MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "moab/Core.hpp" 00002 #include "moab/AdaptiveKDTree.hpp" 00003 #include "moab/Range.hpp" 00004 #include "moab/CartVect.hpp" 00005 00006 #ifdef MOAB_HAVE_MPI 00007 #include "moab_mpi.h" 00008 #endif 00009 00010 #include <cmath> 00011 #include <cassert> 00012 #include <cfloat> 00013 #include <cstdio> 00014 00015 #include "TestUtil.hpp" 00016 00017 using namespace moab; 00018 00019 const unsigned INTERVALS = 4; 00020 const unsigned DEPTH = 7; // 3*log2(INTERVALS)+1 00021 const char* TAG_NAME = "TEST_DATA"; 00022 00023 EntityHandle create_tree( AdaptiveKDTree& tool, unsigned depth, int intervals, Tag* tag_handle = 0 ); 00024 void validate_tree( AdaptiveKDTree& tool, EntityHandle root, int depth, double intervals ); 00025 00026 void test_tree_create(); 00027 void test_leaf_merge(); 00028 void test_tree_readwrite(); 00029 void test_tree_delete(); 00030 void test_iterator_back(); 00031 void test_point_search(); 00032 00033 int main( int argc, char** argv ) 00034 { 00035 #ifdef MOAB_HAVE_MPI 00036 int fail = MPI_Init( &argc, &argv ); 00037 if( fail ) return fail; 00038 #else 00039 // silence the warning of parameters not used, in serial; there should be a smarter way :( 00040 argv[0] = argv[argc - argc]; 00041 #endif 00042 00043 int err = RUN_TEST( test_tree_create ); 00044 if( err ) // can't run other tests if can't create tree 00045 return 1; 00046 err += RUN_TEST( test_leaf_merge ); 00047 #ifdef MOAB_HAVE_HDF5 00048 err += RUN_TEST( test_tree_readwrite ); 00049 #endif 00050 err += RUN_TEST( test_tree_delete ); 00051 err += RUN_TEST( test_iterator_back ); 00052 err += RUN_TEST( test_point_search ); 00053 00054 #ifdef MOAB_HAVE_MPI 00055 fail = MPI_Finalize(); 00056 if( fail ) return fail; 00057 #endif 00058 00059 return err; 00060 } 00061 00062 EntityHandle create_tree( AdaptiveKDTree& tool, unsigned depth, int intervals, Tag* tag_handle ) 00063 { 00064 // Create tree root 00065 ErrorCode err; 00066 EntityHandle root, leaf; 00067 err = tool.create_root( CartVect( 0.0 ).array(), CartVect( intervals ).array(), root ); 00068 assert( !err ); 00069 00070 // Use iterator to create tree to fixed depth of DEPTH 00071 AdaptiveKDTreeIter iter; 00072 err = tool.get_tree_iterator( root, iter );CHECK_ERR( err ); 00073 while( err == MB_SUCCESS ) 00074 { 00075 if( iter.depth() < depth ) 00076 { 00077 // bisect leaves along alternating axes 00078 AdaptiveKDTree::Plane split; 00079 split.norm = iter.depth() % 3; // alternate split axes; 00080 split.coord = 0.5 * ( iter.box_min()[split.norm] + iter.box_max()[split.norm] ); 00081 err = tool.split_leaf( iter, split ); // advances iter to first new leaf 00082 CHECK_ERR( err ); 00083 } 00084 // if current leaf is at desired depth, advance to next one 00085 else 00086 { 00087 err = iter.step(); 00088 } 00089 } 00090 CHECK( MB_ENTITY_NOT_FOUND == err ); 00091 00092 if( !tag_handle ) return root; 00093 00094 // define a tag to use to store integer values on tree leaves 00095 err = tool.moab()->tag_get_handle( TAG_NAME, 1, MB_TYPE_INTEGER, *tag_handle, MB_TAG_DENSE | MB_TAG_EXCL );CHECK_ERR( err ); 00096 00097 // iterate over tree setting data 00098 int counter = 0; 00099 for( err = tool.get_tree_iterator( root, iter ); !err; err = iter.step() ) 00100 { 00101 // store integer value on leaf 00102 ++counter; 00103 leaf = iter.handle(); 00104 err = tool.moab()->tag_set_data( *tag_handle, &leaf, 1, &counter );CHECK_ERR( err ); 00105 } 00106 00107 return root; 00108 } 00109 00110 void validate_tree( AdaptiveKDTree& tool, EntityHandle root, unsigned depth, int intervals, Tag data ) 00111 { 00112 ErrorCode err; 00113 const double VOL = 1.0; // all leaves should be 1x1x1 boxes 00114 int val; 00115 00116 // iterate over tree, verifying leaves 00117 AdaptiveKDTreeIter iter; 00118 int counter = 0; 00119 for( err = tool.get_tree_iterator( root, iter ); !err; err = iter.step() ) 00120 { 00121 // store integer value on leaf 00122 ++counter; 00123 EntityHandle leaf = iter.handle(); 00124 CHECK( leaf != 0 ); 00125 CHECK_EQUAL( MBENTITYSET, TYPE_FROM_HANDLE( leaf ) ); 00126 00127 // check size of leaf 00128 const double* min = iter.box_min(); 00129 const double* max = iter.box_max(); 00130 double dims[] = { max[0] - min[0], max[1] - min[1], max[2] - min[2] }; 00131 double volume = dims[0] * dims[1] * dims[2]; 00132 CHECK_REAL_EQUAL( VOL, volume, DBL_EPSILON ); 00133 00134 // check depth of leaf 00135 CHECK_EQUAL( depth, iter.depth() ); 00136 00137 // check tag value on leaf 00138 err = tool.moab()->tag_get_data( data, &leaf, 1, &val );CHECK_ERR( err ); 00139 CHECK_EQUAL( counter, val ); 00140 } 00141 // check number of leaves 00142 const int num_leaves = intervals * intervals * intervals; 00143 CHECK_EQUAL( num_leaves, counter ); 00144 } 00145 00146 void test_tree_create() 00147 { 00148 Tag tag; 00149 Core mb; 00150 AdaptiveKDTree tool( &mb ); 00151 const EntityHandle root = create_tree( tool, DEPTH, INTERVALS, &tag ); 00152 validate_tree( tool, root, DEPTH, INTERVALS, tag ); 00153 } 00154 00155 void test_leaf_merge() 00156 { 00157 ErrorCode err; 00158 Core mb; 00159 AdaptiveKDTree tool( &mb ); 00160 Tag data; 00161 const EntityHandle root = create_tree( tool, DEPTH, INTERVALS, &data ); 00162 00163 // reduce tree depth to DEPTH-1 by merging adjacent leaf pairs, 00164 // make new "leaf" have smaller of two data values on original pair 00165 AdaptiveKDTreeIter iter; 00166 for( err = tool.get_tree_iterator( root, iter ); !err; err = iter.step() ) 00167 { 00168 // get data for first leaf 00169 int data1; 00170 EntityHandle leaf = iter.handle(); 00171 err = mb.tag_get_data( data, &leaf, 1, &data1 );CHECK_ERR( err ); 00172 // tree traversal is always such that two leaves with same parent are consective 00173 err = iter.step();CHECK_ERR( err ); 00174 // get data for sibling 00175 int data2; 00176 leaf = iter.handle(); 00177 err = mb.tag_get_data( data, &leaf, 1, &data2 );CHECK_ERR( err ); 00178 // as we stored increasing values, these had better be increasing 00179 CHECK_EQUAL( 1, data2 - data1 ); 00180 // merge leaf pair (iter can be at either one) 00181 err = tool.merge_leaf( iter ); // changes iter to be new "merged" leaf 00182 CHECK_ERR( err ); 00183 // store smaller of two values on new leaf 00184 leaf = iter.handle(); 00185 err = mb.tag_set_data( data, &leaf, 1, &data1 );CHECK_ERR( err ); 00186 } 00187 00188 // Iterate over tree, verifying leaves and checking data 00189 // Initial leaves had volume of 1 : merged pairs of leaves so volume should now be 2. 00190 // Initial leaves were enumerated in order : merged pairs so new leaves should 00191 // have data incrementing in steps of 2. 00192 int counter = 1; 00193 for( err = tool.get_tree_iterator( root, iter ); !err; err = iter.step() ) 00194 { 00195 // store integer value on leaf 00196 int data1; 00197 EntityHandle leaf = iter.handle(); 00198 err = mb.tag_get_data( data, &leaf, 1, &data1 );CHECK_ERR( err ); 00199 CHECK_EQUAL( counter, data1 ); 00200 counter += 2; 00201 00202 // check size of leaf 00203 const double* min = iter.box_min(); 00204 const double* max = iter.box_max(); 00205 double dims[] = { max[0] - min[0], max[1] - min[1], max[2] - min[2] }; 00206 double volume = dims[0] * dims[1] * dims[2]; 00207 CHECK_REAL_EQUAL( 2.0, volume, DBL_EPSILON ); 00208 00209 // check depth of leaf 00210 CHECK_EQUAL( DEPTH - 1, iter.depth() ); 00211 } 00212 } 00213 00214 void test_tree_readwrite() 00215 { 00216 ErrorCode err; 00217 Tag tag; 00218 Core mb; 00219 AdaptiveKDTree tool( &mb ); 00220 create_tree( tool, DEPTH, INTERVALS, &tag ); 00221 00222 // write to file 00223 err = mb.write_file( "tree.h5m" );CHECK_ERR( err ); 00224 00225 // clear everything 00226 mb.delete_mesh(); 00227 00228 // read tree from file 00229 err = mb.load_file( "tree.h5m" ); 00230 remove( "tree.h5m" );CHECK_ERR( err ); 00231 00232 // get tag handle by name, because the handle may have changed 00233 err = mb.tag_get_handle( TAG_NAME, 1, MB_TYPE_INTEGER, tag );CHECK_ERR( err ); 00234 00235 // get root handle for tree 00236 Range range; 00237 err = tool.find_all_trees( range ); 00238 assert( !err ); 00239 assert( range.size() == 1 ); 00240 EntityHandle root = range.front(); // first (only) handle 00241 00242 validate_tree( tool, root, DEPTH, INTERVALS, tag ); 00243 } 00244 00245 void test_tree_delete() 00246 { 00247 ErrorCode err; 00248 Core mb; 00249 AdaptiveKDTree tool( &mb ); 00250 Tag data; 00251 create_tree( tool, DEPTH, INTERVALS, &data ); 00252 00253 err = tool.reset_tree();CHECK_ERR( err ); 00254 00255 Range ents; 00256 err = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &data, 0, 1, ents );CHECK_ERR( err ); 00257 CHECK( ents.empty() ); 00258 } 00259 00260 void test_iterator_back() 00261 { 00262 Core mb; 00263 AdaptiveKDTree tool( &mb ); 00264 const EntityHandle root = create_tree( tool, DEPTH, INTERVALS ); 00265 00266 AdaptiveKDTreeIter iter; 00267 ErrorCode rval = tool.get_tree_iterator( root, iter );CHECK_ERR( rval ); 00268 00269 CartVect min( iter.box_min() ); 00270 CartVect max( iter.box_max() ); 00271 EntityHandle leaf = iter.handle(); 00272 00273 // going back from first location should fail. 00274 rval = iter.back(); 00275 CHECK_EQUAL( MB_ENTITY_NOT_FOUND, rval ); 00276 rval = tool.get_tree_iterator( root, iter );CHECK_ERR( rval ); 00277 00278 // make sure iterator is valid 00279 CHECK_REAL_EQUAL( min[0], iter.box_min()[0], DBL_EPSILON ); 00280 CHECK_REAL_EQUAL( min[1], iter.box_min()[1], DBL_EPSILON ); 00281 CHECK_REAL_EQUAL( min[2], iter.box_min()[2], DBL_EPSILON ); 00282 CHECK_REAL_EQUAL( max[0], iter.box_max()[0], DBL_EPSILON ); 00283 CHECK_REAL_EQUAL( max[1], iter.box_max()[1], DBL_EPSILON ); 00284 CHECK_REAL_EQUAL( max[2], iter.box_max()[2], DBL_EPSILON ); 00285 CHECK_EQUAL( leaf, iter.handle() ); 00286 00287 while( MB_SUCCESS == iter.step() ) 00288 { 00289 // Get values at current iterator location 00290 CartVect next_min( iter.box_min() ); 00291 CartVect next_max( iter.box_max() ); 00292 EntityHandle next_leaf = iter.handle(); 00293 00294 // step back to previous location 00295 rval = iter.back();CHECK_ERR( rval ); 00296 00297 // check expected values for previous location 00298 CHECK_REAL_EQUAL( min[0], iter.box_min()[0], DBL_EPSILON ); 00299 CHECK_REAL_EQUAL( min[1], iter.box_min()[1], DBL_EPSILON ); 00300 CHECK_REAL_EQUAL( min[2], iter.box_min()[2], DBL_EPSILON ); 00301 CHECK_REAL_EQUAL( max[0], iter.box_max()[0], DBL_EPSILON ); 00302 CHECK_REAL_EQUAL( max[1], iter.box_max()[1], DBL_EPSILON ); 00303 CHECK_REAL_EQUAL( max[2], iter.box_max()[2], DBL_EPSILON ); 00304 CHECK_EQUAL( leaf, iter.handle() ); 00305 00306 // advance iterator to 'current' location 00307 rval = iter.step();CHECK_ERR( rval ); 00308 00309 // check that iterator values are correct 00310 CHECK_REAL_EQUAL( next_min[0], iter.box_min()[0], DBL_EPSILON ); 00311 CHECK_REAL_EQUAL( next_min[1], iter.box_min()[1], DBL_EPSILON ); 00312 CHECK_REAL_EQUAL( next_min[2], iter.box_min()[2], DBL_EPSILON ); 00313 CHECK_REAL_EQUAL( next_max[0], iter.box_max()[0], DBL_EPSILON ); 00314 CHECK_REAL_EQUAL( next_max[1], iter.box_max()[1], DBL_EPSILON ); 00315 CHECK_REAL_EQUAL( next_max[2], iter.box_max()[2], DBL_EPSILON ); 00316 CHECK_EQUAL( next_leaf, iter.handle() ); 00317 00318 // store values for next iteration 00319 min = next_min; 00320 max = next_max; 00321 leaf = next_leaf; 00322 } 00323 } 00324 00325 void test_point_search() 00326 { 00327 Core mb; 00328 AdaptiveKDTree tool( &mb ); 00329 const EntityHandle root = create_tree( tool, DEPTH, INTERVALS ); 00330 00331 ErrorCode rval; 00332 EntityHandle leaf; 00333 AdaptiveKDTreeIter iter, iter2; 00334 00335 // points to test 00336 CartVect left( 0.5 ); 00337 CartVect right( CartVect( INTERVALS ) - left ); 00338 00339 // compare leaf search to iterator search 00340 rval = tool.point_search( left.array(), leaf );CHECK_ERR( rval ); 00341 rval = tool.point_search( left.array(), iter );CHECK_ERR( rval ); 00342 CHECK_EQUAL( leaf, iter.handle() ); 00343 00344 // iterator should be at 'first' leaf 00345 rval = tool.get_tree_iterator( root, iter2 );CHECK_ERR( rval ); 00346 for( ;; ) 00347 { 00348 CHECK_EQUAL( iter.handle(), iter2.handle() ); 00349 CHECK_EQUAL( iter.depth(), iter2.depth() ); 00350 CHECK_REAL_EQUAL( iter.box_min()[0], iter2.box_min()[0], DBL_EPSILON ); 00351 CHECK_REAL_EQUAL( iter.box_min()[1], iter2.box_min()[1], DBL_EPSILON ); 00352 CHECK_REAL_EQUAL( iter.box_min()[2], iter2.box_min()[2], DBL_EPSILON ); 00353 CHECK_REAL_EQUAL( iter.box_max()[0], iter2.box_max()[0], DBL_EPSILON ); 00354 CHECK_REAL_EQUAL( iter.box_max()[1], iter2.box_max()[1], DBL_EPSILON ); 00355 CHECK_REAL_EQUAL( iter.box_max()[2], iter2.box_max()[2], DBL_EPSILON ); 00356 00357 rval = iter2.step(); 00358 if( MB_ENTITY_NOT_FOUND == rval ) break;CHECK_ERR( rval ); 00359 rval = iter.step();CHECK_ERR( rval ); 00360 } 00361 00362 // compare leaf search to iterator search 00363 rval = tool.point_search( right.array(), leaf, 0.0, 0.0, NULL, const_cast< EntityHandle* >( &root ) );CHECK_ERR( rval ); 00364 rval = tool.point_search( right.array(), iter, 0.0, 0.0, NULL, const_cast< EntityHandle* >( &root ) );CHECK_ERR( rval ); 00365 assert( iter.handle() == leaf ); 00366 00367 // iterator should be at 'last' leaf 00368 rval = tool.get_last_iterator( root, iter2 );CHECK_ERR( rval ); 00369 for( ;; ) 00370 { 00371 CHECK_EQUAL( iter.handle(), iter2.handle() ); 00372 CHECK_EQUAL( iter.depth(), iter2.depth() ); 00373 CHECK_REAL_EQUAL( iter.box_min()[0], iter2.box_min()[0], DBL_EPSILON ); 00374 CHECK_REAL_EQUAL( iter.box_min()[1], iter2.box_min()[1], DBL_EPSILON ); 00375 CHECK_REAL_EQUAL( iter.box_min()[2], iter2.box_min()[2], DBL_EPSILON ); 00376 CHECK_REAL_EQUAL( iter.box_max()[0], iter2.box_max()[0], DBL_EPSILON ); 00377 CHECK_REAL_EQUAL( iter.box_max()[1], iter2.box_max()[1], DBL_EPSILON ); 00378 CHECK_REAL_EQUAL( iter.box_max()[2], iter2.box_max()[2], DBL_EPSILON ); 00379 00380 rval = iter2.back(); 00381 if( MB_ENTITY_NOT_FOUND == rval ) break;CHECK_ERR( rval ); 00382 rval = iter.back();CHECK_ERR( rval ); 00383 } 00384 }
