MOAB: Mesh Oriented datABase
(version 5.4.1)
Public Member Functions | |
| integer(c_int) function | iMOAB_GetMeshInfo (pid, num_visible_vertices, num_visible_elements, num_visible_blocks, num_visible_surfaceBC, num_visible_vertexBC) |
Definition at line 111 of file iMOABF.F90.
| integer(c_int) function iMOAB::iMOAB_GetMeshInfo::iMOAB_GetMeshInfo | ( | integer(c_int), intent(in) | pid, |
| integer(c_int), dimension(3), intent(out) | num_visible_vertices, | ||
| integer(c_int), dimension(3), intent(out) | num_visible_elements, | ||
| integer(c_int), dimension(3), intent(out) | num_visible_blocks, | ||
| integer(c_int), dimension(3), intent(out) | num_visible_surfaceBC, | ||
| integer(c_int), dimension(3), intent(out) | num_visible_vertexBC | ||
