MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include <iostream> 00002 #include "moab/Interface.hpp" 00003 #ifndef IS_BUILDING_MB 00004 #define IS_BUILDING_MB 00005 #endif 00006 #include "Internals.hpp" 00007 #include "moab/ReadUtilIface.hpp" 00008 #include "moab/Core.hpp" 00009 #include "moab/Range.hpp" 00010 00011 using namespace moab; 00012 00013 #define CHKERR( A ) \ 00014 do \ 00015 { \ 00016 if( MB_SUCCESS != ( A ) ) \ 00017 { \ 00018 std::cerr << "Failure (error code " << ( A ) << ") at " __FILE__ ":" << __LINE__ << std::endl; \ 00019 return A; \ 00020 } \ 00021 } while( false ) 00022 00023 ErrorCode gather_related_test() 00024 { 00025 // create an entityset structure and test related entities function 00026 // sets: A 00027 // | 00028 // B C 00029 // |/ | 00030 // D E 00031 // if D is passed in to gather_related_ents, A-D should be returned, and E should not be 00032 // 00033 EntityHandle A, B, C, D, E; 00034 Core mb; 00035 ErrorCode rval = mb.create_meshset( MESHSET_SET, A );CHKERR( rval ); 00036 rval = mb.create_meshset( MESHSET_SET, B );CHKERR( rval ); 00037 rval = mb.create_meshset( MESHSET_SET, C );CHKERR( rval ); 00038 rval = mb.create_meshset( MESHSET_SET, D );CHKERR( rval ); 00039 rval = mb.create_meshset( MESHSET_SET, E );CHKERR( rval ); 00040 00041 rval = mb.add_parent_child( A, B );CHKERR( rval ); 00042 rval = mb.add_parent_child( B, D );CHKERR( rval ); 00043 rval = mb.add_parent_child( C, D );CHKERR( rval ); 00044 rval = mb.add_parent_child( C, E );CHKERR( rval ); 00045 00046 // now test it 00047 ReadUtilIface* readMeshIface; 00048 mb.Interface::query_interface( readMeshIface ); 00049 00050 Range init_range, set_range, all_sets( A, E ); 00051 init_range.insert( D ); 00052 rval = readMeshIface->gather_related_ents( init_range, set_range );CHKERR( rval ); 00053 00054 if( set_range.size() != 4 ) return MB_FAILURE; 00055 all_sets -= set_range; 00056 if( 1 != all_sets.size() || *all_sets.begin() != E ) return MB_FAILURE; 00057 00058 return MB_SUCCESS; 00059 } 00060 00061 int number_tests = 0; 00062 int number_tests_failed = 0; 00063 #define RUN_TEST( A ) _run_test( ( A ), #A ) 00064 00065 typedef ErrorCode ( *TestFunc )(); 00066 static void _run_test( TestFunc func, const char* func_str ) 00067 { 00068 ++number_tests; 00069 std::cout << " " << func_str << ": "; 00070 std::cout.flush(); 00071 ErrorCode error = func(); 00072 00073 if( MB_SUCCESS == error ) 00074 std::cout << "Success" << std::endl; 00075 else if( MB_FAILURE == error ) 00076 std::cout << "Failure" << std::endl; 00077 else 00078 { 00079 Core moab; 00080 std::cout << "Failed: " << moab.get_error_string( error ) << std::endl; 00081 } 00082 00083 if( MB_SUCCESS != error ) 00084 { 00085 ++number_tests_failed; 00086 } 00087 } 00088 00089 int main( int /*argc*/, char** /*argv[]*/ ) 00090 { 00091 RUN_TEST( gather_related_test ); 00092 00093 std::cout << "\nMB TEST SUMMARY: \n" 00094 << " Number Tests: " << number_tests << "\n" 00095 << " Number Successful: " << number_tests - number_tests_failed << "\n" 00096 << " Number Failed: " << number_tests_failed << "\n\n"; 00097 00098 return number_tests_failed; 00099 }
