MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "TestRunner.hpp"#include "iMesh.h"#include "MBiMesh.hpp"#include "moab/Core.hpp"#include <algorithm>
Include dependency graph for MOAB_iMesh_unit_tests.cpp:Go to the source code of this file.
Functions | |
| iMesh_Instance | create_mesh () |
| void | test_getEntArrAdj_conn () |
| void | test_getEntArrAdj_vertex () |
| void | test_getEntArrAdj_up () |
| void | test_getEntArrAdj_down () |
| void | test_getEntArrAdj_invalid_size () |
| void | test_getEntArrAdj_none () |
| void | test_existinterface () |
| void | test_tags_retrieval () |
| void | test_invalid_parallel_option () |
| int | main (int argc, char *argv[]) |
| static void | HEX_VERTS (int i, int j, int k, iBase_EntityHandle conn[8]) |
| static void | QUAD_VERTS (int f, int i, int j, iBase_EntityHandle conn[4]) |
Variables | |
| const int | INTERVALS = 2 |
| iBase_EntityHandle | VERTS [INTERVALS+1][INTERVALS+1][INTERVALS+1] |
| iBase_EntityHandle | HEXES [INTERVALS][INTERVALS][INTERVALS] |
| iBase_EntityHandle | FACES [6][INTERVALS][INTERVALS] |
Definition at line 98 of file MOAB_iMesh_unit_tests.cpp.
References CHECK_EQUAL, FACES, HEX_VERTS(), HEXES, iBase_NEW, iBase_SUCCESS, iMesh_createEnt, iMesh_createVtx, iMesh_HEXAHEDRON, iMesh_newMesh, iMesh_QUADRILATERAL, INTERVALS, QUAD_VERTS(), and VERTS.
static iMesh_Instance instance = 0;
if( instance ) return instance;
int err;
iMesh_Instance tmp;
iMesh_newMesh( 0, &tmp, &err, 0 );
CHECK_EQUAL( iBase_SUCCESS, err );
for( int i = 0; i < INTERVALS + 1; ++i )
for( int j = 0; j < INTERVALS + 1; ++j )
for( int k = 0; k < INTERVALS + 1; ++k )
iMesh_createVtx( tmp, i, j, k, &VERTS[i][j][k], &err );
int status;
iBase_EntityHandle conn[8];
for( int i = 0; i < INTERVALS; ++i )
for( int j = 0; j < INTERVALS; ++j )
for( int k = 0; k < INTERVALS; ++k )
HEX_VERTS( i, j, k, conn );
iMesh_createEnt( tmp, iMesh_HEXAHEDRON, conn, 8, &HEXES[i][j][k], &status, &err );
CHECK_EQUAL( iBase_NEW, status );
for( int f = 0; f < 6; ++f )
QUAD_VERTS( f, i, j, conn );
iMesh_createEnt( tmp, iMesh_QUADRILATERAL, conn, 4, &FACES[f][i][j], &status, &err );
return ( instance = tmp );
| static void HEX_VERTS | ( | int | i, |
| int | j, | ||
| int | k, | ||
| iBase_EntityHandle | conn[8] | ||
| ) | [static] |
Definition at line 56 of file MOAB_iMesh_unit_tests.cpp.
References VERTS.
Referenced by create_mesh(), and test_getEntArrAdj_conn().
| int main | ( | int | argc, |
| char * | argv[] | ||
Definition at line 19 of file MOAB_iMesh_unit_tests.cpp.
References CHECK_EQUAL, create_mesh(), iBase_SUCCESS, iMesh_dtor, mesh, REGISTER_TEST, RUN_TESTS, test_existinterface(), test_getEntArrAdj_conn(), test_getEntArrAdj_down(), test_getEntArrAdj_invalid_size(), test_getEntArrAdj_none(), test_getEntArrAdj_up(), test_getEntArrAdj_vertex(), test_invalid_parallel_option(), and test_tags_retrieval().
REGISTER_TEST( test_getEntArrAdj_conn );
REGISTER_TEST( test_getEntArrAdj_vertex );
REGISTER_TEST( test_getEntArrAdj_up );
REGISTER_TEST( test_getEntArrAdj_down );
REGISTER_TEST( test_getEntArrAdj_invalid_size );
REGISTER_TEST( test_getEntArrAdj_none );
REGISTER_TEST( test_existinterface );
#ifdef MOAB_HAVE_HDF5
REGISTER_TEST( test_tags_retrieval );
#endif
#ifndef MOAB_HAVE_MPI
REGISTER_TEST( test_invalid_parallel_option );
#endif
int result = RUN_TESTS( argc, argv );
// Delete the static iMesh instance defined in create_mesh()
iMesh_Instance mesh = create_mesh();
int err;
iMesh_dtor( mesh, &err );
return result;
| static void QUAD_VERTS | ( | int | f, |
| int | i, | ||
| int | j, | ||
| iBase_EntityHandle | conn[4] | ||
| ) | [static] |
Definition at line 68 of file MOAB_iMesh_unit_tests.cpp.
References CHECK, INTERVALS, and VERTS.
switch( f )
case 0:
case 2:
conn[0] = VERTS[i][INTERVALS * ( f / 2 )][j];
conn[1] = VERTS[i + 1][INTERVALS * ( f / 2 )][j];
conn[2] = VERTS[i + 1][INTERVALS * ( f / 2 )][j + 1];
conn[3] = VERTS[i][INTERVALS * ( f / 2 )][j + 1];
break;
case 1:
case 3:
conn[0] = VERTS[INTERVALS * ( 1 / f )][i][j];
conn[1] = VERTS[INTERVALS * ( 1 / f )][i + 1][j];
conn[2] = VERTS[INTERVALS * ( 1 / f )][i + 1][j + 1];
conn[3] = VERTS[INTERVALS * ( 1 / f )][i][j + 1];
break;
case 4:
case 5:
conn[0] = VERTS[i][j][INTERVALS * ( f - 4 )];
conn[1] = VERTS[i + 1][j][INTERVALS * ( f - 4 )];
conn[2] = VERTS[i + 1][j + 1][INTERVALS * ( f - 4 )];
conn[3] = VERTS[i][j + 1][INTERVALS * ( f - 4 )];
break;
default:
CHECK( false );
| void test_existinterface | ( | ) |
Definition at line 402 of file MOAB_iMesh_unit_tests.cpp.
References CHECK_EQUAL, dim, ErrorCode, moab::Core::get_number_entities_by_dimension(), iBase_SUCCESS, iMesh_dtor, iMesh_getGeometricDimension, MB_SUCCESS, and mesh.
Referenced by main().
// test construction of an imesh instance from a core instance
moab::Core* core = new moab::Core();
MBiMesh* mesh = new MBiMesh( core );
iMesh_Instance imesh = reinterpret_cast< iMesh_Instance >( mesh );
// make sure we can call imesh functions
int dim, err;
iMesh_getGeometricDimension( imesh, &dim, &err );
// now make sure we can delete the instance without it deleting the MOAB instance
iMesh_dtor( imesh, &err );
CHECK_EQUAL( err, iBase_SUCCESS );
ErrorCode rval = core->get_number_entities_by_dimension( 0, 0, dim );
CHECK_EQUAL( moab::MB_SUCCESS, rval );
// finally, delete the MOAB instance
delete core;
| void test_getEntArrAdj_conn | ( | ) |
Definition at line 140 of file MOAB_iMesh_unit_tests.cpp.
References CHECK_ARRAYS_EQUAL, CHECK_EQUAL, create_mesh(), FACES, HEX_VERTS(), HEXES, iBase_SUCCESS, iBase_VERTEX, iMesh_getEntArrAdj, INTERVALS, mesh, and QUAD_VERTS().
int err;
// test hex vertices
iBase_EntityHandle adj[8 * INTERVALS];
int off[INTERVALS + 1];
int adj_alloc = sizeof( adj ) / sizeof( adj[0] );
int off_alloc = sizeof( off ) / sizeof( off[0] );
int adj_size = -1, off_size = -1;
iBase_EntityHandle* adj_ptr = adj;
int* off_ptr = off;
iMesh_getEntArrAdj( mesh, HEXES[i][j], INTERVALS, iBase_VERTEX, &adj_ptr, &adj_alloc, &adj_size, &off_ptr,
&off_alloc, &off_size, &err );
CHECK_EQUAL( &adj[0], adj_ptr );
CHECK_EQUAL( &off[0], off_ptr );
CHECK_EQUAL( 8 * INTERVALS, adj_size );
CHECK_EQUAL( 8 * INTERVALS, adj_alloc );
CHECK_EQUAL( INTERVALS + 1, off_size );
CHECK_EQUAL( INTERVALS + 1, off_alloc );
CHECK_EQUAL( 8 * k, off[k] );
CHECK_ARRAYS_EQUAL( conn, 8, adj + off[k], off[k + 1] - off[k] );
// test quad vertices for one side of mesh
const int f = 0;
iBase_EntityHandle adj[4 * INTERVALS];
int* off_ptr = off;
iMesh_getEntArrAdj( mesh, FACES[f][i], INTERVALS, iBase_VERTEX, &adj_ptr, &adj_alloc, &adj_size, &off_ptr,
CHECK_EQUAL( 4 * INTERVALS, adj_size );
CHECK_EQUAL( 4 * INTERVALS, adj_alloc );
CHECK_EQUAL( 4 * k, off[k] );
iBase_EntityHandle conn[4];
QUAD_VERTS( f, i, k, conn );
CHECK_ARRAYS_EQUAL( conn, 4, adj + off[k], off[k + 1] - off[k] );
| void test_getEntArrAdj_down | ( | ) |
Definition at line 274 of file MOAB_iMesh_unit_tests.cpp.
References CHECK, CHECK_ARRAYS_EQUAL, CHECK_EQUAL, create_mesh(), FACES, HEXES, iBase_FACE, iBase_SUCCESS, iMesh_getEntArrAdj, INTERVALS, and mesh.
int err;
// get quads adjacent to a edge-row of hexes
iBase_EntityHandle* adj = 0;
int* off = 0;
int adj_alloc = 0, off_alloc = 0;
iMesh_getEntArrAdj( mesh, HEXES[0][0], INTERVALS, iBase_FACE, &adj, &adj_alloc, &adj_size, &off, &off_alloc,
&off_size, &err );
CHECK( 0 != adj );
CHECK( 0 != off );
CHECK_EQUAL( 2 * INTERVALS + 2, adj_size ); // corner hexes adj to 3 faces, others adj to 2
CHECK_EQUAL( INTERVALS + 1, off_size ); // one more than number of input handles
CHECK( adj_alloc >= adj_size );
CHECK( off_alloc >= off_size );
// first (corner) hex should have three adjacent faces
CHECK_EQUAL( 3, off[1] - off[0] );
iBase_EntityHandle exp[3] = { FACES[0][0][0], FACES[3][0][0], FACES[4][0][0] };
iBase_EntityHandle act[3];
std::copy( adj + off[0], adj + off[1], act );
std::sort( exp, exp + 3 );
std::sort( act, act + 3 );
CHECK_ARRAYS_EQUAL( exp, 3, act, 3 );
// last (corner) hex should have three adjacent faces
CHECK_EQUAL( 3, off[INTERVALS] - off[INTERVALS - 1] );
iBase_EntityHandle exp2[3] = { FACES[0][0][INTERVALS - 1], FACES[3][0][INTERVALS - 1], FACES[5][0][0] };
std::copy( adj + off[INTERVALS - 1], adj + off[INTERVALS], act );
std::sort( exp2, exp2 + 3 );
CHECK_ARRAYS_EQUAL( exp2, 3, act, 3 );
// all middle hexes should have two adjacent faces
// FixME: This loop is never executed (INTERVALS is 2)
for (int i = 1; i < INTERVALS-1; ++i) {
iBase_EntityHandle e1, e2, a1, a2;
e1 = FACES[0][0][i];
e2 = FACES[3][0][i];
if (e1 > e2) std::swap(e1,e2);
CHECK_EQUAL( 2, off[i+1] - off[i] );
a1 = adj[off[i] ];
a2 = adj[off[i]+1];
if (a1 > a2) std::swap(a1,a2);
CHECK_EQUAL( e1, a1 );
CHECK_EQUAL( e2, a2 );
free( adj );
free( off );
| void test_getEntArrAdj_invalid_size | ( | ) |
Definition at line 334 of file MOAB_iMesh_unit_tests.cpp.
References CHECK_EQUAL, create_mesh(), HEXES, iBase_BAD_ARRAY_SIZE, iBase_REGION, iBase_SUCCESS, iBase_VERTEX, iMesh_getEntArrAdj, INTERVALS, mesh, and VERTS.
int err = -1;
const int SPECIAL1 = 0xDeadBeef;
const int SPECIAL2 = 0xCafe5;
const int SPECIAL3 = 0xbabb1e;
// test a downward query
volatile int marker1 = SPECIAL1;
iBase_EntityHandle adj1[8 * INTERVALS - 1]; // one too small
volatile int marker2 = SPECIAL2;
int off1[INTERVALS + 1];
int adj1_alloc = sizeof( adj1 ) / sizeof( adj1[0] );
int off1_alloc = sizeof( off1 ) / sizeof( off1[0] );
int adj_size, off_size;
iBase_EntityHandle* adj_ptr = adj1;
int* off_ptr = off1;
iMesh_getEntArrAdj( mesh, HEXES[0][0], INTERVALS, iBase_VERTEX, &adj_ptr, &adj1_alloc, &adj_size, &off_ptr,
&off1_alloc, &off_size, &err );
CHECK_EQUAL( &adj1[0], adj_ptr );
CHECK_EQUAL( &off1[0], off_ptr );
// first ensure no stack corruption from writing off end of array
CHECK_EQUAL( SPECIAL1, marker1 );
CHECK_EQUAL( SPECIAL2, marker2 );
// now verify that it correctly failed
CHECK_EQUAL( iBase_BAD_ARRAY_SIZE, err );
// now test an upwards query
volatile int marker3 = SPECIAL3;
int off2[INTERVALS];
volatile int marker4 = SPECIAL1;
int off2_alloc = sizeof( off2 ) / sizeof( off2[0] );
err = iBase_SUCCESS;
adj_ptr = adj1;
off_ptr = off2;
iMesh_getEntArrAdj( mesh, VERTS[0][0], INTERVALS + 1, iBase_REGION, &adj_ptr, &adj1_alloc, &adj_size, &off_ptr,
&off2_alloc, &off_size, &err );
CHECK_EQUAL( &off2[0], off_ptr );
CHECK_EQUAL( SPECIAL3, marker3 );
CHECK_EQUAL( SPECIAL1, marker4 );
| void test_getEntArrAdj_none | ( | ) |
Definition at line 382 of file MOAB_iMesh_unit_tests.cpp.
References CHECK, CHECK_EQUAL, create_mesh(), iBase_REGION, iBase_SUCCESS, iMesh_getEntArrAdj, and mesh.
int err = -1;
int* off = 0;
iMesh_getEntArrAdj( mesh, NULL, 0, iBase_REGION, &adj, &adj_alloc, &adj_size, &off, &off_alloc, &off_size, &err );
CHECK_EQUAL( 0, adj_alloc );
CHECK_EQUAL( 0, adj_size );
CHECK_EQUAL( 1, off_size );
CHECK( off_alloc >= 1 );
CHECK_EQUAL( 0, off[0] );
free( off );
| void test_getEntArrAdj_up | ( | ) |
Definition at line 244 of file MOAB_iMesh_unit_tests.cpp.
References CHECK, CHECK_EQUAL, create_mesh(), FACES, HEXES, iBase_REGION, iBase_SUCCESS, iMesh_getEntArrAdj, INTERVALS, and mesh.
int err;
// get hexes adjacent to a row of faces in the z=0 plane
int* off = 0;
iMesh_getEntArrAdj( mesh, FACES[4][0], INTERVALS, iBase_REGION, &adj, &adj_alloc, &adj_size, &off, &off_alloc,
&off_size, &err );
CHECK( 0 != adj );
CHECK( 0 != off );
CHECK_EQUAL( INTERVALS, adj_size ); // one hex adjacent to each skin face
CHECK_EQUAL( 1, off[i + 1] - off[i] );
CHECK_EQUAL( HEXES[0][i][0], adj[off[i]] );
free( adj );
free( off );
| void test_getEntArrAdj_vertex | ( | ) |
Definition at line 206 of file MOAB_iMesh_unit_tests.cpp.
References CHECK, CHECK_EQUAL, create_mesh(), HEXES, iBase_REGION, iBase_SUCCESS, iMesh_getEntArrAdj, INTERVALS, mesh, and VERTS.
int err;
// get hexes adjacent to row of vertices at x=0,y=0;
int* off = 0;
iMesh_getEntArrAdj( mesh, VERTS[0][0], INTERVALS + 1, iBase_REGION, &adj, &adj_alloc, &adj_size, &off, &off_alloc,
&off_size, &err );
CHECK( 0 != adj );
CHECK( 0 != off );
CHECK_EQUAL( 2 * INTERVALS,
adj_size ); // INTERVALS+1 verts, end ones with one hex, others with two
CHECK_EQUAL( INTERVALS + 2, off_size ); // one more than number of input handles
// first and last vertices should have one adjacent hex
CHECK_EQUAL( 1, off[1] - off[0] );
CHECK_EQUAL( HEXES[0][0][0], adj[off[0]] );
CHECK_EQUAL( 1, off[INTERVALS + 1] - off[INTERVALS] );
CHECK_EQUAL( HEXES[0][0][INTERVALS - 1], adj[off[INTERVALS]] );
// middle ones should have two adjacent hexes
for( int i = 1; i < INTERVALS; ++i )
CHECK_EQUAL( 2, off[i + 1] - off[i] );
CHECK_EQUAL( HEXES[0][0][i - 1], adj[off[i]] );
CHECK_EQUAL( HEXES[0][0][i], adj[off[i] + 1] );
free( adj );
free( off );
| void test_invalid_parallel_option | ( | ) |
Definition at line 477 of file MOAB_iMesh_unit_tests.cpp.
References CHECK_EQUAL, iBase_NOT_SUPPORTED, iBase_SUCCESS, iMesh_dtor, iMesh_newMesh, and mesh.
iMesh_Instance mesh;
int err;
iMesh_newMesh( "moab:PARALLEL", &mesh, &err, 13 );
CHECK_EQUAL( iBase_NOT_SUPPORTED, err );
| void test_tags_retrieval | ( | ) |
Definition at line 425 of file MOAB_iMesh_unit_tests.cpp.
References CHECK_EQUAL, filename, iBase_SUCCESS, iMesh_dtor, iMesh_getAllEntSetTags, iMesh_getEntSets, iMesh_getRootSet, iMesh_getTagSizeValues, iMesh_load, iMesh_newMesh, mesh, root_set, and STRINGIFY.
int err;
iMesh_newMesh( "", &mesh, &err, 0 );
iBase_EntitySetHandle root_set;
iMesh_getRootSet( mesh, &root_set, &err );
// open a file with var len tags (sense tags)
// they should be filtered out
std::string filename = STRINGIFY( MESHDIR ) "/PB.h5m";
iMesh_load( mesh, root_set, filename.c_str(), NULL, &err, filename.length(), 0 );
iBase_EntitySetHandle* contained_set_handles = NULL;
int contained_set_handles_allocated = 0;
int contained_set_handles_size;
// get all entity sets
iMesh_getEntSets( mesh, root_set, 1, &contained_set_handles, &contained_set_handles_allocated,
&contained_set_handles_size, &err );
// get tags for all sets
for( int i = 0; i < contained_set_handles_size; i++ )
iBase_TagHandle* tag_handles = NULL;
int tag_handles_allocated = 0;
int tag_handles_size;
iMesh_getAllEntSetTags( mesh, contained_set_handles[i], &tag_handles, &tag_handles_allocated, &tag_handles_size,
&err );
for( int j = 0; j < tag_handles_size; j++ )
int tagSize;
iMesh_getTagSizeValues( mesh, tag_handles[j], &tagSize, &err );
free( tag_handles );
free( contained_set_handles );
// Delete the iMesh instance
return;
Definition at line 54 of file MOAB_iMesh_unit_tests.cpp.
Referenced by create_mesh(), test_getEntArrAdj_conn(), test_getEntArrAdj_down(), and test_getEntArrAdj_up().
Definition at line 53 of file MOAB_iMesh_unit_tests.cpp.
Referenced by create_mesh(), test_getEntArrAdj_conn(), test_getEntArrAdj_down(), test_getEntArrAdj_invalid_size(), test_getEntArrAdj_up(), and test_getEntArrAdj_vertex().
| const int INTERVALS = 2 |
Definition at line 51 of file MOAB_iMesh_unit_tests.cpp.
Referenced by build_mesh(), coords_from_gid(), create_mesh(), QUAD_VERTS(), tag_vals_from_gid(), test_elements(), test_getEntArrAdj_conn(), test_getEntArrAdj_down(), test_getEntArrAdj_invalid_size(), test_getEntArrAdj_up(), test_getEntArrAdj_vertex(), test_iterator_back(), test_leaf_merge(), test_point_search(), test_read_bit_tag(), test_read_set_contents(), test_read_set_parent_child(), test_read_vertices(), test_tree_delete(), and test_tree_readwrite().
| iBase_EntityHandle VERTS[INTERVALS+1][INTERVALS+1][INTERVALS+1] |
Definition at line 52 of file MOAB_iMesh_unit_tests.cpp.
Referenced by create_mesh(), HEX_VERTS(), QUAD_VERTS(), test_getEntArrAdj_invalid_size(), and test_getEntArrAdj_vertex().
