MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** \file ReadHDF5Dataset.hpp 00002 * \author Jason Kraftcheck 00003 * \date 2010-07-09 00004 */ 00005 00006 #ifndef moab_READ_HDF5DATASET_HPP 00007 #define moab_READ_HDF5DATASET_HPP 00008 00009 #include "moab/MOABConfig.h" 00010 #ifdef MOAB_HAVE_MPI 00011 #include <moab_mpi.h> 00012 #endif 00013 00014 #include <cstdlib> // for size_t 00015 #include <H5Ipublic.h> 00016 #include <H5Spublic.h> 00017 00018 #include "moab/Range.hpp" 00019 #include <vector> 00020 00021 namespace moab 00022 { 00023 00024 /**\brief Utility used for reading portions of an HDF5 dataset 00025 * 00026 * Implement iterative read of table where: 00027 * - subset of rows to be read can be specified usign an Range of offsets 00028 * - each read fills as much as possible of a passed buffer 00029 * - each read call reads a subsequent set of rows of the data set in an 00030 * iterator-like fashion. 00031 * 00032 * NOTE: This class also implements an RAII pattern for the data set handle: 00033 * It will close the data set in its destructor unless it is specified 00034 * to the constructor that only a single column should be read. 00035 * 00036 * NOTE: This class will always do collective IO for parallel reads. 00037 */ 00038 class ReadHDF5Dataset 00039 { 00040 public: 00041 #ifdef MOAB_HAVE_MPI 00042 typedef MPI_Comm Comm; 00043 #else 00044 typedef int Comm; 00045 #endif 00046 00047 class Exception 00048 { 00049 public: 00050 int line_no; 00051 Exception( int l ) : line_no( l ) {} 00052 }; 00053 00054 /**\brief Setup to read entire table 00055 *\param data_set_handle The HDF5 DataSet to read. 00056 *\param parallel Doing true partial-read parallel read (as opposed 00057 * to read and delete where collective IO is done for 00058 * everything because all procs read the same stuff.) 00059 *\param communictor If \c parallel is \c true and \c io_prop is 00060 * \c H5FD_MPIO_COLLECTIVE, then this 00061 * must be a pointer to the MPI_Communicator value. 00062 *\param close_data_set_on_destruct Call \c H5Dclose on passed 00063 * \c data_set_handle in desturctor. 00064 * 00065 *\NOTE If \c parallel is \c true and \c io_prop is \c H5FD_MPIO_COLLECTIVE, 00066 * then not only must \c communicator be non-null, but this call must 00067 * be made collectively! 00068 00069 *\NOTE Class instance will not be usable until one of either 00070 * \c set_file_ids or \c set_all_file_ids is called. 00071 */ 00072 ReadHDF5Dataset( const char* debug_desc, 00073 hid_t data_set_handle, 00074 bool parallel, 00075 const Comm* communicator = 0, 00076 bool close_data_set_on_destruct = true ); 00077 00078 ReadHDF5Dataset( const char* debug_desc, bool parallel, const Comm* communicator = 0 ); 00079 void init( hid_t data_set_handle, bool close_data_set_on_destruct = true ); 00080 00081 bool will_close_data_set() const 00082 { 00083 return closeDataSet; 00084 } 00085 void close_data_set_on_destruct( bool val ) 00086 { 00087 closeDataSet = val; 00088 } 00089 00090 ~ReadHDF5Dataset(); 00091 00092 /**\brief Change file ids to read from. 00093 * 00094 *\param file_ids List of rows to read from dataset 00095 *\param start_id Rows of dataset are enumerating beginning with 00096 * this value. Thus the offset row to be read from 00097 * dataset will be \c file_ids.begin() - \c start_id . 00098 *\param row_count Read buffer size in number of table rows. 00099 *\param data_type The data type of the buffer into which table values 00100 * are to be read. 00101 */ 00102 void set_file_ids( const Range& file_ids, EntityHandle start_id, hsize_t row_cout, hid_t data_type ); 00103 00104 /**\brief Read all values in dataset (undo set_file_ids) 00105 * 00106 *\param row_count Read buffer size in number of table rows. 00107 *\param data_type The data type of the buffer into which table values 00108 * are to be read. 00109 */ 00110 void set_all_file_ids( hsize_t row_count, hid_t data_type ); 00111 00112 /**\brief Return false if more data to read, true otherwise 00113 * 00114 * Test if the iterative read has reached the end. 00115 */ 00116 bool done() const 00117 { 00118 return ( currOffset == rangeEnd ) && ( readCount == 0 ); 00119 } 00120 00121 /**\brief Read rows of table 00122 * 00123 * Read up to max_num_rows from data set. 00124 *\param buffer Memory in which to store values read from data set 00125 *\param rows_read The actual number of rows read from the table. Will 00126 * never exceed \c max_rows . 00127 */ 00128 void read( void* buffer, size_t& rows_read ); 00129 00130 /**\brief Return position in \c Range of file IDs at which next read will start 00131 */ 00132 Range::const_iterator next_file_id() const 00133 { 00134 return currOffset; 00135 } 00136 00137 /**\brief Do null read operation 00138 * 00139 * Do a read call requesting no data. This functionality is provided 00140 * so as to allow collective IO when not all processes need to make the 00141 * same number of read calls. To prevent deadlock in this case, processes 00142 * that have finished their necessary read calls can call this function 00143 * so that all processes are calling the read method collectively. 00144 */ 00145 void null_read(); 00146 00147 unsigned columns() const; 00148 void set_column( unsigned c ); 00149 00150 unsigned long get_read_count() const 00151 { 00152 return readCount; 00153 } 00154 const char* get_debug_desc() const 00155 { 00156 return mpeDesc.c_str(); 00157 } 00158 00159 static void set_hyperslab_selection_limit( size_t val ) 00160 { 00161 hyperslabSelectionLimit = val; 00162 } 00163 static void default_hyperslab_selection_limit(); 00164 00165 /** Use non-standard 'APPEND' operation for hyperslab selection */ 00166 static void append_hyperslabs() 00167 { 00168 hyperslabSelectOp = H5S_SELECT_APPEND; 00169 } 00170 /** Revert to default select behavior for standard HDF5 library */ 00171 static void or_hyperslabs() 00172 { 00173 hyperslabSelectOp = H5S_SELECT_OR; 00174 } 00175 00176 private: 00177 Range::const_iterator next_end( Range::const_iterator iter ); 00178 00179 Range internalRange; //!< used when reading entire dataset 00180 00181 bool closeDataSet; //!< close dataset in destructor 00182 hsize_t dataSetOffset[64], dataSetCount[64]; 00183 hid_t dataSet; //!< Handle for HDF5 data set 00184 hid_t dataSpace; //!< Data space for data set 00185 hid_t dataType; //!< Data type client code wants for data 00186 hid_t fileType; //!< Data type as stored in data set 00187 hid_t ioProp; //!< Used to specify collective IO 00188 int dataSpaceRank; //!< Rank of data set 00189 hsize_t rowsInTable; //!< Total number of rows in dataset 00190 bool doConversion; //!< True if dataType != fileType 00191 bool nativeParallel; //!< If true then reading different data on different procs 00192 00193 hsize_t readCount; //!< Number of actual reads to do 00194 hsize_t bufferSize; //!< size of buffer passed to \c read, in number of rows 00195 const Comm* mpiComm; 00196 00197 Range::const_iterator currOffset, rangeEnd; 00198 EntityHandle startID; 00199 00200 static bool haveMPEEvents; 00201 static std::pair< int, int > mpeReadEvent; 00202 static std::pair< int, int > mpeReduceEvent; 00203 std::string mpeDesc; 00204 00205 static size_t hyperslabSelectionLimit; 00206 static H5S_seloper_t hyperslabSelectOp; 00207 }; 00208 00209 } // namespace moab 00210 00211 #endif // moab_READ_HDF5DATASET_HPP
