MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "moab/Range.hpp" 00002 #include "TestUtil.hpp" 00003 00004 using namespace moab; 00005 00006 void insert_hint_test(); 00007 void intersect_test(); 00008 void merge_test(); 00009 void const_pair_iterator_test(); 00010 void swap_test(); 00011 void subtract_test(); 00012 void subset_by_dimension_test(); 00013 void erase_test(); 00014 void contains_test(); 00015 00016 int main() 00017 { 00018 int rval = 0; 00019 rval += RUN_TEST( insert_hint_test ); 00020 rval += RUN_TEST( intersect_test ); 00021 rval += RUN_TEST( merge_test ); 00022 rval += RUN_TEST( const_pair_iterator_test ); 00023 rval += RUN_TEST( swap_test ); 00024 rval += RUN_TEST( subtract_test ); 00025 rval += RUN_TEST( subset_by_dimension_test ); 00026 rval += RUN_TEST( erase_test ); 00027 rval += RUN_TEST( contains_test ); 00028 return rval; 00029 } 00030 00031 void insert_hint_test() 00032 { 00033 const EntityHandle pairs[][2] = { { 4980, 4981 }, { 4985, 4986 }, { 4990, 4990 }, { 5886, 5886 }, { 5888, 5890 }, 00034 { 5890, 5890 }, { 5886, 5888 }, { 5890, 5890 }, { 5894, 5894 }, { 5899, 5899 } }; 00035 const int num_pairs = sizeof( pairs ) / sizeof( pairs[0] ); 00036 const EntityHandle exp_pairs[][2] = { { 4980, 4981 }, { 4985, 4986 }, { 4990, 4990 }, 00037 { 5886, 5890 }, { 5894, 5894 }, { 5899, 5899 } }; 00038 const int num_exp = sizeof( exp_pairs ) / sizeof( exp_pairs[0] ); 00039 00040 Range range; 00041 Range::iterator it = range.begin(); 00042 for( int i = 0; i < num_pairs; ++i ) 00043 it = range.insert( it, pairs[i][0], pairs[i][1] ); 00044 00045 Range::const_pair_iterator pit = range.const_pair_begin(); 00046 for( int i = 0; i < num_exp; ++i ) 00047 { 00048 CHECK( pit != range.const_pair_end() ); 00049 CHECK_EQUAL( exp_pairs[i][0], pit->first ); 00050 CHECK_EQUAL( exp_pairs[i][1], pit->second ); 00051 ++pit; 00052 } 00053 CHECK( pit == range.const_pair_end() ); 00054 } 00055 00056 // common constants used for a bunch of tests below 00057 const EntityHandle h1 = CREATE_HANDLE( MBVERTEX, 1 ); 00058 const EntityHandle h4 = CREATE_HANDLE( MBVERTEX, 4 ); 00059 const EntityHandle h5 = CREATE_HANDLE( MBVERTEX, 5 ); 00060 const EntityHandle h9 = CREATE_HANDLE( MBVERTEX, 9 ); 00061 const EntityHandle h10 = CREATE_HANDLE( MBVERTEX, 10 ); 00062 const EntityHandle h15 = CREATE_HANDLE( MBVERTEX, 15 ); 00063 const EntityHandle h16 = CREATE_HANDLE( MBVERTEX, 16 ); 00064 const EntityHandle h20 = CREATE_HANDLE( MBVERTEX, 20 ); 00065 const EntityHandle hh1 = CREATE_HANDLE( MBHEX, 1 ); 00066 const EntityHandle hh3 = CREATE_HANDLE( MBHEX, 3 ); 00067 00068 void intersect_test() 00069 { 00070 Range r1, r2, rhs; 00071 00072 // equal start/end 00073 r1.insert( h1, h5 ); 00074 r1.insert( h10, h15 ); 00075 r2.insert( h5, h10 ); 00076 r2.insert( h15, h20 ); 00077 rhs = intersect( r1, r2 ); 00078 CHECK_EQUAL( (size_t)3, rhs.size() ); 00079 00080 // identical ranges test 00081 r1.clear(); 00082 r2.clear(); 00083 rhs.clear(); 00084 r1.insert( h1, h5 ); 00085 r1.insert( h10, h20 ); 00086 r2.insert( h1, h5 ); 00087 r2.insert( h10, h20 ); 00088 rhs = intersect( r1, r2 ); 00089 CHECK_EQUAL( r1.size(), rhs.size() ); 00090 CHECK_EQUAL( r2.size(), rhs.size() ); 00091 00092 // off by one test 00093 r1.clear(); 00094 r2.clear(); 00095 rhs.clear(); 00096 r1.insert( h1, h4 ); 00097 r1.insert( h10, h15 ); 00098 r2.insert( h5, h9 ); 00099 r2.insert( h16, h20 ); 00100 rhs = intersect( r1, r2 ); 00101 CHECK( rhs.empty() ); 00102 00103 // interior test 00104 r1.clear(); 00105 r2.clear(); 00106 rhs.clear(); 00107 r1.insert( h1, h20 ); 00108 r2.insert( h5, h10 ); 00109 rhs = intersect( r1, r2 ); 00110 CHECK_EQUAL( r2.size(), rhs.size() ); 00111 00112 // half-above test 00113 r1.clear(); 00114 r2.clear(); 00115 rhs.clear(); 00116 r1.insert( h1, h10 ); 00117 r2.insert( h5, h20 ); 00118 rhs = intersect( r1, r2 ); 00119 CHECK_EQUAL( (size_t)( h10 - h5 + 1 ), rhs.size() ); 00120 00121 // half-below test 00122 r1.clear(); 00123 r2.clear(); 00124 rhs.clear(); 00125 r1.insert( h5, h20 ); 00126 r2.insert( h1, h10 ); 00127 rhs = intersect( r1, r2 ); 00128 CHECK_EQUAL( (size_t)( h10 - h5 + 1 ), rhs.size() ); 00129 } 00130 00131 void merge_test() 00132 { 00133 Range r1, r2; 00134 00135 // merge all test 00136 r1.clear(); 00137 r2.clear(); 00138 r1.insert( h1, h5 ); 00139 r1.insert( h10, h15 ); 00140 r2 = r1; 00141 r1.merge( r2 ); 00142 CHECK_EQUAL( r2.size(), r1.size() ); 00143 00144 // merge subset test 00145 r1.clear(); 00146 r2.clear(); 00147 r1.insert( h1, h5 ); 00148 r1.insert( h10, h15 ); 00149 Range::const_iterator i1 = r1.begin(); 00150 Range::const_iterator i2 = r1.end(); 00151 i1 += 2; 00152 i2 -= 2; 00153 r2.merge( i1, i2 ); 00154 CHECK_EQUAL( r1.size() - 4, r2.size() ); 00155 } 00156 00157 void const_pair_iterator_test() 00158 { 00159 // const_pair_iterator test 00160 Range r1; 00161 r1.insert( h1 ); 00162 r1.insert( h4 ); 00163 r1.insert( h5 ); 00164 Range::const_pair_iterator pair_iter = r1.const_pair_begin(); 00165 EntityHandle cpi_h1 = ( *pair_iter ).first; 00166 EntityHandle cpi_h2 = ( *pair_iter ).second; 00167 ++pair_iter; 00168 EntityHandle cpi_h3 = ( *pair_iter ).first; 00169 EntityHandle cpi_h4 = ( *pair_iter ).second; 00170 00171 ++pair_iter; 00172 CHECK_EQUAL( cpi_h1, h1 ); 00173 CHECK_EQUAL( cpi_h2, h1 ); 00174 CHECK_EQUAL( cpi_h3, h4 ); 00175 CHECK_EQUAL( cpi_h4, h5 ); 00176 } 00177 00178 void swap_test() 00179 { 00180 Range r1, r2; 00181 00182 // both non-empty 00183 r1.clear(); 00184 r2.clear(); 00185 r1.insert( h1 ); 00186 r1.insert( h4 ); 00187 r1.insert( h5 ); 00188 r2.insert( h9 ); 00189 r1.swap( r2 ); 00190 CHECK_EQUAL( (size_t)1, r1.size() ); 00191 CHECK_EQUAL( (size_t)3, r2.size() ); 00192 CHECK( r1.find( h9 ) != r1.end() ); 00193 CHECK( r2.find( h1 ) != r2.end() ); 00194 CHECK( r2.find( h4 ) != r2.end() ); 00195 CHECK( r2.find( h5 ) != r2.end() ); 00196 00197 // destination empty 00198 r1.clear(); 00199 r2.clear(); 00200 r2.insert( h1 ); 00201 r2.insert( h4 ); 00202 r2.insert( h5 ); 00203 r1.swap( r2 ); 00204 CHECK_EQUAL( (size_t)3, r1.size() ); 00205 CHECK_EQUAL( (size_t)0, r2.size() ); 00206 CHECK( r1.find( h1 ) != r1.end() ); 00207 CHECK( r1.find( h4 ) != r1.end() ); 00208 CHECK( r1.find( h5 ) != r1.end() ); 00209 00210 // source empty 00211 r1.clear(); 00212 r2.clear(); 00213 r1.insert( h1 ); 00214 r1.insert( h4 ); 00215 r1.insert( h5 ); 00216 r1.swap( r2 ); 00217 CHECK_EQUAL( (size_t)0, r1.size() ); 00218 CHECK_EQUAL( (size_t)3, r2.size() ); 00219 CHECK( r2.find( h1 ) != r2.end() ); 00220 CHECK( r2.find( h4 ) != r2.end() ); 00221 CHECK( r2.find( h5 ) != r2.end() ); 00222 00223 // both empty 00224 r1.clear(); 00225 r2.clear(); 00226 r1.swap( r2 ); 00227 CHECK( r1.empty() ); 00228 CHECK( r2.empty() ); 00229 } 00230 00231 void subtract_test() 00232 { 00233 Range r1, r2, r3; 00234 00235 r1.clear(); 00236 r2.clear(); 00237 r1.insert( h1 ); 00238 r1.insert( h4 ); 00239 r1.insert( h5 ); 00240 r2.insert( h4 ); 00241 r3 = subtract( r1, r2 ); 00242 CHECK_EQUAL( (size_t)2, r3.size() ); 00243 CHECK( r3.find( h1 ) != r3.end() ); 00244 CHECK( r3.find( h5 ) != r3.end() ); 00245 CHECK( r3.find( h4 ) == r3.end() ); 00246 00247 // destination empty 00248 r1.clear(); 00249 r2.clear(); 00250 r1.insert( h1 ); 00251 r1.insert( h4 ); 00252 r1.insert( h5 ); 00253 r3 = subtract( r1, r2 ); 00254 CHECK_EQUAL( (size_t)3, r3.size() ); 00255 CHECK( r3.find( h1 ) != r3.end() ); 00256 CHECK( r3.find( h4 ) != r3.end() ); 00257 CHECK( r3.find( h5 ) != r3.end() ); 00258 } 00259 00260 void subset_by_dimension_test() 00261 { 00262 Range r1, r2; 00263 00264 // subset_by_dimension test 00265 r1.insert( h1 ); 00266 r1.insert( h4 ); 00267 r1.insert( hh1 ); 00268 r1.insert( hh3 ); 00269 r2 = r1.subset_by_dimension( 3 ); 00270 CHECK_EQUAL( (size_t)2, r2.size() ); 00271 CHECK_EQUAL( hh1, r2.front() ); 00272 CHECK_EQUAL( hh3, r2.back() ); 00273 } 00274 00275 void erase_test() 00276 { 00277 Range range; 00278 Range::iterator result; 00279 00280 // test erase from first node 00281 range.clear(); 00282 range.insert( 5, 10 ); 00283 range.insert( 12, 20 ); 00284 result = range.erase( range.begin(), range.begin() + 2 ); 00285 CHECK_EQUAL( (EntityHandle)7, range.front() ); 00286 CHECK_EQUAL( (EntityHandle)20, range.back() ); 00287 CHECK_EQUAL( (size_t)13, range.size() ); 00288 CHECK_EQUAL( (EntityHandle)7, *result ); 00289 00290 // test erase first node 00291 range.clear(); 00292 range.insert( 5, 10 ); 00293 range.insert( 12, 20 ); 00294 result = range.erase( range.begin(), range.begin() + 6 ); 00295 CHECK_EQUAL( (EntityHandle)12, range.front() ); 00296 CHECK_EQUAL( (EntityHandle)20, range.back() ); 00297 CHECK_EQUAL( (size_t)9, range.size() ); 00298 CHECK_EQUAL( (EntityHandle)12, *result ); 00299 00300 // test erase from back of first node 00301 range.clear(); 00302 range.insert( 5, 10 ); 00303 range.insert( 12, 20 ); 00304 result = range.erase( range.begin() + 2, range.begin() + 6 ); 00305 CHECK_EQUAL( (EntityHandle)5, range.front() ); 00306 CHECK_EQUAL( (EntityHandle)20, range.back() ); 00307 CHECK_EQUAL( (size_t)11, range.size() ); 00308 CHECK_EQUAL( (EntityHandle)12, *result ); 00309 00310 // test erase from middle of first node 00311 range.clear(); 00312 range.insert( 5, 10 ); 00313 range.insert( 12, 20 ); 00314 result = range.erase( range.begin() + 2, range.begin() + 5 ); 00315 CHECK_EQUAL( (EntityHandle)5, range.front() ); 00316 CHECK_EQUAL( (EntityHandle)20, range.back() ); 00317 CHECK_EQUAL( (size_t)12, range.size() ); 00318 CHECK_EQUAL( (EntityHandle)10, *result ); 00319 00320 // test erase spanning two nodes 00321 range.clear(); 00322 range.insert( 5, 10 ); 00323 range.insert( 12, 20 ); 00324 result = range.erase( range.begin() + 3, range.begin() + 7 ); 00325 CHECK_EQUAL( (EntityHandle)5, range.front() ); 00326 CHECK_EQUAL( (EntityHandle)20, range.back() ); 00327 CHECK_EQUAL( (size_t)11, range.size() ); 00328 CHECK_EQUAL( (EntityHandle)13, *result ); 00329 00330 // test erase of first node and part of second 00331 range.clear(); 00332 range.insert( 5, 10 ); 00333 range.insert( 12, 20 ); 00334 result = range.erase( range.begin(), range.begin() + 7 ); 00335 CHECK_EQUAL( (EntityHandle)13, range.front() ); 00336 CHECK_EQUAL( (EntityHandle)20, range.back() ); 00337 CHECK_EQUAL( (size_t)8, range.size() ); 00338 CHECK_EQUAL( (EntityHandle)13, *result ); 00339 00340 // test erase spanning three nodes 00341 range.clear(); 00342 range.insert( 5, 10 ); 00343 range.insert( 12, 20 ); 00344 range.insert( 100, 101 ); 00345 result = range.erase( range.begin() + 3, range.begin() + 16 ); 00346 CHECK_EQUAL( (EntityHandle)5, range.front() ); 00347 CHECK_EQUAL( (EntityHandle)101, range.back() ); 00348 CHECK_EQUAL( (size_t)4, range.size() ); 00349 CHECK_EQUAL( (EntityHandle)101, *result ); 00350 00351 // test erase from start of second node 00352 range.clear(); 00353 range.insert( 5, 10 ); 00354 range.insert( 12, 20 ); 00355 result = range.erase( range.begin() + 6, range.begin() + 8 ); 00356 CHECK_EQUAL( (EntityHandle)5, range.front() ); 00357 CHECK_EQUAL( (EntityHandle)20, range.back() ); 00358 CHECK_EQUAL( (size_t)13, range.size() ); 00359 CHECK_EQUAL( (EntityHandle)14, *result ); 00360 00361 // test erase from back of last node 00362 range.clear(); 00363 range.insert( 5, 10 ); 00364 range.insert( 12, 20 ); 00365 result = range.erase( range.begin() + 13, range.end() ); 00366 CHECK_EQUAL( (EntityHandle)5, range.front() ); 00367 CHECK_EQUAL( (EntityHandle)18, range.back() ); 00368 CHECK_EQUAL( (size_t)13, range.size() ); 00369 CHECK( result == range.end() ); 00370 00371 // test erase part of first node through end 00372 range.clear(); 00373 range.insert( 5, 10 ); 00374 range.insert( 12, 20 ); 00375 result = range.erase( range.begin() + 4, range.end() ); 00376 CHECK_EQUAL( (EntityHandle)5, range.front() ); 00377 CHECK_EQUAL( (EntityHandle)8, range.back() ); 00378 CHECK_EQUAL( (size_t)4, range.size() ); 00379 CHECK( result == range.end() ); 00380 00381 // test erase of single node 00382 range.clear(); 00383 range.insert( 5, 10 ); 00384 result = range.erase( range.begin(), range.end() ); 00385 CHECK_EQUAL( (size_t)0, range.size() ); 00386 CHECK( result == range.end() ); 00387 00388 // test erase of multi-node range 00389 range.clear(); 00390 range.insert( 5, 10 ); 00391 range.insert( 12, 20 ); 00392 range.insert( 100, 101 ); 00393 result = range.erase( range.begin(), range.end() ); 00394 CHECK_EQUAL( (size_t)0, range.size() ); 00395 CHECK( result == range.end() ); 00396 00397 // test erase nothing 00398 range.clear(); 00399 range.insert( 5, 10 ); 00400 range.insert( 12, 20 ); 00401 result = range.erase( range.begin() + 3, range.begin() + 3 ); 00402 CHECK_EQUAL( (EntityHandle)5, range.front() ); 00403 CHECK_EQUAL( (EntityHandle)20, range.back() ); 00404 CHECK_EQUAL( (size_t)15, range.size() ); 00405 CHECK_EQUAL( (EntityHandle)8, *result ); 00406 00407 // test iterators before erase remain valid 00408 Range::iterator a, b, c; 00409 range.clear(); 00410 range.insert( 5, 10 ); 00411 range.insert( 12, 20 ); 00412 a = range.begin(); 00413 b = range.begin() + 6; 00414 c = range.begin() + 8; 00415 result = range.erase( range.begin() + 9, range.end() ); 00416 CHECK( a == range.begin() ); 00417 CHECK( b == range.begin() + 6 ); 00418 CHECK( c == range.begin() + 8 ); 00419 CHECK( result == range.end() ); 00420 00421 // test iterators before erase remain valid, single value case 00422 range.clear(); 00423 range.insert( 5, 10 ); 00424 range.insert( 12, 20 ); 00425 a = range.begin(); 00426 b = range.begin() + 6; 00427 c = range.begin() + 8; 00428 result = range.erase( range.begin() + 9 ); 00429 CHECK_EQUAL( (EntityHandle)5, range.front() ); 00430 CHECK_EQUAL( (EntityHandle)20, range.back() ); 00431 CHECK_EQUAL( (size_t)14, range.size() ); 00432 CHECK( a == range.begin() ); 00433 CHECK( b == range.begin() + 6 ); 00434 CHECK( c == range.begin() + 8 ); 00435 CHECK_EQUAL( (EntityHandle)16, *result ); 00436 } 00437 00438 void contains_test() 00439 { 00440 Range r1, r2; 00441 00442 // simple test cases: one range each 00443 00444 r1.clear(); 00445 r2.clear(); 00446 r1.insert( 1, 20 ); 00447 r2.insert( 1, 21 ); 00448 CHECK( !r1.contains( r2 ) ); 00449 CHECK( r2.contains( r1 ) ); 00450 00451 r1.clear(); 00452 r2.clear(); 00453 r1.insert( 2, 20 ); 00454 r2.insert( 1, 20 ); 00455 CHECK( !r1.contains( r2 ) ); 00456 CHECK( r2.contains( r1 ) ); 00457 00458 r1.clear(); 00459 r2.clear(); 00460 r1.insert( 5 ); 00461 r2.insert( 1, 6 ); 00462 CHECK( !r1.contains( r2 ) ); 00463 CHECK( r2.contains( r1 ) ); 00464 00465 r1.clear(); 00466 r2.clear(); 00467 r1.insert( 5 ); 00468 r2.insert( 6 ); 00469 CHECK( !r1.contains( r2 ) ); 00470 CHECK( !r2.contains( r1 ) ); 00471 00472 r1.clear(); 00473 r2.clear(); 00474 r1.insert( 18 ); 00475 r2.insert( 18 ); 00476 CHECK( r1.contains( r2 ) ); 00477 CHECK( r2.contains( r1 ) ); 00478 00479 // empty range test cases 00480 00481 r1.clear(); 00482 r2.clear(); 00483 CHECK( r1.contains( r2 ) ); 00484 CHECK( r2.contains( r1 ) ); 00485 00486 r1.clear(); 00487 r2.clear(); 00488 r1.insert( 18 ); 00489 CHECK( r1.contains( r2 ) ); 00490 CHECK( !r2.contains( r1 ) ); 00491 00492 // slightly more complex tests: one range in one container 00493 // and multiple in the other 00494 00495 r1.clear(); 00496 r1.insert( 10, 100 ); 00497 r2.clear(); 00498 r2.insert( 20, 30 ); 00499 r2.insert( 40, 50 ); 00500 CHECK( r1.contains( r2 ) ); 00501 CHECK( !r2.contains( r1 ) ); 00502 00503 r2.insert( 10, 12 ); 00504 CHECK( r1.contains( r2 ) ); 00505 CHECK( !r2.contains( r1 ) ); 00506 00507 r2.insert( 90, 100 ); 00508 CHECK( r1.contains( r2 ) ); 00509 CHECK( !r2.contains( r1 ) ); 00510 00511 r2.insert( 9 ); 00512 CHECK( !r1.contains( r2 ) ); 00513 CHECK( !r2.contains( r1 ) ); 00514 00515 r2.erase( 9 ); 00516 r2.insert( 101 ); 00517 CHECK( !r1.contains( r2 ) ); 00518 CHECK( !r2.contains( r1 ) ); 00519 00520 r2.erase( 101 ); 00521 r2.insert( 103, 110 ); 00522 CHECK( !r1.contains( r2 ) ); 00523 CHECK( !r2.contains( r1 ) ); 00524 00525 r2.insert( 1, 5 ); 00526 CHECK( !r1.contains( r2 ) ); 00527 CHECK( !r2.contains( r1 ) ); 00528 00529 // most complex case: both containers have several ranges 00530 00531 r1.clear(); 00532 r1.insert( 10, 30 ); 00533 r1.insert( 40, 50 ); 00534 r1.insert( 90, 100 ); 00535 r2.clear(); 00536 r2.insert( 20, 30 ); 00537 r2.insert( 40, 50 ); 00538 CHECK( r1.contains( r2 ) ); 00539 CHECK( !r2.contains( r1 ) ); 00540 00541 r2.insert( 10, 12 ); 00542 CHECK( r1.contains( r2 ) ); 00543 CHECK( !r2.contains( r1 ) ); 00544 00545 r2.insert( 90, 100 ); 00546 CHECK( r1.contains( r2 ) ); 00547 CHECK( !r2.contains( r1 ) ); 00548 00549 r2.insert( 9 ); 00550 CHECK( !r1.contains( r2 ) ); 00551 CHECK( !r2.contains( r1 ) ); 00552 00553 r2.erase( 9 ); 00554 r2.insert( 101 ); 00555 CHECK( !r1.contains( r2 ) ); 00556 CHECK( !r2.contains( r1 ) ); 00557 00558 r2.erase( 101 ); 00559 r2.insert( 103, 110 ); 00560 CHECK( !r1.contains( r2 ) ); 00561 CHECK( !r2.contains( r1 ) ); 00562 00563 r2.insert( 1, 5 ); 00564 CHECK( !r1.contains( r2 ) ); 00565 CHECK( !r2.contains( r1 ) ); 00566 }
