moab::MeshTopoUtil Class Reference
MeshTopoUtil contains general mesh utility functions. More...
#include <MeshTopoUtil.hpp>
+ Collaboration diagram for moab::MeshTopoUtil:
Public Member Functions
 MeshTopoUtil (Interface *impl)
 ~MeshTopoUtil ()
ErrorCode construct_aentities (const Range &vertices)
 generate all the AEntities bounding the vertices
ErrorCode get_average_position (Range &entities, double *avg_position)
 given an entity, get its average position (avg vertex locations)
ErrorCode get_average_position (const EntityHandle entity, double *avg_position)
ErrorCode get_average_position (const EntityHandle *entities, const int num_entities, double *avg_position)
 given a set of entities, get their average position (avg vertex locations)
ErrorCode get_manifold (const EntityHandle star_entity, const int target_dim, Range &manifold)
ErrorCode star_entities (const EntityHandle star_center, std::vector< EntityHandle > &star_entities, bool &bdy_entity, const EntityHandle starting_star_entity=0, std::vector< EntityHandle > *star_entities_dp1=NULL, Range *star_entities_candidates_dp1=NULL)
ErrorCode star_entities_nonmanifold (const EntityHandle star_entity, std::vector< std::vector< EntityHandle > > &stars, std::vector< bool > *bdy_flags=NULL, std::vector< std::vector< EntityHandle > > *dp2_stars=NULL)
ErrorCode star_next_entity (const EntityHandle star_center, const EntityHandle last_entity, const EntityHandle last_dp1, Range *star_candidates_dp1, EntityHandle &next_entity, EntityHandle &next_dp1)
ErrorCode get_bridge_adjacencies (Range &from_entities, int bridge_dim, int to_dim, Range &to_ents, int num_layers=1)
 get "bridge" or "2nd order" adjacencies, going through dimension bridge_dim
ErrorCode get_bridge_adjacencies (const EntityHandle from_entity, const int bridge_dim, const int to_dim, Range &to_adjs)
EntityHandle common_entity (const EntityHandle ent1, const EntityHandle ent2, const int dim)
 return a common entity of the specified dimension, or 0 if there isn't one
ErrorCode opposite_entity (const EntityHandle parent, const EntityHandle child, EntityHandle &opposite_element)
ErrorCode split_entity_nonmanifold (EntityHandle split_ent, Range &old_adjs, Range &new_adjs, EntityHandle &new_entity)
ErrorCode split_entities_manifold (Range &entities, Range &new_entities, Range *fill_entities)
ErrorCode split_entities_manifold (EntityHandle *entities, const int num_entities, EntityHandle *new_entities, Range *fill_entities, EntityHandle *gowith_ents=NULL)
bool equivalent_entities (const EntityHandle entity, Range *equiv_ents=NULL)
Private Attributes
Interface * mbImpl
Detailed Description
Authors:
Tim Tautges
Date:
2/04
Definition at line 30 of file MeshTopoUtil.hpp.
Definition at line 33 of file MeshTopoUtil.hpp.
: mbImpl( impl ) {}
Definition at line 35 of file MeshTopoUtil.hpp.
Member Function Documentation
EntityHandle moab::MeshTopoUtil::common_entity ( const EntityHandle  ent1,
const int  dim
Definition at line 541 of file MeshTopoUtil.cpp.
References moab::Range::begin(), moab::Range::empty(), ErrorCode, moab::Interface::get_adjacencies(), moab::Range::insert(), MB_SUCCESS, and mbImpl.
Referenced by moab::DualTool::foc_get_ents(), moab::DualTool::fs_check_quad_sense(), moab::AEntityFactory::get_element(), moab::DualTool::get_opposite_verts(), split_entity_nonmanifold(), moab::DualTool::split_pair_nonmanifold(), and star_next_entity().
    Range tmp_range, tmp_range2;
    tmp_range.insert( ent1 );
    tmp_range.insert( ent2 );
    ErrorCode result = mbImpl->get_adjacencies( tmp_range, dim, false, tmp_range2 );
    if( MB_SUCCESS != result || tmp_range2.empty() )
        return 0;
    else
        return *tmp_range2.begin();
Definition at line 37 of file MeshTopoUtil.cpp.
References moab::Range::clear(), ErrorCode, moab::Interface::get_adjacencies(), MB_SUCCESS, mbImpl, and moab::Interface::UNION.
Referenced by SphereDecomp::build_sphere_mesh(), moab::DualTool::construct_dual(), main(), mb_split_test(), and mb_topo_util_test().
    Range out_range;
    ErrorCode result;
    result = mbImpl->get_adjacencies( vertices, 1, true, out_range, Interface::UNION );
    if( MB_SUCCESS != result ) return result;
    out_range.clear();
    result = mbImpl->get_adjacencies( vertices, 2, true, out_range, Interface::UNION );
    out_range.clear();
    result = mbImpl->get_adjacencies( vertices, 3, true, out_range, Interface::UNION );
    return result;
bool moab::MeshTopoUtil::equivalent_entities ( const EntityHandle  entity,
Range *  equiv_ents = NULL
return whether entity is equivalent to any other of same type and same vertices; if equivalent entity is found, it's returned in equiv_ents and return value is true, false otherwise.
Definition at line 978 of file MeshTopoUtil.cpp.
References moab::Interface::dimension_from_handle(), moab::dum, moab::Range::empty(), moab::Range::erase(), ErrorCode, moab::Interface::get_adjacencies(), moab::Interface::get_connectivity(), MB_SUCCESS, mbImpl, and moab::Range::swap().
Referenced by moab::DualTool::face_shrink(), moab::DualTool::rev_face_shrink(), and split_entities_manifold().
    const EntityHandle* connect = NULL;
    int num_connect             = 0;
    ErrorCode result            = mbImpl->get_connectivity( entity, connect, num_connect );
    if( MB_SUCCESS != result ) return false;
    Range dum;
    result = mbImpl->get_adjacencies( connect, num_connect, mbImpl->dimension_from_handle( entity ), false, dum );
    dum.erase( entity );
    if( NULL != equiv_ents )
        equiv_ents->swap( dum );
    if( !dum.empty() )
        return true;
    else
        return false;
ErrorCode moab::MeshTopoUtil::get_average_position ( Range &  entities,
double *  avg_position
ErrorCode moab::MeshTopoUtil::get_average_position ( const EntityHandle  entity,
Definition at line 90 of file MeshTopoUtil.cpp.
References ErrorCode, get_average_position(), moab::Interface::get_connectivity(), moab::Interface::get_coords(), MB_SUCCESS, mbImpl, MBVERTEX, and moab::Interface::type_from_handle().
    if( MBVERTEX == mbImpl->type_from_handle( entity ) ) return mbImpl->get_coords( &entity, 1, avg_position );
    return get_average_position( connect, num_connect, avg_position );
ErrorCode moab::MeshTopoUtil::get_average_position ( const EntityHandle *  entities,
Definition at line 61 of file MeshTopoUtil.cpp.
References moab::Range::begin(), moab::Range::empty(), moab::Range::end(), ErrorCode, moab::Interface::get_adjacencies(), moab::Interface::get_coords(), MB_SUCCESS, mbImpl, moab::Range::size(), and moab::Interface::UNION.
    double dum_pos[3];
    avg_position[0] = avg_position[1] = avg_position[2] = 0.0;
    Range connect;
    ErrorCode result = mbImpl->get_adjacencies( entities, num_entities, 0, false, connect, Interface::UNION );
    if( connect.empty() ) return MB_FAILURE;
    for( Range::iterator rit = connect.begin(); rit != connect.end(); ++rit )
        result = mbImpl->get_coords( &( *rit ), 1, dum_pos );
        avg_position[0] += dum_pos[0];
        avg_position[1] += dum_pos[1];
        avg_position[2] += dum_pos[2];
    avg_position[0] /= (double)connect.size();
    avg_position[1] /= (double)connect.size();
    avg_position[2] /= (double)connect.size();
    return MB_SUCCESS;
ErrorCode moab::MeshTopoUtil::get_bridge_adjacencies ( Range &  from_entities,
int  bridge_dim,
int  to_dim,
Range &  to_ents,
int  num_layers = 1
Definition at line 402 of file MeshTopoUtil.cpp.
References moab::Range::empty(), ErrorCode, moab::Interface::get_adjacencies(), MB_SUCCESS, mbImpl, moab::Range::merge(), nl, moab::subtract(), and moab::Interface::UNION.
Referenced by adj_perf(), ahf_test(), MetisPartitioner::assemble_graph(), ZoltanPartitioner::assemble_graph(), cube_tris_connectivity_test(), moab::DualTool::face_shrink(), moab::DualTool::foc_delete_dual(), moab::ParallelComm::get_ghosted_entities(), iMesh_getEntArr2ndAdj(), iMOAB_GetNeighborElements(), ZoltanPartitioner::partition_owned_cells(), test_adjacencies(), and moab::DualTool::traverse_hyperplane().
    Range bridge_ents, accum_layers, new_toents( from_entities );
    ErrorCode result;
    if( 0 == num_layers || from_entities.empty() ) return MB_FAILURE;
    // for each layer, get bridge-adj entities and accumulate
    for( int nl = 0; nl < num_layers; nl++ )
        Range new_bridges;
        // get bridge ents
        result = mbImpl->get_adjacencies( new_toents, bridge_dim, true, new_bridges, Interface::UNION );
        // get to_dim adjacencies, merge into to_ents
        Range new_layer;
        if( -1 == to_dim )
            result = mbImpl->get_adjacencies( new_bridges, 3, false, new_layer, Interface::UNION );
            for( int d = 2; d >= 1; d-- )
                result = mbImpl->get_adjacencies( to_ents, d, true, new_layer, Interface::UNION );
        else
            result = mbImpl->get_adjacencies( new_bridges, to_dim, false, new_layer, Interface::UNION );
        // subtract last_toents to get new_toents
        accum_layers.merge( new_layer );
        if( nl < num_layers - 1 ) new_toents = subtract( new_layer, new_toents );
    to_ents.merge( accum_layers );
    return MB_SUCCESS;
ErrorCode moab::MeshTopoUtil::get_bridge_adjacencies ( const EntityHandle  from_entity,
const int  to_dim,
Range &  to_adjs
Definition at line 448 of file MeshTopoUtil.cpp.
References moab::Range::clear(), moab::CN::Dimension(), moab::Range::erase(), ErrorCode, moab::Interface::get_adjacencies(), moab::Interface::get_connectivity(), moab::Range::insert(), moab::Interface::INTERSECT, moab::MAX_SUB_ENTITIES, MB_SUCCESS, MBENTITYSET, mbImpl, MBPOLYGON, MBVERTEX, moab::Range::merge(), moab::CN::NumSubEntities(), moab::CN::SubEntityType(), moab::CN::SubEntityVertexIndices(), moab::TYPE_FROM_HANDLE(), moab::Interface::UNION, and moab::CN::VerticesPerEntity().
    // get pointer to connectivity for this entity
    const EntityHandle* connect;
    int num_connect;
    ErrorCode result     = MB_SUCCESS;
    EntityType from_type = TYPE_FROM_HANDLE( from_entity );
    if( from_type == MBVERTEX )
        connect     = &from_entity;
        num_connect = 1;
    else
        result = mbImpl->get_connectivity( from_entity, connect, num_connect );
    if( from_type >= MBENTITYSET ) return MB_FAILURE;
    int from_dim = CN::Dimension( from_type );
    Range to_ents;
    if( bridge_dim < from_dim )
        // looping over each sub-entity of dimension bridge_dim...
        if( MBPOLYGON == from_type )
            for( int i = 0; i < num_connect; i++ )
                // loop over edges, and get the vertices
                EntityHandle verts_on_edge[2] = { connect[i], connect[( i + 1 ) % num_connect] };
                to_ents.clear();
                ErrorCode tmp_result =
                    mbImpl->get_adjacencies( verts_on_edge, 2, to_dim, false, to_ents, Interface::INTERSECT );
                if( MB_SUCCESS != tmp_result ) result = tmp_result;
                to_adjs.merge( to_ents );
        else
            EntityHandle bridge_verts[MAX_SUB_ENTITIES];
            int bridge_indices[MAX_SUB_ENTITIES];
            for( int i = 0; i < CN::NumSubEntities( from_type, bridge_dim ); i++ )
                // get the vertices making up this sub-entity
                int num_bridge_verts = CN::VerticesPerEntity( CN::SubEntityType( from_type, bridge_dim, i ) );
                assert( num_bridge_verts >= 0 && num_bridge_verts <= MAX_SUB_ENTITIES );
                CN::SubEntityVertexIndices( from_type, bridge_dim, i, bridge_indices );
                for( int j = 0; j < num_bridge_verts; ++j )
                    if( bridge_indices[j] >= 0 && bridge_indices[j] < num_connect )
                        bridge_verts[j] = connect[bridge_indices[j]];
                    else
                        bridge_verts[j] = 0;
                // CN::SubEntityConn(connect, from_type, bridge_dim, i, &bridge_verts[0],
                // num_bridge_verts);
                // get the to_dim entities adjacent
                to_ents.clear();
                ErrorCode tmp_result = mbImpl->get_adjacencies( bridge_verts, num_bridge_verts, to_dim, false, to_ents,
    // now get the direct ones too, or only in the case where we're
    // going to higher dimension for bridge
    Range bridge_ents, tmp_ents;
    tmp_ents.insert( from_entity );
    ErrorCode tmp_result = mbImpl->get_adjacencies( tmp_ents, bridge_dim, false, bridge_ents, Interface::UNION );
    if( MB_SUCCESS != tmp_result ) return tmp_result;
    tmp_result = mbImpl->get_adjacencies( bridge_ents, to_dim, false, to_adjs, Interface::UNION );
    // if to_dimension is same as that of from_entity, make sure from_entity isn't
    // in list
    if( to_dim == from_dim ) to_adjs.erase( from_entity );
    return result;
ErrorCode moab::MeshTopoUtil::get_manifold ( const EntityHandle  star_entity,
Range &  manifold
get (target_dim)-dimensional manifold entities connected to star_entity; that is, the entities with <= 1 connected (target_dim+2)-dimensional adjacent entities; for target_dim=3, just return all of them just insert into the list, w/o clearing manifold list first
Definition at line 372 of file MeshTopoUtil.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, moab::Interface::get_adjacencies(), moab::Range::insert(), MB_SUCCESS, mbImpl, moab::Range::merge(), and moab::Range::size().
Referenced by star_entities_nonmanifold().
    // get all the entities of target dimension connected to star
    Range tmp_range;
    ErrorCode result = mbImpl->get_adjacencies( &star_entity, 1, target_dim, false, tmp_range );
    // now save the ones which are (target_dim+1)-dimensional manifold;
    // for target_dim=3, just return whole range, since we don't do 4d
    if( target_dim == 3 )
        manifold.merge( tmp_range );
        return MB_SUCCESS;
    for( Range::iterator rit = tmp_range.begin(); rit != tmp_range.end(); ++rit )
        Range dum_range;
        // get (target_dim+1)-dimensional entities
        result = mbImpl->get_adjacencies( &( *rit ), 1, target_dim + 1, false, dum_range );
        // if there are only 1 or zero, add to manifold list
        if( 1 >= dum_range.size() ) manifold.insert( *rit );
    return MB_SUCCESS;
ErrorCode moab::MeshTopoUtil::opposite_entity ( const EntityHandle  parent,
EntityHandle &  opposite_element
return the opposite side entity given a parent and bounding entity. This function is only defined for certain types of parent/child types; See MBCN.hpp::OppositeSide for details.
Parameters:
parentThe parent element
childThe child element
opposite_elementThe index of the opposite element
return the opposite side entity given a parent and bounding entity. This function is only defined for certain types of parent/child types; See CN.hpp::OppositeSide for details.
Parameters:
Definition at line 560 of file MeshTopoUtil.cpp.
References moab::Interface::dimension_from_handle(), ErrorCode, MB_SUCCESS, mbImpl, moab::CN::OppositeSide(), moab::Interface::side_element(), moab::Interface::side_number(), and moab::Interface::type_from_handle().
Referenced by moab::ReadCCMIO::create_cell_from_faces(), and moab::DualTool::foc_get_ents().
    // get the side no.
    int side_no, offset, sense;
    ErrorCode result = mbImpl->side_number( parent, child, side_no, offset, sense );
    // get the child index from CN
    int opposite_index, opposite_dim;
    int status = CN::OppositeSide( mbImpl->type_from_handle( parent ), side_no, mbImpl->dimension_from_handle( child ),
                                   opposite_index, opposite_dim );
    if( 0 != status ) return MB_FAILURE;
    // now get the side element from MOAB
    result = mbImpl->side_element( parent, opposite_dim, opposite_index, opposite_element );
    return MB_SUCCESS;
ErrorCode moab::MeshTopoUtil::split_entities_manifold ( Range &  entities,
Range &  new_entities,
Range *  fill_entities
split entities that are manifold (shared by two or less entities of each higher dimension), optionally creating an entity of next higher dimension to fill the gap
Parameters:
entitiesThe entities to be split
new_entitiesNew entities, in order of correspondence to that of entities
fill_entitiesIf non-NULL, create an entity of next higher dimension to fill the gap, passing it back in *fill_entities
Definition at line 582 of file MeshTopoUtil.cpp.
References moab::Range::begin(), moab::Range::clear(), moab::Range::end(), ErrorCode, moab::Range::insert(), MB_SUCCESS, and moab::Range::merge().
Referenced by mb_split_test(), and moab::DualTool::split_pair_nonmanifold().
    Range tmp_range, *tmp_ptr_fill_entity;
    if( NULL != fill_entities )
        tmp_ptr_fill_entity = &tmp_range;
    else
        tmp_ptr_fill_entity = NULL;
    for( Range::iterator rit = entities.begin(); rit != entities.end(); ++rit )
        EntityHandle new_entity;
        if( NULL != tmp_ptr_fill_entity ) tmp_ptr_fill_entity->clear();
        EntityHandle this_ent = *rit;
        ErrorCode result      = split_entities_manifold( &this_ent, 1, &new_entity, tmp_ptr_fill_entity );
        new_entities.insert( new_entity );
        if( NULL != fill_entities ) fill_entities->merge( *tmp_ptr_fill_entity );
    return MB_SUCCESS;
ErrorCode moab::MeshTopoUtil::split_entities_manifold ( EntityHandle *  entities,
EntityHandle *  new_entities,
Range *  fill_entities,
EntityHandle *  gowith_ents = NULL
Parameters:
gowith_entsIf non-NULL, each of the new entities will adj to the corresponding gowith entities after the split; this parameter is ignored for boundary split entities; in that case, the split entity remains on the boundary (i.e. not adj to any entity of higher dimension). Dimension of gowith_ents must be the same as entities.
Definition at line 606 of file MeshTopoUtil.cpp.
References moab::Interface::add_adjacencies(), moab::Range::begin(), moab::Interface::create_element(), dim, moab::CN::Dimension(), moab::Range::end(), equivalent_entities(), ErrorCode, moab::Interface::get_adjacencies(), GET_CONNECT_DECL, moab::Range::insert(), MB_SUCCESS, MBEDGE, mbImpl, MBPOLYGON, MBPOLYHEDRON, moab::Range::rbegin(), moab::Interface::remove_adjacencies(), size, TC, moab::TYPE_FROM_HANDLE(), and moab::Interface::type_from_handle().
    // split entities by duplicating them; splitting manifold means that there is at
    // most two higher-dimension entities bounded by a given entity; after split, the
    // new entity bounds one and the original entity bounds the other
#define ITERATE_RANGE( range, it ) for( Range::iterator it = ( range ).begin(); ( it ) != ( range ).end(); ++( it ) )
#define GET_CONNECT_DECL( ent, connect, num_connect )                                     \
    const EntityHandle* connect = NULL;                                                   \
    int num_connect             = 0;                                                      \
        ErrorCode connect_result = mbImpl->get_connectivity( ent, connect, num_connect ); \
        if( MB_SUCCESS != connect_result ) return connect_result;                         \
#define GET_CONNECT( ent, connect, num_connect )                                          \
#define TC                         \
    if( MB_SUCCESS != tmp_result ) \
        result = tmp_result;       \
        continue;                  \
    for( int i = 0; i < num_entities; i++ )
        ErrorCode tmp_result;
        // get original higher-dimensional bounding entities
        Range up_adjs[4];
        // can only do a split_manifold if there are at most 2 entities of each
        // higher dimension; otherwise it's a split non-manifold
        bool valid_up_adjs = true;
        for( int dim = 1; dim <= 3; dim++ )
            tmp_result = mbImpl->get_adjacencies( entities + i, 1, dim, false, up_adjs[dim] );
            TC;
            if( dim > CN::Dimension( TYPE_FROM_HANDLE( entities[i] ) ) && up_adjs[dim].size() > 2 )
                valid_up_adjs = false;
                break;
        if( !valid_up_adjs ) return MB_FAILURE;
        // ok to split; create the new entity, with connectivity of the original
        GET_CONNECT_DECL( entities[i], connect, num_connect );
        result = mbImpl->create_element( mbImpl->type_from_handle( entities[i] ), connect, num_connect, new_entity );
        TC;
        // by definition, new entity and original will be equivalent; need to add explicit
        // adjs to distinguish them; don't need to check if there's already one there,
        // 'cuz add_adjacency does that for us
            if( up_adjs[dim].empty() || dim == CN::Dimension( TYPE_FROM_HANDLE( entities[i] ) ) ) continue;
            if( dim < CN::Dimension( TYPE_FROM_HANDLE( entities[i] ) ) )
                // adjacencies from other entities to this one; if any of those are equivalent
                // entities, need to make explicit adjacency to new entity too
                for( Range::iterator rit = up_adjs[dim].begin(); rit != up_adjs[dim].end(); ++rit )
                    if( equivalent_entities( *rit ) ) result = mbImpl->add_adjacencies( *rit, &new_entity, 1, false );
            else
                // get the two up-elements
                EntityHandle up_elem1 = *( up_adjs[dim].begin() ),
                             up_elem2 = ( up_adjs[dim].size() > 1 ? *( up_adjs[dim].rbegin() ) : 0 );
                // if two, and a gowith entity was input, make sure the new entity goes with
                // that one
                if( gowith_ents && up_elem2 && gowith_ents[i] != up_elem1 && gowith_ents[i] == up_elem2 )
                    EntityHandle tmp_elem = up_elem1;
                    up_elem1              = up_elem2;
                    up_elem2              = tmp_elem;
                mbImpl->remove_adjacencies( entities[i], &up_elem1, 1 );
                // (ok if there's an error, that just means there wasn't an explicit adj)
                tmp_result = mbImpl->add_adjacencies( new_entity, &up_elem1, 1, false );
                TC;
                if( !up_elem2 ) continue;
                // add adj to other up_adj
                tmp_result = mbImpl->add_adjacencies( entities[i], &up_elem2, 1, false );
                TC;
        // if we're asked to build a next-higher-dimension object, do so
        EntityHandle fill_entity = 0;
        EntityHandle tmp_ents[2];
            // how to do this depends on dimension
            switch( CN::Dimension( TYPE_FROM_HANDLE( entities[i] ) ) )
                case 0:
                    tmp_ents[0] = entities[i];
                    tmp_ents[1] = new_entity;
                    tmp_result  = mbImpl->create_element( MBEDGE, tmp_ents, 2, fill_entity );
                    TC;
                    break;
                case 1:
                    tmp_result = mbImpl->create_element( MBPOLYGON, connect, 2, fill_entity );
                    TC;
                    // need to create explicit adj in this case
                    tmp_result = mbImpl->add_adjacencies( entities[i], &fill_entity, 1, false );
                    TC;
                    tmp_result = mbImpl->add_adjacencies( new_entity, &fill_entity, 1, false );
                    TC;
                    break;
                case 2:
                    tmp_result  = mbImpl->create_element( MBPOLYHEDRON, tmp_ents, 2, fill_entity );
                    TC;
                    break;
            if( 0 == fill_entity )
                result = MB_FAILURE;
                continue;
            fill_entities->insert( fill_entity );
        new_entities[i] = new_entity;
    }  // end for over input entities
    return result;
ErrorCode moab::MeshTopoUtil::split_entity_nonmanifold ( EntityHandle  split_ent,
Range &  old_adjs,
Range &  new_adjs,
EntityHandle &  new_entity
split entity which is non-manifold, that is, which has > 2 connected entities of next higher dimension; assumes that there are >= 2 connected regions of (d+2)-dimensional entities; a new d-entity is created for each region after the first, and it's made explicitly-adjacent to the region to which it corresponds
Definition at line 754 of file MeshTopoUtil.cpp.
References moab::Interface::add_adjacencies(), moab::Range::begin(), common_entity(), moab::Interface::create_element(), moab::Interface::create_vertex(), moab::Interface::dimension_from_handle(), moab::Range::end(), ErrorCode, moab::Interface::get_adjacencies(), moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::Range::insert(), mbImpl, MBVERTEX, moab::Interface::remove_adjacencies(), RR, moab::Interface::set_connectivity(), moab::subtract(), moab::Interface::type_from_handle(), and moab::Interface::UNION.
Referenced by moab::DualTool::split_pair_nonmanifold().
    // split an entity into two entities; new entity gets explicit adj to new_adjs,
    // old to old_adjs
    // make new entities and add adjacencies
    // create the new entity
    EntityType split_type = mbImpl->type_from_handle( split_ent );
    ErrorCode result;
    if( MBVERTEX == split_type )
        double coords[3];
        result = mbImpl->get_coords( &split_ent, 1, coords );RR;
        result = mbImpl->create_vertex( coords, new_entity );RR;
    else
        int num_connect;
        result = mbImpl->get_connectivity( split_ent, connect, num_connect );RR;
        result = mbImpl->create_element( split_type, connect, num_connect, new_entity );RR;
        // remove any explicit adjacencies between new_adjs and split entity
        for( Range::iterator rit = new_adjs.begin(); rit != new_adjs.end(); ++rit )
            mbImpl->remove_adjacencies( split_ent, &( *rit ), 1 );
    if( MBVERTEX != split_type )
        //  add adj's between new_adjs & new entity, old_adjs & split_entity
            mbImpl->add_adjacencies( new_entity, &( *rit ), 1, true );
        for( Range::iterator rit = old_adjs.begin(); rit != old_adjs.end(); ++rit )
            mbImpl->add_adjacencies( split_ent, &( *rit ), 1, true );
    else if( split_ent != new_entity )
        // in addition to explicit adjs, need to check if vertex is part of any
        // other entities, and check those entities against ents in old and new adjs
        Range other_adjs;
        for( int i = 1; i < 4; i++ )
            result = mbImpl->get_adjacencies( &split_ent, 1, i, false, other_adjs, Interface::UNION );RR;
        other_adjs = subtract( other_adjs, old_adjs );
        other_adjs = subtract( other_adjs, new_adjs );
        for( Range::iterator rit1 = other_adjs.begin(); rit1 != other_adjs.end(); ++rit1 )
            // find an adjacent lower-dimensional entity in old_ or new_ adjs
            bool found = false;
            for( Range::iterator rit2 = old_adjs.begin(); rit2 != old_adjs.end(); ++rit2 )
                if( mbImpl->dimension_from_handle( *rit1 ) != mbImpl->dimension_from_handle( *rit2 ) &&
                    common_entity( *rit1, *rit2, mbImpl->dimension_from_handle( *rit1 ) ) )
                    found = true;
                    old_adjs.insert( *rit1 );
                    break;
            if( found ) continue;
            for( Range::iterator rit2 = new_adjs.begin(); rit2 != new_adjs.end(); ++rit2 )
                    found = true;
                    new_adjs.insert( *rit1 );
                    break;
            if( !found ) return MB_FAILURE;
        // instead of adjs replace in connectivity
        std::vector< EntityHandle > connect;
            connect.clear();
            result = mbImpl->get_connectivity( &( *rit ), 1, connect );RR;
            std::replace( connect.begin(), connect.end(), split_ent, new_entity );
            result = mbImpl->set_connectivity( *rit, &connect[0], connect.size() );RR;
    return result;
    Commented out for now, because I decided to do a different implementation
    for the sake of brevity.  However, I still think this function is the right
    way to do it, if I ever get the time.  Sigh.
        // split entity d, producing entity nd; generates various new entities,
        // see algorithm description in notes from 2/25/05
      const EntityHandle split_types = {MBEDGE, MBPOLYGON, MBPOLYHEDRON};
      const int dim = CN::Dimension(TYPE_FROM_HANDLE(d));
      MeshTopoUtil mtu(this);
        // get all (d+2)-, (d+1)-cells connected to d
      Range dp2s, dp1s, dp1s_manif, dp2s_manif;
      result = get_adjacencies(&d, 1, dim+2, false, dp2s); RR;
      result = get_adjacencies(&d, 1, dim+1, false, dp1s); RR;
        // also get (d+1)-cells connected to d which are manifold
      get_manifold_dp1s(d, dp1s_manif);
      get_manifold_dp2s(d, dp2s_manif);
        // make new cell nd, then ndp1
      result = copy_entity(d, nd); RR;
      EntityHandle tmp_connect[] = {d, nd};
      EntityHandle ndp1;
      result = create_element(split_types[dim],
                              tmp_connect, 2, ndp1); RR;
        // modify (d+2)-cells, depending on what type they are
      ITERATE_RANGE(dp2s, dp2) {
          // first, get number of connected manifold (d+1)-entities
        Range tmp_range, tmp_range2(dp1s_manif);
        tmp_range.insert(*dp2);
        tmp_range.insert(d);
        tmp_result = get_adjacencies(tmp_range, 1, false, tmp_range2); TC;
        EntityHandle ndp2;
          // a. manif (d+1)-cells is zero
        if (tmp_range2.empty()) {
            // construct new (d+1)-cell
          EntityHandle ndp1a;
          EntityHandle tmp_result = create_element(split_types[dim],
                                                     tmp_connect, 2, ndp1a); TC;
            // now make new (d+2)-cell
          EntityHandle tmp_connect2[] = {ndp1, ndp1a};
          tmp_result = create_element(split_types[dim+1],
                                      tmp_connect2, 2, ndp2); TC;
            // need to add explicit adjacencies, since by definition ndp1, ndp1a will be equivalent
          tmp_result = add_adjacencies(ndp1a, &dp2, 1, false); TC;
          tmp_result = add_adjacencies(ndp1a, &ndp2, 1, false); TC;
          tmp_result = add_adjacencies(ndp1, &ndp2, 1, false); TC;
            // now insert nd into connectivity of dp2, right after d if dim < 1
          std::vector<EntityHandle> connect;
          tmp_result = get_connectivity(&dp2, 1, connect); TC;
          if (dim < 1) {
            std::vector<EntityHandle>::iterator vit = std::find(connect.begin(), connect.end(), d);
            if (vit == connect.end()) {
              continue;
            connect.insert(vit, nd);
          else
            connect.push_back(nd);
          tmp_result = set_connectivity(dp2, connect); TC;
            // if dim < 1, need to add explicit adj from ndp2 to higher-dim ents, since it'll
            // be equiv to other dp2 entities
          if (dim < 1) {
            Range tmp_dp3s;
            tmp_result = get_adjacencies(&dp2, 1, dim+3, false, tmp_dp3s); TC;
            tmp_result = add_adjacencies(ndp2, tmp_dp3s, false); TC;
        } // end if (tmp_range2.empty())
          // b. single manifold (d+1)-cell, which isn't adjacent to manifold (d+2)-cell
        else if (tmp_range2.size() == 1) {
            // b1. check validity, and skip if not valid
            // only change if not dp1-adjacent to manifold dp2cell; check that...
          Range tmp_adjs(dp2s_manif);
          tmp_result = get_adjacencies(&(*tmp_range2.begin()), 1, dim+2, false, tmp_adjs); TC;
          if (!tmp_adjs.empty()) continue;
          EntityHandle dp1 = *tmp_range2.begin();
            // b2. make new (d+1)- and (d+2)-cell next to dp2
            // get the (d+2)-cell on the other side of dp1
          tmp_result = get_adjacencies(&dp1, 1, dim+2, false, tmp_adjs); TC;
          EntityHandle odp2 = *tmp_adjs.begin();
          if (odp2 == dp2) odp2 = *tmp_adjs.rbegin();
            // get od, the d-cell on dp1_manif which isn't d
          tmp_result = get_adjacencies(&dp1_manif, 1, dim, false, tmp_adjs); TC;
          tmp_adjs.erase(d);
          if (tmp_adjs.size() != 1) {
            continue;
          EntityHandle od = *tmp_adjs.begin();
            // make a new (d+1)-cell from od and nd
          tmp_adjs.insert(nd);
          tmp_result = create_element(split_types[1], tmp_adjs, ndp1a); TC;
            // construct new (d+2)-cell from dp1, ndp1, ndp1a
          tmp_adjs.clear();
          tmp_adjs.insert(dp1); tmp_adjs.insert(ndp1); tmp_adjs.insert(ndp1a);
          tmp_result = create_element(split_types[2], tmp_adjs, ndp2); TC;
            // b3. replace d, dp1 in connect/adjs of odp2
          tmp_result = get_connectivity(&odp2, 1, connect); TC;
          if (dim == 0) {
            *(std::find(connect.begin(), connect.end(), d)) = nd;
            remove_adjacency(dp1, odp2);
            // if dp1 was explicitly adj to odp2, remove it
          remove_adjacency
ErrorCode moab::MeshTopoUtil::star_entities ( const EntityHandle  star_center,
std::vector< EntityHandle > &  star_entities,
bool &  bdy_entity,
const EntityHandle  starting_star_entity = 0,
std::vector< EntityHandle > *  star_entities_dp1 = NULL,
Range *  star_entities_candidates_dp1 = NULL
given an entity, find the entities of next higher dimension around that entity, ordered by connection through next higher dimension entities; if any of the star entities is in only entity of next higher dimension, on_boundary is returned true
Definition at line 106 of file MeshTopoUtil.cpp.
References moab::Interface::dimension_from_handle(), moab::Range::erase(), ErrorCode, moab::Interface::get_adjacencies(), MB_SUCCESS, mbImpl, and star_next_entity().
Referenced by moab::DualTool::foc_get_stars(), moab::DualTool::get_radial_dverts(), mb_topo_util_test(), and star_entities_nonmanifold().
    // now start the traversal
    bdy_entity               = false;
    EntityHandle last_entity = starting_star_entity, last_dp2 = 0, next_entity, next_dp2;
    std::vector< EntityHandle > star_dp2;
    ErrorCode result;
    int center_dim = mbImpl->dimension_from_handle( star_center );
    Range tmp_candidates_dp2;
    if( NULL != star_candidates_dp2 )
        tmp_candidates_dp2 = *star_candidates_dp2;
    else
        result = mbImpl->get_adjacencies( &star_center, 1, center_dim + 2, false, tmp_candidates_dp2 );
    do
        // get the next star entity
        result = star_next_entity( star_center, last_entity, last_dp2, &tmp_candidates_dp2, next_entity, next_dp2 );
        // special case: if starting_star_entity isn't connected to any entities of next
        // higher dimension, it's the only entity in the star; put it on the list and return
        if( star_ents.empty() && next_entity == 0 && next_dp2 == 0 )
            star_ents.push_back( last_entity );
            bdy_entity = true;
            return MB_SUCCESS;
        // if we're at a bdy and bdy_entity hasn't been set yet, we're at the
        // first bdy; reverse the lists and start traversing in the other direction; but,
        // pop the last star entity off the list and find it again, so that we properly
        // check for next_dp2
        if( 0 == next_dp2 && !bdy_entity )
            star_ents.push_back( next_entity );
            bdy_entity = true;
            std::reverse( star_ents.begin(), star_ents.end() );
            star_ents.pop_back();
            last_entity = star_ents.back();
            if( !star_dp2.empty() )
                std::reverse( star_dp2.begin(), star_dp2.end() );
                last_dp2 = star_dp2.back();
        // else if we're not on the bdy and next_entity is already in star, that means
        // we've come all the way around; don't put next_entity on list again, and
        // zero out last_dp2 to terminate while loop
        else if( !bdy_entity && std::find( star_ents.begin(), star_ents.end(), next_entity ) != star_ents.end() &&
                 ( std::find( star_dp2.begin(), star_dp2.end(), next_dp2 ) != star_dp2.end() || !next_dp2 ) )
            last_dp2 = 0;
        // else, just assign last entities seen and go on to next iteration
        else
            if( std::find( star_ents.begin(), star_ents.end(), next_entity ) == star_ents.end() )
            if( 0 != next_dp2 )
                star_dp2.push_back( next_dp2 );
                tmp_candidates_dp2.erase( next_dp2 );
            last_entity = next_entity;
            last_dp2    = next_dp2;
    } while( 0 != last_dp2 );
    // copy over the star_dp2 list, if requested
    if( NULL != star_entities_dp2 ) ( *star_entities_dp2 ).swap( star_dp2 );
    return MB_SUCCESS;
ErrorCode moab::MeshTopoUtil::star_entities_nonmanifold ( const EntityHandle  star_entity,
std::vector< std::vector< EntityHandle > > &  stars,
std::vector< bool > *  bdy_flags = NULL,
std::vector< std::vector< EntityHandle > > *  dp2_stars = NULL
Get a series of (d+1)-dimensional stars around a d-dimensional entity, such that each star is on a (d+2)-manifold containing the d-dimensional entity; each star is either open or closed, and also defines a (d+2)-star whose entities are bounded by (d+1)-entities on the star and on the (d+2)-manifold
Definition at line 264 of file MeshTopoUtil.cpp.
References moab::Range::begin(), moab::Interface::dimension_from_handle(), moab::Range::empty(), moab::Range::end(), moab::Range::erase(), ErrorCode, moab::Interface::get_adjacencies(), get_manifold(), MB_SUCCESS, mbImpl, star_entities(), and moab::Interface::UNION.
    // Get a series of (d+1)-dimensional stars around a d-dimensional entity, such that
    // each star is on a (d+2)-manifold containing the d-dimensional entity; each star
    // is either open or closed, and also defines a (d+2)-star whose entities are bounded by
    // (d+1)-entities on the star and on the (d+2)-manifold
    // Algorithm:
    // get the (d+2)-manifold entities; for d=1 / d+2=3, just assume all connected elements, since
    //   we don't do 4d yet
    // get intersection of (d+1)-entities adjacent to star entity and union of (d+1)-entities
    //   adjacent to (d+2)-manifold entities; these will be the entities in the star
    // while (d+1)-entities
    //   remove (d+1)-entity from (d+1)-entities
    //   get the (d+1)-star and (d+2)-star around that (d+1)-entity (using star_entities)
    //   save that star to the star list, and the bdy flag and (d+2)-star if requested
    //   remove (d+2)-entities from the (d+2)-manifold entities
    //   remove (d+1)-entities from the (d+1)-entities
    // (end while)
    int this_dim = mbImpl->dimension_from_handle( star_entity );
    if( 3 <= this_dim || 0 > this_dim ) return MB_FAILURE;
    Range dp2_manifold;
    ErrorCode result = get_manifold( star_entity, this_dim + 2, dp2_manifold );
    // get intersection of (d+1)-entities adjacent to star and union of (d+1)-entities
    //   adjacent to (d+2)-manifold entities; also add manifold (d+1)-entities, to catch
    //   any not connected to (d+2)-entities
    Range dp1_manifold;
    result = mbImpl->get_adjacencies( dp2_manifold, this_dim + 1, false, dp1_manifold, Interface::UNION );
    result = mbImpl->get_adjacencies( &star_entity, 1, this_dim + 1, false, dp1_manifold );
    result = get_manifold( star_entity, this_dim + 1, dp1_manifold );
    while( !dp1_manifold.empty() )
        //   get (d+1)-entity from (d+1)-entities (don't remove it until after star,
        //     since the star entities must come from dp1_manifold)
        EntityHandle this_ent = *dp1_manifold.begin();
        std::vector< EntityHandle > this_star_dp1, this_star_dp2;
        bool on_bdy;
        result = star_entities( star_entity, this_star_dp1, on_bdy, this_ent, &this_star_dp2, &dp2_manifold );
        // if there's no star entities, it must mean this_ent isn't bounded by any dp2
        // entities (wasn't put into star in star_entities 'cuz we're passing in non-null
        // dp2_manifold above); put it in
        if( this_star_dp1.empty() )
            Range dum_range;
            result = mbImpl->get_adjacencies( &this_ent, 1, this_dim + 2, false, dum_range );
            if( dum_range.empty() ) this_star_dp1.push_back( this_ent );
        // now we can remove it
        dp1_manifold.erase( dp1_manifold.begin() );
        if( !this_star_dp1.empty() )
            stars.push_back( this_star_dp1 );
            if( NULL != bdy_flags ) bdy_flags->push_back( on_bdy );
            if( NULL != dp2_stars ) dp2_stars->push_back( this_star_dp2 );
        for( std::vector< EntityHandle >::iterator vit = this_star_dp2.begin(); vit != this_star_dp2.end(); ++vit )
            dp2_manifold.erase( *vit );
        for( std::vector< EntityHandle >::iterator vit = this_star_dp1.begin(); vit != this_star_dp1.end(); ++vit )
            dp1_manifold.erase( *vit );
        // (end while)
    // check for leftover dp2 manifold entities, these should be in one of the
    // stars
    if( !dp2_manifold.empty() )
        for( Range::iterator rit = dp2_manifold.begin(); rit != dp2_manifold.end(); ++rit )
    return MB_SUCCESS;
ErrorCode moab::MeshTopoUtil::star_next_entity ( const EntityHandle  star_center,
Range *  star_candidates_dp1,
EntityHandle &  next_entity,
EntityHandle &  next_dp1
given a star_center, a last_entity (whose dimension should be 1 greater than center) and last_dp1 (dimension 2 higher than center), returns the next star entity across last_dp1, and the next dp1 entity sharing next_entity; if star_candidates is non-empty, star must come from those
Definition at line 191 of file MeshTopoUtil.cpp.
References moab::Range::begin(), moab::Range::clear(), common_entity(), dim, moab::Interface::dimension_from_handle(), moab::Range::empty(), moab::Range::end(), moab::Range::erase(), ErrorCode, moab::Interface::get_adjacencies(), moab::Range::insert(), moab::intersect(), MB_SUCCESS, mbImpl, moab::Range::size(), and moab::Interface::UNION.
Referenced by star_entities().
    // given a star_center, a last_entity (whose dimension should be 1 greater than center)
    // and last_dp1 (dimension 2 higher than center), returns the next star entity across
    // last_dp1, and the next dp1 entity sharing next_entity; if star_candidates is non-empty,
    // star must come from those
    Range from_ents, to_ents;
    from_ents.insert( star_center );
    if( 0 != last_dp1 ) from_ents.insert( last_dp1 );
    int dim = mbImpl->dimension_from_handle( star_center );
    ErrorCode result = mbImpl->get_adjacencies( from_ents, dim + 1, true, to_ents );
    // remove last_entity from result, and should only have 1 left, if any
    if( 0 != last_entity ) to_ents.erase( last_entity );
    // if no last_dp1, contents of to_ents should share dp1-dimensional entity with last_entity
    if( 0 != last_entity && 0 == last_dp1 )
        Range tmp_to_ents;
        for( Range::iterator rit = to_ents.begin(); rit != to_ents.end(); ++rit )
            if( 0 != common_entity( last_entity, *rit, dim + 2 ) ) tmp_to_ents.insert( *rit );
        to_ents = tmp_to_ents;
    if( 0 == last_dp1 && to_ents.size() > 1 && NULL != star_candidates_dp1 && !star_candidates_dp1->empty() )
        // if we have a choice of to_ents and no previous dp1 and there are dp1 candidates,
        // the one we choose needs to be adjacent to one of the candidates
        result = mbImpl->get_adjacencies( *star_candidates_dp1, dim + 1, true, from_ents, Interface::UNION );
        to_ents = intersect( to_ents, from_ents );
    if( !to_ents.empty() )
        next_entity = *to_ents.begin();
    else
        next_entity = 0;
        next_dp1    = 0;
        return MB_SUCCESS;
    // get next_dp1
    if( 0 != star_candidates_dp1 )
        to_ents = *star_candidates_dp1;
    else
        to_ents.clear();
    result = mbImpl->get_adjacencies( &next_entity, 1, dim + 2, true, to_ents );
    // can't be last one
    if( 0 != last_dp1 ) to_ents.erase( last_dp1 );
    if( !to_ents.empty() ) next_dp1 = *to_ents.begin();
    // could be zero, means we're at bdy
    else
        next_dp1 = 0;
    return MB_SUCCESS;
Member Data Documentation
List of all members.
