MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 #include "FileTokenizer.hpp" 00017 #include "moab/ReadUtilIface.hpp" 00018 #include "moab/ErrorHandler.hpp" 00019 00020 #include <cstring> 00021 #include <cctype> 00022 #include <string> 00023 #include <cstdlib> 00024 00025 namespace moab 00026 { 00027 00028 using namespace std; 00029 00030 FileTokenizer::FileTokenizer( FILE* file_ptr, ReadUtilIface* ) 00031 : filePtr( file_ptr ), nextToken( buffer ), bufferEnd( buffer ), lineNumber( 1 ), lastChar( '\0' ) 00032 { 00033 } 00034 00035 FileTokenizer::~FileTokenizer() 00036 { 00037 fclose( filePtr ); 00038 } 00039 00040 bool FileTokenizer::eof() const 00041 { 00042 return nextToken == bufferEnd && feof( filePtr ); 00043 } 00044 00045 const char* FileTokenizer::get_string() 00046 { 00047 // If the whitespace character marking the end of the 00048 // last token was a newline, increment the line count. 00049 if( lastChar == '\n' ) ++lineNumber; 00050 00051 // Loop until either found the start of a token to return or have 00052 // reached the end of the file. 00053 for( ;; ) 00054 { 00055 // If the buffer is empty, read more. 00056 if( nextToken == bufferEnd ) 00057 { 00058 size_t count = fread( buffer, 1, sizeof( buffer ) - 1, filePtr ); 00059 if( 0 == count ) 00060 { 00061 if( feof( filePtr ) ) 00062 return NULL; 00063 else 00064 MB_SET_ERR_RET_VAL( "I/O Error", NULL ); 00065 } 00066 00067 nextToken = buffer; 00068 bufferEnd = buffer + count; 00069 } 00070 00071 // If the current character is not a space, we've found a token. 00072 if( !isspace( *nextToken ) ) break; 00073 00074 // If the current space character is a newline, 00075 // increment the line number count. 00076 if( *nextToken == '\n' ) ++lineNumber; 00077 ++nextToken; 00078 } 00079 00080 // Store the start of the token in "result" and 00081 // advance "nextToken" to one past the end of the 00082 // token. 00083 char* result = nextToken; 00084 while( nextToken != bufferEnd && !isspace( static_cast< unsigned char >( *nextToken ) ) ) 00085 ++nextToken; 00086 00087 // If we have reached the end of the buffer without finding 00088 // a whitespace character terminating the token, we need to 00089 // read more from the file. Only try once. If the token is 00090 // too large to fit in the buffer, give up. 00091 if( nextToken == bufferEnd ) 00092 { 00093 // Shift the (possibly) partial token to the start of the buffer. 00094 size_t remaining = bufferEnd - result; 00095 memmove( buffer, result, remaining ); 00096 result = buffer; 00097 nextToken = result + remaining; 00098 00099 // Fill the remainder of the buffer after the token. 00100 size_t count = fread( nextToken, 1, sizeof( buffer ) - remaining - 1, filePtr ); 00101 if( 0 == count && !feof( filePtr ) ) MB_SET_ERR_RET_VAL( "I/O Error", NULL ); 00102 bufferEnd = nextToken + count; 00103 00104 // Continue to advance nextToken until we find the space 00105 // terminating the token. 00106 while( nextToken != bufferEnd && !isspace( *nextToken ) ) 00107 ++nextToken; 00108 00109 if( nextToken == bufferEnd ) 00110 { // EOF 00111 *bufferEnd = '\0'; 00112 ++bufferEnd; 00113 } 00114 } 00115 00116 // Save terminating whitespace character (or NULL char if EOF). 00117 lastChar = *nextToken; 00118 // Put null in buffer to mark end of current token. 00119 *nextToken = '\0'; 00120 // Advance nextToken to the next character to search next time. 00121 ++nextToken; 00122 00123 return result; 00124 } 00125 00126 bool FileTokenizer::get_double_internal( double& result ) 00127 { 00128 // Get a token 00129 const char *token_end, *token = get_string(); 00130 if( !token ) return false; 00131 00132 // Check for hex value -- on some platforms (e.g. Linux), strtod 00133 // will accept hex values, on others (e.g. Sun) it will not. Force 00134 // failure on hex numbers for consistency. 00135 if( token[0] && token[1] && token[0] == '0' && toupper( token[1] ) == 'X' ) 00136 MB_SET_ERR_RET_VAL( "Syntax error at line " << line_number() << ": expected number, got \"" << token << "\"", 00137 false ); 00138 00139 // Parse token as double 00140 result = strtod( token, (char**)&token_end ); 00141 00142 // If the one past the last char read by strtod is 00143 // not the NULL character terminating the string, 00144 // then parse failed. 00145 if( *token_end ) 00146 MB_SET_ERR_RET_VAL( "Syntax error at line " << line_number() << ": expected number, got \"" << token << "\"", 00147 false ); 00148 00149 return true; 00150 } 00151 00152 bool FileTokenizer::get_float_internal( float& result ) 00153 { 00154 double d; 00155 if( !get_double_internal( d ) ) return false; 00156 00157 result = (float)d; 00158 00159 return true; 00160 } 00161 00162 bool FileTokenizer::get_long_int_internal( long& result ) 00163 { 00164 // Get a token 00165 const char *token_end, *token = get_string(); 00166 if( !token ) return false; 00167 00168 // Parse token as long 00169 result = strtol( token, (char**)&token_end, 0 ); 00170 00171 // If the one past the last char read by strtol is 00172 // not the NULL character terminating the string, 00173 // then parse failed. 00174 if( *token_end ) 00175 MB_SET_ERR_RET_VAL( "Syntax error at line " << line_number() << ": expected number, got \"" << token << "\"", 00176 false ); 00177 00178 return true; 00179 } 00180 00181 bool FileTokenizer::get_byte_internal( unsigned char& result ) 00182 { 00183 long i; 00184 if( !get_long_int_internal( i ) ) return false; 00185 00186 result = (unsigned char)i; 00187 if( i != (long)result ) MB_SET_ERR_RET_VAL( "Numeric overflow at line " << line_number(), false ); 00188 00189 return true; 00190 } 00191 00192 bool FileTokenizer::get_short_int_internal( short& result ) 00193 { 00194 long i; 00195 if( !get_long_int_internal( i ) ) return false; 00196 00197 result = (short)i; 00198 if( i != (long)result ) MB_SET_ERR_RET_VAL( "Numeric overflow at line " << line_number(), false ); 00199 00200 return true; 00201 } 00202 00203 bool FileTokenizer::get_integer_internal( int& result ) 00204 { 00205 long i; 00206 if( !get_long_int_internal( i ) ) return false; 00207 00208 result = (int)i; 00209 if( i != (long)result ) MB_SET_ERR_RET_VAL( "Numeric overflow at line " << line_number(), false ); 00210 00211 return true; 00212 } 00213 00214 bool FileTokenizer::get_boolean_internal( bool& result ) 00215 { 00216 // Get a token 00217 const char* token = get_string(); 00218 if( !token ) return false; 00219 00220 if( token[1] || ( token[0] != '0' && token[0] != '1' ) ) 00221 MB_SET_ERR_RET_VAL( "Syntax error at line " << line_number() << ": expected 0 or 1, got \"" << token << "\"", 00222 false ); 00223 00224 result = token[0] == '1'; 00225 00226 return true; 00227 } 00228 00229 bool FileTokenizer::get_floats( size_t count, float* array ) 00230 { 00231 for( size_t i = 0; i < count; ++i ) 00232 { 00233 if( !get_float_internal( *array ) ) return false; 00234 ++array; 00235 } 00236 00237 return true; 00238 } 00239 00240 bool FileTokenizer::get_doubles( size_t count, double* array ) 00241 { 00242 for( size_t i = 0; i < count; ++i ) 00243 { 00244 if( !get_double_internal( *array ) ) return false; 00245 ++array; 00246 } 00247 00248 return true; 00249 } 00250 00251 bool FileTokenizer::get_bytes( size_t count, unsigned char* array ) 00252 { 00253 for( size_t i = 0; i < count; ++i ) 00254 { 00255 if( !get_byte_internal( *array ) ) return false; 00256 ++array; 00257 } 00258 00259 return true; 00260 } 00261 00262 bool FileTokenizer::get_short_ints( size_t count, short* array ) 00263 { 00264 for( size_t i = 0; i < count; ++i ) 00265 { 00266 if( !get_short_int_internal( *array ) ) return false; 00267 ++array; 00268 } 00269 00270 return true; 00271 } 00272 00273 bool FileTokenizer::get_integers( size_t count, int* array ) 00274 { 00275 for( size_t i = 0; i < count; ++i ) 00276 { 00277 if( !get_integer_internal( *array ) ) return false; 00278 ++array; 00279 } 00280 00281 return true; 00282 } 00283 00284 bool FileTokenizer::get_long_ints( size_t count, long* array ) 00285 { 00286 for( size_t i = 0; i < count; ++i ) 00287 { 00288 if( !get_long_int_internal( *array ) ) return false; 00289 ++array; 00290 } 00291 00292 return true; 00293 } 00294 00295 bool FileTokenizer::get_booleans( size_t count, bool* array ) 00296 { 00297 for( size_t i = 0; i < count; ++i ) 00298 { 00299 if( !get_boolean_internal( *array ) ) return false; 00300 ++array; 00301 } 00302 00303 return true; 00304 } 00305 00306 void FileTokenizer::unget_token() 00307 { 00308 if( nextToken - buffer < 2 ) return; 00309 00310 --nextToken; 00311 *nextToken = lastChar; 00312 --nextToken; 00313 while( nextToken > buffer && *nextToken ) 00314 --nextToken; 00315 00316 if( !*nextToken ) ++nextToken; 00317 00318 lastChar = '\0'; 00319 } 00320 00321 bool FileTokenizer::match_token( const char* str, bool print_error ) 00322 { 00323 // Get a token 00324 const char* token = get_string(); 00325 if( !token ) return false; 00326 00327 // Check if it matches 00328 if( 0 == strcmp( token, str ) ) return true; 00329 00330 // Construct error message 00331 if( print_error ) 00332 MB_SET_ERR_CONT( "Syntax error at line " << line_number() << ": expected \"" << str << "\", got \"" << token 00333 << "\"" ); 00334 00335 return false; 00336 } 00337 00338 int FileTokenizer::match_token( const char* const* list, bool print_error ) 00339 { 00340 // Get a token 00341 const char* token = get_string(); 00342 if( !token ) return 0; 00343 00344 // Check if it matches any input string 00345 const char* const* ptr; 00346 for( ptr = list; *ptr; ++ptr ) 00347 { 00348 if( 0 == strcmp( token, *ptr ) ) return ptr - list + 1; 00349 } 00350 00351 if( !print_error ) return 0; 00352 00353 // No match, constuct error message 00354 std::string message( "Parsing error at line " ); 00355 char lineno[16]; 00356 sprintf( lineno, "%d", line_number() ); 00357 message += lineno; 00358 message += ": expected one of {"; 00359 for( ptr = list; *ptr; ++ptr ) 00360 { 00361 message += " "; 00362 message += *ptr; 00363 } 00364 message += " } got \""; 00365 message += token; 00366 message += "\""; 00367 MB_SET_ERR_CONT( message.c_str() ); 00368 00369 return 0; 00370 } 00371 00372 bool FileTokenizer::get_newline( bool report_error ) 00373 { 00374 if( lastChar == '\n' ) 00375 { 00376 lastChar = ' '; 00377 ++lineNumber; 00378 return true; 00379 } 00380 00381 // Loop until either we a) find a newline, b) find a non-whitespace 00382 // character or c) reach the end of the file. 00383 for( ;; ) 00384 { 00385 // If the buffer is empty, read more. 00386 if( nextToken == bufferEnd ) 00387 { 00388 size_t count = fread( buffer, 1, sizeof( buffer ), filePtr ); 00389 if( 0 == count ) 00390 { 00391 if( eof() ) 00392 MB_SET_ERR_RET_VAL( "File truncated at line " << line_number(), false ); 00393 else 00394 MB_SET_ERR_RET_VAL( "I/O Error", false ); 00395 } 00396 00397 nextToken = buffer; 00398 bufferEnd = buffer + count; 00399 } 00400 00401 // If the current character is not a space, the we've failed. 00402 if( !isspace( *nextToken ) ) 00403 if( report_error ) MB_SET_ERR_RET_VAL( "Expected newline at line " << line_number(), false ); 00404 00405 // If the current space character is a newline, 00406 // increment the line number count. 00407 if( *nextToken == '\n' ) 00408 { 00409 ++lineNumber; 00410 ++nextToken; 00411 lastChar = ' '; 00412 return true; 00413 } 00414 ++nextToken; 00415 } 00416 00417 return false; 00418 } 00419 00420 bool FileTokenizer::get_binary( size_t size, void* mem ) 00421 { 00422 // If data in buffer 00423 if( nextToken != bufferEnd ) 00424 { 00425 // If requested size is less than buffer contents, 00426 // just pass back part of the buffer 00427 if( bufferEnd - nextToken <= (int)size ) 00428 { 00429 memcpy( mem, nextToken, size ); 00430 nextToken += size; 00431 return true; 00432 } 00433 00434 // Copy buffer contents into memory and clear buffer 00435 memcpy( mem, nextToken, bufferEnd - nextToken ); 00436 size -= bufferEnd - nextToken; 00437 mem = reinterpret_cast< char* >( mem ) + ( bufferEnd - nextToken ); 00438 nextToken = bufferEnd; 00439 } 00440 00441 // Read any additional data from file 00442 return size == fread( mem, 1, size, filePtr ); 00443 } 00444 00445 } // namespace moab
