MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "moab/ParallelComm.hpp"#include "moab/Core.hpp"#include "moab_mpi.h"#include "moab/ParallelMergeMesh.hpp"#include "MBParallelConventions.h"#include "TestUtil.hpp"#include <iostream>
Include dependency graph for parmerge_test.cpp:Go to the source code of this file.
Functions | |
| int | main (int argc, char *argv[]) |
| int main | ( | int | argc, |
| char * | argv[] | ||
Definition at line 11 of file parmerge_test.cpp.
References ErrorCode, moab::ParallelComm::filter_pstatus(), moab::Core::get_coords(), moab::Core::get_entities_by_type(), moab::ParallelComm::get_shared_entities(), moab::Core::load_file(), mb, MB_CHK_ERR, MB_SUCCESS, MBVERTEX, moab::ParallelMergeMesh::merge(), MPI_COMM_WORLD, moab::Range::num_of_dimension(), PSTATUS_NOT, PSTATUS_NOT_OWNED, rank, moab::Core::set_coords(), moab::Range::size(), and moab::Core::write_file().
MPI_Init( &argc, &argv );
int nproc, rank;
MPI_Comm_size( MPI_COMM_WORLD, &nproc );
MPI_Comm_rank( MPI_COMM_WORLD, &rank );
std::string filename0 = TestDir + "unittest/brick1.vtk";
std::string filename1 = TestDir + "unittest/brick2.vtk";
moab::Core* mb = new moab::Core();
moab::ParallelComm* pc = new moab::ParallelComm( mb, MPI_COMM_WORLD );
ErrorCode rval = MB_SUCCESS;
if( 0 == rank%2 )
rval = mb->load_file( filename0.c_str() );
else
rval = mb->load_file( filename1.c_str() );
if( rval != MB_SUCCESS )
std::cout << "fail to load file\n";
delete pc;
delete mb;
MPI_Finalize();
return 1;
// if rank > 2, translate in z direction, with the distance ( (rank)/2 ) * 10
if (rank >= 2)
Range verts;
rval = mb->get_entities_by_type(0, MBVERTEX, verts);MB_CHK_ERR( rval );
int num_verts=(int)verts.size();
std::vector<double> coords;
coords.resize(num_verts*3);
rval = mb->get_coords(verts, &coords[0]);MB_CHK_ERR( rval );
int steps=rank/2;
double z_translate = steps*10.;// the 2 bricks are size 10
for (int i=0; i<num_verts; i++)
coords[3*i+2] += z_translate;
rval = mb->set_coords(verts, &coords[0]);MB_CHK_ERR( rval );
ParallelMergeMesh pm( pc, 0.001 );
rval = pm.merge();
std::cout << "fail to merge in parallel \n";
delete pc;
delete mb;
MPI_Finalize();
return 1;
if (nproc == 2)
// check number of shared entities
Range shared_ents;
// Get entities shared with all other processors
rval = pc->get_shared_entities( -1, shared_ents );
delete pc;
delete mb;
MPI_Finalize();
return 1;
// there should be exactly 9 vertices, 12 edges, 4 faces
unsigned numV = shared_ents.num_of_dimension( 0 );
unsigned numE = shared_ents.num_of_dimension( 1 );
unsigned numF = shared_ents.num_of_dimension( 2 );
if( numV != 9 || numE != 12 || numF != 4 )
std::cout << " wrong number of shared entities on proc " << rank << " v:" << numV << " e:" << numE
<< " f:" << numF << "\n";
delete pc;
delete mb;
MPI_Finalize();
return 1;
Range verts, verts_owned;
rval = mb->get_entities_by_type( 0, MBVERTEX, verts );MB_CHK_ERR( rval );
// Get local owned vertices
rval = pc->filter_pstatus( verts, PSTATUS_NOT_OWNED, PSTATUS_NOT, -1, &verts_owned );MB_CHK_ERR( rval );
int num_owned_verts = (int) verts_owned.size();
int num_total_verts = 0;
MPI_Reduce(&num_owned_verts, &num_total_verts, 1, MPI_INT, MPI_SUM, 0,
MPI_COMM_WORLD);
if (0==rank)
std::cout << "total vertex number: " << num_total_verts << "\n";
// each brick has 27 vertices;
// first 2 share 9, total number of vertices should be 27*2 -9 = 45
// for each additional row of 2 bricks, we will have 3*5* 2 = 30 more vertices
int correct = 45 + (nproc/2 - 1) * 30;
if (nproc%2 == 1)
correct += 18; // odd cases have extra 18 nodes (3 * 3 * 2)
if (nproc >= 2 && 0==rank)
if (correct != num_total_verts)
std::cout << "incorrect number of vertices, expected: " << correct << "\n";
delete pc;
delete mb;
MPI_Finalize();
return 1;
rval = mb->write_file( "testpm.h5m", 0, "PARALLEL=WRITE_PART" );MB_CHK_ERR( rval );
std::cout << "fail to write output file \n";
delete pc;
delete mb;
MPI_Finalize();
return 1;
delete pc;
delete mb;
MPI_Finalize();
return 0;
