MOAB: Mesh Oriented datABase
(version 5.4.1)
Child helper class for ucd mesh, e.g. CAM_SE (HOMME) or MPAS. More...
#include <NCHelper.hpp>
Inheritance diagram for moab::UcdNCHelper:
Collaboration diagram for moab::UcdNCHelper:Public Member Functions | |
| UcdNCHelper (ReadNC *readNC, int fileId, const FileOptions &opts, EntityHandle fileSet) | |
| virtual | ~UcdNCHelper () |
Protected Member Functions | |
| template<typename T > | |
| void | kji_to_jik_stride (size_t, size_t nj, size_t nk, void *dest, T *source, Range &localGid) |
Protected Attributes | |
| int | nCells |
| Dimensions of global grid in file. | |
| int | nEdges |
| int | nVertices |
| int | nLocalCells |
| Dimensions of my local part of grid. | |
| int | nLocalEdges |
| int | nLocalVertices |
| std::vector< double > | xVertVals |
| Coordinate values for vertices. | |
| std::vector< double > | yVertVals |
| std::vector< double > | zVertVals |
| int | cDim |
| Dimension numbers for nCells, nEdges and nVertices. | |
| int | eDim |
| int | vDim |
| Range | localGidCells |
| Local global ID for cells, edges and vertices. | |
| Range | localGidEdges |
| Range | localGidVerts |
Private Member Functions | |
| virtual ErrorCode | read_variables (std::vector< std::string > &var_names, std::vector< int > &tstep_nums) |
| Implementation of NCHelper::read_variables() | |
| virtual ErrorCode | read_ucd_variables_to_nonset_allocate (std::vector< ReadNC::VarData > &vdatas, std::vector< int > &tstep_nums)=0 |
| Read non-set variables for ucd mesh (implemented differently in child classes) | |
| virtual ErrorCode | read_ucd_variables_to_nonset (std::vector< ReadNC::VarData > &vdatas, std::vector< int > &tstep_nums)=0 |
Definition at line 203 of file NCHelper.hpp.
| moab::UcdNCHelper::UcdNCHelper | ( | ReadNC * | readNC, |
| int | fileId, | ||
| const FileOptions & | opts, | ||
| EntityHandle | fileSet | ||
| ) | [inline] |
Definition at line 206 of file NCHelper.hpp.
: NCHelper( readNC, fileId, opts, fileSet ), nCells( 0 ), nEdges( 0 ), nVertices( 0 ), nLocalCells( 0 ), nLocalEdges( 0 ), nLocalVertices( 0 ), cDim( -1 ), eDim( -1 ), vDim( -1 ) { }
| virtual moab::UcdNCHelper::~UcdNCHelper | ( | ) | [inline, virtual] |
Definition at line 211 of file NCHelper.hpp.
| void moab::UcdNCHelper::kji_to_jik_stride | ( | size_t | , |
| size_t | nj, | ||
| size_t | nk, | ||
| void * | dest, | ||
| T * | source, | ||
| Range & | localGid | ||
| ) | [inline, protected] |
This version takes as input the moab range, from which we actually need just the size of each sequence, for a proper transpose of the data
Definition at line 232 of file NCHelper.hpp.
References moab::Range::pair_begin(), moab::Range::pair_end(), and T.
Referenced by moab::NCHelperHOMME::read_ucd_variables_to_nonset().
std::size_t idxInSource = 0; // Position of the start of the stride
// For each subrange, we will transpose a matrix of size
// subrange*nj*nk (subrange takes the role of ni)
T* tmp_data = reinterpret_cast< T* >( dest );
for( Range::pair_iterator pair_iter = localGid.pair_begin(); pair_iter != localGid.pair_end(); ++pair_iter )
std::size_t size_range = pair_iter->second - pair_iter->first + 1;
std::size_t nik = size_range * nk, nij = size_range * nj;
for( std::size_t j = 0; j != nj; j++ )
for( std::size_t i = 0; i != size_range; i++ )
for( std::size_t k = 0; k != nk; k++ )
tmp_data[idxInSource + j * nik + i * nk + k] =
source[idxInSource + k * nij + j * size_range + i];
idxInSource += ( size_range * nj * nk );
| virtual ErrorCode moab::UcdNCHelper::read_ucd_variables_to_nonset | ( | std::vector< ReadNC::VarData > & | vdatas, |
| std::vector< int > & | tstep_nums | ||
| ) | [private, pure virtual] |
Implemented in moab::NCHelperGCRM, moab::NCHelperMPAS, and moab::NCHelperHOMME.
Referenced by read_variables().
| virtual ErrorCode moab::UcdNCHelper::read_ucd_variables_to_nonset_allocate | ( | std::vector< ReadNC::VarData > & | vdatas, |
| ErrorCode moab::UcdNCHelper::read_variables | ( | std::vector< std::string > & | var_names, |
| ) | [private, virtual] |
Implements moab::NCHelper.
Definition at line 1325 of file NCHelper.cpp.
References ErrorCode, MB_CHK_SET_ERR, MB_SUCCESS, read_ucd_variables_to_nonset(), moab::NCHelper::read_variables_setup(), and moab::NCHelper::read_variables_to_set().
std::vector< ReadNC::VarData > vdatas;
std::vector< ReadNC::VarData > vsetdatas;
ErrorCode rval = read_variables_setup( var_names, tstep_nums, vdatas, vsetdatas );MB_CHK_SET_ERR( rval, "Trouble setting up to read variables" );
if( !vsetdatas.empty() )
rval = read_variables_to_set( vsetdatas, tstep_nums );MB_CHK_SET_ERR( rval, "Trouble reading variables to set" );
if( !vdatas.empty() )
#ifdef MOAB_HAVE_PNETCDF
// With pnetcdf support, we will use async read
rval = read_ucd_variables_to_nonset_async( vdatas, tstep_nums );MB_CHK_SET_ERR( rval, "Trouble reading variables to verts/edges/faces" );
#else
// Without pnetcdf support, we will use old read
rval = read_ucd_variables_to_nonset( vdatas, tstep_nums );MB_CHK_SET_ERR( rval, "Trouble reading variables to verts/edges/faces" );
#endif
return MB_SUCCESS;
int moab::UcdNCHelper::cDim [protected] |
Definition at line 265 of file NCHelper.hpp.
Referenced by moab::NCHelperGCRM::init_mesh_vals(), and moab::NCHelperMPAS::init_mesh_vals().
int moab::UcdNCHelper::eDim [protected] |
Range moab::UcdNCHelper::localGidCells [protected] |
Definition at line 268 of file NCHelper.hpp.
Range moab::UcdNCHelper::localGidEdges [protected] |
Range moab::UcdNCHelper::localGidVerts [protected] |
Referenced by moab::NCHelperHOMME::check_existing_mesh(), moab::NCHelperHOMME::create_mesh(), moab::NCHelperHOMME::read_ucd_variables_to_nonset(), and moab::NCHelperHOMME::read_ucd_variables_to_nonset_allocate().
int moab::UcdNCHelper::nCells [protected] |
Definition at line 252 of file NCHelper.hpp.
Referenced by moab::NCHelperHOMME::create_mesh(), moab::NCHelperHOMME::init_mesh_vals(), moab::NCHelperMPAS::init_mesh_vals(), and moab::NCHelperGCRM::init_mesh_vals().
int moab::UcdNCHelper::nEdges [protected] |
Definition at line 253 of file NCHelper.hpp.
int moab::UcdNCHelper::nLocalCells [protected] |
Definition at line 257 of file NCHelper.hpp.
int moab::UcdNCHelper::nLocalEdges [protected] |
Definition at line 258 of file NCHelper.hpp.
int moab::UcdNCHelper::nLocalVertices [protected] |
Definition at line 259 of file NCHelper.hpp.
Referenced by moab::NCHelperHOMME::check_existing_mesh(), moab::NCHelperHOMME::create_mesh(), and moab::NCHelperHOMME::read_ucd_variables_to_nonset_allocate().
int moab::UcdNCHelper::nVertices [protected] |
Definition at line 254 of file NCHelper.hpp.
int moab::UcdNCHelper::vDim [protected] |
Referenced by moab::NCHelperHOMME::init_mesh_vals(), moab::NCHelperMPAS::init_mesh_vals(), and moab::NCHelperGCRM::init_mesh_vals().
std::vector< double > moab::UcdNCHelper::xVertVals [protected] |
Definition at line 262 of file NCHelper.hpp.
Referenced by moab::NCHelperHOMME::create_mesh(), and moab::NCHelperHOMME::init_mesh_vals().
std::vector< double > moab::UcdNCHelper::yVertVals [protected] |
std::vector< double > moab::UcdNCHelper::zVertVals [protected] |
