MOAB: Mesh Oriented datABase
(version 5.4.1)
Parse a file as space-separated tokens. More...
#include <FileTokenizer.hpp>
Public Member Functions | |
| FileTokenizer (std::FILE *file_ptr, ReadUtilIface *read_util_ptr) | |
| constructor | |
| ~FileTokenizer () | |
| destructor : closes file. | |
| const char * | get_string () |
| get next token | |
| bool | get_newline (bool report_error=true) |
| check for newline | |
| bool | get_doubles (size_t count, double *array) |
| Parse a sequence of double values. | |
| bool | get_floats (size_t count, float *array) |
| Parse a sequence of float values. | |
| bool | get_integers (size_t count, int *array) |
| Parse a sequence of integer values. | |
| bool | get_long_ints (size_t count, long *array) |
| bool | get_short_ints (size_t count, short *array) |
| bool | get_bytes (size_t count, unsigned char *array) |
| bool | get_binary (size_t bytes, void *mem) |
| Read binary data (interleaved with ASCII) | |
| bool | get_booleans (size_t count, bool *array) |
| Parse a sequence of bit or boolean values. | |
| bool | eof () const |
| int | line_number () const |
| void | unget_token () |
| bool | match_token (const char *string, bool print_error=true) |
| int | match_token (const char *const *string_list, bool print_error=true) |
Private Member Functions | |
| bool | get_double_internal (double &result) |
| bool | get_long_int_internal (long &result) |
| bool | get_boolean_internal (bool &result) |
| bool | get_float_internal (float &result) |
| bool | get_integer_internal (int &result) |
| bool | get_short_int_internal (short &result) |
| bool | get_byte_internal (unsigned char &result) |
Private Attributes | |
| std::FILE * | filePtr |
| char | buffer [512] |
| char * | nextToken |
| char * | bufferEnd |
| int | lineNumber |
| char | lastChar |
Read a file, separating it into space-separated tokens. This is provided in place of using the standard C or C++ file parsing routines because it counts lines, which is useful for error reporting. Also provides some useful utility methods for parsing VTK files (which is the intended use of this implementation.)
Uses raw reads/writes, implementing internal buffering. Token size may not exceed buffer size.
Definition at line 44 of file FileTokenizer.hpp.
| moab::FileTokenizer::FileTokenizer | ( | std::FILE * | file_ptr, |
| ReadUtilIface * | read_util_ptr | ||
constructor
| file_ptr | The file to read from. |
| read_util_ptr | Pointer to ReadUtilIface to use for reporting errors. |
Definition at line 30 of file FileTokenizer.cpp.
The destructor closes the passed file handle. This is done as a convenience feature. If the caller creates an instance of this object on the stack, the file will automatically be closed when the caller returns.
Definition at line 35 of file FileTokenizer.cpp.
References filePtr.
fclose( filePtr );
| bool moab::FileTokenizer::eof | ( | ) | const |
Check for end-of-file condition.
Definition at line 40 of file FileTokenizer.cpp.
References bufferEnd, filePtr, and nextToken.
Referenced by get_newline(), and moab::ReadVtk::load_file().
| bool moab::FileTokenizer::get_binary | ( | size_t | bytes, |
| void * | mem | ||
Read a block of binary data.
| bytes | Number of bytes to read |
| mem | Memory address at which to store data. |
Definition at line 420 of file FileTokenizer.cpp.
References bufferEnd, filePtr, nextToken, and size.
// If data in buffer
if( nextToken != bufferEnd )
// If requested size is less than buffer contents,
// just pass back part of the buffer
if( bufferEnd - nextToken <= (int)size )
memcpy( mem, nextToken, size );
nextToken += size;
return true;
// Copy buffer contents into memory and clear buffer
memcpy( mem, nextToken, bufferEnd - nextToken );
size -= bufferEnd - nextToken;
mem = reinterpret_cast< char* >( mem ) + ( bufferEnd - nextToken );
nextToken = bufferEnd;
// Read any additional data from file
return size == fread( mem, 1, size, filePtr );
| bool moab::FileTokenizer::get_boolean_internal | ( | bool & | result | ) | [private] |
Internal implementation of get_Booleans
Definition at line 214 of file FileTokenizer.cpp.
References get_string(), line_number(), and MB_SET_ERR_RET_VAL.
Referenced by get_booleans().
// Get a token
const char* token = get_string();
if( !token ) return false;
if( token[1] || ( token[0] != '0' && token[0] != '1' ) )
MB_SET_ERR_RET_VAL( "Syntax error at line " << line_number() << ": expected 0 or 1, got \"" << token << "\"",
false );
result = token[0] == '1';
return true;
| bool moab::FileTokenizer::get_booleans | ( | size_t | count, |
| bool * | array | ||
Read the specified number of space-delimited values.
| count | The number of values to read. |
| array | The memory at which to store the values. |
Definition at line 295 of file FileTokenizer.cpp.
References get_boolean_internal().
Referenced by moab::ReadVtk::vtk_read_tag_data().
for( size_t i = 0; i < count; ++i )
if( !get_boolean_internal( *array ) ) return false;
++array;
return true;
| bool moab::FileTokenizer::get_byte_internal | ( | unsigned char & | result | ) | [private] |
Internal implementation of get_bytes
Definition at line 181 of file FileTokenizer.cpp.
References get_long_int_internal(), line_number(), and MB_SET_ERR_RET_VAL.
Referenced by get_bytes().
long i;
if( !get_long_int_internal( i ) ) return false;
result = (unsigned char)i;
if( i != (long)result ) MB_SET_ERR_RET_VAL( "Numeric overflow at line " << line_number(), false );
return true;
| bool moab::FileTokenizer::get_bytes | ( | size_t | count, |
| unsigned char * | array | ||
Read the specified number of space-delimited ints.
Definition at line 251 of file FileTokenizer.cpp.
References get_byte_internal().
if( !get_byte_internal( *array ) ) return false;
++array;
return true;
| bool moab::FileTokenizer::get_double_internal | ( | double & | result | ) | [private] |
Internal implementation of get_doubles
Definition at line 126 of file FileTokenizer.cpp.
Referenced by get_doubles(), and get_float_internal().
// Get a token
const char *token_end, *token = get_string();
// Check for hex value -- on some platforms (e.g. Linux), strtod
// will accept hex values, on others (e.g. Sun) it will not. Force
// failure on hex numbers for consistency.
if( token[0] && token[1] && token[0] == '0' && toupper( token[1] ) == 'X' )
MB_SET_ERR_RET_VAL( "Syntax error at line " << line_number() << ": expected number, got \"" << token << "\"",
false );
// Parse token as double
result = strtod( token, (char**)&token_end );
// If the one past the last char read by strtod is
// not the NULL character terminating the string,
// then parse failed.
if( *token_end )
false );
return true;
| bool moab::FileTokenizer::get_doubles | ( | size_t | count, |
| double * | array | ||
Read the specified number of space-delimited doubles.
Definition at line 240 of file FileTokenizer.cpp.
References get_double_internal().
Referenced by moab::ReadGmsh::load_file(), moab::ReadVtk::read_vertices(), moab::ReadVtk::vtk_read_field(), moab::ReadVtk::vtk_read_rectilinear_grid(), moab::ReadVtk::vtk_read_structured_points(), and moab::ReadVtk::vtk_read_tag_data().
if( !get_double_internal( *array ) ) return false;
++array;
return true;
| bool moab::FileTokenizer::get_float_internal | ( | float & | result | ) | [private] |
Internal implementation of get_floats
Definition at line 152 of file FileTokenizer.cpp.
Referenced by get_floats().
double d;
if( !get_double_internal( d ) ) return false;
result = (float)d;
return true;
| bool moab::FileTokenizer::get_floats | ( | size_t | count, |
| float * | array | ||
Definition at line 229 of file FileTokenizer.cpp.
References get_float_internal().
Referenced by moab::ReadSTL::ascii_read_triangles().
if( !get_float_internal( *array ) ) return false;
++array;
return true;
| bool moab::FileTokenizer::get_integer_internal | ( | int & | result | ) | [private] |
Internal implementation of get_integers
Definition at line 203 of file FileTokenizer.cpp.
Referenced by get_integers().
long i;
result = (int)i;
return true;
| bool moab::FileTokenizer::get_integers | ( | size_t | count, |
| int * | array | ||
Definition at line 273 of file FileTokenizer.cpp.
References get_integer_internal().
Referenced by moab::ReadGmsh::load_file(), moab::ReadVtk::vtk_read_tag_data(), and moab::ReadVtk::vtk_read_texture_attrib().
if( !get_integer_internal( *array ) ) return false;
++array;
return true;
| bool moab::FileTokenizer::get_long_int_internal | ( | long & | result | ) | [private] |
Internal implementation of get_long_ints
Definition at line 162 of file FileTokenizer.cpp.
Referenced by get_byte_internal(), get_integer_internal(), get_long_ints(), and get_short_int_internal().
// Get a token
// Parse token as long
result = strtol( token, (char**)&token_end, 0 );
// If the one past the last char read by strtol is
if( *token_end )
false );
return true;
| bool moab::FileTokenizer::get_long_ints | ( | size_t | count, |
| long * | array | ||
Definition at line 284 of file FileTokenizer.cpp.
References get_long_int_internal().
Referenced by moab::ReadVtk::load_file(), moab::ReadGmsh::load_file(), moab::ReadVtk::vtk_read_color_attrib(), moab::ReadVtk::vtk_read_field(), moab::ReadVtk::vtk_read_field_attrib(), moab::ReadVtk::vtk_read_polydata(), moab::ReadVtk::vtk_read_polygons(), moab::ReadVtk::vtk_read_rectilinear_grid(), moab::ReadVtk::vtk_read_structured_grid(), moab::ReadVtk::vtk_read_structured_points(), and moab::ReadVtk::vtk_read_unstructured_grid().
if( !get_long_int_internal( *array ) ) return false;
++array;
return true;
| bool moab::FileTokenizer::get_newline | ( | bool | report_error = true | ) |
check for newline
Consume whitespace up to and including the next newline. If a non-space character is found before a newline, the function will stop, set the error message, and return false.
Definition at line 372 of file FileTokenizer.cpp.
References buffer, bufferEnd, eof(), filePtr, lastChar, line_number(), lineNumber, MB_SET_ERR_RET_VAL, and nextToken.
Referenced by moab::ReadGmsh::load_file(), moab::ReadVtk::vtk_read_polydata(), moab::ReadVtk::vtk_read_polygons(), moab::ReadVtk::vtk_read_rectilinear_grid(), moab::ReadVtk::vtk_read_structured_grid(), moab::ReadVtk::vtk_read_structured_points(), and moab::ReadVtk::vtk_read_unstructured_grid().
if( lastChar == '\n' )
lastChar = ' ';
++lineNumber;
return true;
// Loop until either we a) find a newline, b) find a non-whitespace
// character or c) reach the end of the file.
for( ;; )
// If the buffer is empty, read more.
if( nextToken == bufferEnd )
size_t count = fread( buffer, 1, sizeof( buffer ), filePtr );
if( 0 == count )
if( eof() )
MB_SET_ERR_RET_VAL( "File truncated at line " << line_number(), false );
else
MB_SET_ERR_RET_VAL( "I/O Error", false );
nextToken = buffer;
bufferEnd = buffer + count;
// If the current character is not a space, the we've failed.
if( !isspace( *nextToken ) )
if( report_error ) MB_SET_ERR_RET_VAL( "Expected newline at line " << line_number(), false );
// If the current space character is a newline,
// increment the line number count.
if( *nextToken == '\n' )
++lineNumber;
++nextToken;
lastChar = ' ';
return true;
++nextToken;
return false;
| bool moab::FileTokenizer::get_short_int_internal | ( | short & | result | ) | [private] |
Internal implementation of get_short_ints
Definition at line 192 of file FileTokenizer.cpp.
Referenced by get_short_ints().
long i;
result = (short)i;
return true;
| bool moab::FileTokenizer::get_short_ints | ( | size_t | count, |
| short * | array | ||
Definition at line 262 of file FileTokenizer.cpp.
References get_short_int_internal().
if( !get_short_int_internal( *array ) ) return false;
++array;
return true;
| const char * moab::FileTokenizer::get_string | ( | ) |
get next token
Get the next whitespace-delimited token from the file. NOTE: The returned string is only valid until the next call to any of the functions in this class that read from the file.
Definition at line 45 of file FileTokenizer.cpp.
References buffer, bufferEnd, filePtr, lastChar, lineNumber, MB_SET_ERR_RET_VAL, and nextToken.
Referenced by get_boolean_internal(), get_double_internal(), get_long_int_internal(), moab::ReadGmsh::load_file(), match_token(), moab::ReadVtk::vtk_read_attrib_data(), moab::ReadVtk::vtk_read_field(), moab::ReadVtk::vtk_read_field_attrib(), and moab::ReadVtk::vtk_read_scalar_attrib().
// If the whitespace character marking the end of the
// last token was a newline, increment the line count.
if( lastChar == '\n' ) ++lineNumber;
// Loop until either found the start of a token to return or have
// reached the end of the file.
for( ;; )
size_t count = fread( buffer, 1, sizeof( buffer ) - 1, filePtr );
if( 0 == count )
if( feof( filePtr ) )
return NULL;
else
MB_SET_ERR_RET_VAL( "I/O Error", NULL );
nextToken = buffer;
// If the current character is not a space, we've found a token.
if( !isspace( *nextToken ) ) break;
if( *nextToken == '\n' ) ++lineNumber;
++nextToken;
// Store the start of the token in "result" and
// advance "nextToken" to one past the end of the
// token.
char* result = nextToken;
while( nextToken != bufferEnd && !isspace( static_cast< unsigned char >( *nextToken ) ) )
++nextToken;
// If we have reached the end of the buffer without finding
// a whitespace character terminating the token, we need to
// read more from the file. Only try once. If the token is
// too large to fit in the buffer, give up.
// Shift the (possibly) partial token to the start of the buffer.
size_t remaining = bufferEnd - result;
memmove( buffer, result, remaining );
result = buffer;
nextToken = result + remaining;
// Fill the remainder of the buffer after the token.
size_t count = fread( nextToken, 1, sizeof( buffer ) - remaining - 1, filePtr );
if( 0 == count && !feof( filePtr ) ) MB_SET_ERR_RET_VAL( "I/O Error", NULL );
bufferEnd = nextToken + count;
// Continue to advance nextToken until we find the space
// terminating the token.
while( nextToken != bufferEnd && !isspace( *nextToken ) )
++nextToken;
{ // EOF
*bufferEnd = '\0';
++bufferEnd;
// Save terminating whitespace character (or NULL char if EOF).
lastChar = *nextToken;
// Put null in buffer to mark end of current token.
*nextToken = '\0';
// Advance nextToken to the next character to search next time.
++nextToken;
return result;
| int moab::FileTokenizer::line_number | ( | ) | const [inline] |
Get the line number the last token was read from.
Definition at line 175 of file FileTokenizer.hpp.
References lineNumber.
Referenced by get_boolean_internal(), get_byte_internal(), get_double_internal(), get_integer_internal(), get_long_int_internal(), get_newline(), get_short_int_internal(), moab::ReadVtk::load_file(), moab::ReadGmsh::load_file(), match_token(), moab::ReadVtk::vtk_read_field_attrib(), moab::ReadVtk::vtk_read_polydata(), moab::ReadVtk::vtk_read_rectilinear_grid(), moab::ReadVtk::vtk_read_scalar_attrib(), moab::ReadVtk::vtk_read_structured_grid(), moab::ReadVtk::vtk_read_structured_points(), moab::ReadVtk::vtk_read_tag_data(), moab::ReadVtk::vtk_read_texture_attrib(), and moab::ReadVtk::vtk_read_unstructured_grid().
return lineNumber;
| bool moab::FileTokenizer::match_token | ( | const char * | string, |
| bool | print_error = true |
Match current token to passed string. If token doesn't match, set error message.
Definition at line 321 of file FileTokenizer.cpp.
References get_string(), line_number(), and MB_SET_ERR_CONT.
Referenced by moab::ReadSTL::ascii_read_triangles(), moab::ReadVtk::load_file(), moab::ReadGmsh::load_file(), moab::ReadVtk::vtk_read_attrib_data(), moab::ReadVtk::vtk_read_dataset(), moab::ReadVtk::vtk_read_field(), moab::ReadVtk::vtk_read_field_attrib(), moab::ReadVtk::vtk_read_polydata(), moab::ReadVtk::vtk_read_rectilinear_grid(), moab::ReadVtk::vtk_read_scalar_attrib(), moab::ReadVtk::vtk_read_structured_grid(), moab::ReadVtk::vtk_read_structured_points(), moab::ReadVtk::vtk_read_tensor_attrib(), moab::ReadVtk::vtk_read_texture_attrib(), moab::ReadVtk::vtk_read_unstructured_grid(), and moab::ReadVtk::vtk_read_vector_attrib().
// Get a token
// Check if it matches
if( 0 == strcmp( token, str ) ) return true;
// Construct error message
if( print_error )
MB_SET_ERR_CONT( "Syntax error at line " << line_number() << ": expected \"" << str << "\", got \"" << token
return false;
| int moab::FileTokenizer::match_token | ( | const char *const * | string_list, |
Match the current token to one of an array of strings. Sets the error message if the current token doesn't match any of the input strings.
| string_list | A NULL-terminated array of strings. |
Definition at line 338 of file FileTokenizer.cpp.
// Get a token
if( !token ) return 0;
// Check if it matches any input string
const char* const* ptr;
for( ptr = list; *ptr; ++ptr )
if( 0 == strcmp( token, *ptr ) ) return ptr - list + 1;
if( !print_error ) return 0;
// No match, constuct error message
std::string message( "Parsing error at line " );
char lineno[16];
sprintf( lineno, "%d", line_number() );
message += lineno;
message += ": expected one of {";
message += " ";
message += *ptr;
message += " } got \"";
message += token;
message += "\"";
MB_SET_ERR_CONT( message.c_str() );
return 0;
| void moab::FileTokenizer::unget_token | ( | ) |
Put current token back in buffer. Can only unget one token.
Definition at line 306 of file FileTokenizer.cpp.
References buffer, lastChar, and nextToken.
Referenced by moab::ReadVtk::load_file(), and moab::ReadVtk::vtk_read_scalar_attrib().
char moab::FileTokenizer::buffer[512] [private] |
Input buffer
Definition at line 223 of file FileTokenizer.hpp.
Referenced by get_newline(), get_string(), and unget_token().
char* moab::FileTokenizer::bufferEnd [private] |
One past the last used byte of the buffer
Definition at line 228 of file FileTokenizer.hpp.
Referenced by eof(), get_binary(), get_newline(), and get_string().
std::FILE* moab::FileTokenizer::filePtr [private] |
Pointer to standard C FILE struct
Definition at line 220 of file FileTokenizer.hpp.
Referenced by eof(), get_binary(), get_newline(), get_string(), and ~FileTokenizer().
char moab::FileTokenizer::lastChar [private] |
The whitespace character marking the end of the last returned token. Saved here because if it is a newline, the line count will need to be incremented when the next token is returned.
Definition at line 238 of file FileTokenizer.hpp.
int moab::FileTokenizer::lineNumber [private] |
Line number of last returned token
Definition at line 231 of file FileTokenizer.hpp.
Referenced by get_newline(), get_string(), and line_number().
char* moab::FileTokenizer::nextToken [private] |
One past the end of the last token returned
Definition at line 226 of file FileTokenizer.hpp.
Referenced by eof(), get_binary(), get_newline(), get_string(), and unget_token().
