MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "FBiGeom.h"#include <iostream>#include <set>#include <algorithm>#include <vector>#include <iterator>#include <iomanip>#include <cassert>#include <cstring>#include <cmath>
Include dependency graph for testSmooth.cpp:Go to the source code of this file.
Classes | |
| class | SimpleArray< T > |
Defines | |
| #define | CHECK(STR) if( err != iBase_SUCCESS ) return print_error( STR, err, geom, __FILE__, __LINE__ ) |
| #define | STRINGIFY(S) XSTRINGIFY( S ) |
| #define | XSTRINGIFY(S) #S |
| #define | ARRAY_INOUT(A) A.ptr(), &( A ).capacity(), &( A ).size() |
| #define | ARRAY_IN(A) &( A )[0], ( A ).size() |
Typedefs | |
| typedef iBase_TagHandle | TagHandle |
| typedef iBase_EntityHandle | GentityHandle |
| typedef iBase_EntitySetHandle | GentitysetHandle |
Functions | |
| static bool | print_error (const char *desc, int err, FBiGeom_Instance geom, const char *file, int line) |
| bool | smooth_test (const std::string &filename, FBiGeom_Instance) |
| bool | tags_test (FBiGeom_Instance geom) |
| bool | tag_get_set_test (FBiGeom_Instance geom) |
| bool | tag_info_test (FBiGeom_Instance geom) |
| bool | gentityset_test (FBiGeom_Instance geom, bool, bool) |
| bool | topology_adjacencies_test (FBiGeom_Instance geom) |
| bool | geometry_evaluation_test (FBiGeom_Instance geom) |
| bool | construct_test (FBiGeom_Instance geom) |
| bool | primitives_test (FBiGeom_Instance geom) |
| bool | transforms_test (FBiGeom_Instance geom) |
| bool | booleans_test (FBiGeom_Instance geom) |
| bool | shutdown_test (FBiGeom_Instance geom, std::string &engine_opt) |
| bool | save_entset_test (FBiGeom_Instance geom) |
| bool | mesh_size_test (FBiGeom_Instance geom) |
| bool | normals_test (FBiGeom_Instance geom) |
| bool | ray_test (FBiGeom_Instance geom) |
| void | handle_error_code (const bool result, int &number_failed, int &, int &number_successful) |
| int | main (int argc, char *argv[]) |
| static bool | compare_box (const double *expected_min, const double *expected_max, const double *actual_min, const double *actual_max) |
| static int | get_entities (FBiGeom_Instance geom, int entity_type, std::vector< iBase_EntityHandle > &entities_out, iBase_TagHandle id_tag=0, std::vector< int > *ids_out=0) |
| static int | check_firmness (FBiGeom_Instance geom, const std::vector< iBase_EntityHandle > &entities, const std::vector< int > &ids, iBase_TagHandle firmness_tag, const char *expected_value, const char *ent_type_str) |
| static int | count_num_with_tag (FBiGeom_Instance geom, const std::vector< iBase_EntityHandle > &ents, iBase_TagHandle tag) |
Definition at line 125 of file testSmooth.cpp.
| #define ARRAY_INOUT | ( | A | ) | A.ptr(), &( A ).capacity(), &( A ).size() |
Definition at line 124 of file testSmooth.cpp.
Referenced by normals_test(), and ray_test().
| #define CHECK | ( | STR | ) | if( err != iBase_SUCCESS ) return print_error( STR, err, geom, __FILE__, __LINE__ ) |
Definition at line 25 of file testSmooth.cpp.
Referenced by main(), normals_test(), ray_test(), and smooth_test().
| #define STRINGIFY | ( | S | ) | XSTRINGIFY( S ) |
Definition at line 28 of file testSmooth.cpp.
Referenced by main().
| #define XSTRINGIFY | ( | S | ) | #S |
Definition at line 29 of file testSmooth.cpp.
| typedef iBase_EntityHandle GentityHandle |
Definition at line 46 of file testSmooth.cpp.
Definition at line 47 of file testSmooth.cpp.
| typedef iBase_TagHandle TagHandle |
Definition at line 45 of file testSmooth.cpp.
| bool booleans_test | ( | FBiGeom_Instance | geom | ) |
| static int check_firmness | ( | FBiGeom_Instance | geom, |
| const std::vector< iBase_EntityHandle > & | entities, | ||
| const std::vector< int > & | ids, | ||
| iBase_TagHandle | firmness_tag, | ||
| const char * | expected_value, | ||
| const char * | ent_type_str | ||
| ) | [static] |
Definition at line 1423 of file testSmooth.cpp.
References FBiGeom_getArrData, iBase_FAILURE, and iBase_SUCCESS.
const int firmness_size = 4;
std::vector< char > firmness( firmness_size * entities.size() );
char* byte_ptr = &firmness[0];
int err, junk1 = firmness.size(), junk2 = entities.size() * firmness_size;
FBiGeom_getArrData( geom, &entities[0], entities.size(), firmness_tag, (void**)&byte_ptr, &junk1, &junk2, &err );
if( iBase_SUCCESS != err ) return err;
bool all_correct = true;
for( unsigned i = 0; i < entities.size(); ++i )
if( std::string( &firmness[firmness_size * i], firmness_size ) != expected_value ) all_correct = false;
if( !all_correct )
std::cout << "ERROR: Expected \"" << expected_value << "\" firmness "
<< "for all " << ent_type_str << "." << std::endl;
std::cout << "ID Actual " << std::endl;
std::cout << std::setw( 2 ) << ids[i] << " " << std::string( &firmness[firmness_size * i], firmness_size )
<< std::endl;
return iBase_FAILURE;
return iBase_SUCCESS;
| static bool compare_box | ( | const double * | expected_min, |
| const double * | expected_max, | ||
| const double * | actual_min, | ||
| const double * | actual_max | ||
| ) | [static] |
Definition at line 1212 of file testSmooth.cpp.
bool same = true;
double dtol = 1.0e-6;
for( int i = 0; i < 3; ++i )
if( expected_min[i] < actual_min[i] - dtol || expected_min[i] * 10 > actual_min[i] ||
expected_max[i] > actual_max[i] + dtol || expected_max[i] * 10 < actual_max[i] )
same = false;
return same;
| bool construct_test | ( | FBiGeom_Instance | geom | ) |
| static int count_num_with_tag | ( | FBiGeom_Instance | geom, |
| const std::vector< iBase_EntityHandle > & | ents, | ||
| iBase_TagHandle | tag | ||
| ) | [static] |
Definition at line 1455 of file testSmooth.cpp.
References FBiGeom_getData, FBiGeom_getTagSizeBytes, iBase_SUCCESS, and iBase_TAG_NOT_FOUND.
int err, bytes;
FBiGeom_getTagSizeBytes( geom, tag, &bytes, &err );
if( iBase_SUCCESS != err ) return -1;
std::vector< char > data( bytes );
int success_count = 0;
for( size_t i = 0; i < ents.size(); ++i )
char* ptr = &data[0];
int junk1 = bytes, junk2;
FBiGeom_getData( geom, ents[i], tag, (void**)&ptr, &junk1, &junk2, &err );
if( iBase_TAG_NOT_FOUND == err ) continue;
++success_count;
return success_count;
| bool gentityset_test | ( | FBiGeom_Instance | geom, |
| bool | , | ||
| bool | |||
| bool geometry_evaluation_test | ( | FBiGeom_Instance | geom | ) |
| static int get_entities | ( | FBiGeom_Instance | geom, |
| int | entity_type, | ||
| std::vector< iBase_EntityHandle > & | entities_out, | ||
| iBase_TagHandle | id_tag = 0, |
| std::vector< int > * | ids_out = 0 |
| ) | [static] |
Definition at line 1391 of file testSmooth.cpp.
References FBiGeom_getEntities, FBiGeom_getIntArrData, FBiGeom_getNumOfType, FBiGeom_getRootSet, iBase_SUCCESS, and id_tag.
int err, num;
iBase_EntitySetHandle root;
FBiGeom_getRootSet( geom, &root, &err );
FBiGeom_getNumOfType( geom, root, entity_type, &num, &err );
entities_out.resize( num );
int junk1 = entities_out.size(), junk2;
iBase_EntityHandle* junk_ptr = &entities_out[0];
FBiGeom_getEntities( geom, root, entity_type, &junk_ptr, &junk1, &junk2, &err );
assert( num == junk1 && num == junk2 );
if( !ids_out ) return iBase_SUCCESS;
ids_out->resize( num );
int* int_ptr = &( *ids_out )[0];
FBiGeom_getIntArrData( geom, &entities_out[0], num, id_tag, &int_ptr, &junk1, &junk2, &err );
| void handle_error_code | ( | const bool | result, |
| int & | number_failed, | ||
| int & | , | ||
| int & | number_successful | ||
Definition at line 146 of file testSmooth.cpp.
if( result )
std::cout << "Success";
number_successful++;
else
std::cout << "Failure";
number_failed++;
| int main | ( | int | argc, |
| char * | argv[] | ||
Definition at line 160 of file testSmooth.cpp.
References CHECK, FBiGeom_newGeom, filename, geom, geometry_evaluation_test(), handle_error_code(), normals_test(), number_tests, number_tests_failed, number_tests_successful, ray_test(), shutdown_test(), smooth_test(), STRINGIFY, tags_test(), and topology_adjacencies_test().
std::string filename = STRINGIFY( MESHDIR ) "/shell.h5m";
std::string engine_opt;
if( argc == 1 )
std::cout << "Using default input file: " << filename << std::endl;
else if( argc == 2 )
filename = argv[1];
else
std::cerr << "Usage: " << argv[0] << " [geom_filename]" << std::endl;
return 1;
bool result;
int number_tests = 0;
int number_tests_successful = 0;
int number_tests_not_implemented = 0;
int number_tests_failed = 0;
// initialize the Mesh
int err;
FBiGeom_Instance geom;
FBiGeom_newGeom( engine_opt.c_str(), &geom, &err, engine_opt.length() );
CHECK( "Interface initialization didn't work properly." );
// Print out Header information
std::cout << "\n\nITAPS GEOMETRY INTERFACE TEST PROGRAM:\n\n";
// gLoad test
std::cout << " Smooth faceting load and initialization: \n";
result = smooth_test( filename, geom );
handle_error_code( result, number_tests_failed, number_tests_not_implemented, number_tests_successful );
number_tests++;
std::cout << "\n";
// tags test
std::cout << " tags: ";
result = tags_test( geom );
number_tests++;
std::cout << "\n";
// gentitysets test
std::cout << " gentity sets: ";
result = gentityset_test(geom, false, false);
handle_error_code(result, number_tests_failed,
number_tests_successful);
number_tests++;
std::cout << "\n";
// topology adjacencies test
std::cout << " topology adjacencies: ";
result = topology_adjacencies_test( geom );
number_tests++;
std::cout << "\n";
// geometry evaluation test
std::cout << " geometry evaluation: \n";
result = geometry_evaluation_test( geom );
number_tests++;
std::cout << "\n";
// normals evaluation test
std::cout << " normals geometry evaluation: \n";
result = normals_test( geom );
number_tests++;
std::cout << "\n";
// ray tracing test
std::cout << " ray intersection test: \n";
result = ray_test( geom );
number_tests++;
std::cout << "\n";
// construct test
std::cout << " construct: ";
result = construct_test(geom);
number_tests++;
std::cout << "\n";
// primitives test
std::cout << " primitives: ";
result = primitives_test(geom);
number_tests++;
std::cout << "\n";
// transforms test
std::cout << " transforms: ";
result = transforms_test(geom);
number_tests++;
std::cout << "\n";
// booleans test
std::cout << " booleans: ";
result = booleans_test(geom);
number_tests++;
std::cout << "\n";
#if defined(HAVE_ACIS) && !defined(FORCE_OCC)
std::cout << " mesh size: ";
result = mesh_size_test(geom);
number_tests++;
std::cout << "\n";
// save entset test
std::cout << " save entset: ";
result = save_entset_test(geom);
number_tests++;
std::cout << "\n";
#endif
// shutdown test
std::cout << " shutdown: ";
result = shutdown_test( geom, engine_opt );
number_tests++;
std::cout << "\n";
// summary
std::cout << "\nTSTT TEST SUMMARY: \n"
<< " Number Tests: " << number_tests << "\n"
<< " Number Successful: " << number_tests_successful << "\n"
<< " Number Not Implemented: " << number_tests_not_implemented << "\n"
<< " Number Failed: " << number_tests_failed << "\n\n"
<< std::endl;
return number_tests_failed;
| bool mesh_size_test | ( | FBiGeom_Instance | geom | ) |
| bool normals_test | ( | FBiGeom_Instance | geom | ) |
Definition at line 1050 of file testSmooth.cpp.
References ARRAY_INOUT, SimpleArray< T >::begin(), CHECK, SimpleArray< T >::end(), FBiGeom_getEntBoundBox, FBiGeom_getEntities, FBiGeom_getEntNrmlXYZ, FBiGeom_getRootSet, iBase_ALL_TYPES, iBase_EDGE, iBase_VERTEX, root_set, and SimpleArray< T >::size().
Referenced by check_split(), main(), and split_quads_test().
int i, err;
iBase_EntitySetHandle root_set;
FBiGeom_getRootSet( geom, &root_set, &err );
CHECK( "ERROR : getRootSet failed!" );
int top = iBase_VERTEX;
int num_test_top = iBase_ALL_TYPES;
std::vector< std::vector< iBase_EntityHandle > > gentity_vectors( num_test_top );
// fill the vectors of each topology entities
// like lines vector, polygon vector, triangle vector,
// quadrilateral, polyhedrron, tet, hex, prism, pyramid,
// septahedron vectors
for( i = top; i < num_test_top; i++ )
SimpleArray< iBase_EntityHandle > gentities;
FBiGeom_getEntities( geom, root_set, i, ARRAY_INOUT( gentities ), &err );
CHECK( "Failed to get gentities in adjacencies_test." );
gentity_vectors[i].resize( gentities.size() );
std::copy( gentities.begin(), gentities.end(), gentity_vectors[i].begin() );
// check adjacencies in both directions
double min[3], max[3];
double normal[3] = { .0, .0, .0 };
std::vector< iBase_EntityHandle >::iterator vit;
for( i = iBase_REGION; i > iBase_EDGE; i-- )
for( vit = gentity_vectors[i].begin(); vit != gentity_vectors[i].end(); ++vit )
iBase_EntityHandle this_gent = *vit;
FBiGeom_getEntBoundBox( geom, this_gent, &min[0], &min[1], &min[2], &max[0], &max[1], &max[2], &err );
CHECK( "Failed to get bounding box of entity." );
FBiGeom_getEntNrmlXYZ( geom, this_gent, ( max[0] + min[0] ) / 2, ( max[1] + min[1] ) / 2,
( max[2] + min[2] ) / 2, &normal[0], &normal[1], &normal[2], &err );
CHECK( "Failed to get normal to the closest point." );
std::cout << " entity of type " << i << " closest normal to center:\n " << normal[0] << " " << normal[1]
<< " " << normal[2] << "\n";
return true;
| bool primitives_test | ( | FBiGeom_Instance | geom | ) |
| static bool print_error | ( | const char * | desc, |
| int | err, | ||
| FBiGeom_Instance | geom, | ||
| const char * | file, | ||
| int | line | ||
| ) | [static] |
Definition at line 31 of file testSmooth.cpp.
References buffer, and FBiGeom_getDescription.
char buffer[1024];
FBiGeom_getDescription( geom, buffer, sizeof( buffer ) );
buffer[sizeof( buffer ) - 1] = '\0';
std::cerr << "ERROR: " << desc << std::endl
<< " Error code: " << err << std::endl
<< " Error desc: " << buffer << std::endl
<< " At : " << file << ':' << line << std::endl;
return false; // must always return false or CHECK macro will break
| bool ray_test | ( | FBiGeom_Instance | geom | ) |
Definition at line 1100 of file testSmooth.cpp.
References ARRAY_INOUT, CHECK, FBiGeom_getEntBoundBox, FBiGeom_getEntities, FBiGeom_getEntType, FBiGeom_getPntRayIntsct, FBiGeom_getRootSet, iBase_FACE, iBase_INTERLEAVED, root_set, and SimpleArray< T >::size().
int err;
int top = iBase_FACE;
SimpleArray< iBase_EntityHandle > faces;
FBiGeom_getEntities( geom, root_set, top, ARRAY_INOUT( faces ), &err );
// check only the first face
iBase_EntityHandle first_face = faces[0];
FBiGeom_getEntBoundBox( geom, first_face, &min[0], &min[1], &min[2], &max[0], &max[1], &max[2], &err );
// assume that the ray shot from the bottom of the box (middle) is a pretty good candidate
// in z direction
double x = ( min[0] + max[0] ) / 2, y = ( min[1] + max[1] ) / 2, z = min[2];
SimpleArray< iBase_EntityHandle > intersect_entity_handles;
SimpleArray< double > intersect_coords;
SimpleArray< double > param_coords;
FBiGeom_getPntRayIntsct( geom, x, y, z, // shot from
0., 0., 1., // direction
ARRAY_INOUT( intersect_entity_handles ), iBase_INTERLEAVED,
ARRAY_INOUT( intersect_coords ), ARRAY_INOUT( param_coords ), &err );
CHECK( "Failed to find ray intersections points " );
for( int i = 0; i < intersect_entity_handles.size(); i++ )
int j;
FBiGeom_getEntType( geom, intersect_entity_handles[i], &j, &err );
CHECK( "Failed to get type of entity." );
std::cout << " entity of type " << j << " n: " << intersect_entity_handles[i] << "\n"
<< intersect_coords[3 * i] << " " << intersect_coords[3 * i + 1] << " " << intersect_coords[3 * i + 2]
<< "\n"
<< " distance: " << param_coords[i] << "\n";
return true;
| bool save_entset_test | ( | FBiGeom_Instance | geom | ) |
| bool shutdown_test | ( | FBiGeom_Instance | geom, |
| std::string & | engine_opt | ||
| bool smooth_test | ( | const std::string & | filename, |
| FBiGeom_Instance | geom | ||
Definition at line 326 of file testSmooth.cpp.
References CHECK, FBiGeom_getNumOfType, FBiGeom_getRootSet, FBiGeom_load, and root_set.
int err;
char opts[] = "SMOOTH;";
FBiGeom_load( geom, &filename[0], opts, &err, filename.length(), 8 );
// FBiGeom_load( geom, &filename[0], 0, &err, filename.length(), 0 );
CHECK( "ERROR : can not load a geometry" );
// print out the number of entities
std::cout << "Model contents: " << std::endl;
const char* gtype[] = { "vertices: ", "edges: ", "faces: ", "regions: " };
for( int i = 0; i <= 3; ++i )
int count;
FBiGeom_getNumOfType( geom, root_set, i, &count, &err );
CHECK( "Error: problem getting entities after gLoad." );
std::cout << gtype[i] << count << std::endl;
return true;
| bool tag_get_set_test | ( | FBiGeom_Instance | geom | ) |
| bool tag_info_test | ( | FBiGeom_Instance | geom | ) |
| bool tags_test | ( | FBiGeom_Instance | geom | ) |
| bool topology_adjacencies_test | ( | FBiGeom_Instance | geom | ) |
| bool transforms_test | ( | FBiGeom_Instance | geom | ) |
