MOAB: Mesh Oriented datABase
(version 5.4.1)
#include <iMesh_MOAB.hpp>
Public Member Functions | |
| iMeshArrayManager (iMesh_Instance instance, void **array_ptr, int &array_allocated_space, int &array_size, int count, int val_size, int *err) | |
| ~iMeshArrayManager () | |
| void | keep_array () |
Private Attributes | |
| void ** | arrayPtr |
Definition at line 117 of file iMesh_MOAB.hpp.
| iMeshArrayManager::iMeshArrayManager | ( | iMesh_Instance | instance, |
| void ** | array_ptr, | ||
| int & | array_allocated_space, | ||
| int & | array_size, | ||
| int | count, | ||
| int | val_size, | ||
| int * | err | ||
| ) | [inline] |
Definition at line 122 of file iMesh_MOAB.hpp.
References ERROR, iBase_BAD_ARRAY_SIZE, iBase_MEMORY_ALLOCATION_FAILED, iBase_SUCCESS, and RETURN.
: arrayPtr( 0 ) { if( !array_allocated_space || !*array_ptr ) { *array_ptr = std::malloc( val_size * count ); array_allocated_space = array_size = count; if( !*array_ptr ) { ERROR( iBase_MEMORY_ALLOCATION_FAILED, "Couldn't allocate array." ); } arrayPtr = array_ptr; } else { array_size = count; if( array_allocated_space < count ) { ERROR( iBase_BAD_ARRAY_SIZE, "Allocated array not large enough to hold returned contents." ); } } RETURN( iBase_SUCCESS ); }
| iMeshArrayManager::~iMeshArrayManager | ( | ) | [inline] |
Definition at line 152 of file iMesh_MOAB.hpp.
| void iMeshArrayManager::keep_array | ( | ) | [inline] |
Definition at line 161 of file iMesh_MOAB.hpp.
arrayPtr = 0;
void** iMeshArrayManager::arrayPtr [private] |
Definition at line 119 of file iMesh_MOAB.hpp.
