moab::element_utility::Linear_hex_map Class Reference
#include <linear_hex_map.hpp>
+ Inheritance diagram for moab::element_utility::Linear_hex_map:
Public Member Functions
 Linear_hex_map ()
 Linear_hex_map (const Linear_hex_map &)
template<typename Moab , typename Entity_handle , typename Points , typename Point >
std::pair< bool, CartVect > evaluate_reverse (const double *verts, const double *eval_point, const double tol=1.e-6) const
Private Member Functions
const CartVect & reference_points (const std::size_t &i) const
bool is_contained (const CartVect &params, const double tol) const
bool solve_inverse (const CartVect &point, CartVect &params, const CartVect *verts, const double tol=1.e-6) const
void evaluate_forward (const CartVect &p, const CartVect *verts, CartVect &f) const
double integrate_scalar_field (const CartVect *points, const double *field_values) const
template<typename Point , typename Points >
Matrix3 & jacobian (const Point &p, const Points &points, Matrix3 &J) const
Detailed Description
Definition at line 16 of file linear_hex_map.hpp.
Definition at line 22 of file linear_hex_map.hpp.
Member Function Documentation
void moab::element_utility::Linear_hex_map::evaluate_forward ( const CartVect &  p,
const CartVect *  verts,
CartVect &  f
) const [inline, private]
Definition at line 107 of file linear_hex_map.hpp.
Referenced by moab::element_utility::Linear_hex_map< moab::Matrix3 >::solve_inverse().
            typedef typename Points::value_type Vector;
            f.set( 0.0, 0.0, 0.0 );
            for( unsigned i = 0; i < 8; ++i )
                const double N_i = ( 1 + p[0] * reference_points( i )[0] ) * ( 1 + p[1] * reference_points( i )[1] ) *
                                   ( 1 + p[2] * reference_points( i )[2] );
                f += N_i * verts[i];
            f *= 0.125;
            return f;
std::pair< bool, CartVect > moab::element_utility::Linear_hex_map::evaluate_reverse ( const double *  verts,
const double *  eval_point,
const double  tol = 1.e-6
) const [inline]
Definition at line 27 of file linear_hex_map.hpp.
            CartVect params( 3, 0.0 );
            solve_inverse( eval_point, params, verts );
            bool point_found = solve_inverse( eval_point, params, verts, tol ) && is_contained( params, tol );
            return std::make_pair( point_found, params );
double moab::element_utility::Linear_hex_map::integrate_scalar_field ( const CartVect *  points,
const double *  field_values
Definition at line 121 of file linear_hex_map.hpp.
bool moab::element_utility::Linear_hex_map::is_contained ( const CartVect &  params,
const double  tol
Definition at line 49 of file linear_hex_map.hpp.
Referenced by moab::element_utility::Linear_hex_map< moab::Matrix3 >::evaluate_reverse().
            // just look at the box+tol here
            return ( params[0] >= -1. - tol ) && ( params[0] <= 1. + tol ) && ( params[1] >= -1. - tol ) &&
                   ( params[1] <= 1. + tol ) && ( params[2] >= -1. - tol ) && ( params[2] <= 1. + tol );
Matrix3& moab::element_utility::Linear_hex_map::jacobian ( const Point &  p,
const Points &  points,
Matrix3 &  J
const CartVect& moab::element_utility::Linear_hex_map::reference_points ( const std::size_t &  i) const [inline, private]
Definition at line 41 of file linear_hex_map.hpp.
Referenced by moab::element_utility::Linear_hex_map< moab::Matrix3 >::evaluate_forward().
            const CartVect rpts[8] = { CartVect( -1, -1, -1 ), CartVect( 1, -1, -1 ), CartVect( 1, 1, -1 ),
                                       CartVect( -1, 1, -1 ),  CartVect( -1, -1, 1 ), CartVect( 1, -1, 1 ),
                                       CartVect( 1, 1, 1 ),    CartVect( -1, 1, 1 ) };
            return rpts[i];
bool moab::element_utility::Linear_hex_map::solve_inverse ( const CartVect &  point,
CartVect &  params,
Definition at line 56 of file linear_hex_map.hpp.
            const double error_tol_sqr = tol * tol;
            CartVect delta( 0.0, 0.0, 0.0 );
            params = delta;
            evaluate_forward( params, verts, delta );
            delta -= point;
            std::size_t num_iterations = 0;
#ifdef LINEAR_HEX_DEBUG
            std::stringstream ss;
            ss << "CartVect: ";
            ss << point[0] << ", " << point[1] << ", " << point[2] << std::endl;
            ss << "Hex: ";
            for( int i = 0; i < 8; ++i )
                ss << points[i][0] << ", " << points[i][1] << ", " << points[i][2] << std::endl;
            ss << std::endl;
#endif
            while( delta.length_squared() > error_tol_sqr )
                ss << "Iter #: " << num_iterations << " Err: " << delta.length() << " Iterate: ";
                ss << params[0] << ", " << params[1] << ", " << params[2] << std::endl;
#endif
                if( ++num_iterations >= 5 )
                    return false;
                Matrix3 J;
                jacobian( params, verts, J );
                double det = moab::Matrix3::determinant3( J );
                if( fabs( det ) < 1.e-10 )
                    std::cerr << ss.str();
#endif
#ifndef LINEAR_HEX_DEBUG
                    std::cerr << x[0] << ", " << x[1] << ", " << x[2] << std::endl;
#endif
                    std::cerr << "inverse solve failure: det: " << det << std::endl;
                    exit( -1 );
                params -= moab::Matrix3::inverse( J, 1.0 / det ) * delta;
                evaluate_forward( params, points, delta );
                delta -= x;
            return true;
List of all members.
