MOAB: Mesh Oriented datABase
(version 5.4.1)
#include <ScdInterface.hpp>
Collaboration diagram for moab::ScdBox:Public Member Functions | |
| ~ScdBox () | |
| Destructor. | |
| ScdInterface * | sc_impl () const |
| Return the ScdInterface responsible for this box. | |
| ErrorCode | add_vbox (ScdBox *vbox, HomCoord from1, HomCoord to1, HomCoord from2, HomCoord to2, HomCoord from3, HomCoord to3, bool bb_input=false, const HomCoord &bb_min=HomCoord::getUnitv(0), const HomCoord &bb_max=HomCoord::getUnitv(0)) |
| Add a vertex box to this box. | |
| bool | boundary_complete () const |
| Return whether this box has all its vertices defined. | |
| int | box_dimension () const |
| Return highest topological dimension of box. | |
| EntityHandle | start_vertex () const |
| Starting vertex handle for this box. | |
| EntityHandle | start_element () const |
| Starting entity handle for this box. | |
| int | num_elements () const |
| Return the number of elements in the box. | |
| int | num_vertices () const |
| Return the number of vertices in the box. | |
| const int * | box_dims () const |
| Return the parametric coordinates for this box. | |
| HomCoord | box_min () const |
| Return the lower corner parametric coordinates for this box. | |
| HomCoord | box_max () const |
| Return the upper corner parametric coordinates for this box. | |
| HomCoord | box_size () const |
| Return the parameter extents for this box. | |
| void | box_size (int *ijk) const |
| Return the parametric extents for this box. | |
| void | box_size (int &i, int &j, int &k) const |
| EntityHandle | get_element (const HomCoord &ijk) const |
| Get the element at the specified coordinates. | |
| EntityHandle | get_element (int i, int j=0, int k=0) const |
| EntityHandle | get_vertex (const HomCoord &ijk) const |
| Get the vertex at the specified coordinates. | |
| EntityHandle | get_vertex (int i, int j=0, int k=0) const |
| ErrorCode | get_params (EntityHandle ent, int &i, int &j, int &k, int &dir) const |
| Get parametric coordinates of the specified entity. | |
| ErrorCode | get_params (EntityHandle ent, int &i, int &j, int &k) const |
| ErrorCode | get_params (EntityHandle ent, HomCoord &ijkd) const |
| ErrorCode | get_adj_edge_or_face (int dim, int i, int j, int k, int dir, EntityHandle &ent, bool create_if_missing=true) const |
| Get the adjacent edge or face at a parametric location This function gets the left (i=0), front (j=0), or bottom (k=0) edge or face for a parametric element. Left, front, or bottom is indicated by dir = 0, 1, or 2, resp. All edges and faces in a structured mesh block can be accessed using these parameters. | |
| bool | contains (int i, int j, int k) const |
| Return whether the box contains the parameters passed in. | |
| bool | contains (const HomCoord &ijk) const |
| void | box_set (EntityHandle this_set) |
| Set/Get the entity set representing the box. | |
| EntityHandle | box_set () |
| ErrorCode | get_coordinate_arrays (double *&xc, double *&yc, double *&zc) |
| Get coordinate arrays for vertex coordinates for a structured block. | |
| ErrorCode | get_coordinate_arrays (const double *&xc, const double *&yc, const double *&zc) const |
| Get read-only coordinate arrays for vertex coordinates for a structured block. | |
| bool | locally_periodic_i () const |
| Return whether box is locally periodic in i. | |
| bool | locally_periodic_j () const |
| Return whether box is locally periodic in j. | |
| bool | locally_periodic_k () const |
| Return whether box is locally periodic in k. | |
| void | locally_periodic (bool lperiodic[3]) |
| Set local periodicity. | |
| const int * | locally_periodic () const |
| Get local periodicity. | |
| ScdParData & | par_data () |
| Return parallel data. | |
| const ScdParData & | par_data () const |
| void | par_data (const ScdParData &par_datap) |
| set parallel data | |
Private Member Functions | |
| ScdBox (ScdInterface *sc_impl, EntityHandle box_set, EntitySequence *seq1, EntitySequence *seq2=NULL) | |
| Constructor. | |
| EntityHandle | get_vertex_from_seq (int i, int j, int k) const |
| function to get vertex handle directly from sequence | |
| ErrorCode | vert_dat (ScdVertexData *vert_dat) |
| set the vertex sequence | |
| ScdVertexData * | vert_dat () const |
| get the vertex sequence | |
| ErrorCode | elem_seq (EntitySequence *elem_seq) |
| set the element sequence | |
| StructuredElementSeq * | elem_seq () const |
| get the element sequence | |
| void | start_vertex (EntityHandle startv) |
| Set the starting vertex handle for this box. | |
| void | start_element (EntityHandle starte) |
| Set the starting entity handle for this box. | |
Private Attributes | |
| ScdInterface * | scImpl |
| interface instance | |
| EntityHandle | boxSet |
| entity set representing this box | |
| ScdVertexData * | vertDat |
| StructuredElementSeq * | elemSeq |
| element sequence this box represents | |
| EntityHandle | startVertex |
| starting vertex handle for this box | |
| EntityHandle | startElem |
| starting element handle for this box | |
| int | boxDims [6] |
| lower and upper corners | |
| int | locallyPeriodic [3] |
| is locally periodic in i or j or k | |
| ScdParData | parData |
| parallel data associated with this box, if any | |
| HomCoord | boxSize |
| parameter extents | |
| int | boxSizeIJ |
| convenience parameters, (boxSize[1]-1)*(boxSize[0]-1) and boxSize[0]-1 | |
| int | boxSizeIJM1 |
| int | boxSizeIM1 |
Friends | |
| class | ScdInterface |
Definition at line 506 of file ScdInterface.hpp.
Destructor.
Definition at line 548 of file ScdInterface.cpp.
References moab::ScdInterface::box_set_tag(), boxSet, moab::Core::is_valid(), mbcore, moab::ScdInterface::mbImpl, moab::ScdInterface::remove_box(), scImpl, and moab::Interface::tag_set_data().
// Reset the tag on the set
if( boxSet )
// It is possible that the box set entity has been deleted (e.g. by
// Core::clean_up_failed_read)
Core* mbcore = dynamic_cast< Core* >( scImpl->mbImpl );
assert( mbcore != NULL );
if( mbcore->is_valid( boxSet ) )
ScdBox* tmp_ptr = NULL;
scImpl->mbImpl->tag_set_data( scImpl->box_set_tag(), &boxSet, 1, &tmp_ptr );
else
boxSet = 0;
scImpl->remove_box( this );
| moab::ScdBox::ScdBox | ( | ScdInterface * | sc_impl, |
| EntityHandle | box_set, | ||
| EntitySequence * | seq1, | ||
| EntitySequence * | seq2 = NULL |
| ) | [private] |
Constructor.
Create a structured box instance; this constructor is private because it should only be called from ScdInterface, a friend class. This constructor takes two sequences, one of which can be NULL. If both sequences come in non-NULL, the first should be a VertexSequence* corresponding to a structured vertex sequence and the second should be a StructuredElementSeq*. If the 2nd is NULL, the first can be either of those types. The other members of this class are taken from the sequences (e.g. parametric space) or the box set argument. Tags on the box set should be set from the caller.
| sc_impl | A ScdInterface instance |
| box_set | Entity set representing this rectangle |
| seq1 | An EntitySequence (see ScdBox description) |
| seq2 | An EntitySequence (see ScdBox description), or NULL |
Definition at line 474 of file ScdInterface.cpp.
References moab::ScdInterface::add_box(), moab::Range::begin(), boxDims, moab::ScdInterface::boxDimsTag, moab::ScdInterface::boxPeriodicTag, boxSize, boxSizeIJ, boxSizeIJM1, boxSizeIM1, moab::EntitySequence::data(), elemSeq, moab::Range::empty(), ErrorCode, moab::Interface::get_entities_by_dimension(), locallyPeriodic, moab::ScdVertexData::max_params(), moab::ScdElementData::max_params(), MB_SUCCESS, moab::ScdInterface::mbImpl, moab::ScdVertexData::min_params(), moab::ScdElementData::min_params(), scImpl, moab::StructuredElementSeq::sdata(), moab::SequenceData::start_handle(), moab::EntitySequence::start_handle(), startElem, startVertex, moab::Interface::tag_get_data(), and vertDat.
: scImpl( impl ), boxSet( bset ), vertDat( NULL ), elemSeq( NULL ), startVertex( 0 ), startElem( 0 ) { for( int i = 0; i < 6; i++ ) boxDims[i] = 0; for( int i = 0; i < 3; i++ ) locallyPeriodic[i] = false; VertexSequence* vseq = dynamic_cast< VertexSequence* >( seq1 ); if( vseq ) vertDat = dynamic_cast< ScdVertexData* >( vseq->data() ); if( vertDat ) { // retrieve the parametric space for( int i = 0; i < 3; i++ ) { boxDims[i] = vertDat->min_params()[i]; boxDims[3 + i] = vertDat->max_params()[i]; } startVertex = vertDat->start_handle(); } else if( impl->boxDimsTag ) { // look for parametric space info on set ErrorCode rval = impl->mbImpl->tag_get_data( impl->boxDimsTag, &bset, 1, boxDims ); if( MB_SUCCESS == rval ) { Range verts; impl->mbImpl->get_entities_by_dimension( bset, 0, verts ); if( !verts.empty() ) startVertex = *verts.begin(); } } elemSeq = dynamic_cast< StructuredElementSeq* >( seq2 ); if( !elemSeq ) elemSeq = dynamic_cast< StructuredElementSeq* >( seq1 ); if( elemSeq ) { if( vertDat ) { // check the parametric space to make sure it's consistent assert( elemSeq->sdata()->min_params() == HomCoord( boxDims, 3 ) && ( elemSeq->sdata()->max_params() + HomCoord( 1, 1, 1 ) ) == HomCoord( boxDims, 3 ) ); } else { // get the parametric space from the element sequence for( int i = 0; i < 3; i++ ) { boxDims[i] = elemSeq->sdata()->min_params()[i]; boxDims[3 + i] = elemSeq->sdata()->max_params()[i]; } } startElem = elemSeq->start_handle(); } else { Range elems; impl->mbImpl->get_entities_by_dimension( bset, ( boxDims[2] == boxDims[5] ? ( boxDims[1] == boxDims[4] ? 1 : 2 ) : 3 ), elems ); if( !elems.empty() ) startElem = *elems.begin(); // call the following w/o looking at return value, since it doesn't really need to be there if( impl->boxPeriodicTag ) impl->mbImpl->tag_get_data( impl->boxPeriodicTag, &bset, 1, locallyPeriodic ); } assert( vertDat || elemSeq || boxDims[0] != boxDims[3] || boxDims[1] != boxDims[4] || boxDims[2] != boxDims[5] ); boxSize = HomCoord( boxDims + 3, 3 ) - HomCoord( boxDims, 3 ) + HomCoord( 1, 1, 1 ); boxSizeIJ = ( boxSize[1] ? boxSize[1] : 1 ) * boxSize[0]; boxSizeIM1 = boxSize[0] - ( locallyPeriodic[0] ? 0 : 1 ); boxSizeIJM1 = ( boxSize[1] ? ( boxSize[1] - ( locallyPeriodic[1] ? 0 : 1 ) ) : 1 ) * boxSizeIM1; scImpl->add_box( this ); }
| ErrorCode moab::ScdBox::add_vbox | ( | ScdBox * | vbox, |
| HomCoord | from1, | ||
| HomCoord | to1, | ||
| HomCoord | from2, | ||
| HomCoord | to2, | ||
| HomCoord | from3, | ||
| HomCoord | to3, | ||
| bool | bb_input = false, |
| const HomCoord & | bb_min = HomCoord::getUnitv( 0 ), |
| const HomCoord & | bb_max = HomCoord::getUnitv( 0 ) |
Definition at line 580 of file ScdInterface.cpp.
References moab::ScdElementData::add_vsequence(), elemSeq, ErrorCode, moab::StructuredElementSeq::sdata(), and vertDat.
Referenced by moab::ScdInterface::construct_box(), create_1d_3_sequences(), create_2d_3_sequences(), create_2dtri_3_sequences(), create_3dtri_3_sequences(), eseq_test1a(), eseq_test1b(), and eseq_test1c().
if( !vbox->vertDat ) return MB_FAILURE;
ScdVertexData* dum_data = dynamic_cast< ScdVertexData* >( vbox->vertDat );
ErrorCode rval =
elemSeq->sdata()->add_vsequence( dum_data, from1, to1, from2, to2, from3, to3, bb_input, bb_min, bb_max );
return rval;
| bool moab::ScdBox::boundary_complete | ( | ) | const |
Tests whether vertex boxs added with add_vbox have completely defined the vertex parametric space for this box.
Definition at line 598 of file ScdInterface.cpp.
References moab::StructuredElementSeq::boundary_complete(), and elemSeq.
Referenced by check_element_sequence(), and moab::ScdNCHelper::create_mesh().
return elemSeq->boundary_complete();
| int moab::ScdBox::box_dimension | ( | ) | const [inline] |
Definition at line 575 of file ScdInterface.cpp.
References moab::Interface::dimension_from_handle(), moab::ScdInterface::mbImpl, scImpl, and startElem.
Referenced by get_params(), and moab::ScdInterface::tag_shared_vertices().
return ( startElem ? scImpl->mbImpl->dimension_from_handle( startElem ) : -1 );
| const int * moab::ScdBox::box_dims | ( | ) | const [inline] |
Definition at line 1520 of file ScdInterface.hpp.
References boxDims.
Referenced by moab::ScdInterface::assign_global_ids(), and moab::ScdInterface::get_shared_vertices().
return boxDims;
| HomCoord moab::ScdBox::box_max | ( | ) | const [inline] |
Definition at line 1530 of file ScdInterface.hpp.
References boxDims.
Referenced by access_adjacencies(), check_element_sequence(), check_vertex_sequence(), evaluate_element_sequence(), evaluate_vertex_sequence(), and moab::Skinner::skin_box().
return HomCoord( boxDims + 3, 3 );
| HomCoord moab::ScdBox::box_min | ( | ) | const [inline] |
Definition at line 1525 of file ScdInterface.hpp.
References boxDims.
return HomCoord( boxDims, 3 );
| void moab::ScdBox::box_set | ( | EntityHandle | this_set | ) | [inline] |
Definition at line 1589 of file ScdInterface.hpp.
References boxSet.
Referenced by moab::ScdInterface::construct_box(), moab::ScdNCHelper::create_mesh(), create_parallel_mesh(), iMesh_createStructuredMesh(), and moab::ScdInterface::tag_shared_vertices().
boxSet = this_set;
| EntityHandle moab::ScdBox::box_set | ( | ) | [inline] |
| HomCoord moab::ScdBox::box_size | ( | ) | const [inline] |
Definition at line 1535 of file ScdInterface.hpp.
References boxSize.
Referenced by access_adjacencies(), check_element_sequence(), check_vertex_sequence(), and moab::ScdInterface::construct_box().
return boxSize;
| void moab::ScdBox::box_size | ( | int * | ijk | ) | const [inline] |
| void moab::ScdBox::box_size | ( | int & | i, |
| int & | j, | ||
| int & | k | ||
| bool moab::ScdBox::contains | ( | int | i, |
| int | j, | ||
| int | k | ||
| i | Parametric coordinates being evaluated |
| j | Parametric coordinates being evaluated |
| k | Parametric coordinates being evaluated |
Definition at line 1584 of file ScdInterface.hpp.
Referenced by evaluate_element_sequence(), and evaluate_vertex_sequence().
return contains( HomCoord( i, j, k ) );
| bool moab::ScdBox::contains | ( | const HomCoord & | ijk | ) | const [inline] |
Definition at line 1579 of file ScdInterface.hpp.
References boxDims.
| ErrorCode moab::ScdBox::elem_seq | ( | EntitySequence * | elem_seq | ) | [private] |
Definition at line 628 of file ScdInterface.cpp.
References boxSize, boxSizeIJM1, boxSizeIM1, elemSeq, moab::StructuredElementSeq::is_periodic(), locallyPeriodic, and MB_SUCCESS.
Referenced by moab::ScdInterface::construct_box().
elemSeq = dynamic_cast< StructuredElementSeq* >( elem_sq );
if( elemSeq ) elemSeq->is_periodic( locallyPeriodic );
if( locallyPeriodic[0] ) boxSizeIM1 = boxSize[0] - ( locallyPeriodic[0] ? 0 : 1 );
if( locallyPeriodic[0] || locallyPeriodic[1] )
return ( elemSeq ? MB_SUCCESS : MB_FAILURE );
| StructuredElementSeq * moab::ScdBox::elem_seq | ( | ) | const [inline, private] |
Definition at line 1604 of file ScdInterface.hpp.
References elemSeq.
return elemSeq;
| ErrorCode moab::ScdBox::get_adj_edge_or_face | ( | int | dim, |
| int | i, | ||
| int | j, | ||
| int | k, | ||
| int | dir, | ||
| EntityHandle & | ent, | ||
| bool | create_if_missing = true |
| ) | const |
Get the entity of specified dimension adjacent to parametric element.
| dim | Dimension of adjacent entity being requested |
| i | Parametric coordinates of cell being evaluated |
| j | Parametric coordinates of cell being evaluated |
| k | Parametric coordinates of cell being evaluated |
| dir | Direction (0, 1, or 2), for getting adjacent edges (2d, 3d) or faces (3d) |
| ent | Entity returned from this function |
| create_if_missing | If true, creates the entity if it doesn't already exist |
| ent | EntityHandle of adjacent entity |
Definition at line 669 of file ScdInterface.cpp.
References moab::Range::begin(), boxDims, moab::Interface::create_element(), dim, ErrorCode, moab::Interface::get_adjacencies(), get_vertex(), moab::ScdInterface::impl(), locallyPeriodic, MB_SUCCESS, MBEDGE, MBQUAD, scImpl, and moab::Range::size().
Referenced by access_adjacencies(), and moab::Skinner::skin_box().
// describe connectivity of sub-element in static array
// subconnect[dim-1][dir][numv][ijk] where dimensions are:
// [dim-1]: dim=1 or 2, so this is 0 or 1
// [dir]: one of 0..2, for ijk directions in a hex
// [numv]: number of vertices describing sub entity = 2*dim <= 4
// [ijk]: 3 values for i, j, k
int subconnect[2][3][4][3] = { { { { 0, 0, 0 }, { 1, 0, 0 }, { -1, -1, -1 }, { -1, -1, -1 } }, // i edge
{ { 0, 0, 0 }, { 0, 1, 0 }, { -1, -1, -1 }, { -1, -1, -1 } }, // j edge
{ { 0, 0, 0 }, { 0, 0, 1 }, { -1, -1, -1 }, { -1, -1, -1 } } }, // k edge
{ { { 0, 0, 0 }, { 0, 1, 0 }, { 0, 1, 1 }, { 0, 0, 1 } }, // i face
{ { 0, 0, 0 }, { 1, 0, 0 }, { 1, 0, 1 }, { 0, 0, 1 } }, // j face
{ { 0, 0, 0 }, { 1, 0, 0 }, { 1, 1, 0 }, { 0, 1, 0 } } } }; // k face
// check proper input dimensions and lower bound
if( dim < 1 || dim > 2 || i < boxDims[0] || j < boxDims[1] || k < boxDims[2] ) return MB_FAILURE;
// now check upper bound; parameters must be <= upper corner, since edges/faces
// follow element parameterization, not vertex parameterization
else if( ( boxDims[3] != boxDims[0] && i > ( locallyPeriodic[0] ? boxDims[3] + 1 : boxDims[3] ) ) ||
( boxDims[4] != boxDims[1] && j > ( locallyPeriodic[1] ? boxDims[4] + 1 : boxDims[4] ) ) ||
( boxDims[5] != boxDims[2] && k > boxDims[5] ) )
return MB_FAILURE;
// get the vertices making up this entity
EntityHandle verts[4];
for( int ind = 0; ind < 2 * dim; ind++ )
int i1 = i + subconnect[dim - 1][dir][ind][0];
int j1 = j + subconnect[dim - 1][dir][ind][1];
// if periodic in i and i1 is boxDims[3]+1, wrap around
if( locallyPeriodic[0] && i1 == boxDims[3] + 1 ) i1 = boxDims[0];
// if periodic in j and j1 is boxDims[4]+1, wrap around
if( locallyPeriodic[1] && j1 == boxDims[4] + 1 ) j1 = boxDims[1];
verts[ind] = get_vertex( i1, j1, k + subconnect[dim - 1][dir][ind][2] );
if( !verts[ind] ) return MB_FAILURE;
Range ents;
ErrorCode rval = scImpl->impl()->get_adjacencies( verts, 2 * dim, dim, false, ents );
if( MB_SUCCESS != rval ) return rval;
if( ents.size() > 1 )
return MB_FAILURE;
else if( ents.size() == 1 )
ent = *ents.begin();
else if( create_if_missing )
rval = scImpl->impl()->create_element( ( 1 == dim ? MBEDGE : MBQUAD ), verts, 2 * dim, ent );
return rval;
| ErrorCode moab::ScdBox::get_coordinate_arrays | ( | double *& | xc, |
| double *& | yc, | ||
| double *& | zc | ||
Returns error if there isn't a single vertex sequence associated with this structured block
| xc | X coordinate array pointer returned |
| yc | Y coordinate array pointer returned |
| zc | Z coordinate array pointer returned |
Definition at line 603 of file ScdInterface.cpp.
References moab::SequenceData::get_sequence_data(), MB_SUCCESS, and vertDat.
Referenced by moab::ScdInterface::construct_box(), moab::ScdNCHelper::create_mesh(), and iMesh_createStructuredMesh().
if( !vertDat ) return MB_FAILURE;
xc = reinterpret_cast< double* >( vertDat->get_sequence_data( 0 ) );
yc = reinterpret_cast< double* >( vertDat->get_sequence_data( 1 ) );
zc = reinterpret_cast< double* >( vertDat->get_sequence_data( 2 ) );
return MB_SUCCESS;
| ErrorCode moab::ScdBox::get_coordinate_arrays | ( | const double *& | xc, |
| const double *& | yc, | ||
| const double *& | zc | ||
| ) | const |
Definition at line 613 of file ScdInterface.cpp.
xc = reinterpret_cast< const double* >( vertDat->get_sequence_data( 0 ) );
yc = reinterpret_cast< const double* >( vertDat->get_sequence_data( 1 ) );
zc = reinterpret_cast< const double* >( vertDat->get_sequence_data( 2 ) );
return MB_SUCCESS;
| EntityHandle moab::ScdBox::get_element | ( | const HomCoord & | ijk | ) | const [inline] |
| ijk | Parametric coordinates being evaluated |
Definition at line 1561 of file ScdInterface.hpp.
Referenced by moab::Core::create_scd_sequence(), evaluate_element_sequence(), and main().
return get_element( ijk[0], ijk[1], ijk[2] );
| EntityHandle moab::ScdBox::get_element | ( | int | i, |
| int | j = 0, |
| int | k = 0 |
Definition at line 1554 of file ScdInterface.hpp.
References boxDims, boxSizeIJM1, boxSizeIM1, and startElem.
return ( !startElem
? 0
: startElem + ( k - boxDims[2] ) * boxSizeIJM1 + ( j - boxDims[1] ) * boxSizeIM1 + i - boxDims[0] );
| ErrorCode moab::ScdBox::get_params | ( | EntityHandle | ent, |
| int & | i, | ||
| int & | j, | ||
| int & | k, | ||
| int & | dir | ||
This function returns MB_ENTITY_NOT_FOUND if the entity is not in this ScdBox.
| ent | Entity being queried |
| i | Parametric coordinates returned |
| j | Parametric coordinates returned |
| k | Parametric coordinates returned |
| dir | Parametric coordinate direction returned (in case of getting adjacent edges (2d, 3d) or faces (3d); not modified otherwise |
Definition at line 1609 of file ScdInterface.hpp.
References ErrorCode, and MB_SUCCESS.
Referenced by evaluate_element_sequence(), evaluate_vertex_sequence(), and get_params().
HomCoord hc;
ErrorCode rval = get_params( ent, hc );
i = hc[0];
j = hc[1];
k = hc[2];
dir = hc[3];
return rval;
| int & | i, | ||
| int & | j, | ||
| int & | k | ||
Get parametric coordinates of the specified entity, intermediate entities not allowed (no dir parameter) This function returns MB_ENTITY_NOT_FOUND if the entity is not in this ScdBox, or MB_FAILURE if the entity is an intermediate-dimension entity.
Definition at line 1624 of file ScdInterface.hpp.
References ErrorCode, get_params(), and MB_SUCCESS.
HomCoord hc;
i = hc[0];
j = hc[1];
k = hc[2];
return rval;
| HomCoord & | ijkd | ||
| ) | const |
| ijkd | Parametric coordinates returned (including direction, in case of getting adjacent edges (2d, 3d) or faces (3d)) |
Definition at line 640 of file ScdInterface.cpp.
References box_dimension(), moab::Interface::dimension_from_handle(), elemSeq, moab::ScdVertexData::get_params(), moab::StructuredElementSeq::get_params(), moab::ScdInterface::impl(), MB_NOT_IMPLEMENTED, scImpl, and vertDat.
// check first whether this is an intermediate entity, so we know what to do
int dimension = box_dimension();
int this_dim = scImpl->impl()->dimension_from_handle( ent );
if( ( 0 == this_dim && !vertDat ) || ( this_dim && this_dim == dimension ) )
assert( elemSeq );
return elemSeq->get_params( ent, ijkd[0], ijkd[1], ijkd[2] );
else if( !this_dim && vertDat )
return vertDat->get_params( ent, ijkd[0], ijkd[1], ijkd[2] );
else
return MB_NOT_IMPLEMENTED;
| EntityHandle moab::ScdBox::get_vertex | ( | const HomCoord & | ijk | ) | const [inline] |
Definition at line 1574 of file ScdInterface.hpp.
Referenced by moab::Core::create_scd_sequence(), evaluate_element_sequence(), evaluate_vertex_sequence(), get_adj_edge_or_face(), and main().
return get_vertex( ijk[0], ijk[1], ijk[2] );
| EntityHandle moab::ScdBox::get_vertex | ( | int | i, |
| int | j = 0, |
| int | k = 0 |
Definition at line 1566 of file ScdInterface.hpp.
References boxDims, boxSize, boxSizeIJ, get_vertex_from_seq(), startVertex, and vertDat.
| EntityHandle moab::ScdBox::get_vertex_from_seq | ( | int | i, |
| int | j, | ||
| int | k | ||
| ) | const [private] |
| i | Parameter being queried |
| j | Parameter being queried |
| k | Parameter being queried |
Definition at line 569 of file ScdInterface.cpp.
References elemSeq, and moab::StructuredElementSeq::get_vertex().
Referenced by get_vertex().
assert( elemSeq );
return elemSeq->get_vertex( i, j, k );
| void moab::ScdBox::locally_periodic | ( | bool | lperiodic[3] | ) | [inline] |
| lperiodic | Vector of ijk periodicities to set this box to |
Definition at line 1653 of file ScdInterface.hpp.
References locallyPeriodic.
Referenced by moab::ScdInterface::assign_global_ids().
locallyPeriodic[i] = lperiodic[i];
| const int * moab::ScdBox::locally_periodic | ( | ) | const [inline] |
Definition at line 1659 of file ScdInterface.hpp.
return locallyPeriodic;
| bool moab::ScdBox::locally_periodic_i | ( | ) | const [inline] |
Definition at line 1638 of file ScdInterface.hpp.
Referenced by evaluate_element_sequence().
return locallyPeriodic[0];
| bool moab::ScdBox::locally_periodic_j | ( | ) | const [inline] |
Definition at line 1643 of file ScdInterface.hpp.
return locallyPeriodic[1];
| bool moab::ScdBox::locally_periodic_k | ( | ) | const [inline] |
Definition at line 1648 of file ScdInterface.hpp.
return locallyPeriodic[2];
| int moab::ScdBox::num_elements | ( | ) | const [inline] |
Definition at line 1493 of file ScdInterface.hpp.
References boxSize, locallyPeriodic, and startElem.
Referenced by moab::ScdInterface::construct_box(), moab::ScdNCHelper::create_mesh(), moab::ScdInterface::create_scd_sequence(), eseq_test1a(), iMesh_createStructuredMesh(), mb_skin_scd_test(), moab::ScdInterface::tag_shared_vertices(), and test_bound_box().
if( !startElem ) return 0; // not initialized yet
/* for a structured mesh, total number of elements is obtained by multiplying
number of elements in each direction
number of elements in each direction is given by number of vertices in that direction minus 1
if periodic in that direction, the last vertex is the same as first one, count one more
element
int num_e_i = ( -1 == boxSize[0] || 1 == boxSize[0] ) ? 1 : boxSize[0] - 1;
if( locallyPeriodic[0] ) ++num_e_i;
int num_e_j = ( -1 == boxSize[1] || 1 == boxSize[1] ) ? 1 : boxSize[1] - 1;
if( locallyPeriodic[1] ) ++num_e_j;
int num_e_k = ( -1 == boxSize[2] || 1 == boxSize[2] ) ? 1 : boxSize[2] - 1;
if( locallyPeriodic[2] ) ++num_e_k;
return num_e_i * num_e_j * num_e_k;
| int moab::ScdBox::num_vertices | ( | ) | const [inline] |
Definition at line 1515 of file ScdInterface.hpp.
References boxSize.
Referenced by moab::ScdInterface::assign_global_ids(), moab::ScdNCHelper::create_mesh(), moab::ScdInterface::create_scd_sequence(), and iMesh_createStructuredMesh().
| ScdParData& moab::ScdBox::par_data | ( | ) | [inline] |
Return parallel data, if there is any
Definition at line 749 of file ScdInterface.hpp.
Referenced by moab::ScdInterface::assign_global_ids(), moab::ScdInterface::construct_box(), moab::ScdInterface::get_shared_vertices(), iMesh_createStructuredMesh(), and moab::ScdInterface::tag_shared_vertices().
return parData;
| const ScdParData& moab::ScdBox::par_data | ( | ) | const [inline] |
Definition at line 758 of file ScdInterface.hpp.
return parData;
| void moab::ScdBox::par_data | ( | const ScdParData & | par_datap | ) | [inline] |
set parallel data
Set parallel data for this box
| par_data | Parallel data to be set on this box |
Definition at line 767 of file ScdInterface.hpp.
parData = par_datap;
| ScdInterface * moab::ScdBox::sc_impl | ( | ) | const [inline] |
Definition at line 1468 of file ScdInterface.hpp.
References scImpl.
Referenced by access_adjacencies().
return scImpl;
| EntityHandle moab::ScdBox::start_element | ( | ) | const [inline] |
If this is a vertex box, the start vertex handle is returned.
Definition at line 1483 of file ScdInterface.hpp.
References startElem.
Referenced by check_element_sequence(), moab::ScdInterface::construct_box(), moab::ScdNCHelper::create_mesh(), eseq_test1a(), eseq_test1b(), eseq_test1c(), iMesh_createStructuredMesh(), mb_skin_scd_test(), moab::ScdInterface::tag_shared_vertices(), test_bound_box(), and test_scd_invalid().
return startElem;
| void moab::ScdBox::start_element | ( | EntityHandle | starte | ) | [inline, private] |
Definition at line 1488 of file ScdInterface.hpp.
startElem = starte;
| EntityHandle moab::ScdBox::start_vertex | ( | ) | const [inline] |
Definition at line 1473 of file ScdInterface.hpp.
References startVertex.
Referenced by moab::ScdInterface::assign_global_ids(), check_vertex_sequence(), moab::ScdNCHelper::create_mesh(), evaluate_vertex_sequence(), iMesh_createStructuredMesh(), moab::ScdInterface::tag_shared_vertices(), test_bound_box(), and test_vertex_seq().
return startVertex;
| void moab::ScdBox::start_vertex | ( | EntityHandle | startv | ) | [inline, private] |
Definition at line 1478 of file ScdInterface.hpp.
startVertex = startv;
| ErrorCode moab::ScdBox::vert_dat | ( | ScdVertexData * | vert_dat | ) | [private] |
Definition at line 622 of file ScdInterface.cpp.
References MB_SUCCESS, and vertDat.
vertDat = vert_dt;
return MB_SUCCESS;
| ScdVertexData * moab::ScdBox::vert_dat | ( | ) | const [inline, private] |
Definition at line 1599 of file ScdInterface.hpp.
References vertDat.
return vertDat;
friend class ScdInterface [friend] |
Definition at line 508 of file ScdInterface.hpp.
int moab::ScdBox::boxDims[6] [private] |
Definition at line 832 of file ScdInterface.hpp.
Referenced by box_dims(), box_max(), box_min(), contains(), get_adj_edge_or_face(), get_element(), get_vertex(), and ScdBox().
EntityHandle moab::ScdBox::boxSet [private] |
Definition at line 816 of file ScdInterface.hpp.
HomCoord moab::ScdBox::boxSize [private] |
parameter extents
Definition at line 841 of file ScdInterface.hpp.
Referenced by box_size(), elem_seq(), get_vertex(), num_elements(), num_vertices(), and ScdBox().
int moab::ScdBox::boxSizeIJ [private] |
Definition at line 844 of file ScdInterface.hpp.
Referenced by get_vertex(), and ScdBox().
int moab::ScdBox::boxSizeIJM1 [private] |
Definition at line 845 of file ScdInterface.hpp.
Referenced by elem_seq(), get_element(), and ScdBox().
int moab::ScdBox::boxSizeIM1 [private] |
Definition at line 846 of file ScdInterface.hpp.
StructuredElementSeq* moab::ScdBox::elemSeq [private] |
Definition at line 823 of file ScdInterface.hpp.
Referenced by add_vbox(), boundary_complete(), elem_seq(), get_params(), get_vertex_from_seq(), and ScdBox().
int moab::ScdBox::locallyPeriodic[3] [private] |
Definition at line 835 of file ScdInterface.hpp.
Referenced by elem_seq(), get_adj_edge_or_face(), locally_periodic(), locally_periodic_i(), locally_periodic_j(), locally_periodic_k(), num_elements(), and ScdBox().
ScdParData moab::ScdBox::parData [private] |
Definition at line 838 of file ScdInterface.hpp.
ScdInterface* moab::ScdBox::scImpl [private] |
interface instance
Definition at line 813 of file ScdInterface.hpp.
Referenced by box_dimension(), get_adj_edge_or_face(), get_params(), sc_impl(), ScdBox(), and ~ScdBox().
EntityHandle moab::ScdBox::startElem [private] |
Definition at line 829 of file ScdInterface.hpp.
Referenced by box_dimension(), get_element(), num_elements(), ScdBox(), and start_element().
EntityHandle moab::ScdBox::startVertex [private] |
Definition at line 826 of file ScdInterface.hpp.
Referenced by get_vertex(), ScdBox(), and start_vertex().
ScdVertexData* moab::ScdBox::vertDat [private] |
vertex sequence this box represents, if there's only one, otherwise they're retrieved from the element sequence
Definition at line 820 of file ScdInterface.hpp.
Referenced by add_vbox(), get_coordinate_arrays(), get_params(), get_vertex(), ScdBox(), and vert_dat().
