MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 ! iMOAB Interface for Fortran 90/2003/2008 compatible compilers 00002 00003 #include "moab/MOABConfig.h" 00004 00005 module iMOAB 00006 00007 use iso_c_binding 00008 implicit none 00009 00010 ! Interface to all the API routines 00011 interface 00012 00013 integer(c_int) function iMOAB_Initialize() bind(C, name='iMOAB_InitializeFortran') 00014 ! Directly forward the call 00015 use, intrinsic :: iso_c_binding, only: c_int 00016 end function iMOAB_Initialize 00017 00018 integer(c_int) function iMOAB_Finalize() bind(C, name='iMOAB_Finalize') 00019 ! Directly forward the call 00020 use, intrinsic :: iso_c_binding, only: c_int 00021 end function iMOAB_Finalize 00022 00023 #ifdef MOAB_HAVE_MPI 00024 integer(c_int) function iMOAB_RegisterApplication(app_name, fcomm, compid, pid) & 00025 bind(C, name='iMOAB_RegisterApplicationFortran') 00026 #else 00027 integer(c_int) function iMOAB_RegisterApplication(app_name, compid, pid) & 00028 bind(C, name='iMOAB_RegisterApplicationFortran') 00029 #endif 00030 ! Interface blocks don't know about their context, 00031 ! so we need to use iso_c_binding inside all interface functions again 00032 use, intrinsic :: iso_c_binding, only: c_int, c_char, c_ptr 00033 character(kind=c_char), intent(in) :: app_name(*) 00034 #ifdef MOAB_HAVE_MPI 00035 integer, intent(in) :: fcomm 00036 #endif 00037 integer(c_int), intent(in) :: compid 00038 integer(c_int), intent(out) :: pid 00039 end function iMOAB_RegisterApplication 00040 00041 integer(c_int) function iMOAB_DeregisterApplication(pid) bind(C, name='iMOAB_DeregisterApplicationFortran') 00042 use, intrinsic :: iso_c_binding, only: c_int 00043 integer(c_int), intent(in) :: pid 00044 end function iMOAB_DeregisterApplication 00045 00046 integer(c_int) function iMOAB_ReadHeaderInfo(filename, num_global_vertices, num_global_elements, & 00047 num_dimension, num_parts) bind(C, name='iMOAB_ReadHeaderInfo') 00048 use, intrinsic :: iso_c_binding, only: c_int, c_char 00049 character(kind=c_char), intent(in) :: filename(*) 00050 integer(c_int), intent(out) :: num_global_vertices 00051 integer(c_int), intent(out) :: num_global_elements 00052 integer(c_int), intent(out) :: num_dimension 00053 integer(c_int), intent(out) :: num_parts 00054 end function iMOAB_ReadHeaderInfo 00055 00056 integer(c_int) function iMOAB_LoadMesh(pid, filename, read_options, num_ghost_layers) bind(C, name='iMOAB_LoadMesh') 00057 use, intrinsic :: iso_c_binding, only: c_int, c_char 00058 integer(c_int), intent(in) :: pid 00059 character(kind=c_char), intent(in) :: filename(*) 00060 character(kind=c_char), intent(in) :: read_options(*) 00061 integer(c_int), intent(in) :: num_ghost_layers 00062 end function iMOAB_LoadMesh 00063 00064 integer(c_int) function iMOAB_CreateVertices(pid, coords_len, dim, coordinates) bind(C, name='iMOAB_CreateVertices') 00065 use, intrinsic :: iso_c_binding, only: c_int, c_double 00066 integer(c_int), intent(in) :: pid 00067 integer(c_int), intent(in) :: coords_len 00068 integer(c_int), intent(in) :: dim 00069 real(c_double), intent(in) :: coordinates(*) 00070 end function iMOAB_CreateVertices 00071 00072 integer(c_int) function iMOAB_CreateElements(pid, num_elem, type, num_nodes_per_element, & 00073 connectivity, block_ID) bind(C, name='iMOAB_CreateElements') 00074 use, intrinsic :: iso_c_binding, only: c_int 00075 integer(c_int), intent(in) :: pid 00076 integer(c_int), intent(in) :: num_elem 00077 integer(c_int), intent(in) :: type 00078 integer(c_int), intent(in) :: num_nodes_per_element 00079 integer(c_int), intent(in) :: connectivity(*) 00080 integer(c_int), intent(in) :: block_ID 00081 end function iMOAB_CreateElements 00082 00083 integer(c_int) function iMOAB_ResolveSharedEntities(pid, num_verts, marker) bind(C, name='iMOAB_ResolveSharedEntities') 00084 use, intrinsic :: iso_c_binding, only: c_int 00085 integer(c_int), intent(in) :: pid 00086 integer(c_int), intent(in) :: num_verts 00087 integer(c_int), intent(in) :: marker(*) 00088 end function iMOAB_ResolveSharedEntities 00089 00090 integer(c_int) function iMOAB_DetermineGhostEntities(pid, ghost_dim, num_ghost_layers, bridge_dim) & 00091 bind(C, name='iMOAB_DetermineGhostEntities') 00092 use, intrinsic :: iso_c_binding, only: c_int 00093 integer(c_int), intent(in) :: pid 00094 integer(c_int), intent(in) :: ghost_dim 00095 integer(c_int), intent(in) :: num_ghost_layers 00096 integer(c_int), intent(in) :: bridge_dim 00097 end function iMOAB_DetermineGhostEntities 00098 00099 integer(c_int) function iMOAB_WriteMesh(pid, filename, write_options) bind(C, name='iMOAB_WriteMesh') 00100 use, intrinsic :: iso_c_binding, only: c_int, c_char 00101 integer(c_int), intent(in) :: pid 00102 character(kind=c_char), intent(in) :: filename(*) 00103 character(kind=c_char), intent(in) :: write_options(*) 00104 end function iMOAB_WriteMesh 00105 00106 integer(c_int) function iMOAB_UpdateMeshInfo(pid) bind(C, name='iMOAB_UpdateMeshInfo') 00107 use, intrinsic :: iso_c_binding, only: c_int 00108 integer(c_int), intent(in) :: pid 00109 end function iMOAB_UpdateMeshInfo 00110 00111 integer(c_int) function iMOAB_GetMeshInfo(pid, num_visible_vertices, num_visible_elements, & 00112 num_visible_blocks, num_visible_surfaceBC, & 00113 num_visible_vertexBC) bind(C, name='iMOAB_GetMeshInfo') 00114 use, intrinsic :: iso_c_binding, only: c_int 00115 integer(c_int), intent(in) :: pid 00116 integer(c_int), intent(out) :: num_visible_vertices(3) 00117 integer(c_int), intent(out) :: num_visible_elements(3) 00118 integer(c_int), intent(out) :: num_visible_blocks(3) 00119 integer(c_int), intent(out) :: num_visible_surfaceBC(3) 00120 integer(c_int), intent(out) :: num_visible_vertexBC(3) 00121 end function iMOAB_GetMeshInfo 00122 00123 integer(c_int) function iMOAB_GetVertexID(pid, vertices_length, global_vertex_ID) bind(C, name='iMOAB_GetVertexID') 00124 use, intrinsic :: iso_c_binding, only: c_int 00125 integer(c_int), intent(in) :: pid 00126 integer(c_int), intent(in) :: vertices_length 00127 integer(c_int), intent(out) :: global_vertex_ID(*) 00128 end function iMOAB_GetVertexID 00129 00130 integer(c_int) function iMOAB_GetVertexOwnership(pid, vertices_length, visible_global_rank_ID) & 00131 bind(C, name='iMOAB_GetVertexOwnership') 00132 use, intrinsic :: iso_c_binding, only: c_int 00133 integer(c_int), intent(in) :: pid 00134 integer(c_int), intent(in) :: vertices_length 00135 integer(c_int), intent(out) :: visible_global_rank_ID(*) 00136 end function iMOAB_GetVertexOwnership 00137 00138 integer(c_int) function iMOAB_GetVisibleVerticesCoordinates(pid, coords_length, coordinates) & 00139 bind(C, name='iMOAB_GetVisibleVerticesCoordinates') 00140 use, intrinsic :: iso_c_binding, only: c_int, c_double 00141 integer(c_int), intent(in) :: pid 00142 integer(c_int), intent(in) :: coords_length 00143 real(c_double), intent(out) :: coordinates(*) 00144 end function iMOAB_GetVisibleVerticesCoordinates 00145 00146 integer(c_int) function iMOAB_GetBlockID(pid, block_length, global_block_IDs) bind(C, name='iMOAB_GetBlockID') 00147 use, intrinsic :: iso_c_binding, only: c_int 00148 integer(c_int), intent(in) :: pid 00149 integer(c_int), intent(in) :: block_length 00150 integer(c_int), intent(out) :: global_block_IDs(*) 00151 end function iMOAB_GetBlockID 00152 00153 integer(c_int) function iMOAB_GetBlockInfo(pid, global_block_ID, vertices_per_element, & 00154 num_elements_in_block) bind(C, name='iMOAB_GetBlockInfo') 00155 use, intrinsic :: iso_c_binding, only: c_int 00156 integer(c_int), intent(in) :: pid 00157 integer(c_int), intent(in) :: global_block_ID 00158 integer(c_int), intent(out) :: vertices_per_element 00159 integer(c_int), intent(out) :: num_elements_in_block 00160 end function iMOAB_GetBlockInfo 00161 00162 integer(c_int) function iMOAB_GetVisibleElementsInfo(pid, num_visible_elements, element_global_IDs, & 00163 ranks, block_IDs) bind(C, name='iMOAB_GetVisibleElementsInfo') 00164 use, intrinsic :: iso_c_binding, only: c_int 00165 integer(c_int), intent(in) :: pid 00166 integer(c_int), intent(out) :: num_visible_elements 00167 integer(c_int), intent(out) :: element_global_IDs(*) 00168 integer(c_int), intent(out) :: ranks(*) 00169 integer(c_int), intent(out) :: block_IDs(*) 00170 end function iMOAB_GetVisibleElementsInfo 00171 00172 integer(c_int) function iMOAB_GetBlockElementConnectivities(pid, global_block_ID, connectivity_length, & 00173 element_connectivity) & 00174 bind(C, name='iMOAB_GetBlockElementConnectivities') 00175 use, intrinsic :: iso_c_binding, only: c_int 00176 integer(c_int), intent(in) :: pid 00177 integer(c_int), intent(in) :: global_block_ID 00178 integer(c_int), intent(in) :: connectivity_length 00179 integer(c_int), intent(out) :: element_connectivity(*) 00180 end function iMOAB_GetBlockElementConnectivities 00181 00182 integer(c_int) function iMOAB_GetElementConnectivity(pid, elem_index, connectivity_length, & 00183 element_connectivity) bind(C, name='iMOAB_GetElementConnectivity') 00184 use, intrinsic :: iso_c_binding, only: c_int 00185 integer(c_int), intent(in) :: pid 00186 integer(c_int), intent(in) :: elem_index 00187 integer(c_int), intent(in) :: connectivity_length 00188 integer(c_int), intent(out) :: element_connectivity(*) 00189 end function iMOAB_GetElementConnectivity 00190 00191 integer(c_int) function iMOAB_GetElementOwnership(pid, global_block_ID, num_elements_in_block, & 00192 element_ownership) bind(C, name='iMOAB_GetElementOwnership') 00193 use, intrinsic :: iso_c_binding, only: c_int 00194 integer(c_int), intent(in) :: pid 00195 integer(c_int), intent(in) :: global_block_ID 00196 integer(c_int), intent(out) :: num_elements_in_block 00197 integer(c_int), intent(out) :: element_ownership(*) 00198 end function iMOAB_GetElementOwnership 00199 00200 integer(c_int) function iMOAB_GetElementID(pid, global_block_ID, num_elements_in_block, & 00201 global_element_ID, local_element_ID) bind(C, name='iMOAB_GetElementID') 00202 use, intrinsic :: iso_c_binding, only: c_int 00203 integer(c_int), intent(in) :: pid 00204 integer(c_int), intent(in) :: global_block_ID 00205 integer(c_int), intent(in) :: num_elements_in_block 00206 integer(c_int), intent(in) :: global_element_ID 00207 integer(c_int), intent(out) :: local_element_ID 00208 end function iMOAB_GetElementID 00209 00210 integer(c_int) function iMOAB_GetPointerToSurfaceBC(pid, surface_BC_length, local_element_ID, & 00211 reference_surface_ID, boundary_condition_value) & 00212 bind(C, name='iMOAB_GetPointerToSurfaceBC') 00213 use, intrinsic :: iso_c_binding, only: c_int 00214 integer(c_int), intent(in) :: pid 00215 integer(c_int), intent(in) :: surface_BC_length 00216 integer(c_int), intent(in) :: local_element_ID 00217 integer(c_int), intent(in) :: reference_surface_ID 00218 integer(c_int), intent(out) :: boundary_condition_value 00219 end function iMOAB_GetPointerToSurfaceBC 00220 00221 integer(c_int) function iMOAB_GetPointerToVertexBC(pid, vertex_BC_length, local_vertex_ID, & 00222 boundary_condition_value) bind(C, name='iMOAB_GetPointerToVertexBC') 00223 use, intrinsic :: iso_c_binding, only: c_int 00224 integer(c_int), intent(in) :: pid 00225 integer(c_int), intent(in) :: vertex_BC_length 00226 integer(c_int), intent(in) :: local_vertex_ID 00227 integer(c_int), intent(out) :: boundary_condition_value 00228 end function iMOAB_GetPointerToVertexBC 00229 00230 integer(c_int) function iMOAB_DefineTagStorage(pid, tag_storage_name, tag_type, components_per_entity, & 00231 tag_index) bind(C, name='iMOAB_DefineTagStorage') 00232 use, intrinsic :: iso_c_binding, only: c_int, c_char 00233 integer(c_int), intent(in) :: pid 00234 character(kind=c_char), intent(in) :: tag_storage_name(*) 00235 integer(c_int), intent(in) :: tag_type 00236 integer(c_int), intent(in) :: components_per_entity 00237 integer(c_int), intent(in) :: tag_index 00238 end function iMOAB_DefineTagStorage 00239 00240 integer(c_int) function iMOAB_SetIntTagStorage(pid, tag_storage_name, num_tag_storage_length, entity_type, & 00241 tag_storage_data) bind(C, name='iMOAB_SetIntTagStorage') 00242 use, intrinsic :: iso_c_binding, only: c_int, c_char 00243 integer(c_int), intent(in) :: pid 00244 character(kind=c_char), intent(in) :: tag_storage_name(*) 00245 integer(c_int), intent(in) :: num_tag_storage_length 00246 integer(c_int), intent(in) :: entity_type 00247 integer(c_int), intent(in) :: tag_storage_data(*) 00248 end function iMOAB_SetIntTagStorage 00249 00250 integer(c_int) function iMOAB_GetIntTagStorage(pid, tag_storage_name, num_tag_storage_length, entity_type, & 00251 tag_storage_data) bind(C, name='iMOAB_GetIntTagStorage') 00252 use, intrinsic :: iso_c_binding, only: c_int, c_char 00253 integer(c_int), intent(in) :: pid 00254 character(kind=c_char), intent(in) :: tag_storage_name(*) 00255 integer(c_int), intent(in) :: num_tag_storage_length 00256 integer(c_int), intent(in) :: entity_type 00257 integer(c_int), intent(out) :: tag_storage_data(*) 00258 end function iMOAB_GetIntTagStorage 00259 00260 integer(c_int) function iMOAB_SetDoubleTagStorage(pid, tag_storage_name, num_tag_storage_length, entity_type, & 00261 tag_storage_data) bind(C, name='iMOAB_SetDoubleTagStorage') 00262 use, intrinsic :: iso_c_binding, only: c_int, c_char, c_double 00263 integer(c_int), intent(in) :: pid 00264 character(kind=c_char), intent(in) :: tag_storage_name(*) 00265 integer(c_int), intent(in) :: num_tag_storage_length 00266 integer(c_int), intent(in) :: entity_type 00267 real(c_double), intent(in) :: tag_storage_data(*) 00268 end function iMOAB_SetDoubleTagStorage 00269 00270 integer(c_int) function iMOAB_SetDoubleTagStorageWithGid(pid, tag_storage_name, num_tag_storage_length, entity_type, & 00271 tag_storage_data, globalIds) bind(C, name='iMOAB_SetDoubleTagStorageWithGid') 00272 use, intrinsic :: iso_c_binding, only: c_int, c_char, c_double 00273 integer(c_int), intent(in) :: pid 00274 character(kind=c_char), intent(in) :: tag_storage_name(*) 00275 integer(c_int), intent(in) :: num_tag_storage_length 00276 integer(c_int), intent(in) :: entity_type 00277 real(c_double), intent(in) :: tag_storage_data(*) 00278 integer(c_int), intent(in) :: globalIds(*) 00279 end function iMOAB_SetDoubleTagStorageWithGid 00280 00281 00282 integer(c_int) function iMOAB_GetDoubleTagStorage(pid, tag_storage_name, num_tag_storage_length, entity_type, & 00283 tag_storage_data) bind(C, name='iMOAB_GetDoubleTagStorage') 00284 use, intrinsic :: iso_c_binding, only: c_int, c_char, c_double 00285 integer(c_int), intent(in) :: pid 00286 character(kind=c_char), intent(in) :: tag_storage_name(*) 00287 integer(c_int), intent(in) :: num_tag_storage_length 00288 integer(c_int), intent(in) :: entity_type 00289 real(c_double), intent(out) :: tag_storage_data(*) 00290 end function iMOAB_GetDoubleTagStorage 00291 00292 integer(c_int) function iMOAB_SynchronizeTags(pid, num_tag, tag_indices, entity_type) bind(C, name='iMOAB_SynchronizeTags') 00293 use, intrinsic :: iso_c_binding, only: c_int 00294 integer(c_int), intent(in) :: pid 00295 integer(c_int), intent(in) :: num_tag 00296 integer(c_int), intent(in) :: tag_indices(*) 00297 integer(c_int), intent(in) :: entity_type(*) 00298 end function iMOAB_SynchronizeTags 00299 00300 integer(c_int) function iMOAB_ReduceTagsMax(pid, tag_index, entity_type) bind(C, name='iMOAB_ReduceTagsMax') 00301 use, intrinsic :: iso_c_binding, only: c_int 00302 integer(c_int), intent(in) :: pid 00303 integer(c_int), intent(in) :: tag_index 00304 integer(c_int), intent(in) :: entity_type 00305 end function iMOAB_ReduceTagsMax 00306 00307 integer(c_int) function iMOAB_GetNeighborElements(pid, local_index, num_adjacent_elements, adjacent_element_IDs) & 00308 bind(C, name='iMOAB_GetNeighborElements') 00309 use, intrinsic :: iso_c_binding, only: c_int 00310 integer(c_int), intent(in) :: pid 00311 integer(c_int), intent(in) :: local_index 00312 integer(c_int), intent(out) :: num_adjacent_elements 00313 integer(c_int), intent(out) :: adjacent_element_IDs 00314 end function iMOAB_GetNeighborElements 00315 00316 integer(c_int) function iMOAB_GetNeighborVertices(pid, local_index, num_adjacent_vertices, adjacent_vertex_IDs) & 00317 bind(C, name='iMOAB_GetNeighborVertices') 00318 use, intrinsic :: iso_c_binding, only: c_int 00319 integer(c_int), intent(in) :: pid 00320 integer(c_int), intent(in) :: local_index 00321 integer(c_int), intent(out) :: num_adjacent_vertices 00322 integer(c_int), intent(out) :: adjacent_vertex_IDs 00323 end function iMOAB_GetNeighborVertices 00324 00325 integer(c_int) function iMOAB_SetGlobalInfo(pid, num_global_verts, num_global_elems) bind(C, name='iMOAB_SetGlobalInfo') 00326 use, intrinsic :: iso_c_binding, only: c_int 00327 integer(c_int), intent(in) :: pid 00328 integer(c_int), intent(in) :: num_global_verts 00329 integer(c_int), intent(in) :: num_global_elems 00330 end function iMOAB_SetGlobalInfo 00331 00332 integer(c_int) function iMOAB_GetGlobalInfo(pid, num_global_verts, num_global_elems) bind(C, name='iMOAB_GetGlobalInfo') 00333 use, intrinsic :: iso_c_binding, only: c_int 00334 integer(c_int), intent(in) :: pid 00335 integer(c_int), intent(out) :: num_global_verts 00336 integer(c_int), intent(out) :: num_global_elems 00337 end function iMOAB_GetGlobalInfo 00338 00339 integer(c_int) function iMOAB_WriteLocalMesh(pid, prefix) bind(C, name='iMOAB_WriteLocalMesh') 00340 use, intrinsic :: iso_c_binding, only : c_int, c_char 00341 integer(c_int), intent(in) :: pid 00342 character(kind=c_char), intent(in) :: prefix(*) 00343 end function iMOAB_WriteLocalMesh 00344 00345 #ifdef MOAB_HAVE_MPI 00346 00347 integer(c_int) function iMOAB_SendMesh(pid, joint_comm, receivingGroup, rcompid, method) bind(C, name='iMOAB_SendMesh') 00348 use, intrinsic :: iso_c_binding, only: c_int, c_ptr 00349 integer(c_int), intent(in) :: pid 00350 integer, intent(in) :: joint_comm ! MPI_Comm 00351 integer, intent(in) :: receivingGroup ! MPI_Group 00352 integer(c_int), intent(in) :: rcompid 00353 integer(c_int), intent(in) :: method 00354 end function iMOAB_SendMesh 00355 00356 integer(c_int) function iMOAB_ReceiveMesh(pid, joint_comm, sendingGroup, scompid) bind(C, name='iMOAB_ReceiveMesh') 00357 use, intrinsic :: iso_c_binding, only: c_int, c_ptr 00358 integer(c_int), intent(in) :: pid 00359 integer, intent(in) :: joint_comm ! MPI_Comm 00360 integer, intent(in) :: sendingGroup ! MPI_Group 00361 integer(c_int), intent(in) :: scompid 00362 end function iMOAB_ReceiveMesh 00363 00364 integer(c_int) function iMOAB_FreeSenderBuffers(pid, context_id) bind(C, name='iMOAB_FreeSenderBuffers') 00365 use, intrinsic :: iso_c_binding, only: c_int 00366 integer(c_int), intent(in) :: pid 00367 integer(c_int), intent(in) :: context_id 00368 end function iMOAB_FreeSenderBuffers 00369 00370 integer(c_int) function iMOAB_SendElementTag(pid, tag_storage_name, joint_comm, context_id) & 00371 bind(C, name='iMOAB_SendElementTag') 00372 use, intrinsic :: iso_c_binding, only: c_int, c_char, c_ptr 00373 integer(c_int), intent(in) :: pid 00374 character(kind=c_char), intent(in) :: tag_storage_name(*) 00375 integer, intent(in) :: joint_comm ! MPI_Comm 00376 integer(c_int), intent(in) :: context_id 00377 end function iMOAB_SendElementTag 00378 00379 integer(c_int) function iMOAB_ReceiveElementTag(pid, tag_storage_name, joint_comm, context_id) & 00380 bind(C, name='iMOAB_ReceiveElementTag') 00381 use, intrinsic :: iso_c_binding, only: c_int, c_char, c_ptr 00382 integer(c_int), intent(in) :: pid 00383 character(kind=c_char), intent(in) :: tag_storage_name(*) 00384 integer, intent(in) :: joint_comm ! MPI_Comm 00385 integer(c_int), intent(in) :: context_id 00386 end function iMOAB_ReceiveElementTag 00387 00388 integer(c_int) function iMOAB_ComputeCommGraph(pid1, pid2, joint_comm, group1, group2, type1, type2, & 00389 comp1, comp2) bind(C, name='iMOAB_ComputeCommGraph') 00390 use, intrinsic :: iso_c_binding, only: c_int, c_ptr 00391 integer(c_int), intent(in) :: pid1 00392 integer(c_int), intent(in) :: pid2 00393 integer, intent(in) :: joint_comm ! MPI_Comm 00394 integer, intent(in) :: group1 ! MPI_Group 00395 integer, intent(in) :: group2 ! MPI_Group 00396 integer(c_int), intent(in) :: type1 00397 integer(c_int), intent(in) :: type2 00398 integer(c_int), intent(in) :: comp1 00399 integer(c_int), intent(in) :: comp2 00400 end function iMOAB_ComputeCommGraph 00401 00402 integer(c_int) function iMOAB_CoverageGraph(joint_comm, pid_source, pid_migration, pid_intx, source_id, & 00403 migration_id, context_id) bind(C, name='iMOAB_CoverageGraph') 00404 use, intrinsic :: iso_c_binding, only: c_int, c_ptr 00405 integer, intent(in) :: joint_comm ! MPI_Comm 00406 integer(c_int), intent(in) :: pid_source 00407 integer(c_int), intent(in) :: pid_migration 00408 integer(c_int), intent(in) :: pid_intx 00409 integer(c_int), intent(in) :: source_id 00410 integer(c_int), intent(in) :: migration_id 00411 integer(c_int), intent(in) :: context_id 00412 end function iMOAB_CoverageGraph 00413 00414 integer(c_int) function iMOAB_DumpCommGraph(pid, context_id, is_sender, prefix) bind(C, name='iMOAB_DumpCommGraph') 00415 use, intrinsic :: iso_c_binding, only: c_int, c_char 00416 integer(c_int), intent(in) :: pid 00417 integer(c_int), intent(in) :: context_id 00418 integer(c_int), intent(in) :: is_sender 00419 character(kind=c_char), intent(in) :: prefix(*) 00420 end function iMOAB_DumpCommGraph 00421 00422 integer(c_int) function iMOAB_MergeVertices(pid) bind(C, name='iMOAB_MergeVertices') 00423 use, intrinsic :: iso_c_binding, only: c_int 00424 integer(c_int), intent(in) :: pid 00425 end function iMOAB_MergeVertices 00426 00427 integer(c_int) function iMOAB_MigrateMapMesh( pid1, pid2, pid3, jointcomm, groupA, groupB, type, comp1, comp2, & 00428 direction) bind(C, name='iMOAB_MigrateMapMesh') 00429 use, intrinsic :: iso_c_binding, only : c_int 00430 integer(c_int), intent(in) :: pid1 00431 integer(c_int), intent(in) :: pid2 00432 integer(c_int), intent(in) :: pid3 00433 integer, intent(in) :: jointcomm ! MPI_Comm 00434 integer, intent(in) :: groupA ! MPI_Group 00435 integer, intent(in) :: groupB ! MPI_Group 00436 integer(c_int), intent(in) :: type 00437 integer(c_int), intent(in) :: comp1 00438 integer(c_int), intent(in) :: comp2 00439 integer(c_int), intent(in) :: direction 00440 end function iMOAB_MigrateMapMesh 00441 00442 ! closing endif: MOAB_HAVE_MPI 00443 #endif 00444 00445 #ifdef MOAB_HAVE_TEMPESTREMAP 00446 00447 integer(c_int) function iMOAB_ComputeMeshIntersectionOnSphere(pid_source, pid_target, pid_intersection) & 00448 bind(C, name='iMOAB_ComputeMeshIntersectionOnSphere') 00449 use, intrinsic :: iso_c_binding, only: c_int 00450 integer(c_int), intent(in) :: pid_source 00451 integer(c_int), intent(in) :: pid_target 00452 integer(c_int), intent(in) :: pid_intersection 00453 end function iMOAB_ComputeMeshIntersectionOnSphere 00454 00455 integer(c_int) function iMOAB_ComputePointDoFIntersection(pid_source, pid_target, pid_intersection) & 00456 bind(C, name='iMOAB_ComputePointDoFIntersection') 00457 use, intrinsic :: iso_c_binding, only: c_int 00458 integer(c_int), intent(in) :: pid_source 00459 integer(c_int), intent(in) :: pid_target 00460 integer(c_int), intent(in) :: pid_intersection 00461 end function iMOAB_ComputePointDoFIntersection 00462 00463 #ifdef MOAB_HAVE_NETCDF 00464 00465 integer(c_int) function iMOAB_LoadMappingWeightsFromFile(pid_intersection, pid_cpl, column_or_row, mtype, & 00466 solution_weights_identifier, remap_weights_filename) & 00467 bind(C, name='iMOAB_LoadMappingWeightsFromFile') 00468 use, intrinsic :: iso_c_binding, only : c_int, c_char 00469 integer(c_int), intent(in) :: pid_intersection 00470 integer(c_int), intent(in) :: pid_cpl 00471 integer(c_int), intent(in) :: column_or_row 00472 integer(c_int), intent(in) :: mtype 00473 character(kind=c_char), intent(in) :: solution_weights_identifier(*) 00474 character(kind=c_char), intent(in) :: remap_weights_filename(*) 00475 end function iMOAB_LoadMappingWeightsFromFile 00476 00477 integer(c_int) function iMOAB_WriteMappingWeightsToFile(pid_intersection, solution_weights_identifier, & 00478 remap_weights_filename) bind(C, name='iMOAB_WriteMappingWeightsToFile') 00479 use, intrinsic :: iso_c_binding, only: c_int, c_char 00480 integer(c_int), intent(in) :: pid_intersection 00481 character(kind=c_char), intent(in) :: solution_weights_identifier(*) 00482 character(kind=c_char), intent(in) :: remap_weights_filename(*) 00483 end function iMOAB_WriteMappingWeightsToFile 00484 00485 ! closing endif: MOAB_HAVE_NETCDF 00486 #endif 00487 00488 integer(c_int) function iMOAB_ComputeScalarProjectionWeights(pid_intersection, solution_weights_identifier, & 00489 disc_method_source, disc_order_source, & 00490 disc_method_target, disc_order_target, & 00491 fNoBubble, fMonotoneTypeID, fVolumetric, & 00492 fInverseDistanceMap, fNoConservation, fValidate, & 00493 source_solution_tag_dof_name, target_solution_tag_dof_name) & 00494 bind(C, name='iMOAB_ComputeScalarProjectionWeights') 00495 use, intrinsic :: iso_c_binding, only: c_int, c_char 00496 integer(c_int), intent(in) :: pid_intersection 00497 character(kind=c_char), intent(in) :: solution_weights_identifier(*) 00498 character(kind=c_char), intent(in) :: disc_method_source(*) 00499 integer(c_int), intent(in) :: disc_order_source 00500 character(kind=c_char), intent(in) :: disc_method_target(*) 00501 integer(c_int), intent(in) :: disc_order_target 00502 integer(c_int), intent(in) :: fNoBubble 00503 integer(c_int), intent(in) :: fMonotoneTypeID 00504 integer(c_int), intent(in) :: fVolumetric 00505 integer(c_int), intent(in) :: fInverseDistanceMap 00506 integer(c_int), intent(in) :: fNoConservation 00507 integer(c_int), intent(in) :: fValidate 00508 character(kind=c_char), intent(in) :: source_solution_tag_dof_name(*) 00509 character(kind=c_char), intent(in) :: target_solution_tag_dof_name(*) 00510 end function iMOAB_ComputeScalarProjectionWeights 00511 00512 integer(c_int) function iMOAB_ApplyScalarProjectionWeights(pid_intersection, solution_weights_identifier, & 00513 source_solution_tag_name, target_solution_tag_name) & 00514 bind(C, name='iMOAB_ApplyScalarProjectionWeights') 00515 use, intrinsic :: iso_c_binding, only: c_int, c_char 00516 integer(c_int), intent(in) :: pid_intersection 00517 character(kind=c_char), intent(in) :: solution_weights_identifier(*) 00518 character(kind=c_char), intent(in) :: source_solution_tag_name(*) 00519 character(kind=c_char), intent(in) :: target_solution_tag_name(*) 00520 end function iMOAB_ApplyScalarProjectionWeights 00521 00522 ! closing endif: MOAB_HAVE_TEMPESTREMAP 00523 #endif 00524 00525 #ifdef MOAB_HAVE_MPI 00526 00527 ! Add some helper MPI converter functions 00528 00529 ! Convert a C-based MPI-Comm handle to fortran 00530 integer function iMOAB_MPI_Comm_c2f(c_handle) bind(C, name="MOAB_MPI_Comm_c2f") 00531 use, intrinsic :: iso_c_binding, only: c_ptr 00532 type(c_ptr), value :: c_handle 00533 end function 00534 00535 ! Convert a Fortran-based MPI-integer handle to MPI-Comm pointer 00536 type(c_ptr) function iMOAB_MPI_Comm_f2c(f_handle) bind(C, name="MOAB_MPI_Comm_f2c") 00537 use, intrinsic :: iso_c_binding, only: c_ptr 00538 integer, intent(in) :: f_handle 00539 end function 00540 00541 ! Convert a C-based MPI-Group handle to fortran 00542 integer function iMOAB_MPI_Group_c2f(c_handle) bind(C, name="MOAB_MPI_Group_c2f") 00543 use, intrinsic :: iso_c_binding, only: c_ptr 00544 type(c_ptr), value :: c_handle 00545 end function 00546 00547 ! Convert a Fortran-based MPI-integer handle to MPI-Group pointer 00548 type(c_ptr) function iMOAB_MPI_Group_f2c(f_handle) bind(C, name="MOAB_MPI_Group_f2c") 00549 use, intrinsic :: iso_c_binding, only: c_ptr 00550 integer, intent(in) :: f_handle 00551 end function 00552 00553 #endif 00554 00555 end interface 00556 00557 end module iMOAB
