MOAB: Mesh Oriented datABase
(version 5.4.1)
Misc. knobs controlling tree subdivision. More...
#include <OrientedBoxTreeTool.hpp>
Public Member Functions | |
| Settings () | |
| set defaults | |
| bool | valid () const |
| Check if settings are valid. | |
Public Attributes | |
| int | max_leaf_entities |
| Average number of entities per leaf. | |
| int | max_depth |
| double | worst_split_ratio |
| double | best_split_ratio |
| unsigned int | set_options |
| Flags used to create entity sets representing tree nodes. | |
Available settings for controlling when and how nodes in the tree are split. The constructor will initialize to the default settings. All settings except best_split_ratio control when a node is subdivided. best_split_ratio influences the choice of how the node is subdivided.
A calculated ratio is used in the determination of when and how to split a node. The ratio is calculated as:
ALL of the following conditions must be met for a node to be further subdivied:
The node will be subdivided using a plane normal to one of the box axis and containing the box center. The planes are tested beginning with the one orthogonal to the longest box axis and finishing with the one orthogonal to the shortest box axis. The search will stop at the first plane for which the 'ratio' is at least Settings::best_split_ratio . Giving Settings::best_split_ratio a non-zero value gives preference to a split orthogonal to larger box dimensions.
Definition at line 88 of file OrientedBoxTreeTool.hpp.
set defaults
Definition at line 72 of file OrientedBoxTreeTool.cpp.
: max_leaf_entities( 8 ), max_depth( 0 ), worst_split_ratio( 0.95 ), best_split_ratio( 0.4 ), set_options( MESHSET_SET ) { }
| bool moab::OrientedBoxTreeTool::Settings::valid | ( | ) | const |
Definition at line 78 of file OrientedBoxTreeTool.cpp.
References max_depth.
Referenced by moab::OrientedBoxTreeTool::build(), moab::OrientedBoxTreeTool::join_trees(), and main().
return max_leaf_entities > 0 && max_depth >= 0 && worst_split_ratio <= 1.0 && best_split_ratio >= 0.0 &&
worst_split_ratio >= best_split_ratio;
Must be in [0.0,worst_split_ratio] The search for an optimal split plane for splitting a node will stop if at least this ratio is achieved for the number of entities on each side of the split plane.
Definition at line 102 of file OrientedBoxTreeTool.hpp.
Referenced by moab::OrientedBoxTreeTool::build_tree(), main(), and usage().
Maximum tree depth - 0->no limit
Definition at line 93 of file OrientedBoxTreeTool.hpp.
Referenced by moab::OrientedBoxTreeTool::build_tree(), main(), usage(), and TreeValidator::visit().
Definition at line 92 of file OrientedBoxTreeTool.hpp.
| unsigned int moab::OrientedBoxTreeTool::Settings::set_options |
Definition at line 104 of file OrientedBoxTreeTool.hpp.
Referenced by moab::OrientedBoxTreeTool::build_sets(), moab::OrientedBoxTreeTool::build_tree(), and main().
Must be in [best_split_ratio,1.0] A tree node will not be split if the ratio of children in the child nodes is greater than this value.
Definition at line 97 of file OrientedBoxTreeTool.hpp.
