moab::ReorderTool Class Reference
#include <ReorderTool.hpp>
+ Collaboration diagram for moab::ReorderTool:
Public Member Functions
 ReorderTool (Core *moab)
ErrorCode handle_order_from_int_tag (Tag ordering_tag, int ordering_tag_skip_value, Tag &new_handle_tag_out)
 Calculate new handle order by tag value.
ErrorCode handle_order_from_int_tag (EntityType type, int vals_per_ent, Tag ordering_tag, int ordering_tag_skip_value, Tag new_handle_tag)
ErrorCode handle_order_from_sets_and_adj (const Range &sets, Tag &new_handle_tag_out)
 Calculate new handle order by set containment.
ErrorCode reorder_entities (Tag new_handle_tag)
 Do the re-ordering indicated by the passed handle tag.
Private Member Functions
ErrorCode reorder_tag_data (EntityType type, Tag new_handles, Tag reorder_tag)
 helper function for reorder_entities
ErrorCode update_set_contents (Tag new_handles)
void get_entities (EntityType t, int vals_per_ent, Range &result)
 Get all entities of specified type and size.
ErrorCode get_reordered_handles (Tag tag, const Range &old_handles, std::vector< EntityHandle > &new_handles)
 Get new handles corresponding to old handles.
ErrorCode get_reordered_handles (Tag tag, const std::vector< EntityHandle > &old_handles, std::vector< EntityHandle > &new_handles)
ErrorCode get_reordered_handles (Tag tag, const EntityHandle *old_handles, EntityHandle *new_handles, size_t num_handles)
ErrorCode get_new_handles (Tag tag, Range &old_handles, std::vector< EntityHandle > &newhandles)
 Remove any non-ordered handles and return new handles for remaining.
ErrorCode int_order_from_sets_and_adj (const Range &sets, Tag order_tag, int skip_val, std::vector< std::vector< EntityHandle > * > &data)
 convert from input for handle_order_from_sets_and_adj to input for handle_order_from_int_tag
Private Attributes
Core * mMB
Detailed Description
Definition at line 18 of file ReorderTool.hpp.
moab::ReorderTool::ReorderTool ( Core *  moab) [inline]
Definition at line 21 of file ReorderTool.hpp.
: mMB( moab ) {}
Member Function Documentation
void moab::ReorderTool::get_entities ( EntityType  t,
int  vals_per_ent,
Range &  result
) [private]
Parameters:
tthe type of entity to retreive
vals_per_ententity size (connectivity length for elements, dimension for vertices)
Definition at line 101 of file ReorderTool.cpp.
References moab::TypeSequenceManager::begin(), moab::Range::begin(), moab::TypeSequenceManager::end(), moab::EntitySequence::end_handle(), moab::SequenceManager::entity_map(), moab::Range::insert(), mMB, moab::Core::sequence_manager(), moab::EntitySequence::start_handle(), and moab::EntitySequence::values_per_entity().
Referenced by handle_order_from_int_tag(), and reorder_entities().
    Range::iterator hint = entities.begin();
    TypeSequenceManager& seqs = mMB->sequence_manager()->entity_map( t );
    TypeSequenceManager::iterator s;
    for( s = seqs.begin(); s != seqs.end(); ++s )
        EntitySequence* seq = *s;
        if( seq->values_per_entity() == vals_per_ent )
            hint = entities.insert( hint, seq->start_handle(), seq->end_handle() );
ErrorCode moab::ReorderTool::get_new_handles ( Tag  tag,
Range &  old_handles,
std::vector< EntityHandle > &  newhandles
) [private]
Parameters:
tagTag containing old->new mapping
Definition at line 372 of file ReorderTool.cpp.
References moab::Range::begin(), CHKERR, moab::Range::erase(), ErrorCode, MB_SUCCESS, mMB, moab::Range::size(), and moab::Core::tag_get_data().
Referenced by reorder_tag_data(), and update_set_contents().
    // get new handles for tagged entities
    newhandles.resize( old_handles.size() );
    ErrorCode rval = mMB->tag_get_data( tag, old_handles, ( newhandles.empty() ) ? NULL : &newhandles[0] );CHKERR;
    // remove entities that were not reordered
    Range::iterator i = old_handles.begin();
    size_t w          = 0;
    for( size_t r = 0; r < newhandles.size(); ++r )
        if( 0 != newhandles[r] )
            newhandles[w] = newhandles[r];
            ++w;
            ++i;
        else
            i = old_handles.erase( i );
    newhandles.resize( w );
    assert( newhandles.size() == old_handles.size() );
    return MB_SUCCESS;
ErrorCode moab::ReorderTool::get_reordered_handles ( Tag  tag,
const Range &  old_handles,
std::vector< EntityHandle > &  new_handles
) [private]
Parameters:
Definition at line 336 of file ReorderTool.cpp.
References moab::Range::begin(), CHKERR, moab::Range::end(), ErrorCode, MB_SUCCESS, mMB, moab::Range::size(), and moab::Core::tag_get_data().
Referenced by get_reordered_handles(), reorder_entities(), reorder_tag_data(), and update_set_contents().
    new_handles.resize( old_handles.size() );
    ErrorCode rval = mMB->tag_get_data( tag, old_handles, ( new_handles.empty() ) ? NULL : &new_handles[0] );CHKERR;
    Range::const_iterator it1                 = old_handles.begin();
    std::vector< EntityHandle >::iterator it2 = new_handles.begin();
    for( ; it1 != old_handles.end(); ++it1, ++it2 )
        if( 0 == *it2 ) *it2 = *it1;
    return MB_SUCCESS;
const std::vector< EntityHandle > &  old_handles,
) [private]
Parameters:
Definition at line 351 of file ReorderTool.cpp.
References get_reordered_handles().
    return get_reordered_handles( tag, &old_handles[0], &new_handles[0], old_handles.size() );
const EntityHandle *  old_handles,
EntityHandle *  new_handles,
size_t  num_handles
) [private]
Parameters:
Definition at line 359 of file ReorderTool.cpp.
References CHKERR, ErrorCode, MB_SUCCESS, mMB, and moab::Core::tag_get_data().
    ErrorCode rval = mMB->tag_get_data( tag, old_handles, num_handles, new_handles );CHKERR;
    for( size_t i = 0; i < num_handles; ++i )
        if( 0 == new_handles[i] ) new_handles[i] = old_handles[i];
    return MB_SUCCESS;
ErrorCode moab::ReorderTool::handle_order_from_int_tag ( Tag  ordering_tag,
Tag &  new_handle_tag_out
Given a tag containing integer values, calculate new order for entities in the database (except entity sets) such that all entities with tag value A occur before all entities with tag value B in the handle space where A < B. Ordering will be stable for entities with the same tag value.
Parameters:
ordering_tagSinlge integer tag, where value on each entity determines the new position in the handle ordering. Entities may have duplicate values.
ordering_tag_skip_valueDo not reorder entities with this tag value. This is typically the default value of ordering_tag. Specifying this limits the re-ordering to only those entities for which ordering_tag has been set.
new_handle_tag_outPassed back new tag handle containing the entity mapping. The returned tag will be anonymous. The caller is responsible for releasing the tag. The value of this tag on each handle is the new handle that the entity will will be moved to. The tag value will be zero for entities that were not re-ordered.
Definition at line 59 of file ReorderTool.cpp.
References moab::TypeSequenceManager::begin(), moab::check_tag_type(), CHKERR, moab::TypeSequenceManager::end(), moab::SequenceManager::entity_map(), moab::error(), ErrorCode, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TAG_EXCL, MB_TYPE_HANDLE, MB_TYPE_INTEGER, MBENTITYSET, MBVERTEX, mMB, moab::Core::sequence_manager(), t, moab::Core::tag_delete(), moab::Core::tag_get_handle(), and moab::EntitySequence::values_per_entity().
Referenced by call_reorder(), handle_order_from_sets_and_adj(), and main().
    ErrorCode rval;
    // check that input tag handles are what we expect
    rval = check_tag_type( mMB, tag, MB_TYPE_INTEGER, sizeof( int ) );CHKERR;
    EntityHandle zero = 0;
    rval = mMB->tag_get_handle( 0, 1, MB_TYPE_HANDLE, new_handles, MB_TAG_DENSE | MB_TAG_CREAT | MB_TAG_EXCL, &zero );CHKERR;
    // Can only reorder within same type/connectivity (or vertex/num_coords)
    // groupings.  Call helper function for each such grouping.
    for( EntityType t = MBVERTEX; t < MBENTITYSET; ++t )
        // Get list of all connectivity lengths (or vertex dimensions)
        // that exist for type t.
        TypeSequenceManager::iterator i;
        std::set< int > values;
        for( i = seqs.begin(); i != seqs.end(); ++i )
            EntitySequence* seq = *i;
            // 0 values per entity implies structured data, which
            // we cannot reorder.  Skip those.
            if( t == MBVERTEX || 0 < seq->values_per_entity() ) values.insert( seq->values_per_entity() );
        // Call helper function for each (type,size) tuple.
        std::set< int >::iterator j;
        for( j = values.begin(); j != values.end(); ++j )
            rval = handle_order_from_int_tag( t, *j, tag, skip_value, new_handles );
            if( MB_SUCCESS != rval )
                mMB->tag_delete( new_handles );
                return error( rval );
    return MB_SUCCESS;
ErrorCode moab::ReorderTool::handle_order_from_int_tag ( EntityType  type,
int  vals_per_ent,
Tag  ordering_tag,
Tag  new_handle_tag
Parameters:
typeEntity type for which to calculate re-ordering.
vals_per_entZero for vertices. Connectivity length for elements.
new_handle_tagTag into which to store new handle for each entity. Tag must be defined to store a single entity handle and must have a default value of zero.
Definition at line 115 of file ReorderTool.cpp.
References moab::Range::begin(), moab::check_tag_type(), CHKERR, moab::Range::end(), entities, moab::Range::erase(), ErrorCode, get_entities(), MB_SUCCESS, MB_TYPE_HANDLE, MB_TYPE_INTEGER, mMB, moab::Range::size(), moab::Core::tag_get_data(), and moab::Core::tag_set_data().
    ErrorCode rval;
    rval = check_tag_type( mMB, new_handles, MB_TYPE_HANDLE, sizeof( EntityHandle ) );CHKERR;
    // get entities to re-order
    Range entities;
    get_entities( t, vals_per_ent, entities );
    // get entity order values
    std::vector< int > sortvals( entities.size() );
    rval = mMB->tag_get_data( tag, entities, &sortvals[0] );CHKERR;
    // remove any entities for which value is skip_value
    size_t r = 0, w = 0;
    for( Range::iterator i = entities.begin(); i != entities.end(); ++r )
        if( sortvals[r] == skip_value )
            i = entities.erase( i );
        else
            sortvals[w++] = sortvals[r];
            ++i;
    sortvals.resize( w );
    // sort
    std::sort( sortvals.begin(), sortvals.end() );
    // Convert to unique list and offsets for each value
    // When done, sortvals will contain unique, sortvals and
    // offsets will contain, for each unique value in sortvals,
    // the number of values that occured in the non-unique list
    // before the first instance of that value.
    std::vector< size_t > offsets;
    offsets.push_back( 0 );
    offsets.push_back( 1 );
    for( w = 0, r = 1; r < sortvals.size(); ++r )
        if( sortvals[r] == sortvals[w] )
            ++offsets.back();
        else
            ++w;
            sortvals[w] = sortvals[r];
            offsets.push_back( offsets.back() + 1 );
    ++w;
    assert( w + 1 == offsets.size() );
    // Tag each entity with its new handle
    for( Range::iterator i = entities.begin(); i != entities.end(); ++i )
        int val;
        rval = mMB->tag_get_data( tag, &*i, 1, &val );CHKERR;
        w = std::lower_bound( sortvals.begin(), sortvals.end(), val ) - sortvals.begin();
        assert( w < sortvals.size() );
        size_t offset = offsets[w];
        ++offsets[w];
        // should maybe copy range into array to avoid possibly n^2 behavior here
        EntityHandle h = *( entities.begin() + offset );
        rval           = mMB->tag_set_data( new_handles, &*i, 1, &h );CHKERR;
    return MB_SUCCESS;
ErrorCode moab::ReorderTool::handle_order_from_sets_and_adj ( const Range &  sets,
Given a list of sets, re-order entities such that handles are grouped contiguously by set. Will also group all adjacent mesh entities, such that entities that are are adjacent to members of two or more of the input sets will ge grouped by the combined list of sets (e.g. if the input sets contain elements then all vertices that are adjacent to only elements in the first two sets will be grouped together).
Parameters:
setsEntity sets by which to group entities.
Definition at line 193 of file ReorderTool.cpp.
References moab::Range::all_of_type(), moab::error(), ErrorCode, handle_order_from_int_tag(), int_order_from_sets_and_adj(), MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TAG_EXCL, MB_TYPE_INTEGER, MB_TYPE_OUT_OF_RANGE, MBENTITYSET, mMB, order_tag, moab::Core::tag_delete(), and moab::Core::tag_get_handle().
Referenced by check_order_by_sets_and_adj(), and main().
    ErrorCode rval;
    if( !sets.all_of_type( MBENTITYSET ) ) return MB_TYPE_OUT_OF_RANGE;
    Tag order_tag;
    const int negone = -1;
    rval = mMB->tag_get_handle( 0, 1, MB_TYPE_INTEGER, order_tag, MB_TAG_DENSE | MB_TAG_CREAT | MB_TAG_EXCL, &negone );
        mMB->tag_delete( handle_tag );
        handle_tag = 0;
    std::vector< std::vector< EntityHandle >* > data;
    rval = int_order_from_sets_and_adj( sets, order_tag, negone, data );
    for( size_t i = 0; i < data.size(); ++i )
        delete data[i];
        mMB->tag_delete( order_tag );
    rval = handle_order_from_int_tag( order_tag, negone, handle_tag );
    rval = mMB->tag_delete( order_tag );
    if( MB_SUCCESS != rval ) return error( rval );
    return MB_SUCCESS;
ErrorCode moab::ReorderTool::int_order_from_sets_and_adj ( const Range &  sets,
Tag  order_tag,
int  skip_val,
std::vector< std::vector< EntityHandle > * > &  data
) [private]
Definition at line 249 of file ReorderTool.cpp.
References moab::Range::all_of_type(), moab::Range::begin(), moab::check_tag_type(), CHKERR, moab::Range::clear(), dim, moab::Range::end(), ErrorCode, moab::Core::get_adjacencies(), moab::Core::get_entities_by_dimension(), MB_SUCCESS, MB_TYPE_INTEGER, MB_TYPE_OUT_OF_RANGE, MBENTITYSET, moab::Range::merge(), mMB, moab::Core::tag_get_data(), moab::Core::tag_set_data(), and moab::Interface::UNION.
Referenced by handle_order_from_sets_and_adj().
    ErrorCode rval;
    rval = check_tag_type( mMB, order_tag, MB_TYPE_INTEGER, sizeof( int ) );CHKERR;
    // Compare function to use for a map keyed on pointers to sorted vectors
    CompSortedVect lessthan;
    // Map from sorted list of handles to index
    std::map< std::vector< EntityHandle >*, int, CompSortedVect > forMap;
    std::map< std::vector< EntityHandle >*, int, CompSortedVect >::iterator fiter, fiter2;
    std::vector< EntityHandle > sharing;  // tmp storage for entity
    // for each set
    for( Range::iterator s = sets.begin(); s != sets.end(); ++s )
        // gather up all entities and adjacencies
        Range tmp, ents, adj[4];  // indexed by dimension
        for( int dim = 0; dim < 4; ++dim )
            rval = mMB->get_entities_by_dimension( *s, dim, tmp );CHKERR;
            for( int ldim = 0; ldim < dim; ++ldim )
                rval = mMB->get_adjacencies( tmp, ldim, false, adj[ldim], Interface::UNION );CHKERR;
            for( int udim = dim + 1; udim <= 3; ++udim )
                rval = mMB->get_adjacencies( tmp, udim, false, adj[udim], Interface::UNION );CHKERR;
            ents.merge( tmp );
            tmp.clear();
            ents.merge( adj[dim] );
            adj[dim].clear();
        // process each entity
        for( Range::iterator e = ents.begin(); e != ents.end(); ++e )
            int val;
            rval = mMB->tag_get_data( order_tag, &*e, 1, &val );CHKERR;
            // If this entity is already in one or more of the sets (either
            // directly or through adjacency) then get the existing list of
            // sets and append this set handle (we are iterating over sets
            // in sorted order, so appending should aways maintain a sorted
            // list.)
            sharing.clear();
            if( val != skip_val )
                sharing = *revMap[val];
                assert( std::lower_bound( sharing.begin(), sharing.end(), *s ) == sharing.end() );
            sharing.push_back( *s );
            // Check if new sharing list already exists in forward map
            fiter = forMap.lower_bound( &sharing );
            if( fiter == forMap.end() || lessthan( fiter->first, &sharing ) )
                // Add new sharing list to forward and reverse maps.
                std::vector< EntityHandle >* newvec = new std::vector< EntityHandle >;
                newvec->swap( sharing );
                if( (int)revMap.size() == skip_val ) revMap.push_back( 0 );
                fiter2 =
                    forMap.insert( fiter, std::pair< std::vector< EntityHandle >*, int >( newvec, revMap.size() ) );
                assert( fiter2 != fiter );
                fiter = fiter2;
                revMap.push_back( newvec );
            // Update index on entity
            val  = fiter->second;
            rval = mMB->tag_set_data( order_tag, &*e, 1, &val );CHKERR;
    return MB_SUCCESS;
The specified re-ordering must be a permutation. Each existing entity must be moved to a new, existing handle such that no two entities are moved to the same new handle.
Given a tag storing handles that define a permution, apply the described re-ordering. The passed tag must contain one entity handle per entity. The value of the tag must be zero for all entities that are not to be re-ordered. For entities to be re-ordered, the tag must contain the new handle that the entity is to be moved to. No two entities may have the same value for this tag (other than a value of zero.)
Parameters:
new_handle_tagTag containing new handles for entities to reorder. Typically the output of handle_order_from_int_tag or similar.
Definition at line 399 of file ReorderTool.cpp.
References moab::TypeSequenceManager::begin(), moab::Range::begin(), moab::check_tag_type(), CHKERR, moab::TypeSequenceManager::end(), moab::Range::end(), entities, moab::SequenceManager::entity_map(), moab::error(), ErrorCode, moab::Core::get_connectivity(), moab::Core::get_coords(), get_entities(), get_reordered_handles(), MB_INDEX_OUT_OF_RANGE, MB_SUCCESS, MB_TYPE_HANDLE, MBENTITYSET, MBVERTEX, mMB, reorder_tag_data(), moab::Core::sequence_manager(), moab::Core::set_connectivity(), moab::Core::set_coords(), moab::Range::size(), t, moab::Core::tag_get_default_value(), moab::Core::tag_get_tags(), UNRECOVERABLE, update_set_contents(), and moab::EntitySequence::values_per_entity().
Referenced by call_reorder(), and main().
    ErrorCode rval;
    EntityHandle defval;
    rval = mMB->tag_get_default_value( new_handles, &defval );CHKERR;
    if( 0 != defval ) return error( MB_INDEX_OUT_OF_RANGE );
    // groupings.
        // reorder primary data for each (type,size) tuple.
            Range entities;
            get_entities( t, *j, entities );
            std::vector< EntityHandle > handles;
            rval = get_reordered_handles( new_handles, entities, handles );
            UNRECOVERABLE( rval );
            if( t == MBVERTEX )
                std::vector< double > coords( entities.size() * 3 );
                rval = mMB->get_coords( entities, &coords[0] );
                rval = mMB->set_coords( &handles[0], handles.size(), &coords[0] );
            else
                std::vector< EntityHandle > conn;
                conn.reserve( entities.size() * *j );
                std::vector< EntityHandle > old_handles;
                old_handles.resize( entities.size() );
                std::copy( entities.begin(), entities.end(), old_handles.begin() );
                rval = mMB->get_connectivity( &old_handles[0], old_handles.size(), conn, false );
                old_handles.clear();
                old_handles = conn;
                rval        = get_reordered_handles( new_handles, old_handles, conn );
                for( unsigned int h = 0; h < handles.size(); ++h )
                    rval = mMB->set_connectivity( handles[h], &conn[h * *j], *j );
    // now update tag data
    std::vector< Tag > tag_handles;
    mMB->tag_get_tags( tag_handles );
    for( size_t i = 0; i < tag_handles.size(); ++i )
        Tag tag = tag_handles[i];
        if( tag == new_handles )  // don't mess up mapping from old to new handles
            continue;
        for( EntityType t = MBVERTEX; t <= MBENTITYSET; ++t )
            rval = reorder_tag_data( t, new_handles, tag );
    rval = update_set_contents( new_handles );
    return MB_SUCCESS;
ErrorCode moab::ReorderTool::reorder_tag_data ( EntityType  type,
Tag  new_handles,
Tag  reorder_tag
) [private]
Reorder tag data for all entities of specified type.
Also updates tag values for MB_TYPE_HANDLE tags.
Parameters:
typeEntity type to reorder
new_handlesTag containing old->new handle mapping
reorder_tagThe tag data to reorder
Definition at line 487 of file ReorderTool.cpp.
References moab::Range::begin(), buffer, CHKERR, moab::Range::empty(), moab::Range::end(), moab::Range::erase(), moab::error(), ErrorCode, moab::Core::get_entities_by_type_and_tag(), get_new_handles(), get_reordered_handles(), MB_SUCCESS, MB_TYPE_BIT, MB_TYPE_DOUBLE, MB_TYPE_HANDLE, MB_TYPE_INTEGER, MB_TYPE_OPAQUE, MB_TYPE_OUT_OF_RANGE, MB_VARIABLE_DATA_LENGTH, MBENTITYSET, mMB, moab::Range::size(), sizes, moab::Core::tag_delete_data(), moab::Core::tag_get_by_ptr(), moab::Core::tag_get_bytes(), moab::Core::tag_get_data(), moab::Core::tag_get_data_type(), moab::Core::tag_set_by_ptr(), and moab::Core::tag_set_data().
Referenced by reorder_entities().
    ErrorCode rval;
    int tagsize;
    DataType tagtype;
    rval = mMB->tag_get_data_type( tag, tagtype );
    if( MB_TYPE_BIT == tagtype )
        tagsize = 1;
    else
        rval = mMB->tag_get_bytes( tag, tagsize );
        if( MB_VARIABLE_DATA_LENGTH == rval )
            tagsize = -1;
        else if( MB_SUCCESS != rval )
    // we don't re-order set handles, so we don't care about sets
    // unless the tag contains handles that need to be updated
    if( MBENTITYSET == etype && MB_TYPE_HANDLE != tagtype ) return MB_SUCCESS;
    // get tagged entities
    Range old_tagged;
    rval = mMB->get_entities_by_type_and_tag( 0, etype, &tag, 0, 1, old_tagged );
    if( MB_SUCCESS != rval && old_tagged.empty() ) return error( rval );
    // remove entities that were not reordered, unless the tag
    // is handle type in which case we need to update the data
    // for all entities, regardless of reordering.
    std::vector< EntityHandle > newhandles;
    if( MB_TYPE_HANDLE == tagtype )
        rval = get_reordered_handles( new_handles, old_tagged, newhandles );
    else
        rval = get_new_handles( new_handles, old_tagged, newhandles );CHKERR;
    if( old_tagged.empty() ) return MB_SUCCESS;
    // get copy of all tag data
    std::vector< unsigned char > buffer;
    std::vector< const void* > pointers;
    std::vector< int > sizes;
    // if variable-length tag
    if( -1 == tagsize )
        pointers.resize( old_tagged.size() );
        sizes.resize( pointers.size() );
        rval = mMB->tag_get_by_ptr( tag, old_tagged, &pointers[0], &sizes[0] );CHKERR;
        int total = std::accumulate( sizes.begin(), sizes.end(), 0 );
        DataType dtype;
        mMB->tag_get_data_type( tag, dtype );
        int type_size;
        switch( dtype )
            case MB_TYPE_INTEGER:
                type_size = sizeof( int );
                break;
            case MB_TYPE_DOUBLE:
                type_size = sizeof( double );
                break;
            case MB_TYPE_HANDLE:
                type_size = sizeof( EntityHandle );
                break;
            case MB_TYPE_BIT:
                type_size = 1;
                break;
            case MB_TYPE_OPAQUE:
                type_size = 1;
                break;
            default:
        buffer.resize( total * type_size );
        size_t off = 0;
        for( size_t j = 0; j < pointers.size(); ++j )
            memcpy( &buffer[off], pointers[j], type_size * sizes[j] );
            pointers[j] = &buffer[off];
            off += sizes[j] * type_size;
    // if fixed-length tag
    else
        buffer.resize( old_tagged.size() * tagsize );
        rval = mMB->tag_get_data( tag, old_tagged, &buffer[0] );CHKERR;
    // if handle tag, update tag values for reordered handles
        assert( !( buffer.size() % sizeof( EntityHandle ) ) );
        std::vector< unsigned char > buffer2( buffer.size() );
        rval = get_reordered_handles( new_handles, reinterpret_cast< const EntityHandle* >( &buffer[0] ),
                                      reinterpret_cast< EntityHandle* >( &buffer2[0] ),
                                      buffer.size() / sizeof( EntityHandle ) );CHKERR;
        // if var-length tag then do not do swap because pointers[] contains pointers
        // into old buffer
        if( -1 == tagsize )
            memcpy( &buffer[0], &buffer2[0], buffer.size() );
        else
            buffer.swap( buffer2 );
    // store re-ordered tag data
    if( -1 == tagsize )
        rval = mMB->tag_set_by_ptr( tag, &newhandles[0], newhandles.size(), &pointers[0], &sizes[0] );
        pointers.clear();
        sizes.clear();
        buffer.clear();
    else
        rval = mMB->tag_set_data( tag, &newhandles[0], newhandles.size(), &buffer[0] );
        buffer.clear();
    CHKERR;
    // all permutations should be cyclical, but not all permuted
    // entities necessarily had tag values, so we might need to delete
    // tags for some entities
    std::sort( newhandles.begin(), newhandles.end() );
    std::vector< EntityHandle >::iterator k = newhandles.begin();
    Range::iterator i                       = old_tagged.begin();
    while( i != old_tagged.end() )
        while( k != newhandles.end() && *k < *i )
            ++k;
        if( k == newhandles.end() ) break;
        if( *i == *k )  // what old_tagged -= newhandles
            i = old_tagged.erase( i );
        else
            ++i;
    if( !old_tagged.empty() )
        rval = mMB->tag_delete_data( tag, old_tagged );CHKERR;
    return MB_SUCCESS;
Update set contents for changed handles.
Parameters:
Definition at line 633 of file ReorderTool.cpp.
References moab::Core::add_entities(), moab::Range::begin(), CHKERR, moab::Core::clear_meshset(), moab::Range::empty(), moab::Range::end(), ErrorCode, moab::Core::get_entities_by_handle(), moab::Core::get_entities_by_type(), moab::Core::get_meshset_options(), get_new_handles(), get_reordered_handles(), moab::Range::insert(), moab::intersect(), MB_SUCCESS, MBENTITYSET, mMB, moab::Core::remove_entities(), and moab::Range::size().
    Range sets;
    ErrorCode rval = mMB->get_entities_by_type( 0, MBENTITYSET, sets );CHKERR;
    std::vector< EntityHandle > old_handles, new_handles;
    for( Range::iterator i = sets.begin(); i != sets.end(); ++i )
        // If set is un-ordered...
        unsigned opts = 0;
        mMB->get_meshset_options( *i, opts );
        if( !( opts & MESHSET_ORDERED ) )
            Range contents;
            rval = mMB->get_entities_by_handle( *i, contents );CHKERR;
            rval = get_new_handles( nh_tag, contents, new_handles );CHKERR;
            Range replace;
            std::sort( new_handles.begin(), new_handles.end() );
            Range::iterator hint = replace.begin();
            for( size_t j = 0; j < new_handles.size(); ++j )
                hint = replace.insert( hint, new_handles[j] );
            Range common = intersect( contents, replace );
            contents -= common;
            replace -= common;
            assert( contents.size() == replace.size() );
            if( !contents.empty() )
                rval = mMB->remove_entities( *i, contents );CHKERR;
                rval = mMB->add_entities( *i, replace );
        // If set is ordered...
        else
            // get set contents
            rval = mMB->get_entities_by_handle( *i, old_handles );CHKERR;
            // get new handles from old contained handles
            rval = get_reordered_handles( nh_tag, old_handles, new_handles );CHKERR;
            rval = mMB->clear_meshset( &*i, 1 );CHKERR;
            rval = mMB->add_entities( *i, &new_handles[0], new_handles.size() );CHKERR;
    }  // for each set
    return MB_SUCCESS;
Member Data Documentation
List of all members.
