MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /* 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 /**\file OrientedBox.hpp 00017 *\author Jason Kraftcheck ([email protected]) 00018 *\date 2006-07-18 00019 */ 00020 00021 #include "moab/Interface.hpp" 00022 #include "Internals.hpp" 00023 #include "moab/OrientedBoxTreeTool.hpp" 00024 #include "moab/Range.hpp" 00025 #include "moab/CN.hpp" 00026 #include "moab/GeomUtil.hpp" 00027 #include "MBTagConventions.hpp" 00028 #include <iostream> 00029 #include <iomanip> 00030 #include <algorithm> 00031 #include <limits> 00032 #include <cassert> 00033 #include <cmath> 00034 00035 //#define MB_OBB_USE_VECTOR_QUERIES 00036 //#define MB_OBB_USE_TYPE_QUERIES 00037 00038 namespace moab 00039 { 00040 00041 #if defined( MB_OBB_USE_VECTOR_QUERIES ) && defined( MB_OBB_USE_TYPE_QUERIES ) 00042 #undef MB_OBB_USE_TYPE_QUERIES 00043 #endif 00044 00045 const char DEFAULT_TAG_NAME[] = "OBB"; 00046 00047 OrientedBoxTreeTool::Op::~Op() {} 00048 00049 OrientedBoxTreeTool::OrientedBoxTreeTool( Interface* i, const char* tag_name, bool destroy_created_trees ) 00050 : instance( i ), cleanUpTrees( destroy_created_trees ) 00051 { 00052 if( !tag_name ) tag_name = DEFAULT_TAG_NAME; 00053 ErrorCode rval = OrientedBox::tag_handle( tagHandle, instance, tag_name ); 00054 if( MB_SUCCESS != rval ) tagHandle = 0; 00055 } 00056 00057 OrientedBoxTreeTool::~OrientedBoxTreeTool() 00058 { 00059 if( !cleanUpTrees ) return; 00060 00061 while( !createdTrees.empty() ) 00062 { 00063 EntityHandle tree = createdTrees.back(); 00064 // make sure this is a tree (rather than some other, stale handle) 00065 const void* data_ptr = 0; 00066 ErrorCode rval = instance->tag_get_by_ptr( tagHandle, &tree, 1, &data_ptr ); 00067 if( MB_SUCCESS == rval ) rval = delete_tree( tree ); 00068 if( MB_SUCCESS != rval ) createdTrees.pop_back(); 00069 } 00070 } 00071 00072 OrientedBoxTreeTool::Settings::Settings() 00073 : max_leaf_entities( 8 ), max_depth( 0 ), worst_split_ratio( 0.95 ), best_split_ratio( 0.4 ), 00074 set_options( MESHSET_SET ) 00075 { 00076 } 00077 00078 bool OrientedBoxTreeTool::Settings::valid() const 00079 { 00080 return max_leaf_entities > 0 && max_depth >= 0 && worst_split_ratio <= 1.0 && best_split_ratio >= 0.0 && 00081 worst_split_ratio >= best_split_ratio; 00082 } 00083 00084 /********************** Simple Tree Access Methods ****************************/ 00085 00086 ErrorCode OrientedBoxTreeTool::box( EntityHandle set, OrientedBox& obb ) 00087 { 00088 return instance->tag_get_data( tagHandle, &set, 1, &obb ); 00089 } 00090 00091 ErrorCode OrientedBoxTreeTool::box( EntityHandle set, 00092 double center[3], 00093 double axis1[3], 00094 double axis2[3], 00095 double axis3[3] ) 00096 { 00097 OrientedBox obb; 00098 ErrorCode rval = this->box( set, obb ); 00099 obb.center.get( center ); 00100 obb.scaled_axis( 0 ).get( axis1 ); 00101 obb.scaled_axis( 1 ).get( axis2 ); 00102 obb.scaled_axis( 2 ).get( axis3 ); 00103 return rval; 00104 } 00105 00106 /********************** Tree Construction Code ****************************/ 00107 00108 struct OrientedBoxTreeTool::SetData 00109 { 00110 EntityHandle handle; 00111 OrientedBox::CovarienceData box_data; 00112 // Range vertices; 00113 }; 00114 00115 ErrorCode OrientedBoxTreeTool::build( const Range& entities, EntityHandle& set_handle_out, const Settings* settings ) 00116 { 00117 if( !entities.all_of_dimension( 2 ) ) return MB_TYPE_OUT_OF_RANGE; 00118 if( settings && !settings->valid() ) return MB_FAILURE; 00119 00120 return build_tree( entities, set_handle_out, 0, settings ? *settings : Settings() ); 00121 } 00122 00123 ErrorCode OrientedBoxTreeTool::join_trees( const Range& sets, EntityHandle& set_handle_out, const Settings* settings ) 00124 { 00125 if( !sets.all_of_type( MBENTITYSET ) ) return MB_TYPE_OUT_OF_RANGE; 00126 if( settings && !settings->valid() ) return MB_FAILURE; 00127 00128 // Build initial set data list. 00129 std::list< SetData > data; 00130 for( Range::const_iterator i = sets.begin(); i != sets.end(); ++i ) 00131 { 00132 Range elements; 00133 ErrorCode rval = instance->get_entities_by_dimension( *i, 2, elements, true ); 00134 if( MB_SUCCESS != rval ) return rval; 00135 if( elements.empty() ) continue; 00136 00137 data.push_back( SetData() ); 00138 SetData& set_data = data.back(); 00139 set_data.handle = *i; 00140 rval = OrientedBox::covariance_data_from_tris( set_data.box_data, instance, elements ); 00141 if( MB_SUCCESS != rval ) return rval; 00142 } 00143 00144 ErrorCode result = build_sets( data, set_handle_out, 0, settings ? *settings : Settings() ); 00145 if( MB_SUCCESS != result ) return result; 00146 00147 for( Range::reverse_iterator i = sets.rbegin(); i != sets.rend(); ++i ) 00148 { 00149 createdTrees.erase( std::remove( createdTrees.begin(), createdTrees.end(), *i ), createdTrees.end() ); 00150 } 00151 createdTrees.push_back( set_handle_out ); 00152 return MB_SUCCESS; 00153 } 00154 00155 /**\brief Split triangles by which side of a plane they are on 00156 * 00157 * Given a plane specified as a bisecting plane normal to one 00158 * of the axes of a box, split triangles based on which side 00159 * of the plane they are on. 00160 *\param instance MOAB instance 00161 *\param box The oriented box containing all the entities 00162 *\param axis The axis for which the split plane is orthogonal 00163 *\param left_list Output, entities to the left of the plane 00164 *\param right_list Output, entities to the right of the plane 00165 *\param num_intersecting Output, number entities intersecting plane 00166 */ 00167 static ErrorCode split_box( Interface* instance, 00168 const OrientedBox& box, 00169 int axis, 00170 const Range& entities, 00171 Range& left_list, 00172 Range& right_list ) 00173 { 00174 ErrorCode rval; 00175 left_list.clear(); 00176 right_list.clear(); 00177 00178 std::vector< CartVect > coords; 00179 for( Range::reverse_iterator i = entities.rbegin(); i != entities.rend(); ++i ) 00180 { 00181 const EntityHandle* conn = NULL; 00182 int conn_len = 0; 00183 rval = instance->get_connectivity( *i, conn, conn_len ); 00184 if( MB_SUCCESS != rval ) return rval; 00185 00186 coords.resize( conn_len ); 00187 rval = instance->get_coords( conn, conn_len, coords[0].array() ); 00188 if( MB_SUCCESS != rval ) return rval; 00189 00190 CartVect centroid( 0.0 ); 00191 for( int j = 0; j < conn_len; ++j ) 00192 centroid += coords[j]; 00193 centroid /= conn_len; 00194 00195 if( ( box.axis( axis ) % ( centroid - box.center ) ) < 0.0 ) 00196 left_list.insert( *i ); 00197 else 00198 right_list.insert( *i ); 00199 } 00200 00201 return MB_SUCCESS; 00202 } 00203 00204 ErrorCode OrientedBoxTreeTool::build_tree( const Range& entities, 00205 EntityHandle& set, 00206 int depth, 00207 const Settings& settings ) 00208 { 00209 OrientedBox tmp_box; 00210 ErrorCode rval; 00211 00212 if( entities.empty() ) 00213 { 00214 Matrix3 axis; 00215 tmp_box = OrientedBox( axis, CartVect( 0. ) ); 00216 } 00217 else 00218 { 00219 rval = OrientedBox::compute_from_2d_cells( tmp_box, instance, entities ); 00220 if( MB_SUCCESS != rval ) return rval; 00221 } 00222 00223 // create an entity set for the tree node 00224 rval = instance->create_meshset( settings.set_options, set ); 00225 if( MB_SUCCESS != rval ) return rval; 00226 00227 rval = instance->tag_set_data( tagHandle, &set, 1, &tmp_box ); 00228 if( MB_SUCCESS != rval ) 00229 { 00230 delete_tree( set ); 00231 return rval; 00232 } 00233 00234 // check if should create children 00235 bool leaf = true; 00236 ++depth; 00237 if( ( !settings.max_depth || depth < settings.max_depth ) && 00238 entities.size() > (unsigned)settings.max_leaf_entities ) 00239 { 00240 // try splitting with planes normal to each axis of the box 00241 // until we find an acceptable split 00242 double best_ratio = settings.worst_split_ratio; // worst case ratio 00243 Range best_left_list, best_right_list; 00244 // Axes are sorted from shortest to longest, so search backwards 00245 for( int axis = 2; best_ratio > settings.best_split_ratio && axis >= 0; --axis ) 00246 { 00247 Range left_list, right_list; 00248 00249 rval = split_box( instance, tmp_box, axis, entities, left_list, right_list ); 00250 if( MB_SUCCESS != rval ) 00251 { 00252 delete_tree( set ); 00253 return rval; 00254 } 00255 00256 double ratio = fabs( (double)right_list.size() - left_list.size() ) / entities.size(); 00257 00258 if( ratio < best_ratio ) 00259 { 00260 best_ratio = ratio; 00261 best_left_list.swap( left_list ); 00262 best_right_list.swap( right_list ); 00263 } 00264 } 00265 00266 // create children 00267 if( !best_left_list.empty() ) 00268 { 00269 EntityHandle child = 0; 00270 00271 rval = build_tree( best_left_list, child, depth, settings ); 00272 if( MB_SUCCESS != rval ) 00273 { 00274 delete_tree( set ); 00275 return rval; 00276 } 00277 rval = instance->add_child_meshset( set, child ); 00278 if( MB_SUCCESS != rval ) 00279 { 00280 delete_tree( set ); 00281 delete_tree( child ); 00282 return rval; 00283 } 00284 00285 rval = build_tree( best_right_list, child, depth, settings ); 00286 if( MB_SUCCESS != rval ) 00287 { 00288 delete_tree( set ); 00289 return rval; 00290 } 00291 rval = instance->add_child_meshset( set, child ); 00292 if( MB_SUCCESS != rval ) 00293 { 00294 delete_tree( set ); 00295 delete_tree( child ); 00296 return rval; 00297 } 00298 00299 leaf = false; 00300 } 00301 } 00302 00303 if( leaf ) 00304 { 00305 rval = instance->add_entities( set, entities ); 00306 if( MB_SUCCESS != rval ) 00307 { 00308 delete_tree( set ); 00309 return rval; 00310 } 00311 } 00312 00313 createdTrees.push_back( set ); 00314 return MB_SUCCESS; 00315 } 00316 00317 static ErrorCode split_sets( Interface*, 00318 const OrientedBox& box, 00319 int axis, 00320 const std::list< OrientedBoxTreeTool::SetData >& sets, 00321 std::list< OrientedBoxTreeTool::SetData >& left, 00322 std::list< OrientedBoxTreeTool::SetData >& right ) 00323 { 00324 left.clear(); 00325 right.clear(); 00326 00327 std::list< OrientedBoxTreeTool::SetData >::const_iterator i; 00328 for( i = sets.begin(); i != sets.end(); ++i ) 00329 { 00330 CartVect centroid( i->box_data.center / i->box_data.area ); 00331 if( ( box.axis( axis ) % ( centroid - box.center ) ) < 0.0 ) 00332 left.push_back( *i ); 00333 else 00334 right.push_back( *i ); 00335 } 00336 00337 return MB_SUCCESS; 00338 } 00339 00340 ErrorCode OrientedBoxTreeTool::build_sets( std::list< SetData >& sets, 00341 EntityHandle& node_set, 00342 int depth, 00343 const Settings& settings ) 00344 { 00345 ErrorCode rval; 00346 int count = sets.size(); 00347 if( 0 == count ) return MB_FAILURE; 00348 00349 // calculate box 00350 OrientedBox obox; 00351 00352 // make vector go out of scope when done, so memory is released 00353 { 00354 Range elems; 00355 std::vector< OrientedBox::CovarienceData > data( sets.size() ); 00356 data.clear(); 00357 for( std::list< SetData >::iterator i = sets.begin(); i != sets.end(); ++i ) 00358 { 00359 data.push_back( i->box_data ); 00360 rval = instance->get_entities_by_dimension( i->handle, 2, elems, true ); 00361 if( MB_SUCCESS != rval ) return rval; 00362 } 00363 00364 Range points; 00365 rval = instance->get_adjacencies( elems, 0, false, points, Interface::UNION ); 00366 if( MB_SUCCESS != rval ) return rval; 00367 00368 rval = OrientedBox::compute_from_covariance_data( obox, instance, &data[0], data.size(), points ); 00369 if( MB_SUCCESS != rval ) return rval; 00370 } 00371 00372 // If only one set in list... 00373 if( count == 1 ) 00374 { 00375 node_set = sets.front().handle; 00376 return instance->tag_set_data( tagHandle, &node_set, 1, &obox ); 00377 } 00378 00379 // create an entity set for the tree node 00380 rval = instance->create_meshset( settings.set_options, node_set ); 00381 if( MB_SUCCESS != rval ) return rval; 00382 00383 rval = instance->tag_set_data( tagHandle, &node_set, 1, &obox ); 00384 if( MB_SUCCESS != rval ) 00385 { 00386 delete_tree( node_set ); 00387 return rval; 00388 } 00389 00390 double best_ratio = 2.0; 00391 std::list< SetData > best_left_list, best_right_list; 00392 for( int axis = 0; axis < 2; ++axis ) 00393 { 00394 std::list< SetData > left_list, right_list; 00395 rval = split_sets( instance, obox, axis, sets, left_list, right_list ); 00396 if( MB_SUCCESS != rval ) 00397 { 00398 delete_tree( node_set ); 00399 return rval; 00400 } 00401 00402 double ratio = fabs( (double)right_list.size() - left_list.size() ) / sets.size(); 00403 00404 if( ratio < best_ratio ) 00405 { 00406 best_ratio = ratio; 00407 best_left_list.swap( left_list ); 00408 best_right_list.swap( right_list ); 00409 } 00410 } 00411 00412 // We must subdivide the list of sets, because we want to guarantee that 00413 // there is a node in the tree corresponding to each of the sets. So if 00414 // we couldn't find a usable split plane, just split them in an arbitrary 00415 // manner. 00416 if( best_left_list.empty() || best_right_list.empty() ) 00417 { 00418 best_left_list.clear(); 00419 best_right_list.clear(); 00420 std::list< SetData >* lists[2] = { &best_left_list, &best_right_list }; 00421 int i = 0; 00422 while( !sets.empty() ) 00423 { 00424 lists[i]->push_back( sets.front() ); 00425 sets.pop_front(); 00426 i = 1 - i; 00427 } 00428 } 00429 else 00430 { 00431 sets.clear(); // release memory before recursion 00432 } 00433 00434 // Create child sets 00435 00436 EntityHandle child = 0; 00437 00438 rval = build_sets( best_left_list, child, depth + 1, settings ); 00439 if( MB_SUCCESS != rval ) 00440 { 00441 delete_tree( node_set ); 00442 return rval; 00443 } 00444 rval = instance->add_child_meshset( node_set, child ); 00445 if( MB_SUCCESS != rval ) 00446 { 00447 delete_tree( node_set ); 00448 delete_tree( child ); 00449 return rval; 00450 } 00451 00452 rval = build_sets( best_right_list, child, depth + 1, settings ); 00453 if( MB_SUCCESS != rval ) 00454 { 00455 delete_tree( node_set ); 00456 return rval; 00457 } 00458 rval = instance->add_child_meshset( node_set, child ); 00459 if( MB_SUCCESS != rval ) 00460 { 00461 delete_tree( node_set ); 00462 delete_tree( child ); 00463 return rval; 00464 } 00465 00466 return MB_SUCCESS; 00467 } 00468 00469 ErrorCode OrientedBoxTreeTool::delete_tree( EntityHandle set ) 00470 { 00471 std::vector< EntityHandle > children; 00472 ErrorCode rval = instance->get_child_meshsets( set, children, 0 ); 00473 if( MB_SUCCESS != rval ) return rval; 00474 00475 createdTrees.erase( std::remove( createdTrees.begin(), createdTrees.end(), set ), createdTrees.end() ); 00476 children.insert( children.begin(), set ); 00477 return instance->delete_entities( &children[0], children.size() ); 00478 } 00479 00480 ErrorCode OrientedBoxTreeTool::remove_root( EntityHandle root ) 00481 { 00482 std::vector< EntityHandle >::iterator i = find( createdTrees.begin(), createdTrees.end(), root ); 00483 if( i != createdTrees.end() ) 00484 { 00485 createdTrees.erase( i ); 00486 return MB_SUCCESS; 00487 } 00488 else 00489 return MB_ENTITY_NOT_FOUND; 00490 } 00491 00492 /********************** Generic Tree Traversal ****************************/ 00493 struct Data 00494 { 00495 EntityHandle set; 00496 int depth; 00497 }; 00498 ErrorCode OrientedBoxTreeTool::preorder_traverse( EntityHandle set, Op& operation, TrvStats* accum ) 00499 { 00500 ErrorCode rval; 00501 std::vector< EntityHandle > children; 00502 std::vector< Data > the_stack; 00503 Data data = { set, 0 }; 00504 the_stack.push_back( data ); 00505 int max_depth = -1; 00506 00507 while( !the_stack.empty() ) 00508 { 00509 data = the_stack.back(); 00510 the_stack.pop_back(); 00511 00512 // increment traversal statistics 00513 if( accum ) 00514 { 00515 accum->increment( data.depth ); 00516 max_depth = std::max( max_depth, data.depth ); 00517 } 00518 00519 bool descend = true; 00520 rval = operation.visit( data.set, data.depth, descend ); 00521 assert( MB_SUCCESS == rval ); 00522 if( MB_SUCCESS != rval ) return rval; 00523 00524 if( !descend ) continue; 00525 00526 children.clear(); 00527 rval = instance->get_child_meshsets( data.set, children ); 00528 assert( MB_SUCCESS == rval ); 00529 if( MB_SUCCESS != rval ) return rval; 00530 if( children.empty() ) 00531 { 00532 if( accum ) 00533 { 00534 accum->increment_leaf( data.depth ); 00535 } 00536 rval = operation.leaf( data.set ); 00537 assert( MB_SUCCESS == rval ); 00538 if( MB_SUCCESS != rval ) return rval; 00539 } 00540 else if( children.size() == 2 ) 00541 { 00542 data.depth++; 00543 data.set = children[0]; 00544 the_stack.push_back( data ); 00545 data.set = children[1]; 00546 the_stack.push_back( data ); 00547 } 00548 else 00549 return MB_MULTIPLE_ENTITIES_FOUND; 00550 } 00551 00552 if( accum ) 00553 { 00554 accum->end_traversal( max_depth ); 00555 } 00556 00557 return MB_SUCCESS; 00558 } 00559 00560 /********************** General Sphere/Triangle Intersection ***************/ 00561 00562 struct OBBTreeSITFrame 00563 { 00564 OBBTreeSITFrame( EntityHandle n, EntityHandle s, int dp ) : node( n ), surf( s ), depth( dp ) {} 00565 EntityHandle node; 00566 EntityHandle surf; 00567 int depth; 00568 }; 00569 00570 ErrorCode OrientedBoxTreeTool::sphere_intersect_triangles( const double* center_v, 00571 double radius, 00572 EntityHandle tree_root, 00573 std::vector< EntityHandle >& facets_out, 00574 std::vector< EntityHandle >* sets_out, 00575 TrvStats* accum ) 00576 { 00577 const double radsqr = radius * radius; 00578 OrientedBox b; 00579 ErrorCode rval; 00580 Range sets; 00581 const CartVect center( center_v ); 00582 CartVect closest, coords[3]; 00583 const EntityHandle* conn; 00584 int num_conn; 00585 #ifndef MB_OBB_USE_VECTOR_QUERIES 00586 Range tris; 00587 Range::const_iterator t; 00588 #else 00589 std::vector< EntityHandle > tris; 00590 std::vector< EntityHandle >::const_iterator t; 00591 #endif 00592 00593 std::vector< OBBTreeSITFrame > stack; 00594 std::vector< EntityHandle > children; 00595 stack.reserve( 30 ); 00596 stack.push_back( OBBTreeSITFrame( tree_root, 0, 0 ) ); 00597 00598 int max_depth = -1; 00599 00600 while( !stack.empty() ) 00601 { 00602 EntityHandle surf = stack.back().surf; 00603 EntityHandle node = stack.back().node; 00604 int current_depth = stack.back().depth; 00605 stack.pop_back(); 00606 00607 // increment traversal statistics. 00608 if( accum ) 00609 { 00610 accum->increment( current_depth ); 00611 max_depth = std::max( max_depth, current_depth ); 00612 } 00613 00614 if( !surf && sets_out ) 00615 { 00616 rval = get_moab_instance()->get_entities_by_type( node, MBENTITYSET, sets ); 00617 if( !sets.empty() ) surf = sets.front(); 00618 sets.clear(); 00619 } 00620 00621 // check if sphere intersects box 00622 rval = box( node, b ); 00623 if( MB_SUCCESS != rval ) return rval; 00624 b.closest_location_in_box( center, closest ); 00625 closest -= center; 00626 if( ( closest % closest ) > radsqr ) continue; 00627 00628 // push child boxes on stack 00629 children.clear(); 00630 rval = instance->get_child_meshsets( node, children ); 00631 if( MB_SUCCESS != rval ) return rval; 00632 if( !children.empty() ) 00633 { 00634 assert( children.size() == 2 ); 00635 stack.push_back( OBBTreeSITFrame( children[0], surf, current_depth + 1 ) ); 00636 stack.push_back( OBBTreeSITFrame( children[1], surf, current_depth + 1 ) ); 00637 continue; 00638 } 00639 00640 if( accum ) 00641 { 00642 accum->increment_leaf( current_depth ); 00643 } 00644 // if leaf, intersect sphere with triangles 00645 #ifndef MB_OBB_USE_VECTOR_QUERIES 00646 #ifdef MB_OBB_USE_TYPE_QUERIES 00647 rval = get_moab_instance()->get_entities_by_type( node, MBTRI, tris ); 00648 #else 00649 rval = get_moab_instance()->get_entities_by_handle( node, tris ); 00650 #endif 00651 t = tris.begin(); 00652 #else 00653 rval = get_moab_instance()->get_entities_by_handle( node, tris ); 00654 t = tris.lower_bound( MBTRI ); 00655 #endif 00656 if( MB_SUCCESS != rval ) return rval; 00657 00658 for( t = tris.begin(); t != tris.end(); ++t ) 00659 { 00660 #ifndef MB_OBB_USE_VECTOR_QUERIES 00661 if( TYPE_FROM_HANDLE( *t ) != MBTRI ) break; 00662 #elif !defined( MB_OBB_USE_TYPE_QUERIES ) 00663 if( TYPE_FROM_HANDLE( *t ) != MBTRI ) continue; 00664 #endif 00665 rval = get_moab_instance()->get_connectivity( *t, conn, num_conn, true ); 00666 if( MB_SUCCESS != rval ) return rval; 00667 if( num_conn != 3 ) continue; 00668 00669 rval = get_moab_instance()->get_coords( conn, num_conn, coords[0].array() ); 00670 if( MB_SUCCESS != rval ) return rval; 00671 00672 GeomUtil::closest_location_on_tri( center, coords, closest ); 00673 closest -= center; 00674 if( ( closest % closest ) <= radsqr && 00675 std::find( facets_out.begin(), facets_out.end(), *t ) == facets_out.end() ) 00676 { 00677 facets_out.push_back( *t ); 00678 if( sets_out ) sets_out->push_back( surf ); 00679 } 00680 } 00681 } 00682 00683 if( accum ) 00684 { 00685 accum->end_traversal( max_depth ); 00686 } 00687 00688 return MB_SUCCESS; 00689 } 00690 00691 /********************** General Ray/Tree and Ray/Triangle Intersection ***************/ 00692 00693 class RayIntersector : public OrientedBoxTreeTool::Op 00694 { 00695 private: 00696 OrientedBoxTreeTool* tool; 00697 const CartVect b, m; 00698 const double* len; 00699 const double tol; 00700 Range& boxes; 00701 00702 public: 00703 RayIntersector( OrientedBoxTreeTool* tool_ptr, 00704 const double* ray_point, 00705 const double* unit_ray_dir, 00706 const double* ray_length, 00707 double tolerance, 00708 Range& leaf_boxes ) 00709 : tool( tool_ptr ), b( ray_point ), m( unit_ray_dir ), len( ray_length ), tol( tolerance ), boxes( leaf_boxes ) 00710 { 00711 } 00712 00713 virtual ErrorCode visit( EntityHandle node, int depth, bool& descend ); 00714 virtual ErrorCode leaf( EntityHandle node ); 00715 }; 00716 00717 //#include <stdio.h> 00718 // inline void dump_fragmentation( const Range& range ) { 00719 // static FILE* file = fopen( "fragmentation", "w" ); 00720 // unsigned ranges = 0, entities = 0; 00721 // for (Range::const_pair_iterator i = range.const_pair_begin(); i != range.const_pair_end(); ++i) 00722 // { 00723 // ++ranges; 00724 // entities += i->second - i->first + 1; 00725 // } 00726 // fprintf( file, "%u %u\n", ranges, entities ); 00727 //} 00728 00729 ErrorCode OrientedBoxTreeTool::ray_intersect_triangles( std::vector< double >& intersection_distances_out, 00730 std::vector< EntityHandle >& intersection_facets_out, 00731 const Range& boxes, 00732 double /*tolerance*/, 00733 const double ray_point[3], 00734 const double unit_ray_dir[3], 00735 const double* ray_length, 00736 unsigned int* raytri_test_count ) 00737 { 00738 ErrorCode rval; 00739 intersection_distances_out.clear(); 00740 #ifdef MB_OBB_USE_VECTOR_QUERIES 00741 std::vector< EntityHandle > tris; 00742 #endif 00743 00744 const CartVect point( ray_point ); 00745 const CartVect dir( unit_ray_dir ); 00746 00747 for( Range::iterator b = boxes.begin(); b != boxes.end(); ++b ) 00748 { 00749 #ifndef MB_OBB_USE_VECTOR_QUERIES 00750 Range tris; 00751 #ifdef MB_OBB_USE_TYPE_QUERIES 00752 rval = instance->get_entities_by_type( *b, MBTRI, tris ); 00753 #else 00754 rval = instance->get_entities_by_handle( *b, tris ); 00755 #endif 00756 #else 00757 tris.clear(); 00758 rval = instance->get_entities_by_handle( *b, tris ); 00759 #endif 00760 if( MB_SUCCESS != rval ) return rval; 00761 // dump_fragmentation( tris ); 00762 00763 #ifndef MB_OBB_USE_VECTOR_QUERIES 00764 for( Range::iterator t = tris.begin(); t != tris.end(); ++t ) 00765 #else 00766 for( std::vector< EntityHandle >::iterator t = tris.begin(); t != tris.end(); ++t ) 00767 #endif 00768 { 00769 #ifndef MB_OBB_USE_TYPE_QUERIES 00770 if( TYPE_FROM_HANDLE( *t ) != MBTRI ) continue; 00771 #endif 00772 00773 const EntityHandle* conn = NULL; 00774 int len = 0; 00775 rval = instance->get_connectivity( *t, conn, len, true ); 00776 if( MB_SUCCESS != rval ) return rval; 00777 00778 CartVect coords[3]; 00779 rval = instance->get_coords( conn, 3, coords[0].array() ); 00780 if( MB_SUCCESS != rval ) return rval; 00781 00782 if( raytri_test_count ) *raytri_test_count += 1; 00783 00784 double td; 00785 if( GeomUtil::plucker_ray_tri_intersect( coords, point, dir, td, ray_length ) ) 00786 { 00787 intersection_distances_out.push_back( td ); 00788 intersection_facets_out.push_back( *t ); 00789 } 00790 } 00791 } 00792 00793 return MB_SUCCESS; 00794 } 00795 00796 ErrorCode OrientedBoxTreeTool::ray_intersect_triangles( std::vector< double >& intersection_distances_out, 00797 std::vector< EntityHandle >& intersection_facets_out, 00798 EntityHandle root_set, 00799 double tolerance, 00800 const double ray_point[3], 00801 const double unit_ray_dir[3], 00802 const double* ray_length, 00803 TrvStats* accum ) 00804 { 00805 Range boxes; 00806 ErrorCode rval; 00807 00808 rval = ray_intersect_boxes( boxes, root_set, tolerance, ray_point, unit_ray_dir, ray_length, accum ); 00809 if( MB_SUCCESS != rval ) return rval; 00810 00811 return ray_intersect_triangles( intersection_distances_out, intersection_facets_out, boxes, tolerance, ray_point, 00812 unit_ray_dir, ray_length, accum ? &( accum->ray_tri_tests_count ) : NULL ); 00813 } 00814 00815 ErrorCode OrientedBoxTreeTool::ray_intersect_boxes( Range& boxes_out, 00816 EntityHandle root_set, 00817 double tolerance, 00818 const double ray_point[3], 00819 const double unit_ray_dir[3], 00820 const double* ray_length, 00821 TrvStats* accum ) 00822 { 00823 RayIntersector op( this, ray_point, unit_ray_dir, ray_length, tolerance, boxes_out ); 00824 return preorder_traverse( root_set, op, accum ); 00825 } 00826 00827 ErrorCode RayIntersector::visit( EntityHandle node, int, bool& descend ) 00828 { 00829 OrientedBox box; 00830 ErrorCode rval = tool->box( node, box ); 00831 if( MB_SUCCESS != rval ) return rval; 00832 00833 descend = box.intersect_ray( b, m, tol, len ); 00834 return MB_SUCCESS; 00835 } 00836 00837 ErrorCode RayIntersector::leaf( EntityHandle node ) 00838 { 00839 boxes.insert( node ); 00840 return MB_SUCCESS; 00841 } 00842 00843 /********************** Ray/Set Intersection ****************************/ 00844 00845 ErrorCode OrientedBoxTreeTool::get_close_tris( CartVect int_pt, 00846 double tol, 00847 const EntityHandle* rootSet, 00848 const EntityHandle* geomVol, 00849 const Tag* senseTag, 00850 std::vector< EntityHandle >& close_tris, 00851 std::vector< int >& close_senses ) 00852 { 00853 std::vector< EntityHandle > close_surfs; 00854 ErrorCode rval = sphere_intersect_triangles( int_pt.array(), tol, *rootSet, close_tris, &close_surfs ); 00855 assert( MB_SUCCESS == rval ); 00856 if( MB_SUCCESS != rval ) return rval; 00857 00858 // for each surface, get the surf sense wrt parent volume 00859 close_senses.resize( close_surfs.size() ); 00860 for( unsigned i = 0; i < close_surfs.size(); ++i ) 00861 { 00862 EntityHandle vols[2]; 00863 rval = get_moab_instance()->tag_get_data( *senseTag, &( close_surfs[i] ), 1, vols ); 00864 assert( MB_SUCCESS == rval ); 00865 if( MB_SUCCESS != rval ) return rval; 00866 if( vols[0] == vols[1] ) 00867 { 00868 std::cerr << "error: surf has positive and negative sense wrt same volume" << std::endl; 00869 return MB_FAILURE; 00870 } 00871 if( *geomVol == vols[0] ) 00872 { 00873 close_senses[i] = 1; 00874 } 00875 else if( *geomVol == vols[1] ) 00876 { 00877 close_senses[i] = -1; 00878 } 00879 else 00880 { 00881 return MB_FAILURE; 00882 } 00883 } 00884 00885 return MB_SUCCESS; 00886 } 00887 00888 class RayIntersectSets : public OrientedBoxTreeTool::Op 00889 { 00890 private: 00891 // Input 00892 OrientedBoxTreeTool* tool; 00893 const CartVect ray_origin; 00894 const CartVect ray_direction; 00895 OrientedBoxTreeTool::IntersectSearchWindow& search_win; /* length to search ahead/behind of ray origin */ 00896 const double tol; /* used for box.intersect_ray, radius of 00897 neighborhood for adjacent triangles, 00898 and old mode of add_intersection */ 00899 OrientedBoxTreeTool::IntRegCtxt& int_reg_callback; 00900 00901 // Optional Input - to screen RTIs by orientation and edge/node intersection 00902 int* surfTriOrient; /* holds desired orientation of tri wrt surface */ 00903 int surfTriOrient_val; 00904 00905 // Other Variables 00906 unsigned int* raytri_test_count; 00907 EntityHandle lastSet; 00908 int lastSetDepth; 00909 00910 public: 00911 RayIntersectSets( OrientedBoxTreeTool* tool_ptr, 00912 const double* ray_point, 00913 const double* unit_ray_dir, 00914 const double tolerance, 00915 OrientedBoxTreeTool::IntersectSearchWindow& win, 00916 unsigned int* ray_tri_test_count, 00917 OrientedBoxTreeTool::IntRegCtxt& intRegCallback ) 00918 : tool( tool_ptr ), ray_origin( ray_point ), ray_direction( unit_ray_dir ), search_win( win ), tol( tolerance ), 00919 int_reg_callback( intRegCallback ), surfTriOrient_val( 0 ), raytri_test_count( ray_tri_test_count ), 00920 lastSet( 0 ), lastSetDepth( 0 ) 00921 { 00922 00923 // specified orientation should be 1 or -1, indicating ray and surface 00924 // normal in the same or opposite directions, respectively. 00925 if( int_reg_callback.getDesiredOrient() ) 00926 { 00927 surfTriOrient = &surfTriOrient_val; 00928 } 00929 else 00930 { 00931 surfTriOrient = NULL; 00932 } 00933 00934 // check the limits 00935 if( search_win.first ) 00936 { 00937 assert( 0 <= *( search_win.first ) ); 00938 } 00939 if( search_win.second ) 00940 { 00941 assert( 0 >= *( search_win.second ) ); 00942 } 00943 }; 00944 00945 virtual ErrorCode visit( EntityHandle node, int depth, bool& descend ); 00946 virtual ErrorCode leaf( EntityHandle node ); 00947 }; 00948 00949 ErrorCode RayIntersectSets::visit( EntityHandle node, int depth, bool& descend ) 00950 { 00951 OrientedBox box; 00952 ErrorCode rval = tool->box( node, box ); 00953 assert( MB_SUCCESS == rval ); 00954 if( MB_SUCCESS != rval ) return rval; 00955 00956 descend = box.intersect_ray( ray_origin, ray_direction, tol, search_win.first, search_win.second ); 00957 00958 if( lastSet && depth <= lastSetDepth ) lastSet = 0; 00959 00960 if( descend && !lastSet ) 00961 { 00962 Range tmp_sets; 00963 rval = tool->get_moab_instance()->get_entities_by_type( node, MBENTITYSET, tmp_sets ); 00964 assert( MB_SUCCESS == rval ); 00965 if( MB_SUCCESS != rval ) return rval; 00966 00967 if( !tmp_sets.empty() ) 00968 { 00969 if( tmp_sets.size() > 1 ) return MB_FAILURE; 00970 lastSet = *tmp_sets.begin(); 00971 lastSetDepth = depth; 00972 00973 rval = int_reg_callback.update_orient( lastSet, surfTriOrient ); 00974 if( MB_SUCCESS != rval ) return rval; 00975 } 00976 } 00977 00978 return MB_SUCCESS; 00979 } 00980 00981 ErrorCode RayIntersectSets::leaf( EntityHandle node ) 00982 { 00983 assert( lastSet ); 00984 if( !lastSet ) // if no surface has been visited yet, something's messed up. 00985 return MB_FAILURE; 00986 00987 #ifndef MB_OBB_USE_VECTOR_QUERIES 00988 Range tris; 00989 #ifdef MB_OBB_USE_TYPE_QUERIES 00990 ErrorCode rval = tool->get_moab_instance()->get_entities_by_type( node, MBTRI, tris ); 00991 #else 00992 ErrorCode rval = tool->get_moab_instance()->get_entities_by_handle( node, tris ); 00993 #endif 00994 #else 00995 std::vector< EntityHandle > tris; 00996 ErrorCode rval = tool->get_moab_instance()->get_entities_by_handle( node, tris ); 00997 #endif 00998 assert( MB_SUCCESS == rval ); 00999 if( MB_SUCCESS != rval ) return rval; 01000 01001 #ifndef MB_OBB_USE_VECTOR_QUERIES 01002 for( Range::iterator t = tris.begin(); t != tris.end(); ++t ) 01003 #else 01004 for( std::vector< EntityHandle >::iterator t = tris.begin(); t != tris.end(); ++t ) 01005 #endif 01006 { 01007 #ifndef MB_OBB_USE_TYPE_QUERIES 01008 if( TYPE_FROM_HANDLE( *t ) != MBTRI ) continue; 01009 #endif 01010 01011 const EntityHandle* conn; 01012 int num_conn; 01013 rval = tool->get_moab_instance()->get_connectivity( *t, conn, num_conn, true ); 01014 assert( MB_SUCCESS == rval ); 01015 if( MB_SUCCESS != rval ) return rval; 01016 01017 CartVect coords[3]; 01018 rval = tool->get_moab_instance()->get_coords( conn, 3, coords[0].array() ); 01019 assert( MB_SUCCESS == rval ); 01020 if( MB_SUCCESS != rval ) return rval; 01021 01022 if( raytri_test_count ) *raytri_test_count += 1; 01023 01024 double int_dist; 01025 GeomUtil::intersection_type int_type = GeomUtil::NONE; 01026 01027 if( GeomUtil::plucker_ray_tri_intersect( coords, ray_origin, ray_direction, int_dist, search_win.first, 01028 search_win.second, surfTriOrient, &int_type ) ) 01029 { 01030 int_reg_callback.register_intersection( lastSet, *t, int_dist, search_win, int_type ); 01031 } 01032 } 01033 return MB_SUCCESS; 01034 } 01035 01036 ErrorCode OrientedBoxTreeTool::ray_intersect_sets( std::vector< double >& distances_out, 01037 std::vector< EntityHandle >& sets_out, 01038 std::vector< EntityHandle >& facets_out, 01039 EntityHandle root_set, 01040 const double tolerance, 01041 const double ray_point[3], 01042 const double unit_ray_dir[3], 01043 IntersectSearchWindow& search_win, 01044 IntRegCtxt& int_reg_callback, 01045 TrvStats* accum ) 01046 01047 { 01048 RayIntersectSets op( this, ray_point, unit_ray_dir, tolerance, search_win, 01049 accum ? &( accum->ray_tri_tests_count ) : NULL, int_reg_callback ); 01050 ErrorCode rval = preorder_traverse( root_set, op, accum ); 01051 01052 distances_out = int_reg_callback.get_intersections(); 01053 sets_out = int_reg_callback.get_sets(); 01054 facets_out = int_reg_callback.get_facets(); 01055 01056 return rval; 01057 } 01058 01059 ErrorCode OrientedBoxTreeTool::ray_intersect_sets( std::vector< double >& distances_out, 01060 std::vector< EntityHandle >& sets_out, 01061 std::vector< EntityHandle >& facets_out, 01062 EntityHandle root_set, 01063 double tolerance, 01064 const double ray_point[3], 01065 const double unit_ray_dir[3], 01066 const double* ray_length, 01067 TrvStats* accum ) 01068 { 01069 IntRegCtxt int_reg_ctxt; 01070 01071 OrientedBoxTreeTool::IntersectSearchWindow search_win( ray_length, (double*)0 ); 01072 01073 RayIntersectSets op( this, ray_point, unit_ray_dir, tolerance, search_win, 01074 accum ? &( accum->ray_tri_tests_count ) : NULL, int_reg_ctxt ); 01075 01076 ErrorCode rval = preorder_traverse( root_set, op, accum ); 01077 01078 if( MB_SUCCESS != rval ) 01079 { 01080 return rval; 01081 } 01082 01083 distances_out = int_reg_ctxt.get_intersections(); 01084 sets_out = int_reg_ctxt.get_sets(); 01085 facets_out = int_reg_ctxt.get_facets(); 01086 01087 return MB_SUCCESS; 01088 } 01089 01090 ErrorCode OrientedBoxTreeTool::ray_intersect_sets( EntityHandle root_set, 01091 const double tolerance, 01092 const double ray_point[3], 01093 const double unit_ray_dir[3], 01094 IntersectSearchWindow& search_win, 01095 IntRegCtxt& int_reg_callback, 01096 TrvStats* accum ) 01097 01098 { 01099 RayIntersectSets op( this, ray_point, unit_ray_dir, tolerance, search_win, 01100 accum ? &( accum->ray_tri_tests_count ) : NULL, int_reg_callback ); 01101 return preorder_traverse( root_set, op, accum ); 01102 } 01103 01104 /********************** Closest Point code ***************/ 01105 01106 struct OBBTreeCPFrame 01107 { 01108 OBBTreeCPFrame( double d, EntityHandle n, EntityHandle s, int dp ) 01109 : dist_sqr( d ), node( n ), mset( s ), depth( dp ) 01110 { 01111 } 01112 double dist_sqr; 01113 EntityHandle node; 01114 EntityHandle mset; 01115 int depth; 01116 }; 01117 01118 ErrorCode OrientedBoxTreeTool::closest_to_location( const double* point, 01119 EntityHandle root, 01120 double* point_out, 01121 EntityHandle& facet_out, 01122 EntityHandle* set_out, 01123 TrvStats* accum ) 01124 { 01125 ErrorCode rval; 01126 const CartVect loc( point ); 01127 double smallest_dist_sqr = std::numeric_limits< double >::max(); 01128 01129 EntityHandle current_set = 0; 01130 Range sets; 01131 std::vector< EntityHandle > children( 2 ); 01132 std::vector< double > coords; 01133 std::vector< OBBTreeCPFrame > stack; 01134 int max_depth = -1; 01135 01136 stack.push_back( OBBTreeCPFrame( 0.0, root, current_set, 0 ) ); 01137 01138 while( !stack.empty() ) 01139 { 01140 01141 // pop from top of stack 01142 EntityHandle node = stack.back().node; 01143 double dist_sqr = stack.back().dist_sqr; 01144 current_set = stack.back().mset; 01145 int current_depth = stack.back().depth; 01146 stack.pop_back(); 01147 01148 // If current best result is closer than the box, skip this tree node. 01149 if( dist_sqr > smallest_dist_sqr ) continue; 01150 01151 // increment traversal statistics. 01152 if( accum ) 01153 { 01154 accum->increment( current_depth ); 01155 max_depth = std::max( max_depth, current_depth ); 01156 } 01157 01158 // Check if this node has a set associated with it 01159 if( set_out && !current_set ) 01160 { 01161 sets.clear(); 01162 rval = instance->get_entities_by_type( node, MBENTITYSET, sets ); 01163 if( MB_SUCCESS != rval ) return rval; 01164 if( !sets.empty() ) 01165 { 01166 if( sets.size() != 1 ) return MB_MULTIPLE_ENTITIES_FOUND; 01167 current_set = sets.front(); 01168 } 01169 } 01170 01171 // Get child boxes 01172 children.clear(); 01173 rval = instance->get_child_meshsets( node, children ); 01174 if( MB_SUCCESS != rval ) return rval; 01175 01176 // if not a leaf node 01177 if( !children.empty() ) 01178 { 01179 if( children.size() != 2 ) return MB_MULTIPLE_ENTITIES_FOUND; 01180 01181 // get boxes 01182 OrientedBox box1, box2; 01183 rval = box( children[0], box1 ); 01184 if( MB_SUCCESS != rval ) return rval; 01185 rval = box( children[1], box2 ); 01186 if( MB_SUCCESS != rval ) return rval; 01187 01188 // get distance from each box 01189 CartVect pt1, pt2; 01190 box1.closest_location_in_box( loc, pt1 ); 01191 box2.closest_location_in_box( loc, pt2 ); 01192 pt1 -= loc; 01193 pt2 -= loc; 01194 const double dsqr1 = pt1 % pt1; 01195 const double dsqr2 = pt2 % pt2; 01196 01197 // push children on tree such that closer one is on top 01198 if( dsqr1 < dsqr2 ) 01199 { 01200 stack.push_back( OBBTreeCPFrame( dsqr2, children[1], current_set, current_depth + 1 ) ); 01201 stack.push_back( OBBTreeCPFrame( dsqr1, children[0], current_set, current_depth + 1 ) ); 01202 } 01203 else 01204 { 01205 stack.push_back( OBBTreeCPFrame( dsqr1, children[0], current_set, current_depth + 1 ) ); 01206 stack.push_back( OBBTreeCPFrame( dsqr2, children[1], current_set, current_depth + 1 ) ); 01207 } 01208 } 01209 else 01210 { // LEAF NODE 01211 if( accum ) 01212 { 01213 accum->increment_leaf( current_depth ); 01214 } 01215 01216 Range facets; 01217 rval = instance->get_entities_by_dimension( node, 2, facets ); 01218 if( MB_SUCCESS != rval ) return rval; 01219 01220 const EntityHandle* conn = NULL; 01221 int len = 0; 01222 CartVect tmp, diff; 01223 for( Range::iterator i = facets.begin(); i != facets.end(); ++i ) 01224 { 01225 rval = instance->get_connectivity( *i, conn, len, true ); 01226 if( MB_SUCCESS != rval ) return rval; 01227 01228 coords.resize( 3 * len ); 01229 rval = instance->get_coords( conn, len, &coords[0] ); 01230 if( MB_SUCCESS != rval ) return rval; 01231 01232 if( len == 3 ) 01233 GeomUtil::closest_location_on_tri( loc, (CartVect*)( &coords[0] ), tmp ); 01234 else 01235 GeomUtil::closest_location_on_polygon( loc, (CartVect*)( &coords[0] ), len, tmp ); 01236 01237 diff = tmp - loc; 01238 dist_sqr = diff % diff; 01239 if( dist_sqr < smallest_dist_sqr ) 01240 { 01241 smallest_dist_sqr = dist_sqr; 01242 facet_out = *i; 01243 tmp.get( point_out ); 01244 if( set_out ) *set_out = current_set; 01245 } 01246 } 01247 } // LEAF NODE 01248 } 01249 01250 if( accum ) 01251 { 01252 accum->end_traversal( max_depth ); 01253 } 01254 01255 return MB_SUCCESS; 01256 } 01257 01258 ErrorCode OrientedBoxTreeTool::closest_to_location( const double* point, 01259 EntityHandle root, 01260 double tolerance, 01261 std::vector< EntityHandle >& facets_out, 01262 std::vector< EntityHandle >* sets_out, 01263 TrvStats* accum ) 01264 { 01265 ErrorCode rval; 01266 const CartVect loc( point ); 01267 double smallest_dist_sqr = std::numeric_limits< double >::max(); 01268 double smallest_dist = smallest_dist_sqr; 01269 01270 EntityHandle current_set = 0; 01271 Range sets; 01272 std::vector< EntityHandle > children( 2 ); 01273 std::vector< double > coords; 01274 std::vector< OBBTreeCPFrame > stack; 01275 int max_depth = -1; 01276 01277 stack.push_back( OBBTreeCPFrame( 0.0, root, current_set, 0 ) ); 01278 01279 while( !stack.empty() ) 01280 { 01281 01282 // pop from top of stack 01283 EntityHandle node = stack.back().node; 01284 double dist_sqr = stack.back().dist_sqr; 01285 current_set = stack.back().mset; 01286 int current_depth = stack.back().depth; 01287 stack.pop_back(); 01288 01289 // If current best result is closer than the box, skip this tree node. 01290 if( dist_sqr > smallest_dist_sqr + tolerance ) continue; 01291 01292 // increment traversal statistics. 01293 if( accum ) 01294 { 01295 accum->increment( current_depth ); 01296 max_depth = std::max( max_depth, current_depth ); 01297 } 01298 01299 // Check if this node has a set associated with it 01300 if( sets_out && !current_set ) 01301 { 01302 sets.clear(); 01303 rval = instance->get_entities_by_type( node, MBENTITYSET, sets ); 01304 if( MB_SUCCESS != rval ) return rval; 01305 if( !sets.empty() ) 01306 { 01307 if( sets.size() != 1 ) return MB_MULTIPLE_ENTITIES_FOUND; 01308 current_set = *sets.begin(); 01309 } 01310 } 01311 01312 // Get child boxes 01313 children.clear(); 01314 rval = instance->get_child_meshsets( node, children ); 01315 if( MB_SUCCESS != rval ) return rval; 01316 01317 // if not a leaf node 01318 if( !children.empty() ) 01319 { 01320 if( children.size() != 2 ) return MB_MULTIPLE_ENTITIES_FOUND; 01321 01322 // get boxes 01323 OrientedBox box1, box2; 01324 rval = box( children[0], box1 ); 01325 if( MB_SUCCESS != rval ) return rval; 01326 rval = box( children[1], box2 ); 01327 if( MB_SUCCESS != rval ) return rval; 01328 01329 // get distance from each box 01330 CartVect pt1, pt2; 01331 box1.closest_location_in_box( loc, pt1 ); 01332 box2.closest_location_in_box( loc, pt2 ); 01333 pt1 -= loc; 01334 pt2 -= loc; 01335 const double dsqr1 = pt1 % pt1; 01336 const double dsqr2 = pt2 % pt2; 01337 01338 // push children on tree such that closer one is on top 01339 if( dsqr1 < dsqr2 ) 01340 { 01341 stack.push_back( OBBTreeCPFrame( dsqr2, children[1], current_set, current_depth + 1 ) ); 01342 stack.push_back( OBBTreeCPFrame( dsqr1, children[0], current_set, current_depth + 1 ) ); 01343 } 01344 else 01345 { 01346 stack.push_back( OBBTreeCPFrame( dsqr1, children[0], current_set, current_depth + 1 ) ); 01347 stack.push_back( OBBTreeCPFrame( dsqr2, children[1], current_set, current_depth + 1 ) ); 01348 } 01349 } 01350 else 01351 { // LEAF NODE 01352 if( accum ) 01353 { 01354 accum->increment_leaf( current_depth ); 01355 } 01356 01357 Range facets; 01358 rval = instance->get_entities_by_dimension( node, 2, facets ); 01359 if( MB_SUCCESS != rval ) return rval; 01360 01361 const EntityHandle* conn = NULL; 01362 int len = 0; 01363 CartVect tmp, diff; 01364 for( Range::iterator i = facets.begin(); i != facets.end(); ++i ) 01365 { 01366 rval = instance->get_connectivity( *i, conn, len, true ); 01367 if( MB_SUCCESS != rval ) return rval; 01368 01369 coords.resize( 3 * len ); 01370 rval = instance->get_coords( conn, len, &coords[0] ); 01371 if( MB_SUCCESS != rval ) return rval; 01372 01373 if( len == 3 ) 01374 GeomUtil::closest_location_on_tri( loc, (CartVect*)( &coords[0] ), tmp ); 01375 else 01376 GeomUtil::closest_location_on_polygon( loc, (CartVect*)( &coords[0] ), len, tmp ); 01377 01378 diff = tmp - loc; 01379 dist_sqr = diff % diff; 01380 if( dist_sqr < smallest_dist_sqr ) 01381 { 01382 if( 0.5 * dist_sqr < 0.5 * smallest_dist_sqr + tolerance * ( 0.5 * tolerance - smallest_dist ) ) 01383 { 01384 facets_out.clear(); 01385 if( sets_out ) sets_out->clear(); 01386 } 01387 smallest_dist_sqr = dist_sqr; 01388 smallest_dist = sqrt( smallest_dist_sqr ); 01389 // put closest result at start of lists 01390 facets_out.push_back( *i ); 01391 std::swap( facets_out.front(), facets_out.back() ); 01392 if( sets_out ) 01393 { 01394 sets_out->push_back( current_set ); 01395 std::swap( sets_out->front(), sets_out->back() ); 01396 } 01397 } 01398 else if( dist_sqr <= smallest_dist_sqr + tolerance * ( tolerance + 2 * smallest_dist ) ) 01399 { 01400 facets_out.push_back( *i ); 01401 if( sets_out ) sets_out->push_back( current_set ); 01402 } 01403 } 01404 } // LEAF NODE 01405 } 01406 01407 if( accum ) 01408 { 01409 accum->end_traversal( max_depth ); 01410 } 01411 01412 return MB_SUCCESS; 01413 } 01414 01415 /********************** Tree Printing Code ****************************/ 01416 01417 class TreeLayoutPrinter : public OrientedBoxTreeTool::Op 01418 { 01419 public: 01420 TreeLayoutPrinter( std::ostream& stream, Interface* instance ); 01421 01422 virtual ErrorCode visit( EntityHandle node, int depth, bool& descend ); 01423 virtual ErrorCode leaf( EntityHandle node ); 01424 01425 private: 01426 Interface* instance; 01427 std::ostream& outputStream; 01428 std::vector< bool > path; 01429 }; 01430 01431 TreeLayoutPrinter::TreeLayoutPrinter( std::ostream& stream, Interface* interface ) 01432 : instance( interface ), outputStream( stream ) 01433 { 01434 } 01435 01436 ErrorCode TreeLayoutPrinter::visit( EntityHandle node, int depth, bool& descend ) 01437 { 01438 descend = true; 01439 01440 if( (unsigned)depth > path.size() ) 01441 { 01442 // assert(depth+1 == path.size); // preorder traversal 01443 path.push_back( true ); 01444 } 01445 else 01446 { 01447 path.resize( depth ); 01448 if( depth ) path.back() = false; 01449 } 01450 01451 for( unsigned i = 0; i + 1 < path.size(); ++i ) 01452 { 01453 if( path[i] ) 01454 outputStream << "| "; 01455 else 01456 outputStream << " "; 01457 } 01458 if( depth ) 01459 { 01460 if( path.back() ) 01461 outputStream << "+---"; 01462 else 01463 outputStream << "\\---"; 01464 } 01465 outputStream << instance->id_from_handle( node ) << std::endl; 01466 return MB_SUCCESS; 01467 } 01468 01469 ErrorCode TreeLayoutPrinter::leaf( EntityHandle ) 01470 { 01471 return MB_SUCCESS; 01472 } 01473 01474 class TreeNodePrinter : public OrientedBoxTreeTool::Op 01475 { 01476 public: 01477 TreeNodePrinter( std::ostream& stream, 01478 bool list_contents, 01479 bool list_box, 01480 const char* id_tag_name, 01481 OrientedBoxTreeTool* tool_ptr ); 01482 01483 virtual ErrorCode visit( EntityHandle node, int depth, bool& descend ); 01484 01485 virtual ErrorCode leaf( EntityHandle ) 01486 { 01487 return MB_SUCCESS; 01488 } 01489 01490 private: 01491 ErrorCode print_geometry( EntityHandle node ); 01492 ErrorCode print_contents( EntityHandle node ); 01493 ErrorCode print_counts( EntityHandle node ); 01494 01495 bool printContents; 01496 bool printGeometry; 01497 bool haveTag; 01498 Tag tag, gidTag, geomTag; 01499 Interface* instance; 01500 OrientedBoxTreeTool* tool; 01501 std::ostream& outputStream; 01502 }; 01503 01504 TreeNodePrinter::TreeNodePrinter( std::ostream& stream, 01505 bool list_contents, 01506 bool list_box, 01507 const char* id_tag_name, 01508 OrientedBoxTreeTool* tool_ptr ) 01509 : printContents( list_contents ), printGeometry( list_box ), haveTag( false ), tag( 0 ), gidTag( 0 ), geomTag( 0 ), 01510 instance( tool_ptr->get_moab_instance() ), tool( tool_ptr ), outputStream( stream ) 01511 { 01512 ErrorCode rval; 01513 if( id_tag_name ) 01514 { 01515 rval = instance->tag_get_handle( id_tag_name, 1, MB_TYPE_INTEGER, tag ); 01516 if( !rval ) 01517 { 01518 std::cerr << "Could not get tag \"" << id_tag_name << "\"\n"; 01519 stream << "Could not get tag \"" << id_tag_name << "\"\n"; 01520 } 01521 else 01522 { 01523 haveTag = true; 01524 } 01525 } 01526 01527 gidTag = instance->globalId_tag(); 01528 01529 rval = instance->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, geomTag ); 01530 if( MB_SUCCESS != rval ) geomTag = 0; 01531 } 01532 01533 ErrorCode TreeNodePrinter::visit( EntityHandle node, int, bool& descend ) 01534 { 01535 descend = true; 01536 EntityHandle setid = instance->id_from_handle( node ); 01537 outputStream << setid << ":" << std::endl; 01538 01539 Range surfs; 01540 ErrorCode r3 = MB_SUCCESS; 01541 if( geomTag ) 01542 { 01543 const int two = 2; 01544 const void* tagdata[] = { &two }; 01545 r3 = instance->get_entities_by_type_and_tag( node, MBENTITYSET, &geomTag, tagdata, 1, surfs ); 01546 01547 if( MB_SUCCESS == r3 && surfs.size() == 1 ) 01548 { 01549 EntityHandle surf = *surfs.begin(); 01550 int id; 01551 if( gidTag && MB_SUCCESS == instance->tag_get_data( gidTag, &surf, 1, &id ) ) 01552 outputStream << " Surface " << id << std::endl; 01553 else 01554 outputStream << " Surface w/ unknown ID (" << surf << ")" << std::endl; 01555 } 01556 } 01557 01558 ErrorCode r1 = printGeometry ? print_geometry( node ) : MB_SUCCESS; 01559 ErrorCode r2 = printContents ? print_contents( node ) : print_counts( node ); 01560 outputStream << std::endl; 01561 01562 if( MB_SUCCESS != r1 ) 01563 return r1; 01564 else if( MB_SUCCESS != r2 ) 01565 return r2; 01566 else 01567 return r3; 01568 } 01569 01570 ErrorCode TreeNodePrinter::print_geometry( EntityHandle node ) 01571 { 01572 OrientedBox box; 01573 ErrorCode rval = tool->box( node, box ); 01574 if( MB_SUCCESS != rval ) return rval; 01575 01576 CartVect length = box.dimensions(); 01577 01578 outputStream << box.center << " Radius: " << box.inner_radius() << " - " << box.outer_radius() << std::endl 01579 << '+' << box.axis( 0 ) << " : " << length[0] << std::endl 01580 << 'x' << box.axis( 1 ) << " : " << length[1] << std::endl 01581 << 'x' << box.axis( 2 ) << " : " << length[2] << std::endl; 01582 return MB_SUCCESS; 01583 } 01584 01585 ErrorCode TreeNodePrinter::print_counts( EntityHandle node ) 01586 { 01587 for( EntityType type = MBVERTEX; type != MBMAXTYPE; ++type ) 01588 { 01589 int count = 0; 01590 ErrorCode rval = instance->get_number_entities_by_type( node, type, count ); 01591 if( MB_SUCCESS != rval ) return rval; 01592 if( count > 0 ) outputStream << " " << count << " " << CN::EntityTypeName( type ) << std::endl; 01593 } 01594 return MB_SUCCESS; 01595 } 01596 01597 ErrorCode TreeNodePrinter::print_contents( EntityHandle node ) 01598 { 01599 // list contents 01600 for( EntityType type = MBVERTEX; type != MBMAXTYPE; ++type ) 01601 { 01602 Range range; 01603 ErrorCode rval = instance->get_entities_by_type( node, type, range ); 01604 if( MB_SUCCESS != rval ) return rval; 01605 if( range.empty() ) continue; 01606 outputStream << " " << CN::EntityTypeName( type ) << " "; 01607 std::vector< int > ids( range.size() ); 01608 if( haveTag ) 01609 { 01610 rval = instance->tag_get_data( tag, range, &ids[0] ); 01611 std::sort( ids.begin(), ids.end() ); 01612 } 01613 else 01614 { 01615 Range::iterator ri = range.begin(); 01616 std::vector< int >::iterator vi = ids.begin(); 01617 while( ri != range.end() ) 01618 { 01619 *vi = instance->id_from_handle( *ri ); 01620 ++ri; 01621 ++vi; 01622 } 01623 } 01624 01625 unsigned i = 0; 01626 for( ;; ) 01627 { 01628 unsigned beg = i, end; 01629 do 01630 { 01631 end = i++; 01632 } while( i < ids.size() && ids[end] + 1 == ids[i] ); 01633 if( end == beg ) 01634 outputStream << ids[end]; 01635 else if( end == beg + 1 ) 01636 outputStream << ids[beg] << ", " << ids[end]; 01637 else 01638 outputStream << ids[beg] << "-" << ids[end]; 01639 01640 if( i == ids.size() ) 01641 { 01642 outputStream << std::endl; 01643 break; 01644 } 01645 else 01646 outputStream << ", "; 01647 } 01648 } 01649 01650 return MB_SUCCESS; 01651 } 01652 01653 void OrientedBoxTreeTool::print( EntityHandle set, std::ostream& str, bool list, const char* tag ) 01654 { 01655 TreeLayoutPrinter op1( str, instance ); 01656 TreeNodePrinter op2( str, list, true, tag, this ); 01657 ErrorCode r1 = preorder_traverse( set, op1 ); 01658 str << std::endl; 01659 ErrorCode r2 = preorder_traverse( set, op2 ); 01660 if( r1 != MB_SUCCESS || r2 != MB_SUCCESS ) 01661 { 01662 std::cerr << "Errors encountered while printing tree\n"; 01663 str << "Errors encountered while printing tree\n"; 01664 } 01665 } 01666 01667 /********************* Traversal Metrics Code **************************/ 01668 01669 void OrientedBoxTreeTool::TrvStats::reset() 01670 { 01671 nodes_visited_count.clear(); 01672 leaves_visited_count.clear(); 01673 traversals_ended_count.clear(); 01674 ray_tri_tests_count = 0; 01675 } 01676 01677 void OrientedBoxTreeTool::TrvStats::increment( unsigned depth ) 01678 { 01679 01680 while( nodes_visited_count.size() <= depth ) 01681 { 01682 nodes_visited_count.push_back( 0 ); 01683 leaves_visited_count.push_back( 0 ); 01684 traversals_ended_count.push_back( 0 ); 01685 } 01686 nodes_visited_count[depth] += 1; 01687 } 01688 01689 void OrientedBoxTreeTool::TrvStats::increment_leaf( unsigned depth ) 01690 { 01691 // assume safe depth, because increment is called first 01692 leaves_visited_count[depth] += 1; 01693 } 01694 01695 void OrientedBoxTreeTool::TrvStats::end_traversal( unsigned depth ) 01696 { 01697 // assume safe depth, because increment is always called on a given 01698 // tree level first 01699 traversals_ended_count[depth] += 1; 01700 } 01701 01702 void OrientedBoxTreeTool::TrvStats::print( std::ostream& str ) const 01703 { 01704 01705 const std::string h1 = "OBBTree Depth"; 01706 const std::string h2 = " - NodesVisited"; 01707 const std::string h3 = " - LeavesVisited"; 01708 const std::string h4 = " - TraversalsEnded"; 01709 01710 str << h1 << h2 << h3 << h4 << std::endl; 01711 01712 unsigned num_visited = 0, num_leaves = 0, num_traversals = 0; 01713 for( unsigned i = 0; i < traversals_ended_count.size(); ++i ) 01714 { 01715 01716 num_visited += nodes_visited_count[i]; 01717 num_leaves += leaves_visited_count[i]; 01718 num_traversals += traversals_ended_count[i]; 01719 01720 str << std::setw( h1.length() ) << i << std::setw( h2.length() ) << nodes_visited_count[i] 01721 << std::setw( h3.length() ) << leaves_visited_count[i] << std::setw( h4.length() ) 01722 << traversals_ended_count[i] << std::endl; 01723 } 01724 01725 str << std::setw( h1.length() ) << "---- Totals:" << std::setw( h2.length() ) << num_visited 01726 << std::setw( h3.length() ) << num_leaves << std::setw( h4.length() ) << num_traversals << std::endl; 01727 01728 if( ray_tri_tests_count ) 01729 { 01730 str << std::setw( h1.length() ) << "---- Total ray-tri tests: " << ray_tri_tests_count << std::endl; 01731 } 01732 } 01733 01734 /********************** Tree Statistics Code ****************************/ 01735 01736 class StatData 01737 { 01738 public: 01739 struct Ratio 01740 { 01741 double min, max, sum, sqr; 01742 int hist[10]; 01743 Ratio() 01744 : min( std::numeric_limits< double >::max() ), max( -std::numeric_limits< double >::max() ), sum( 0.0 ), 01745 sqr( 0.0 ) 01746 { 01747 hist[0] = hist[1] = hist[2] = hist[3] = hist[4] = hist[5] = hist[6] = hist[7] = hist[8] = hist[9] = 0; 01748 } 01749 void accum( double v ) 01750 { 01751 if( v < min ) min = v; 01752 if( v > max ) max = v; 01753 sum += v; 01754 sqr += v * v; 01755 int i = (int)( 10 * v ); 01756 if( i < 0 ) 01757 i = 0; 01758 else if( i > 9 ) 01759 i = 9; 01760 ++hist[i]; 01761 } 01762 }; 01763 01764 template < typename T > 01765 struct Stat 01766 { 01767 T min, max; 01768 double sum, sqr; 01769 Stat() : sum( 0.0 ), sqr( 0.0 ) 01770 { 01771 std::numeric_limits< T > lim; 01772 min = lim.max(); 01773 if( lim.is_integer ) 01774 max = lim.min(); 01775 else 01776 max = -lim.max(); 01777 } 01778 void accum( T v ) 01779 { 01780 if( v < min ) min = v; 01781 if( v > max ) max = v; 01782 sum += v; 01783 sqr += (double)v * v; 01784 } 01785 }; 01786 01787 StatData() : count( 0 ) {} 01788 01789 Ratio volume; 01790 Ratio entities; 01791 Ratio radius; 01792 Stat< unsigned > leaf_ent; 01793 Stat< double > vol; 01794 Stat< double > area; 01795 std::vector< unsigned > leaf_depth; 01796 unsigned count; 01797 }; 01798 01799 static int measure( const CartVect& v, double& result ) 01800 { 01801 const double tol = 1e-6; 01802 int dims = 0; 01803 result = 1; 01804 for( int i = 0; i < 3; ++i ) 01805 if( v[i] > tol ) 01806 { 01807 ++dims; 01808 result *= v[i]; 01809 } 01810 return dims; 01811 } 01812 01813 ErrorCode OrientedBoxTreeTool::recursive_stats( OrientedBoxTreeTool* tool, 01814 Interface* inst, 01815 EntityHandle set, 01816 int depth, 01817 StatData& data, 01818 unsigned& count_out, 01819 CartVect& dimensions_out ) 01820 { 01821 ErrorCode rval; 01822 OrientedBox tmp_box; 01823 std::vector< EntityHandle > children( 2 ); 01824 unsigned counts[2]; 01825 bool isleaf; 01826 01827 ++data.count; 01828 01829 rval = tool->box( set, tmp_box ); 01830 if( MB_SUCCESS != rval ) return rval; 01831 children.clear(); 01832 rval = inst->get_child_meshsets( set, children ); 01833 if( MB_SUCCESS != rval ) return rval; 01834 isleaf = children.empty(); 01835 if( !isleaf && children.size() != 2 ) return MB_MULTIPLE_ENTITIES_FOUND; 01836 01837 dimensions_out = tmp_box.dimensions(); 01838 data.radius.accum( tmp_box.inner_radius() / tmp_box.outer_radius() ); 01839 data.vol.accum( tmp_box.volume() ); 01840 data.area.accum( tmp_box.area() ); 01841 01842 if( isleaf ) 01843 { 01844 if( data.leaf_depth.size() <= (unsigned)depth ) data.leaf_depth.resize( depth + 1, 0 ); 01845 ++data.leaf_depth[depth]; 01846 01847 int count; 01848 rval = inst->get_number_entities_by_handle( set, count ); 01849 if( MB_SUCCESS != rval ) return rval; 01850 count_out = count; 01851 data.leaf_ent.accum( count_out ); 01852 } 01853 else 01854 { 01855 for( int i = 0; i < 2; ++i ) 01856 { 01857 CartVect dims; 01858 rval = recursive_stats( tool, inst, children[i], depth + 1, data, counts[i], dims ); 01859 if( MB_SUCCESS != rval ) return rval; 01860 double this_measure, chld_measure; 01861 int this_dim = measure( dimensions_out, this_measure ); 01862 int chld_dim = measure( dims, chld_measure ); 01863 double ratio; 01864 if( chld_dim < this_dim ) 01865 ratio = 0; 01866 else 01867 ratio = chld_measure / this_measure; 01868 01869 data.volume.accum( ratio ); 01870 } 01871 count_out = counts[0] + counts[1]; 01872 data.entities.accum( (double)counts[0] / count_out ); 01873 data.entities.accum( (double)counts[1] / count_out ); 01874 } 01875 return MB_SUCCESS; 01876 } 01877 01878 static inline double std_dev( double sqr, double sum, double count ) 01879 { 01880 sum /= count; 01881 sqr /= count; 01882 return sqrt( sqr - sum * sum ); 01883 } 01884 01885 //#define WW <<std::setw(10)<<std::fixed<< 01886 #define WE << std::setw( 10 ) << 01887 #define WW WE 01888 ErrorCode OrientedBoxTreeTool::stats( EntityHandle set, 01889 unsigned& total_entities, 01890 double& rv, 01891 double& tot_node_volume, 01892 double& tot_to_root_volume, 01893 unsigned& tree_height, 01894 unsigned& node_count, 01895 unsigned& num_leaves ) 01896 { 01897 StatData d; 01898 ErrorCode rval; 01899 unsigned i; 01900 CartVect total_dim; 01901 01902 rval = recursive_stats( this, instance, set, 0, d, total_entities, total_dim ); 01903 if( MB_SUCCESS != rval ) return rval; 01904 01905 tree_height = d.leaf_depth.size(); 01906 unsigned min_leaf_depth = tree_height; 01907 num_leaves = 0; 01908 unsigned max_leaf_per_depth = 0; 01909 // double sum_leaf_depth = 0, sqr_leaf_depth = 0; 01910 for( i = 0; i < d.leaf_depth.size(); ++i ) 01911 { 01912 unsigned val = d.leaf_depth[i]; 01913 num_leaves += val; 01914 // sum_leaf_depth += (double)val*i; 01915 // sqr_leaf_depth += (double)val*i*i; 01916 if( val && i < min_leaf_depth ) min_leaf_depth = i; 01917 if( max_leaf_per_depth < val ) max_leaf_per_depth = val; 01918 } 01919 rv = total_dim[0] * total_dim[1] * total_dim[2]; 01920 tot_node_volume = d.vol.sum; 01921 tot_to_root_volume = d.vol.sum / rv; 01922 node_count = d.count; 01923 01924 return MB_SUCCESS; 01925 } 01926 01927 ErrorCode OrientedBoxTreeTool::stats( EntityHandle set, std::ostream& s ) 01928 { 01929 StatData d; 01930 ErrorCode rval; 01931 unsigned total_entities, i; 01932 CartVect total_dim; 01933 01934 rval = recursive_stats( this, instance, set, 0, d, total_entities, total_dim ); 01935 if( MB_SUCCESS != rval ) return rval; 01936 01937 unsigned tree_height = d.leaf_depth.size(); 01938 unsigned min_leaf_depth = tree_height, num_leaves = 0; 01939 unsigned max_leaf_per_depth = 0; 01940 double sum_leaf_depth = 0, sqr_leaf_depth = 0; 01941 for( i = 0; i < d.leaf_depth.size(); ++i ) 01942 { 01943 unsigned val = d.leaf_depth[i]; 01944 num_leaves += val; 01945 sum_leaf_depth += (double)val * i; 01946 sqr_leaf_depth += (double)val * i * i; 01947 if( val && i < min_leaf_depth ) min_leaf_depth = i; 01948 if( max_leaf_per_depth < val ) max_leaf_per_depth = val; 01949 } 01950 unsigned num_non_leaf = d.count - num_leaves; 01951 01952 double rv = total_dim[0] * total_dim[1] * total_dim[2]; 01953 s << "entities in tree: " << total_entities << std::endl 01954 << "root volume: " << rv << std::endl 01955 << "total node volume: " << d.vol.sum << std::endl 01956 << "total/root volume: " << d.vol.sum / rv << std::endl 01957 << "tree height: " << tree_height << std::endl 01958 << "node count: " << d.count << std::endl 01959 << "leaf count: " << num_leaves << std::endl 01960 << std::endl; 01961 01962 double avg_leaf_depth = sum_leaf_depth / num_leaves; 01963 double rms_leaf_depth = sqrt( sqr_leaf_depth / num_leaves ); 01964 double std_leaf_depth = std_dev( sqr_leaf_depth, sum_leaf_depth, num_leaves ); 01965 01966 double avg_leaf_ent = d.leaf_ent.sum / num_leaves; 01967 double rms_leaf_ent = sqrt( d.leaf_ent.sqr / num_leaves ); 01968 double std_leaf_ent = std_dev( d.leaf_ent.sqr, d.leaf_ent.sum, num_leaves ); 01969 01970 unsigned num_child = 2 * num_non_leaf; 01971 01972 double avg_vol_ratio = d.volume.sum / num_child; 01973 double rms_vol_ratio = sqrt( d.volume.sqr / num_child ); 01974 double std_vol_ratio = std_dev( d.volume.sqr, d.volume.sum, num_child ); 01975 01976 double avg_ent_ratio = d.entities.sum / num_child; 01977 double rms_ent_ratio = sqrt( d.entities.sqr / num_child ); 01978 double std_ent_ratio = std_dev( d.entities.sqr, d.entities.sum, num_child ); 01979 01980 double avg_rad_ratio = d.radius.sum / d.count; 01981 double rms_rad_ratio = sqrt( d.radius.sqr / d.count ); 01982 double std_rad_ratio = std_dev( d.radius.sqr, d.radius.sum, d.count ); 01983 01984 double avg_vol = d.vol.sum / d.count; 01985 double rms_vol = sqrt( d.vol.sqr / d.count ); 01986 double std_vol = std_dev( d.vol.sqr, d.vol.sum, d.count ); 01987 01988 double avg_area = d.area.sum / d.count; 01989 double rms_area = sqrt( d.area.sqr / d.count ); 01990 double std_area = std_dev( d.area.sqr, d.area.sum, d.count ); 01991 01992 int prec = s.precision(); 01993 s << " " WW "Minimum" WW "Average" WW "RMS" WW "Maximum" WW "Std.Dev." << std::endl; 01994 s << std::setprecision( 1 ) 01995 << "Leaf Depth " WW min_leaf_depth WW avg_leaf_depth WW rms_leaf_depth WW d.leaf_depth.size() - 01996 1 WW std_leaf_depth 01997 << std::endl; 01998 s << std::setprecision( 0 ) 01999 << "Entities/Leaf " WW d.leaf_ent.min WW avg_leaf_ent WW rms_leaf_ent WW d.leaf_ent.max WW std_leaf_ent 02000 << std::endl; 02001 s << std::setprecision( 3 ) 02002 << "Child Volume Ratio " WW d.volume.min WW avg_vol_ratio WW rms_vol_ratio WW d.volume.max WW std_vol_ratio 02003 << std::endl; 02004 s << std::setprecision( 3 ) 02005 << "Child Entity Ratio " WW d.entities.min WW avg_ent_ratio WW rms_ent_ratio WW d.entities.max WW std_ent_ratio 02006 << std::endl; 02007 s << std::setprecision( 3 ) 02008 << "Box Radius Ratio " WW d.radius.min WW avg_rad_ratio WW rms_rad_ratio WW d.radius.max WW std_rad_ratio 02009 << std::endl; 02010 s << std::setprecision( 0 ) << "Box volume " WE d.vol.min WE avg_vol WE rms_vol WE d.vol.max WE std_vol 02011 << std::endl; 02012 s << std::setprecision( 0 ) << "Largest side area " WE d.area.min WE avg_area WE rms_area WE d.area.max WE std_area 02013 << std::endl; 02014 s << std::setprecision( prec ) << std::endl; 02015 02016 s << "Leaf Depth Histogram (Root depth is 0)" << std::endl; 02017 double f = 60.0 / max_leaf_per_depth; 02018 for( i = min_leaf_depth; i < d.leaf_depth.size(); ++i ) 02019 s << std::setw( 2 ) << i << " " << std::setw( 5 ) << d.leaf_depth[i] << " |" << std::setfill( '*' ) 02020 << std::setw( (int)floor( f * d.leaf_depth[i] + 0.5 ) ) << "" << std::setfill( ' ' ) << std::endl; 02021 s << std::endl; 02022 02023 s << "Child/Parent Volume Ratio Histogram" << std::endl; 02024 f = 60.0 / *( std::max_element( d.volume.hist, d.volume.hist + 10 ) ); 02025 for( i = 0; i < 10u; ++i ) 02026 s << "0." << i << " " << std::setw( 5 ) << d.volume.hist[i] << " |" << std::setfill( '*' ) 02027 << std::setw( (int)floor( f * d.volume.hist[i] + 0.5 ) ) << "" << std::setfill( ' ' ) << std::endl; 02028 s << std::endl; 02029 02030 s << "Child/Parent Entity Count Ratio Histogram" << std::endl; 02031 f = 60.0 / *( std::max_element( d.entities.hist, d.entities.hist + 10 ) ); 02032 for( i = 0; i < 10u; ++i ) 02033 s << "0." << i << " " << std::setw( 5 ) << d.entities.hist[i] << " |" << std::setfill( '*' ) 02034 << std::setw( (int)floor( f * d.entities.hist[i] + 0.5 ) ) << "" << std::setfill( ' ' ) << std::endl; 02035 s << std::endl; 02036 02037 s << "Inner/Outer Radius Ratio Histogram (~0.70 for cube)" << std::endl; 02038 // max radius ratio for a box is about 0.7071. Move any boxes 02039 // in the .7 bucket into .6 and print .0 to .6. 02040 d.radius.hist[6] += d.radius.hist[7]; 02041 f = 60.0 / *( std::max_element( d.entities.hist, d.entities.hist + 7 ) ); 02042 for( i = 0; i < 7u; ++i ) 02043 s << "0." << i << " " << std::setw( 5 ) << d.entities.hist[i] << " |" << std::setfill( '*' ) 02044 << std::setw( (int)floor( f * d.entities.hist[i] + 0.5 ) ) << "" << std::setfill( ' ' ) << std::endl; 02045 s << std::endl; 02046 02047 return MB_SUCCESS; 02048 } 02049 02050 } // namespace moab
