MOAB: Mesh Oriented datABase
(version 5.4.1)
#include <VtkUtil.hpp>
Collaboration diagram for moab::VtkUtil:Static Public Member Functions | |
| static const VtkElemType * | get_vtk_type (EntityType type, unsigned num_nodes) |
Static Public Attributes | |
| static const char * | vtkTypeNames [] |
| vtk data type names, indexed by DataType | |
| static const VtkElemType | vtkElemTypes [] |
| static const unsigned | numVtkElemType = sizeof( VtkUtil::vtkElemTypes ) / sizeof( VtkUtil::vtkElemTypes[0] ) |
| Lenght of vtkElemTypes. | |
General data about VTK files for use by read and write code.
Definition at line 43 of file VtkUtil.hpp.
| const VtkElemType * moab::VtkUtil::get_vtk_type | ( | EntityType | type, |
| unsigned | num_nodes | ||
| ) | [static] |
Get the VTK type corresponding to a tuple of the MOAB type and number of nodes. num_nodes is ignored for MBPOLYGON type.
Definition at line 125 of file VtkUtil.cpp.
References moab::mb_to_vtk_type, MBPOLYGON, MBPOLYHEDRON, and vtkElemTypes.
Referenced by moab::WriteVtk::gather_mesh(), and moab::WriteVtk::write_elems().
const int i = mb_to_vtk_type[type][0]; // Index for linear type
const int j = mb_to_vtk_type[type][1]; // Index for quadratic type
const int k = mb_to_vtk_type[type][2]; // Index for full quadratic type
if( i ) // If element type is supported at all (if not linear then not quadratic either)
// If the linear type is requested (all polygons are linear
// irrespective of the number of nodes), return that.
if( type == MBPOLYGON || type == MBPOLYHEDRON || vtkElemTypes[i].num_nodes == num_nodes )
return vtkElemTypes + i;
// Otherwise if there is a quadratic type and the number of
// nodes specified corresponds to the quadratic type, return that.
else if( j && vtkElemTypes[j].num_nodes == num_nodes )
return vtkElemTypes + j;
// Otherwise if there is a full quadratic type and the number of
else if( k && vtkElemTypes[k].num_nodes == num_nodes )
return vtkElemTypes + k;
return 0;
const unsigned moab::VtkUtil::numVtkElemType = sizeof( VtkUtil::vtkElemTypes ) / sizeof( VtkUtil::vtkElemTypes[0] ) [static] |
Definition at line 55 of file VtkUtil.hpp.
Referenced by moab::ReadVtk::vtk_read_unstructured_grid().
const VtkElemType moab::VtkUtil::vtkElemTypes [static] |
Vtk types, indexed by VTK type number. For unused VTK type numbers, mb_type will be MBMAXTYPE.
Definition at line 52 of file VtkUtil.hpp.
Referenced by get_vtk_type(), and moab::ReadVtk::vtk_read_unstructured_grid().
const char * moab::VtkUtil::vtkTypeNames [static] |
"unsigned_char",
"int",
"double",
"bit",
"unsigned_long",
Definition at line 48 of file VtkUtil.hpp.
Referenced by moab::WriteVtk::write_tag().
