parallel_unit_tests.cpp File Reference
#include "moab/ParallelComm.hpp"
#include "MBParallelConventions.h"
#include "moab/ParCommGraph.hpp"
#include "ReadParallel.hpp"
#include "moab/FileOptions.hpp"
#include "MBTagConventions.hpp"
#include "moab/Core.hpp"
#include "moab_mpi.h"
#include "TestUtil.hpp"
#include <iostream>
#include <algorithm>
#include <map>
#include <sstream>
#include <cassert>
#include <unistd.h>
+ Include dependency graph for parallel_unit_tests.cpp:
Classes
struct  VtxData
Defines
#define CHKERR(a)
#define PCHECK(A)   if( is_any_proc_error( !( A ) ) ) return report_error( __FILE__, __LINE__ )
#define RUN_TEST_ARG2(A, B)   run_test( &( A ), #A, B )
Functions
ErrorCode report_error (const char *file, int line)
ErrorCode get_sharing_processors (Interface &moab, EntityHandle entity, std::vector< int > &other_procs_out)
ErrorCode parallel_create_mesh (Interface &mb, int output_vertx_ids[9], EntityHandle output_vertex_handles[9], Range &output_elements, EntityHandle output_sets[3]=0)
int is_any_proc_error (int is_my_error)
ErrorCode test_elements_on_several_procs (const char *filename)
ErrorCode test_ghost_elements_3_2_1 (const char *filename)
ErrorCode test_ghost_elements_3_2_2 (const char *filename)
ErrorCode test_ghost_elements_3_0_1 (const char *filename)
ErrorCode test_ghost_elements_2_0_1 (const char *filename)
ErrorCode test_ghost_tag_exchange (const char *filename)
ErrorCode regression_ghost_tag_exchange_no_default (const char *filename)
ErrorCode test_interface_owners (const char *)
ErrorCode regression_owners_with_ghosting (const char *)
ErrorCode test_ghosted_entity_shared_data (const char *)
ErrorCode test_assign_global_ids (const char *)
ErrorCode test_shared_sets (const char *)
ErrorCode test_reduce_tags (const char *)
ErrorCode test_reduce_tag_failures (const char *)
ErrorCode test_reduce_tag_explicit_dest (const char *)
ErrorCode test_delete_entities (const char *)
ErrorCode test_ghost_polyhedra (const char *)
ErrorCode test_too_few_parts (const char *)
ErrorCode test_sequences_after_ghosting (const char *)
void test_trivial_partition ()
int run_test (ErrorCode(*func)(const char *), const char *func_name, const char *file_name)
int main (int argc, char *argv[])
ErrorCode parallel_create_mesh (Interface &mb, int vtx_ids[9], EntityHandle vtx_handles[9], Range &range, EntityHandle *entity_sets)
ErrorCode get_ghost_entities (ParallelComm &pcomm, Range &ghost_ents)
ErrorCode get_ents_from_geometric_sets (Interface &moab, const Tag tags[2], int dimension, const std::vector< int > &ids, Range &results)
ErrorCode get_expected_ghosts (Interface &moab, const std::vector< int > partition_geom_ids[4], std::vector< int > &ghost_entity_ids, int ghost_dimension, int bridge_dimension, int num_layers)
 Given entire file and IDs of geometric sets, get expected ghost entities.
ErrorCode test_ghost_elements (const char *filename, int ghost_dimension, int bridge_dimension, int num_layers)
ErrorCode get_owner_handles (ParallelComm *pcomm, const Range &ents, EntityHandle *handle_arr)
int MPI_swap (void *buffer, int num_val, MPI_Datatype val_type, int other_proc)
int valid_ghosting_owners (int comm_size, const int *ids, const int *owners)
ErrorCode test_interface_owners_common (int num_ghost_layers)
ErrorCode check_consistent_ids (Interface &mb, const EntityHandle *entities, const int *orig_ids, int num_ents, const char *singular_name, const char *plural_name)
template<typename T >
ErrorCode check_shared_ents (ParallelComm &pcomm, Tag tagh, T fact, MPI_Op mpi_op)
ErrorCode test_reduce_tags (const char *, DataType tp)
Define Documentation
#define RUN_TEST_ARG2 (   A,
  B
Definition at line 150 of file parallel_unit_tests.cpp.
Referenced by main().
Function Documentation
ErrorCode check_consistent_ids ( Interface &  mb,
const EntityHandle *  entities,
const int *  orig_ids,
int  num_ents,
const char *  singular_name,
const char *  plural_name
Definition at line 1162 of file parallel_unit_tests.cpp.
References CHKERR, ErrorCode, moab::Interface::globalId_tag(), id_tag, ierr, MB_SUCCESS, MPI_COMM_WORLD, rank, size, and moab::Interface::tag_get_data().
Referenced by test_assign_global_ids().
    ErrorCode rval;
    int rank, size, ierr;
    MPI_Comm_rank( MPI_COMM_WORLD, &rank );
    MPI_Comm_size( MPI_COMM_WORLD, &size );
    Tag id_tag = mb.globalId_tag();
    std::vector< int > new_ids( num_ents );
    rval = mb.tag_get_data( id_tag, entities, num_ents, &new_ids[0] );CHKERR( rval );
    // This test is wrong.  a) The caller can select a start ID so there's
    // no guarantee that the IDs will be in any specific range and b) There
    // is no reason to expect the global number of entities to be num_ents*size
    // if there are any shared entities. J.Kraftcheck 2010-12-22
    // rval = MB_SUCCESS;
    // for (int i = 0; i < num_ents; ++i)
    //  if (new_ids[i] < 0 || new_ids[i] >= num_ents*size) {
    //    std::cerr << "ID out of bounds on proc " << rank
    //              << " : " << new_ids[i] << " not in [0," << num_ents*size-1
    //              << "]" << std::endl;
    //    rval = MB_FAILURE;
    // if (MB_SUCCESS != rval)
    //  return rval;
    // Gather up all data on root proc for consistency check
    std::vector< int > all_orig_ids( num_ents * size ), all_new_ids( num_ents * size );
    ierr = MPI_Gather( (void*)orig_ids, num_ents, MPI_INT, &all_orig_ids[0], num_ents, MPI_INT, 0, MPI_COMM_WORLD );
    if( ierr ) return MB_FAILURE;
    ierr = MPI_Gather( &new_ids[0], num_ents, MPI_INT, &all_new_ids[0], num_ents, MPI_INT, 0, MPI_COMM_WORLD );
    // build a local map from original ID to new ID and use it
    // to check for consistancy between all procs
    rval = MB_SUCCESS;
    if( 0 == rank )
        // check for two processors having different global ID for same entity
        std::map< int, int > idmap;  // index by original ID and contains new ID
        std::map< int, int > owner;  // index by original ID and contains owning rank
        for( int i = 0; i < num_ents * size; ++i )
            std::map< int, int >::iterator it = idmap.find( all_orig_ids[i] );
            if( it == idmap.end() )
                idmap[all_orig_ids[i]] = all_new_ids[i];
                owner[all_orig_ids[i]] = i / num_ents;
            else if( it->second != all_new_ids[i] )
                std::cerr << "Inconsistant " << singular_name << " IDs between processors " << owner[all_orig_ids[i]]
                          << " and " << i / num_ents << " : " << it->second << " and " << all_new_ids[i]
                          << " respectively." << std::endl;
                rval = MB_FAILURE;
        // check for two processors having same global ID for different entities
        idmap.clear();
        owner.clear();
            std::map< int, int >::iterator it = idmap.find( all_new_ids[i] );
                idmap[all_new_ids[i]] = all_orig_ids[i];
                owner[all_new_ids[i]] = i / num_ents;
            else if( it->second != all_orig_ids[i] )
                std::cerr << "ID " << all_new_ids[i] << " assigned to different " << plural_name << " on processors "
                          << owner[all_new_ids[i]] << " and " << i / num_ents << std::endl;
                rval = MB_FAILURE;
    return rval;
ErrorCode check_shared_ents ( ParallelComm &  pcomm,
Tag  tagh,
T  fact,
MPI_Op  mpi_op
Definition at line 1474 of file parallel_unit_tests.cpp.
References moab::Range::begin(), CHKERR, moab::Range::end(), ErrorCode, moab::ParallelComm::get_moab(), moab::ParallelComm::get_shared_entities(), moab::ParallelComm::get_sharing_data(), MAX_SHARING_PROCS, MB_SUCCESS, np, moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), moab::ParallelComm::rank(), moab::Range::size(), and moab::Interface::tag_get_data().
Referenced by test_reduce_tags().
    // get the shared entities
    Range shared_ents;
    ErrorCode rval = pcomm.get_shared_entities( -1, shared_ents );CHKERR( rval );
    std::vector< int > shprocs( MAX_SHARING_PROCS );
    std::vector< EntityHandle > shhandles( MAX_SHARING_PROCS );
    std::vector< T > dum_vals( shared_ents.size() );
    int np;
    unsigned char pstatus;
    rval = pcomm.get_moab()->tag_get_data( tagh, shared_ents, &dum_vals[0] );CHKERR( rval );
    // for each, compare number of sharing procs against tag value, should be 1/fact the tag value
    Range::iterator rit;
    int i = 0;
    for( rit = shared_ents.begin(); rit != shared_ents.end(); ++rit, i++ )
        rval = pcomm.get_sharing_data( *rit, &shprocs[0], &shhandles[0], pstatus, np );CHKERR( rval );
        if( 1 == np && shprocs[0] != (int)pcomm.proc_config().proc_rank() ) np++;
        bool with_root = std::find( &shprocs[0], &shprocs[np], 0 ) - &shprocs[0] != np || !pcomm.rank();
        if( mpi_op == MPI_SUM )
            if( dum_vals[i] != fact * np ) return MB_FAILURE;
        else if( mpi_op == MPI_PROD )
            if( dum_vals[i] != pow( fact, np ) ) return MB_FAILURE;
        else if( mpi_op == MPI_MAX )
            if( with_root && dum_vals[i] != fact ) return MB_FAILURE;
        else if( mpi_op == MPI_MIN )
        else
            return MB_FAILURE;
    return MB_SUCCESS;
ErrorCode get_ents_from_geometric_sets ( Interface &  moab,
const Tag  tags[2],
int  dimension,
const std::vector< int > &  ids,
Range &  results
Definition at line 578 of file parallel_unit_tests.cpp.
References moab::Range::begin(), CHKERR, moab::Range::end(), ErrorCode, moab::Interface::get_entities_by_dimension(), moab::Interface::get_entities_by_type_and_tag(), MB_SUCCESS, MBENTITYSET, and moab::Range::merge().
Referenced by get_expected_ghosts().
    ErrorCode rval;
    for( size_t i = 0; i < ids.size(); ++i )
        const void* tag_vals[2] = { &dimension, &ids[i] };
        Range sets;
        rval = moab.get_entities_by_type_and_tag( 0, MBENTITYSET, tags, tag_vals, 2, sets );CHKERR( rval );
        for( Range::iterator j = sets.begin(); j != sets.end(); ++j )
            Range ents;
            rval = moab.get_entities_by_dimension( *j, dimension, ents );CHKERR( rval );
            results.merge( ents );
    return MB_SUCCESS;
ErrorCode get_expected_ghosts ( Interface &  moab,
std::vector< int > &  ghost_entity_ids,
int  num_layers
Parameters:
moabThe entire mesh, loaded in serial
partition_geom_idsIDs of: geometric volumes owned by this proc and interface topology
ghost_entity_idsoutput list
Definition at line 606 of file parallel_unit_tests.cpp.
References CHKERR, moab::Range::clear(), ErrorCode, GEOM_DIMENSION_TAG_NAME, moab::Interface::get_adjacencies(), get_ents_from_geometric_sets(), moab::Interface::globalId_tag(), MB_SUCCESS, MB_TYPE_INTEGER, moab::Range::size(), skin(), moab::subtract(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), and moab::Interface::UNION.
Referenced by test_ghost_elements().
    ErrorCode rval;
    Tag tags[2];
    rval = moab.tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, tags[0] );CHKERR( rval );
    tags[1] = moab.globalId_tag();
    // get face entities defining interface
    Range skin;
    rval = get_ents_from_geometric_sets( moab, tags, 2, partition_geom_ids[2], skin );CHKERR( rval );
    // get adjacent entities
    Range iface_ghosts, iface_ents;
    if( bridge_dimension == 2 )
        iface_ents = skin;
    else
        rval = moab.get_adjacencies( skin, bridge_dimension, true, iface_ents, Interface::UNION );CHKERR( rval );
    for( int n = 0; n < num_layers; ++n )
        iface_ghosts.clear();
        rval = moab.get_adjacencies( iface_ents, ghost_dimension, false, iface_ghosts, Interface::UNION );CHKERR( rval );
        iface_ents.clear();
        rval = moab.get_adjacencies( iface_ghosts, bridge_dimension, true, iface_ents, Interface::UNION );CHKERR( rval );
    // get volume entities owned by this process
    Range ents;
    rval = get_ents_from_geometric_sets( moab, tags, 3, partition_geom_ids[3], ents );CHKERR( rval );
    // get entities of ghost_dimension owned by this process
    Range owned;
    if( ghost_dimension == 3 )
        owned = ents;
    else
        rval = moab.get_adjacencies( ents, ghost_dimension, false, owned, Interface::UNION );CHKERR( rval );
    // remove owned entities from ghost list
    Range ghosts = subtract( iface_ghosts, owned );
    // get ids
    ghost_entity_ids.resize( ghosts.size() );
    rval = moab.tag_get_data( tags[1], ghosts, &ghost_entity_ids[0] );CHKERR( rval );
    return MB_SUCCESS;
ErrorCode get_ghost_entities ( ParallelComm &  pcomm,
Range &  ghost_ents
Definition at line 561 of file parallel_unit_tests.cpp.
References moab::Range::begin(), CHKERR, moab::Range::end(), ErrorCode, moab::Interface::get_entities_by_handle(), moab::ParallelComm::get_moab(), moab::Range::insert(), MB_SUCCESS, PSTATUS_INTERFACE, PSTATUS_NOT_OWNED, moab::ParallelComm::pstatus_tag(), moab::Range::size(), and moab::Interface::tag_get_data().
    Range all_ents;
    ErrorCode rval;
    rval = pcomm.get_moab()->get_entities_by_handle( 0, all_ents );CHKERR( rval );
    std::vector< unsigned char > flags( all_ents.size() );
    rval = pcomm.get_moab()->tag_get_data( pcomm.pstatus_tag(), all_ents, &flags[0] );CHKERR( rval );
    Range::iterator ins                            = ghost_ents.begin();
    std::vector< unsigned char >::const_iterator f = flags.begin();
    for( Range::iterator i = all_ents.begin(); i != all_ents.end(); ++i, ++f )
        if( ( *f & PSTATUS_NOT_OWNED ) && !( *f & PSTATUS_INTERFACE ) ) ins = ghost_ents.insert( ins, *i, *i );
    return MB_SUCCESS;
ErrorCode get_owner_handles ( ParallelComm *  pcomm,
const Range &  ents,
EntityHandle *  handle_arr
Definition at line 849 of file parallel_unit_tests.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, moab::ParallelComm::get_owner_handle(), and MB_SUCCESS.
Referenced by test_ghost_tag_exchange().
    size_t i = 0;
    int junk;
    for( Range::iterator j = ents.begin(); j != ents.end(); ++i, ++j )
        ErrorCode rval = pcomm->get_owner_handle( *j, junk, handle_arr[i] );
        if( MB_SUCCESS != rval ) return rval;
    return MB_SUCCESS;
ErrorCode get_sharing_processors ( Interface &  moab,
std::vector< int > &  other_procs_out
Definition at line 273 of file parallel_unit_tests.cpp.
References CHKERR, ErrorCode, MAX_SHARING_PROCS, MB_SUCCESS, MB_TYPE_HANDLE, MB_TYPE_INTEGER, MB_TYPE_OPAQUE, PARALLEL_SHARED_HANDLE_TAG_NAME, PARALLEL_SHARED_HANDLES_TAG_NAME, PARALLEL_SHARED_PROC_TAG_NAME, PARALLEL_SHARED_PROCS_TAG_NAME, PARALLEL_STATUS_TAG_NAME, PSTATUS_SHARED, moab::Interface::tag_get_data(), and moab::Interface::tag_get_handle().
Referenced by test_elements_on_several_procs(), and test_ghost_elements().
    ErrorCode rval;
    // get tags for parallel data
    Tag sharedp_tag, sharedps_tag, sharedh_tag, sharedhs_tag, pstatus_tag;
    rval = moab.tag_get_handle( PARALLEL_SHARED_PROC_TAG_NAME, 1, MB_TYPE_INTEGER, sharedp_tag );CHKERR( rval );
    rval = moab.tag_get_handle( PARALLEL_SHARED_PROCS_TAG_NAME, MAX_SHARING_PROCS, MB_TYPE_INTEGER, sharedps_tag );CHKERR( rval );
    rval = moab.tag_get_handle( PARALLEL_SHARED_HANDLE_TAG_NAME, 1, MB_TYPE_HANDLE, sharedh_tag );CHKERR( rval );
    rval = moab.tag_get_handle( PARALLEL_SHARED_HANDLES_TAG_NAME, MAX_SHARING_PROCS, MB_TYPE_HANDLE, sharedhs_tag );CHKERR( rval );
    rval = moab.tag_get_handle( PARALLEL_STATUS_TAG_NAME, 1, MB_TYPE_OPAQUE, pstatus_tag );CHKERR( rval );
    other_procs_out.clear();
    char status;
    rval = moab.tag_get_data( pstatus_tag, &entity, 1, &status );CHKERR( rval );
    if( !( status & PSTATUS_SHARED ) ) return MB_SUCCESS;
    int proc_id;
    rval = moab.tag_get_data( sharedp_tag, &entity, 1, &proc_id );CHKERR( rval );
    if( proc_id >= 0 )
        other_procs_out.push_back( proc_id );
        return MB_SUCCESS;
    int procs[MAX_SHARING_PROCS];
    rval = moab.tag_get_data( sharedps_tag, &entity, 1, procs );CHKERR( rval );
    for( int i = 0; i < MAX_SHARING_PROCS && procs[i] >= 0; ++i )
        other_procs_out.push_back( procs[i] );
    return MB_SUCCESS;
int is_any_proc_error ( int  is_my_error)
int main ( int  argc,
char *  argv[]
Definition at line 169 of file parallel_unit_tests.cpp.
References filename, filename2, MPI_COMM_WORLD, rank, regression_ghost_tag_exchange_no_default(), regression_owners_with_ghosting(), RUN_TEST, RUN_TEST_ARG2, size, test_assign_global_ids(), test_delete_entities(), test_elements_on_several_procs(), test_ghost_elements_2_0_1(), test_ghost_elements_3_0_1(), test_ghost_elements_3_2_1(), test_ghost_elements_3_2_2(), test_ghost_polyhedra(), test_ghost_tag_exchange(), test_ghosted_entity_shared_data(), test_interface_owners(), test_reduce_tag_explicit_dest(), test_reduce_tag_failures(), test_reduce_tags(), test_sequences_after_ghosting(), test_shared_sets(), test_too_few_parts(), and test_trivial_partition().
    int rank, size;
    MPI_Init( &argc, &argv );
    int pause_proc = -1;
    std::string filename;
    for( int i = 1; i < argc; ++i )
        if( !strcmp( argv[i], "-p" ) )
            ++i;
            assert( i < argc );
            pause_proc = atoi( argv[i] );
        else if( !filename.size() )
            filename = std::string( argv[i] );
        else
            std::cerr << "Invalid arg: \"" << argv[i] << '"' << std::endl
                      << "Usage: " << argv[0] << " [-p <rank>] [<filename>]" << std::endl;
            exit( 1 );
#ifdef MOAB_HAVE_HDF5
        filename = TestDir + "unittest/64bricks_512hex.h5m";
#else
        filename = TestDir + "unittest/64bricks_512hex.vtk";
#endif
    std::cout << "Loading " << filename << "..\n";
    std::string filename2 = TestDir + "unittest/64bricks_1khex.h5m";
    std::string filename3 = TestDir + "unittest/twoPolyh.h5m";
    std::string filename4 = TestDir + "unittest/onepart.h5m";
#endif
    if( pause_proc != -1 )
#if !defined( _MSC_VER ) && !defined( __MINGW32__ )
        std::cout << "Processor " << rank << " of " << size << " with PID " << getpid() << std::endl;
        std::cout.flush();
#endif
        // loop forever on requested processor, giving the user time
        // to attach a debugger.  Once the debugger in attached, user
        // can change 'pause'.  E.g. on gdb do "set var pause = 0"
        if( pause_proc == rank )
            volatile int pause = 1;
            while( pause )
        MPI_Barrier( MPI_COMM_WORLD );
        std::cout << "Processor " << rank << " resuming" << std::endl;
    int num_errors = 0;
    num_errors += RUN_TEST_ARG2( test_elements_on_several_procs, filename.c_str() );
    num_errors += RUN_TEST_ARG2( test_ghost_elements_3_2_1, filename.c_str() );
    num_errors += RUN_TEST_ARG2( test_ghost_elements_3_2_2, filename.c_str() );
    num_errors += RUN_TEST_ARG2( test_ghost_elements_3_0_1, filename.c_str() );
    num_errors += RUN_TEST_ARG2( test_ghost_elements_2_0_1, filename.c_str() );
    num_errors += RUN_TEST_ARG2( test_ghost_tag_exchange, filename.c_str() );
    num_errors += RUN_TEST_ARG2( regression_ghost_tag_exchange_no_default, filename.c_str() );
    num_errors += RUN_TEST_ARG2( test_delete_entities, filename2.c_str() );
    num_errors += RUN_TEST_ARG2( test_sequences_after_ghosting, filename2.c_str() );
    if( 2 >= size )  // run this one only on one or 2 processors; the file has only 2 parts in partition
        num_errors += RUN_TEST_ARG2( test_ghost_polyhedra, filename3.c_str() );
    num_errors += RUN_TEST_ARG2( test_too_few_parts, filename4.c_str() );
#endif
    num_errors += RUN_TEST_ARG2( test_assign_global_ids, 0 );
    num_errors += RUN_TEST_ARG2( test_shared_sets, 0 );
    num_errors += RUN_TEST_ARG2( test_reduce_tags, 0 );
    num_errors += RUN_TEST_ARG2( test_reduce_tag_failures, 0 );
    num_errors += RUN_TEST_ARG2( test_reduce_tag_explicit_dest, 0 );
    num_errors += RUN_TEST_ARG2( test_interface_owners, 0 );
    num_errors += RUN_TEST_ARG2( test_ghosted_entity_shared_data, 0 );
    num_errors += RUN_TEST_ARG2( regression_owners_with_ghosting, 0 );
    num_errors += RUN_TEST( test_trivial_partition );
    if( rank == 0 )
        if( !num_errors )
            std::cout << "All tests passed" << std::endl;
        else
            std::cout << num_errors << " TESTS FAILED!" << std::endl;
    MPI_Finalize();
    return num_errors;
int MPI_swap ( void *  buffer,
int  num_val,
int  other_proc
Definition at line 997 of file parallel_unit_tests.cpp.
References MPI_COMM_WORLD, and rank.
    int err, rank, bytes;
    MPI_Type_size( val_type, &bytes );
    bytes *= num_val;
    std::vector< unsigned char > buffer2( bytes );
    for( int i = 0; i < 2; ++i )
        if( i == ( rank < other_proc ) )
            err = MPI_Send( buffer, num_val, val_type, other_proc, 0, MPI_COMM_WORLD );
            if( err ) return err;
        else
            MPI_Status status;
            err = MPI_Recv( &buffer2[0], num_val, val_type, other_proc, 0, MPI_COMM_WORLD, &status );
    memcpy( buffer, &buffer2[0], bytes );
    return 0;
ErrorCode parallel_create_mesh ( Interface &  mb,
int  vtx_ids[9],
Range &  range,
EntityHandle *  entity_sets
Definition at line 312 of file parallel_unit_tests.cpp.
References moab::Interface::add_entities(), moab::Range::begin(), CHKERR, moab::Range::clear(), moab::Interface::create_element(), moab::Interface::create_meshset(), moab::Interface::create_vertices(), moab::Range::end(), ErrorCode, moab::Interface::globalId_tag(), id_tag, moab::Range::insert(), MB_SUCCESS, MBQUAD, MESHSET_SET, MPI_COMM_WORLD, rank, size, moab::Range::size(), and moab::Interface::tag_set_data().
    // Each processor will create four quads.
    // Groups of four quads will be arranged as follows:
    // +    Proc 0   +    Proc 2   +    Proc 4
    // +    Proc 1   +    Proc 3   +    Proc 5
    // Vertices will be enumerated as follows:
    // 1------6-----11-----16-----21-----26-----
    // 2      7     12     17     22     27
    // 3------8-----13-----18-----23-----28-----
    // 4      9     14     19     24     29
    // 5-----10-----15-----20-----25-----30-----
    // Element IDs will be [4*rank+1,4*rank+5]
    int size, rank;
    const int first_vtx_id = 10 * ( rank / 2 ) + 2 * ( rank % 2 ) + 1;
    const double x         = 2.0 * ( rank / 2 );
    const double y         = 2.0 * ( rank % 2 );
    // create vertices
    const int idoff  = ( size % 2 && rank / 2 == size / 2 ) ? 0 : 2;
    const int idoff1 = rank ? 2 : idoff;
    const int idoff2 = idoff1 + idoff;
    const int ids[9] = { first_vtx_id,     first_vtx_id + 3 + idoff1, first_vtx_id + 6 + idoff2,
                         first_vtx_id + 1, first_vtx_id + 4 + idoff1, first_vtx_id + 7 + idoff2,
                         first_vtx_id + 2, first_vtx_id + 5 + idoff1, first_vtx_id + 8 + idoff2 };
    memcpy( vtx_ids, ids, sizeof( ids ) );
    const double coords[27] = { x, y,     0,     x + 1, y, 0,     x + 2, y,     0,     x, y + 1, 0,     x + 1, y + 1,
                                0, x + 2, y + 1, 0,     x, y + 2, 0,     x + 1, y + 2, 0, x + 2, y + 2, 0 };
    ErrorCode rval;
    Tag id_tag;
    rval = mb.create_vertices( coords, 9, range );CHKERR( rval );
    assert( range.size() == 9 );
    std::copy( range.begin(), range.end(), vtx_handles );
    range.clear();
    rval   = mb.tag_set_data( id_tag, vtx_handles, 9, &ids );CHKERR( rval );
    const EntityHandle conn[4][4] = { { vtx_handles[0], vtx_handles[3], vtx_handles[4], vtx_handles[1] },
                                      { vtx_handles[1], vtx_handles[4], vtx_handles[5], vtx_handles[2] },
                                      { vtx_handles[3], vtx_handles[6], vtx_handles[7], vtx_handles[4] },
                                      { vtx_handles[4], vtx_handles[7], vtx_handles[8], vtx_handles[5] } };
    for( int i = 0; i < 4; ++i )
        const int id = 4 * rank + i + 1;
        EntityHandle h;
        rval = mb.create_element( MBQUAD, conn[i], 4, h );CHKERR( rval );
        range.insert( h );
        rval = mb.tag_set_data( id_tag, &h, 1, &id );CHKERR( rval );
    if( !entity_sets ) return MB_SUCCESS;
    int set_ids[3] = { size + 1, rank / 2, rank / 2 + 1 };
    int nsets      = 0;
    rval           = mb.create_meshset( MESHSET_SET, entity_sets[nsets++] );CHKERR( rval );
    entity_sets[nsets] = 0;
    if( rank < 2 )
    {  // if first (left-most) column
        set_ids[1] = set_ids[2];
    else if( rank / 2 < ( size - 1 ) / 2 )
    {  // if not last (right-most) column
    for( int i = 0; i < nsets; ++i )
        rval = mb.add_entities( entity_sets[0], range );CHKERR( rval );
    rval = mb.tag_set_data( id_tag, entity_sets, nsets, set_ids );CHKERR( rval );
    return MB_SUCCESS;
Definition at line 957 of file parallel_unit_tests.cpp.
References CHKERR, ErrorCode, moab::ParallelComm::exchange_tags(), moab::ParallelComm::get_pcomm(), moab::Interface::load_file(), mb_instance(), MB_SUCCESS, MB_TAG_DENSE, MB_TAG_EXCL, MB_TYPE_HANDLE, PCHECK, and moab::Interface::tag_get_handle().
    Core mb_instance;
    Interface& moab = mb_instance;
    ErrorCode rval;
    rval = moab.load_file( filename, 0,
                           "PARALLEL=READ_DELETE;"
                           "PARTITION=GEOM_DIMENSION;PARTITION_VAL=3;"
                           "PARTITION_DISTRIBUTE;"
                           "PARALLEL_RESOLVE_SHARED_ENTS;"
                           "PARALLEL_GHOSTS=3.2.1" );
#else
                           "PARALLEL=READ_BCAST;"
#endif
    CHKERR( rval );
    // create a tag to exchange
    Tag dense_test_tag;
    // rval = moab.tag_get_handle( "TEST-TAG", sizeof(EntityHandle), MB_TAG_DENSE,
    //                         dense_test_tag, 0 ); CHKERR(rval);
    rval = moab.tag_get_handle( "TEST-TAG", 1, MB_TYPE_HANDLE, dense_test_tag, MB_TAG_DENSE | MB_TAG_EXCL );CHKERR( rval );
    // exchange tag data
    ParallelComm* pcomm = ParallelComm::get_pcomm( &moab, 0 );
    Range tmp_range;
    rval = pcomm->exchange_tags( dense_test_tag, tmp_range );
    PCHECK( MB_SUCCESS == rval );
    return MB_SUCCESS;
Definition at line 1122 of file parallel_unit_tests.cpp.
References test_interface_owners_common().
ErrorCode report_error ( const char *  file,
int  line
Definition at line 36 of file parallel_unit_tests.cpp.
    std::cerr << "Failure at " << file << ':' << line << std::endl;
    return MB_FAILURE;
int run_test ( ErrorCode(*)(const char *)  func,
const char *  func_name,
const char *  file_name
Definition at line 152 of file parallel_unit_tests.cpp.
References ErrorCode, is_any_proc_error(), MB_SUCCESS, MPI_COMM_WORLD, and rank.
    ErrorCode result = ( *func )( file_name );
    int is_err       = is_any_proc_error( ( MB_SUCCESS != result ) );
    int rank;
    if( rank == 0 )
        if( is_err )
            std::cout << func_name << " : FAILED!!" << std::endl;
        else
            std::cout << func_name << " : success" << std::endl;
    return is_err;
ErrorCode test_assign_global_ids ( const char *  )
Definition at line 1246 of file parallel_unit_tests.cpp.
References moab::ParallelComm::assign_global_ids(), moab::Range::begin(), check_consistent_ids(), CHKERR, moab::Range::end(), ErrorCode, moab::Interface::globalId_tag(), id_tag, mb, MB_SUCCESS, MPI_COMM_WORLD, parallel_create_mesh(), PCHECK, rank, moab::ParallelComm::resolve_shared_ents(), size, moab::Range::size(), moab::Interface::tag_get_data(), and moab::Interface::tag_set_data().
    ErrorCode rval;
    Core moab_instance;
    Interface& mb = moab_instance;
    ParallelComm pcomm( &mb, MPI_COMM_WORLD );
    int rank, size;
    // build distributed quad mesh
    Range quad_range;
    EntityHandle verts[9];
    int vert_ids[9];
    rval = parallel_create_mesh( mb, vert_ids, verts, quad_range );
    rval = pcomm.resolve_shared_ents( 0, quad_range, 2, 1 );
    // get global ids for quads
    assert( 4u == quad_range.size() );
    EntityHandle quads[4];
    std::copy( quad_range.begin(), quad_range.end(), quads );
    int quad_ids[4];
    rval = mb.tag_get_data( id_tag, quads, 4, quad_ids );CHKERR( rval );
    // clear GLOBAL_ID tag
    int zero[9] = { 0 };
    rval        = mb.tag_set_data( id_tag, verts, 9, zero );CHKERR( rval );
    rval = mb.tag_set_data( id_tag, quads, 4, zero );CHKERR( rval );
    // assign new global IDs
    rval = pcomm.assign_global_ids( 0, 2 );
    rval = check_consistent_ids( mb, verts, vert_ids, 9, "vertex", "vertices" );
    rval = check_consistent_ids( mb, quads, quad_ids, 4, "quad", "quads" );
    return rval;
ErrorCode test_delete_entities ( const char *  filename)
Definition at line 1702 of file parallel_unit_tests.cpp.
References moab::Range::begin(), CHKERR, moab::ParallelComm::delete_entities(), moab::Range::end(), ErrorCode, moab::Interface::get_entities_by_dimension(), moab::ParallelComm::get_pcomm(), moab::Core::is_valid(), moab::Interface::load_file(), mb_instance(), MB_SUCCESS, moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), moab::Range::size(), and moab::Interface::write_file().
    Core mb_instance;
    ErrorCode rval;
                           "PARALLEL=READ_PART;"
                           "PARTITION=PARALLEL_PARTITION;"
                           "PARALLEL_RESOLVE_SHARED_ENTS" );CHKERR( rval );
    // Get ghost elements
    // get some edges and faces, and delete some
    Range local;
    rval = moab.get_entities_by_dimension( 0, 1, local );CHKERR( rval );
    rval = moab.get_entities_by_dimension( 0, 2, local );CHKERR( rval );  // it is appending to range
    Range local2;  // extract about half of those
    std::copy( local.begin(), local.begin() + local.size() / 2, range_inserter( local2 ) );
    // delete local 2
    rval = pcomm->delete_entities( local2 );CHKERR( rval );
    for( Range::iterator it = local2.begin(); it != local2.end(); ++it )
        if( mb_instance.is_valid( *it ) ) return MB_FAILURE;
    const char* opt = "PARALLEL=WRITE_PART";
    rval            = moab.write_file( "tmpx.h5m", 0, opt );CHKERR( rval );
    if( pcomm->proc_config().proc_rank() == 0 ) remove( "tmpx.h5m" );
    return MB_SUCCESS;
ErrorCode test_elements_on_several_procs ( const char *  filename)
Definition at line 421 of file parallel_unit_tests.cpp.
References moab::Range::begin(), moab::Core::check_adjacencies(), moab::ParallelComm::check_all_shared_handles(), CHKERR, moab::Range::clear(), dim, moab::Range::empty(), moab::Range::end(), ErrorCode, GEOM_DIMENSION_TAG_NAME, geom_tag, moab::Interface::get_connectivity(), moab::Interface::get_entities_by_dimension(), moab::Interface::get_entities_by_type_and_tag(), moab::ParallelComm::get_pcomm(), get_sharing_processors(), moab::Interface::globalId_tag(), id_tag, moab::Range::insert(), moab::Interface::load_file(), mb_instance(), MB_SUCCESS, MB_TYPE_INTEGER, MBENTITYSET, moab::Range::merge(), PCHECK, moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), moab::Interface::tag_get_data(), and moab::Interface::tag_get_handle().
    Core mb_instance;
    ErrorCode rval;
    const char* geom_names[] = { "vertex", "curve", "surface", "volume", "unknown" };
                           "PARALLEL_SEQUENCE_FACTOR=1.4" );CHKERR( rval );
    // test contents of interface sets against sharedEnts structure in pcomm;
    int my_error        = 0;
    rval                = pcomm->check_all_shared_handles();
        my_error = 1;
        std::cerr << "check_all_shared_handles test failed on proc " << pcomm->proc_config().proc_rank() << std::endl;
    PCHECK( !my_error );
    // check adjacencies just to make sure they're consistent
    rval = mb_instance.check_adjacencies();
    if( MB_SUCCESS != rval ) my_error = 1;
    Tag geom_tag, id_tag;
    rval = moab.tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, geom_tag );CHKERR( rval );
    id_tag = moab.globalId_tag();
    // Because we partitioned based on geometric volume sets, then for each
    // lower-dimension geometric entity set all of the contained entities of
    // the same dimension must be shared by the same set of processors
    Range shared, invalid;
    for( int dim = 2; dim > 0; --dim )
        Range geom_sets;
        const void* tagvals[] = { &dim };
        rval                  = moab.get_entities_by_type_and_tag( 0, MBENTITYSET, &geom_tag, tagvals, 1, geom_sets );CHKERR( rval );
        for( Range::iterator j = geom_sets.begin(); j != geom_sets.end(); ++j )
            Range ents;
            rval = moab.get_entities_by_dimension( *j, dim, ents );CHKERR( rval );
            if( ents.empty() ) continue;
            // get a single sharing list to compare with
            Range::iterator k = ents.begin();
            std::vector< int > procs;
            rval = get_sharing_processors( moab, *k, procs );CHKERR( rval );
            std::sort( procs.begin(), procs.end() );
            if( procs.size() > 1 ) shared.merge( ents );
            // compare other elements
            for( ++k; k != ents.end(); ++k )
                std::vector< int > tmp_procs;
                rval = get_sharing_processors( moab, *k, tmp_procs );CHKERR( rval );
                std::sort( tmp_procs.begin(), tmp_procs.end() );
                if( tmp_procs != procs ) invalid.insert( *j );
            // compare interior vertices
            ents.clear();
            rval = moab.get_entities_by_dimension( *j, 0, ents );CHKERR( rval );
            for( k = ents.begin(); k != ents.end(); ++k )
    // Report any geometric sets for which sharing was inconsistent
    if( !invalid.empty() )
        std::cerr << "Elements or vertices owned by a single geometric entity are "
                  << "not shared by the same set of processors for the "
                  << "following geometric entities on process " << pcomm->proc_config().proc_rank() << ": ";
        for( Range::iterator i = invalid.begin(); i != invalid.end(); ++i )
            int dim;
            int id;
            rval = moab.tag_get_data( geom_tag, &*i, 1, &dim );
            if( MB_SUCCESS != rval ) dim = 4;
            rval = moab.tag_get_data( id_tag, &*i, 1, &id );
            if( MB_SUCCESS != rval ) id = -1;
            std::cerr << geom_names[dim] << " " << id << ", ";
        std::cerr << std::endl;
        my_error = 1;
    // for each shared element, check that its vertices are shared
    // with at least the same processes
    for( Range::iterator i = shared.begin(); i != shared.end(); ++i )
        rval = get_sharing_processors( moab, *i, procs );CHKERR( rval );
        std::vector< EntityHandle > tmp;
        const EntityHandle* conn;
        int len;
        rval = moab.get_connectivity( *i, conn, len, false, &tmp );CHKERR( rval );
        for( int j = 0; j < len; ++j )
            std::vector< int > vprocs;
            rval = get_sharing_processors( moab, conn[j], vprocs );CHKERR( rval );
            std::sort( vprocs.begin(), vprocs.end() );
            std::vector< int > diff( std::max( procs.size(), vprocs.size() ) );
            std::vector< int >::iterator k =
                std::set_difference( procs.begin(), procs.end(), vprocs.begin(), vprocs.end(), diff.begin() );
            if( k != diff.begin() )  // difference is not empty
                invalid.insert( conn[j] );
    // Report any vertices with insufficient sharing
        std::cerr << "Vertices must be shared with at least the union of the processes "
                  << "sharing the elements containing the vertex.  This is NOT true for "
                  << "the following vertices on process " << pcomm->proc_config().proc_rank() << ": " << invalid
                  << std::endl;
        my_error = 1;
    return MB_SUCCESS;
ErrorCode test_ghost_elements ( const char *  filename,
int  num_layers
Definition at line 662 of file parallel_unit_tests.cpp.
References moab::Range::begin(), moab::ParallelComm::check_all_shared_handles(), CHKERR, moab::Range::clear(), dim, moab::Range::empty(), moab::Range::end(), moab::Range::equal_range(), moab::Range::erase(), moab::error(), ErrorCode, moab::ParallelComm::exchange_tags(), GEOM_DIMENSION_TAG_NAME, geom_tag, moab::Interface::get_adjacencies(), moab::Interface::get_child_meshsets(), moab::Interface::get_entities_by_dimension(), get_expected_ghosts(), get_ghost_entities(), moab::ParallelComm::get_pcomm(), moab::ParallelComm::get_shared_entities(), get_sharing_processors(), moab::Interface::globalId_tag(), id_tag, moab::Range::insert(), is_any_proc_error(), moab::Core::load_file(), moab::Interface::load_file(), mb_instance(), MB_SUCCESS, MB_TYPE_INTEGER, MBVERTEX, moab::Range::merge(), moab::ParallelComm::partition_sets(), PCHECK, moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), size, moab::Range::size(), moab::Range::swap(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), moab::Interface::UNION, and vtx().
Referenced by test_ghost_elements_2_0_1(), test_ghost_elements_3_0_1(), test_ghost_elements_3_2_1(), and test_ghost_elements_3_2_2().
    Core mb_instance;
    ErrorCode rval;
    std::ostringstream file_opts;
    file_opts << "PARALLEL=READ_DELETE;"
              << "PARTITION=GEOM_DIMENSION;PARTITION_VAL=3;"
              << "PARTITION_DISTRIBUTE;"
              << "PARALLEL_RESOLVE_SHARED_ENTS;"
              << "PARALLEL_GHOSTS=" << ghost_dimension << '.' << bridge_dimension << '.' << num_layers;
    rval = moab.load_file( filename, 0, file_opts.str().c_str() );CHKERR( rval );
    // Get partition sets
    Range partition_geom[4];
    partition_geom[3]   = pcomm->partition_sets();
    PCHECK( !partition_geom[3].empty() );
    rval = pcomm->check_all_shared_handles();CHKERR( rval );
    // exchange id tags to allow comparison by id
    Range tmp_ents;
    rval = pcomm->get_shared_entities( -1, tmp_ents, -1, false, true );
    rval = pcomm->exchange_tags( id_tag, tmp_ents );CHKERR( rval );
    // Get geometric surfaces
    Range surfs, tmp;
    for( Range::iterator i = partition_geom[3].begin(); i != partition_geom[3].end(); ++i )
        tmp.clear();
        rval = moab.get_child_meshsets( *i, tmp );CHKERR( rval );
        surfs.merge( tmp );
    // Get the set of geometric surfaces that represent the skin
    // of the union of the parts for this processor.  As we partition
    // based on geometric volumes, the interface must be represented
    // by some subset of the surfaces and their child geometric topology.
    int error = 0;
    std::ostringstream error_msg;
    Range ents, iface_surfs, iface_curves, iface_vertices;
    for( Range::iterator i = surfs.begin(); !error && i != surfs.end(); ++i )
        ents.clear();
        rval = moab.get_entities_by_dimension( *i, ghost_dimension - 1, ents );CHKERR( rval );
        std::vector< int > procs, tmp_procs;
        rval              = get_sharing_processors( moab, *j, procs );CHKERR( rval );
        for( ++j; !error && j != ents.end(); ++j )
            tmp_procs.clear();
            rval = get_sharing_processors( moab, *j, tmp_procs );CHKERR( rval );
                error_msg << "Failure at " << __FILE__ << ':' << __LINE__ << std::endl
                          << "\tNot all entities in geometric surface are shared with"
                          << " same processor." << std::endl;
                error = 1;
                break;
        if( error ) break;
        // if surface is not part of inter-proc interface, skip it.
        if( procs.empty() ) continue;
        if( procs.size() != 1 )
                      << "\tSurface elements shared with" << procs.size() << "processors." << std::endl;
            error = 1;
            break;
        int other_rank = procs[0];
        if( other_rank == (int)pcomm->proc_config().proc_rank() ) continue;
        partition_geom[2].insert( *i );
        ents.clear();
        rval = moab.get_child_meshsets( *i, ents );CHKERR( rval );
        partition_geom[1].merge( ents );
    // Don't to global communication until outside
    // of loops.  Otherwise we will deadlock if not all
    // procs iterate the same number of times.
    if( is_any_proc_error( error ) )
        std::cerr << error_msg.str();
        return MB_FAILURE;
    for( Range::iterator i = partition_geom[1].begin(); i != partition_geom[1].end(); ++i )
        ents.clear();
        partition_geom[0].merge( ents );
    std::vector< int > partn_geom_ids[4];
    for( int dim = 0; dim <= 3; ++dim )
        partn_geom_ids[dim].resize( partition_geom[dim].size() );
        rval = moab.tag_get_data( id_tag, partition_geom[dim], &( partn_geom_ids[dim][0] ) );CHKERR( rval );
    // get the global IDs of the ghosted entities
    Range ghost_ents;
    rval = get_ghost_entities( *pcomm, ghost_ents );CHKERR( rval );
    std::pair< Range::iterator, Range::iterator > vtx = ghost_ents.equal_range( MBVERTEX );
    ghost_ents.erase( vtx.first, vtx.second );
    std::vector< int > actual_ghost_ent_ids( ghost_ents.size() );
    rval = moab.tag_get_data( id_tag, ghost_ents, &actual_ghost_ent_ids[0] );CHKERR( rval );
    // read file in serial
    Core moab2;
    rval = moab2.load_file( filename );
    // get the global IDs of the entities we expect to be ghosted
    std::vector< int > expected_ghost_ent_ids;
    rval = get_expected_ghosts( moab2, partn_geom_ids, expected_ghost_ent_ids, ghost_dimension, bridge_dimension,
                                num_layers );
    // check that the correct entities were ghosted
    std::sort( actual_ghost_ent_ids.begin(), actual_ghost_ent_ids.end() );
    std::sort( expected_ghost_ent_ids.begin(), expected_ghost_ent_ids.end() );
    PCHECK( expected_ghost_ent_ids == actual_ghost_ent_ids );
    // check we only have the partitioned and ghosted entities
    // on this processor.
    Range myents;
        ents.clear();
        rval = moab.get_entities_by_dimension( *i, 3, ents );CHKERR( rval );
        myents.merge( ents );
    if( ghost_dimension != 3 )
        ents.clear();
        rval = moab.get_adjacencies( myents, ghost_dimension, false, ents, Interface::UNION );
        myents.swap( ents );
    myents.merge( ghost_ents );
    ents.clear();
    rval = moab.get_entities_by_dimension( 0, ghost_dimension, ents );
    PCHECK( ents == myents );
    if( MB_SUCCESS != rval ) error = 1;
    PCHECK( !error );
    // done
    return MB_SUCCESS;
ErrorCode test_ghost_elements_2_0_1 ( const char *  filename)
Definition at line 844 of file parallel_unit_tests.cpp.
References test_ghost_elements().
    return test_ghost_elements( filename, 2, 0, 1 );
ErrorCode test_ghost_elements_3_0_1 ( const char *  filename)
Definition at line 839 of file parallel_unit_tests.cpp.
    return test_ghost_elements( filename, 3, 0, 1 );
ErrorCode test_ghost_elements_3_2_1 ( const char *  filename)
Definition at line 829 of file parallel_unit_tests.cpp.
    return test_ghost_elements( filename, 3, 2, 1 );
ErrorCode test_ghost_elements_3_2_2 ( const char *  filename)
Definition at line 834 of file parallel_unit_tests.cpp.
    return test_ghost_elements( filename, 3, 2, 2 );
ErrorCode test_ghost_polyhedra ( const char *  filename)
Definition at line 1737 of file parallel_unit_tests.cpp.
References CHKERR, ErrorCode, moab::Interface::load_file(), mb_instance(), and MB_SUCCESS.
    Core mb_instance;
    ErrorCode rval;
                           "PARALLEL_GHOSTS=3.0.1" );CHKERR( rval );
    return MB_SUCCESS;
ErrorCode test_ghost_tag_exchange ( const char *  filename)
Definition at line 861 of file parallel_unit_tests.cpp.
References moab::Range::begin(), CHKERR, moab::Range::clear(), moab::Range::end(), moab::Range::erase(), ErrorCode, moab::ParallelComm::exchange_tags(), moab::Interface::get_entities_by_dimension(), moab::ParallelComm::get_owner(), get_owner_handles(), moab::ParallelComm::get_pcomm(), moab::Range::insert(), moab::Interface::load_file(), mb_instance(), MB_SUCCESS, MB_TAG_DENSE, MB_TAG_EXCL, MB_TYPE_HANDLE, MB_TYPE_INTEGER, PCHECK, moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), rank, moab::Range::size(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), and moab::Interface::tag_set_data().
    Core mb_instance;
    ErrorCode rval;
                           "PARALLEL_GHOSTS=3.2.1;"
                           "PARALLEL_SEQUENCE_FACTOR=1.5" );CHKERR( rval );
    Range local, ghosts;
    rval = moab.get_entities_by_dimension( 0, 3, local );CHKERR( rval );
    Range::iterator i = local.begin();
    while( i != local.end() )
        int rank;
        rval = pcomm->get_owner( *i, rank );CHKERR( rval );
        if( rank == (int)pcomm->proc_config().proc_rank() )
            ++i;
        else
            ghosts.insert( *i );
            i = local.erase( i );
    Tag dense_test_tag;
    EntityHandle defval = 0;
    //                         dense_test_tag, &defval ); CHKERR(rval);
    rval = moab.tag_get_handle( "TEST-TAG", 1, MB_TYPE_HANDLE, dense_test_tag, MB_TAG_DENSE | MB_TAG_EXCL, &defval );CHKERR( rval );
    // for all entities that I own, set tag to handle value
    std::vector< EntityHandle > handles( local.size() ), handles2;
    std::copy( local.begin(), local.end(), handles.begin() );
    rval = moab.tag_set_data( dense_test_tag, local, &handles[0] );CHKERR( rval );
    Range tmp_range;
    rval = pcomm->exchange_tags( dense_test_tag, tmp_range );CHKERR( rval );
    // make sure local values are unchanged
    handles2.resize( local.size() );
    rval = moab.tag_get_data( dense_test_tag, local, &handles2[0] );CHKERR( rval );
    PCHECK( handles == handles2 );
    // compare values on ghost entities
    handles.resize( ghosts.size() );
    handles2.resize( ghosts.size() );
    rval = moab.tag_get_data( dense_test_tag, ghosts, &handles2[0] );CHKERR( rval );
    rval = get_owner_handles( pcomm, ghosts, &handles[0] );CHKERR( rval );
    // now do it all again for a sparse tag
    Tag sparse_test_tag;
    // rval = moab.tag_get_handle( "TEST-TAG-2", sizeof(int), MB_TAG_DENSE,
    //                         MB_TYPE_INTEGER, sparse_test_tag, 0 ); CHKERR(rval);
    rval = moab.tag_get_handle( "TEST-TAG-2", 1, MB_TYPE_INTEGER, sparse_test_tag, MB_TAG_DENSE | MB_TAG_EXCL );CHKERR( rval );
    // for all entiites that I own, set tag to my rank
    std::vector< int > procs1( local.size(), pcomm->proc_config().proc_rank() );
    rval = moab.tag_set_data( sparse_test_tag, local, &procs1[0] );CHKERR( rval );
    tmp_range.clear();
    rval = pcomm->exchange_tags( sparse_test_tag, tmp_range );
    std::vector< int > procs2( local.size() );
    rval = moab.tag_get_data( sparse_test_tag, local, &procs2[0] );CHKERR( rval );
    PCHECK( procs1 == procs2 );
    procs1.resize( ghosts.size() );
    procs2.resize( ghosts.size() );
    rval = moab.tag_get_data( sparse_test_tag, ghosts, &procs2[0] );CHKERR( rval );
    std::vector< int >::iterator j = procs1.begin();
    for( i = ghosts.begin(); i != ghosts.end(); ++i, ++j )
        rval = pcomm->get_owner( *i, *j );CHKERR( rval );
    return MB_SUCCESS;
Definition at line 1134 of file parallel_unit_tests.cpp.
References moab::ParallelComm::check_all_shared_handles(), ErrorCode, moab::ParallelComm::exchange_ghost_cells(), mb, MB_SUCCESS, MPI_COMM_WORLD, parallel_create_mesh(), PCHECK, rank, moab::ParallelComm::resolve_shared_ents(), and size.
    ErrorCode rval;
    Core moab_instance;
    int rank, size;
    Range quads;
    int ids[9];
    rval = parallel_create_mesh( mb, ids, verts, quads );
    rval = pcomm.resolve_shared_ents( 0, quads, 2, 1 );
    rval = pcomm.exchange_ghost_cells( 2, 1, 1, 0, true );
    rval = pcomm.check_all_shared_handles();
    return MB_SUCCESS;
ErrorCode test_interface_owners ( const char *  )
Definition at line 1117 of file parallel_unit_tests.cpp.
ErrorCode test_interface_owners_common ( int  num_ghost_layers)
Definition at line 1069 of file parallel_unit_tests.cpp.
References ErrorCode, moab::ParallelComm::exchange_ghost_cells(), moab::ParallelComm::get_owner(), ierr, mb, MB_SUCCESS, MPI_COMM_WORLD, parallel_create_mesh(), PCHECK, rank, moab::ParallelComm::resolve_shared_ents(), size, and valid_ghosting_owners().
Referenced by regression_owners_with_ghosting(), and test_interface_owners().
    ErrorCode rval;
    Core moab_instance;
    Range quads;
    int ids[9];
    if( num_ghost_layers )
        rval = pcomm.exchange_ghost_cells( 2, 0, num_ghost_layers, 0, true );
    // get vertex owners
    int owner[9];
    for( int i = 0; i < 9; ++i )
        rval = pcomm.get_owner( verts[i], owner[i] );
        if( MB_SUCCESS != rval ) break;
    // exchange vertex owners amongst all processors
    std::vector< int > all_ids( 9 * size ), all_owner( 9 * size );
    ierr = MPI_Gather( ids, 9, MPI_INT, &all_ids[0], 9, MPI_INT, 0, MPI_COMM_WORLD );
    ierr = MPI_Gather( owner, 9, MPI_INT, &all_owner[0], 9, MPI_INT, 0, MPI_COMM_WORLD );
    int errors = rank ? 0 : valid_ghosting_owners( size, &all_ids[0], &all_owner[0] );
    MPI_Bcast( &errors, 1, MPI_INT, 0, MPI_COMM_WORLD );
    return errors ? MB_FAILURE : MB_SUCCESS;
Definition at line 1653 of file parallel_unit_tests.cpp.
References CHKERR, ErrorCode, moab::ParallelComm::get_shared_entities(), mb, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_DOUBLE, MPI_COMM_WORLD, parallel_create_mesh(), PCHECK, rank, moab::ParallelComm::reduce_tags(), moab::ParallelComm::resolve_shared_ents(), size, moab::Range::size(), moab::Interface::tag_delete(), moab::Interface::tag_get_handle(), and moab::Interface::tag_set_data().
    // test tag_reduce stuff with explicit destination tag
    ErrorCode rval;
    Core moab_instance;
    int rank, size;
    Range quad_range;
    int vert_ids[9];
    Tag src_tag, dest_tag;
    Range dum_range;
    double def_dbl = 5.0;
    // src tag has one value, pre-existing dest tag has another; should get MPI_Op of src values
    std::vector< Tag > src_tags, dest_tags;
    // create the tags
    rval = mb.tag_get_handle( "src_tag", 1, MB_TYPE_DOUBLE, src_tag, MB_TAG_DENSE | MB_TAG_CREAT, &def_dbl );CHKERR( rval );
    src_tags.push_back( src_tag );
    rval = mb.tag_get_handle( "dest_tag", 1, MB_TYPE_DOUBLE, dest_tag, MB_TAG_DENSE | MB_TAG_CREAT, &def_dbl );CHKERR( rval );
    dest_tags.push_back( dest_tag );
    // set values for src tag to one value, dest tag to another
    rval = pcomm.get_shared_entities( -1, dum_range, -1, false, false );CHKERR( rval );
    std::vector< double > tag_vals( dum_range.size(), 1.0 );
    rval = mb.tag_set_data( src_tag, dum_range, &tag_vals[0] );CHKERR( rval );
    std::fill( tag_vals.begin(), tag_vals.end(), 2.0 );
    rval = mb.tag_set_data( dest_tag, dum_range, &tag_vals[0] );CHKERR( rval );
    // do the reduce
    rval = pcomm.reduce_tags( src_tags, dest_tags, MPI_SUM, dum_range );CHKERR( rval );
    // check the reduced value
    rval = check_shared_ents< double >( pcomm, dest_tag, (double)1.0, MPI_SUM );CHKERR( rval );
    rval = mb.tag_delete( src_tag );CHKERR( rval );
    rval = mb.tag_delete( dest_tag );CHKERR( rval );
    return MB_SUCCESS;
ErrorCode test_reduce_tag_failures ( const char *  )
Definition at line 1585 of file parallel_unit_tests.cpp.
References CHKERR, ErrorCode, mb, MB_ENTITY_NOT_FOUND, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_DOUBLE, MB_TYPE_INTEGER, MPI_COMM_WORLD, parallel_create_mesh(), PCHECK, rank, moab::ParallelComm::reduce_tags(), moab::ParallelComm::resolve_shared_ents(), size, moab::Interface::tag_delete(), and moab::Interface::tag_get_handle().
    // test things that should fail
    ErrorCode rval;
    Core moab_instance;
    int rank, size;
    Range quad_range;
    int vert_ids[9];
    Tag test_tag;
    Range dum_range;
    int def_int;
    double def_dbl;
    // explicit destination tag of different type
    Tag test_dest;
    rval = mb.tag_get_handle( "test_tag", 1, MB_TYPE_INTEGER, test_tag, MB_TAG_DENSE | MB_TAG_CREAT, &def_int );CHKERR( rval );
    src_tags.push_back( test_tag );
    rval = mb.tag_get_handle( "dtest_tag", 1, MB_TYPE_DOUBLE, test_dest, MB_TAG_DENSE | MB_TAG_CREAT, &def_dbl );CHKERR( rval );
    dest_tags.push_back( test_dest );
    rval = pcomm.reduce_tags( src_tags, dest_tags, MPI_MIN, dum_range );
    PCHECK( rval == MB_FAILURE );
    rval = mb.tag_delete( test_dest );CHKERR( rval );
    rval = mb.tag_delete( test_tag );CHKERR( rval );
    // tag w/ no default value
    rval = mb.tag_get_handle( "test_tag", 1, MB_TYPE_INTEGER, test_tag, MB_TAG_DENSE | MB_TAG_CREAT );CHKERR( rval );
    rval = pcomm.reduce_tags( test_tag, MPI_MIN, dum_range );
    PCHECK( rval == MB_ENTITY_NOT_FOUND );
    return MB_SUCCESS;
ErrorCode test_reduce_tags ( const char *  )
Definition at line 1632 of file parallel_unit_tests.cpp.
References ErrorCode, MB_SUCCESS, MB_TYPE_DOUBLE, and MB_TYPE_INTEGER.
    ErrorCode rval = MB_SUCCESS, tmp_rval;
    tmp_rval = test_reduce_tags< int >( "test_reduce_tags (int)", MB_TYPE_INTEGER );
    if( MB_SUCCESS != tmp_rval )
        std::cout << "test_reduce_tags failed for int data type." << std::endl;
        rval = tmp_rval;
    tmp_rval = test_reduce_tags< double >( "test_reduce_tags (dbl)", MB_TYPE_DOUBLE );
        std::cout << "test_reduce_tags failed for double data type." << std::endl;
        rval = tmp_rval;
    return rval;
ErrorCode test_reduce_tags ( const char *  ,
DataType  tp
Definition at line 1520 of file parallel_unit_tests.cpp.
References check_shared_ents(), CHKERR, ErrorCode, moab::ParallelComm::get_shared_entities(), mb, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MPI_COMM_WORLD, parallel_create_mesh(), PCHECK, rank, moab::ParallelComm::rank(), moab::ParallelComm::reduce_tags(), moab::ParallelComm::resolve_shared_ents(), size, moab::Range::size(), T, moab::Interface::tag_delete(), moab::Interface::tag_get_handle(), and moab::Interface::tag_set_data().
    ErrorCode rval;
    Core moab_instance;
    int rank, size;
    Range quad_range;
    int vert_ids[9];
    Tag test_tag;
    T def_val = 2;
    Range dum_range;
    std::vector< T > dum_vals;
    // T, MPI_SUM
    rval = mb.tag_get_handle( "test_tag", 1, tp, test_tag, MB_TAG_DENSE | MB_TAG_CREAT, &def_val );CHKERR( rval );
    rval = pcomm.reduce_tags( test_tag, MPI_SUM, dum_range );CHKERR( rval );
    rval = check_shared_ents( pcomm, test_tag, (T)2, MPI_SUM );CHKERR( rval );
    // T, MPI_PROD
    rval = pcomm.reduce_tags( test_tag, MPI_PROD, dum_range );CHKERR( rval );
    rval = check_shared_ents( pcomm, test_tag, (T)2, MPI_PROD );CHKERR( rval );
    // T, MPI_MAX
    // get owned entities and set a different value on them
    if( pcomm.rank() == 0 )
        dum_vals.resize( dum_range.size(), (T)3 );
        rval = mb.tag_set_data( test_tag, dum_range, &dum_vals[0] );CHKERR( rval );
    rval = pcomm.reduce_tags( test_tag, MPI_MAX, dum_range );CHKERR( rval );
    rval = check_shared_ents( pcomm, test_tag, (T)3, MPI_MAX );CHKERR( rval );
    // T, MPI_MIN
        std::fill( dum_vals.begin(), dum_vals.end(), (T)-1 );
    rval = pcomm.reduce_tags( test_tag, MPI_MIN, dum_range );CHKERR( rval );
    rval = check_shared_ents( pcomm, test_tag, (T)-1, MPI_MIN );CHKERR( rval );
    return MB_SUCCESS;
ErrorCode test_sequences_after_ghosting ( const char *  filename)
Definition at line 1767 of file parallel_unit_tests.cpp.
References moab::Range::begin(), CHKERR, moab::Interface::connect_iterate(), moab::Interface::coords_iterate(), moab::Range::end(), ErrorCode, moab::Interface::get_entities_by_dimension(), moab::Interface::globalId_tag(), id_tag, moab::Interface::load_file(), mb_instance(), MB_SUCCESS, moab::Range::psize(), moab::Range::size(), and moab::Interface::tag_iterate().
    Core mb_instance;
    ErrorCode rval;
    // get all elements of dimension 3, and check they are on one sequence, with connect_iterate
    Range elems;
    rval = moab.get_entities_by_dimension( 0, 3, elems );CHKERR( rval );
    if( elems.psize() != 1 )
        std::cout << " elems.psize() = " << elems.psize() << "\n";
        return MB_FAILURE;
    // we want only one sequence
    int count, vpere;
    EntityHandle* conn_ptr;
    rval = moab.connect_iterate( elems.begin(), elems.end(), conn_ptr, vpere, count );CHKERR( rval );
    if( count != (int)elems.size() )
        std::cout << " more than one sequence:  elems.size() = " << elems.size() << "  count:" << count << "\n";
        return MB_FAILURE;
    // check also global id tag, which is dense
    Tag id_tag          = moab.globalId_tag();
    void* globalid_data = NULL;
    rval                = moab.tag_iterate( id_tag, elems.begin(), elems.end(), count, globalid_data );CHKERR( rval );
        std::cout << " more than one tag sequence:  elems.size() = " << elems.size() << "  count:" << count << "\n";
        return MB_FAILURE;
    // repeat the tests for vertex sequences
    // get all elements of dimension 3, and check they are on one sequence, with coords_iterate
    Range verts;
    rval = moab.get_entities_by_dimension( 0, 0, verts );CHKERR( rval );
    if( verts.psize() != 1 )
        std::cout << " verts.psize() = " << verts.psize() << "\n";
        return MB_FAILURE;
    double *x_ptr, *y_ptr, *z_ptr;
    rval = moab.coords_iterate( verts.begin(), verts.end(), x_ptr, y_ptr, z_ptr, count );CHKERR( rval );
    if( count != (int)verts.size() )
        std::cout << " more than one sequence:  verts.size() = " << verts.size() << "  count:" << count << "\n";
        return MB_FAILURE;
    rval = moab.tag_iterate( id_tag, verts.begin(), verts.end(), count, globalid_data );CHKERR( rval );
        std::cout << " more than one tag sequence:  verts.size() = " << verts.size() << "  count:" << count << "\n";
        return MB_FAILURE;
    return MB_SUCCESS;
ErrorCode test_shared_sets ( const char *  )
Definition at line 1290 of file parallel_unit_tests.cpp.
References moab::Range::clear(), ErrorCode, moab::ParallelComm::get_entityset_local_handle(), moab::ParallelComm::get_entityset_owner(), moab::ParallelComm::get_entityset_owners(), moab::ParallelComm::get_entityset_procs(), moab::ParallelComm::get_owned_sets(), moab::Interface::globalId_tag(), id_tag, moab::Range::insert(), mb, MB_SUCCESS, MPI_COMM_WORLD, parallel_create_mesh(), PCHECK, rank, moab::ParallelComm::resolve_shared_ents(), moab::ParallelComm::resolve_shared_sets(), and moab::Interface::tag_get_data().
    ErrorCode rval;
    Core moab_instance;
    int rank_i, size_i;
    MPI_Comm_rank( MPI_COMM_WORLD, &rank_i );
    MPI_Comm_size( MPI_COMM_WORLD, &size_i );
    const unsigned rank  = rank_i;
    const unsigned nproc = size_i;
    Range quads, sets;
    EntityHandle verts[9], set_arr[3];
    int ids[9];
    rval = parallel_create_mesh( mb, ids, verts, quads, set_arr );
    sets.insert( set_arr[0] );
    sets.insert( set_arr[1] );
    if( set_arr[2] )
        sets.insert( set_arr[2] );
    else
        set_arr[2] = set_arr[1];
    rval       = pcomm.resolve_shared_sets( sets, id_tag );
    // check that set data is consistent
    ErrorCode ok = MB_SUCCESS;
    for( size_t i = 0; i < 3; ++i )
        unsigned owner;
        EntityHandle owner_handle, local;
        rval = pcomm.get_entityset_owner( set_arr[i], owner, &owner_handle );
            ok = rval;
        else if( owner == rank )
            if( owner_handle != set_arr[i] )
                std::cerr << __FILE__ << ":" << __LINE__ << " rank " << rank << "invalid remote handle for owned set"
                          << std::endl;
                ok = MB_FAILURE;
        else if( MB_SUCCESS != pcomm.get_entityset_local_handle( owner, owner_handle, local ) )
            ok = MB_FAILURE;
        else if( local != set_arr[i] )
            std::cerr << __FILE__ << ":" << __LINE__ << " rank " << rank << "invalid local handle for remote data"
                      << std::endl;
            ok = MB_FAILURE;
    PCHECK( MB_SUCCESS == ok );
    const unsigned col = rank / 2;  // which column is proc in
    const unsigned colrank =
        2 * col;  // rank of first of two procs in col (rank if rank is even, rank-1 if rank is odd)
    unsigned mins[3] = { 0, 0, 0 };
    unsigned maxs[3] = { nproc - 1, 0, 0 };
    if( rank < 2 )
    {  // if in first (left-most) column, then
        mins[1] = mins[2] = 0;
        maxs[1] = maxs[2] = std::min( 3u, nproc - 1 );
    else if( col == ( nproc - 1 ) / 2 )
    {  // else if last (right-most) column, then
        mins[1] = mins[2] = colrank - 2;
        maxs[1] = maxs[2] = std::min( colrank + 1, nproc - 1 );
    else
    {  // if inside column, then
        mins[1] = colrank - 2;
        mins[2] = colrank;
        maxs[1] = std::min( colrank + 1, nproc - 1 );
        maxs[2] = std::min( colrank + 3, nproc - 1 );
    // check expected sharing lists
    // set 0 is shared between all procs in the range [ mins[0], maxs[0] ]
    std::vector< unsigned > expected, list;
        expected.clear();
        for( unsigned r = mins[i]; r <= std::min( maxs[i], nproc - 1 ); ++r )
            if( r != rank ) expected.push_back( r );
        list.clear();
        rval = pcomm.get_entityset_procs( set_arr[i], list );
            ok = rval;
        else
            std::sort( list.begin(), list.end() );
            if( expected != list )
                std::cerr << __FILE__ << ":" << __LINE__ << " rank " << rank << " incorrect sharing list for entity set"
                          << std::endl;
                ok = MB_FAILURE;
    // check consistent owners
    unsigned send_list[6], set_owners[3];
    std::vector< unsigned > recv_list( 6 * nproc );
        mb.tag_get_data( id_tag, set_arr + i, 1, &send_list[2 * i] );
        pcomm.get_entityset_owner( set_arr[i], set_owners[i] );
        send_list[2 * i + 1] = set_owners[i];
    MPI_Allgather( send_list, 6, MPI_UNSIGNED, &recv_list[0], 6, MPI_UNSIGNED, MPI_COMM_WORLD );
    std::map< unsigned, unsigned > owners;
    for( unsigned i = 0; i < 6 * nproc; i += 2 )
        unsigned id    = recv_list[i];
        unsigned owner = recv_list[i + 1];
        if( owners.find( id ) == owners.end() )
            owners[id] = owner;
        else if( owners[id] != owner )
            std::cerr << __FILE__ << ":" << __LINE__ << " rank " << rank << " mismatched owners (" << owners[id]
                      << " and " << owner << ") for set with ID " << id << std::endl;
            ok = MB_FAILURE;
    // test PComm::get_entityset_owners
    std::vector< unsigned > act_owners, exp_owners;
        exp_owners.push_back( set_owners[i] );
    ok = pcomm.get_entityset_owners( act_owners );
    // PCHECK(std::find(act_owners.begin(),act_owners.end(),rank) == act_owners.end());
    std::sort( act_owners.begin(), act_owners.end() );
    std::sort( exp_owners.begin(), exp_owners.end() );
    exp_owners.erase( std::unique( exp_owners.begin(), exp_owners.end() ), exp_owners.end() );
    PCHECK( exp_owners == act_owners );
    // test PComm::get_owned_sets
    ok = MB_SUCCESS;
    for( unsigned i = 0; i < nproc; ++i )
        sets.clear();
        if( MB_SUCCESS != pcomm.get_owned_sets( i, sets ) )
                      << " failed to get shared set list for sets owned by rank " << set_owners[i] << std::endl;
            continue;
        Range expected_range;
        for( size_t j = 0; j < 3; ++j )
            if( set_owners[j] == i ) expected_range.insert( set_arr[j] );
        if( expected_range != sets )
                      << " has incorrect shared set list for sets owned by rank " << set_owners[i] << std::endl
                      << "Expected: " << expected_range << std::endl
                      << "Actual: " << sets << std::endl;
            ok = MB_FAILURE;
    return MB_SUCCESS;
ErrorCode test_too_few_parts ( const char *  filename)
Definition at line 1751 of file parallel_unit_tests.cpp.
References ErrorCode, moab::Interface::load_file(), and mb_instance().
    Core mb_instance;
    ErrorCode rval;
                           "PARALLEL_RESOLVE_SHARED_ENTS;" );
    // if(rval==MB_SUCCESS)
    // return MB_FAILURE;
    return rval;
Definition at line 1840 of file parallel_unit_tests.cpp.
References moab::ParCommGraph::compute_trivial_partition(), MPI_COMM_WORLD, rank, moab::Range::size(), and moab::ParCommGraph::split_owned_range().
    // nothing is modified inside moab
    // by these methods;
    // to instantiate par com graph, we just need 2 groups!
    // they can be overlapping !!!! we do not test that yet
    // create 2 groups; one over task 0 and 1, one over 2
    MPI_Group worldg;
    MPI_Comm duplicate;
    MPI_Comm_dup( MPI_COMM_WORLD, &duplicate );
    MPI_Comm_group( duplicate, &worldg );
    // this is usually run on 2 processes
    int rank[2] = { 0, 1 };
    MPI_Group gr1, gr2;
    MPI_Group_incl( worldg, 2, rank, &gr1 );      // will contain 2 ranks, 0 and 1
    MPI_Group_incl( worldg, 1, &rank[1], &gr2 );  // will contain 1 rank only (1)
    int comp1 = 10, comp2 = 12;
    ParCommGraph* pgr = new ParCommGraph( duplicate, gr1, gr2, comp1, comp2 );
    std::map< int, Range > ranges_to_send;
    std::vector< int > number_elems_per_part;
    number_elems_per_part.push_back( 6 );
    number_elems_per_part.push_back( 10 );
    std::cout << " send sizes ";
    for( int k = 0; k < (int)number_elems_per_part.size(); k++ )
        std::cout << " " << number_elems_per_part[k];
    std::cout << "\n";
    std::cout << "\n";
    pgr->compute_trivial_partition( number_elems_per_part );
    Range verts( 10, 20 );
    pgr->split_owned_range( 0, verts );
    for( std::map< int, Range >::iterator it = ranges_to_send.begin(); it != ranges_to_send.end(); it++ )
        Range& ran = it->second;
        std::cout << " receiver " << it->first << " receive range: [" << ran[0] << ", " << ran[ran.size() - 1]
                  << "] \n";
    delete( pgr );
    MPI_Group_free( &worldg );
    MPI_Group_free( &gr1 );
    MPI_Group_free( &gr2 );
    MPI_Comm_free( &duplicate );
int valid_ghosting_owners ( int  comm_size,
const int *  ids,
const int *  owners
Definition at line 1024 of file parallel_unit_tests.cpp.
References error_count.
Referenced by test_interface_owners_common().
    // for each vertex ID, build list of {rank,owner} tuples
    std::map< int, std::vector< int > > verts;
    for( int p = 0; p < comm_size; ++p )
        {  // nine verts per proc
            int idx = 9 * p + i;
            verts[ids[idx]].push_back( p );
            verts[ids[idx]].push_back( owners[idx] );
    // now check for each vertex that the owner from
    // each processor is the same
    bool print_desc = true;
    int error_count = 0;
    std::map< int, std::vector< int > >::iterator it;
    for( it = verts.begin(); it != verts.end(); ++it )
        int id                   = it->first;
        std::vector< int >& list = it->second;
        bool all_same            = true;
        for( size_t i = 2; i < list.size(); i += 2 )
            if( list[i + 1] != list[1] ) all_same = false;
        if( all_same ) continue;
        ++error_count;
        if( print_desc )
            print_desc = false;
            std::cerr << "ERROR at " __FILE__ ":" << __LINE__ << std::endl
                      << "  Processors have inconsistant ideas of vertex ownership:" << std::endl;
        std::cerr << "  Vertex " << id << ": " << std::endl;
        for( size_t i = 0; i < list.size(); i += 2 )
            std::cerr << "    Proc " << list[i] << " thinks owner is " << list[i + 1] << std::endl;
    return error_count;
