moab::ReadVtk Class Reference
#include <ReadVtk.hpp>
+ Inheritance diagram for moab::ReadVtk:
+ Collaboration diagram for moab::ReadVtk:
Public Member Functions
ErrorCode load_file (const char *file_name, const EntityHandle *file_set, const FileOptions &opts, const SubsetList *subset_list=0, const Tag *file_id_tag=0)
 load a file
ErrorCode read_tag_values (const char *file_name, const char *tag_name, const FileOptions &opts, std::vector< int > &tag_values_out, const SubsetList *subset_list=0)
 Read tag values from a file.
 ReadVtk (Interface *impl=NULL)
 Constructor.
virtual ~ReadVtk ()
 Destructor.
Static Public Member Functions
static ReaderIface * factory (Interface *)
Protected Member Functions
ErrorCode allocate_vertices (long num_vtx, EntityHandle &start_handle_out, double *&x_coord_array_out, double *&y_coord_array_out, double *&z_coord_array_out)
ErrorCode read_vertices (FileTokenizer &tokens, long num_verts, EntityHandle &start_handle_out)
ErrorCode allocate_elements (long num_elements, int vert_per_element, EntityType type, EntityHandle &start_handle_out, EntityHandle *&conn_array_out, std::vector< Range > &append_to_this)
ErrorCode vtk_read_dataset (FileTokenizer &tokens, Range &vertex_list, std::vector< Range > &element_list)
ErrorCode vtk_read_structured_points (FileTokenizer &tokens, Range &vertex_list, std::vector< Range > &elem_list)
ErrorCode vtk_read_structured_grid (FileTokenizer &tokens, Range &vertex_list, std::vector< Range > &elem_list)
ErrorCode vtk_read_rectilinear_grid (FileTokenizer &tokens, Range &vertex_list, std::vector< Range > &elem_list)
ErrorCode vtk_read_polydata (FileTokenizer &tokens, Range &vertex_list, std::vector< Range > &elem_list)
ErrorCode vtk_read_polygons (FileTokenizer &tokens, EntityHandle first_vtx, std::vector< Range > &elem_list)
ErrorCode vtk_read_unstructured_grid (FileTokenizer &tokens, Range &vertex_list, std::vector< Range > &elem_list)
ErrorCode vtk_create_structured_elems (const long *dims, EntityHandle first_vtx, std::vector< Range > &elem_list)
ErrorCode vtk_read_field (FileTokenizer &tokens)
ErrorCode vtk_read_attrib_data (FileTokenizer &tokens, std::vector< Range > &entities)
ErrorCode vtk_read_tag_data (FileTokenizer &tokens, int type, size_t per_elem, std::vector< Range > &entities, const char *name)
ErrorCode vtk_read_scalar_attrib (FileTokenizer &tokens, std::vector< Range > &entities, const char *name)
ErrorCode vtk_read_color_attrib (FileTokenizer &tokens, std::vector< Range > &entities, const char *name)
ErrorCode vtk_read_vector_attrib (FileTokenizer &tokens, std::vector< Range > &entities, const char *name)
ErrorCode vtk_read_texture_attrib (FileTokenizer &tokens, std::vector< Range > &entities, const char *name)
ErrorCode vtk_read_tensor_attrib (FileTokenizer &tokens, std::vector< Range > &entities, const char *name)
ErrorCode vtk_read_field_attrib (FileTokenizer &tokens, std::vector< Range > &entities, const char *name)
ErrorCode store_file_ids (Tag tag, const Range &vertices, const std::vector< Range > &elements)
Private Attributes
ReadUtilIface * readMeshIface
Interface * mdbImpl
 interface instance
std::string mPartitionTagName
Detailed Description
Definition at line 30 of file ReadVtk.hpp.
ReadVtk::ReadVtk ( Interface *  impl = NULL)
Constructor.
Definition at line 161 of file ReadVtk.cpp.
References mdbImpl, moab::Interface::query_interface(), and readMeshIface.
Referenced by factory().
ReadVtk::~ReadVtk ( ) [virtual]
Destructor.
Definition at line 166 of file ReadVtk.cpp.
References mdbImpl, readMeshIface, and moab::Interface::release_interface().
Member Function Documentation
ErrorCode ReadVtk::allocate_elements ( long  num_elements,
EntityType  type,
EntityHandle &  start_handle_out,
EntityHandle *&  conn_array_out,
std::vector< Range > &  append_to_this
) [protected]
Definition at line 359 of file ReadVtk.cpp.
References ErrorCode, moab::ReadUtilIface::get_element_connect(), MB_START_ID, MB_SUCCESS, and readMeshIface.
Referenced by vtk_create_structured_elems(), and vtk_read_unstructured_grid().
    ErrorCode result;
    start_handle_out = 0;
    result = readMeshIface->get_element_connect( num_elements, vert_per_element, type, MB_START_ID, start_handle_out,
                                                 conn_array_out );
    if( MB_SUCCESS != result ) return result;
    Range range( start_handle_out, start_handle_out + num_elements - 1 );
    append_to_this.push_back( range );
    return MB_SUCCESS;
ErrorCode ReadVtk::allocate_vertices ( long  num_vtx,
double *&  x_coord_array_out,
double *&  y_coord_array_out,
double *&  z_coord_array_out
) [protected]
Definition at line 320 of file ReadVtk.cpp.
References ErrorCode, moab::ReadUtilIface::get_node_coords(), MB_START_ID, MB_SUCCESS, and readMeshIface.
Referenced by read_vertices(), vtk_read_rectilinear_grid(), and vtk_read_structured_points().
    ErrorCode result;
    // Create vertices
    std::vector< double* > arrays;
    result           = readMeshIface->get_node_coords( 3, num_verts, MB_START_ID, start_handle_out, arrays );
    x_coord_array_out = arrays[0];
    y_coord_array_out = arrays[1];
    z_coord_array_out = arrays[2];
    return MB_SUCCESS;
ReaderIface * ReadVtk::factory ( Interface *  iface) [static]
Definition at line 156 of file ReadVtk.cpp.
References ReadVtk().
Referenced by moab::ReaderWriterSet::ReaderWriterSet().
    return new ReadVtk( iface );
ErrorCode ReadVtk::load_file ( const char *  file_name,
const EntityHandle *  file_set,
const FileOptions &  opts,
const SubsetList *  subset_list = 0,
const Tag *  file_id_tag = 0
) [virtual]
load a file
Implements moab::ReaderIface.
Definition at line 188 of file ReadVtk.cpp.
References moab::FileTokenizer::eof(), ErrorCode, moab::FileTokenizer::get_long_ints(), moab::FileOptions::get_option(), moab::FileTokenizer::line_number(), moab::major, moab::FileTokenizer::match_token(), MB_FILE_DOES_NOT_EXIST, MB_SET_ERR, MB_SUCCESS, MB_UNSUPPORTED_OPERATION, moab::minor, mPartitionTagName, readMeshIface, moab::Range::size(), store_file_ids(), moab::FileTokenizer::unget_token(), vtk_read_attrib_data(), and vtk_read_dataset().
    ErrorCode result;
    int major, minor;
    char vendor_string[257];
    std::vector< Range > element_list;
    Range vertices;
    if( subset_list )
        MB_SET_ERR( MB_UNSUPPORTED_OPERATION, "Reading subset of files not supported for VTK" );
    // Does the caller want a field to be used for partitioning the entities?
    // If not, we'll assume any scalar integer field named MATERIAL_SET specifies partitions.
    std::string partition_tag_name;
    result = opts.get_option( "PARTITION", partition_tag_name );
    if( result == MB_SUCCESS ) mPartitionTagName = partition_tag_name;
    FILE* file = fopen( filename, "r" );
    if( !file ) return MB_FILE_DOES_NOT_EXIST;
    // Read file header
    if( !fgets( vendor_string, sizeof( vendor_string ), file ) )
        fclose( file );
        return MB_FAILURE;
    if( !strchr( vendor_string, '\n' ) || 2 != sscanf( vendor_string, "# vtk DataFile Version %d.%d", &major, &minor ) )
        fclose( file );
        return MB_FAILURE;
        fclose( file );
        return MB_FAILURE;
    // VTK spec says this should not exceed 256 chars.
    if( !strchr( vendor_string, '\n' ) )
        fclose( file );
        MB_SET_ERR( MB_FAILURE, "Vendor string (line 2) exceeds 256 characters" );
    // Check file type
    FileTokenizer tokens( file, readMeshIface );
    const char* const file_type_names[] = { "ASCII", "BINARY", 0 };
    int filetype                        = tokens.match_token( file_type_names );
    switch( filetype )
        case 2:  // BINARY
            MB_SET_ERR( MB_FAILURE, "Cannot read BINARY VTK files" );
        default:  // ERROR
            return MB_FAILURE;
        case 1:  // ASCII
            break;
    // Read the mesh
    if( !tokens.match_token( "DATASET" ) ) return MB_FAILURE;
    result = vtk_read_dataset( tokens, vertices, element_list );
    if( file_id_tag )
        result = store_file_ids( *file_id_tag, vertices, element_list );
    // Count the number of elements read
    long elem_count = 0;
    for( std::vector< Range >::iterator it = element_list.begin(); it != element_list.end(); ++it )
        elem_count += it->size();
    // Read attribute data until end of file.
    const char* const block_type_names[] = { "POINT_DATA", "CELL_DATA", 0 };
    std::vector< Range > vertex_list( 1 );
    vertex_list[0] = vertices;
    int blocktype  = 0;
    while( !tokens.eof() )
        // Get POINT_DATA or CELL_DATA
        int new_block_type = tokens.match_token( block_type_names, false );
        if( tokens.eof() ) break;
        if( !new_block_type )
            // If next token was neither POINT_DATA nor CELL_DATA,
            // then there's another attribute under the current one.
            if( blocktype )
                tokens.unget_token();
            else
                break;
        else
            blocktype = new_block_type;
            long count;
            if( !tokens.get_long_ints( 1, &count ) ) return MB_FAILURE;
            if( blocktype == 1 && (unsigned long)count != vertices.size() )
                MB_SET_ERR( MB_FAILURE, "Count inconsistent with number of vertices at line " << tokens.line_number() );
            else if( blocktype == 2 && count != elem_count )
                MB_SET_ERR( MB_FAILURE, "Count inconsistent with number of elements at line " << tokens.line_number() );
        if( blocktype == 1 )
            result = vtk_read_attrib_data( tokens, vertex_list );
        else
            result = vtk_read_attrib_data( tokens, element_list );
    return MB_SUCCESS;
ErrorCode ReadVtk::read_tag_values ( const char *  file_name,
const char *  tag_name,
std::vector< int > &  tag_values_out,
) [virtual]
Read the list if all integer tag values from the file for a tag that is a single integer value per entity.
Parameters:
file_nameThe file to read.
tag_nameThe tag for which to read values
tag_values_outOutput: The list of tag values.
subset_listAn array of tag name and value sets specifying the subset of the file to read. If multiple tags are specified, the sets that match all tags (intersection) should be read.
subset_list_lengthThe length of the 'subset_list' array.
Definition at line 179 of file ReadVtk.cpp.
References MB_NOT_IMPLEMENTED.
    return MB_NOT_IMPLEMENTED;
ErrorCode ReadVtk::read_vertices ( FileTokenizer &  tokens,
long  num_verts,
) [protected]
Definition at line 341 of file ReadVtk.cpp.
References allocate_vertices(), ErrorCode, moab::FileTokenizer::get_doubles(), MB_SUCCESS, and vtx().
Referenced by vtk_read_polydata(), vtk_read_structured_grid(), and vtk_read_unstructured_grid().
    ErrorCode result;
    double *x, *y, *z;
    result = allocate_vertices( num_verts, start_handle_out, x, y, z );
    // Read vertex coordinates
    for( long vtx = 0; vtx < num_verts; ++vtx )
        if( !tokens.get_doubles( 1, x++ ) || !tokens.get_doubles( 1, y++ ) || !tokens.get_doubles( 1, z++ ) )
            return MB_FAILURE;
    return MB_SUCCESS;
ErrorCode ReadVtk::store_file_ids ( Tag  tag,
const Range &  vertices,
const std::vector< Range > &  elements
) [protected]
Definition at line 1221 of file ReadVtk.cpp.
References moab::ReadUtilIface::assign_ids(), ErrorCode, MB_SUCCESS, and readMeshIface.
Referenced by load_file().
    ErrorCode rval;
    rval = readMeshIface->assign_ids( tag, verts );
    if( MB_SUCCESS != rval ) return rval;
    int id = 0;
    for( size_t i = 0; i < elems.size(); ++i )
        rval = readMeshIface->assign_ids( tag, elems[i], id );
        id += elems[i].size();
    return MB_SUCCESS;
ErrorCode ReadVtk::vtk_create_structured_elems ( const long *  dims,
std::vector< Range > &  elem_list
) [protected]
Definition at line 864 of file ReadVtk.cpp.
References allocate_elements(), ErrorCode, MB_SET_ERR, MB_SUCCESS, MBEDGE, MBHEX, MBQUAD, readMeshIface, and moab::ReadUtilIface::update_adjacencies().
Referenced by vtk_read_rectilinear_grid(), vtk_read_structured_grid(), and vtk_read_structured_points().
    ErrorCode result;
    // int non_zero[3] = {0, 0, 0}; // True if dim > 0 for x, y, z respectively
    long elem_dim  = 0;           // Element dimension (2->quad, 3->hex)
    long num_elems = 1;           // Total number of elements
    long vert_per_elem;           // Element connectivity length
    long edims[3] = { 1, 1, 1 };  // Number of elements in each grid direction
    // Populate above data
    for( int d = 0; d < 3; d++ )
        if( dims[d] > 1 )
            // non_zero[elem_dim] = d;
            ++elem_dim;
            edims[d] = dims[d] - 1;
            num_elems *= edims[d];
    vert_per_elem = 1 << elem_dim;
    // Get element type from element dimension
    EntityType type;
    switch( elem_dim )
        case 1:
            type = MBEDGE;
            break;
        case 2:
            type = MBQUAD;
            break;
        case 3:
            type = MBHEX;
            break;
        default:
            MB_SET_ERR( MB_FAILURE, "Invalid dimension for structured elements: " << elem_dim );
    // Allocate storage for elements
    EntityHandle start_handle = 0;
    EntityHandle* conn_array;
    result = allocate_elements( num_elems, vert_per_elem, type, start_handle, conn_array, elem_list );
    if( MB_SUCCESS != result ) return MB_FAILURE;
    EntityHandle* conn_sav = conn_array;
    // Offsets of element vertices in grid relative to corner closest to origin
    long k                = dims[0] * dims[1];
    const long corners[8] = { 0, 1, 1 + dims[0], dims[0], k, k + 1, k + 1 + dims[0], k + dims[0] };
    // Populate element list
    for( long z = 0; z < edims[2]; ++z )
        for( long y = 0; y < edims[1]; ++y )
            for( long x = 0; x < edims[0]; ++x )
                const long index = x + y * dims[0] + z * ( dims[0] * dims[1] );
                for( long j = 0; j < vert_per_elem; ++j, ++conn_array )
                    *conn_array = index + corners[j] + first_vtx;
    // Notify MOAB of the new elements
    result = readMeshIface->update_adjacencies( start_handle, num_elems, vert_per_elem, conn_sav );
    return MB_SUCCESS;
ErrorCode ReadVtk::vtk_read_attrib_data ( FileTokenizer &  tokens,
std::vector< Range > &  entities
) [protected]
Definition at line 972 of file ReadVtk.cpp.
References moab::FileTokenizer::get_string(), moab::FileTokenizer::match_token(), vtk_read_color_attrib(), vtk_read_field_attrib(), vtk_read_scalar_attrib(), vtk_read_tensor_attrib(), vtk_read_texture_attrib(), and vtk_read_vector_attrib().
    const char* const type_names[] = { "SCALARS", "COLOR_SCALARS", "VECTORS", "NORMALS", "TEXTURE_COORDINATES",
                                       "TENSORS", "FIELD",         0 };
    int type             = tokens.match_token( type_names );
    const char* tmp_name = tokens.get_string();
    if( !type || !tmp_name ) return MB_FAILURE;
    std::string name_alloc( tmp_name );
    const char* name = name_alloc.c_str();
    switch( type )
        case 1:
            return vtk_read_scalar_attrib( tokens, entities, name );
        case 2:
            return vtk_read_color_attrib( tokens, entities, name );
        case 3:
            return vtk_read_vector_attrib( tokens, entities, name );
        case 4:
        case 5:
            return vtk_read_texture_attrib( tokens, entities, name );
        case 6:
            return vtk_read_tensor_attrib( tokens, entities, name );
        case 7:
            return vtk_read_field_attrib( tokens, entities, name );
    return MB_FAILURE;
ErrorCode ReadVtk::vtk_read_color_attrib ( FileTokenizer &  tokens,
std::vector< Range > &  entities,
const char *  name
) [protected]
Definition at line 1154 of file ReadVtk.cpp.
References moab::FileTokenizer::get_long_ints(), size, and vtk_read_tag_data().
Referenced by vtk_read_attrib_data().
    long size;
    if( !tokens.get_long_ints( 1, &size ) || size < 1 ) return MB_FAILURE;
    return vtk_read_tag_data( tokens, 10, size, entities, name );
ErrorCode ReadVtk::vtk_read_dataset ( FileTokenizer &  tokens,
Range &  vertex_list,
std::vector< Range > &  element_list
) [protected]
Definition at line 378 of file ReadVtk.cpp.
References moab::FileTokenizer::match_token(), vtk_read_field(), vtk_read_polydata(), vtk_read_rectilinear_grid(), vtk_read_structured_grid(), vtk_read_structured_points(), and vtk_read_unstructured_grid().
    const char* const data_type_names[] = {
        "STRUCTURED_POINTS", "STRUCTURED_GRID", "UNSTRUCTURED_GRID", "POLYDATA", "RECTILINEAR_GRID", "FIELD", 0 };
    int datatype = tokens.match_token( data_type_names );
    switch( datatype )
        case 1:
            return vtk_read_structured_points( tokens, vertex_list, element_list );
        case 2:
            return vtk_read_structured_grid( tokens, vertex_list, element_list );
        case 3:
            return vtk_read_unstructured_grid( tokens, vertex_list, element_list );
        case 4:
            return vtk_read_polydata( tokens, vertex_list, element_list );
        case 5:
            return vtk_read_rectilinear_grid( tokens, vertex_list, element_list );
        case 6:
            return vtk_read_field( tokens );
        default:
            return MB_FAILURE;
ErrorCode ReadVtk::vtk_read_field ( FileTokenizer &  tokens) [protected]
Definition at line 934 of file ReadVtk.cpp.
References moab::FileTokenizer::get_doubles(), moab::FileTokenizer::get_long_ints(), moab::FileTokenizer::get_string(), moab::FileTokenizer::match_token(), MB_SUCCESS, and moab::vtk_type_names.
Referenced by vtk_read_dataset(), and vtk_read_unstructured_grid().
    // This is not supported yet.
    // Parse the data but throw it away because
    // Mesquite has no internal representation for it.
    // Could save this in tags, but the only useful thing that
    // could be done with the data is to write it back out
    // with the modified mesh. As there's no way to save the
    // type of a tag in Mesquite, it cannot be written back
    // out correctly either.
    // FIXME: Don't know what to do with this data.
    // For now, read it and throw it out.
    long num_arrays;
    if( !tokens.get_string() ||  // Name
        !tokens.get_long_ints( 1, &num_arrays ) )
        return MB_FAILURE;
    for( long i = 0; i < num_arrays; ++i )
        /*const char* name =*/tokens.get_string();
        long dims[2];
        if( !tokens.get_long_ints( 2, dims ) || !tokens.match_token( vtk_type_names ) ) return MB_FAILURE;
        long num_vals = dims[0] * dims[1];
        for( long j = 0; j < num_vals; j++ )
            double junk;
            if( !tokens.get_doubles( 1, &junk ) ) return MB_FAILURE;
    return MB_SUCCESS;
ErrorCode ReadVtk::vtk_read_field_attrib ( FileTokenizer &  tokens,
const char *  name
) [protected]
Definition at line 1191 of file ReadVtk.cpp.
References ErrorCode, moab::FileTokenizer::get_long_ints(), moab::FileTokenizer::get_string(), moab::FileTokenizer::line_number(), moab::FileTokenizer::match_token(), MB_CHK_SET_ERR, MB_SUCCESS, vtk_read_tag_data(), and moab::vtk_type_names.
    long num_fields;
    if( !tokens.get_long_ints( 1, &num_fields ) ) return MB_FAILURE;
    long i;
    for( i = 0; i < num_fields; ++i )
        const char* tok = tokens.get_string();
        if( !tok ) return MB_FAILURE;
        std::string name_alloc( tok );
        long num_comp;
        if( !tokens.get_long_ints( 1, &num_comp ) ) return MB_FAILURE;
        long num_tuples;
        if( !tokens.get_long_ints( 1, &num_tuples ) ) return MB_FAILURE;
        int type = tokens.match_token( vtk_type_names );
        if( !type ) return MB_FAILURE;
        ErrorCode result = vtk_read_tag_data( tokens, type, num_comp, entities, name_alloc.c_str() );MB_CHK_SET_ERR( result, "Error reading data for field \"" << name_alloc << "\" (" << num_comp << " components, "
        << num_tuples << " tuples, type " << type
        << ") at line " << tokens.line_number() );
    return MB_SUCCESS;
ErrorCode ReadVtk::vtk_read_polydata ( FileTokenizer &  tokens,
) [protected]
Definition at line 540 of file ReadVtk.cpp.
References ErrorCode, moab::FileTokenizer::get_long_ints(), moab::FileTokenizer::get_newline(), moab::Range::insert(), moab::FileTokenizer::line_number(), moab::FileTokenizer::match_token(), MB_SET_ERR, MB_SUCCESS, read_vertices(), vtk_read_polygons(), and moab::vtk_type_names.
Referenced by vtk_read_dataset().
    ErrorCode result;
    long num_verts;
    const char* const poly_data_names[] = { "VERTICES", "LINES", "POLYGONS", "TRIANGLE_STRIPS", 0 };
    if( !tokens.match_token( "POINTS" ) || !tokens.get_long_ints( 1, &num_verts ) ||
        !tokens.match_token( vtk_type_names ) || !tokens.get_newline() )
        return MB_FAILURE;
    if( num_verts < 1 )
        MB_SET_ERR( MB_FAILURE, "Invalid point count at line " << tokens.line_number() );
    // Create vertices and read coordinates
    result                    = read_vertices( tokens, num_verts, start_handle );
    vertex_list.insert( start_handle, start_handle + num_verts - 1 );
    int poly_type = tokens.match_token( poly_data_names );
    switch( poly_type )
        case 0:
            result = MB_FAILURE;
            break;
        case 1:
            MB_SET_ERR( MB_FAILURE, "Vertex element type at line " << tokens.line_number() );
            break;
        case 2:
            MB_SET_ERR( MB_FAILURE, "Unsupported type: polylines at line " << tokens.line_number() );
            break;
        case 3:
            result = vtk_read_polygons( tokens, start_handle, elem_list );
            break;
        case 4:
            MB_SET_ERR( MB_FAILURE, "Unsupported type: triangle strips at line " << tokens.line_number() );
            break;
    return result;
ErrorCode ReadVtk::vtk_read_polygons ( FileTokenizer &  tokens,
) [protected]
Definition at line 586 of file ReadVtk.cpp.
References moab::Interface::create_element(), ErrorCode, moab::GeomUtil::first(), moab::FileTokenizer::get_long_ints(), moab::FileTokenizer::get_newline(), MB_SUCCESS, MBPOLYGON, mdbImpl, and size.
Referenced by vtk_read_polydata().
    ErrorCode result;
    long size[2];
    if( !tokens.get_long_ints( 2, size ) || !tokens.get_newline() ) return MB_FAILURE;
    const Range empty;
    std::vector< EntityHandle > conn_hdl;
    std::vector< long > conn_idx;
    EntityHandle first = 0, prev = 0, handle;
    for( int i = 0; i < size[0]; ++i )
        long count;
        conn_idx.resize( count );
        conn_hdl.resize( count );
        if( !tokens.get_long_ints( count, &conn_idx[0] ) ) return MB_FAILURE;
        for( long j = 0; j < count; ++j )
            conn_hdl[j] = first_vtx + conn_idx[j];
        result = mdbImpl->create_element( MBPOLYGON, &conn_hdl[0], count, handle );
        if( prev + 1 != handle )
            if( first )
            {  // True except for first iteration (first == 0)
                if( elem_list.empty() || first < elem_list.back().front() )  // Only need new range if order would get
        // mixed up, or we just began inserting
                    elem_list.push_back( empty );
                elem_list.back().insert( first, prev );
            first = handle;
        prev = handle;
    if( first )
    {        // True unless no elements (size[0] == 0)
        if( elem_list.empty() || first < elem_list.back().front() )  // Only need new range if order would get mixed
        // up, or we just began inserting
    return MB_SUCCESS;
ErrorCode ReadVtk::vtk_read_rectilinear_grid ( FileTokenizer &  tokens,
) [protected]
Definition at line 482 of file ReadVtk.cpp.
References allocate_vertices(), ErrorCode, moab::FileTokenizer::get_doubles(), moab::FileTokenizer::get_long_ints(), moab::FileTokenizer::get_newline(), moab::Range::insert(), moab::FileTokenizer::line_number(), moab::FileTokenizer::match_token(), MB_SET_ERR, MB_SUCCESS, vtk_create_structured_elems(), and moab::vtk_type_names.
    int i, j, k;
    long dims[3];
    const char* labels[] = { "X_COORDINATES", "Y_COORDINATES", "Z_COORDINATES" };
    std::vector< double > coords[3];
    ErrorCode result;
    if( !tokens.match_token( "DIMENSIONS" ) || !tokens.get_long_ints( 3, dims ) || !tokens.get_newline() )
        return MB_FAILURE;
    if( dims[0] < 1 || dims[1] < 1 || dims[2] < 1 )
        MB_SET_ERR( MB_FAILURE, "Invalid dimension at line " << tokens.line_number() );
    for( i = 0; i < 3; i++ )
        long count;
        if( !tokens.match_token( labels[i] ) || !tokens.get_long_ints( 1, &count ) ||
            return MB_FAILURE;
        if( count != dims[i] )
            MB_SET_ERR( MB_FAILURE, "Coordinate count inconsistent with dimensions at line " << tokens.line_number() );
        coords[i].resize( count );
        if( !tokens.get_doubles( count, &coords[i][0] ) ) return MB_FAILURE;
    // Create vertices
    double *x, *y, *z;
    long num_verts            = dims[0] * dims[1] * dims[2];
    result                    = allocate_vertices( num_verts, start_handle, x, y, z );
    // Calculate vertex coordinates
    for( k = 0; k < dims[2]; ++k )
        for( j = 0; j < dims[1]; ++j )
            for( i = 0; i < dims[0]; ++i )
                *x = coords[0][i];
                ++x;
                *y = coords[1][j];
                ++y;
                *z = coords[2][k];
                ++z;
    return vtk_create_structured_elems( dims, start_handle, elem_list );
ErrorCode ReadVtk::vtk_read_scalar_attrib ( FileTokenizer &  tokens,
const char *  name
) [protected]
Definition at line 1126 of file ReadVtk.cpp.
References moab::FileTokenizer::get_string(), moab::FileTokenizer::line_number(), moab::FileTokenizer::match_token(), MB_SET_ERR, size, moab::FileTokenizer::unget_token(), vtk_read_tag_data(), and moab::vtk_type_names.
    long size;
    const char* end = 0;
    size            = strtol( tok, (char**)&end, 0 );
    if( *end )
        size = 1;
    // VTK spec says cannot be greater than 4--do we care?
    if( size < 1 )
    {  //|| size > 4)
        MB_SET_ERR( MB_FAILURE, "Scalar count out of range [1,4] at line " << tokens.line_number() );
    if( !tokens.match_token( "LOOKUP_TABLE" ) || !tokens.match_token( "default" ) ) return MB_FAILURE;
    return vtk_read_tag_data( tokens, type, size, entities, name );
ErrorCode ReadVtk::vtk_read_structured_grid ( FileTokenizer &  tokens,
) [protected]
Definition at line 449 of file ReadVtk.cpp.
References ErrorCode, moab::FileTokenizer::get_long_ints(), moab::FileTokenizer::get_newline(), moab::Range::insert(), moab::FileTokenizer::line_number(), moab::FileTokenizer::match_token(), MB_SET_ERR, MB_SUCCESS, read_vertices(), vtk_create_structured_elems(), and moab::vtk_type_names.
    long num_verts, dims[3];
    ErrorCode result;
        return MB_FAILURE;
        return MB_FAILURE;
    if( num_verts != ( dims[0] * dims[1] * dims[2] ) )
        MB_SET_ERR( MB_FAILURE, "Point count not consistent with dimensions at line " << tokens.line_number() );
    // Create and read vertices
ErrorCode ReadVtk::vtk_read_structured_points ( FileTokenizer &  tokens,
) [protected]
Definition at line 402 of file ReadVtk.cpp.
References allocate_vertices(), ErrorCode, moab::FileTokenizer::get_doubles(), moab::FileTokenizer::get_long_ints(), moab::FileTokenizer::get_newline(), moab::Range::insert(), moab::FileTokenizer::line_number(), moab::FileTokenizer::match_token(), MB_SET_ERR, MB_SUCCESS, origin, and vtk_create_structured_elems().
    long i, j, k;
    long dims[3];
    double origin[3], space[3];
    ErrorCode result;
        return MB_FAILURE;
    if( !tokens.match_token( "ORIGIN" ) || !tokens.get_doubles( 3, origin ) || !tokens.get_newline() )
        return MB_FAILURE;
    const char* const spacing_names[] = { "SPACING", "ASPECT_RATIO", 0 };
    if( !tokens.match_token( spacing_names ) || !tokens.get_doubles( 3, space ) || !tokens.get_newline() )
        return MB_FAILURE;
    // Create vertices
    double *x, *y, *z;
                *x = origin[0] + i * space[0];
                ++x;
                *y = origin[1] + j * space[1];
                ++y;
                *z = origin[2] + k * space[2];
                ++z;
ErrorCode ReadVtk::vtk_read_tag_data ( FileTokenizer &  tokens,
int  type,
size_t  per_elem,
const char *  name
) [protected]
Definition at line 1004 of file ReadVtk.cpp.
References ErrorCode, moab::FileTokenizer::get_booleans(), moab::FileTokenizer::get_doubles(), moab::FileTokenizer::get_integers(), moab::FileTokenizer::line_number(), MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_BIT, MB_TYPE_DOUBLE, MB_TYPE_INTEGER, mdbImpl, mPartitionTagName, size, moab::Interface::tag_get_handle(), and moab::Interface::tag_set_data().
Referenced by vtk_read_color_attrib(), vtk_read_field_attrib(), vtk_read_scalar_attrib(), vtk_read_tensor_attrib(), vtk_read_texture_attrib(), and vtk_read_vector_attrib().
    ErrorCode result;
    DataType mb_type;
    if( type == 1 )
        mb_type = MB_TYPE_BIT;
    else if( type >= 2 && type <= 9 )
        mb_type = MB_TYPE_INTEGER;
    else if( type == 10 || type == 11 )
        mb_type = MB_TYPE_DOUBLE;
    else if( type == 12 )
    else
        return MB_FAILURE;
#ifdef MB_VTK_MATERIAL_SETS
    size_t size;
    if( type == 1 )
        size = sizeof( bool );
        size = sizeof( int );
        size = sizeof( double );
    else /* (type == 12) */
        size = 4;  // Could be 4 or 8, but we don't know. Hope it's 4 because MOAB doesn't support
                   // 64-bit ints.
    Modulator materialMap( this->mdbImpl );
    result = materialMap.initialize( this->mPartitionTagName, mb_type, size, per_elem );MB_CHK_SET_ERR( result, "MaterialMap tag (" << this->mPartitionTagName << ") creation failed." );
    bool isMaterial = size * per_elem <= 4 &&              // Must have int-sized values (ParallelComm requires it)
                      !this->mPartitionTagName.empty() &&  // Must have a non-empty field name...
                      !strcmp( name, this->mPartitionTagName.c_str() );  // ... that matches our spec.
#endif        // MB_VTK_MATERIAL_SETS
    // Get/create tag
    Tag handle;
    result = mdbImpl->tag_get_handle( name, per_elem, mb_type, handle, MB_TAG_DENSE | MB_TAG_CREAT );MB_CHK_SET_ERR( result, "Tag name conflict for attribute \"" << name << "\" at line " << tokens.line_number() );
    std::vector< Range >::iterator iter;
    if( type == 1 )
        for( iter = entities.begin(); iter != entities.end(); ++iter )
            bool* data = new bool[iter->size() * per_elem];
            if( !tokens.get_booleans( per_elem * iter->size(), data ) )
                delete[] data;
                return MB_FAILURE;
            bool* data_iter          = data;
            Range::iterator ent_iter = iter->begin();
            for( ; ent_iter != iter->end(); ++ent_iter )
                unsigned char bits = 0;
                for( unsigned j = 0; j < per_elem; ++j, ++data_iter )
                    bits |= (unsigned char)( *data_iter << j );
                if( isMaterial ) materialMap.add_entity( *ent_iter, &bits, 1 );
                result = mdbImpl->tag_set_data( handle, &*ent_iter, 1, &bits );
                    delete[] data;
                    return result;
            delete[] data;
    else if( ( type >= 2 && type <= 9 ) || type == 12 )
        std::vector< int > data;
            data.resize( iter->size() * per_elem );
            if( !tokens.get_integers( iter->size() * per_elem, &data[0] ) ) return MB_FAILURE;
            if( isMaterial ) materialMap.add_entities( *iter, (unsigned char*)&data[0], per_elem * size );
            result = mdbImpl->tag_set_data( handle, *iter, &data[0] );
        std::vector< double > data;
            if( !tokens.get_doubles( iter->size() * per_elem, &data[0] ) ) return MB_FAILURE;
    return MB_SUCCESS;
ErrorCode ReadVtk::vtk_read_tensor_attrib ( FileTokenizer &  tokens,
const char *  name
) [protected]
Definition at line 1183 of file ReadVtk.cpp.
References moab::FileTokenizer::match_token(), vtk_read_tag_data(), and moab::vtk_type_names.
    return vtk_read_tag_data( tokens, type, 9, entities, name );
ErrorCode ReadVtk::vtk_read_texture_attrib ( FileTokenizer &  tokens,
const char *  name
) [protected]
Definition at line 1170 of file ReadVtk.cpp.
References dim, moab::FileTokenizer::get_integers(), moab::FileTokenizer::line_number(), moab::FileTokenizer::match_token(), MB_SET_ERR, vtk_read_tag_data(), and moab::vtk_type_names.
    int type, dim;
    if( !tokens.get_integers( 1, &dim ) || !( type = tokens.match_token( vtk_type_names ) ) ) return MB_FAILURE;
    if( dim < 1 || dim > 3 )
        MB_SET_ERR( MB_FAILURE, "Invalid dimension (" << dim << ") at line " << tokens.line_number() );
    return vtk_read_tag_data( tokens, type, dim, entities, name );
ErrorCode ReadVtk::vtk_read_unstructured_grid ( FileTokenizer &  tokens,
) [protected]
Definition at line 635 of file ReadVtk.cpp.
References allocate_elements(), moab::Interface::create_element(), ErrorCode, moab::Interface::get_adjacencies(), moab::FileTokenizer::get_long_ints(), moab::FileTokenizer::get_newline(), moab::Range::insert(), moab::FileTokenizer::line_number(), moab::FileTokenizer::match_token(), MB_CHK_ERR, MB_SET_ERR, MB_SUCCESS, moab::VtkElemType::mb_type, MBMAXTYPE, MBPOLYGON, MBPOLYHEDRON, MBQUAD, MBTRI, MBVERTEX, mdbImpl, moab::VtkElemType::node_order, moab::VtkUtil::numVtkElemType, read_vertices(), readMeshIface, moab::Range::size(), moab::ReadUtilIface::update_adjacencies(), vtk_read_field(), moab::vtk_type_names, and moab::VtkUtil::vtkElemTypes.
    ErrorCode result;
    long i, num_verts, num_elems[2];
    EntityHandle tmp_conn_list[27];
    // Poorly formatted VTK legacy format document seems to
    // lead many to think that a FIELD block can occur within
    // an UNSTRUCTURED_GRID dataset rather than as its own data
    // set. So allow for field data between other blocks of
    // data.
    const char* pts_str[] = { "FIELD", "POINTS", 0 };
    while( 1 == ( i = tokens.match_token( pts_str ) ) )
        result = vtk_read_field( tokens );
    if( i != 2 ) return MB_FAILURE;
    if( !tokens.get_long_ints( 1, &num_verts ) || !tokens.match_token( vtk_type_names ) || !tokens.get_newline() )
        return MB_FAILURE;
    if( num_verts < 1 )
    EntityHandle first_vertex = 0;
    result                    = read_vertices( tokens, num_verts, first_vertex );
    vertex_list.insert( first_vertex, first_vertex + num_verts - 1 );
    const char* cell_str[] = { "FIELD", "CELLS", 0 };
    while( 1 == ( i = tokens.match_token( cell_str ) ) )
    if( !tokens.get_long_ints( 2, num_elems ) || !tokens.get_newline() ) return MB_FAILURE;
    // Read element connectivity for all elements
    std::vector< long > connectivity( num_elems[1] );
    if( !tokens.get_long_ints( num_elems[1], &connectivity[0] ) ) return MB_FAILURE;
    if( !tokens.match_token( "CELL_TYPES" ) || !tokens.get_long_ints( 1, &num_elems[1] ) || !tokens.get_newline() )
        return MB_FAILURE;
    // Read element types
    std::vector< long > types( num_elems[0] );
    if( !tokens.get_long_ints( num_elems[0], &types[0] ) ) return MB_FAILURE;
    // Create elements in blocks of the same type
    // It is important to preserve the order in
    // which the elements were read for later reading
    // attribute data.
    long id                                 = 0;
    std::vector< long >::iterator conn_iter = connectivity.begin();
    while( id < num_elems[0] )
        unsigned vtk_type = types[id];
        if( vtk_type >= VtkUtil::numVtkElemType ) return MB_FAILURE;
        EntityType type = VtkUtil::vtkElemTypes[vtk_type].mb_type;
        if( type == MBMAXTYPE )
            MB_SET_ERR( MB_FAILURE, "Unsupported VTK element type: " << VtkUtil::vtkElemTypes[vtk_type].name << " ("
        << vtk_type << ")" );
        int num_vtx = *conn_iter;
        if( type != MBPOLYGON && type != MBPOLYHEDRON && num_vtx != (int)VtkUtil::vtkElemTypes[vtk_type].num_nodes )
            MB_SET_ERR( MB_FAILURE, "Cell " << id << " is of type '" << VtkUtil::vtkElemTypes[vtk_type].name
                                            << "' but has " << num_vtx << " vertices" );
        // Find any subsequent elements of the same type
        // if polyhedra, need to look at the number of faces to put in the same range
        std::vector< long >::iterator conn_iter2 = conn_iter + num_vtx + 1;
        long end_id                              = id + 1;
        if( MBPOLYHEDRON != type )
            while( end_id < num_elems[0] && (unsigned)types[end_id] == vtk_type && *conn_iter2 == num_vtx )
                ++end_id;
                conn_iter2 += num_vtx + 1;
        else
            // advance only if next is polyhedron too, and if number of faces is the same
            int num_faces = conn_iter[1];
            while( end_id < num_elems[0] && (unsigned)types[end_id] == vtk_type && conn_iter2[1] == num_faces )
                ++end_id;
            // num_vtx becomes in this case num_faces
            num_vtx = num_faces;  // for polyhedra, this is what we want
            // trigger vertex adjacency call
            Range firstFaces;
            mdbImpl->get_adjacencies( &first_vertex, 1, 2, false, firstFaces );
        // Allocate element block
        long num_elem             = end_id - id;
        // if type is MBVERTEX, skip, we will not create elements with one vertex
        if( MBVERTEX == type )
            id += num_elem;
            conn_iter += 2 * num_elem;  // skip 2 * number of 1-vertex elements
            continue;
        result = allocate_elements( num_elem, num_vtx, type, start_handle, conn_array, elem_list );
        // Store element connectivity
        if( type != MBPOLYHEDRON )
            for( ; id < end_id; ++id )
                if( conn_iter == connectivity.end() )
                    MB_SET_ERR( MB_FAILURE, "Connectivity data truncated at cell " << id );
                // Make sure connectivity length is correct.
                if( *conn_iter != num_vtx )
                ++conn_iter;
                for( i = 0; i < num_vtx; ++i, ++conn_iter )
                    conn_array[i] = *conn_iter + first_vertex;
                const unsigned* order = VtkUtil::vtkElemTypes[vtk_type].node_order;
                if( order )
                    assert( num_vtx * sizeof( EntityHandle ) <= sizeof( tmp_conn_list ) );
                    memcpy( tmp_conn_list, conn_array, num_vtx * sizeof( EntityHandle ) );
                    for( int j = 0; j < num_vtx; ++j )
                        conn_array[order[j]] = tmp_conn_list[j];
                conn_array += num_vtx;
        else  // type == MBPOLYHEDRON
            // in some cases, we may need to create new elements; will it screw the tags?
            // not if the file was not from moab
            ErrorCode rv = MB_SUCCESS;
                    MB_SET_ERR( MB_FAILURE, "Connectivity data truncated at polyhedra cell " << id );
                ++conn_iter;
                // iterator is now at number of faces
                // we should check it is indeed num_vtx
                int num_faces = *conn_iter;
                if( num_faces != num_vtx ) MB_SET_ERR( MB_FAILURE, "Connectivity data wrong at polyhedra cell " << id );
                EntityHandle connec[20];  // we bet we will have only 20 vertices at most, in a
                                          // face in a polyhedra
                for( int j = 0; j < num_faces; j++ )
                    conn_iter++;
                    int numverticesInFace = (int)*conn_iter;
                    if( numverticesInFace > 20 )
                                    "too many vertices in face index " << j << " for polyhedra cell " << id );
                    // need to find the face, but first fill with vertices
                    for( int k = 0; k < numverticesInFace; k++ )
                        connec[k] = first_vertex + *( ++conn_iter );  //
                    Range adjFaces;
                    // find a face with these vertices; if not, we need to create one, on the fly :(
                    rv = mdbImpl->get_adjacencies( connec, numverticesInFace, 2, false, adjFaces );MB_CHK_ERR( rv );
                    if( adjFaces.size() >= 1 )
                        conn_array[j] = adjFaces[0];  // get the first face found
                    else
                        // create the face; tri, quad or polygon
                        EntityType etype = MBTRI;
                        if( 4 == numverticesInFace ) etype = MBQUAD;
                        if( 4 < numverticesInFace ) etype = MBPOLYGON;
                        rv = mdbImpl->create_element( etype, connec, numverticesInFace, conn_array[j] );MB_CHK_ERR( rv );
                conn_array += num_vtx;  // advance for next polyhedra
                conn_iter++;            // advance to the next field
        result = readMeshIface->update_adjacencies( start_handle, num_elem, num_vtx, conn_sav );
    return MB_SUCCESS;
ErrorCode ReadVtk::vtk_read_vector_attrib ( FileTokenizer &  tokens,
const char *  name
) [protected]
Definition at line 1162 of file ReadVtk.cpp.
    return vtk_read_tag_data( tokens, type, 3, entities, name );
Member Data Documentation
interface instance
Definition at line 117 of file ReadVtk.hpp.
Referenced by ReadVtk(), vtk_read_polygons(), vtk_read_tag_data(), vtk_read_unstructured_grid(), and ~ReadVtk().
std::string moab::ReadVtk::mPartitionTagName [private]
A field which, if present and having a single integer for storage, should be used to partition the mesh by range. Defaults to MATERIAL_SET_TAG_NAME
Definition at line 121 of file ReadVtk.hpp.
Referenced by load_file(), and vtk_read_tag_data().
List of all members.
