moab::WriteNC Class Reference
Export NC files. More...
#include <WriteNC.hpp>
+ Inheritance diagram for moab::WriteNC:
+ Collaboration diagram for moab::WriteNC:
Classes
class  AttData
class  VarData
Public Member Functions
 WriteNC (Interface *impl=NULL)
 Constructor.
virtual ~WriteNC ()
 Destructor.
ErrorCode write_file (const char *file_name, const bool overwrite, const FileOptions &opts, const EntityHandle *output_list, const int num_sets, const std::vector< std::string > &qa_list, const Tag *tag_list=NULL, int num_tags=0, int export_dimension=3)
 Writes out a file.
Static Public Member Functions
static WriterIface * factory (Interface *)
 Factory method.
Private Types
enum  EntityLocation {
  ENTLOCVERT = 0, ENTLOCNSEDGE, ENTLOCEWEDGE, ENTLOCFACE,
  ENTLOCSET, ENTLOCEDGE, ENTLOCREGION
Private Member Functions
ErrorCode parse_options (const FileOptions &opts, std::vector< std::string > &var_names, std::vector< std::string > &desired_names, std::vector< int > &tstep_nums, std::vector< double > &tstep_vals)
ErrorCode process_conventional_tags (EntityHandle fileSet)
ErrorCode process_concatenated_attribute (const void *attPtr, int attSz, std::vector< int > &attLen, std::map< std::string, AttData > &attributes)
Private Attributes
std::vector< std::string > dimNames
std::vector< int > dimLens
 Dimension lengths.
std::set< std::string > usedCoordinates
 Will collect used dimensions (coordinate variables)
std::set< std::string > dummyVarNames
 Dummy variables (for dimensions that have no corresponding coordinate variables)
std::map< std::string, AttData > globalAtts
 Global attribs.
std::map< std::string, VarData > varInfo
 Variable info.
Interface * mbImpl
 Interface instance.
WriteUtilIface * mWriteIface
const char * fileName
 File var.
int fileId
 File numbers assigned by (p)netcdf.
DebugOutput dbgOut
 Debug stuff.
bool noMesh
 Write options.
bool noVars
bool append
Tag mGlobalIdTag
 Cached tags for writing. This will be important for ordering the data, in parallel.
bool isParallel
 Are we writing in parallel? (probably in the future)
std::string grid_type
 CAM Euler, etc,.
NCWriteHelper * myHelper
 Helper class instance.
Friends
class NCWriteHelper
class ScdNCWriteHelper
class UcdNCWriteHelper
class NCWriteEuler
class NCWriteFV
class NCWriteHOMME
class NCWriteMPAS
class NCWriteGCRM
Detailed Description
Export NC files.
Definition at line 70 of file WriteNC.hpp.
Member Enumeration Documentation
ENTLOCNSEDGE for north/south edge ENTLOCWEEDGE for west/east edge
Enumerator:
ENTLOCVERT
ENTLOCNSEDGE
ENTLOCEWEDGE
ENTLOCFACE
ENTLOCSET
ENTLOCEDGE
ENTLOCREGION
Definition at line 105 of file WriteNC.hpp.
moab::WriteNC::WriteNC ( Interface *  impl = NULL)
Constructor.
Definition at line 32 of file WriteNC.cpp.
References mWriteIface, and moab::Interface::query_interface().
Referenced by factory().
    : mbImpl( impl ), dbgOut( stderr ),
#ifdef MOAB_HAVE_MPI
      myPcomm( NULL ),
#endif
      noMesh( false ), noVars( false ), append( false ), mGlobalIdTag( 0 ), isParallel( false ), myHelper( NULL )
    assert( impl != NULL );
    impl->query_interface( mWriteIface );
moab::WriteNC::~WriteNC ( ) [virtual]
Destructor.
Definition at line 43 of file WriteNC.cpp.
References mbImpl, mWriteIface, myHelper, and moab::Interface::release_interface().
    mbImpl->release_interface( mWriteIface );
    if( myHelper != NULL ) delete myHelper;
Member Function Documentation
WriterIface * moab::WriteNC::factory ( Interface *  iface) [static]
Factory method.
Definition at line 27 of file WriteNC.cpp.
References WriteNC().
Referenced by moab::ReaderWriterSet::ReaderWriterSet().
    return new WriteNC( iface );
ErrorCode moab::WriteNC::parse_options ( const FileOptions &  opts,
std::vector< std::string > &  var_names,
std::vector< std::string > &  desired_names,
std::vector< int > &  tstep_nums,
std::vector< double > &  tstep_vals
) [private]
Definition at line 140 of file WriteNC.cpp.
References append, dbgOut, ErrorCode, moab::FileOptions::get_int_option(), moab::FileOptions::get_ints_option(), moab::FileOptions::get_null_option(), moab::ParallelComm::get_pcomm(), moab::FileOptions::get_reals_option(), moab::FileOptions::get_strs_option(), moab::DebugOutput::get_verbosity(), isParallel, moab::FileOptions::match_option(), MB_ENTITY_NOT_FOUND, MB_SET_ERR, MB_SUCCESS, MB_TYPE_OUT_OF_RANGE, MB_UNSUPPORTED_OPERATION, mbImpl, MPI_COMM_WORLD, noMesh, noVars, rank, moab::DebugOutput::set_prefix(), moab::DebugOutput::set_rank(), and moab::DebugOutput::set_verbosity().
Referenced by write_file().
    int tmpval;
    if( MB_SUCCESS == opts.get_int_option( "DEBUG_IO", 1, tmpval ) )
        dbgOut.set_verbosity( tmpval );
        dbgOut.set_prefix( "NCWrite" );
    ErrorCode rval = opts.get_strs_option( "VARIABLE", var_names );
    if( MB_TYPE_OUT_OF_RANGE == rval )
        noVars = true;
    else
        noVars = false;
    rval = opts.get_strs_option( "RENAME", desired_names );
    if( MB_ENTITY_NOT_FOUND == rval )
        if( !noVars )
            desired_names.resize( var_names.size() );
            std::copy( var_names.begin(), var_names.end(), desired_names.begin() );
    // Either way
    assert( desired_names.size() == var_names.size() );
    opts.get_ints_option( "TIMESTEP", tstep_nums );
    opts.get_reals_option( "TIMEVAL", tstep_vals );
    rval = opts.get_null_option( "NOMESH" );
    if( MB_SUCCESS == rval ) noMesh = true;
    rval = opts.get_null_option( "APPEND" );
    if( MB_SUCCESS == rval ) append = true;
    if( 2 <= dbgOut.get_verbosity() )
        if( !var_names.empty() )
            std::cerr << "Variables requested: ";
            for( unsigned int i = 0; i < var_names.size(); i++ )
                std::cerr << var_names[i];
            std::cerr << std::endl;
        if( !tstep_nums.empty() )
            std::cerr << "Timesteps requested: ";
            for( unsigned int i = 0; i < tstep_nums.size(); i++ )
                std::cerr << tstep_nums[i];
        if( !tstep_vals.empty() )
            std::cerr << "Time vals requested: ";
            for( unsigned int i = 0; i < tstep_vals.size(); i++ )
                std::cerr << tstep_vals[i];
// FIXME: copied from ReadNC, may need revise
    isParallel = ( opts.match_option( "PARALLEL", "WRITE_PART" ) != MB_ENTITY_NOT_FOUND );
    if( !isParallel )
        // Return success here, since rval still has _NOT_FOUND from not finding option
        // in this case, myPcomm will be NULL, so it can never be used; always check for isParallel
        // before any use for myPcomm
        return MB_SUCCESS;
    int pcomm_no = 0;
    rval         = opts.get_int_option( "PARALLEL_COMM", pcomm_no );
        MB_SET_ERR( rval, "Invalid value for PARALLEL_COMM option" );
    myPcomm = ParallelComm::get_pcomm( mbImpl, pcomm_no );
    if( 0 == myPcomm )
        myPcomm = new ParallelComm( mbImpl, MPI_COMM_WORLD );
#ifndef MOAB_HAVE_PNETCDF
    const int procs = myPcomm->proc_config().proc_size();
    if( procs > 1 )
        MB_SET_ERR( MB_UNSUPPORTED_OPERATION, "Attempt to launch NC writer in parallel without pnetcdf support" );
#endif
    const int rank = myPcomm->proc_config().proc_rank();
    dbgOut.set_rank( rank );
#endif
    return MB_SUCCESS;
ErrorCode moab::WriteNC::process_concatenated_attribute ( const void *  attPtr,
int  attSz,
std::vector< int > &  attLen,
std::map< std::string, AttData > &  attributes
) [private]
Definition at line 455 of file WriteNC.cpp.
References moab::WriteNC::AttData::attDataType, moab::WriteNC::AttData::attLen, moab::WriteNC::AttData::attValue, dbgOut, MB_SET_ERR, MB_SUCCESS, and moab::DebugOutput::tprintf().
Referenced by process_conventional_tags().
    std::size_t start       = 0;
    std::size_t att_counter = 0;
    std::string concatString( (char*)attPtr, (char*)attPtr + attSz );
    for( std::size_t i = 0; i != (size_t)attSz; i++ )
        if( concatString[i] == '\0' )
            std::string att_name( &concatString[start], i - start );
            start = i + 1;
            while( concatString[i] != ';' )
                ++i;
            std::string data_type( &concatString[start], i - start );
            ++i;
            start = i;
            i     = attLen[att_counter];
            if( concatString[i] != ';' ) MB_SET_ERR( MB_FAILURE, "Error parsing attributes" );
            std::string data_val( &concatString[start], i - start );
            start = i + 1;
            AttData& attrib = attributes[att_name];
            attrib.attValue = data_val;
            attrib.attLen   = data_val.size();
            if( data_type == "char" )
                attrib.attDataType = NC_CHAR;
            else if( data_type == "double" )
                attrib.attDataType = NC_DOUBLE;
            else if( data_type == "float" )
                attrib.attDataType = NC_FLOAT;
            else if( data_type == "int" )
                attrib.attDataType = NC_INT;
            else if( data_type == "short" )
                attrib.attDataType = NC_SHORT;
            ++att_counter;
            dbgOut.tprintf( 2, "       Process attribute %s with value %s \n", att_name.c_str(), data_val.c_str() );
    return MB_SUCCESS;
Definition at line 244 of file WriteNC.cpp.
References dbgOut, dimLens, dimNames, dummyVarNames, moab::WriteNC::VarData::entLoc, ErrorCode, globalAtts, grid_type, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, MB_TAG_ANY, MB_TAG_NOT_FOUND, MB_TAG_SPARSE, MB_TAG_VARLEN, MB_TYPE_INTEGER, MB_TYPE_OPAQUE, mbImpl, moab::WriteNC::VarData::numAtts, process_concatenated_attribute(), moab::Interface::tag_get_by_ptr(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), moab::Interface::tag_get_length(), moab::Interface::tag_get_name(), moab::DebugOutput::tprintf(), moab::WriteNC::VarData::varAtts, moab::WriteNC::VarData::varDims, varInfo, and moab::WriteNC::VarData::varName.
    ErrorCode rval;
    // Start copy
    Tag dimNamesTag      = 0;
    std::string tag_name = "__DIM_NAMES";
    const void* data     = NULL;
    int dimNamesSz       = 0;
    rval                 = mbImpl->tag_get_handle( tag_name.c_str(), 0, MB_TYPE_OPAQUE, dimNamesTag, MB_TAG_ANY );MB_CHK_SET_ERR( rval, "Trouble getting conventional tag " << tag_name );
    rval = mbImpl->tag_get_by_ptr( dimNamesTag, &fileSet, 1, &data, &dimNamesSz );MB_CHK_SET_ERR( rval, "Trouble getting data of conventional tag " << tag_name );
    const char* p = static_cast< const char* >( data );
    dbgOut.tprintf( 1, "__DIM_NAMES tag has string length %d\n", dimNamesSz );
    Tag dimLensTag = 0;
    tag_name       = "__DIM_LENS";
    data           = NULL;
    int dimLensSz  = 0;
    rval           = mbImpl->tag_get_handle( tag_name.c_str(), 0, MB_TYPE_INTEGER, dimLensTag, MB_TAG_ANY );MB_CHK_SET_ERR( rval, "Trouble getting conventional tag " << tag_name );
    rval = mbImpl->tag_get_by_ptr( dimLensTag, &fileSet, 1, &data, &dimLensSz );MB_CHK_SET_ERR( rval, "Trouble getting data of conventional tag " << tag_name );
    const int* int_p = static_cast< const int* >( data );
    dbgOut.tprintf( 1, "__DIM_LENS tag has %d values\n", dimLensSz );
    int idxDim = 0;
    // Dim names are separated by '\0' in the string of __DIM_NAMES tag
    for( std::size_t i = 0; i != static_cast< std::size_t >( dimNamesSz ); i++ )
        if( p[i] == '\0' )
            std::string dim_name( &p[start], i - start );
            int len = int_p[idxDim];
            dimNames.push_back( dim_name );
            dimLens.push_back( len );
            dbgOut.tprintf( 2, "Dimension %s has length %d\n", dim_name.c_str(), len );
            // FIXME: Need info from moab to set unlimited dimension
            // Currently assume each file has the same number of time dimensions
            /*if ((dim_name == "time") || (dim_name == "Time"))
              insert(dim_name, *(new pcdim(dim_name, len * m_file_names.size(), true)));
            else
              insert(dim_name, *(new pcdim(dim_name, len)));*/
            start = i + 1;
            idxDim++;
    Tag meshTypeTag = 0;
    tag_name        = "__MESH_TYPE";
    data            = NULL;
    int meshTypeSz  = 0;
    rval            = mbImpl->tag_get_handle( tag_name.c_str(), 0, MB_TYPE_OPAQUE, meshTypeTag, MB_TAG_ANY );MB_CHK_SET_ERR( rval, "Trouble getting conventional tag " << tag_name );
    rval = mbImpl->tag_get_by_ptr( meshTypeTag, &fileSet, 1, &data, &meshTypeSz );MB_CHK_SET_ERR( rval, "Trouble getting data of conventional tag " << tag_name );
    grid_type = std::string( &p[0], meshTypeSz );
    dbgOut.tprintf( 2, "Mesh type: %s\n", grid_type.c_str() );
    // Read <__VAR_NAMES_LOCATIONS> tag
    Tag varNamesLocsTag = 0;
    tag_name            = "__VAR_NAMES_LOCATIONS";
    data                = NULL;
    int varNamesLocsSz  = 0;
    rval                = mbImpl->tag_get_handle( tag_name.c_str(), 0, MB_TYPE_INTEGER, varNamesLocsTag, MB_TAG_ANY );MB_CHK_SET_ERR( rval, "Trouble getting conventional tag " << tag_name );
    rval = mbImpl->tag_get_by_ptr( varNamesLocsTag, &fileSet, 1, &data, &varNamesLocsSz );MB_CHK_SET_ERR( rval, "Trouble getting data of conventional tag " << tag_name );
    std::vector< int > varNamesLocs( varNamesLocsSz );
    std::copy( int_p, int_p + varNamesLocsSz, varNamesLocs.begin() );
    Tag varNamesTag = 0;
    tag_name        = "__VAR_NAMES";
    rval            = mbImpl->tag_get_handle( tag_name.c_str(), 0, MB_TYPE_OPAQUE, varNamesTag, MB_TAG_ANY );MB_CHK_SET_ERR( rval, "Trouble getting conventional tag " << tag_name );
    data           = NULL;
    int varNamesSz = 0;
    rval           = mbImpl->tag_get_by_ptr( varNamesTag, &fileSet, 1, &data, &varNamesSz );MB_CHK_SET_ERR( rval, "Trouble getting data of conventional tag " << tag_name );
    dbgOut.tprintf( 2, "__VAR_NAMES tag has string length %d\n", varNamesSz );
    start      = 0;
    int idxVar = 0;
    int sz;
    // Var names are separated by '\0' in the string of __VAR_NAMES tag
    for( std::size_t i = 0; i != static_cast< std::size_t >( varNamesSz ); i++ )
        if( p[i] == '\0' )
            std::string var_name( &p[start], i - start );
            dbgOut.tprintf( 2, "var name: %s index %d \n", var_name.c_str(), idxVar );
            // Process var name:
            // This will create/initiate map; we will populate variableDataStruct with info about
            // dims, tags, etc reference & is important; otherwise variableDataStruct will go out of
            // scope, and deleted :(
            VarData& variableDataStruct = varInfo[var_name];
            variableDataStruct.varName  = var_name;
            variableDataStruct.entLoc   = varNamesLocs[idxVar];
            dbgOut.tprintf( 2, "at var name %s varInfo size %d \n", var_name.c_str(), (int)varInfo.size() );
            sz                    = 0;
            Tag dims_tag          = 0;
            std::string dim_names = "__" + var_name + "_DIMS";
            rval = mbImpl->tag_get_handle( dim_names.c_str(), 0, MB_TYPE_OPAQUE, dims_tag, MB_TAG_ANY );
            if( MB_SUCCESS != rval )
                if( MB_TAG_NOT_FOUND == rval )
                    dbgOut.tprintf( 2, "tag : %s not found, continue \n", dim_names.c_str() );
                    start = i + 1;
                    idxVar++;
                    continue;
                MB_SET_ERR( rval, "Trouble getting conventional tag " << dim_names );
            rval = mbImpl->tag_get_length( dims_tag, sz );MB_CHK_SET_ERR( rval, "Trouble getting size of dimensions for variable " << var_name );
            sz /= sizeof( Tag );  // The type is MB_TYPE_OPAQUE, but it is a list of tags, so we
                                  // need to divide by the size of Tag
            // sz is used for number of dimension tags in this list
            dbgOut.tprintf( 2, "var name: %s has %d dimensions \n", var_name.c_str(), sz );
            variableDataStruct.varDims.resize( sz );
            const void* ptr = NULL;
            rval            = mbImpl->tag_get_by_ptr( dims_tag, &fileSet, 1, &ptr );
            const Tag* ptags = static_cast< const moab::Tag* >( ptr );
            for( std::size_t j = 0; j != static_cast< std::size_t >( sz ); j++ )
                std::string dim_name;
                rval = mbImpl->tag_get_name( ptags[j], dim_name );MB_CHK_SET_ERR( rval, "Trouble getting dimension of variable " << var_name );
                dbgOut.tprintf( 2, "var name: %s has %s as dimension \n", var_name.c_str(), dim_name.c_str() );
                std::vector< std::string >::iterator vit = std::find( dimNames.begin(), dimNames.end(), dim_name );
                if( vit == dimNames.end() )
                    MB_SET_ERR( MB_FAILURE, "Dimension " << dim_name << " not found for variable " << var_name );
                variableDataStruct.varDims[j] = (int)( vit - dimNames.begin() );  // Will be used for writing
                // This will have to change to actual file dimension, for writing
            // Attributes for this variable
            std::stringstream ssTagName;
            ssTagName << "__" << var_name << "_ATTRIBS";
            tag_name      = ssTagName.str();
            Tag varAttTag = 0;
            rval =
                mbImpl->tag_get_handle( tag_name.c_str(), 0, MB_TYPE_OPAQUE, varAttTag, MB_TAG_SPARSE | MB_TAG_VARLEN );MB_CHK_SET_ERR( rval, "Trouble getting conventional tag " << tag_name );
            const void* varAttPtr = NULL;
            int varAttSz          = 0;
            rval                  = mbImpl->tag_get_by_ptr( varAttTag, &fileSet, 1, &varAttPtr, &varAttSz );MB_CHK_SET_ERR( rval, "Trouble getting data of conventional tag " << tag_name );
            if( MB_SUCCESS == rval ) dbgOut.tprintf( 2, "Tag retrieved for variable %s\n", tag_name.c_str() );
            std::string attribString( (char*)varAttPtr, (char*)varAttPtr + varAttSz );
            if( attribString == "NO_ATTRIBS" )
                // This variable has no attributes
                variableDataStruct.numAtts = 0;
            else if( attribString == "DUMMY_VAR" )
                // This variable is a dummy coordinate variable
                dummyVarNames.insert( variableDataStruct.varName );
            else
                ssTagName << "_LEN";
                Tag varAttLenTag = 0;
                rval = mbImpl->tag_get_handle( tag_name.c_str(), 0, MB_TYPE_INTEGER, varAttLenTag, MB_TAG_ANY );MB_CHK_SET_ERR( rval, "Trouble getting conventional tag " << tag_name );
                int varAttLenSz = 0;
                rval            = mbImpl->tag_get_length( varAttLenTag, varAttLenSz );MB_CHK_SET_ERR( rval, "Trouble getting length of conventional tag " << tag_name );
                std::vector< int > varAttLen( varAttLenSz );
                rval = mbImpl->tag_get_data( varAttLenTag, &fileSet, 1, &varAttLen[0] );MB_CHK_SET_ERR( rval, "Trouble getting data of conventional tag " << tag_name );
                rval = process_concatenated_attribute( varAttPtr, varAttSz, varAttLen, variableDataStruct.varAtts );MB_CHK_SET_ERR( rval, "Trouble processing attributes of variable " << var_name );
                if( MB_SUCCESS == rval ) dbgOut.tprintf( 2, "Tag metadata for variable %s\n", tag_name.c_str() );
            // End attribute
            start = i + 1;
            idxVar++;
        }  // if (p[i] == '\0')
    // Global attributes
    tag_name         = "__GLOBAL_ATTRIBS";
    Tag globalAttTag = 0;
    rval = mbImpl->tag_get_handle( tag_name.c_str(), 0, MB_TYPE_OPAQUE, globalAttTag, MB_TAG_SPARSE | MB_TAG_VARLEN );MB_CHK_SET_ERR( rval, "Trouble getting conventional tag " << tag_name );
    std::vector< int > gattLen;
    const void* gattptr = NULL;
    int globalAttSz     = 0;
    rval                = mbImpl->tag_get_by_ptr( globalAttTag, &fileSet, 1, &gattptr, &globalAttSz );MB_CHK_SET_ERR( rval, "Trouble getting data of conventional tag " << tag_name );
    if( MB_SUCCESS == rval ) dbgOut.tprintf( 2, "Tag value retrieved for %s size %d\n", tag_name.c_str(), globalAttSz );
    // <__GLOBAL_ATTRIBS_LEN>
    tag_name            = "__GLOBAL_ATTRIBS_LEN";
    Tag globalAttLenTag = 0;
    rval = mbImpl->tag_get_handle( tag_name.c_str(), 0, MB_TYPE_INTEGER, globalAttLenTag, MB_TAG_ANY );MB_CHK_SET_ERR( rval, "Trouble getting conventional tag " << tag_name );
    int sizeGAtt = 0;
    rval         = mbImpl->tag_get_length( globalAttLenTag, sizeGAtt );MB_CHK_SET_ERR( rval, "Trouble getting length of conventional tag " << tag_name );
    gattLen.resize( sizeGAtt );
    rval = mbImpl->tag_get_data( globalAttLenTag, &fileSet, 1, &gattLen[0] );MB_CHK_SET_ERR( rval, "Trouble getting data of conventional tag " << tag_name );
    rval = process_concatenated_attribute( gattptr, globalAttSz, gattLen, globalAtts );MB_CHK_SET_ERR( rval, "Trouble processing global attributes" );
    return MB_SUCCESS;
ErrorCode moab::WriteNC::write_file ( const char *  file_name,
const EntityHandle *  output_list,
const int  num_sets,
const std::vector< std::string > &  qa_list,
const Tag *  tag_list = NULL,
int  num_tags = 0,
int  export_dimension = 3
) [virtual]
Writes out a file.
Implements moab::WriterIface.
Definition at line 50 of file WriteNC.cpp.
References append, moab::NCWriteHelper::collect_mesh_info(), moab::NCWriteHelper::collect_variable_data(), create(), dbgOut, ErrorCode, fileId, fileName, moab::NCWriteHelper::get_nc_helper(), moab::Interface::globalId_tag(), moab::NCWriteHelper::init_file(), isParallel, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, mbImpl, mGlobalIdTag, myHelper, NCFUNC, parse_options(), process_conventional_tags(), moab::DebugOutput::tprintf(), and moab::NCWriteHelper::write_values().
    ErrorCode rval;
    // See if opts has variable(s) specified
    std::vector< std::string > var_names;
    std::vector< std::string > desired_names;
    std::vector< int > tstep_nums;
    std::vector< double > tstep_vals;
    // Get and cache predefined tag handles
    mGlobalIdTag = mbImpl->globalId_tag();
    // num set has to be 1, we will write only one set, the original file set used to load
    if( num_set != 1 ) MB_SET_ERR( MB_FAILURE, "We should write only one set (the file set used to read data into)" );
    rval = parse_options( options, var_names, desired_names, tstep_nums, tstep_vals );MB_CHK_SET_ERR( rval, "Trouble parsing option string" );
    // Important to create some data that will be used to write the file; dimensions, variables, etc
    // new variables still need to have some way of defining their dimensions
    // maybe it will be passed as write options
    rval = process_conventional_tags( *file_set );MB_CHK_SET_ERR( rval, "Trouble processing conventional tags" );
    // Create or append the file
    if( append )
        dbgOut.tprintf( 1, "opening file %s for appending \n", file_name );
    else
        dbgOut.tprintf( 1, "creating file %s\n", file_name );
    fileName = file_name;
    int success;
    if( append )
        int omode = NC_WRITE;
#ifdef MOAB_HAVE_PNETCDF
        if( isParallel )
            success = NCFUNC( open )( myPcomm->proc_config().proc_comm(), file_name, omode, MPI_INFO_NULL, &fileId );
        else
            success = NCFUNC( open )( MPI_COMM_SELF, file_name, omode, MPI_INFO_NULL, &fileId );
#else
        // This is a regular netcdf file, open in write mode
        success = NCFUNC( open )( file_name, omode, &fileId );
#endif
        if( success ) MB_SET_ERR( MB_FAILURE, "Trouble opening file " << file_name << " for appending" );
    else
    {  // Case when the file is new, will be overwritten, most likely
        int cmode = overwrite ? NC_CLOBBER : NC_NOCLOBBER;
        if( isParallel )
            success = NCFUNC( create )( myPcomm->proc_config().proc_comm(), file_name, cmode, MPI_INFO_NULL, &fileId );
        else
            success = NCFUNC( create )( MPI_COMM_SELF, file_name, cmode, MPI_INFO_NULL, &fileId );
#else
        success = NCFUNC( create )( file_name, cmode, &fileId );
#endif
        if( success ) MB_SET_ERR( MB_FAILURE, "Trouble creating file " << file_name << " for writing" );
    if( NULL != myHelper ) delete myHelper;
    // Get appropriate helper instance for WriteNC class based on some info in the file set
    myHelper = NCWriteHelper::get_nc_helper( this, fileId, options, *file_set );
    if( NULL == myHelper )
        MB_SET_ERR( MB_FAILURE, "Failed to get NCWriteHelper class instance" );
    rval = myHelper->collect_mesh_info();MB_CHK_SET_ERR( rval, "Trouble collecting mesh information" );
    rval = myHelper->collect_variable_data( var_names, tstep_nums );MB_CHK_SET_ERR( rval, "Trouble collecting variable data" );
    rval = myHelper->init_file( var_names, desired_names, append );MB_CHK_SET_ERR( rval, "Trouble initializing file" );
    rval = myHelper->write_values( var_names, tstep_nums );MB_CHK_SET_ERR( rval, "Trouble writing values to file" );
    success = NCFUNC( close )( fileId );
    if( success ) MB_SET_ERR( MB_FAILURE, "Trouble closing file" );
    return MB_SUCCESS;
Friends And Related Function Documentation
friend class NCWriteEuler [friend]
Definition at line 75 of file WriteNC.hpp.
friend class NCWriteFV [friend]
Definition at line 76 of file WriteNC.hpp.
friend class NCWriteGCRM [friend]
Definition at line 79 of file WriteNC.hpp.
friend class NCWriteHelper [friend]
Definition at line 72 of file WriteNC.hpp.
friend class NCWriteHOMME [friend]
Definition at line 77 of file WriteNC.hpp.
friend class NCWriteMPAS [friend]
Definition at line 78 of file WriteNC.hpp.
friend class ScdNCWriteHelper [friend]
Definition at line 73 of file WriteNC.hpp.
friend class UcdNCWriteHelper [friend]
Definition at line 74 of file WriteNC.hpp.
Member Data Documentation
bool moab::WriteNC::append [private]
Definition at line 202 of file WriteNC.hpp.
Referenced by parse_options(), and write_file().
std::set< std::string > moab::WriteNC::dummyVarNames [private]
Definition at line 158 of file WriteNC.hpp.
Referenced by moab::NCWriteHelper::collect_variable_data(), moab::NCWriteHelper::init_file(), process_conventional_tags(), and moab::NCWriteHelper::write_values().
int moab::WriteNC::fileId [private]
Definition at line 190 of file WriteNC.hpp.
const char* moab::WriteNC::fileName [private]
File var.
Definition at line 187 of file WriteNC.hpp.
std::map< std::string, AttData > moab::WriteNC::globalAtts [private]
Global attribs.
Definition at line 161 of file WriteNC.hpp.
Referenced by moab::NCWriteHelper::init_file(), and process_conventional_tags().
std::string moab::WriteNC::grid_type [private]
CAM Euler, etc,.
Definition at line 211 of file WriteNC.hpp.
Referenced by moab::NCWriteHelper::get_nc_helper(), and process_conventional_tags().
Definition at line 205 of file WriteNC.hpp.
Referenced by moab::NCWriteGCRM::collect_mesh_info(), moab::NCWriteHOMME::collect_mesh_info(), moab::NCWriteMPAS::collect_mesh_info(), and write_file().
Definition at line 184 of file WriteNC.hpp.
Referenced by WriteNC(), and ~WriteNC().
Definition at line 214 of file WriteNC.hpp.
Referenced by write_file(), and ~WriteNC().
bool moab::WriteNC::noMesh [private]
Write options.
Definition at line 200 of file WriteNC.hpp.
Referenced by parse_options().
bool moab::WriteNC::noVars [private]
Definition at line 201 of file WriteNC.hpp.
std::set< std::string > moab::WriteNC::usedCoordinates [private]
Definition at line 155 of file WriteNC.hpp.
Referenced by moab::NCWriteHelper::collect_variable_data(), moab::NCWriteHelper::init_file(), and moab::NCWriteHelper::write_values().
List of all members.
