MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 //------------------------------------------------------------------------- 00002 // Filename : ReadNC.hpp 00003 // 00004 // Purpose : Climate NC file reader 00005 // 00006 // Creator : Tim Tautges 00007 //------------------------------------------------------------------------- 00008 00009 #ifndef READNC_HPP 00010 #define READNC_HPP 00011 00012 #ifndef IS_BUILDING_MB 00013 #error "ReadNC.hpp isn't supposed to be included into an application" 00014 #endif 00015 00016 #include <vector> 00017 #include <map> 00018 #include <set> 00019 #include <string> 00020 00021 #include "moab/ReaderIface.hpp" 00022 #include "moab/ScdInterface.hpp" 00023 #include "DebugOutput.hpp" 00024 00025 #ifdef MOAB_HAVE_MPI 00026 #include "moab_mpi.h" 00027 #include "moab/ParallelComm.hpp" 00028 #endif 00029 00030 #ifdef MOAB_HAVE_PNETCDF 00031 #include "pnetcdf.h" 00032 #define NCFUNC( func ) ncmpi_##func 00033 00034 //! Collective I/O mode get 00035 #define NCFUNCAG( func ) ncmpi_get##func##_all 00036 00037 //! Independent I/O mode get 00038 #define NCFUNCG( func ) ncmpi_get##func 00039 00040 //! Nonblocking get (request aggregation), used so far only for ucd mesh 00041 #define NCFUNCREQG( func ) ncmpi_iget##func 00042 00043 #define NCDF_SIZE MPI_Offset 00044 #define NCDF_DIFF MPI_Offset 00045 #else 00046 #include "netcdf.h" 00047 #define NCFUNC( func ) nc_##func 00048 #define NCFUNCAG( func ) nc_get##func 00049 #define NCFUNCG( func ) nc_get##func 00050 #define NCDF_SIZE size_t 00051 #define NCDF_DIFF ptrdiff_t 00052 #endif 00053 00054 namespace moab 00055 { 00056 00057 class ReadUtilIface; 00058 class ScdInterface; 00059 class NCHelper; 00060 00061 //! Output Exodus File for VERDE 00062 class ReadNC : public ReaderIface 00063 { 00064 friend class NCHelper; 00065 friend class ScdNCHelper; 00066 friend class UcdNCHelper; 00067 friend class NCHelperEuler; 00068 friend class NCHelperFV; 00069 friend class NCHelperDomain; 00070 friend class NCHelperScrip; 00071 friend class NCHelperHOMME; 00072 friend class NCHelperMPAS; 00073 friend class NCHelperGCRM; 00074 00075 public: 00076 static ReaderIface* factory( Interface* ); 00077 00078 //! Load an NC file 00079 ErrorCode load_file( const char* file_name, 00080 const EntityHandle* file_set, 00081 const FileOptions& opts, 00082 const SubsetList* subset_list = 0, 00083 const Tag* file_id_tag = 0 ); 00084 00085 //! Constructor 00086 ReadNC( Interface* impl = NULL ); 00087 00088 //! Destructor 00089 virtual ~ReadNC(); 00090 00091 virtual ErrorCode read_tag_values( const char* file_name, 00092 const char* tag_name, 00093 const FileOptions& opts, 00094 std::vector< int >& tag_values_out, 00095 const SubsetList* subset_list = 0 ); 00096 00097 //! ENTLOCNSEDGE for north/south edge 00098 //! ENTLOCWEEDGE for west/east edge 00099 enum EntityLocation 00100 { 00101 ENTLOCVERT = 0, 00102 ENTLOCNSEDGE, 00103 ENTLOCEWEDGE, 00104 ENTLOCFACE, 00105 ENTLOCSET, 00106 ENTLOCEDGE, 00107 ENTLOCREGION 00108 }; 00109 00110 private: 00111 class AttData 00112 { 00113 public: 00114 AttData() : attId( -1 ), attLen( 0 ), attVarId( -2 ) {} 00115 int attId; 00116 NCDF_SIZE attLen; 00117 int attVarId; 00118 nc_type attDataType; 00119 std::string attName; 00120 }; 00121 00122 class VarData 00123 { 00124 public: 00125 VarData() : varId( -1 ), numAtts( -1 ), entLoc( ENTLOCSET ), numLev( 0 ), sz( 0 ), has_tsteps( false ) {} 00126 int varId; 00127 int numAtts; 00128 nc_type varDataType; 00129 std::vector< int > varDims; // The dimension indices making up this multi-dimensional variable 00130 std::map< std::string, AttData > varAtts; 00131 std::string varName; 00132 std::vector< Tag > varTags; // Tags created for this variable, e.g. one tag per timestep 00133 std::vector< void* > varDatas; 00134 std::vector< NCDF_SIZE > readStarts; // Starting index for reading data values along each dimension 00135 std::vector< NCDF_SIZE > readCounts; // Number of data values to be read along each dimension 00136 int entLoc; 00137 int numLev; 00138 int sz; 00139 bool has_tsteps; // Indicate whether timestep numbers are appended to tag names 00140 }; 00141 00142 ReadUtilIface* readMeshIface; 00143 00144 //! Read the header information 00145 ErrorCode read_header(); 00146 00147 //! Get all global attributes in the file 00148 ErrorCode get_attributes( int var_id, 00149 int num_atts, 00150 std::map< std::string, AttData >& atts, 00151 const char* prefix = "" ); 00152 00153 //! Get all dimensions in the file 00154 ErrorCode get_dimensions( int file_id, std::vector< std::string >& dim_names, std::vector< int >& dim_lens ); 00155 00156 //! Get the variable names and other info defined for this file 00157 ErrorCode get_variables(); 00158 00159 ErrorCode parse_options( const FileOptions& opts, 00160 std::vector< std::string >& var_names, 00161 std::vector< int >& tstep_nums, 00162 std::vector< double >& tstep_vals ); 00163 00164 //------------member variables ------------// 00165 00166 //! Interface instance 00167 Interface* mbImpl; 00168 00169 //! File name 00170 std::string fileName; 00171 00172 //! File numbers assigned by netcdf 00173 int fileId; 00174 00175 //! Dimension names 00176 std::vector< std::string > dimNames; 00177 00178 //! Dimension lengths 00179 std::vector< int > dimLens; 00180 00181 //! Global attribs 00182 std::map< std::string, AttData > globalAtts; 00183 00184 //! Variable info 00185 std::map< std::string, VarData > varInfo; 00186 00187 //! Cached tags for reading. Note that all these tags are defined when the 00188 //! core is initialized. 00189 Tag mGlobalIdTag; 00190 00191 //! This is a pointer to the file id tag that is passed from ReadParallel 00192 //! it gets deleted at the end of resolve sharing, but it will have same data 00193 //! as the global id tag 00194 //! global id tag is preserved, and is needed later on. 00195 const Tag* mpFileIdTag; 00196 00197 //! Debug stuff 00198 DebugOutput dbgOut; 00199 00200 //! Are we reading in parallel? 00201 bool isParallel; 00202 00203 //! Partitioning method 00204 int partMethod; 00205 00206 //! Scd interface 00207 ScdInterface* scdi; 00208 00209 //! Parallel data object, to be cached with ScdBox 00210 ScdParData parData; 00211 00212 #ifdef MOAB_HAVE_MPI 00213 ParallelComm* myPcomm; 00214 #endif 00215 00216 //! Read options 00217 bool noMesh; 00218 bool noVars; 00219 bool spectralMesh; 00220 bool noMixedElements; 00221 bool noEdges; 00222 int gatherSetRank; 00223 int tStepBase; 00224 int trivialPartitionShift; 00225 00226 //! Helper class instance 00227 NCHelper* myHelper; 00228 }; 00229 00230 } // namespace moab 00231 00232 #endif
