MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "moab/Core.hpp" 00002 #include "moab/SpatialLocator.hpp" 00003 #include "moab/Tree.hpp" 00004 #include "moab/HomXform.hpp" 00005 #include "moab/ScdInterface.hpp" 00006 #include "moab/CartVect.hpp" 00007 #include "moab/AdaptiveKDTree.hpp" 00008 #include "moab/BVHTree.hpp" 00009 #include "moab/ProgOptions.hpp" 00010 #include "moab/CpuTimer.hpp" 00011 #include "moab/ElemEvaluator.hpp" 00012 00013 #ifdef MOAB_HAVE_MPI 00014 #include "moab_mpi.h" 00015 #endif 00016 00017 #include <cstdlib> 00018 #include <sstream> 00019 00020 using namespace moab; 00021 00022 ErrorCode test_locator( SpatialLocator& sl, int npoints, double rtol, double& cpu_time, double& percent_outside ); 00023 ErrorCode create_hex_mesh( Interface& mb, Range& elems, int n, int dim ); 00024 00025 int main( int argc, char** argv ) 00026 { 00027 #ifdef MOAB_HAVE_MPI 00028 int fail = MPI_Init( &argc, &argv ); 00029 if( fail ) return fail; 00030 #else 00031 // silence the warning of parameters not used, in serial; there should be a smarter way :( 00032 argv[0] = argv[argc - argc]; 00033 #endif 00034 00035 int npoints = 100, dim = 3; 00036 int dints = 1, dleafs = 1, ddeps = 1; 00037 bool eval = false; 00038 double rtol = 1.0e-10; 00039 00040 ProgOptions po( "tree_searching_perf options" ); 00041 po.addOpt< void >( ",e", "Use ElemEvaluator in tree search", &eval ); 00042 po.addOpt< int >( "ints,i", "Number of doublings of intervals on each side of scd mesh", &dints ); 00043 po.addOpt< int >( "leaf,l", "Number of doublings of maximum number of elements per leaf", &dleafs ); 00044 po.addOpt< int >( "max_depth,m", "Number of 5-intervals on maximum depth of tree", &ddeps ); 00045 po.addOpt< int >( "npoints,n", "Number of query points", &npoints ); 00046 po.addOpt< int >( "dim,d", "Dimension of the mesh", &dim ); 00047 po.addOpt< double >( "tol,t", "Relative tolerance of point search", &rtol ); 00048 // po.addOpt<void>( "print,p", "Print tree details", &print_tree); 00049 po.parseCommandLine( argc, argv ); 00050 00051 std::vector< int > ints, deps, leafs; 00052 ints.push_back( 10 ); 00053 for( int i = 1; i < dints; i++ ) 00054 ints.push_back( 2 * ints[i - 1] ); 00055 deps.push_back( 30 ); 00056 for( int i = 1; i < ddeps; i++ ) 00057 deps.push_back( deps[i - 1] - 5 ); 00058 leafs.push_back( 6 ); 00059 for( int i = 1; i < dleafs; i++ ) 00060 leafs.push_back( 2 * leafs[i - 1] ); 00061 00062 ErrorCode rval = MB_SUCCESS; 00063 std::cout << "Tree_type" 00064 << " " 00065 << "Elems_per_leaf" 00066 << " " 00067 << "Tree_depth" 00068 << " " 00069 << "Ints_per_side" 00070 << " " 00071 << "N_elements" 00072 << " " 00073 << "search_time" 00074 << " " 00075 << "perc_outside" 00076 << " " 00077 << "initTime" 00078 << " " 00079 << "nodesVisited" 00080 << " " 00081 << "leavesVisited" 00082 << " " 00083 << "numTraversals" 00084 << " " 00085 << "leafObjectTests" << std::endl; 00086 00087 // outermost iteration: # elements 00088 for( std::vector< int >::iterator int_it = ints.begin(); int_it != ints.end(); ++int_it ) 00089 { 00090 Core mb; 00091 Range elems; 00092 rval = create_hex_mesh( mb, elems, *int_it, dim ); 00093 if( MB_SUCCESS != rval ) return rval; 00094 00095 // iteration: tree depth 00096 for( std::vector< int >::iterator dep_it = deps.begin(); dep_it != deps.end(); ++dep_it ) 00097 { 00098 00099 // iteration: tree max elems/leaf 00100 for( std::vector< int >::iterator leafs_it = leafs.begin(); leafs_it != leafs.end(); ++leafs_it ) 00101 { 00102 00103 // iteration: tree type 00104 for( int tree_tp = 0; tree_tp < 2; tree_tp++ ) 00105 { 00106 // create tree 00107 Tree* tree; 00108 if( 0 == tree_tp ) 00109 tree = new BVHTree( &mb ); 00110 else 00111 tree = new AdaptiveKDTree( &mb ); 00112 00113 ElemEvaluator* eeval = NULL; 00114 if( eval ) 00115 { 00116 // create an element evaluator 00117 eeval = new ElemEvaluator( &mb ); 00118 rval = eeval->set_eval_set( *elems.begin() ); 00119 if( MB_SUCCESS != rval ) return rval; 00120 } 00121 00122 std::ostringstream opts; 00123 opts << "MAX_DEPTH=" << *dep_it << ";MAX_PER_LEAF=" << *leafs_it; 00124 FileOptions fo( opts.str().c_str() ); 00125 rval = tree->parse_options( fo ); 00126 if( MB_SUCCESS != rval ) return rval; 00127 SpatialLocator sl( &mb, elems, tree, eeval ); 00128 00129 // call evaluation 00130 double cpu_time, perc_outside; 00131 rval = test_locator( sl, npoints, rtol, cpu_time, perc_outside ); 00132 if( MB_SUCCESS != rval ) return rval; 00133 00134 std::cout << ( tree_tp == 0 ? "BVH" : "KD" ) << " " << *leafs_it << " " << *dep_it << " " << *int_it 00135 << " " << ( *int_it ) * ( *int_it ) * ( *int_it ) << " " << cpu_time << " " 00136 << perc_outside << " "; 00137 00138 tree->tree_stats().output_all_stats(); 00139 00140 if( eeval ) delete eeval; 00141 00142 } // tree_tp 00143 00144 } // max elems/leaf 00145 00146 } // max depth 00147 00148 } // # elements 00149 00150 #ifdef MOAB_HAVE_MPI 00151 fail = MPI_Finalize(); 00152 if( fail ) return fail; 00153 #endif 00154 00155 return 0; 00156 } 00157 00158 ErrorCode test_locator( SpatialLocator& sl, int npoints, double rtol, double& cpu_time, double& percent_outside ) 00159 { 00160 BoundBox box = sl.local_box(); 00161 CartVect box_del = box.bMax - box.bMin; 00162 00163 std::vector< CartVect > test_pts( npoints ), test_res( npoints ); 00164 std::vector< EntityHandle > ents( npoints ); 00165 int* is_in = new int[npoints]; 00166 00167 double denom = 1.0 / (double)RAND_MAX; 00168 for( int i = 0; i < npoints; i++ ) 00169 { 00170 // generate a small number of random point to test 00171 double rx = (double)rand() * denom, ry = (double)rand() * denom, rz = (double)rand() * denom; 00172 test_pts[i] = box.bMin + CartVect( rx * box_del[0], ry * box_del[1], rz * box_del[2] ); 00173 } 00174 00175 CpuTimer ct; 00176 00177 // call spatial locator to locate points 00178 ErrorCode rval = 00179 sl.locate_points( test_pts[0].array(), npoints, &ents[0], test_res[0].array(), &is_in[0], rtol, 0.0 ); 00180 if( MB_SUCCESS != rval ) 00181 { 00182 delete[] is_in; 00183 return rval; 00184 } 00185 00186 cpu_time = ct.time_elapsed(); 00187 00188 int num_out = std::count( is_in, is_in + npoints, false ); 00189 percent_outside = ( (double)num_out ) / npoints; 00190 delete[] is_in; 00191 00192 return rval; 00193 } 00194 00195 ErrorCode create_hex_mesh( Interface& mb, Range& elems, int n, int dim ) 00196 { 00197 ScdInterface* scdi; 00198 ErrorCode rval = mb.query_interface( scdi ); 00199 if( MB_SUCCESS != rval ) return rval; 00200 00201 HomCoord high( n - 1, -1, -1 ); 00202 if( dim > 1 ) high[1] = n - 1; 00203 if( dim > 2 ) high[2] = n - 1; 00204 ScdBox* new_box; 00205 rval = scdi->construct_box( HomCoord( 0, 0, 0 ), high, NULL, 0, new_box ); 00206 if( MB_SUCCESS != rval ) return rval; 00207 rval = mb.release_interface( scdi ); 00208 if( MB_SUCCESS != rval ) return rval; 00209 00210 rval = mb.get_entities_by_dimension( 0, dim, elems ); 00211 if( MB_SUCCESS != rval ) return rval; 00212 00213 return rval; 00214 }
