MOAB: Mesh Oriented datABase
(version 5.4.1)
Include dependency graph for range_test.cpp:Go to the source code of this file.
Functions | |
| void | insert_hint_test () |
| void | intersect_test () |
| void | merge_test () |
| void | const_pair_iterator_test () |
| void | swap_test () |
| void | subtract_test () |
| void | subset_by_dimension_test () |
| void | erase_test () |
| void | contains_test () |
| int | main () |
Variables | |
| const EntityHandle | h1 = CREATE_HANDLE( MBVERTEX, 1 ) |
| const EntityHandle | h4 = CREATE_HANDLE( MBVERTEX, 4 ) |
| const EntityHandle | h5 = CREATE_HANDLE( MBVERTEX, 5 ) |
| const EntityHandle | h9 = CREATE_HANDLE( MBVERTEX, 9 ) |
| const EntityHandle | h10 = CREATE_HANDLE( MBVERTEX, 10 ) |
| const EntityHandle | h15 = CREATE_HANDLE( MBVERTEX, 15 ) |
| const EntityHandle | h16 = CREATE_HANDLE( MBVERTEX, 16 ) |
| const EntityHandle | h20 = CREATE_HANDLE( MBVERTEX, 20 ) |
| const EntityHandle | hh1 = CREATE_HANDLE( MBHEX, 1 ) |
| const EntityHandle | hh3 = CREATE_HANDLE( MBHEX, 3 ) |
| void const_pair_iterator_test | ( | ) |
Definition at line 157 of file range_test.cpp.
References CHECK_EQUAL, moab::Range::const_pair_begin(), h1, h4, h5, and moab::Range::insert().
Referenced by main().
// const_pair_iterator test
Range r1;
r1.insert( h1 );
r1.insert( h4 );
r1.insert( h5 );
Range::const_pair_iterator pair_iter = r1.const_pair_begin();
EntityHandle cpi_h1 = ( *pair_iter ).first;
EntityHandle cpi_h2 = ( *pair_iter ).second;
++pair_iter;
EntityHandle cpi_h3 = ( *pair_iter ).first;
EntityHandle cpi_h4 = ( *pair_iter ).second;
++pair_iter;
CHECK_EQUAL( cpi_h1, h1 );
CHECK_EQUAL( cpi_h2, h1 );
CHECK_EQUAL( cpi_h3, h4 );
CHECK_EQUAL( cpi_h4, h5 );
| void contains_test | ( | ) |
Definition at line 438 of file range_test.cpp.
References CHECK, moab::Range::clear(), moab::Range::contains(), moab::Range::erase(), and moab::Range::insert().
Range r1, r2;
// simple test cases: one range each
r1.clear();
r2.clear();
r1.insert( 1, 20 );
r2.insert( 1, 21 );
CHECK( !r1.contains( r2 ) );
CHECK( r2.contains( r1 ) );
r1.clear();
r2.clear();
r1.insert( 2, 20 );
r2.insert( 1, 20 );
r1.clear();
r2.clear();
r1.insert( 5 );
r2.insert( 1, 6 );
r1.clear();
r2.clear();
r1.insert( 5 );
r2.insert( 6 );
CHECK( !r2.contains( r1 ) );
r1.clear();
r2.clear();
r1.insert( 18 );
r2.insert( 18 );
CHECK( r1.contains( r2 ) );
// empty range test cases
r1.clear();
r2.clear();
r1.clear();
r2.clear();
r1.insert( 18 );
// slightly more complex tests: one range in one container
// and multiple in the other
r1.clear();
r1.insert( 10, 100 );
r2.clear();
r2.insert( 20, 30 );
r2.insert( 40, 50 );
r2.insert( 10, 12 );
r2.insert( 90, 100 );
r2.insert( 9 );
r2.erase( 9 );
r2.insert( 101 );
r2.erase( 101 );
r2.insert( 103, 110 );
r2.insert( 1, 5 );
// most complex case: both containers have several ranges
r1.clear();
r1.insert( 10, 30 );
r1.insert( 40, 50 );
r1.insert( 90, 100 );
r2.clear();
r2.insert( 9 );
r2.erase( 9 );
r2.insert( 101 );
r2.erase( 101 );
r2.insert( 1, 5 );
| void erase_test | ( | ) |
Definition at line 275 of file range_test.cpp.
References moab::Range::back(), moab::Range::begin(), CHECK, CHECK_EQUAL, moab::Range::clear(), moab::Range::end(), moab::Range::erase(), moab::Range::front(), moab::Range::insert(), and moab::Range::size().
Range range;
Range::iterator result;
// test erase from first node
range.clear();
range.insert( 5, 10 );
range.insert( 12, 20 );
result = range.erase( range.begin(), range.begin() + 2 );
CHECK_EQUAL( (EntityHandle)7, range.front() );
CHECK_EQUAL( (EntityHandle)20, range.back() );
CHECK_EQUAL( (size_t)13, range.size() );
CHECK_EQUAL( (EntityHandle)7, *result );
// test erase first node
range.clear();
result = range.erase( range.begin(), range.begin() + 6 );
CHECK_EQUAL( (EntityHandle)12, range.front() );
CHECK_EQUAL( (size_t)9, range.size() );
CHECK_EQUAL( (EntityHandle)12, *result );
// test erase from back of first node
range.clear();
result = range.erase( range.begin() + 2, range.begin() + 6 );
CHECK_EQUAL( (EntityHandle)5, range.front() );
CHECK_EQUAL( (size_t)11, range.size() );
// test erase from middle of first node
range.clear();
result = range.erase( range.begin() + 2, range.begin() + 5 );
CHECK_EQUAL( (size_t)12, range.size() );
CHECK_EQUAL( (EntityHandle)10, *result );
// test erase spanning two nodes
range.clear();
result = range.erase( range.begin() + 3, range.begin() + 7 );
CHECK_EQUAL( (EntityHandle)13, *result );
// test erase of first node and part of second
range.clear();
result = range.erase( range.begin(), range.begin() + 7 );
CHECK_EQUAL( (EntityHandle)13, range.front() );
CHECK_EQUAL( (size_t)8, range.size() );
// test erase spanning three nodes
range.clear();
range.insert( 100, 101 );
result = range.erase( range.begin() + 3, range.begin() + 16 );
CHECK_EQUAL( (EntityHandle)101, range.back() );
CHECK_EQUAL( (size_t)4, range.size() );
CHECK_EQUAL( (EntityHandle)101, *result );
// test erase from start of second node
range.clear();
result = range.erase( range.begin() + 6, range.begin() + 8 );
CHECK_EQUAL( (EntityHandle)14, *result );
// test erase from back of last node
range.clear();
result = range.erase( range.begin() + 13, range.end() );
CHECK_EQUAL( (EntityHandle)18, range.back() );
CHECK( result == range.end() );
// test erase part of first node through end
range.clear();
result = range.erase( range.begin() + 4, range.end() );
CHECK_EQUAL( (EntityHandle)8, range.back() );
// test erase of single node
range.clear();
result = range.erase( range.begin(), range.end() );
CHECK_EQUAL( (size_t)0, range.size() );
// test erase of multi-node range
range.clear();
// test erase nothing
range.clear();
result = range.erase( range.begin() + 3, range.begin() + 3 );
CHECK_EQUAL( (size_t)15, range.size() );
CHECK_EQUAL( (EntityHandle)8, *result );
// test iterators before erase remain valid
Range::iterator a, b, c;
range.clear();
a = range.begin();
b = range.begin() + 6;
c = range.begin() + 8;
result = range.erase( range.begin() + 9, range.end() );
CHECK( a == range.begin() );
CHECK( b == range.begin() + 6 );
CHECK( c == range.begin() + 8 );
// test iterators before erase remain valid, single value case
range.clear();
a = range.begin();
result = range.erase( range.begin() + 9 );
CHECK_EQUAL( (size_t)14, range.size() );
CHECK_EQUAL( (EntityHandle)16, *result );
| void insert_hint_test | ( | ) |
Definition at line 31 of file range_test.cpp.
References moab::Range::begin(), CHECK, CHECK_EQUAL, moab::Range::const_pair_begin(), moab::Range::const_pair_end(), and moab::Range::insert().
const EntityHandle pairs[][2] = { { 4980, 4981 }, { 4985, 4986 }, { 4990, 4990 }, { 5886, 5886 }, { 5888, 5890 },
{ 5890, 5890 }, { 5886, 5888 }, { 5890, 5890 }, { 5894, 5894 }, { 5899, 5899 } };
const int num_pairs = sizeof( pairs ) / sizeof( pairs[0] );
const EntityHandle exp_pairs[][2] = { { 4980, 4981 }, { 4985, 4986 }, { 4990, 4990 },
{ 5886, 5890 }, { 5894, 5894 }, { 5899, 5899 } };
const int num_exp = sizeof( exp_pairs ) / sizeof( exp_pairs[0] );
Range range;
Range::iterator it = range.begin();
for( int i = 0; i < num_pairs; ++i )
it = range.insert( it, pairs[i][0], pairs[i][1] );
Range::const_pair_iterator pit = range.const_pair_begin();
for( int i = 0; i < num_exp; ++i )
CHECK( pit != range.const_pair_end() );
CHECK_EQUAL( exp_pairs[i][0], pit->first );
CHECK_EQUAL( exp_pairs[i][1], pit->second );
++pit;
CHECK( pit == range.const_pair_end() );
| void intersect_test | ( | ) |
Definition at line 68 of file range_test.cpp.
References CHECK, CHECK_EQUAL, moab::Range::clear(), moab::Range::empty(), h1, h10, h15, h16, h20, h4, h5, h9, moab::Range::insert(), moab::intersect(), and moab::Range::size().
Range r1, r2, rhs;
// equal start/end
r1.insert( h1, h5 );
r1.insert( h10, h15 );
r2.insert( h5, h10 );
r2.insert( h15, h20 );
rhs = intersect( r1, r2 );
CHECK_EQUAL( (size_t)3, rhs.size() );
// identical ranges test
r1.clear();
r2.clear();
rhs.clear();
r1.insert( h10, h20 );
r2.insert( h1, h5 );
r2.insert( h10, h20 );
CHECK_EQUAL( r1.size(), rhs.size() );
CHECK_EQUAL( r2.size(), rhs.size() );
// off by one test
r1.clear();
r2.clear();
rhs.clear();
r1.insert( h1, h4 );
r2.insert( h5, h9 );
r2.insert( h16, h20 );
CHECK( rhs.empty() );
// interior test
r1.clear();
r2.clear();
rhs.clear();
r1.insert( h1, h20 );
// half-above test
r1.clear();
r2.clear();
rhs.clear();
r1.insert( h1, h10 );
r2.insert( h5, h20 );
CHECK_EQUAL( (size_t)( h10 - h5 + 1 ), rhs.size() );
// half-below test
r1.clear();
r2.clear();
rhs.clear();
r1.insert( h5, h20 );
r2.insert( h1, h10 );
| int main | ( | ) |
Definition at line 16 of file range_test.cpp.
References const_pair_iterator_test(), contains_test(), erase_test(), insert_hint_test(), intersect_test(), merge_test(), RUN_TEST, subset_by_dimension_test(), subtract_test(), and swap_test().
int rval = 0;
rval += RUN_TEST( insert_hint_test );
rval += RUN_TEST( intersect_test );
rval += RUN_TEST( merge_test );
rval += RUN_TEST( const_pair_iterator_test );
rval += RUN_TEST( swap_test );
rval += RUN_TEST( subtract_test );
rval += RUN_TEST( subset_by_dimension_test );
rval += RUN_TEST( erase_test );
rval += RUN_TEST( contains_test );
return rval;
| void merge_test | ( | ) |
Definition at line 131 of file range_test.cpp.
References moab::Range::begin(), CHECK_EQUAL, moab::Range::clear(), moab::Range::end(), h1, h10, h15, h5, moab::Range::insert(), moab::Range::merge(), and moab::Range::size().
Range r1, r2;
// merge all test
r1.clear();
r2.clear();
r2 = r1;
r1.merge( r2 );
CHECK_EQUAL( r2.size(), r1.size() );
// merge subset test
r1.clear();
r2.clear();
Range::const_iterator i1 = r1.begin();
Range::const_iterator i2 = r1.end();
i1 += 2;
i2 -= 2;
r2.merge( i1, i2 );
CHECK_EQUAL( r1.size() - 4, r2.size() );
| void subset_by_dimension_test | ( | ) |
Definition at line 260 of file range_test.cpp.
References moab::Range::back(), CHECK_EQUAL, moab::Range::front(), h1, h4, hh1, hh3, moab::Range::insert(), moab::Range::size(), and moab::Range::subset_by_dimension().
Range r1, r2;
// subset_by_dimension test
r1.insert( h1 );
r1.insert( h4 );
r1.insert( hh1 );
r1.insert( hh3 );
r2 = r1.subset_by_dimension( 3 );
CHECK_EQUAL( (size_t)2, r2.size() );
CHECK_EQUAL( hh1, r2.front() );
CHECK_EQUAL( hh3, r2.back() );
| void subtract_test | ( | ) |
Definition at line 231 of file range_test.cpp.
References CHECK, CHECK_EQUAL, moab::Range::clear(), moab::Range::end(), moab::Range::find(), h1, h4, h5, moab::Range::insert(), moab::Range::size(), and moab::subtract().
Range r1, r2, r3;
r1.clear();
r2.clear();
r1.insert( h1 );
r1.insert( h4 );
r1.insert( h5 );
r2.insert( h4 );
r3 = subtract( r1, r2 );
CHECK_EQUAL( (size_t)2, r3.size() );
CHECK( r3.find( h1 ) != r3.end() );
CHECK( r3.find( h5 ) != r3.end() );
CHECK( r3.find( h4 ) == r3.end() );
// destination empty
r1.clear();
r2.clear();
r1.insert( h1 );
r1.insert( h4 );
r1.insert( h5 );
CHECK_EQUAL( (size_t)3, r3.size() );
CHECK( r3.find( h4 ) != r3.end() );
| void swap_test | ( | ) |
Definition at line 178 of file range_test.cpp.
References CHECK, CHECK_EQUAL, moab::Range::clear(), moab::Range::empty(), moab::Range::end(), moab::Range::find(), h1, h4, h5, h9, moab::Range::insert(), moab::Range::size(), and moab::Range::swap().
Range r1, r2;
// both non-empty
r1.clear();
r2.clear();
r1.insert( h1 );
r1.insert( h4 );
r1.insert( h5 );
r2.insert( h9 );
r1.swap( r2 );
CHECK_EQUAL( (size_t)1, r1.size() );
CHECK_EQUAL( (size_t)3, r2.size() );
CHECK( r1.find( h9 ) != r1.end() );
CHECK( r2.find( h1 ) != r2.end() );
CHECK( r2.find( h4 ) != r2.end() );
CHECK( r2.find( h5 ) != r2.end() );
r1.clear();
r2.clear();
r2.insert( h1 );
r2.insert( h4 );
r2.insert( h5 );
r1.swap( r2 );
CHECK_EQUAL( (size_t)3, r1.size() );
CHECK_EQUAL( (size_t)0, r2.size() );
CHECK( r1.find( h1 ) != r1.end() );
CHECK( r1.find( h4 ) != r1.end() );
CHECK( r1.find( h5 ) != r1.end() );
// source empty
r1.clear();
r2.clear();
r1.insert( h1 );
r1.insert( h4 );
r1.insert( h5 );
r1.swap( r2 );
CHECK_EQUAL( (size_t)0, r1.size() );
// both empty
r1.clear();
r2.clear();
r1.swap( r2 );
CHECK( r1.empty() );
CHECK( r2.empty() );
| const EntityHandle h1 = CREATE_HANDLE( MBVERTEX, 1 ) |
Definition at line 57 of file range_test.cpp.
Referenced by const_pair_iterator_test(), intersect_test(), mb_type_is_maxtype_test(), merge_test(), moab::EntityRefinerOutputFunctor::operator()(), moab::OrientedBoxTreeTool::TrvStats::print(), moab::SimplexTemplateRefiner::refine_3_simplex(), subset_by_dimension_test(), subtract_test(), swap_test(), test_get_set(), test_get_set_bit(), test_get_set_variable_length(), and test_read_adjacencies().
| const EntityHandle h10 = CREATE_HANDLE( MBVERTEX, 10 ) |
Definition at line 61 of file range_test.cpp.
Referenced by intersect_test(), and merge_test().
| const EntityHandle h15 = CREATE_HANDLE( MBVERTEX, 15 ) |
Definition at line 62 of file range_test.cpp.
| const EntityHandle h16 = CREATE_HANDLE( MBVERTEX, 16 ) |
Definition at line 63 of file range_test.cpp.
Referenced by intersect_test().
| const EntityHandle h20 = CREATE_HANDLE( MBVERTEX, 20 ) |
Definition at line 64 of file range_test.cpp.
| const EntityHandle h4 = CREATE_HANDLE( MBVERTEX, 4 ) |
Definition at line 58 of file range_test.cpp.
Referenced by const_pair_iterator_test(), intersect_test(), moab::OrientedBoxTreeTool::TrvStats::print(), subset_by_dimension_test(), subtract_test(), and swap_test().
| const EntityHandle h5 = CREATE_HANDLE( MBVERTEX, 5 ) |
Definition at line 59 of file range_test.cpp.
Referenced by const_pair_iterator_test(), intersect_test(), merge_test(), subtract_test(), and swap_test().
| const EntityHandle h9 = CREATE_HANDLE( MBVERTEX, 9 ) |
Definition at line 60 of file range_test.cpp.
Referenced by intersect_test(), and swap_test().
| const EntityHandle hh1 = CREATE_HANDLE( MBHEX, 1 ) |
Definition at line 65 of file range_test.cpp.
Referenced by subset_by_dimension_test().
| const EntityHandle hh3 = CREATE_HANDLE( MBHEX, 3 ) |
Definition at line 66 of file range_test.cpp.
