(), is_error(), MB_SET_ERR, MB_SUCCESS, MBMAXTYPE, mhdf_openConnectivitySimple(), mpiComm, nativeParallel, moab::ReadHDF5::IDConnectivity::nodes_per_elem, moab::DebugOutput::printf(), moab::Range::psize(), moab::ReadHDF5Dataset::read(), readUtil, moab::ReadHDF5Dataset::set_file_ids(), moab::Range::size(), mhdf_EntDesc::start_id, t, moab::DebugOutput::tprintf(), mhdf_ElemDesc::type, moab::ReadUtilIface::update_adjacencies(), and mhdf_EntDesc::vals_per_ent.
    CHECK_OPEN_HANDLES;
    debug_barrier();
    dbgOut.tprintf( 1, "READING %s CONNECTIVITY (%lu elems in %lu selects)\n", elems.handle,
                    (unsigned long)file_ids.size(), (unsigned long)file_ids.psize() );
    ErrorCode rval = MB_SUCCESS;
    mhdf_Status status;
    EntityType type = CN::EntityTypeFromName( elems.type );
    if( type == MBMAXTYPE )
        MB_SET_ERR( MB_FAILURE, "Unknown element type: \"" << elems.type << "\"" );
    const int nodes_per_elem = elems.desc.vals_per_ent;
    const size_t count       = file_ids.size();
    hid_t data_id            = mhdf_openConnectivitySimple( filePtr, elems.handle, &status );
    EntityHandle handle;
    EntityHandle* array = 0;
    if( count > 0 ) rval = readUtil->get_element_connect( count, nodes_per_elem, type, 0, handle, array );
    try
        const size_t buffer_size = bufferSize / ( sizeof( EntityHandle ) * nodes_per_elem );
        ReadHDF5Dataset reader( elems.handle, data_id, nativeParallel, mpiComm );
        reader.set_file_ids( file_ids, elems.desc.start_id, buffer_size, handleType );
        dbgOut.printf( 3, "Reading connectivity in %lu chunks for element group \"%s\"\n", reader.get_read_count(),
                       elems.handle );
        EntityHandle* iter = array;
        int nn             = 0;
            dbgOut.printf( 3, "Reading chunk %d for \"%s\"\n", ++nn, elems.handle );
            size_t num_read;
            reader.read( buffer, num_read );
            iter = std::copy( buffer, buffer + num_read * nodes_per_elem, iter );
            if( node_ids )
                std::sort( buffer, buffer + num_read * nodes_per_elem );
                num_read = std::unique( buffer, buffer + num_read * nodes_per_elem ) - buffer;
                copy_sorted_file_ids( buffer, num_read, *node_ids );
        assert( iter - array == (ptrdiff_t)count * nodes_per_elem );
    if( !node_ids )
        rval = convert_id_to_handle( array, count * nodes_per_elem );
        rval = readUtil->update_adjacencies( handle, count, nodes_per_elem, array );
    else
        IDConnectivity t;
        t.handle         = handle;
        t.count          = count;
        t.nodes_per_elem = nodes_per_elem;
        t.array          = array;
        idConnectivityList.push_back( t );
    return insert_in_id_map( file_ids, handle );
const Range &  element_file_ids,
Range &  node_file_ids
) [private]
Definition at line 1740 of file ReadHDF5.cpp.
References moab::Range::back(), buffer, bufferSize, CHECK_OPEN_HANDLES, moab::copy_sorted_file_ids(), mhdf_EntDesc::count, dataBuffer, dbgOut, debug_barrier, mhdf_ElemDesc::desc, moab::ReadHDF5Dataset::done(), mhdf_FileDesc::elems, moab::Range::empty(), fileInfo, filePtr, moab::Range::front(), moab::ReadHDF5Dataset::get_read_count(), mhdf_ElemDesc::handle, handleType, is_error(), MB_CHK_ERR, MB_SET_ERR, MB_SUCCESS, MB_TYPE_OUT_OF_RANGE, mhdf_openConnectivitySimple(), mpiComm, nativeParallel, moab::DebugOutput::printf(), moab::Range::psize(), moab::ReadHDF5Dataset::read(), moab::ReadHDF5Dataset::set_file_ids(), moab::Range::size(), mhdf_EntDesc::start_id, moab::DebugOutput::tprintf(), and mhdf_EntDesc::vals_per_ent.
    CHECK_OPEN_HANDLES;
    debug_barrier();
    dbgOut.tprintf( 1, "READING %s CONNECTIVITY (%lu elems in %lu selects)\n", fileInfo->elems[i].handle,
                    (unsigned long)elems_in.size(), (unsigned long)elems_in.psize() );
    EntityHandle* const buffer = reinterpret_cast< EntityHandle* >( dataBuffer );
    const int node_per_elem    = fileInfo->elems[i].desc.vals_per_ent;
    const size_t buffer_size   = bufferSize / ( node_per_elem * sizeof( EntityHandle ) );
    if( elems_in.empty() ) return MB_SUCCESS;
    assert( (long)elems_in.front() >= fileInfo->elems[i].desc.start_id );
    assert( (long)elems_in.back() - fileInfo->elems[i].desc.start_id < fileInfo->elems[i].desc.count );
    // We don't support version 3 style poly element data
    if( fileInfo->elems[i].desc.vals_per_ent <= 0 ) MB_CHK_ERR( MB_TYPE_OUT_OF_RANGE );
    mhdf_Status status;
    hid_t table = mhdf_openConnectivitySimple( filePtr, fileInfo->elems[i].handle, &status );
    try
        ReadHDF5Dataset reader( fileInfo->elems[i].handle, table, nativeParallel, mpiComm );
        reader.set_file_ids( elems_in, fileInfo->elems[i].desc.start_id, buffer_size, handleType );
        dbgOut.printf( 3, "Reading node list in %lu chunks for \"%s\"\n", reader.get_read_count(),
        int nn = 0;
            dbgOut.printf( 3, "Reading chunk %d of \"%s\" connectivity\n", ++nn, fileInfo->elems[i].handle );
            size_t num_read;
            std::sort( buffer, buffer + num_read * node_per_elem );
            num_read = std::unique( buffer, buffer + num_read * node_per_elem ) - buffer;
            copy_sorted_file_ids( buffer, num_read, nodes );
    return MB_SUCCESS;
ErrorCode moab::ReadHDF5::read_node_adj_elems ( const mhdf_ElemDesc &  group,
Range *  read_entities = 0
) [private]
Definition at line 1623 of file ReadHDF5.cpp.
References CHECK_OPEN_HANDLES, ErrorCode, filePtr, mhdf_ElemDesc::handle, is_error(), MB_SET_ERR, MB_SET_ERR_RET_VAL, MB_SUCCESS, mhdf_closeData(), and mhdf_openConnectivitySimple().
    mhdf_Status status;
    ErrorCode rval;
    CHECK_OPEN_HANDLES;
    hid_t table = mhdf_openConnectivitySimple( filePtr, group.handle, &status );
    rval = read_node_adj_elems( group, table, handles_out );
    if( MB_SUCCESS == rval && is_error( status ) ) MB_SET_ERR_RET_VAL( "ReadHDF5 Failure", MB_FAILURE );
    return rval;
hid_t  connectivity_handle,
) [private]
Definition at line 1641 of file ReadHDF5.cpp.
References moab::IODebugTrack::all_reduce(), assert_range, moab::Range::begin(), buffer, bufferSize, CHECK_OPEN_HANDLES, collIO, mhdf_EntDesc::count, dataBuffer, dbgOut, debug_barrier, debugTrack, mhdf_ElemDesc::desc, moab::CN::EntityTypeFromName(), ErrorCode, moab::RangeMap< KeyType, ValType, NullVal >::find(), moab::ReadUtilIface::get_element_connect(), mhdf_ElemDesc::handle, idMap, moab::RangeMap< KeyType, ValType, NullVal >::insert(), moab::Range::insert(), is_error(), MB_SET_ERR, MB_SUCCESS, mhdf_readConnectivityWithOpt(), moab::DebugOutput::printf(), readUtil, moab::IODebugTrack::record_io(), mhdf_EntDesc::start_id, mhdf_ElemDesc::type, moab::ReadUtilIface::update_adjacencies(), and mhdf_EntDesc::vals_per_ent.
    CHECK_OPEN_HANDLES;
    debug_barrier();
    mhdf_Status status;
    ErrorCode rval;
    IODebugTrack debug_track( debugTrack, std::string( group.handle ) );
    // Copy data to local variables (makes other code clearer)
    const int node_per_elem = group.desc.vals_per_ent;
    long start_id           = group.desc.start_id;
    long remaining          = group.desc.count;
    const EntityType type   = CN::EntityTypeFromName( group.type );
    // Figure out how many elements we can read in each pass
    long* const buffer     = reinterpret_cast< long* >( dataBuffer );
    const long buffer_size = bufferSize / ( node_per_elem * sizeof( buffer[0] ) );
    // Read all element connectivity in buffer_size blocks
    long offset = 0;
    dbgOut.printf( 3, "Reading node-adjacent elements from \"%s\" in %ld chunks\n", group.handle,
                   ( remaining + buffer_size - 1 ) / buffer_size );
    int nn = 0;
    Range::iterator hint;
    if( handles_out ) hint = handles_out->begin();
    while( remaining )
        dbgOut.printf( 3, "Reading chunk %d of connectivity data for \"%s\"\n", ++nn, group.handle );
        // Read a block of connectivity data
        const long count = std::min( remaining, buffer_size );
        debug_track.record_io( offset, count );
        assert_range( buffer, count * node_per_elem );
        mhdf_readConnectivityWithOpt( table_handle, offset, count, H5T_NATIVE_LONG, buffer, collIO, &status );
        offset += count;
        remaining -= count;
        // Count the number of elements in the block that we want,
        // zero connectivity for other elements
        long num_elem = 0;
        long* iter    = buffer;
            for( int j = 0; j < node_per_elem; ++j )
                iter[j] = (long)idMap.find( iter[j] );
                if( !iter[j] )
                    iter[0] = 0;
                    break;
            if( iter[0] ) ++num_elem;
            iter += node_per_elem;
        if( !num_elem )
            start_id += count;
            continue;
        // Create elements
        EntityHandle* array;
        rval = readUtil->get_element_connect( (int)num_elem, node_per_elem, type, 0, handle, array );
        // Copy all non-zero connectivity values
        iter                = buffer;
        EntityHandle* iter2 = array;
        EntityHandle h      = handle;
            if( !*iter )
                continue;
            if( !idMap.insert( start_id + i, h++, 1 ).second ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" );
            long* const end = iter + node_per_elem;
            for( ; iter != end; ++iter, ++iter2 )
                *iter2 = (EntityHandle)*iter;
        assert( iter2 - array == num_elem * node_per_elem );
        start_id += count;
        rval = readUtil->update_adjacencies( handle, num_elem, node_per_elem, array );
        if( handles_out ) hint = handles_out->insert( hint, handle, handle + num_elem - 1 );
    debug_track.all_reduce();
    return MB_SUCCESS;
ErrorCode moab::ReadHDF5::read_nodes ( const Range &  node_file_ids) [private]
Definition at line 1395 of file ReadHDF5.cpp.
References blockedCoordinateIO, buffer, bufferSize, CHECK_OPEN_HANDLES, dataBuffer, dbgOut, dim, moab::ReadHDF5Dataset::done(), moab::Range::empty(), ErrorCode, fileInfo, filePtr, moab::Interface::get_dimension(), moab::ReadUtilIface::get_node_coords(), moab::ReadHDF5Dataset::get_read_count(), iFace, insert_in_id_map(), is_error(), MB_SET_ERR, MB_SUCCESS, mhdf_closeData(), mhdf_openNodeCoordsSimple(), mpiComm, nativeParallel, mhdf_FileDesc::nodes, moab::DebugOutput::print(), moab::DebugOutput::printf(), moab::ReadHDF5Dataset::read(), readUtil, moab::ReadHDF5Dataset::set_column(), moab::Interface::set_dimension(), moab::ReadHDF5Dataset::set_file_ids(), moab::Range::size(), mhdf_EntDesc::start_id, moab::DebugOutput::tprintf(), and mhdf_EntDesc::vals_per_ent.
    ErrorCode rval;
    mhdf_Status status;
    const int dim = fileInfo->nodes.vals_per_ent;
    Range range;
    CHECK_OPEN_HANDLES;
    if( node_file_ids.empty() && !nativeParallel ) return MB_SUCCESS;
    int cdim;
    rval = iFace->get_dimension( cdim );
    if( MB_SUCCESS != rval ) MB_SET_ERR( rval, "ReadHDF5 Failure" );
    if( cdim < dim )
        rval = iFace->set_dimension( dim );
    hid_t data_id = mhdf_openNodeCoordsSimple( filePtr, &status );
    std::vector< double* > arrays( dim );
    const size_t num_nodes = node_file_ids.size();
    if( num_nodes > 0 )
        rval = readUtil->get_node_coords( dim, (int)num_nodes, 0, handle, arrays );
            mhdf_closeData( filePtr, data_id, &status );
    if( blockedCoordinateIO )
        try
            for( int d = 0; d < dim; ++d )
                ReadHDF5Dataset reader( "blocked coords", data_id, nativeParallel, mpiComm, false );
                reader.set_column( d );
                reader.set_file_ids( node_file_ids, fileInfo->nodes.start_id, num_nodes, H5T_NATIVE_DOUBLE );
                dbgOut.printf( 3, "Reading %lu chunks for coordinate dimension %d\n", reader.get_read_count(), d );
                // Should normally only have one read call, unless sparse nature
                // of file_ids caused reader to do something strange
                size_t count, offset = 0;
                int nn = 0;
                    dbgOut.printf( 3, "Reading chunk %d for dimension %d\n", ++nn, d );
                    reader.read( arrays[d] + offset, count );
                    offset += count;
                if( offset != num_nodes )
                    assert( false );
                    return MB_FAILURE;
    else
    {  // !blockedCoordinateIO
        double* buffer  = (double*)dataBuffer;
        long chunk_size = bufferSize / ( 3 * sizeof( double ) );
        long coffset    = 0;
        int nn          = 0;
        try
            ReadHDF5Dataset reader( "interleaved coords", data_id, nativeParallel, mpiComm, false );
            reader.set_file_ids( node_file_ids, fileInfo->nodes.start_id, chunk_size, H5T_NATIVE_DOUBLE );
            dbgOut.printf( 3, "Reading %lu chunks for coordinate coordinates\n", reader.get_read_count() );
                dbgOut.tprintf( 3, "Reading chunk %d of node coords\n", ++nn );
                size_t count;
                reader.read( buffer, count );
                for( size_t i = 0; i < count; ++i )
                        arrays[d][coffset + i] = buffer[dim * i + d];
                coffset += count;
    dbgOut.print( 3, "Closing node coordinate table\n" );
    for( int d = dim; d < cdim; ++d )
        memset( arrays[d], 0, num_nodes * sizeof( double ) );
    dbgOut.printf( 3, "Updating ID to handle map for %lu nodes\n", (unsigned long)node_file_ids.size() );
    return insert_in_id_map( node_file_ids, handle );
ErrorCode moab::ReadHDF5::read_poly ( const mhdf_ElemDesc &  elems,
) [private]
Read poly(gons|hedra)
Definition at line 1789 of file ReadHDF5.cpp.
References buffer, bufferSize, CHECK_OPEN_HANDLES, dataBuffer, dbgOut, debug_barrier, moab::CN::EntityTypeFromName(), ErrorCode, filePtr, mhdf_ElemDesc::handle, handleType, is_error(), MB_CHK_ERR, MB_ENTITY_NOT_FOUND, MB_SET_ERR, MB_SUCCESS, MBMAXTYPE, mhdf_openPolyConnectivity(), mpiComm, nativeParallel, and mhdf_ElemDesc::type.
Referenced by read_elems().
    class PolyReader : public ReadHDF5VarLen
      private:
        const EntityType type;
        ReadHDF5* readHDF5;
      public:
        PolyReader( EntityType elem_type, void* buffer, size_t buffer_size, ReadHDF5* owner, DebugOutput& dbg )
            : ReadHDF5VarLen( dbg, buffer, buffer_size ), type( elem_type ), readHDF5( owner )
        virtual ~PolyReader() {}
        ErrorCode store_data( EntityHandle file_id, void* data, long len, bool )
            size_t valid;
            EntityHandle* conn = reinterpret_cast< EntityHandle* >( data );
            readHDF5->convert_id_to_handle( conn, len, valid );
            if( valid != (size_t)len ) MB_CHK_ERR( MB_ENTITY_NOT_FOUND );
            ErrorCode rval = readHDF5->moab()->create_element( type, conn, len, handle );
            rval = readHDF5->insert_in_id_map( file_id, handle );
            return rval;
    CHECK_OPEN_HANDLES;
    debug_barrier();
    hid_t handles[2];
    mhdf_Status status;
    long num_poly, num_conn, first_id;
    mhdf_openPolyConnectivity( filePtr, elems.handle, &num_poly, &num_conn, &first_id, handles, &status );
    std::string nm( elems.handle );
    ReadHDF5Dataset offset_reader( ( nm + " offsets" ).c_str(), handles[0], nativeParallel, mpiComm, true );
    ReadHDF5Dataset connect_reader( ( nm + " data" ).c_str(), handles[1], nativeParallel, mpiComm, true );
    PolyReader tool( type, dataBuffer, bufferSize, this, dbgOut );
    return tool.read( offset_reader, connect_reader, file_ids, first_id, handleType );
FIX ME - how to put QA list on set??
Definition at line 3535 of file ReadHDF5.cpp.
References CHECK_OPEN_HANDLES, filePtr, MB_SET_ERR, MB_SUCCESS, mhdf_isError(), mhdf_message(), and mhdf_readHistory().
    CHECK_OPEN_HANDLES;
    mhdf_Status status;
    // std::vector<std::string> qa_list;
    int qa_len;
    char** qa = mhdf_readHistory( filePtr, &qa_len, &status );
    if( mhdf_isError( &status ) )
        MB_SET_ERR( MB_FAILURE, mhdf_message( &status ) );
    // qa_list.resize(qa_len);
    for( int i = 0; i < qa_len; i++ )
        // qa_list[i] = qa[i];
        free( qa[i] );
    free( qa );
    /** FIX ME - how to put QA list on set?? */
    return MB_SUCCESS;
ErrorCode moab::ReadHDF5::read_set_data ( const Range &  set_file_ids,
EntityHandle  set_start_handle,
ReadHDF5Dataset &  set_data_set,
SetMode  which_data,
Range *  file_ids_out = 0
) [private]
Definition at line 2411 of file ReadHDF5.cpp.
References moab::Interface::add_child_meshsets(), moab::Interface::add_entities(), moab::Interface::add_parent_meshsets(), moab::Range::begin(), buffer, bufferSize, CHILD, moab::Range::const_pair_begin(), moab::Range::const_pair_end(), CONTENT, convert_id_to_handle(), convert_range_to_handle(), moab::copy_set_contents(), dataBuffer, dbgOut, moab::ReadHDF5Dataset::done(), moab::Range::end(), ErrorCode, fileInfo, moab::GeomUtil::first(), moab::ReadHDF5Dataset::get_debug_desc(), handleType, moab::Range::insert(), MB_CHK_ERR, MB_INDEX_OUT_OF_RANGE, MB_SET_ERR, MB_SUCCESS, mhdf_SET_RANGE_BIT, moab(), moab::ReadHDF5Dataset::null_read(), PARENT, moab::DebugOutput::printf(), moab::ReadHDF5Dataset::read(), moab::ReadHDF5Dataset::set_file_ids(), setMeta, mhdf_FileDesc::sets, moab::Range::size(), and mhdf_EntDesc::start_id.
Referenced by get_set_contents(), read_set_ids_recursive(), and read_sets().
    ErrorCode rval;
    Range::const_pair_iterator pi;
    Range::iterator out_hint;
    if( file_ids_out ) out_hint = file_ids_out->begin();
    // Construct range of offsets into data table at which to read
    // Note: all offsets are incremented by TWEAK because Range cannot
    // store zeros.
    const long TWEAK = 1;
    Range data_offsets;
    Range::iterator hint = data_offsets.begin();
    pi                   = set_file_ids.const_pair_begin();
    if( (long)pi->first == fileInfo->sets.start_id )
        long second = pi->second - fileInfo->sets.start_id;
        if( setMeta[second][mode] >= 0 ) hint = data_offsets.insert( hint, TWEAK, setMeta[second][mode] + TWEAK );
        ++pi;
    for( ; pi != set_file_ids.const_pair_end(); ++pi )
        long first  = pi->first - fileInfo->sets.start_id;
        long idx1   = setMeta[first - 1][mode] + 1;
        long idx2   = setMeta[second][mode];
        if( idx2 >= idx1 ) hint = data_offsets.insert( hint, idx1 + TWEAK, idx2 + TWEAK );
    try
        data.set_file_ids( data_offsets, TWEAK, bufferSize / sizeof( EntityHandle ), handleType );
        return MB_FAILURE;
    // We need to increment this for each processed set because
    // the sets were created in the order of the ids in file_ids.
    EntityHandle h = start_handle;
    const long ranged_flag = ( mode == CONTENT ) ? mhdf_SET_RANGE_BIT : 0;
    std::vector< EntityHandle > partial;  // For when we read only part of the contents of a set/entity
    Range::const_iterator fileid_iter = set_file_ids.begin();
    size_t count, offset;
    int nn = 0;
    #ifdef  MOAB_HAVE_MPI
      if (nativeParallel && mode==CONTENT && myPcomm->proc_config().proc_size()>1 &&
    data_offsets.empty())
        MB_SET_ERR_CONT( "ReadHDF5 Failure: Attempt reading an empty dataset on proc " <<
            myPcomm->proc_config().proc_rank());
        MPI_Abort(myPcomm->proc_config().proc_comm(), 1);
    #endif
    if( ( 1 >= set_file_ids.size() ) && ( data.done() ) && moab::ReadHDF5::CONTENT == mode )
        // do at least one null read, it is needed in parallel
        data.null_read();
    while( !data.done() )
        dbgOut.printf( 3, "Reading chunk %d of %s\n", ++nn, data.get_debug_desc() );
        try
            data.read( buffer, count );
            return MB_FAILURE;
        // Assert not appropriate here - I might have treated all my file ids, but maybe
        // another proc hasn't; for me, count will be zero, so I won't do anything, but
        // I still need to go through the motions to make the read work
        // Handle 'special' case where we read some, but not all
        // of the data for an entity during the last iteration.
        offset = 0;
        if( !partial.empty() )
        {  // Didn't read all of previous entity
            assert( fileid_iter != set_file_ids.end() );
            size_t num_prev = partial.size();
            size_t idx      = *fileid_iter - fileInfo->sets.start_id;
            size_t len      = idx ? setMeta[idx][mode] - setMeta[idx - 1][mode] : setMeta[idx][mode] + 1;
            offset          = len - num_prev;
            if( offset > count )
            {  // Still don't have all
                partial.insert( partial.end(), buffer, buffer + count );
                continue;
            partial.insert( partial.end(), buffer, buffer + offset );
            if( file_ids_out )
                out_hint = copy_set_contents( out_hint, setMeta[idx][3] & ranged_flag, &partial[0], partial.size(),
                                              *file_ids_out );
            else
                switch( mode )
                    size_t valid;
                    case CONTENT:
                        if( setMeta[idx][3] & ranged_flag )
                            if( len % 2 ) MB_CHK_ERR( MB_INDEX_OUT_OF_RANGE );
                            Range range;
                            convert_range_to_handle( &partial[0], len / 2, range );
                            rval = moab()->add_entities( h, range );
                        else
                            convert_id_to_handle( &partial[0], len, valid );
                            rval = moab()->add_entities( h, &partial[0], valid );
                        break;
                    case CHILD:
                        rval = moab()->add_child_meshsets( h, &partial[0], valid );
                        break;
                    case PARENT:
                        rval = moab()->add_parent_meshsets( h, &partial[0], valid );
                        break;
                    default:
                        break;
            ++fileid_iter;
            ++h;
            partial.clear();
        // Process contents for all entities for which we
        // have read the complete list
        while( offset < count )
            // If we did not read all of the final entity,
            // store what we did read to be processed in the
            // next iteration
            if( offset + len > count )
                partial.insert( partial.end(), buffer + offset, buffer + count );
                break;
            if( file_ids_out )
                out_hint =
                    copy_set_contents( out_hint, setMeta[idx][3] & ranged_flag, buffer + offset, len, *file_ids_out );
            else
                switch( mode )
                    size_t valid;
                    case CONTENT:
                            Range range;
                            convert_range_to_handle( buffer + offset, len / 2, range );
                        else
                            convert_id_to_handle( buffer + offset, len, valid );
                            rval = moab()->add_entities( h, buffer + offset, valid );
                        break;
                    case CHILD:
                        rval = moab()->add_child_meshsets( h, buffer + offset, valid );
                        break;
                    case PARENT:
                        rval = moab()->add_parent_meshsets( h, buffer + offset, valid );
                        break;
                    default:
                        break;
            ++fileid_iter;
            ++h;
            offset += len;
    return MB_SUCCESS;
ErrorCode moab::ReadHDF5::read_set_ids_recursive ( Range &  sets_in_out,
bool  containted_sets,
bool  child_sets
) [private]
Given a list of file IDs for entity sets, find all contained or child sets (at any depth) and append them to the Range of file IDs.
Definition at line 2050 of file ReadHDF5.cpp.
References moab::Range::begin(), CHECK_OPEN_HANDLES, child, CHILD, children, moab::Range::clear(), CONTENT, mhdf_EntDesc::count, dbgOut, moab::Range::empty(), moab::Range::end(), moab::Range::erase(), ErrorCode, fileInfo, filePtr, mhdf_FileDesc::have_set_children, mhdf_FileDesc::have_set_contents, moab::ReadHDF5Dataset::init(), is_error(), moab::Range::lower_bound(), MB_SET_ERR, MB_SUCCESS, moab::Range::merge(), mhdf_openSetChildren(), mhdf_openSetData(), mpiComm, moab::DebugOutput::print_ints(), read_set_data(), mhdf_FileDesc::sets, mhdf_EntDesc::start_id, moab::subtract(), and moab::DebugOutput::tprintf().
Referenced by load_file_partial().
    CHECK_OPEN_HANDLES;
    mhdf_Status status;
    if( !fileInfo->have_set_children ) child_sets = false;
    if( !fileInfo->have_set_contents ) contained_sets = false;
    if( !child_sets && !contained_sets ) return MB_SUCCESS;
    // Open data tables
    if( fileInfo->sets.count == 0 )
        assert( sets_in_out.empty() );
        return MB_SUCCESS;
    if( !contained_sets && !child_sets ) return MB_SUCCESS;
    ReadHDF5Dataset cont( "set contents", false, mpiComm );
    ReadHDF5Dataset child( "set children", false, mpiComm );
    if( contained_sets )
        long content_len     = 0;
        hid_t content_handle = mhdf_openSetData( filePtr, &content_len, &status );
        if( is_error( status ) ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" );
        try
            cont.init( content_handle, true );
    if( child_sets )
        long child_len     = 0;
        hid_t child_handle = mhdf_openSetChildren( filePtr, &child_len, &status );
        try
            child.init( child_handle, true );
    Range children, new_children( sets_in_out );
    int iteration_count = 0;
    do
        ++iteration_count;
        dbgOut.tprintf( 2, "Iteration %d of read_set_ids_recursive\n", iteration_count );
        children.clear();
        if( child_sets )
            rval = read_set_data( new_children, 0, child, CHILD, &children );
            if( MB_SUCCESS != rval ) break;
            rval = read_set_data( new_children, 0, cont, CONTENT, &children );
            // Remove any non-set values
            Range::iterator it = children.lower_bound( fileInfo->sets.start_id );
            children.erase( children.begin(), it );
            it = children.lower_bound( fileInfo->sets.start_id + fileInfo->sets.count );
            children.erase( it, children.end() );
        new_children = subtract( children, sets_in_out );
        dbgOut.print_ints( 2, "Adding additional contained/child sets", new_children );
        sets_in_out.merge( new_children );
    } while( !new_children.empty() );
    return MB_SUCCESS;
ErrorCode moab::ReadHDF5::read_sets ( const Range &  set_file_ids) [private]
Read sets.
Definition at line 1915 of file ReadHDF5.cpp.
References moab::Range::begin(), CHECK_OPEN_HANDLES, CHILD, CONTENT, mhdf_EntDesc::count, moab::ReadUtilIface::create_entity_sets(), debug_barrier, moab::Range::empty(), ErrorCode, fileInfo, filePtr, mhdf_FileDesc::have_set_children, mhdf_FileDesc::have_set_contents, mhdf_FileDesc::have_set_parents, insert_in_id_map(), is_error(), MB_SET_ERR, MB_SUCCESS, mhdf_openSetChildren(), mhdf_openSetData(), mhdf_openSetParents(), mhdf_SET_RANGE_BIT, mpiComm, nativeParallel, PARENT, read_set_data(), readUtil, setMeta, mhdf_FileDesc::sets, moab::Range::size(), and mhdf_EntDesc::start_id.
    CHECK_OPEN_HANDLES;
    debug_barrier();
    mhdf_Status status;
    ErrorCode rval;
    const size_t num_sets = fileInfo->sets.count;
    if( !num_sets )  // If no sets at all!
        return MB_SUCCESS;
    // Create sets
    std::vector< unsigned > flags( file_ids.size() );
    Range::iterator si = file_ids.begin();
    for( size_t i = 0; i < flags.size(); ++i, ++si )
        flags[i] = setMeta[*si - fileInfo->sets.start_id][3] & ~(long)mhdf_SET_RANGE_BIT;
    EntityHandle start_handle;
    // the files ids could be empty, for empty partitions
    if( !file_ids.empty() )
        rval = readUtil->create_entity_sets( flags.size(), &flags[0], 0, start_handle );
        rval = insert_in_id_map( file_ids, start_handle );
    // Read contents
    if( fileInfo->have_set_contents )
        long len     = 0;
        hid_t handle = mhdf_openSetData( filePtr, &len, &status );
        ReadHDF5Dataset dat( "set contents", handle, nativeParallel, mpiComm, true );
        rval = read_set_data( file_ids, start_handle, dat, CONTENT );
    // Read set child lists
    if( fileInfo->have_set_children )
        long len     = 0;
        hid_t handle = mhdf_openSetChildren( filePtr, &len, &status );
        ReadHDF5Dataset dat( "set children", handle, nativeParallel, mpiComm, true );
        rval = read_set_data( file_ids, start_handle, dat, CHILD );
    // Read set parent lists
    if( fileInfo->have_set_parents )
        long len     = 0;
        hid_t handle = mhdf_openSetParents( filePtr, &len, &status );
        ReadHDF5Dataset dat( "set parents", handle, nativeParallel, mpiComm, true );
        rval = read_set_data( file_ids, start_handle, dat, PARENT );
    return MB_SUCCESS;
ErrorCode moab::ReadHDF5::read_sets_partial ( const Range &  sets_in) [private]
Read sets from file into MOAB for partial read of file.
Given the file IDs for entity sets (sets_in) and elements and nodes (id_map), read in all sets containing any of the elements or nodes and all sets that are (recursively) children of any other set to be read (those in sets_in or those containing any already-read element or node.)
Parameters:
sets_inFile IDs for sets to read (unconditionally)
ErrorCode moab::ReadHDF5::read_sparse_tag ( Tag  tag_handle,
hid_t  hdf_read_type,
hid_t  ent_table,
hid_t  val_table,
long  num_entities
) [private]
Read sparse tag for all entities.
Definition at line 3243 of file ReadHDF5.cpp.
References bufferSize, CHECK_OPEN_HANDLES, convert_id_to_handle(), dataBuffer, dbgOut, moab::ReadHDF5Dataset::done(), ErrorCode, moab::ReadHDF5Dataset::get_read_count(), iFace, MB_SET_ERR, MB_SUCCESS, MB_TYPE_HANDLE, moab::Range::merge(), mpiComm, nativeParallel, moab::DebugOutput::printf(), moab::ReadHDF5Dataset::read(), read_sparse_tag_indices(), moab::ReadHDF5Dataset::set_file_ids(), moab::Interface::tag_get_bytes(), moab::Interface::tag_get_data_type(), moab::Interface::tag_get_name(), and moab::Interface::tag_set_data().
Referenced by read_tag().
    CHECK_OPEN_HANDLES;
    // Read entire ID table and for those file IDs corresponding
    // to entities that we have read from the file add both the
    // offset into the offset range and the handle into the handle
    // range.  If handles are not ordered, switch to using a vector.
    const EntityHandle base_offset = 1;  // Can't put zero in a Range
    std::vector< EntityHandle > handle_vect;
    Range handle_range, offset_range;
    ErrorCode rval =
        read_sparse_tag_indices( tn.c_str(), id_table, base_offset, offset_range, handle_range, handle_vect );
    if( MB_SUCCESS != rval ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" );
    DataType mbtype;
    rval = iFace->tag_get_data_type( tag_handle, mbtype );
    int read_size;
    // if (MB_TYPE_BIT == mbtype)
    if( hdf_read_type )
    {  // If not opaque
    const int handles_per_tag = read_size / sizeof( EntityHandle );
    // Now read data values
    size_t chunk_size = bufferSize / read_size;
    try
        ReadHDF5Dataset val_reader( ( tn + " values" ).c_str(), value_table, nativeParallel, mpiComm, false );
        val_reader.set_file_ids( offset_range, base_offset, chunk_size, hdf_read_type );
        dbgOut.printf( 3, "Reading sparse values for tag \"%s\" in %lu chunks\n", tn.c_str(),
                       val_reader.get_read_count() );
        int nn        = 0;
        size_t offset = 0;
        while( !val_reader.done() )
            dbgOut.printf( 3, "Reading chunk %d of \"%s\" values\n", ++nn, tn.c_str() );
            size_t count;
            val_reader.read( dataBuffer, count );
            if( MB_TYPE_HANDLE == mbtype )
                rval = convert_id_to_handle( (EntityHandle*)dataBuffer, count * handles_per_tag );
            if( !handle_vect.empty() )
                rval = iFace->tag_set_data( tag_handle, &handle_vect[offset], count, dataBuffer );
                offset += count;
            else
                Range r;
                r.merge( handle_range.begin(), handle_range.begin() + count );
                handle_range.erase( handle_range.begin(), handle_range.begin() + count );
                rval = iFace->tag_set_data( tag_handle, r, dataBuffer );
    catch( ReadHDF5Dataset::Exception )
    return MB_SUCCESS;
ErrorCode moab::ReadHDF5::read_sparse_tag_indices ( const char *  name,
hid_t  id_table,
EntityHandle  start_offset,
Range &  offset_range,
Range &  handle_range,
std::vector< EntityHandle > &  handle_vect
) [private]
Read index table for sparse tag.
Read ID table for a sparse or variable-length tag, returning the handles and offsets within the table for each file ID that corresponds to an entity we've read from the file (an entity that is in idMap).
Parameters:
id_tableThe MOAB handle for the tag
start_offsetSome non-zero value because ranges (in this case the offset_range) cannot contain zeros.
offset_rangeOutput: The offsets in the id table for which IDs that occur in idMap were found. All values are increased by start_offset to avoid putting zeros in the range.
handle_rangeOutput: For each valid ID read from the table, the corresponding entity handle. Note: if the IDs did not occur in handle order, then this will be empty. Use handle_vect instead.
handle_vectOutput: For each valid ID read from the table, the corresponding entity handle. Note: if the IDs occurred in handle order, then this will be empty. Use handle_range instead.
Definition at line 3165 of file ReadHDF5.cpp.
References moab::Range::back(), moab::Range::begin(), bufferSize, CHECK_OPEN_HANDLES, moab::Range::clear(), convert_id_to_handle(), dataBuffer, dbgOut, moab::Range::empty(), moab::Range::end(), ErrorCode, handleType, moab::Range::insert(), MB_SET_ERR, MB_SUCCESS, mpiComm, nativeParallel, moab::DebugOutput::print(), moab::DebugOutput::printf(), moab::ReadHDF5Dataset::set_all_file_ids(), and moab::Range::size().
Referenced by read_sparse_tag(), and read_var_len_tag().
    CHECK_OPEN_HANDLES;
    offset_range.clear();
    handle_range.clear();
    handle_vect.clear();
    ErrorCode rval;
    Range::iterator handle_hint = handle_range.begin();
    Range::iterator offset_hint = offset_range.begin();
    EntityHandle* idbuf = (EntityHandle*)dataBuffer;
    size_t idbuf_size   = bufferSize / sizeof( EntityHandle );
    std::string tn( name );
    tn += " indices";
    assert( start_offset > 0 );  // Can't put zero in a Range
    try
        ReadHDF5Dataset id_reader( tn.c_str(), id_table, nativeParallel, mpiComm, false );
        id_reader.set_all_file_ids( idbuf_size, handleType );
        size_t offset = start_offset;
        dbgOut.printf( 3, "Reading file ids for sparse tag \"%s\" in %lu chunks\n", name, id_reader.get_read_count() );
        int nn = 0;
        while( !id_reader.done() )
            dbgOut.printf( 3, "Reading chunk %d of \"%s\" IDs\n", ++nn, name );
            size_t count;
            id_reader.read( idbuf, count );
            rval = convert_id_to_handle( idbuf, count );
            // idbuf will now contain zero-valued handles for those
            // tag values that correspond to entities we are not reading
            // from the file.
                if( idbuf[i] )
                    offset_hint = offset_range.insert( offset_hint, offset + i );
                        handle_vect.push_back( idbuf[i] );
                    else if( handle_range.empty() || idbuf[i] > handle_range.back() )
                        handle_hint = handle_range.insert( handle_hint, idbuf[i] );
                    else
                        handle_vect.resize( handle_range.size() );
                        std::copy( handle_range.begin(), handle_range.end(), handle_vect.begin() );
                        dbgOut.print( 2, "Switching to unordered list for tag handle list\n" );
            offset += count;
    return MB_SUCCESS;
ErrorCode moab::ReadHDF5::read_tag ( int  index) [private]
Create tag and read all data.
Definition at line 2718 of file ReadHDF5.cpp.
References CHECK_OPEN_HANDLES, mhdf_EntDesc::count, create_tag(), dbgOut, debug_barrier, mhdf_TagDesc::dense_elem_indices, mhdf_ElemDesc::desc, mhdf_FileDesc::elems, ErrorCode, fileInfo, filePtr, mhdf_ElemDesc::handle, mhdf_TagDesc::have_sparse, is_error(), MB_SET_ERR, MB_SUCCESS, mhdf_closeData(), mhdf_node_type_handle(), mhdf_openDenseTagData(), mhdf_openSparseTagData(), mhdf_set_type_handle(), mhdf_TagDesc::name, mhdf_FileDesc::nodes, mhdf_TagDesc::num_dense_indices, moab::DebugOutput::printf(), read_dense_tag(), read_sparse_tag(), read_var_len_tag(), mhdf_FileDesc::sets, mhdf_TagDesc::size, mhdf_EntDesc::start_id, mhdf_FileDesc::tags, and moab::DebugOutput::tprintf().
    CHECK_OPEN_HANDLES;
    dbgOut.tprintf( 2, "Reading tag \"%s\"\n", fileInfo->tags[tag_index].name );
    debug_barrier();
    ErrorCode rval;
    mhdf_Status status;
    Tag tag         = 0;
    hid_t read_type = -1;
    bool table_type;
    rval = create_tag( fileInfo->tags[tag_index], tag, read_type );
    if( fileInfo->tags[tag_index].have_sparse )
        hid_t handles[3];
        long num_ent, num_val;
        mhdf_openSparseTagData( filePtr, fileInfo->tags[tag_index].name, &num_ent, &num_val, handles, &status );
            if( read_type ) H5Tclose( read_type );
        table_type = false;
        if( read_type == 0 )
            read_type = H5Dget_type( handles[1] );
                mhdf_closeData( filePtr, handles[0], &status );
                if( fileInfo->tags[tag_index].size <= 0 ) mhdf_closeData( filePtr, handles[2], &status );
            table_type = true;
        if( fileInfo->tags[tag_index].size > 0 )
            dbgOut.printf( 2, "Reading sparse data for tag \"%s\"\n", fileInfo->tags[tag_index].name );
            rval = read_sparse_tag( tag, read_type, handles[0], handles[1], num_ent );
        else
            dbgOut.printf( 2, "Reading var-len sparse data for tag \"%s\"\n", fileInfo->tags[tag_index].name );
            rval = read_var_len_tag( tag, read_type, handles[0], handles[1], handles[2], num_ent, num_val );
        if( table_type )
            read_type = 0;
        if( MB_SUCCESS == rval && is_error( status ) ) rval = MB_FAILURE;
        mhdf_closeData( filePtr, handles[1], &status );
    for( int j = 0; j < fileInfo->tags[tag_index].num_dense_indices; ++j )
        long count;
        const char* name = 0;
        mhdf_EntDesc* desc;
        int elem_idx = fileInfo->tags[tag_index].dense_elem_indices[j];
        if( elem_idx == -2 )
            desc = &fileInfo->sets;
            name = mhdf_set_type_handle();
        else if( elem_idx == -1 )
            desc = &fileInfo->nodes;
            name = mhdf_node_type_handle();
        else if( elem_idx >= 0 && elem_idx < fileInfo->num_elem_desc )
            desc = &fileInfo->elems[elem_idx].desc;
            name = fileInfo->elems[elem_idx].handle;
        else
        dbgOut.printf( 2, "Read dense data block for tag \"%s\" on \"%s\"\n", fileInfo->tags[tag_index].name, name );
        hid_t handle = mhdf_openDenseTagData( filePtr, fileInfo->tags[tag_index].name, name, &count, &status );
            rval = MB_FAILURE;  // rval = error(MB_FAILURE);
            break;
        if( count > desc->count )
                        "Invalid data length for dense tag data: " << name << "/" << fileInfo->tags[tag_index].name );
        table_type = false;
            read_type = H5Dget_type( handle );
            table_type = true;
        rval = read_dense_tag( tag, name, read_type, handle, desc->start_id, count );
        if( table_type )
            read_type = 0;
            rval = MB_FAILURE;
            break;
    return rval;
ErrorCode moab::ReadHDF5::read_tag_values ( const char *  file_name,
const char *  tag_name,
const FileOptions &  opts,
std::vector< int > &  tag_values_out,
const SubsetList *  subset_list = 0
) [virtual]
Read tag values from a file.
Read the list if all integer tag values from the file for a tag that is a single integer value per entity.
Parameters:
file_nameThe file to read.
tag_nameThe tag for which to read values
tag_values_outOutput: The list of tag values.
subset_listAn array of tag name and value sets specifying the subset of the file to read. If multiple tags are specified, the sets that match all tags (intersection) should be read.
subset_list_lengthThe length of the 'subset_list' array.
Implements moab::ReaderIface.
Definition at line 3655 of file ReadHDF5.cpp.
References clean_up_read(), ErrorCode, find_int_tag(), get_subset_ids(), MB_SET_ERR, MB_SUCCESS, read_tag_values_all(), read_tag_values_partial(), set_up_read(), moab::ReaderIface::SubsetList::tag_list, and moab::ReaderIface::SubsetList::tag_list_length.
Referenced by test_read_ids(), and test_read_partial_ids().
    ErrorCode rval;
    rval = set_up_read( file_name, opts );
    int tag_index;
    rval = find_int_tag( tag_name, tag_index );
        clean_up_read( opts );
    if( subset_list )
        Range file_ids;
        rval = get_subset_ids( subset_list->tag_list, subset_list->tag_list_length, file_ids );
        rval = read_tag_values_partial( tag_index, file_ids, tag_values_out );
    else
        rval = read_tag_values_all( tag_index, tag_values_out );
    return clean_up_read( opts );
ErrorCode moab::ReadHDF5::read_tag_values_all ( int  tag_index,
std::vector< int > &  results
) [protected]
Definition at line 3856 of file ReadHDF5.cpp.
References CHECK_OPEN_HANDLES, collIO, mhdf_TagDesc::dense_elem_indices, mhdf_FileDesc::elems, fileInfo, filePtr, mhdf_ElemDesc::handle, mhdf_TagDesc::have_sparse, MB_SET_ERR, MB_SET_ERR_CONT, MB_SUCCESS, mhdf_closeData(), mhdf_isError(), mhdf_message(), mhdf_node_type_handle(), mhdf_openDenseTagData(), mhdf_openSparseTagData(), mhdf_readTagValuesWithOpt(), mhdf_set_type_handle(), mhdf_TagDesc::name, mhdf_TagDesc::num_dense_indices, and mhdf_FileDesc::tags.
Referenced by read_tag_values().
    CHECK_OPEN_HANDLES;
    mhdf_Status status;
    const mhdf_TagDesc& tag = fileInfo->tags[tag_index];
    long junk, num_val;
    // Read sparse values
    if( tag.have_sparse )
        hid_t handles[3];
        mhdf_openSparseTagData( filePtr, tag.name, &junk, &num_val, handles, &status );
            MB_SET_ERR_CONT( mhdf_message( &status ) );
        hid_t file_type = H5Dget_type( handles[1] );
        tag_values.resize( num_val );
        mhdf_readTagValuesWithOpt( handles[1], 0, num_val, file_type, &tag_values[0], collIO, &status );
            H5Tclose( file_type );
        H5Tconvert( file_type, H5T_NATIVE_INT, num_val, &tag_values[0], 0, H5P_DEFAULT );
    std::sort( tag_values.begin(), tag_values.end() );
    tag_values.erase( std::unique( tag_values.begin(), tag_values.end() ), tag_values.end() );
    // Read dense values
    std::vector< int > prev_data, curr_data;
    for( int i = 0; i < tag.num_dense_indices; ++i )
        int grp           = tag.dense_elem_indices[i];
        const char* gname = 0;
        if( grp == -1 )
            gname = mhdf_node_type_handle();
        else if( grp == -2 )
            gname = mhdf_set_type_handle();
        else
            gname = fileInfo->elems[grp].handle;
        hid_t handle = mhdf_openDenseTagData( filePtr, tag.name, gname, &num_val, &status );
        hid_t file_type = H5Dget_type( handle );
        curr_data.resize( num_val );
        mhdf_readTagValuesWithOpt( handle, 0, num_val, file_type, &curr_data[0], collIO, &status );
        H5Tconvert( file_type, H5T_NATIVE_INT, num_val, &curr_data[0], 0, H5P_DEFAULT );
        std::sort( curr_data.begin(), curr_data.end() );
        curr_data.erase( std::unique( curr_data.begin(), curr_data.end() ), curr_data.end() );
        prev_data.clear();
        tag_values.swap( prev_data );
        std::set_union( prev_data.begin(), prev_data.end(), curr_data.begin(), curr_data.end(),
                        std::back_inserter( tag_values ) );
    return MB_SUCCESS;
ErrorCode moab::ReadHDF5::read_tag_values_partial ( int  tag_index,
const Range &  file_ids,
) [protected]
Definition at line 3704 of file ReadHDF5.cpp.
References moab::Range::begin(), buffer, bufferSize, CHECK_OPEN_HANDLES, mhdf_EntDesc::count, dataBuffer, dbgOut, mhdf_TagDesc::dense_elem_indices, mhdf_ElemDesc::desc, moab::ReadHDF5Dataset::done(), mhdf_FileDesc::elems, moab::Range::end(), fileInfo, filePtr, moab::ReadHDF5Dataset::get_read_count(), mhdf_ElemDesc::handle, mhdf_TagDesc::have_sparse, moab::Range::insert(), moab::Range::lower_bound(), MB_SET_ERR, MB_SUCCESS, moab::Range::merge(), mhdf_isError(), mhdf_message(), mhdf_node_type_handle(), mhdf_openDenseTagData(), mhdf_openSparseTagData(), mhdf_set_type_handle(), mpiComm, mhdf_TagDesc::name, nativeParallel, mhdf_FileDesc::nodes, mhdf_TagDesc::num_dense_indices, moab::DebugOutput::printf(), moab::ReadHDF5Dataset::read(), moab::ReadHDF5Dataset::set_all_file_ids(), moab::ReadHDF5Dataset::set_file_ids(), mhdf_FileDesc::sets, moab::Range::size(), mhdf_EntDesc::start_id, and mhdf_FileDesc::tags.
    CHECK_OPEN_HANDLES;
    mhdf_Status status;
    size_t count;
    std::string tn( tag.name );
        hid_t handles[3];
        mhdf_openSparseTagData( filePtr, tag.name, &num_ent, &num_val, handles, &status );
        try
            // Read all entity handles and fill 'offsets' with ranges of
            // offsets into the data table for entities that we want.
            Range offsets;
            long* buffer           = reinterpret_cast< long* >( dataBuffer );
            const long buffer_size = bufferSize / sizeof( long );
            ReadHDF5Dataset ids( ( tn + " ids" ).c_str(), handles[0], nativeParallel, mpiComm );
            ids.set_all_file_ids( buffer_size, H5T_NATIVE_LONG );
            size_t offset = 0;
            dbgOut.printf( 3, "Reading sparse IDs for tag \"%s\" in %lu chunks\n", tag.name, ids.get_read_count() );
            int nn = 0;
            while( !ids.done() )
                dbgOut.printf( 3, "Reading chunk %d of IDs for \"%s\"\n", ++nn, tag.name );
                ids.read( buffer, count );
                std::sort( buffer, buffer + count );
                Range::iterator ins     = offsets.begin();
                Range::const_iterator i = file_ids.begin();
                for( size_t j = 0; j < count; ++j )
                    while( i != file_ids.end() && (long)*i < buffer[j] )
                        ++i;
                    if( i == file_ids.end() ) break;
                    if( (long)*i == buffer[j] )
                        ins = offsets.insert( ins, j + offset, j + offset );
                offset += count;
            tag_values.clear();
            tag_values.reserve( offsets.size() );
            const size_t data_buffer_size = bufferSize / sizeof( int );
            int* data_buffer              = reinterpret_cast< int* >( dataBuffer );
            ReadHDF5Dataset vals( ( tn + " sparse vals" ).c_str(), handles[1], nativeParallel, mpiComm );
            vals.set_file_ids( offsets, 0, data_buffer_size, H5T_NATIVE_INT );
            dbgOut.printf( 3, "Reading sparse values for tag \"%s\" in %lu chunks\n", tag.name, vals.get_read_count() );
            nn = 0;
            while( !vals.done() )
                dbgOut.printf( 3, "Reading chunk %d of values for \"%s\"\n", ++nn, tag.name );
                vals.read( data_buffer, count );
                tag_values.insert( tag_values.end(), data_buffer, data_buffer + count );
        mhdf_EntDesc* desc = 0;
        if( grp == -1 )
        else
            assert( grp >= 0 && grp < fileInfo->num_elem_desc );
            desc  = &fileInfo->elems[grp].desc;
        Range::iterator s = file_ids.lower_bound( (EntityHandle)( desc->start_id ) );
        Range::iterator e = Range::lower_bound( s, file_ids.end(), (EntityHandle)( desc->start_id ) + desc->count );
        Range subset;
        subset.merge( s, e );
        try
            curr_data.clear();
            tag_values.reserve( subset.size() );
            ReadHDF5Dataset reader( ( tn + " dense vals" ).c_str(), handle, nativeParallel, mpiComm );
            reader.set_file_ids( subset, desc->start_id, data_buffer_size, H5T_NATIVE_INT );
            dbgOut.printf( 3, "Reading dense data for tag \"%s\" and group \"%s\" in %lu chunks\n", tag.name,
                           fileInfo->elems[grp].handle, reader.get_read_count() );
            int nn = 0;
                dbgOut.printf( 3, "Reading chunk %d of \"%s\"/\"%s\"\n", ++nn, tag.name, fileInfo->elems[grp].handle );
                reader.read( data_buffer, count );
                curr_data.insert( curr_data.end(), data_buffer, data_buffer + count );
        prev_data.clear();
    return MB_SUCCESS;
ErrorCode moab::ReadHDF5::read_var_len_tag ( Tag  tag_handle,
hid_t  ent_table,
hid_t  val_table,
hid_t  off_table,
long  num_entities,
long  num_values
) [private]
Read variable-length tag for all entities.
Definition at line 3327 of file ReadHDF5.cpp.
References buffer, bufferSize, CHECK_OPEN_HANDLES, dataBuffer, dbgOut, ErrorCode, iFace, MB_CHK_ERR, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, MB_TYPE_BIT, MB_TYPE_HANDLE, MB_VARIABLE_DATA_LENGTH, mpiComm, nativeParallel, read_sparse_tag_indices(), moab::Interface::tag_get_bytes(), moab::Interface::tag_get_data_type(), and moab::Interface::tag_get_name().
    CHECK_OPEN_HANDLES;
    ErrorCode rval;
    DataType mbtype;
    // Can't do variable-length bit tags
    if( MB_TYPE_BIT == mbtype ) MB_CHK_ERR( MB_VARIABLE_DATA_LENGTH );
    // If here, MOAB tag must be variable-length
    int mbsize;
    if( MB_VARIABLE_DATA_LENGTH != iFace->tag_get_bytes( tag_handle, mbsize ) )
        assert( false );MB_CHK_ERR( MB_VARIABLE_DATA_LENGTH );
    int read_size;
    if( hdf_read_type )
        if( hdf_size < 1 ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" );
        read_size = hdf_size;
    else
        // Opaque
        read_size = 1;
    rval = read_sparse_tag_indices( tn.c_str(), ent_table, base_offset, offset_range, handle_range, handle_vect );
    // This code only works if the id_table is an ordered list.
    // This assumption was also true for the previous iteration
    // of this code, but wasn't checked. MOAB's file writer
    // always writes an ordered list for id_table.
        MB_SET_ERR( MB_FAILURE, "Unordered file ids for variable length tag not supported" );
    class VTReader : public ReadHDF5VarLen
        Tag tagHandle;
        bool isHandle;
        size_t readSize;
        ReadHDF5* readHDF5;
      public:
        ErrorCode store_data( EntityHandle file_id, void* data, long count, bool )
            ErrorCode rval1;
            if( isHandle )
                if( readSize != sizeof( EntityHandle ) ) MB_CHK_SET_ERR( MB_FAILURE, "Invalid read size" );
                rval1 = readHDF5->convert_id_to_handle( (EntityHandle*)data, count );MB_CHK_ERR( rval1 );
            int n = count;
            return readHDF5->moab()->tag_set_by_ptr( tagHandle, &file_id, 1, &data, &n );
        VTReader( DebugOutput& debug_output,
                  void* buffer,
                  size_t buffer_size,
                  Tag tag,
                  bool is_handle_tag,
                  size_t read_size1,
                  ReadHDF5* owner )
            : ReadHDF5VarLen( debug_output, buffer, buffer_size ), tagHandle( tag ), isHandle( is_handle_tag ),
              readSize( read_size1 ), readHDF5( owner )
    VTReader tool( dbgOut, dataBuffer, bufferSize, tag_handle, MB_TYPE_HANDLE == mbtype, read_size, this );
    try
        // Read offsets into value table.
        std::vector< unsigned > counts;
        Range offsets;
        ReadHDF5Dataset off_reader( ( tn + " offsets" ).c_str(), off_table, nativeParallel, mpiComm, false );
        rval = tool.read_offsets( off_reader, offset_range, base_offset, base_offset, offsets, counts );
        // Read tag values
        Range empty;
        ReadHDF5Dataset val_reader( ( tn + " values" ).c_str(), val_table, nativeParallel, mpiComm, false );
        rval = tool.read_data( val_reader, offsets, base_offset, hdf_read_type, handle_range, counts, empty );
    return MB_SUCCESS;
ErrorCode moab::ReadHDF5::search_tag_values ( int  tag_index,
const std::vector< int > &  sorted_values,
Range &  file_ids_out,
bool  sets_only = false
) [private]
Search for entities with specified tag values.
For parallel reads, this function does collective IO.
Parameters:
tag_indexIndex into info->tags specifying which tag to search.
sorted_valuesList of tag values to check for, in ascending sorted order.
file_ids_outFile IDs for entities with specified tag values.
Definition at line 1162 of file ReadHDF5.cpp.
References CHECK_OPEN_HANDLES, moab::copy_sorted_file_ids(), mhdf_EntDesc::count, debug_barrier, mhdf_TagDesc::dense_elem_indices, mhdf_ElemDesc::desc, mhdf_FileDesc::elems, ErrorCode, fileInfo, filePtr, mhdf_ElemDesc::handle, handleType, mhdf_TagDesc::have_sparse, indepIO, is_error(), MB_SET_ERR, MB_SUCCESS, mhdf_closeData(), mhdf_node_type_handle(), mhdf_openDenseTagData(), mhdf_openSparseTagData(), mhdf_readSparseTagEntitiesWithOpt(), mhdf_set_type_handle(), mhdf_TagDesc::name, mhdf_FileDesc::nodes, mhdf_TagDesc::num_dense_indices, mhdf_FileDesc::num_elem_desc, mhdf_FileDesc::sets, size, mhdf_EntDesc::start_id, and mhdf_FileDesc::tags.
Referenced by get_subset_ids().
    ErrorCode rval;
    mhdf_Status status;
    std::vector< EntityHandle >::iterator iter;
    long size;
    long start_id;
    CHECK_OPEN_HANDLES;
    debug_barrier();
    // Do dense data
    hid_t table;
    const char* name;
    std::vector< EntityHandle > indices;
    // These are probably in order of dimension, so iterate
    // in reverse order to make Range insertions more efficient.
    std::vector< int > grp_indices( tag.dense_elem_indices, tag.dense_elem_indices + tag.num_dense_indices );
    for( std::vector< int >::reverse_iterator i = grp_indices.rbegin(); i != grp_indices.rend(); ++i )
        int idx = *i;
        if( idx == -2 )
            start_id = fileInfo->sets.start_id;
        else if( sets_only )
            continue;
        else if( idx == -1 )
            start_id = fileInfo->nodes.start_id;
        else
            if( idx < 0 || idx >= fileInfo->num_elem_desc ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" );
            name     = fileInfo->elems[idx].handle;
            start_id = fileInfo->elems[idx].desc.start_id;
        table = mhdf_openDenseTagData( filePtr, tag.name, name, &size, &status );
        rval = search_tag_values( table, size, sorted_values, indices );
        mhdf_closeData( filePtr, table, &status );
        if( MB_SUCCESS != rval || is_error( status ) ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" );
        // Convert from table indices to file IDs and add to result list
        std::sort( indices.begin(), indices.end(), std::greater< EntityHandle >() );
        std::transform( indices.begin(), indices.end(), range_inserter( file_ids ),
                        // std::bind1st(std::plus<long>(), start_id));
                        std::bind( std::plus< long >(), start_id, std::placeholders::_1 ) );
        indices.clear();
    if( !tag.have_sparse ) return MB_SUCCESS;
    // Do sparse data
    hid_t tables[2];
    long junk;  // Redundant value for non-variable-length tags
    mhdf_openSparseTagData( filePtr, tag.name, &size, &junk, tables, &status );
    rval = search_tag_values( tables[1], size, sorted_values, indices );
    mhdf_closeData( filePtr, tables[1], &status );
        mhdf_closeData( filePtr, tables[0], &status );
    // Convert to ranges
    std::sort( indices.begin(), indices.end() );
    std::vector< EntityHandle > ranges;
    iter = indices.begin();
    while( iter != indices.end() )
        ranges.push_back( *iter );
        EntityHandle last = *iter;
        for( ++iter; iter != indices.end() && ( last + 1 ) == *iter; ++iter, ++last )
        ranges.push_back( last );
    // Read file ids
    iter                 = ranges.begin();
    unsigned long offset = 0;
    while( iter != ranges.end() )
        long begin = *iter;
        ++iter;
        long end = *iter;
        ++iter;
        mhdf_readSparseTagEntitiesWithOpt( tables[0], begin, end - begin + 1, handleType, &indices[offset], indepIO,
                                           &status );
        offset += end - begin + 1;
    assert( offset == indices.size() );
    if( sets_only )
        iter = std::lower_bound( indices.begin(), indices.end(),
                                 (EntityHandle)( fileInfo->sets.start_id + fileInfo->sets.count ) );
        indices.erase( iter, indices.end() );
        iter = std::lower_bound( indices.begin(), indices.end(), fileInfo->sets.start_id );
        indices.erase( indices.begin(), iter );
    copy_sorted_file_ids( &indices[0], indices.size(), file_ids );
    return MB_SUCCESS;
ErrorCode moab::ReadHDF5::search_tag_values ( hid_t  tag_table,
unsigned long  table_size,
std::vector< EntityHandle > &  value_indices
) [private]
Search a table of tag data for a specified set of values.
Search a table of tag values, returning the indices into the table at which matches were found. For parallel reads, this function does collective IO.
Parameters:
infoSummary of data contained in file.
tag_tableHDF5/mhdf handle for tag values
table_sizeNumber of values in table
sorted_valuesSorted list of values to search for.
value_indicesOutput: Offsets into the table of data at which matching values were found.
Definition at line 1362 of file ReadHDF5.cpp.
References assert_range, buffer, bufferSize, CHECK_OPEN_HANDLES, collIO, dataBuffer, debug_barrier, is_error(), MB_SET_ERR, MB_SUCCESS, and mhdf_readTagValuesWithOpt().
    debug_barrier();
    CHECK_OPEN_HANDLES;
    mhdf_Status status;
    size_t chunk_size = bufferSize / sizeof( int );
    int* buffer       = reinterpret_cast< int* >( dataBuffer );
    size_t remaining = table_size, offset = 0;
    while( remaining )
        // Get a block of tag values
        assert_range( buffer, count );
        mhdf_readTagValuesWithOpt( tag_table, offset, count, H5T_NATIVE_INT, buffer, collIO, &status );
        // Search tag values
            if( std::binary_search( sorted_values.begin(), sorted_values.end(), (int)buffer[i] ) )
                value_indices.push_back( i + offset );
        offset += count;
        remaining -= count;
    return MB_SUCCESS;
ErrorCode moab::ReadHDF5::set_up_read ( const char *  file_name,
) [private]
Definition at line 241 of file ReadHDF5.cpp.
References moab::ReadHDF5Dataset::append_hyperslabs(), bcastDuplicateReads, bcastSummary, blockedCoordinateIO, bufferSize, collIO, moab::ReadHDF5::HDF5ErrorHandler::data, dataBuffer, dbgOut, debugTrack, moab::DEFAULT_BCAST_DUPLICATE_READS, moab::DEFAULT_BCAST_SUMMARY, moab::DEFAULT_BLOCKED_COORDINATE_IO, moab::ReadHDF5Dataset::default_hyperslab_selection_limit(), ErrorCode, errorHandler, fileInfo, filePtr, moab::ReadHDF5::HDF5ErrorHandler::func, moab::FileOptions::get_int_option(), moab::FileOptions::get_null_option(), moab::ParallelComm::get_pcomm(), moab::FileOptions::get_str_option(), moab::FileOptions::get_toggle_option(), moab::handle_hdf5_error(), handleType, moab::HDF5_can_append_hyperslabs(), iFace, indepIO, init(), is_error(), moab::DebugOutput::limit_output_to_first_N_procs(), moab::FileOptions::match_option(), MB_CHK_ERR, MB_ENTITY_NOT_FOUND, MB_INVALID_SIZE, MB_MEMORY_ALLOCATION_FAILED, MB_NOT_IMPLEMENTED, MB_SET_ERR, MB_SUCCESS, MB_TYPE_OUT_OF_RANGE, mhdf_closeFile(), mhdf_fixFileDesc(), mhdf_getFileSummary(), mhdf_isError(), mhdf_message(), mhdf_openFile(), mhdf_openFileWithOpt(), MPI_COMM_WORLD, mpiComm, myPcomm, nativeParallel, mhdf_FileDesc::offset, moab::DebugOutput::print(), moab::ProcConfig::proc_comm(), moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), rank, READ_HDF5_BUFFER_SIZE, moab::ReadHDF5Dataset::set_hyperslab_selection_limit(), moab::DebugOutput::set_prefix(), moab::DebugOutput::set_rank(), moab::DebugOutput::set_verbosity(), size, mhdf_FileDesc::total_size, moab::DebugOutput::tprint(), and moab::DebugOutput::tprintf().
Referenced by load_file(), and read_tag_values().
    ErrorCode rval;
    mhdf_Status status;
    indepIO = collIO = H5P_DEFAULT;
    mpiComm          = 0;
    if( MB_SUCCESS != init() ) MB_SET_ERR( MB_FAILURE, "ReadHDF5 Failure" );
#if defined( H5Eget_auto_vers ) && H5Eget_auto_vers > 1
    herr_t err = H5Eget_auto( H5E_DEFAULT, &errorHandler.func, &errorHandler.data );
#else
    herr_t err = H5Eget_auto( &errorHandler.func, &errorHandler.data );
#endif
    if( err < 0 )
        errorHandler.func = 0;
        errorHandler.data = 0;
    else
#if defined( H5Eset_auto_vers ) && H5Eset_auto_vers > 1
        err = H5Eset_auto( H5E_DEFAULT, &handle_hdf5_error, &errorHandler );
#else
        err           = H5Eset_auto( &handle_hdf5_error, &errorHandler );
#endif
        if( err < 0 )
    // Set up debug output
    int tmpval;
    if( MB_SUCCESS == opts.get_int_option( "DEBUG_IO", 1, tmpval ) )
        dbgOut.set_verbosity( tmpval );
        dbgOut.set_prefix( "H5M " );
    dbgOut.limit_output_to_first_N_procs( 32 );
    // Enable some extra checks for reads. Note: amongst other things this
    // will print errors if the entire file is not read, so if doing a
    // partial read that is not a parallel read, this should be disabled.
    debugTrack = ( MB_SUCCESS == opts.get_null_option( "DEBUG_BINIO" ) );
    opts.get_toggle_option( "BLOCKED_COORDINATE_IO", DEFAULT_BLOCKED_COORDINATE_IO, blockedCoordinateIO );
    opts.get_toggle_option( "BCAST_SUMMARY", DEFAULT_BCAST_SUMMARY, bcastSummary );
    opts.get_toggle_option( "BCAST_DUPLICATE_READS", DEFAULT_BCAST_DUPLICATE_READS, bcastDuplicateReads );
    // Handle parallel options
    bool use_mpio  = ( MB_SUCCESS == opts.get_null_option( "USE_MPIO" ) );
    rval           = opts.match_option( "PARALLEL", "READ_PART" );
    bool parallel  = ( rval != MB_ENTITY_NOT_FOUND );
    nativeParallel = ( rval == MB_SUCCESS );
    if( use_mpio && !parallel )
        MB_SET_ERR( MB_NOT_IMPLEMENTED, "'USE_MPIO' option specified w/out 'PARALLEL' option" );
    // This option is intended for testing purposes only, and thus
    // is not documented anywhere.  Decreasing the buffer size can
    // expose bugs that would otherwise only be seen when reading
    // very large files.
    rval = opts.get_int_option( "BUFFER_SIZE", bufferSize );
        bufferSize = READ_HDF5_BUFFER_SIZE;
    else if( bufferSize < (int)std::max( sizeof( EntityHandle ), sizeof( void* ) ) )
        MB_CHK_ERR( MB_INVALID_SIZE );
    dataBuffer = (char*)malloc( bufferSize );
    if( !dataBuffer ) MB_CHK_ERR( MB_MEMORY_ALLOCATION_FAILED );
    if( use_mpio || nativeParallel )
#ifndef MOAB_HAVE_HDF5_PARALLEL
        free( dataBuffer );
        dataBuffer = NULL;
        MB_SET_ERR( MB_NOT_IMPLEMENTED, "MOAB not configured with parallel HDF5 support" );
#else
        MPI_Info info = MPI_INFO_NULL;
        std::string cb_size;
        rval = opts.get_str_option( "CB_BUFFER_SIZE", cb_size );
        if( MB_SUCCESS == rval )
            MPI_Info_create( &info );
            MPI_Info_set( info, const_cast< char* >( "cb_buffer_size" ), const_cast< char* >( cb_size.c_str() ) );
        int pcomm_no = 0;
        rval         = opts.get_int_option( "PARALLEL_COMM", pcomm_no );
        if( rval == MB_TYPE_OUT_OF_RANGE )
            MB_SET_ERR( rval, "Invalid value for PARALLEL_COMM option" );
        myPcomm = ParallelComm::get_pcomm( iFace, pcomm_no );
        if( 0 == myPcomm )
            myPcomm = new ParallelComm( iFace, MPI_COMM_WORLD );
        const int rank = myPcomm->proc_config().proc_rank();
        dbgOut.set_rank( rank );
        mpiComm = new MPI_Comm( myPcomm->proc_config().proc_comm() );
#ifndef H5_MPI_COMPLEX_DERIVED_DATATYPE_WORKS
        dbgOut.print( 1, "H5_MPI_COMPLEX_DERIVED_DATATYPE_WORKS is not defined\n" );
#endif
        // Open the file in serial on root to read summary
        dbgOut.tprint( 1, "Getting file summary\n" );
        fileInfo = 0;
        hid_t file_prop;
        if( bcastSummary )
            unsigned long size = 0;
            if( rank == 0 )
                file_prop = H5Pcreate( H5P_FILE_ACCESS );
                err       = H5Pset_fapl_mpio( file_prop, MPI_COMM_SELF, MPI_INFO_NULL );
                assert( file_prop >= 0 );
                assert( err >= 0 );
                filePtr = mhdf_openFileWithOpt( filename, 0, NULL, handleType, file_prop, &status );
                H5Pclose( file_prop );
                if( filePtr )
                    fileInfo = mhdf_getFileSummary( filePtr, handleType, &status,
                                                    0 );  // no extra set info
                    if( !is_error( status ) )
                        size             = fileInfo->total_size;
                        fileInfo->offset = (unsigned char*)fileInfo;
                mhdf_closeFile( filePtr, &status );
                if( fileInfo && mhdf_isError( &status ) )
                    free( fileInfo );
                    fileInfo = NULL;
            dbgOut.tprint( 1, "Communicating file summary\n" );
            int mpi_err = MPI_Bcast( &size, 1, MPI_UNSIGNED_LONG, 0, myPcomm->proc_config().proc_comm() );
            if( mpi_err || !size ) return MB_FAILURE;
            if( rank != 0 ) fileInfo = reinterpret_cast< mhdf_FileDesc* >( malloc( size ) );
            MPI_Bcast( fileInfo, size, MPI_BYTE, 0, myPcomm->proc_config().proc_comm() );
            if( rank != 0 ) mhdf_fixFileDesc( fileInfo, reinterpret_cast< mhdf_FileDesc* >( fileInfo->offset ) );
        err       = H5Pset_fapl_mpio( file_prop, myPcomm->proc_config().proc_comm(), info );
        assert( err >= 0 );
        collIO = H5Pcreate( H5P_DATASET_XFER );
        assert( collIO > 0 );
        err = H5Pset_dxpl_mpio( collIO, H5FD_MPIO_COLLECTIVE );
        assert( err >= 0 );
        indepIO = nativeParallel ? H5P_DEFAULT : collIO;
        // Re-open file in parallel
        dbgOut.tprintf( 1, "Opening \"%s\" for parallel IO\n", filename );
        if( !filePtr )
            free( dataBuffer );
            dataBuffer = NULL;
            H5Pclose( indepIO );
            if( collIO != indepIO ) H5Pclose( collIO );
            collIO = indepIO = H5P_DEFAULT;
        if( !bcastSummary )
            fileInfo = mhdf_getFileSummary( filePtr, handleType, &status, 0 );
                free( dataBuffer );
                dataBuffer = NULL;
#endif  // HDF5_PARALLEL
    else
        // Open the file
        filePtr = mhdf_openFile( filename, 0, NULL, handleType, &status );
        if( !filePtr )
            free( dataBuffer );
            dataBuffer = NULL;
        // Get file info
            free( dataBuffer );
            dataBuffer = NULL;
    ReadHDF5Dataset::default_hyperslab_selection_limit();
    int hslimit;
    rval = opts.get_int_option( "HYPERSLAB_SELECT_LIMIT", hslimit );
    if( MB_SUCCESS == rval && hslimit > 0 )
        ReadHDF5Dataset::set_hyperslab_selection_limit( hslimit );
    else
    if( MB_SUCCESS != opts.get_null_option( "HYPERSLAB_OR" ) &&
        ( MB_SUCCESS == opts.get_null_option( "HYPERSLAB_APPEND" ) || HDF5_can_append_hyperslabs() ) )
        ReadHDF5Dataset::append_hyperslabs();
        if( MB_SUCCESS != opts.get_int_option( "HYPERSLAB_SELECT_LIMIT", hslimit ) )
            ReadHDF5Dataset::set_hyperslab_selection_limit( std::numeric_limits< int >::max() );
        dbgOut.print( 1, "Using H5S_APPEND for hyperslab selection\n" );
    return MB_SUCCESS;
Store file IDS in tag values.
Copy file ID from IDMap for each entity read from file into a tag value on the entity.
Definition at line 3561 of file ReadHDF5.cpp.
References moab::RangeMap< KeyType, ValType, NullVal >::begin(), moab::Range::begin(), buffer, bufferSize, CHECK_OPEN_HANDLES, dataBuffer, moab::RangeMap< KeyType, ValType, NullVal >::end(), ErrorCode, idMap, iFace, moab::Range::insert(), MB_INDEX_OUT_OF_RANGE, MB_SUCCESS, and moab::Interface::tag_set_data().
Referenced by load_file().
    CHECK_OPEN_HANDLES;
    // typedef int tag_type;
    typedef long tag_type;
    // change it to be able to read much bigger files (long is 64 bits ...)
    tag_type* buffer       = reinterpret_cast< tag_type* >( dataBuffer );
    const long buffer_size = bufferSize / sizeof( tag_type );
    for( IDMap::iterator i = idMap.begin(); i != idMap.end(); ++i )
        IDMap::Range range = *i;
        // Make sure the values will fit in the tag type
        IDMap::key_type rv = range.begin + ( range.count - 1 );
        tag_type tv        = (tag_type)rv;
        if( (IDMap::key_type)tv != rv )
            assert( false );
            return MB_INDEX_OUT_OF_RANGE;
        while( range.count )
            long count = buffer_size < range.count ? buffer_size : range.count;
            Range handles;
            handles.insert( range.value, range.value + count - 1 );
            range.value += count;
            range.count -= count;
            for( long j = 0; j < count; ++j )
                buffer[j] = (tag_type)range.begin++;
            ErrorCode rval = iFace->tag_set_data( tag, handles, buffer );
            if( MB_SUCCESS != rval ) return rval;
    return MB_SUCCESS;
Store sets file IDS in a custom tag.
Copy sets file ID from IDMap for each set read from file into a custom tag on the sets needed now for the VisIt plugin, to identify sets read
Definition at line 3603 of file ReadHDF5.cpp.
References moab::RangeMap< KeyType, ValType, NullVal >::begin(), buffer, bufferSize, CHECK_OPEN_HANDLES, dataBuffer, moab::RangeMap< KeyType, ValType, NullVal >::end(), ErrorCode, idMap, iFace, moab::Range::insert(), MB_INDEX_OUT_OF_RANGE, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_OPAQUE, MBENTITYSET, moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), and moab::Interface::type_from_handle().
    CHECK_OPEN_HANDLES;
    // create a tag that will not be saved, but it will be
    // used by visit plugin to match the sets and their file ids
    // it is the same type as the tag defined in ReadParallelcpp, for file id
    Tag setFileIdTag;
    long default_val = 0;
    ErrorCode rval   = iFace->tag_get_handle( "__FILE_ID_FOR_SETS", sizeof( long ), MB_TYPE_OPAQUE, setFileIdTag,
                                              ( MB_TAG_DENSE | MB_TAG_CREAT ), &default_val );
    if( MB_SUCCESS != rval || 0 == setFileIdTag ) return rval;
        EntityType htype   = iFace->type_from_handle( range.value );
        if( MBENTITYSET != htype ) continue;
        // work only with entity sets
            assert( false );
            Range handles;
            rval = iFace->tag_set_data( setFileIdTag, handles, buffer );
    return MB_SUCCESS;
Update connectivity data for all element groups for which read_elems was called with a non-null node_ids argument.
Definition at line 1606 of file ReadHDF5.cpp.
References convert_id_to_handle(), ErrorCode, idConnectivityList, MB_SET_ERR, MB_SUCCESS, readUtil, and moab::ReadUtilIface::update_adjacencies().
    ErrorCode rval;
    std::vector< IDConnectivity >::iterator i;
    for( i = idConnectivityList.begin(); i != idConnectivityList.end(); ++i )
        rval = convert_id_to_handle( i->array, i->count * i->nodes_per_elem );
        rval = readUtil->update_adjacencies( i->handle, i->count, i->nodes_per_elem, i->array );
    idConnectivityList.clear();
    return MB_SUCCESS;
Member Data Documentation
double moab::ReadHDF5::_times[NUM_TIMES] [private]
Definition at line 205 of file ReadHDF5.hpp.
Referenced by load_file(), load_file_partial(), and print_times().
Definition at line 198 of file ReadHDF5.hpp.
Referenced by find_sets_containing(), read_all_set_meta(), and set_up_read().
Definition at line 197 of file ReadHDF5.hpp.
Referenced by set_up_read().
Flags for some behavior that can be changed through reader options
Definition at line 196 of file ReadHDF5.hpp.
Referenced by read_nodes(), and set_up_read().
bool moab::ReadHDF5::cputime [private]
Definition at line 207 of file ReadHDF5.hpp.
Referenced by load_file(), and load_file_partial().
Use IODebugTrack instances to verify reads. Enable with the DEBUG_OVERLAPS option.
Definition at line 186 of file ReadHDF5.hpp.
Referenced by init(), read_node_adj_elems(), and set_up_read().
Store old HDF5 error handling function.
Definition at line 201 of file ReadHDF5.hpp.
Referenced by clean_up_read(), and set_up_read().
List of connectivity arrays for which conversion from file ID to handle was deferred until later.
Definition at line 173 of file ReadHDF5.hpp.
Referenced by read_elems(), and update_connectivity().
hid_t moab::ReadHDF5::indepIO [private]
Read/write property handle indepIO -> independent IO during true parallel read collIO -> collective IO during true parallel read Both are H5P_DEFAULT for serial IO and collective when reading the entire file on all processors.
Definition at line 180 of file ReadHDF5.hpp.
Referenced by clean_up_read(), init(), load_file(), search_tag_values(), and set_up_read().
Cache pointer to read util.
Definition at line 157 of file ReadHDF5.hpp.
Referenced by init(), read_elems(), read_node_adj_elems(), read_nodes(), read_sets(), update_connectivity(), and ~ReadHDF5().
Definition at line 206 of file ReadHDF5.hpp.
List of all members.
