MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 /** 00017 * \class ReadVtk 00018 * \brief VTK reader from Mesquite 00019 * \author Jason Kraftcheck 00020 */ 00021 00022 #include <cassert> 00023 #include <cstdlib> 00024 #include <cstring> 00025 00026 #include "ReadVtk.hpp" 00027 #include "moab/Range.hpp" 00028 #include "Internals.hpp" 00029 #include "moab/Interface.hpp" 00030 #include "moab/ReadUtilIface.hpp" 00031 #include "moab/FileOptions.hpp" 00032 #include "FileTokenizer.hpp" 00033 #include "moab/VtkUtil.hpp" 00034 #include "MBTagConventions.hpp" 00035 00036 // #define MB_VTK_MATERIAL_SETS 00037 #ifdef MB_VTK_MATERIAL_SETS 00038 #include <map> 00039 #endif 00040 00041 namespace moab 00042 { 00043 00044 #ifdef MB_VTK_MATERIAL_SETS 00045 00046 class Hash 00047 { 00048 public: 00049 unsigned long value; 00050 00051 Hash() 00052 { 00053 this->value = 5381L; 00054 } 00055 00056 Hash( const unsigned char* bytes, size_t len ) 00057 { // djb2, a hash by dan bernstein presented on comp.lang.c for hashing strings. 00058 this->value = 5381L; 00059 for( ; len; --len, ++bytes ) 00060 this->value = this->value * 33 + ( *bytes ); 00061 } 00062 00063 Hash( bool duh ) 00064 { 00065 this->value = duh; // Hashing a single bit with a long is stupid but easy. 00066 } 00067 00068 Hash( const Hash& src ) 00069 { 00070 this->value = src.value; 00071 } 00072 00073 Hash& operator=( const Hash& src ) 00074 { 00075 this->value = src.value; 00076 return *this; 00077 } 00078 00079 bool operator<( const Hash& other ) const 00080 { 00081 return this->value < other.value; 00082 } 00083 }; 00084 00085 // Pass this class opaque data + a handle and it adds the handle to a set 00086 // whose opaque data has the same hash. If no set exists for the hash, 00087 // it creates one. Each set is tagged with the opaque data. 00088 // When entities with different opaque data have the same hash, they 00089 // will be placed into the same set. 00090 // There will be no collisions when the opaque data is shorter than an 00091 // unsigned long, and this is really the only case we need to support. 00092 // The rest is bonus. Hash does quite well with strings, even those 00093 // with identical prefixes. 00094 class Modulator : public std::map< Hash, EntityHandle > 00095 { 00096 public: 00097 Modulator( Interface* iface ) : mesh( iface ) {} 00098 00099 ErrorCode initialize( std::string tag_name, DataType mb_type, size_t sz, size_t per_elem ) 00100 { 00101 std::vector< unsigned char > default_val; 00102 default_val.resize( sz * per_elem ); 00103 ErrorCode rval = this->mesh->tag_get_handle( tag_name.c_str(), per_elem, mb_type, this->tag, 00104 MB_TAG_SPARSE | MB_TAG_BYTES | MB_TAG_CREAT, &default_val[0] ); 00105 return rval; 00106 } 00107 00108 void add_entity( EntityHandle ent, const unsigned char* bytes, size_t len ) 00109 { 00110 Hash h( bytes, len ); 00111 EntityHandle mset = this->congruence_class( h, bytes ); 00112 ErrorCode rval; 00113 rval = this->mesh->add_entities( mset, &ent, 1 );MB_CHK_SET_ERR_RET( rval, "Failed to add entities to mesh" ); 00114 } 00115 00116 void add_entities( Range& range, const unsigned char* bytes, size_t bytes_per_ent ) 00117 { 00118 for( Range::iterator it = range.begin(); it != range.end(); ++it, bytes += bytes_per_ent ) 00119 { 00120 Hash h( bytes, bytes_per_ent ); 00121 EntityHandle mset = this->congruence_class( h, bytes ); 00122 ErrorCode rval; 00123 rval = this->mesh->add_entities( mset, &*it, 1 );MB_CHK_SET_ERR_RET( rval, "Failed to add entities to mesh" ); 00124 } 00125 } 00126 00127 EntityHandle congruence_class( const Hash& h, const void* tag_data ) 00128 { 00129 std::map< Hash, EntityHandle >::iterator it = this->find( h ); 00130 if( it == this->end() ) 00131 { 00132 EntityHandle mset; 00133 Range preexist; 00134 ErrorCode rval; 00135 rval = this->mesh->get_entities_by_type_and_tag( 0, MBENTITYSET, &this->tag, &tag_data, 1, preexist );MB_CHK_SET_ERR_RET_VAL( rval, "Failed to get entities by type and tag", (EntityHandle)0 ); 00136 if( preexist.size() ) 00137 { 00138 mset = *preexist.begin(); 00139 } 00140 else 00141 { 00142 rval = this->mesh->create_meshset( MESHSET_SET, mset );MB_CHK_SET_ERR_RET_VAL( rval, "Failed to create mesh set", (EntityHandle)0 ); 00143 rval = this->mesh->tag_set_data( this->tag, &mset, 1, tag_data );MB_CHK_SET_ERR_RET_VAL( rval, "Failed to set tag data", (EntityHandle)0 ); 00144 } 00145 ( *this )[h] = mset; 00146 return mset; 00147 } 00148 return it->second; 00149 } 00150 00151 Interface* mesh; 00152 Tag tag; 00153 }; 00154 #endif // MB_VTK_MATERIAL_SETS 00155 00156 ReaderIface* ReadVtk::factory( Interface* iface ) 00157 { 00158 return new ReadVtk( iface ); 00159 } 00160 00161 ReadVtk::ReadVtk( Interface* impl ) : mdbImpl( impl ), mPartitionTagName( MATERIAL_SET_TAG_NAME ) 00162 { 00163 mdbImpl->query_interface( readMeshIface ); 00164 } 00165 00166 ReadVtk::~ReadVtk() 00167 { 00168 if( readMeshIface ) 00169 { 00170 mdbImpl->release_interface( readMeshIface ); 00171 readMeshIface = 0; 00172 } 00173 } 00174 00175 const char* const vtk_type_names[] = { 00176 "bit", "char", "unsigned_char", "short", "unsigned_short", "int", "unsigned_int", 00177 "long", "unsigned_long", "float", "double", "vtkIdType", 0 }; 00178 00179 ErrorCode ReadVtk::read_tag_values( const char* /* file_name */, 00180 const char* /* tag_name */, 00181 const FileOptions& /* opts */, 00182 std::vector< int >& /* tag_values_out */, 00183 const SubsetList* /* subset_list */ ) 00184 { 00185 return MB_NOT_IMPLEMENTED; 00186 } 00187 00188 ErrorCode ReadVtk::load_file( const char* filename, 00189 const EntityHandle* /* file_set */, 00190 const FileOptions& opts, 00191 const ReaderIface::SubsetList* subset_list, 00192 const Tag* file_id_tag ) 00193 { 00194 ErrorCode result; 00195 00196 int major, minor; 00197 char vendor_string[257]; 00198 std::vector< Range > element_list; 00199 Range vertices; 00200 00201 if( subset_list ) 00202 { 00203 MB_SET_ERR( MB_UNSUPPORTED_OPERATION, "Reading subset of files not supported for VTK" ); 00204 } 00205 00206 // Does the caller want a field to be used for partitioning the entities? 00207 // If not, we'll assume any scalar integer field named MATERIAL_SET specifies partitions. 00208 std::string partition_tag_name; 00209 result = opts.get_option( "PARTITION", partition_tag_name ); 00210 if( result == MB_SUCCESS ) mPartitionTagName = partition_tag_name; 00211 00212 FILE* file = fopen( filename, "r" ); 00213 if( !file ) return MB_FILE_DOES_NOT_EXIST; 00214 00215 // Read file header 00216 00217 if( !fgets( vendor_string, sizeof( vendor_string ), file ) ) 00218 { 00219 fclose( file ); 00220 return MB_FAILURE; 00221 } 00222 00223 if( !strchr( vendor_string, '\n' ) || 2 != sscanf( vendor_string, "# vtk DataFile Version %d.%d", &major, &minor ) ) 00224 { 00225 fclose( file ); 00226 return MB_FAILURE; 00227 } 00228 00229 if( !fgets( vendor_string, sizeof( vendor_string ), file ) ) 00230 { 00231 fclose( file ); 00232 return MB_FAILURE; 00233 } 00234 00235 // VTK spec says this should not exceed 256 chars. 00236 if( !strchr( vendor_string, '\n' ) ) 00237 { 00238 fclose( file ); 00239 MB_SET_ERR( MB_FAILURE, "Vendor string (line 2) exceeds 256 characters" ); 00240 } 00241 00242 // Check file type 00243 00244 FileTokenizer tokens( file, readMeshIface ); 00245 const char* const file_type_names[] = { "ASCII", "BINARY", 0 }; 00246 int filetype = tokens.match_token( file_type_names ); 00247 switch( filetype ) 00248 { 00249 case 2: // BINARY 00250 MB_SET_ERR( MB_FAILURE, "Cannot read BINARY VTK files" ); 00251 default: // ERROR 00252 return MB_FAILURE; 00253 case 1: // ASCII 00254 break; 00255 } 00256 00257 // Read the mesh 00258 if( !tokens.match_token( "DATASET" ) ) return MB_FAILURE; 00259 result = vtk_read_dataset( tokens, vertices, element_list ); 00260 if( MB_SUCCESS != result ) return result; 00261 00262 if( file_id_tag ) 00263 { 00264 result = store_file_ids( *file_id_tag, vertices, element_list ); 00265 if( MB_SUCCESS != result ) return result; 00266 } 00267 00268 // Count the number of elements read 00269 long elem_count = 0; 00270 for( std::vector< Range >::iterator it = element_list.begin(); it != element_list.end(); ++it ) 00271 elem_count += it->size(); 00272 00273 // Read attribute data until end of file. 00274 const char* const block_type_names[] = { "POINT_DATA", "CELL_DATA", 0 }; 00275 std::vector< Range > vertex_list( 1 ); 00276 vertex_list[0] = vertices; 00277 int blocktype = 0; 00278 while( !tokens.eof() ) 00279 { 00280 // Get POINT_DATA or CELL_DATA 00281 int new_block_type = tokens.match_token( block_type_names, false ); 00282 if( tokens.eof() ) break; 00283 00284 if( !new_block_type ) 00285 { 00286 // If next token was neither POINT_DATA nor CELL_DATA, 00287 // then there's another attribute under the current one. 00288 if( blocktype ) 00289 tokens.unget_token(); 00290 else 00291 break; 00292 } 00293 else 00294 { 00295 blocktype = new_block_type; 00296 long count; 00297 if( !tokens.get_long_ints( 1, &count ) ) return MB_FAILURE; 00298 00299 if( blocktype == 1 && (unsigned long)count != vertices.size() ) 00300 { 00301 MB_SET_ERR( MB_FAILURE, "Count inconsistent with number of vertices at line " << tokens.line_number() ); 00302 } 00303 else if( blocktype == 2 && count != elem_count ) 00304 { 00305 MB_SET_ERR( MB_FAILURE, "Count inconsistent with number of elements at line " << tokens.line_number() ); 00306 } 00307 } 00308 00309 if( blocktype == 1 ) 00310 result = vtk_read_attrib_data( tokens, vertex_list ); 00311 else 00312 result = vtk_read_attrib_data( tokens, element_list ); 00313 00314 if( MB_SUCCESS != result ) return result; 00315 } 00316 00317 return MB_SUCCESS; 00318 } 00319 00320 ErrorCode ReadVtk::allocate_vertices( long num_verts, 00321 EntityHandle& start_handle_out, 00322 double*& x_coord_array_out, 00323 double*& y_coord_array_out, 00324 double*& z_coord_array_out ) 00325 { 00326 ErrorCode result; 00327 00328 // Create vertices 00329 std::vector< double* > arrays; 00330 start_handle_out = 0; 00331 result = readMeshIface->get_node_coords( 3, num_verts, MB_START_ID, start_handle_out, arrays ); 00332 if( MB_SUCCESS != result ) return result; 00333 00334 x_coord_array_out = arrays[0]; 00335 y_coord_array_out = arrays[1]; 00336 z_coord_array_out = arrays[2]; 00337 00338 return MB_SUCCESS; 00339 } 00340 00341 ErrorCode ReadVtk::read_vertices( FileTokenizer& tokens, long num_verts, EntityHandle& start_handle_out ) 00342 { 00343 ErrorCode result; 00344 double *x, *y, *z; 00345 00346 result = allocate_vertices( num_verts, start_handle_out, x, y, z ); 00347 if( MB_SUCCESS != result ) return result; 00348 00349 // Read vertex coordinates 00350 for( long vtx = 0; vtx < num_verts; ++vtx ) 00351 { 00352 if( !tokens.get_doubles( 1, x++ ) || !tokens.get_doubles( 1, y++ ) || !tokens.get_doubles( 1, z++ ) ) 00353 return MB_FAILURE; 00354 } 00355 00356 return MB_SUCCESS; 00357 } 00358 00359 ErrorCode ReadVtk::allocate_elements( long num_elements, 00360 int vert_per_element, 00361 EntityType type, 00362 EntityHandle& start_handle_out, 00363 EntityHandle*& conn_array_out, 00364 std::vector< Range >& append_to_this ) 00365 { 00366 ErrorCode result; 00367 00368 start_handle_out = 0; 00369 result = readMeshIface->get_element_connect( num_elements, vert_per_element, type, MB_START_ID, start_handle_out, 00370 conn_array_out ); 00371 if( MB_SUCCESS != result ) return result; 00372 00373 Range range( start_handle_out, start_handle_out + num_elements - 1 ); 00374 append_to_this.push_back( range ); 00375 return MB_SUCCESS; 00376 } 00377 00378 ErrorCode ReadVtk::vtk_read_dataset( FileTokenizer& tokens, Range& vertex_list, std::vector< Range >& element_list ) 00379 { 00380 const char* const data_type_names[] = { 00381 "STRUCTURED_POINTS", "STRUCTURED_GRID", "UNSTRUCTURED_GRID", "POLYDATA", "RECTILINEAR_GRID", "FIELD", 0 }; 00382 int datatype = tokens.match_token( data_type_names ); 00383 switch( datatype ) 00384 { 00385 case 1: 00386 return vtk_read_structured_points( tokens, vertex_list, element_list ); 00387 case 2: 00388 return vtk_read_structured_grid( tokens, vertex_list, element_list ); 00389 case 3: 00390 return vtk_read_unstructured_grid( tokens, vertex_list, element_list ); 00391 case 4: 00392 return vtk_read_polydata( tokens, vertex_list, element_list ); 00393 case 5: 00394 return vtk_read_rectilinear_grid( tokens, vertex_list, element_list ); 00395 case 6: 00396 return vtk_read_field( tokens ); 00397 default: 00398 return MB_FAILURE; 00399 } 00400 } 00401 00402 ErrorCode ReadVtk::vtk_read_structured_points( FileTokenizer& tokens, 00403 Range& vertex_list, 00404 std::vector< Range >& elem_list ) 00405 { 00406 long i, j, k; 00407 long dims[3]; 00408 double origin[3], space[3]; 00409 ErrorCode result; 00410 00411 if( !tokens.match_token( "DIMENSIONS" ) || !tokens.get_long_ints( 3, dims ) || !tokens.get_newline() ) 00412 return MB_FAILURE; 00413 00414 if( dims[0] < 1 || dims[1] < 1 || dims[2] < 1 ) 00415 { 00416 MB_SET_ERR( MB_FAILURE, "Invalid dimension at line " << tokens.line_number() ); 00417 } 00418 00419 if( !tokens.match_token( "ORIGIN" ) || !tokens.get_doubles( 3, origin ) || !tokens.get_newline() ) 00420 return MB_FAILURE; 00421 00422 const char* const spacing_names[] = { "SPACING", "ASPECT_RATIO", 0 }; 00423 if( !tokens.match_token( spacing_names ) || !tokens.get_doubles( 3, space ) || !tokens.get_newline() ) 00424 return MB_FAILURE; 00425 00426 // Create vertices 00427 double *x, *y, *z; 00428 EntityHandle start_handle = 0; 00429 long num_verts = dims[0] * dims[1] * dims[2]; 00430 result = allocate_vertices( num_verts, start_handle, x, y, z ); 00431 if( MB_SUCCESS != result ) return result; 00432 vertex_list.insert( start_handle, start_handle + num_verts - 1 ); 00433 00434 for( k = 0; k < dims[2]; ++k ) 00435 for( j = 0; j < dims[1]; ++j ) 00436 for( i = 0; i < dims[0]; ++i ) 00437 { 00438 *x = origin[0] + i * space[0]; 00439 ++x; 00440 *y = origin[1] + j * space[1]; 00441 ++y; 00442 *z = origin[2] + k * space[2]; 00443 ++z; 00444 } 00445 00446 return vtk_create_structured_elems( dims, start_handle, elem_list ); 00447 } 00448 00449 ErrorCode ReadVtk::vtk_read_structured_grid( FileTokenizer& tokens, 00450 Range& vertex_list, 00451 std::vector< Range >& elem_list ) 00452 { 00453 long num_verts, dims[3]; 00454 ErrorCode result; 00455 00456 if( !tokens.match_token( "DIMENSIONS" ) || !tokens.get_long_ints( 3, dims ) || !tokens.get_newline() ) 00457 return MB_FAILURE; 00458 00459 if( dims[0] < 1 || dims[1] < 1 || dims[2] < 1 ) 00460 { 00461 MB_SET_ERR( MB_FAILURE, "Invalid dimension at line " << tokens.line_number() ); 00462 } 00463 00464 if( !tokens.match_token( "POINTS" ) || !tokens.get_long_ints( 1, &num_verts ) || 00465 !tokens.match_token( vtk_type_names ) || !tokens.get_newline() ) 00466 return MB_FAILURE; 00467 00468 if( num_verts != ( dims[0] * dims[1] * dims[2] ) ) 00469 { 00470 MB_SET_ERR( MB_FAILURE, "Point count not consistent with dimensions at line " << tokens.line_number() ); 00471 } 00472 00473 // Create and read vertices 00474 EntityHandle start_handle = 0; 00475 result = read_vertices( tokens, num_verts, start_handle ); 00476 if( MB_SUCCESS != result ) return result; 00477 vertex_list.insert( start_handle, start_handle + num_verts - 1 ); 00478 00479 return vtk_create_structured_elems( dims, start_handle, elem_list ); 00480 } 00481 00482 ErrorCode ReadVtk::vtk_read_rectilinear_grid( FileTokenizer& tokens, 00483 Range& vertex_list, 00484 std::vector< Range >& elem_list ) 00485 { 00486 int i, j, k; 00487 long dims[3]; 00488 const char* labels[] = { "X_COORDINATES", "Y_COORDINATES", "Z_COORDINATES" }; 00489 std::vector< double > coords[3]; 00490 ErrorCode result; 00491 00492 if( !tokens.match_token( "DIMENSIONS" ) || !tokens.get_long_ints( 3, dims ) || !tokens.get_newline() ) 00493 return MB_FAILURE; 00494 00495 if( dims[0] < 1 || dims[1] < 1 || dims[2] < 1 ) 00496 { 00497 MB_SET_ERR( MB_FAILURE, "Invalid dimension at line " << tokens.line_number() ); 00498 } 00499 00500 for( i = 0; i < 3; i++ ) 00501 { 00502 long count; 00503 if( !tokens.match_token( labels[i] ) || !tokens.get_long_ints( 1, &count ) || 00504 !tokens.match_token( vtk_type_names ) ) 00505 return MB_FAILURE; 00506 00507 if( count != dims[i] ) 00508 { 00509 MB_SET_ERR( MB_FAILURE, "Coordinate count inconsistent with dimensions at line " << tokens.line_number() ); 00510 } 00511 00512 coords[i].resize( count ); 00513 if( !tokens.get_doubles( count, &coords[i][0] ) ) return MB_FAILURE; 00514 } 00515 00516 // Create vertices 00517 double *x, *y, *z; 00518 EntityHandle start_handle = 0; 00519 long num_verts = dims[0] * dims[1] * dims[2]; 00520 result = allocate_vertices( num_verts, start_handle, x, y, z ); 00521 if( MB_SUCCESS != result ) return result; 00522 vertex_list.insert( start_handle, start_handle + num_verts - 1 ); 00523 00524 // Calculate vertex coordinates 00525 for( k = 0; k < dims[2]; ++k ) 00526 for( j = 0; j < dims[1]; ++j ) 00527 for( i = 0; i < dims[0]; ++i ) 00528 { 00529 *x = coords[0][i]; 00530 ++x; 00531 *y = coords[1][j]; 00532 ++y; 00533 *z = coords[2][k]; 00534 ++z; 00535 } 00536 00537 return vtk_create_structured_elems( dims, start_handle, elem_list ); 00538 } 00539 00540 ErrorCode ReadVtk::vtk_read_polydata( FileTokenizer& tokens, Range& vertex_list, std::vector< Range >& elem_list ) 00541 { 00542 ErrorCode result; 00543 long num_verts; 00544 const char* const poly_data_names[] = { "VERTICES", "LINES", "POLYGONS", "TRIANGLE_STRIPS", 0 }; 00545 00546 if( !tokens.match_token( "POINTS" ) || !tokens.get_long_ints( 1, &num_verts ) || 00547 !tokens.match_token( vtk_type_names ) || !tokens.get_newline() ) 00548 return MB_FAILURE; 00549 00550 if( num_verts < 1 ) 00551 { 00552 MB_SET_ERR( MB_FAILURE, "Invalid point count at line " << tokens.line_number() ); 00553 } 00554 00555 // Create vertices and read coordinates 00556 EntityHandle start_handle = 0; 00557 result = read_vertices( tokens, num_verts, start_handle ); 00558 if( MB_SUCCESS != result ) return result; 00559 vertex_list.insert( start_handle, start_handle + num_verts - 1 ); 00560 00561 int poly_type = tokens.match_token( poly_data_names ); 00562 switch( poly_type ) 00563 { 00564 case 0: 00565 result = MB_FAILURE; 00566 break; 00567 case 1: 00568 MB_SET_ERR( MB_FAILURE, "Vertex element type at line " << tokens.line_number() ); 00569 break; 00570 case 2: 00571 MB_SET_ERR( MB_FAILURE, "Unsupported type: polylines at line " << tokens.line_number() ); 00572 result = MB_FAILURE; 00573 break; 00574 case 3: 00575 result = vtk_read_polygons( tokens, start_handle, elem_list ); 00576 break; 00577 case 4: 00578 MB_SET_ERR( MB_FAILURE, "Unsupported type: triangle strips at line " << tokens.line_number() ); 00579 result = MB_FAILURE; 00580 break; 00581 } 00582 00583 return result; 00584 } 00585 00586 ErrorCode ReadVtk::vtk_read_polygons( FileTokenizer& tokens, EntityHandle first_vtx, std::vector< Range >& elem_list ) 00587 { 00588 ErrorCode result; 00589 long size[2]; 00590 00591 if( !tokens.get_long_ints( 2, size ) || !tokens.get_newline() ) return MB_FAILURE; 00592 00593 const Range empty; 00594 std::vector< EntityHandle > conn_hdl; 00595 std::vector< long > conn_idx; 00596 EntityHandle first = 0, prev = 0, handle; 00597 for( int i = 0; i < size[0]; ++i ) 00598 { 00599 long count; 00600 if( !tokens.get_long_ints( 1, &count ) ) return MB_FAILURE; 00601 conn_idx.resize( count ); 00602 conn_hdl.resize( count ); 00603 if( !tokens.get_long_ints( count, &conn_idx[0] ) ) return MB_FAILURE; 00604 00605 for( long j = 0; j < count; ++j ) 00606 conn_hdl[j] = first_vtx + conn_idx[j]; 00607 00608 result = mdbImpl->create_element( MBPOLYGON, &conn_hdl[0], count, handle ); 00609 if( MB_SUCCESS != result ) return result; 00610 00611 if( prev + 1 != handle ) 00612 { 00613 if( first ) 00614 { // True except for first iteration (first == 0) 00615 if( elem_list.empty() || first < elem_list.back().front() ) // Only need new range if order would get 00616 // mixed up, or we just began inserting 00617 elem_list.push_back( empty ); 00618 elem_list.back().insert( first, prev ); 00619 } 00620 first = handle; 00621 } 00622 prev = handle; 00623 } 00624 if( first ) 00625 { // True unless no elements (size[0] == 0) 00626 if( elem_list.empty() || first < elem_list.back().front() ) // Only need new range if order would get mixed 00627 // up, or we just began inserting 00628 elem_list.push_back( empty ); 00629 elem_list.back().insert( first, prev ); 00630 } 00631 00632 return MB_SUCCESS; 00633 } 00634 00635 ErrorCode ReadVtk::vtk_read_unstructured_grid( FileTokenizer& tokens, 00636 Range& vertex_list, 00637 std::vector< Range >& elem_list ) 00638 { 00639 ErrorCode result; 00640 long i, num_verts, num_elems[2]; 00641 EntityHandle tmp_conn_list[27]; 00642 00643 // Poorly formatted VTK legacy format document seems to 00644 // lead many to think that a FIELD block can occur within 00645 // an UNSTRUCTURED_GRID dataset rather than as its own data 00646 // set. So allow for field data between other blocks of 00647 // data. 00648 00649 const char* pts_str[] = { "FIELD", "POINTS", 0 }; 00650 while( 1 == ( i = tokens.match_token( pts_str ) ) ) 00651 { 00652 result = vtk_read_field( tokens ); 00653 if( MB_SUCCESS != result ) return result; 00654 } 00655 if( i != 2 ) return MB_FAILURE; 00656 00657 if( !tokens.get_long_ints( 1, &num_verts ) || !tokens.match_token( vtk_type_names ) || !tokens.get_newline() ) 00658 return MB_FAILURE; 00659 00660 if( num_verts < 1 ) 00661 { 00662 MB_SET_ERR( MB_FAILURE, "Invalid point count at line " << tokens.line_number() ); 00663 } 00664 00665 // Create vertices and read coordinates 00666 EntityHandle first_vertex = 0; 00667 result = read_vertices( tokens, num_verts, first_vertex ); 00668 if( MB_SUCCESS != result ) return result; 00669 vertex_list.insert( first_vertex, first_vertex + num_verts - 1 ); 00670 00671 const char* cell_str[] = { "FIELD", "CELLS", 0 }; 00672 while( 1 == ( i = tokens.match_token( cell_str ) ) ) 00673 { 00674 result = vtk_read_field( tokens ); 00675 if( MB_SUCCESS != result ) return result; 00676 } 00677 if( i != 2 ) return MB_FAILURE; 00678 00679 if( !tokens.get_long_ints( 2, num_elems ) || !tokens.get_newline() ) return MB_FAILURE; 00680 00681 // Read element connectivity for all elements 00682 std::vector< long > connectivity( num_elems[1] ); 00683 if( !tokens.get_long_ints( num_elems[1], &connectivity[0] ) ) return MB_FAILURE; 00684 00685 if( !tokens.match_token( "CELL_TYPES" ) || !tokens.get_long_ints( 1, &num_elems[1] ) || !tokens.get_newline() ) 00686 return MB_FAILURE; 00687 00688 // Read element types 00689 std::vector< long > types( num_elems[0] ); 00690 if( !tokens.get_long_ints( num_elems[0], &types[0] ) ) return MB_FAILURE; 00691 00692 // Create elements in blocks of the same type 00693 // It is important to preserve the order in 00694 // which the elements were read for later reading 00695 // attribute data. 00696 long id = 0; 00697 std::vector< long >::iterator conn_iter = connectivity.begin(); 00698 while( id < num_elems[0] ) 00699 { 00700 unsigned vtk_type = types[id]; 00701 if( vtk_type >= VtkUtil::numVtkElemType ) return MB_FAILURE; 00702 00703 EntityType type = VtkUtil::vtkElemTypes[vtk_type].mb_type; 00704 if( type == MBMAXTYPE ) 00705 { 00706 MB_SET_ERR( MB_FAILURE, "Unsupported VTK element type: " << VtkUtil::vtkElemTypes[vtk_type].name << " (" 00707 << vtk_type << ")" ); 00708 } 00709 00710 int num_vtx = *conn_iter; 00711 if( type != MBPOLYGON && type != MBPOLYHEDRON && num_vtx != (int)VtkUtil::vtkElemTypes[vtk_type].num_nodes ) 00712 { 00713 MB_SET_ERR( MB_FAILURE, "Cell " << id << " is of type '" << VtkUtil::vtkElemTypes[vtk_type].name 00714 << "' but has " << num_vtx << " vertices" ); 00715 } 00716 00717 // Find any subsequent elements of the same type 00718 // if polyhedra, need to look at the number of faces to put in the same range 00719 std::vector< long >::iterator conn_iter2 = conn_iter + num_vtx + 1; 00720 long end_id = id + 1; 00721 if( MBPOLYHEDRON != type ) 00722 { 00723 while( end_id < num_elems[0] && (unsigned)types[end_id] == vtk_type && *conn_iter2 == num_vtx ) 00724 { 00725 ++end_id; 00726 conn_iter2 += num_vtx + 1; 00727 } 00728 } 00729 else 00730 { 00731 // advance only if next is polyhedron too, and if number of faces is the same 00732 int num_faces = conn_iter[1]; 00733 while( end_id < num_elems[0] && (unsigned)types[end_id] == vtk_type && conn_iter2[1] == num_faces ) 00734 { 00735 ++end_id; 00736 conn_iter2 += num_vtx + 1; 00737 } 00738 // num_vtx becomes in this case num_faces 00739 num_vtx = num_faces; // for polyhedra, this is what we want 00740 // trigger vertex adjacency call 00741 Range firstFaces; 00742 mdbImpl->get_adjacencies( &first_vertex, 1, 2, false, firstFaces ); 00743 } 00744 00745 // Allocate element block 00746 long num_elem = end_id - id; 00747 EntityHandle start_handle = 0; 00748 EntityHandle* conn_array; 00749 00750 // if type is MBVERTEX, skip, we will not create elements with one vertex 00751 if( MBVERTEX == type ) 00752 { 00753 id += num_elem; 00754 conn_iter += 2 * num_elem; // skip 2 * number of 1-vertex elements 00755 continue; 00756 } 00757 00758 result = allocate_elements( num_elem, num_vtx, type, start_handle, conn_array, elem_list ); 00759 if( MB_SUCCESS != result ) return result; 00760 00761 EntityHandle* conn_sav = conn_array; 00762 00763 // Store element connectivity 00764 if( type != MBPOLYHEDRON ) 00765 { 00766 for( ; id < end_id; ++id ) 00767 { 00768 if( conn_iter == connectivity.end() ) 00769 { 00770 MB_SET_ERR( MB_FAILURE, "Connectivity data truncated at cell " << id ); 00771 } 00772 // Make sure connectivity length is correct. 00773 if( *conn_iter != num_vtx ) 00774 { 00775 MB_SET_ERR( MB_FAILURE, "Cell " << id << " is of type '" << VtkUtil::vtkElemTypes[vtk_type].name 00776 << "' but has " << num_vtx << " vertices" ); 00777 } 00778 ++conn_iter; 00779 00780 for( i = 0; i < num_vtx; ++i, ++conn_iter ) 00781 { 00782 if( conn_iter == connectivity.end() ) 00783 { 00784 MB_SET_ERR( MB_FAILURE, "Connectivity data truncated at cell " << id ); 00785 } 00786 00787 conn_array[i] = *conn_iter + first_vertex; 00788 } 00789 00790 const unsigned* order = VtkUtil::vtkElemTypes[vtk_type].node_order; 00791 if( order ) 00792 { 00793 assert( num_vtx * sizeof( EntityHandle ) <= sizeof( tmp_conn_list ) ); 00794 memcpy( tmp_conn_list, conn_array, num_vtx * sizeof( EntityHandle ) ); 00795 for( int j = 0; j < num_vtx; ++j ) 00796 conn_array[order[j]] = tmp_conn_list[j]; 00797 } 00798 00799 conn_array += num_vtx; 00800 } 00801 } 00802 else // type == MBPOLYHEDRON 00803 { 00804 // in some cases, we may need to create new elements; will it screw the tags? 00805 // not if the file was not from moab 00806 ErrorCode rv = MB_SUCCESS; 00807 for( ; id < end_id; ++id ) 00808 { 00809 if( conn_iter == connectivity.end() ) 00810 { 00811 MB_SET_ERR( MB_FAILURE, "Connectivity data truncated at polyhedra cell " << id ); 00812 } 00813 ++conn_iter; 00814 // iterator is now at number of faces 00815 // we should check it is indeed num_vtx 00816 int num_faces = *conn_iter; 00817 if( num_faces != num_vtx ) MB_SET_ERR( MB_FAILURE, "Connectivity data wrong at polyhedra cell " << id ); 00818 00819 EntityHandle connec[20]; // we bet we will have only 20 vertices at most, in a 00820 // face in a polyhedra 00821 for( int j = 0; j < num_faces; j++ ) 00822 { 00823 conn_iter++; 00824 int numverticesInFace = (int)*conn_iter; 00825 if( numverticesInFace > 20 ) 00826 MB_SET_ERR( MB_FAILURE, 00827 "too many vertices in face index " << j << " for polyhedra cell " << id ); 00828 // need to find the face, but first fill with vertices 00829 for( int k = 0; k < numverticesInFace; k++ ) 00830 { 00831 connec[k] = first_vertex + *( ++conn_iter ); // 00832 } 00833 Range adjFaces; 00834 // find a face with these vertices; if not, we need to create one, on the fly :( 00835 rv = mdbImpl->get_adjacencies( connec, numverticesInFace, 2, false, adjFaces );MB_CHK_ERR( rv ); 00836 if( adjFaces.size() >= 1 ) 00837 { 00838 conn_array[j] = adjFaces[0]; // get the first face found 00839 } 00840 else 00841 { 00842 // create the face; tri, quad or polygon 00843 EntityType etype = MBTRI; 00844 if( 4 == numverticesInFace ) etype = MBQUAD; 00845 if( 4 < numverticesInFace ) etype = MBPOLYGON; 00846 00847 rv = mdbImpl->create_element( etype, connec, numverticesInFace, conn_array[j] );MB_CHK_ERR( rv ); 00848 } 00849 } 00850 00851 conn_array += num_vtx; // advance for next polyhedra 00852 conn_iter++; // advance to the next field 00853 } 00854 } 00855 00856 // Notify MOAB of the new elements 00857 result = readMeshIface->update_adjacencies( start_handle, num_elem, num_vtx, conn_sav ); 00858 if( MB_SUCCESS != result ) return result; 00859 } 00860 00861 return MB_SUCCESS; 00862 } 00863 00864 ErrorCode ReadVtk::vtk_create_structured_elems( const long* dims, 00865 EntityHandle first_vtx, 00866 std::vector< Range >& elem_list ) 00867 { 00868 ErrorCode result; 00869 // int non_zero[3] = {0, 0, 0}; // True if dim > 0 for x, y, z respectively 00870 long elem_dim = 0; // Element dimension (2->quad, 3->hex) 00871 long num_elems = 1; // Total number of elements 00872 long vert_per_elem; // Element connectivity length 00873 long edims[3] = { 1, 1, 1 }; // Number of elements in each grid direction 00874 00875 // Populate above data 00876 for( int d = 0; d < 3; d++ ) 00877 { 00878 if( dims[d] > 1 ) 00879 { 00880 // non_zero[elem_dim] = d; 00881 ++elem_dim; 00882 edims[d] = dims[d] - 1; 00883 num_elems *= edims[d]; 00884 } 00885 } 00886 vert_per_elem = 1 << elem_dim; 00887 00888 // Get element type from element dimension 00889 EntityType type; 00890 switch( elem_dim ) 00891 { 00892 case 1: 00893 type = MBEDGE; 00894 break; 00895 case 2: 00896 type = MBQUAD; 00897 break; 00898 case 3: 00899 type = MBHEX; 00900 break; 00901 default: 00902 MB_SET_ERR( MB_FAILURE, "Invalid dimension for structured elements: " << elem_dim ); 00903 } 00904 00905 // Allocate storage for elements 00906 EntityHandle start_handle = 0; 00907 EntityHandle* conn_array; 00908 result = allocate_elements( num_elems, vert_per_elem, type, start_handle, conn_array, elem_list ); 00909 if( MB_SUCCESS != result ) return MB_FAILURE; 00910 00911 EntityHandle* conn_sav = conn_array; 00912 00913 // Offsets of element vertices in grid relative to corner closest to origin 00914 long k = dims[0] * dims[1]; 00915 const long corners[8] = { 0, 1, 1 + dims[0], dims[0], k, k + 1, k + 1 + dims[0], k + dims[0] }; 00916 00917 // Populate element list 00918 for( long z = 0; z < edims[2]; ++z ) 00919 for( long y = 0; y < edims[1]; ++y ) 00920 for( long x = 0; x < edims[0]; ++x ) 00921 { 00922 const long index = x + y * dims[0] + z * ( dims[0] * dims[1] ); 00923 for( long j = 0; j < vert_per_elem; ++j, ++conn_array ) 00924 *conn_array = index + corners[j] + first_vtx; 00925 } 00926 00927 // Notify MOAB of the new elements 00928 result = readMeshIface->update_adjacencies( start_handle, num_elems, vert_per_elem, conn_sav ); 00929 if( MB_SUCCESS != result ) return result; 00930 00931 return MB_SUCCESS; 00932 } 00933 00934 ErrorCode ReadVtk::vtk_read_field( FileTokenizer& tokens ) 00935 { 00936 // This is not supported yet. 00937 // Parse the data but throw it away because 00938 // Mesquite has no internal representation for it. 00939 00940 // Could save this in tags, but the only useful thing that 00941 // could be done with the data is to write it back out 00942 // with the modified mesh. As there's no way to save the 00943 // type of a tag in Mesquite, it cannot be written back 00944 // out correctly either. 00945 // FIXME: Don't know what to do with this data. 00946 // For now, read it and throw it out. 00947 00948 long num_arrays; 00949 if( !tokens.get_string() || // Name 00950 !tokens.get_long_ints( 1, &num_arrays ) ) 00951 return MB_FAILURE; 00952 00953 for( long i = 0; i < num_arrays; ++i ) 00954 { 00955 /*const char* name =*/tokens.get_string(); 00956 00957 long dims[2]; 00958 if( !tokens.get_long_ints( 2, dims ) || !tokens.match_token( vtk_type_names ) ) return MB_FAILURE; 00959 00960 long num_vals = dims[0] * dims[1]; 00961 00962 for( long j = 0; j < num_vals; j++ ) 00963 { 00964 double junk; 00965 if( !tokens.get_doubles( 1, &junk ) ) return MB_FAILURE; 00966 } 00967 } 00968 00969 return MB_SUCCESS; 00970 } 00971 00972 ErrorCode ReadVtk::vtk_read_attrib_data( FileTokenizer& tokens, std::vector< Range >& entities ) 00973 { 00974 const char* const type_names[] = { "SCALARS", "COLOR_SCALARS", "VECTORS", "NORMALS", "TEXTURE_COORDINATES", 00975 "TENSORS", "FIELD", 0 }; 00976 00977 int type = tokens.match_token( type_names ); 00978 const char* tmp_name = tokens.get_string(); 00979 if( !type || !tmp_name ) return MB_FAILURE; 00980 00981 std::string name_alloc( tmp_name ); 00982 const char* name = name_alloc.c_str(); 00983 switch( type ) 00984 { 00985 case 1: 00986 return vtk_read_scalar_attrib( tokens, entities, name ); 00987 case 2: 00988 return vtk_read_color_attrib( tokens, entities, name ); 00989 case 3: 00990 return vtk_read_vector_attrib( tokens, entities, name ); 00991 case 4: 00992 return vtk_read_vector_attrib( tokens, entities, name ); 00993 case 5: 00994 return vtk_read_texture_attrib( tokens, entities, name ); 00995 case 6: 00996 return vtk_read_tensor_attrib( tokens, entities, name ); 00997 case 7: 00998 return vtk_read_field_attrib( tokens, entities, name ); 00999 } 01000 01001 return MB_FAILURE; 01002 } 01003 01004 ErrorCode ReadVtk::vtk_read_tag_data( FileTokenizer& tokens, 01005 int type, 01006 size_t per_elem, 01007 std::vector< Range >& entities, 01008 const char* name ) 01009 { 01010 ErrorCode result; 01011 DataType mb_type; 01012 if( type == 1 ) 01013 { 01014 mb_type = MB_TYPE_BIT; 01015 } 01016 else if( type >= 2 && type <= 9 ) 01017 { 01018 mb_type = MB_TYPE_INTEGER; 01019 } 01020 else if( type == 10 || type == 11 ) 01021 { 01022 mb_type = MB_TYPE_DOUBLE; 01023 } 01024 else if( type == 12 ) 01025 { 01026 mb_type = MB_TYPE_INTEGER; 01027 } 01028 else 01029 return MB_FAILURE; 01030 01031 #ifdef MB_VTK_MATERIAL_SETS 01032 size_t size; 01033 if( type == 1 ) 01034 { 01035 size = sizeof( bool ); 01036 } 01037 else if( type >= 2 && type <= 9 ) 01038 { 01039 size = sizeof( int ); 01040 } 01041 else if( type == 10 || type == 11 ) 01042 { 01043 size = sizeof( double ); 01044 } 01045 else /* (type == 12) */ 01046 { 01047 size = 4; // Could be 4 or 8, but we don't know. Hope it's 4 because MOAB doesn't support 01048 // 64-bit ints. 01049 } 01050 Modulator materialMap( this->mdbImpl ); 01051 result = materialMap.initialize( this->mPartitionTagName, mb_type, size, per_elem );MB_CHK_SET_ERR( result, "MaterialMap tag (" << this->mPartitionTagName << ") creation failed." ); 01052 bool isMaterial = size * per_elem <= 4 && // Must have int-sized values (ParallelComm requires it) 01053 !this->mPartitionTagName.empty() && // Must have a non-empty field name... 01054 !strcmp( name, this->mPartitionTagName.c_str() ); // ... that matches our spec. 01055 #endif // MB_VTK_MATERIAL_SETS 01056 01057 // Get/create tag 01058 Tag handle; 01059 result = mdbImpl->tag_get_handle( name, per_elem, mb_type, handle, MB_TAG_DENSE | MB_TAG_CREAT );MB_CHK_SET_ERR( result, "Tag name conflict for attribute \"" << name << "\" at line " << tokens.line_number() ); 01060 01061 std::vector< Range >::iterator iter; 01062 01063 if( type == 1 ) 01064 { 01065 for( iter = entities.begin(); iter != entities.end(); ++iter ) 01066 { 01067 bool* data = new bool[iter->size() * per_elem]; 01068 if( !tokens.get_booleans( per_elem * iter->size(), data ) ) 01069 { 01070 delete[] data; 01071 return MB_FAILURE; 01072 } 01073 01074 bool* data_iter = data; 01075 Range::iterator ent_iter = iter->begin(); 01076 for( ; ent_iter != iter->end(); ++ent_iter ) 01077 { 01078 unsigned char bits = 0; 01079 for( unsigned j = 0; j < per_elem; ++j, ++data_iter ) 01080 bits |= (unsigned char)( *data_iter << j ); 01081 #ifdef MB_VTK_MATERIAL_SETS 01082 if( isMaterial ) materialMap.add_entity( *ent_iter, &bits, 1 ); 01083 #endif // MB_VTK_MATERIAL_SETS 01084 result = mdbImpl->tag_set_data( handle, &*ent_iter, 1, &bits ); 01085 if( MB_SUCCESS != result ) 01086 { 01087 delete[] data; 01088 return result; 01089 } 01090 } 01091 delete[] data; 01092 } 01093 } 01094 else if( ( type >= 2 && type <= 9 ) || type == 12 ) 01095 { 01096 std::vector< int > data; 01097 for( iter = entities.begin(); iter != entities.end(); ++iter ) 01098 { 01099 data.resize( iter->size() * per_elem ); 01100 if( !tokens.get_integers( iter->size() * per_elem, &data[0] ) ) return MB_FAILURE; 01101 #ifdef MB_VTK_MATERIAL_SETS 01102 if( isMaterial ) materialMap.add_entities( *iter, (unsigned char*)&data[0], per_elem * size ); 01103 #endif // MB_VTK_MATERIAL_SETS 01104 result = mdbImpl->tag_set_data( handle, *iter, &data[0] ); 01105 if( MB_SUCCESS != result ) return result; 01106 } 01107 } 01108 else if( type == 10 || type == 11 ) 01109 { 01110 std::vector< double > data; 01111 for( iter = entities.begin(); iter != entities.end(); ++iter ) 01112 { 01113 data.resize( iter->size() * per_elem ); 01114 if( !tokens.get_doubles( iter->size() * per_elem, &data[0] ) ) return MB_FAILURE; 01115 #ifdef MB_VTK_MATERIAL_SETS 01116 if( isMaterial ) materialMap.add_entities( *iter, (unsigned char*)&data[0], per_elem * size ); 01117 #endif // MB_VTK_MATERIAL_SETS 01118 result = mdbImpl->tag_set_data( handle, *iter, &data[0] ); 01119 if( MB_SUCCESS != result ) return result; 01120 } 01121 } 01122 01123 return MB_SUCCESS; 01124 } 01125 01126 ErrorCode ReadVtk::vtk_read_scalar_attrib( FileTokenizer& tokens, std::vector< Range >& entities, const char* name ) 01127 { 01128 int type = tokens.match_token( vtk_type_names ); 01129 if( !type ) return MB_FAILURE; 01130 01131 long size; 01132 const char* tok = tokens.get_string(); 01133 if( !tok ) return MB_FAILURE; 01134 01135 const char* end = 0; 01136 size = strtol( tok, (char**)&end, 0 ); 01137 if( *end ) 01138 { 01139 size = 1; 01140 tokens.unget_token(); 01141 } 01142 01143 // VTK spec says cannot be greater than 4--do we care? 01144 if( size < 1 ) 01145 { //|| size > 4) 01146 MB_SET_ERR( MB_FAILURE, "Scalar count out of range [1,4] at line " << tokens.line_number() ); 01147 } 01148 01149 if( !tokens.match_token( "LOOKUP_TABLE" ) || !tokens.match_token( "default" ) ) return MB_FAILURE; 01150 01151 return vtk_read_tag_data( tokens, type, size, entities, name ); 01152 } 01153 01154 ErrorCode ReadVtk::vtk_read_color_attrib( FileTokenizer& tokens, std::vector< Range >& entities, const char* name ) 01155 { 01156 long size; 01157 if( !tokens.get_long_ints( 1, &size ) || size < 1 ) return MB_FAILURE; 01158 01159 return vtk_read_tag_data( tokens, 10, size, entities, name ); 01160 } 01161 01162 ErrorCode ReadVtk::vtk_read_vector_attrib( FileTokenizer& tokens, std::vector< Range >& entities, const char* name ) 01163 { 01164 int type = tokens.match_token( vtk_type_names ); 01165 if( !type ) return MB_FAILURE; 01166 01167 return vtk_read_tag_data( tokens, type, 3, entities, name ); 01168 } 01169 01170 ErrorCode ReadVtk::vtk_read_texture_attrib( FileTokenizer& tokens, std::vector< Range >& entities, const char* name ) 01171 { 01172 int type, dim; 01173 if( !tokens.get_integers( 1, &dim ) || !( type = tokens.match_token( vtk_type_names ) ) ) return MB_FAILURE; 01174 01175 if( dim < 1 || dim > 3 ) 01176 { 01177 MB_SET_ERR( MB_FAILURE, "Invalid dimension (" << dim << ") at line " << tokens.line_number() ); 01178 } 01179 01180 return vtk_read_tag_data( tokens, type, dim, entities, name ); 01181 } 01182 01183 ErrorCode ReadVtk::vtk_read_tensor_attrib( FileTokenizer& tokens, std::vector< Range >& entities, const char* name ) 01184 { 01185 int type = tokens.match_token( vtk_type_names ); 01186 if( !type ) return MB_FAILURE; 01187 01188 return vtk_read_tag_data( tokens, type, 9, entities, name ); 01189 } 01190 01191 ErrorCode ReadVtk::vtk_read_field_attrib( FileTokenizer& tokens, std::vector< Range >& entities, const char* ) 01192 { 01193 long num_fields; 01194 if( !tokens.get_long_ints( 1, &num_fields ) ) return MB_FAILURE; 01195 01196 long i; 01197 for( i = 0; i < num_fields; ++i ) 01198 { 01199 const char* tok = tokens.get_string(); 01200 if( !tok ) return MB_FAILURE; 01201 01202 std::string name_alloc( tok ); 01203 01204 long num_comp; 01205 if( !tokens.get_long_ints( 1, &num_comp ) ) return MB_FAILURE; 01206 01207 long num_tuples; 01208 if( !tokens.get_long_ints( 1, &num_tuples ) ) return MB_FAILURE; 01209 01210 int type = tokens.match_token( vtk_type_names ); 01211 if( !type ) return MB_FAILURE; 01212 01213 ErrorCode result = vtk_read_tag_data( tokens, type, num_comp, entities, name_alloc.c_str() );MB_CHK_SET_ERR( result, "Error reading data for field \"" << name_alloc << "\" (" << num_comp << " components, " 01214 << num_tuples << " tuples, type " << type 01215 << ") at line " << tokens.line_number() ); 01216 } 01217 01218 return MB_SUCCESS; 01219 } 01220 01221 ErrorCode ReadVtk::store_file_ids( Tag tag, const Range& verts, const std::vector< Range >& elems ) 01222 { 01223 ErrorCode rval; 01224 01225 rval = readMeshIface->assign_ids( tag, verts ); 01226 if( MB_SUCCESS != rval ) return rval; 01227 01228 int id = 0; 01229 for( size_t i = 0; i < elems.size(); ++i ) 01230 { 01231 rval = readMeshIface->assign_ids( tag, elems[i], id ); 01232 id += elems[i].size(); 01233 } 01234 01235 return MB_SUCCESS; 01236 } 01237 01238 } // namespace moab
