moab::TreeStats Class Reference
Traversal statistics accumulating and reporting. More...
#include <TreeStats.hpp>
Public Member Functions
 TreeStats ()
 constructor
ErrorCode compute_stats (Interface *impl, EntityHandle root_node)
 Given a root node, compute the stats for a tree.
void reset_trav_stats ()
 reset traversal counters
void reset ()
 reset all counters
void print () const
 print the contents of this structure
void output_all_stats (const bool with_endl=true) const
 output all the contents of this structure on a single line
void output_trav_stats (const bool with_endl=true) const
 output just the traversal stats of this structure on a single line
Public Attributes
double initTime
unsigned int maxDepth
unsigned int numNodes
unsigned int numLeaves
double avgObjPerLeaf
unsigned int minObjPerLeaf
unsigned int maxObjPerLeaf
unsigned int nodesVisited
unsigned int leavesVisited
unsigned int numTraversals
unsigned int constructLeafObjectTests
unsigned int traversalLeafObjectTests
unsigned int boxElemTests
Private Member Functions
ErrorCode traverse (Interface *impl, EntityHandle node, unsigned int &depth)
Detailed Description
Class to accumulate statistics on traversal performance. This structure contains the count of nodes visited at each level in a tree, and the count of traversals that ended at each level. One TrvStats structure can be used with multiple trees or multiple queries, or used on only a single tree or a single query.
Note that these traversal statistics are not related to the stats() query below, which calculates static information about a tree. These statistics relate to a tree's dynamic behavior on particular operations.
Definition at line 26 of file TreeStats.hpp.
constructor
Definition at line 30 of file TreeStats.hpp.
References reset().
        reset();
Member Function Documentation
ErrorCode moab::TreeStats::compute_stats ( Interface *  impl,
) [inline]
Parameters:
implMOAB instance pointer
root_nodeRoot entity set for the tree
Definition at line 81 of file TreeStats.hpp.
References avgObjPerLeaf, ErrorCode, maxDepth, maxObjPerLeaf, minObjPerLeaf, numLeaves, numNodes, and traverse().
Referenced by moab::AdaptiveKDTree::build_tree(), and moab::BVHTree::build_tree().
    maxDepth      = 0;
    numNodes      = 0;
    numLeaves     = 0;
    avgObjPerLeaf = 0.0;
    minObjPerLeaf = 0;
    maxObjPerLeaf = 0;
    ErrorCode rval = traverse( impl, root_node, maxDepth );
    avgObjPerLeaf  = ( avgObjPerLeaf > 0 ? avgObjPerLeaf / (double)numLeaves : 0.0 );
    return rval;
void moab::TreeStats::output_all_stats ( const bool  with_endl = true) const [inline]
Definition at line 170 of file TreeStats.hpp.
References avgObjPerLeaf, boxElemTests, constructLeafObjectTests, initTime, leavesVisited, maxDepth, maxObjPerLeaf, minObjPerLeaf, nodesVisited, numLeaves, numNodes, numTraversals, and traversalLeafObjectTests.
Referenced by main().
    std::cout << initTime << " " << numNodes << " " << numLeaves << " " << maxDepth << " " << avgObjPerLeaf << " "
              << minObjPerLeaf << " " << maxObjPerLeaf << " " << constructLeafObjectTests << " " << boxElemTests << " "
              << nodesVisited << " " << leavesVisited << " " << numTraversals << " " << traversalLeafObjectTests << " ";
    if( with_endl ) std::cout << std::endl;
void moab::TreeStats::output_trav_stats ( const bool  with_endl = true) const [inline]
Definition at line 178 of file TreeStats.hpp.
References leavesVisited, nodesVisited, numTraversals, and traversalLeafObjectTests.
Referenced by test_locator().
    std::cout << nodesVisited << " " << leavesVisited << " " << numTraversals << " " << traversalLeafObjectTests << " ";
void moab::TreeStats::print ( ) const [inline]
Definition at line 149 of file TreeStats.hpp.
Referenced by DeformMeshRemap::execute().
    std::cout << "Tree initialization time = " << initTime << " seconds" << std::endl;
    std::cout << "Num nodes         = " << numNodes << std::endl;
    std::cout << "Num leaves        = " << numLeaves << std::endl;
    std::cout << "Max depth         = " << maxDepth << std::endl << std::endl;
    std::cout << "Avg objs per leaf = " << avgObjPerLeaf << std::endl;
    std::cout << "Min objs per leaf = " << minObjPerLeaf << std::endl;
    std::cout << "Max objs per leaf = " << maxObjPerLeaf << std::endl;
    std::cout << "Construction Leaf Object Tests = " << constructLeafObjectTests << std::endl;
    std::cout << "Box-Element Tests = " << boxElemTests << std::endl;
    std::cout << "NodesVisited      = " << nodesVisited << std::endl;
    std::cout << "LeavesVisited     = " << leavesVisited << std::endl;
    std::cout << "Num Traversals    = " << numTraversals << std::endl;
    std::cout << "Traversal Leaf Object Tests = " << traversalLeafObjectTests << std::endl;
Definition at line 141 of file TreeStats.hpp.
Referenced by reset().
ErrorCode moab::TreeStats::traverse ( Interface *  impl,
EntityHandle  node,
unsigned int &  depth
) [inline, private]
Definition at line 95 of file TreeStats.hpp.
References avgObjPerLeaf, children, ErrorCode, moab::Interface::get_child_meshsets(), moab::Interface::get_entities_by_handle(), maxObjPerLeaf, MB_SUCCESS, minObjPerLeaf, numLeaves, and numNodes.
Referenced by compute_stats().
    depth++;
    numNodes++;
    std::vector< EntityHandle > children;
    children.reserve( 2 );
    ErrorCode rval = impl->get_child_meshsets( node, children );
    if( MB_SUCCESS != rval ) return rval;
    if( children.empty() )
        numLeaves++;
        rval = impl->get_entities_by_handle( node, children );
        avgObjPerLeaf += children.size();
        minObjPerLeaf = std::min( (unsigned int)children.size(), minObjPerLeaf );
        maxObjPerLeaf = std::max( (unsigned int)children.size(), maxObjPerLeaf );
        return MB_SUCCESS;
    else
        unsigned int right_depth = depth, left_depth = depth;
        rval = traverse( impl, children[0], left_depth );
        rval = traverse( impl, children[1], right_depth );
        depth = std::max( left_depth, right_depth );
        return MB_SUCCESS;
Member Data Documentation
Definition at line 60 of file TreeStats.hpp.
Referenced by compute_stats(), output_all_stats(), print(), and reset().
Definition at line 65 of file TreeStats.hpp.
Referenced by compute_stats(), output_all_stats(), print(), reset(), and traverse().
Definition at line 64 of file TreeStats.hpp.
Definition at line 62 of file TreeStats.hpp.
Definition at line 61 of file TreeStats.hpp.
List of all members.
