read_cgm_connectivity_test.cpp File Reference
#include <iostream>
#include "moab/Interface.hpp"
#include "TestUtil.hpp"
#include "Internals.hpp"
#include "moab/Core.hpp"
#include "MBTagConventions.hpp"
#include "InitCGMA.hpp"
#include "GeometryQueryTool.hpp"
#include "moab/MeshTopoUtil.hpp"
+ Include dependency graph for read_cgm_connectivity_test.cpp:
Defines
#define IS_BUILDING_MB
#define CHKERR(A)
Functions
void read_file (Interface *moab, const char *input_file)
void cube_verts_connectivity_test ()
void cube_tris_connectivity_test ()
void cube_tri_curve_coincidence_test ()
void cube_edge_adjacencies_test ()
void cube_tri_vertex_test ()
void match_tri_edges_w_curve (const Range &tri_edges, const Range &curves)
int main (int, char **)
Variables
std::string input_cube = "unittest/io/cube.sat"
Define Documentation
#define CHKERR (   A)
Value:
do        \
        if( MB_SUCCESS != ( A ) )        \
            std::cerr << "Failure (error code " << ( A ) << ") at " __FILE__ ":" << __LINE__ << std::endl; \
            return A;        \
    } while( false )
Definition at line 15 of file read_cgm_connectivity_test.cpp.
Definition at line 4 of file read_cgm_connectivity_test.cpp.
Function Documentation
Definition at line 176 of file read_cgm_connectivity_test.cpp.
References CHECK, CHECK_ERR, ErrorCode, moab::Interface::get_adjacencies(), moab::Interface::get_entities_by_type(), input_cube, mb, MBEDGE, read_file(), and moab::Range::size().
    ErrorCode rval;
    // Open the test file
    Core moab;
    Interface* mb = &moab;
    read_file( mb, input_cube.c_str() );
    // Get the curves
    Range curves;
    rval = mb->get_entities_by_type( 0, MBEDGE, curves );CHECK_ERR( rval );
    for( Range::const_iterator i = curves.begin(); i != curves.end(); ++i )
        // Get triangle adjacent to each edge
        Range adj_tris;
        rval = mb->get_adjacencies( &( *i ), 1, 2, false, adj_tris );CHECK_ERR( rval );
        int num_adj_tris = adj_tris.size();
        // Ensure that no edge is adjacent to more than two triangles
        CHECK( num_adj_tris <= 2 );
Definition at line 123 of file read_cgm_connectivity_test.cpp.
References moab::Range::begin(), CHECK_EQUAL, CHECK_ERR, moab::Range::end(), ErrorCode, moab::Interface::get_adjacencies(), moab::Interface::get_entities_by_type(), input_cube, match_tri_edges_w_curve(), mb, MBEDGE, MBTRI, read_file(), and moab::Range::size().
Referenced by main().
    ErrorCode rval;
    Core moab;
    // Get curves from the mesh
    Range curves;
    curves.print();
    // Get triangles from the mesh
    Range tris;
    rval = mb->get_entities_by_type( 0, MBTRI, tris );CHECK_ERR( rval );
    for( Range::const_iterator i = tris.begin(); i != tris.end(); ++i )
        // Get the any curve edges that are a part of the triangle
        Range tri_edges;
        rval = mb->get_adjacencies( &( *i ), 1, 1, false, tri_edges );CHECK_ERR( rval );
        // Check that we've retrieved two edges from get_adjacencies
        // For a this file (cube), each triangle should have two curve
        // edges
        int num_of_tri_edges = tri_edges.size();
        CHECK_EQUAL( 2, num_of_tri_edges );
        match_tri_edges_w_curve( tri_edges, curves );CHECK_ERR( rval );
Definition at line 201 of file read_cgm_connectivity_test.cpp.
References CHECK, CHECK_ERR, ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_entities_by_type(), input_cube, mb, MBTRI, read_file(), and moab::Range::size().
    ErrorCode rval;
    Core moab;
    // Get all triangles
    Range tris;
        // Get all triangle vertices
        Range verts;
        rval = mb->get_connectivity( &( *i ), 1, verts );CHECK_ERR( rval );
        // Make sure that each vertex making up
        // the triangle is different
        int number_of_verts = verts.size();
        CHECK( 3 == number_of_verts );
        CHECK( verts[0] != verts[1] );
        CHECK( verts[1] != verts[2] );
        CHECK( verts[2] != verts[0] );
Definition at line 92 of file read_cgm_connectivity_test.cpp.
References CHECK_EQUAL, CHECK_ERR, ErrorCode, moab::MeshTopoUtil::get_bridge_adjacencies(), moab::Interface::get_entities_by_type(), input_cube, mb, MBTRI, read_file(), moab::Range::size(), and moab::Range::subset_by_type().
    ErrorCode rval;
    Core moab;
    Range tris;
    int expected_num_of_adj_tris = 3;
    for( Range::const_iterator i = tris.begin() + 1; i != tris.end(); ++i )
        Range adj_tris;
        moab::MeshTopoUtil mu( mb );
        // Use Triangle edges to get all adjacent triangles
        rval = mu.get_bridge_adjacencies( *i, 1, 2, adj_tris );CHECK_ERR( rval );
        CHECK_EQUAL( expected_num_of_adj_tris, (int)adj_tris.size() );
        // Check that the entities we found from bridge_adjacencies
        // are triangles
        Range adj_tri_test = adj_tris.subset_by_type( MBTRI );
        CHECK_EQUAL( (int)adj_tris.size(), (int)adj_tri_test.size() );
Definition at line 66 of file read_cgm_connectivity_test.cpp.
References CHECK, CHECK_ERR, ErrorCode, moab::Interface::get_adjacencies(), moab::Interface::get_entities_by_type(), input_cube, mb, MBVERTEX, and read_file().
    ErrorCode rval;
    Core moab;
    // Get all vertex handles from the mesh
    Range verts;
    rval = mb->get_entities_by_type( 0, MBVERTEX, verts );CHECK_ERR( rval );
    // Check that each vertex connects to at least 4 and no more than 6 triangles
    for( Range::const_iterator i = verts.begin(); i != verts.end(); ++i )
        std::vector< EntityHandle > adj_tris;
        int adj_size = adj_tris.size();
        CHECK( adj_size >= 4 && adj_size <= 6 );
void match_tri_edges_w_curve ( const Range &  tri_edges,
const Range &  curves
Definition at line 155 of file read_cgm_connectivity_test.cpp.
References moab::Range::begin(), CHECK, CHECK_EQUAL, moab::Range::end(), and moab::Range::size().
Referenced by cube_tri_curve_coincidence_test().
    int match_counter    = 0;
    CHECK( num_of_tri_edges );
    for( Range::const_iterator i = tri_edges.begin(); i != tri_edges.end(); ++i )
        for( Range::const_iterator j = curves.begin(); j != curves.end(); ++j )
            // If the edge handle matches a curve handle, increment the number
            // matches
            if( *i == *j ) match_counter++;
    // Make sure that each edge returned from triangle edges
    // has been matched to a curve
    CHECK_EQUAL( num_of_tri_edges, match_counter );
void read_file ( Interface *  moab,
const char *  input_file
Definition at line 57 of file read_cgm_basic_test.cpp.
    InitCGMA::initialize_cgma();
    GeometryQueryTool::instance()->delete_geometry();
    ErrorCode rval = moab->load_file( input_file );CHECK_ERR( rval );
Variable Documentation
Definition at line 28 of file read_cgm_connectivity_test.cpp.
